Home » Language IDEs » PHP Development Tools (PDT) » couple of feature requests: file search
couple of feature requests: file search [message #31880] Tue, 26 June 2007 20:08 Go to next message
Originally posted by: eclipsenews.20.epm.spamgourmet.com
I'm not sure if this is a PDT thing or just an eclipse thing so I'm
posting here to find out where I should post my feature requests.
Both relate to the search dialog.
When accessed via ctrl-h, could it remember which tab/settings you used
previously and take you straight back there? It's kind of annoying that
it always defaults to the php function search, most of the time I use it
for file search since I normally can jump straight to a function/class
by ctrl-clicking anyway.
The other thing is that if your 'navigator' view is detached from the
main eclipse window, the checkbox to search 'Selected Resources' doesn't
work, you get '0 matches in empty scope'. This seems more a
straightforward bug, but my suspicion is that this is a bug with eclipse
itself.
Cheers
Tom
Re: couple of feature requests: file search [message #32615 is a reply to message #31880] Fri, 29 June 2007 08:54 Go to previous messageGo to next message
Originally posted by: pavel.dvorak.work.gmail.com
i agree
Tom Walter napsal(a):
> used previously and take you straight back there? It's kind of
> annoying that it always defaults to the php function search, most of
> the time I use it for file search since I normally can jump straight
> to a function/class by ctrl-clicking anyway.
> doesn't work, you get '0 matches in empty scope'. This seems more a
> eclipse itself.
> Cheers
> Tom
Re: couple of feature requests: file search [message #32968 is a reply to message #32615] Tue, 03 July 2007 06:55 Go to previous messageGo to next message
Hi list,
Amongst other things, I also agree quite a lot frankly but don't feel
the urge to post that feelings.
As for the problem, have you tried
Window->Preferences->General->Keys
Switch "Category" to "Search", "Name" to "File Search", and remap Ctrl-H
with it. Should take you directly to the "File Search" - Tab when
pressing Ctrl-H, instead of the "PHP Search" Tab.
another Tom
pavel.dvorak.work@gmail.com wrote:
> i agree
>> eclipse itself.
>> Cheers
>> Tom
Re: couple of feature requests: file search [message #33278 is a reply to message #32968] Tue, 03 July 2007 19:49 Go to previous messageGo to next message
Awesome. Thanks for the tip!
I stand by the second thing though about the 'Selected Resources' thing
should work properly even if the navigator view is detached...
Thomas Nickl wrote:
> Hi list,
> Cheers,
> another Tom
>> i agree
>>> eclipse itself.
>>> Cheers
>>> Tom
Re: couple of feature requests: file search [message #64157 is a reply to message #32968] Sun, 06 January 2008 08:34 Go to previous message
Hi Thomas
I also find this bug very annoying because I use the file search very
extensively (it is soo useful in a big project!)
BUT I can't make your tip work?
What to mean by "switch name to File search"? I don't have a "file
search" entry under my Window->Preferences->General->Keys setting.
I hope I can make your tip work it would save me lots of time :)
Cheers
Matt
Thomas Nickl wrote:
> Hi list,
> Cheers,
> another Tom
>> i agree
>>> eclipse itself.
>>> Cheers
>>> Tom
Previous Topic:(How) can i create code snippets?
Next Topic:imported syntax highlighting
Current Time: Fri Apr 25 18:00:22 EDT 2025
Powered by FUDForum. Page generated in 0.04440 seconds
