Home » Eclipse Projects » Eclipse Platform » VM constantly crashes with Eclipse 3.2.2 on Linux
VM constantly crashes with Eclipse 3.2.2 on Linux [message #313338] |
Tue, 13 March 2007 16:57 |
Anima Gupta Messages: 44 Registered: July 2009 |
Member |
--------------080100080405050707040208
Content-Type: text/plain; charset=us-ascii; format=flowed
Hi -
I have been unsuccessful in running my eclipse 3.2.2 install on Linux
(redhat 9, gtk) - It crashes after sometime.
I have tried changing the vmargs -Xmx params, jvm 1.4 to 1.5_05 but the
no matter I am able to crash it after couple of minutes or opening 5-10
java files.
It exists each time giving Hotspot erros and differen exit code, 11, 6 etc
I have been able to run eclipse 3.1 on the same linux box with no issues -
Is someone using eclipse3.2 on redhat 9 with success? Can you give me
some pointers? Attached are 2 logfiles on different jvms I have tried -
Thanks -
Anima.
name="hs_err_pid14564_on_jvm1.5.log"
Content-Disposition: inline;
filename="hs_err_pid14564_on_jvm1.5.log"
# An unexpected error has been detected by HotSpot Virtual Machine:
# SIGSEGV (0xb) at pc=0x00010206, pid=14564, tid=1434448320
# Java VM: Java HotSpot(TM) Client VM (1.5.0_05-b05 mixed mode)
# Problematic frame:
# C 0x00010206
--------------- T H R E A D ---------------
Current thread (0x54d84968): JavaThread "TP-Processor4" daemon
siginfo:si_signo=33700, si_errno=0, si_code=0
Registers:
EAX=0x00000004, EBX=0x46c2f258, ECX=0x0000000e, EDX=0x00000000
ESP=0x557fdde0, EBP=0x4a945038, ESI=0x557fe05c, EDI=0x557fe0c0
EIP=0x00010206, CR2=0xffff0063, EFLAGS=0x0000002b
Top of Stack: (sp=0x557fdde0)
0x557fdde0: ffff027f ffff0063 ffffffff 44723ac7
0x557fddf0: 03870023 557fe7d4 0000002b 00000000
0x557fde00: 00000000 00000000 00660000 40079900
0x557fde10: 00000000 99000066 00004007 00000000
0x557fde20: 4006ff00 7ae14800 e147ae14 00003ffb
0x557fde30: 00000000 3ffec000 00000000 c0000000
0x557fde40: 00003ffe 00000000 40028400 00000063
0x557fde50: 0063027f 03870000 44723ac7 00000023
Instructions: (pc=0x00010206)
0x000101f6:
Stack:
=>0x54d84968 JavaThread "TP-Processor4" daemon
0x542913a0 JavaThread "TP-Processor3" daemon
0x54d530f8 JavaThread "TP-Processor2" daemon
0x54d5cbf8 JavaThread "TP-Processor1" daemon
0x54d4d950 JavaThread "StandardManager[]" daemon
0x08252480 JavaThread "Worker-2"
0x081bd778 JavaThread "Worker-1"
0x51024648 JavaThread "Java indexing" daemon
0x4f316510 JavaThread "Worker-0"
0x083f8360 JavaThread "Start Level Event Dispatcher" daemon
0x083f69e0 JavaThread "Framework Event Dispatcher" daemon
0x083f12a8 JavaThread "State Data Manager" daemon
0x080c5720 JavaThread "Low Memory Detector" daemon
0x080c4058 JavaThread "CompilerThread0" daemon
0x080c31d8 JavaThread "Signal Dispatcher" daemon
0x080b8660 JavaThread "Finalizer" daemon
0x080b79e8 JavaThread "Reference Handler" daemon
0x0805b208 JavaThread "main"
Other Threads:
0x080b4db0 VMThread
0x080c6bb0 WatcherThread
VM state:synchronizing (normal execution)
VM Mutex/Monitor currently owned by a thread: ()
Safepoint_lock - owner thread: 0x080b4db0
Threads_lock - owner thread: 0x080b4db0
