Re: resource loading [message #314231 is a reply to message #314211] |
Thu, 05 April 2007 12:11 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Alex,
Most often you'd use a path that doesn't start with "/" to look up the
resource in the same folder as the .class file itself.
Aleksandr Krvavets wrote:
> Hello,
> I have a file in my plugin that I am trying to read. I am using
> getClass().getResource() to load the file but always get
> NullPointerException. What's the input string to getResource() should
> be to correctly identify the file? I am trying to pass the whole
> package path to the file, but nothing works.
> thanks,
> Alex
Re: resource loading [message #314245 is a reply to message #314231] |
Thu, 05 April 2007 14:32 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Aleksandr Kravets![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=aleksandr.kravets%40gmail.com) Messages: 30 Registered: July 2009 |
Member |
Thanks Ed,
Right, the file that is in the same package as executing class I can
get, but I meant file in the plugin's root directory:
com.ak.myplugin:
src
xslt
file.xslt
I want to read file.xslt from class in src directory.
Also, when I create file from with the executing class' directory:
URL url = this.getClass().getResource("file.xslt");
File file = new File(url.toString());
I get file with path:
bundleresource:\1187\com\ak\wizard\file.xslt
Then, when I try to read this file using BufferedReader, the file cannot
be found.
thanks,
Alex
Ed Merks wrote:
> Alex,
>> Hello,
>> thanks,
>> Alex
Re: resource loading [message #314254 is a reply to message #314245] |
Thu, 05 April 2007 15:42 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Alex,
I think you'd use this.getClass().getResource("/file.xslt") but you
can't assume that the URL that comes back is a file: URL. It could be a
jar, or as you see, an OSGi-specific scheme. Can't you use
URL.openStream directly? You could also use a URL of the form
platform:/plugin/<plugin-ID>/file.xslt directly and open the stream for
that.
> Thanks Ed,
> com.ak.myplugin:
> src
> xslt
> file.xslt
> cannot be found.
> thanks,
> Alex
> Ed Merks wrote:
>> Alex,
>> the resource in the same folder as the .class file itself.
>>> Hello,
>>> should be to correctly identify the file? I am trying to pass the
>>> whole package path to the file, but nothing works.
>>> thanks,
>>> Alex
FUDForum. Page generated in 0.03385 seconds
