Home » Eclipse Projects » Eclipse Platform » Annoying Search view appears in 3.3RC4
Annoying Search view appears in 3.3RC4 [message #317164] Wed, 27 June 2007 09:29 Go to next message
I've recently updgraded to eclipse 3.3RC4 and I get this annoying Search
view appearing on top of my main coding view. To reproduce, open a Java
file, double click on its tab to make it "full screen", then right click
on a method and choose References > Project. I also get the same thing
with the Debug view. Is there any way to turn it off?
Re: Annoying Search view appears in 3.3RC4 [message #317166 is a reply to message #317164] Wed, 27 June 2007 09:55 Go to previous message
John,
This is just the way the new maximized editors work. When you do an
action that would normally be displayed in a view and that view isn't
visible, it comes up as a quick view. Clicking on the editor again will
make that quick view disappear. I'm not sure if you'd have been happier
if you did a search and absolutely nothing appeared to happen. That
would seem very confusing...
> Search view appearing on top of my main coding view. To reproduce,
> open a Java file, double click on its tab to make it "full screen",
> then right click on a method and choose References > Project. I also
> get the same thing with the Debug view. Is there any way to turn it off?
Previous Topic:view problem
Next Topic:Tabbed Properties
Current Time: Sun Apr 27 02:54:07 EDT 2025
Powered by FUDForum. Page generated in 0.02567 seconds
