Home » Archived » M2M (model-to-model transformation) » Command line access to Extend language
Command line access to Extend language [message #32074] Mon, 16 April 2007 13:48 Go to next message
Originally posted by: norman.astro.gla.ac.uk
Greetings.
[Forgive me if this is the wrong group; where ought I to be?]
I've been pointed towards oAW, and its transformation support, by an
enthusiastic, but geographically distant, colleague.
Re: [ATL] Command line access to Extend language [message #32111 is a reply to message #32074] Mon, 16 April 2007 14:30 Go to previous messageGo to next message
Xtend, as part of oAW, is hosted by the GMT project. You would therefore
probably get more answers about it if you asked Xtend-related questions
in the GMT newsgroup. Please prefix the subject of your posts there on
Xtend with [oAW].
I am only answering the ATL-related part of your question here. This is
why I added the [ATL] prefix in the subject.
There are already two OWL-related ATL use cases that you might want to
consider:
http://www.eclipse.org/m2m/atl/usecases/ODMImplementation/
http://www.eclipse.org/m2m/atl/usecases/SharingRulesBetweenO CLUML_SWRLOWL/
As for running ATL from the command line, there is usually no problem
doing so. The following Howto gives information related to using ATL
from the command-line:
http://wiki.eclipse.org/index.php/ATL_Howtos#How_do_I_launch _transformations_programmatically.3F
Frédéric Jouault
Norman Gray wrote:
> Greetings.
> enthusiastic, but geographically distant, colleague. The Extend
> language looks useful, and I'd like to play around with it. I'm aiming
> to transform UML models, expressed in XMI, to other formats, most
> specifically OWL/RDF (which has an XML serialisation); Extend appears to
> be a good way of doing that, which means I don't have to worry about
> subtleties of, or changes in, the XMI spec.
> I'm not sure how to get started, though, since the tutorials on
> <http://www.eclipse.org/gmt/oaw/doc/>, though they look excellent, all
> appear to assume that you're using Eclipse. There are hints towards the
> end of the Extend Language Reference that you can call Extend from Java,
> but with the implication that you would write the corresponding few-line
> main program yourself, which suggests I'm missing something.
> The Workflow Reference mentions a
> org.openarchitectureware.workflow.WorkflowRunner, but that class isn't
> in any obvious place within the SDK download (it's not
> in plugins/org.openarchitectureware.workflow_4.1.2.v20070314.ja r, for
> example). The emfExample tutorial doesn't mention this.
> Similarly, the `Getting Started with oAW 4.1' screencast is expressed in
> terms of Eclipse. I found a couple of rather oblique mentions of
> command-line access to ATL in this group; should I be using ATL instead?
> Am I missing a tutorial, or is the workflow reference the only guidance
> on how to get started with Extend on the command line?
> Thanks for any pointers. Best wishes,
> Norman
Re: [ATL] Command line access to Extend language [message #32146 is a reply to message #32111] Mon, 16 April 2007 16:22 Go to previous message
Salut Fr
Previous Topic:author to Person
Next Topic:[ATL] EBNF Injection warnings - with MDR
Current Time: Sun Apr 27 01:06:27 EDT 2025
Powered by FUDForum. Page generated in 0.03399 seconds
