Home » Eclipse Projects » Eclipse Platform » Dynamic popup menu and objectContribution
Dynamic popup menu and objectContribution [message #323602] Thu, 03 January 2008 15:31 Go to next message
Originally posted by: juraj.bak.gmail.com
I try to create dynamic popup menu on select treeitem in standard Package
explorer or Navigator view. Extension org.eclipse.ui.popupMenus does not
offer possibility to create menu dynamically, but it gives information
about selected items. Extension org.eclipse.ui.menus gives the possibility
to create such menu, but there's no information about selected objects (if
any).
I created one static menu item via org.eclipse.ui.menus and use its
information about selected item while creating dynamic items for
org.eclipse.ui.popupMenus. But it's nasty solution.
Is there a nicer way how to create dynamic popup menu for tree?
Thanks for every advice.
Juraj
Re: Dynamic popup menu and objectContribution [message #323783 is a reply to message #323602] Tue, 08 January 2008 15:50 Go to previous message
Paul Webster is currently offline Paul WebsterFriend
Executing a command from a popup menu will provide the popup menu
selection. When using org.eclipse.ui.menus to fill a popup menu, you
can use "visibleWhen/with variable=activeMenuSelection" to determine
which which of your menu contributions should be included.
Or is your question about using a dynamic element, but the selection is
not provided to your compound contribution item?
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Previous Topic:Deactivating/superseding another plugin
Next Topic:NullPointerException when I install my update site
Current Time: Sat Dec 21 14:40:26 GMT 2024
Powered by FUDForum. Page generated in 0.03019 seconds
