Syntax highlighting - Different background color in some items [message #314931] |
Fri, 27 April 2007 20:09 |
Originally posted by: xmontero.dsitelecom.com
Hello all.
I think this is my first post, although I have a user created since some years
ago. Perhaps I someday posted. Anyway hello. Here I go:
- I use Eclipse for editing PHP.
- I use white background, although I would like to use green background and
white fore, but only for comments, the rest continuing with white background.
- I think the version I use does not permit this.
- I use Eclipse version 3.0.1 buidid 200409161125. The PHP subsystem should be
of a similar date or so.
QUESTIONS:
1) Does a newer version of either Eclipse or the PHP sub-engine allow a single
item of syntax highlighting to have the background color changed? I mean: Could
I do that simply by downloading a new version?
2) It is clear that the "renderer" of the editor may change background colors,
as for example, the selected line has a different color. If there is no
interface for settling the config, at least could I tweak a config file directly
to achieve that?
3) If none is possible, how could I contribute to improve the code to setup that
option?
Thanks in advance for all.
Xavi.
Re: Syntax highlighting - Different background color in some items [message #314979 is a reply to message #314931] |
Mon, 30 April 2007 16:04 |
Joe Scylla Messages: 3 Registered: July 2009 |
Junior Member |
well maybe i don't understand your question but with the current version
of PDT (http://www.zend.com/pdt) it's possible to change the background
and foreground of comments in your php-code.
I don't know if PHPEclipse (http://www.phpeclipse.de/) supports that
feature.
You didn't notice what plugin you use for editing php files.
best regards
Joe
Xavier Montero wrote:
> Hello all.
> years ago. Perhaps I someday posted. Anyway hello. Here I go:
> and white fore, but only for comments, the rest continuing with white
> background.
> should be of a similar date or so.
> QUESTIONS:
> single item of syntax highlighting to have the background color changed?
> I mean: Could I do that simply by downloading a new version?
> colors, as for example, the selected line has a different color. If
> there is no interface for settling the config, at least could I tweak a
> config file directly to achieve that?
> setup that option?
> Xavi.
Re: Syntax highlighting - Different background color in some items [message #314980 is a reply to message #314979] |
Mon, 30 April 2007 16:34 |
Hi Joe.
> with the current version of PDT [...]
> and foreground of comments [...]
That was what I was looking for: To upgrade or not. I'll do. Thanks.
I don't know how to check the version of my current PDT. I installed it some
years ago and I am also unaware to remember which directory it is in.
Let me a way to find and I'll tell my current PDT version.
Thank you very much!!!!
Xavi.
FUDForum. Page generated in 0.05485 seconds