Heap_lock - owner thread: 0x0805b208
Heap
def new generation total 1664K, used 1536K , sa_mask=0xfffbfeff, sa_flags=0x14000004
SIGBUS: , sa_mask=0xfffbfeff, sa_flags=0x14000004
SIGFPE: , sa_mask=0xfffbfeff, sa_flags=0x14000004
SIGPIPE: SIG_IGN, sa_mask=0x00001000, sa_flags=0x14000000
SIGILL: , sa_mask=0xfffbfeff, sa_flags=0x04000000
SIGUSR1: SIG_DFL, sa_mask=0x00000000, sa_flags=0x00000000
SIGUSR2: , sa_mask=0x00000000, sa_flags=0x14000004
SIGHUP: , sa_mask=0xfffbfeff, sa_flags=0x04000000
SIGINT: , sa_mask=0xfffbfeff, sa_flags=0x04000000
SIGQUIT: , sa_mask=0xfffbfeff, sa_flags=0x04000000
SIGTERM: , sa_mask=0xfffbfeff, sa_flags=0x04000000
--------------- S Y S T E M ---------------
OS:Red Hat Linux release 9 (Shrike)
uname:Linux 2.4.20-8 #1 Thu Mar 13 17:54:28 EST 2003 i686
libc:glibc 2.3.2 NPTL 0.29
rlimit: STACK 8192k, CORE 0k, NPROC 7168, NOFILE 1024, AS infinity
load average:1.29 0.85 0.68
CPU:total 1 family 15, cmov, cx8, fxsr, mmx, sse, sse2, ht
Memory: 4k page, physical 1022304k(148512k free), swap 1044216k(938312k free)
vm_info: Java HotSpot(TM) Client VM (1.5.0_05-b05) for linux-x86, built on Aug 26 2005 16:24:31 by java_re with gcc 3.2.1-7a (J2SE release)
name="hs_err_pid15789.log_on_jvm_1.4.log"
filename="hs_err_pid15789.log_on_jvm_1.4.log"
An unexpected exception has been detected in native code outside the VM.
Unexpected Signal : 11 occurred at PC=0x210246
Function=[Unknown.]
Library=(N/A)
NOTE: We are unable to locate the function name symbol for the error
just occurred. Please refer to release documentation for possible
reason and solutions.
Current Java thread:
Dynamic libraries:
08048000-0804e000 r-xp 00000000 03:02 883608 /home/agupta/src/javaLinux1.4.2_04/j2sdk1.4.2_04/bin/java
0804e000-0804f000 rw-p 00005000 03:02 883608 /home/agupta/src/javaLinux1.4.2_04/j2sdk1.4.2_04/bin/java
40000000-40015000 r-xp 00000000 03:02 3908136 /lib/ld-2.3.2.so
40015000-40016000 rw-p 00014000 03:02 3908136 /lib/ld-2.3.2.so
40017000-4001f000 r-xp 00000000 03:02 1063456 /home/agupta/src/javaLinux1.4.2_04/j2sdk1.4.2_04/jre/lib/i38 6/native_threads/libhpi.so
4001f000-40020000 rw-p 00007000 03:02 1063456 /home/agupta/src/javaLinux1.4.2_04/j2sdk1.4.2_04/jre/lib/i38 6/native_threads/libhpi.so
40020000-40024000 rw-s 00000000 03:02 4416073 /tmp/hsperfdata_agupta/15789
40024000-40027000 r--s 00000000 03:02 2813087 /home/agupta/src/javaLinux1.4.2_04/j2sdk1.4.2_04/jre/lib/ext /dnsns.jar
40027000-4002a000 r--s 00000000 03:02 2175840 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.pde.juni t.runtime_3.2.0.v20060605.jar
4002a000-40034000 r-xp 00000000 03:02 719501 /lib/tls/libpthread-0.29.so
40034000-40035000 rw-p 0000a000 03:02 719501 /lib/tls/libpthread-0.29.so
40037000-40039000 r-xp 00000000 03:02 3908147 /lib/libdl-2.3.2.so
40039000-4003a000 rw-p 00002000 03:02 3908147 /lib/libdl-2.3.2.so
4003b000-40436000 r-xp 00000000 03:02 2763925 /home/agupta/src/javaLinux1.4.2_04/j2sdk1.4.2_04/jre/lib/i38 6/client/libjvm.so
40436000-40451000 rw-p 003fa000 03:02 2763925 /home/agupta/src/javaLinux1.4.2_04/j2sdk1.4.2_04/jre/lib/i38 6/client/libjvm.so
40464000-40476000 r-xp 00000000 03:02 3908151 /lib/libnsl-2.3.2.so
