Home » Eclipse Projects » DSDP - Target Management » problem with list with new rse 301
| problem with list with new rse 301 [message #32447] |
Wed, 25 February 2009 08:35  |
Hi all,
hope I'm not doing something wrong but since I moved from rse 2.x to rse 301
I'm having problem with my db model ...
the problem is when I start listing ...
everything works fine when I'm mapping item that are similar to the file
system ... I mean /Test ... /Temp/aaa.xml and so on ...
what about if my file in the db can only be found via a specific url ...
I have seen that the listFile/listFolder of the old FileServiceSubSystem
have been replaced with just a list ...
the problem comes in here ...
// update the parent with it's latest
properties
// null is passed for the second argument because we currently don't get
the parent in our results query
updateRemoteFile(parent, null, monitor);
when parent is null and the internal code will note take care of getting the
absolute path of the object but just the name ... and this even if the
previous call
// query children of the parent
IHostFile[] results = internalList(parentPath, fileNameFilter, fileType,
monitor);
has worked perfectly ...
I don't know if I have been clear?
Ciao
Kar
| Re: problem with list with new rse 301 [message #32517 is a reply to message #32447] |
Mon, 02 March 2009 12:24   |
Hello Kar,
I'm not sure if I got you right, but what you describe sounds like a
normal migration problem as part of migrating to a new major release.
Have you checked the Build Notes to see if there are any migration
guides related to what you see? - I'm sure that there is something
pointing to a bugzilla item that describes the change that was made, why
it was made, and how client code is expected to be changed.
Your entry point into the build notes and release notes could be this:
http://www.eclipse.org/dsdp/tm/development/relnotes/3.0/read me_tm_3.0.html
http://download.eclipse.org/dsdp/tm/downloads/drops/R-3.0-20 0806202130/buildNotes.php
https://bugs.eclipse.org/bugs/show_bug.cgi?id=207178
https://bugs.eclipse.org/bugs/show_bug.cgi?id=162195
Hope that helps,
Martin Oberhuber, Senior Member of Technical Staff, Wind River
Target Management Project Lead, DSDP PMC Member
Kar wrote:
> Hi all,
> 301 I'm having problem with my db model ...
> properties
> don't get the parent in our results query
> the absolute path of the object but just the name ... and this even if
> the previous call
> fileType, monitor);
> Ciao
> Kar
| Re: problem with list with new rse 301 [message #32552 is a reply to message #32447] |
Mon, 02 March 2009 12:27   |
Hello Kar,
Hope that helps,
Kar wrote:
> Hi all,
> properties
> the previous call
> fileType, monitor);
> Ciao
> Kar
| Re: problem with list with new rse 301 [message #32943 is a reply to message #32552] |
Mon, 09 March 2009 06:40   |
Hi Martin sorry for the delay in answering your email ....
thank for the links u sent me ... but I'm still lost ...
So ... I found interesting the article about the rse inizialization one of
the problem I'm having with 3.0.1 too - and we talked about few "posts ago"
(I did try to call something from RSEUIPLUGIN as u suggested ... but no
luck ...
right now if I use the subsystem inside my own view what I get is that it
works fine for me but opening the rse perspective I cannot navigate the tree
for a null adapter ... The same subsystem works fine if I start it the rse
view (I guess once this is correctly initialized ... )
still don't know how to solve this problem (I did had the same problem with
3.0.2)
about the updateRemoteFile inside the list call I could not find anything in
the article u sent ...
what I want just to point out is that u can mount as root folder any mapping
of your subsystem u like (and this is what I do in my rse project) ....
clearly if I work with remote files that are mapped correctly on root
everything is ok (I mean something that start with a '/') ... but the
problem is when u have got something mapped on root that u need to access
via a specific path/uri ... and here clearly the list works fine but NOT the
following call
the root node has parent null and the code will ask again for file name ...
WHY
Kar
"Martin Oberhuber" <martin.oberhuber@windriver.com> wrote in message
news:49AC16FF.9090406@windriver.com...
> Hello Kar,
> Have you checked the Build Notes to see if there are any migration guides
> related to what you see? - I'm sure that there is something pointing to a
> bugzilla item that describes the change that was made, why it was made,
> Hope that helps,
> Cheers,
> Kar wrote:
>> Hi all,
>> properties
>> the previous call
>> fileType, monitor);
>> Ciao
>> Kar
| Re: problem with list with new rse 301 [message #33015 is a reply to message #32943] |
Mon, 09 March 2009 11:00   |
Ok solved the problem of the rse view not working when I was starting the
subsystem from my rcp view.
I do still have the timeout on the .log file ...
