Home » Eclipse Projects » Eclipse Platform » problems with undo in SourceViewer
problems with undo in SourceViewer [message #313992] Fri, 30 March 2007 06:59 Go to next message
Originally posted by: starkom.ngs.ru
Hi, i'm using my own subclass of SourceViewer in my editor. There is suc=
h =
code in it:
protected void handleVisibleDocumentAboutToBeChanged(DocumentEv=
ent =
event) {
if (!isRollback) {
if (isUndesirableChange(event.getOffset(), =
event.getOffset() + event.getLength())) {
oldText =3D getTextWidget().getText();
} else {
super.handleVisibleDocumentAboutToBeChanged(event);=
protected void handleVisibleDocumentChanged(DocumentEvent event=
if (oldText !=3D null && !isRollback) {
isRollback =3D true;
getTextWidget.getContent().setText(oldText);
isRollback =3D false;
oldText =3D null;
} else {
super.handleVisibleDocumentChanged(event);
This works fine with all undesirable changes of my document. But if =
rollback of undesirable change is occured and then client call "undo" =
operation,
exception occured:
org.eclipse.core.commands.ExecutionException: While undoing the operatio=
n, =
an exception occurred
at =
org.eclipse.core.commands.operations.DefaultOperationHistory .doUndo(Defa=
ultOperationHistory.java:429)
at =
org.eclipse.core.commands.operations.DefaultOperationHistory .undo(Defaul=
tOperationHistory.java:1244)
at =
org.eclipse.ui.operations.UndoActionHandler.runCommand(UndoA ctionHandler=
..java:66)
at =
org.eclipse.ui.operations.OperationHistoryActionHandler$4.ru n(OperationH=
istoryActionHandler.java:279)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Caused by: org.eclipse.jface.util.Assert$AssertionFailedException: =
Assertion failed:
at org.eclipse.jface.util.Assert.isTrue(Assert.java:182)
at org.eclipse.jface.util.Assert.isTrue(Assert.java:167)
at =
org.eclipse.ui.internal.texteditor.quickdiff.compare.rangedi fferencer.Ra=
ngeDifferencer.findDifferencesUkkonen(RangeDifferencer.java: 169)
at =
ultOperationHistory.java:413)
What is wrong in my code? And what is right concept of implementing =
untouchable text in SourceViewer?
Re: problems with undo in SourceViewer [message #314000 is a reply to message #313992] Fri, 30 March 2007 10:31 Go to previous messageGo to next message
> such code in it:
> protected void
> handleVisibleDocumentAboutToBeChanged(DocumentEvent event) {
> if (!isRollback) {
> oldText = getTextWidget().getText();
> } else {
> event) {
> if (oldText != null && !isRollback) {
> isRollback = true;
> isRollback = false;
> oldText = null;
> } else {
Well, only for those entered into the viewer. If the underlying document
gets changed this approach will fail. As I don't see all code but I can
say that the code as posted is not supported by the source viewer.
Dani
> But if rollback of undesirable change is occured and then client call
> "undo" operation,
> exception occured:
> operation, an exception occurred
> at
> org.eclipse.core.commands.operations.DefaultOperationHistory .doUndo(DefaultOperationHistory.java:429)
> at
> org.eclipse.core.commands.operations.DefaultOperationHistory .undo(DefaultOperationHistory.java:1244)
> at
> org.eclipse.ui.operations.UndoActionHandler.runCommand(UndoA ctionHandler.java:66)
> at
> org.eclipse.ui.operations.OperationHistoryActionHandler$4.ru n(OperationHistoryActionHandler.java:279)
> Assertion failed:
> at
> org.eclipse.ui.internal.texteditor.quickdiff.compare.rangedi fferencer.RangeDifferencer.findDifferencesUkkonen(RangeDiffe rencer.java:169)
> at
> org.eclipse.core.commands.operations.DefaultOperationHistory .doUndo(DefaultOperationHistory.java:413)
Re: problems with undo in SourceViewer [message #314025 is a reply to message #314000] Mon, 02 April 2007 01:51 Go to previous message
On Fri, 30 Mar 2007 21:31:43 +0700, Daniel Megert =
<daniel_megert@ch.ibm.com> wrote:
> Well, only for those entered into the viewer. If the underlying docume=
nt =
> gets changed this approach will fail. As I don't see all code but I ca=
n =
> Dani
I's all code:
private class InternalProjectionViewer extends SourceViewer {
private String oldText =3D null;
private boolean isRollback =3D false;
public InternalProjectionViewer(Composite parent, IVerticalRule=
r =
ruler, IOverviewRuler overviewRuler, boolean showsAnnotationOverview, in=
t =
styles) {
super(parent, ruler, overviewRuler, showsAnnotationOverview=
styles);
ent =
event) {
if (!isRollback) {
if (isHeader(event.getOffset(), event.getOffset() =
} else {
oldText =3D null;
} else {
protected ISourceViewer createSourceViewer(Composite parent, =
IVerticalRuler ruler, int styles) {
ISourceViewer viewer =3D new InternalProjectionViewer(parent, r=
uler, =
getOverviewRuler(), isOverviewRulerVisible(), styles);
return viewer;
But how can I restore text correctly after undesirable change of it? I =
tried use getUndoManager().undo(), but it modifies undo-redo history and=
I =
can't handle that history directly. I tried save getDocument() in =
aboutToBeChanged event dipatcher and restore it with setDocument(). I =
tried getDocument.set(oldText). But all these workarounds works =
incorrectly.
The problem is that I can't deny any text-change actions. Keyboards' =
changes denies by such listener added to TextWidget:
private class InternalVerifyListener implements VerifyListener {
public void verifyText(VerifyEvent e) {
if (isHeader(e.start, e.end)) {
e.doit =3D false;
return;
But actions send aboutToBeChanged event and work anyway :(
Previous Topic:Re: not getting IFile
Next Topic:Several questions regarding extension points
Current Time: Wed Sep 17 12:05:16 EDT 2025
Powered by FUDForum. Page generated in 0.04083 seconds
