Home » Archived » BIRT » BIRT report model source released
BIRT report model source released [message #271] Mon, 06 December 2004 18:31 Go to next message
Paul Rogers is currently offline Paul RogersFriend
Today, we released the source code for the org.eclipse.birt.report.model
package. This component implements the reporting model specified in the
Report Object Model (specifications). The code is reasonably complete. It
reads & writes designs, implements a full API, and has a robust set of
unit tests. You can use this code to experiment with BIRT report designs.
Paul Rogers
Actuate Corporation
BIRT PMC
Re: BIRT report model source released [message #281 is a reply to message #271] Mon, 06 December 2004 22:52 Go to previous messageGo to next message
Francois-Xavier Le Louarn is currently offline Francois-Xavier Le LouarnFriend
> designs.
Hi Paul,
I was wondering: where would the code be? I haven't managed to find it
on the dev.eclipse.org CVS server. Have I missed something?
FX.
Re: BIRT report model source released [message #288 is a reply to message #281] Tue, 07 December 2004 00:03 Go to previous message
Originally posted by: smesh.openrules.com
dev.eclipse.org:/home/birt
10x,
Sam Mesh
Previous Topic:Use case
Next Topic:Report Object Model Examples?
Current Time: Sat Dec 21 15:03:26 GMT 2024
Powered by FUDForum. Page generated in 0.02902 seconds
