Home » Eclipse Projects » Buckminster dev » [buckminster-dev] Exporting artifacts (such as WAR files?)
[buckminster-dev] Exporting artifacts (such as WAR files?) [message #32837] Fri, 15 May 2009 12:43 Go to next message
Hi again!
Trying to ask a hopefully more intelligent question:
I can now successfully resolve a cquery in my headless Buckminster. So I
have Buckminster headless resolve
http://www.eclipse.org/buckminster/samples/queries/demo.cque ry
for example.
This will materialize to a workspace with three Eclipse projects in it:
org.demo.worlds - a java project producing a JAR file
org.demo.xml.provider - seems to a plugin project, though I cannot spot
a plugin.xml file ??
org.demo.hello.xml.world - a plugin project which depends on the other two
What would I have to do to make the plugin be exported to some directory
in JAR format?
The use case I have would be a web application which I want to build.
How would I make Buckminster export it as a WAR file automatically?
Or is exporting in Buckminster currently limited to Eclipse stuff such
as Plugins, Feature, RCP products and the like?
Torsten
Re: [buckminster-dev] Exporting artifacts (such as WAR files?) [message #32873 is a reply to message #32837] Fri, 15 May 2009 13:51 Go to previous messageGo to next message
Hi Torsten,
The plugin.xml is not mandatory. It's only needed when the bundle use Eclipse specific things such as extension points.
> in JAR format?
Right click on the project, choose "Buckminster" -> "Invoke Action" -> "bundle.jar"
The output ends up in ${buckminster.output.root}/<bundle name>_<bundle version>-osgi.bundle
buckminster.output.root is set to ${user.temp}/buckminster/build by default. You can set it to any value by providing a
property file to the perform command or by using -vmargs -Dxxx=yyyy. The "invoke action" in the UI will also allow you
to provide a property file.
Buckminster will generate a lot of predefined actions for features and bundles but currently we don't have anything that
will recognize projects that produce war files. The easiest way to accomplish it is to add a buckminster.cspec and an
ant-script to your project. The cspec can contain actions with actor="ant" that calls on the targets in the ant script.
- thomas
Re: [buckminster-dev] Exporting artifacts (such as WAR files?) [message #32908 is a reply to message #32873] Wed, 20 May 2009 06:05 Go to previous message
Hi Thomas,
That's a coincidence; I was just about to post a question on the subject.
We used another approach on one of my projects: we wrote an actor which
did any packaging (including .war), using code based on the packaging
plug-in provided by the JBoss tools project. We wrote a lot of
Buckminster extensions, under the 'Fuller' moniker, including a
Buckminster actor which branded version numbers into the meta-data of
the final artefacts (sorely needed in real-life software development).
You might remember this, because I managed Thomas Spiessens to write
Subversive support for Buckminster. Those were the days!
I was about to upgrade everything, starting from the latest 'Project
Archives' packaging plug-in provided by JBoss tools (Nice! Even nicer
than the previous), yet this time I was keen to get p2 support in.
I want to publish an artefact to a p2 repository, e.g. after the
packaging step has been concluded.
Back to the original question: where are we in terms of p2+Buckminster?
I'm specifically looking for:
- a way to publish artefacts (created by Bucky actors) to p2 repo's
- a way to acquire artefacts from p2 repo's prior to construction (as
building material).
Dann
Thomas Hallgren wrote:
> Hi Torsten,
>> spot a plugin.xml file ??
>> directory in JAR format?
> "bundle.jar"
> default. You can set it to any value by providing a property file to the
> the UI will also allow you to provide a property file.
> bundles but currently we don't have anything that will recognize
> add a buckminster.cspec and an ant-script to your project. The cspec can
> script.
> - thomas
Previous Topic:Re: [buckminster-dev] Buckminster, headless and making the two co-operate
Next Topic:[buckminster-dev] Where can I find buckminster.core 1.1.350.r10332?
Current Time: Tue Sep 16 20:35:58 EDT 2025
Powered by FUDForum. Page generated in 0.02829 seconds
