Home » Eclipse Projects » Eclipse Platform » Problems with extensionpoint org.eclipse.ui.viewActions
Problems with extensionpoint org.eclipse.ui.viewActions [message #321515] Thu, 18 October 2007 15:36 Go to next message
Hi All,
the enablement for this extensionpoint seems not to work (for me).
I have a ViewPart with a Table viewer in it and
four ActionContributions to this ViewPart.
One Action should always be enabled. That is working.
The other Actions should be enabled when one or more
entries in the table are selected.
But the actions keep disabled.
Here you could see my plugin.xml
<extension
point="org.eclipse.ui.views">
<view
id="de.qatools.smartest.view.param.ParamViewPart"
</view>
</extension>
<extension
point="org.eclipse.ui.viewActions">
<viewContribution
id="de.qatools.smartest.view.param.viewContributionActions"
targetID="de.qatools.smartest.view.param.ParamViewPart">
<action
class="...DeleteParameterAction"
icon="icons/delete.gif"
id="...DeleteParameterAction.id"
label="Delete Parameter"
state="true"
style="push"
toolbarPath="additions"
tooltip="Löscht einen oder mehrere Parameter">
<!-- first try name ist the FQ interface name NOT working-->
<enablement>
<objectClass
name="...IParameter">
</objectClass>
</enablement>
</action>
<action
<!-- THIS IS WORKING -->
class="...AddParameterAction"
enablesFor="*"
icon="icons/add.gif"
id="...AddParameterAction.id"
label="Add Parameter"
state="true"
style="push"
tooltip="Fügt einen neuen Parameter hinzu">
</action>
<action
<!-- second try NOT working-->
class="...DownAction"
enablesFor="+"
icon="icons/down.gif"
id="...DownAction.id"
label="Down"
state="true"
style="push"
toolbarPath="additions">
</action>
</viewContribution>
</extension>
Do you have any ideas?
Thanks in advance
Torsten Link
Re: Problems with extensionpoint org.eclipse.ui.viewActions [message #321546 is a reply to message #321515] Fri, 19 October 2007 11:08 Go to previous message
Your definitions looked fine to me. This example works for me:
<action
class="org.eclipse.ui.examples.contributions.ViewActionDelegate1 "
enablesFor="+"
id="org.eclipse.ui.examples.contributions.action1"
label="%view.action.label"
menubarPath="additions"
style="push">
</action>
[/xml]
It's disabled when there are no selections, enabled otherwise.
Did you make your tree viewer your site selection provider? From InfoView:
viewer = new ListViewer(parent);
.... stuff
getSite().setSelectionProvider(viewer);
Later,
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: Problems with extensionpoint org.eclipse.ui.viewActions [message #321548 is a reply to message #321546] Fri, 19 October 2007 11:05 Go to previous message
Hi Paul,
Thanks a lot.
> <action
> enablesFor="+"
> style="push">
> </action>
> [/xml]
> ... stuff
If I do it right, it is working
> Later,
> PW
Previous Topic:rcp application in os taskbar while splashscreen is displayed
Next Topic:Eclipse won't start up (Ubuntu 7.10 64-Bit)
Current Time: Sat Oct 25 12:04:08 EDT 2025
Powered by FUDForum. Page generated in 0.03255 seconds
