Integrating my plugin with Clearcase team support [message #317593] |
Mon, 09 July 2007 19:27 |
Warwick Burrows Messages: 132 Registered: July 2009 Location: Austin, TX |
Hi, I'm looking for information on how to properly integrate my plugin
with eclipse team support such that modifications to files will
automatically cause the Clearcase team plugin to intercept the request,
prompt to checkout the file, create an activity when needed, etc, just as
it does when working with files in a clearcase integrated project. I find
that when I run my plugin and edit files that are under source control
that the clearcase plugin (CCRC) is not prompting to create activities and
add new files to source control and not always prompting to checkout files
even when an activity is available. Is there any documentation on the
correct way to manipulate files so that the team interfaces are called?
I'm wrapping my filesystem interaction in IWorkspaceRunnable objects as is
suggested in the brief documentation on integration with the workbench and
am using the IFile, IFolder, etc objects to create or modify the files and
folders. I would appreciate any pointers to documentation or examples
that can help.
Warwick
Re: Integrating my plugin with Clearcase team support [message #317629 is a reply to message #317593] |
Tue, 10 July 2007 17:13 |
Michael Valenta Messages: 560 Registered: July 2009 |
Warwick,
You need to call the IWorkspace#validateEdit method to request that any
read-only files be made writable by the repository provider before
allowing the user to make any changes in an editor.
Michael
> as it does when working with files in a clearcase integrated project. I
> find that when I run my plugin and edit files that are under source
> control that the clearcase plugin (CCRC) is not prompting to create
> activities and add new files to source control and not always prompting
> to checkout files even when an activity is available. Is there any
> documentation on the correct way to manipulate files so that the team
> interfaces are called? I'm wrapping my filesystem interaction in
> IWorkspaceRunnable objects as is suggested in the brief documentation on
> integration with the workbench and am using the IFile, IFolder, etc
> objects to create or modify the files and folders. I would appreciate
> any pointers to documentation or examples that can help.
> Warwick
FUDForum. Page generated in 0.02646 seconds
