Home » Archived » M2M (model-to-model transformation) » CPL2SPL sample does not work with ATL_bundle eclipse
CPL2SPL sample does not work with ATL_bundle eclipse [message #31790] |
Sun, 15 April 2007 21:38  |
Originally posted by: miwamasa.ieee.org
The sample project CPL2SPL seems not working with
Development build(February 16, 2007).
I have tested with ATL_bundle(for windows only) version.
There are two problems. "[1]CPL2SPL error" and "[2]TCS loading
error(SPL.tcs)"
[1]CPL2SPL error
When applying CPL2SPL with sample AComplexExample.cpl
I got Error like this,
********************************* ERROR *********************************
Message: cannot set feature SPL!Dialog.methods to value null
A.main() : ??#60 null
local variables = {self=CPL2SPL : ASMModule}
local stack = []
A.__exec__() : ??#8 null
local variables = {self=CPL2SPL : ASMModule, e=TransientLink {rule =
'CPL2Program', sourceElements = {s = IN!<unnamed>}, targetElements =
{dialog = OUT!<unnamed>, service = OUT!unnamed, t = OUT!<unnamed>},
variables = {}}}
local stack = []
A.__applyCPL2Program(1 : NTransientLink;) : ??#54 42:25-42:69
local variables = {t=OUT!<unnamed>, dialog=OUT!<unnamed>, s=IN!<unnamed>,
self=CPL2SPL : ASMModule, service=OUT!unnamed, link=TransientLink {rule =
variables = {}}}
local stack = [OUT!<unnamed>]
[2]TCS loading error(SPL.tcs)
[am3.loadModel] Loading of model SPL.tcs
[am3.loadModel] java.lang.NullPointerException
[am3.loadModel] at
org.atl.engine.repositories.emf4atl.ASMEMFModelElement.set(A SMEMFModelElement.java:193)
[am3.loadModel] at
org.atl.engine.injectors.ebnf.EBNFInjector2.set(EBNFInjector 2.java:903)
[am3.loadModel] at
org.atl.engine.injectors.ebnf.EBNFInjector2.set(EBNFInjector 2.java:450)
[am3.loadModel] at
org.atl.engine.injectors.ebnf.TCSParser.operator(TCSParser.j ava:3829)
[am3.loadModel] at
org.atl.engine.injectors.ebnf.TCSParser.priority(TCSParser.j ava:1163)
[am3.loadModel] at
org.atl.engine.injectors.ebnf.TCSParser.concreteSyntax(TCSPa rser.java:289)
[am3.loadModel] at
org.atl.engine.injectors.ebnf.TCSParser.main(TCSParser.java: 65)
Re: CPL2SPL sample does not work with ATL_bundle eclipse [message #32355 is a reply to message #31790] |
Tue, 17 April 2007 16:33   |
This is the self reply. Despite the ERROR message on the consle,
CPL2SPL.atl generates target SPL ecore model (seemes fine) by setting
the launch configuration.
<booleanAttribute key="ContinueAfterError" value="true"/>
I still have [2]TCS loading error(SPL.tcs), which causes all
the operation definitions in TCS is out of the recognition in
the text transformation.
> error(SPL.tcs)"
> [1]CPL2SPL error
> local stack = []
> variables = {}}}
> local stack = []
> variables = {}}}
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
Re: [ATL] CPL2SPL sample does not work with ATL_bundle eclipse [message #32427 is a reply to message #32355] |
Tue, 17 April 2007 19:20  |
Thank you for this additional information.
This will hopefully help us investigating the issue.
Frédéric Jouault
P.S.: Could you please prefix the subject of your ATL-related posts with
[ATL] within this newsgroup?
> Miki Iwamasa wrote:
>> The sample project CPL2SPL seems not working with Development
>> error(SPL.tcs)"
>> [1]CPL2SPL error
>> local stack = []
>> = 'CPL2Program', sourceElements = {s = IN!<unnamed>}, targetElements =
>> variables = {}}}
>> local stack = []
>> s=IN!<unnamed>, self=CPL2SPL : ASMModule, service=OUT!unnamed,
>> link=TransientLink {rule = 'CPL2Program', sourceElements = {s =
>> IN!<unnamed>}, targetElements = {dialog = OUT!<unnamed>, service =
>> OUT!unnamed, t = OUT!<unnamed>}, variables = {}}}
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
>> [am3.loadModel] at
Current Time: Fri Apr 25 19:16:34 EDT 2025
Powered by FUDForum. Page generated in 0.07035 seconds