Don't know if this is the right thing ... but now I can navigate my
subsystem ...
thanks Martin
public class XXXFileAdapter implements IHostFileToRemoteFileAdapter
private static boolean _init = true;
public AbstractRemoteFile[] convertToRemoteFiles(FileServiceSubSystem
ss,
IRemoteFileContext context, IRemoteFile parent, IHostFile[]
nodes)
if (_init)
ss.initializeSubSystem(new NullProgressMonitor());
_init = false;
public AbstractRemoteFile convertToRemoteFile(FileServiceSubSystem ss,
IRemoteFile parent, IHostFile node)
if (_init)
_init = false;
return file;
"Kar" <carmeloscala@hotmail.com> wrote in message
news:gp2rnt$jbs$1@build.eclipse.org...
> ago" (I did try to call something from RSEUIPLUGIN as u suggested ... but
> no luck ...
> tree for a null adapter ... The same subsystem works fine if I start it
> the rse view (I guess once this is correctly initialized ... )
> with 3.0.2)
> in the article u sent ...
> mapping of your subsystem u like (and this is what I do in my rse project)
> the following call
> ... WHY
> Kar
>> Hello Kar,
>> Hope that helps,
>> Cheers,
>> Kar wrote:
>>> Hi all,
>>> properties
>>> the previous call
>>> fileType, monitor);
>>> Ciao
>>> Kar
| Re: problem with list with new rse 301 [message #33122 is a reply to message #33015] |
Tue, 10 March 2009 14:43  |
Sorry but if you want anybody to help, you'll need to be more specific.
> the subsystem from my rcp view.
> subsystem ...
> thanks Martin
> ss,
> nodes)
> if (_init)
> _init = false;
> ss, IRemoteFileContext context,
> if (_init)
> _init = false;
> return file;
>> one of the problem I'm having with 3.0.1 too - and we talked about few
>> "posts ago" (I did try to call something from RSEUIPLUGIN as u
>> suggested ... but no luck ...
>> it works fine for me but opening the rse perspective I cannot navigate
>> the tree for a null adapter ... The same subsystem works fine if I
>> start it the rse view (I guess once this is correctly initialized ... )
>> with 3.0.2)
>> anything in the article u sent ...
>> project) ....
>> access via a specific path/uri ... and here clearly the list works
>> fine but NOT the following call
>> name ... WHY
>> Kar
>>> Hello Kar,
>>> why it was made, and how client code is expected to be changed.
>>> Hope that helps,
>>> Cheers,
>>> Kar wrote:
>>>> Hi all,
>>>> rse 301 I'm having problem with my db model ...
>>>> file system ... I mean /Test ... /Temp/aaa.xml and so on ...
>>>> FileServiceSubSystem have been replaced with just a list ...
>>>> properties
>>>> currently don't get the parent in our results query
>>>> getting the absolute path of the object but just the name ... and
>>>> this even if the previous call
>>>> fileNameFilter, fileType, monitor);
>>>> Ciao
>>>> Kar
| Re: problem with list with new rse 301 [message #579371 is a reply to message #32447] |
Hello Kar,
Hope that helps,
Kar wrote:
> Hi all,
> properties
> the previous call
> fileType, monitor);
> Ciao
> Kar
| Re: problem with list with new rse 301 [message #579395 is a reply to message #32447] |
Hello Kar,
Hope that helps,
Kar wrote:
> Hi all,
> properties
> the previous call
> fileType, monitor);
> Ciao
> Kar
| Re: problem with list with new rse 301 [message #579583 is a reply to message #32552] |
luck ...
3.0.2)
following call
WHY
Kar
> Hello Kar,
> Hope that helps,
> Cheers,
> Kar wrote:
>> Hi all,
>> properties
>> the previous call
>> fileType, monitor);
>> Ciao
>> Kar
| Re: problem with list with new rse 301 [message #579629 is a reply to message #32943] |
subsystem ...
thanks Martin
ss,
nodes)
if (_init)
_init = false;
if (_init)
_init = false;
return file;
> no luck ...
> with 3.0.2)
> the following call
> ... WHY
> Kar
>> Hello Kar,
>> Hope that helps,
>> Cheers,
>> Kar wrote:
>>> Hi all,
>>> properties
>>> the previous call
>>> fileType, monitor);
>>> Ciao
>>> Kar
| Re: problem with list with new rse 301 [message #579696 is a reply to message #33015] |
> subsystem ...
> thanks Martin
> ss,
> nodes)
> if (_init)
> _init = false;
> if (_init)
> _init = false;
> return file;
>> with 3.0.2)
>> project) ....
>> name ... WHY
>> Kar
>>> Hello Kar,
>>> Hope that helps,
>>> Cheers,
>>> Kar wrote:
>>>> Hi all,
>>>> properties
>>>> Ciao
>>>> Kar
Current Time: Wed Nov 05 21:32:06 EST 2025
Powered by FUDForum. Page generated in 0.27503 seconds
