FastPartitioner throwing NPEs in latest 3.3 integration build [message #315198] |
Fri, 04 May 2007 21:28 |
Originally posted by: mark_melvin.amis.com
Hi There,
We are trying to port our codebase to 3.3 and I have run across an issue I
can't see how to immediately work around. I have implemented a generic
"Code Templates" preference page that applies to more than one language.
I wrote a very simply implementation to dynamically unhook the current
SourceViewerConfiguration and hook up a new one with different syntax
highlighting based on the context of the current selected code template.
It has worked in past versions of Eclipse but in 3.3 it explodes. I get
the following stack trace:
!ENTRY org.eclipse.jface 4 2 2007-05-04 17:17:50.859
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.jface".
!STACK 0
org.eclipse.jface.text.rules.FastPartitioner.initialize(Fast Partitioner.java:163)
org.eclipse.jface.text.rules.FastPartitioner.checkInitializa tion(FastPartitioner.java:151)
org.eclipse.jface.text.rules.FastPartitioner.computePartitio ning(FastPartitioner.java:613)
org.eclipse.jface.text.AbstractDocument.computePartitioning( AbstractDocument.java:1302)
org.eclipse.jface.text.TextUtilities.computePartitioning(Tex tUtilities.java:428)
org.eclipse.jface.text.presentation.PresentationReconciler.c reatePresentation(PresentationReconciler.java:448)
org.eclipse.jface.text.presentation.PresentationReconciler.p rocessDamage(PresentationReconciler.java:565)
org.eclipse.jface.text.presentation.PresentationReconciler.a ccess$3(PresentationReconciler.java:563)
org.eclipse.jface.text.presentation.PresentationReconciler$I nternalListener.documentPartitioningChanged(PresentationReco nciler.java:139)
org.eclipse.jface.text.presentation.PresentationReconciler$I nternalListener.documentPartitioningChanged(PresentationReco nciler.java:153)
org.eclipse.jface.text.AbstractDocument.fireDocumentPartitio ningChanged(AbstractDocument.java:565)
org.eclipse.jface.text.AbstractDocument.setDocumentPartition er(AbstractDocument.java:1407)
com.amis.sk2x.ui.text.SK2xDocumentSetupParticipant.setup(SK2 xDocumentSetupParticipant.java:46)
Now I am using the exact same document setup participant as my editors and
they work fine. I have traced it through and it seems that in the case of
my editors, the call to <mydocumentsetupparticipant>.setup() does not fire
a partitioning changed event - but in the simplistic source viewer on my
template page it does (for some reason). This happens just before my
partitioner is even connected to the document - hence the NPE. This seems
like a regression in the platform. Can any jface gurus give me a hint as
to what is going on here and how to fix it?
Mark.
Re: FastPartitioner throwing NPEs in latest 3.3 integration build [message #315280 is a reply to message #315278] |
Mon, 07 May 2007 16:01 |
Daniel Megert wrote:
> Mark Melvin wrote:
>> Hi There,
>> issue I can't see how to immediately work around. I have implemented
>> a generic "Code Templates" preference page that applies to more than
>> one language. I wrote a very simply implementation to dynamically
>> unhook the current SourceViewerConfiguration and hook up a new one
>> with different syntax highlighting based on the context of the current
>> selected code template. It has worked in past versions of Eclipse but
>> in 3.3 it explodes. I get the following stack trace:
>> !STACK 0
>> java.lang.NullPointerException
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> and they work fine. I have traced it through and it seems that in the
>> case of my editors, the call to <mydocumentsetupparticipant>.setup()
>> does not fire a partitioning changed event - but in the simplistic
>> source viewer on my template page it does (for some reason). This
>> happens just before my partitioner is even connected to the document -
>> hence the NPE. This seems like a regression in the platform. Can any
>> jface gurus give me a hint as to what is going on here and how to fix it?
> We didn't touch the FastPartitioner for almost a year but of course some
> other change might cause what you see. If you can boil this down to
> reproducible example then please file a bug report.
> Dani
Thanks, Dani. I just figured out how to make it work. In my code that
configures the SourceViewer, I used to do:
public void configureViewer(SourceViewer viewer) {
MySourceViewerConfiguration configuration = new
MySourceViewerConfiguration(null);
viewer.configure(configuration);
new MyDocumentSetupParticipant().setup(viewer.getDocument());
Reversing the last two lines fixes the problem. So now my method looks
like:
...and all is well.
Thanks for the reply.
Mark.
FUDForum. Page generated in 0.02869 seconds
