Home » Eclipse Projects » Eclipse Platform » Builder Trouble
Builder Trouble [message #2734] Tue, 22 April 2003 11:04 Go to next message
Hi Folks,
I'm trying to programmatically install a builder into the list of
builders for a JDT project. It seems that the builder gets inserted
into the build list ok. But when I try to run a build, I get the
following error.
================ Eclipse Error Log ===============================
!ENTRY org.eclipse.core.resources 2 1 Apr 17, 2003 20:28:24.989
!MESSAGE Skipping builder com.abc.plugins.builders.PropSelect for
project KillerProperties. Either the builder is missing from the
install, or it belongs to a project nature that is missing or disabled.
My builder is not associated with a project nature. Is is necessary to
associate a builder with a nature (as described in "Project Builders and
Natures") in order to have a builder actually run?
That article describes Nature dependencies whereby one nature depending
on another nature would cause its builder to run after the dependency's
builder. In my case, I would like my builder to run BEFORE the JDT
builders. I didn't notice a method to enforce this other than inserting
the builder as first in the list.
- Paul
Re: Builder Trouble [message #2760 is a reply to message #2734] Tue, 22 April 2003 11:18 Go to previous messageGo to next message
Originally posted by: genadyb.inter.net.il
I think you need to have it associated with a nature, but you can still
have it as the first builder in the list.
Genady
Paul Glezen wrote:
> Hi Folks,
> following error.
> - Paul
Re: Builder Trouble [message #4371 is a reply to message #2760] Tue, 22 April 2003 15:18 Go to previous messageGo to next message
Cool. I can do that. When I manually install an external build tool
using the project's property dialog, does it get a nature associated
with it under the covers? I guess "no" because the association is from
the nature to the builder. I don't see a way to associate a builder
with a nature dynamically.
- Paul
Re: Builder Trouble [message #4723 is a reply to message #4371] Tue, 22 April 2003 18:13 Go to previous messageGo to next message
You should do it programmatically. Here is what I do:
IProjectDescription descr = project.getProject().getDescription();
String natures[] = descr.getNatureIds();
for (int i = 0; i < natures.length; i++) {
if (natures[i].equals(RMIProjectNature.NATURE_ID)) {
return;
String newNatures[] = new String[natures.length+1];
System.arraycopy(natures, 0, newNatures, 0, natures.length);
newNatures[natures.length] = RMIProjectNature.NATURE_ID;
descr.setNatureIds(newNatures);
project.getProject().setDescription(descr, null);
and the nature class has:
public void configure() throws CoreException {
ICommand rmiBuilder = descr.newCommand();
rmiBuilder.setBuilderName(RMIBuilder.BUILDER_ID);
ICommand builders[] = descr.getBuildSpec();
for (int i = 0; i < builders.length; i++) {
if (builders[i].getBuilderName().equals(RMIBuilder.BUILDER_ID)) {
return;
ICommand newBuilders[] = new ICommand[builders.length+1];
System.arraycopy(builders, 0, newBuilders, 0, builders.length);
newBuilders[builders.length] = rmiBuilder;
descr.setBuildSpec(newBuilders);
project.setDescription(descr, null);
> - Paul
>> still have it as the first builder in the list.
Re: Builder Trouble [message #7823 is a reply to message #2734] Wed, 23 April 2003 17:21 Go to previous message
Originally posted by: John_Arthorne.oti.com_
Your builder does not HAVE to belong to a nature. You can create an
install a builder without any nature being involved. However, you
generally should associate a nature, because:
- natures give the configure() and deconfigure() lifecycle hooks that
can be used for installing and removing your builder.
- natures can depend on other natures. You can use these dependencies
to ensure your builder is installed after the JDT builder by making your
nature depend on the JDT nature.
I suspect your error is actually due to an incorrectly specified builder
id. The builder Id (name) used in the build spec must be the same as
the fully qualified id of your builder's extension. If plugin com.xyz
installs a builder with extension id ="PropSelect", then the "builder
name" in the build command must be "com.xyz.PropSelect". If this didn't
make sense, just post your plugin.xml and I will tell you what your
builder name in the build spec should be.
Paul Glezen wrote:
> Hi Folks,
> following error.
> - Paul
Previous Topic:make C-o open/show Outline view?
Next Topic:Problem using Ant
Current Time: Sat Oct 18 21:28:05 EDT 2025
Powered by FUDForum. Page generated in 0.03731 seconds
