Home » Eclipse Projects » Buckminster dev » Re: [buckminster-dev] Buckminster, headless and making the two co-operate
Re: [buckminster-dev] Buckminster, headless and making the two co-operate [message #32731] Fri, 15 May 2009 12:25
Sorry to bother you guys, this was a JVM problem that has nothing to do
with Buckminster.
I used the -vm parameter to point it to the Sun JVM and all of a sudden
I was able to resolve my project.
Torsten Schlabach schrieb:
> Hi!
> I have a working setup of Buckminster (in my IDE) and I have a
> Buckminster headless installation. So to explain my problem in a simple
> way:
> Works for me:
> http://wiki.eclipse.org/Hello_XML_World_Example_(Buckminster)
> So that's using Buckminster in an IDE.
> Also works for me (partially):
> http://wiki.eclipse.org/Sample_headless_configuration_(Buckminster)
> I was able to finish the "Installing required features" section, so I am
> here:
> ./buckminster listsite
> Features:
> org.eclipse.buckminster.core.headless.feature_1.1.340.r10056
> (Buckminster - Core Headless)
> org.eclipse.buckminster.cvs.headless.feature_1.0.0.r09930 (Buckminster
> - CVS support for headless operation)
> org.eclipse.buckminster.maven.feature_1.1.0.r09904 (Buckminster -
> Maven support)
> org.eclipse.buckminster.pde.headless.feature_1.1.340.r10061
> (Buckminster - PDE support for headless operation)
> org.eclipse.buckminster.product_1.1.340.r10068 (Buckminster Product)
> org.eclipse.buckminster.subversive.headless.feature_1.0.0.r0 9908
> (Buckminster - Subversive based SVN support for headless operation)
> Now I am trying to do something useful as described under "Let's try
> loading a workspace with some very simple test components:"
> Unfortunately
> http://www.eclipse.org/buckminster/samples/queries/build_a.c query
> (the URL used in the example)
> is a 404.
> So I tried the URL from the other IDE based Howto:
> ./buckminster -data fridaysworkspace resolve
> http://www.eclipse.org/buckminster/samples/queries/demo.cque ry
> All I am getting is a single line of output:
> org.xml.sax.SAXNotSupportedException:
> http://apache.org/xml/features/validation/schema
> I guess this may very well be because my headless environment does not
> have a lot of stuff in it. It might not even have a Java compiler for
> examples, does it?
> But my question is: How would I
> a) determine and
> b) install
> the features I would need in my headless environment to build my app?
> Torsten
> _______________________________________________
> buckminster-dev mailing list
> buckminster-dev@eclipse.org
> https://dev.eclipse.org/mailman/listinfo/buckminster-dev
Previous Topic:[buckminster-dev] Buckminster, headless and making the two co-operate
Next Topic:[buckminster-dev] Exporting artifacts (such as WAR files?)
Current Time: Wed Apr 16 14:18:01 EDT 2025
Powered by FUDForum. Page generated in 0.02973 seconds