40476000-40477000 rw-p 00011000 03:02 3908151 /lib/libnsl-2.3.2.so
40479000-4049a000 r-xp 00000000 03:02 719499 /lib/tls/libm-2.3.2.so
4049a000-4049b000 rw-p 00020000 03:02 719499 /lib/tls/libm-2.3.2.so
4049b000-404ab000 r-xp 00000000 03:02 1537596 /home/agupta/src/javaLinux1.4.2_04/j2sdk1.4.2_04/jre/lib/i38 6/libverify.so
404ab000-404ad000 rw-p 0000f000 03:02 1537596 /home/agupta/src/javaLinux1.4.2_04/j2sdk1.4.2_04/jre/lib/i38 6/libverify.so
404ad000-404ae000 r--s 00000000 03:02 2175882 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.core.boo t_3.1.100.v20060603.jar
404ae000-404b9000 r-xp 00000000 03:02 3908157 /lib/libnss_files-2.3.2.so
404b9000-404ba000 rw-p 0000a000 03:02 3908157 /lib/libnss_files-2.3.2.so
404ba000-404da000 r-xp 00000000 03:02 1537582 /home/agupta/src/javaLinux1.4.2_04/j2sdk1.4.2_04/jre/lib/i38 6/libjava.so
404da000-404dc000 rw-p 0001f000 03:02 1537582 /home/agupta/src/javaLinux1.4.2_04/j2sdk1.4.2_04/jre/lib/i38 6/libjava.so
404dc000-404f0000 r-xp 00000000 03:02 1537597 /home/agupta/src/javaLinux1.4.2_04/j2sdk1.4.2_04/jre/lib/i38 6/libzip.so
404f0000-404f3000 rw-p 00013000 03:02 1537597 /home/agupta/src/javaLinux1.4.2_04/j2sdk1.4.2_04/jre/lib/i38 6/libzip.so
404f3000-41e93000 r--s 00000000 03:02 3892450 /home/agupta/src/javaLinux1.4.2_04/j2sdk1.4.2_04/jre/lib/rt. jar
41edd000-41ef3000 r--s 00000000 03:02 3892451 /home/agupta/src/javaLinux1.4.2_04/j2sdk1.4.2_04/jre/lib/sun rsasign.jar
41ef3000-41fce000 r--s 00000000 03:02 3892443 /home/agupta/src/javaLinux1.4.2_04/j2sdk1.4.2_04/jre/lib/jss e.jar
41fce000-41fdf000 r--s 00000000 03:02 3892442 /home/agupta/src/javaLinux1.4.2_04/j2sdk1.4.2_04/jre/lib/jce .jar
41ffd000-42000000 r--s 00000000 03:02 2175844 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.swt_3.2. 2.v3236b.jar
42000000-4212e000 r-xp 00000000 03:02 719497 /lib/tls/libc-2.3.2.so
4212e000-42131000 rw-p 0012e000 03:02 719497 /lib/tls/libc-2.3.2.so
42133000-4268c000 r--s 00000000 03:02 3892412 /home/agupta/src/javaLinux1.4.2_04/j2sdk1.4.2_04/jre/lib/cha rsets.jar
44734000-4473d000 r--s 00000000 03:02 2175914 /home/agupta/eclipse3.2/eclipse/startup.jar
4473d000-44740000 r--s 00000000 03:02 2175847 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.jdt.core .manipulation_1.0.1.r321_v20060721.jar
4c922000-4cb22000 r--p 00000000 03:02 474216 /usr/lib/locale/locale-archive
4cd22000-4cd58000 r--s 00000000 03:02 2813085 /home/agupta/src/javaLinux1.4.2_04/j2sdk1.4.2_04/jre/lib/ext /IngrianNAE.jar
4cd58000-4cd65000 r--s 00000000 03:02 2813088 /home/agupta/src/javaLinux1.4.2_04/j2sdk1.4.2_04/jre/lib/ext /ldapsec.jar
4cd65000-4ce21000 r--s 00000000 03:02 2813089 /home/agupta/src/javaLinux1.4.2_04/j2sdk1.4.2_04/jre/lib/ext /localedata.jar
4ce21000-4ce3d000 r--s 00000000 03:02 2813090 /home/agupta/src/javaLinux1.4.2_04/j2sdk1.4.2_04/jre/lib/ext /sunjce_provider.jar
4ce3d000-4ce46000 r--s 00000000 03:02 2175914 /home/agupta/eclipse3.2/eclipse/startup.jar
4cec6000-4cf9c000 r--s 00000000 03:02 2175899 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.osgi_3.2 .2.R32x_v20070118.jar
4cf9c000-4cfac000 r-xp 00000000 03:02 1537593 /home/agupta/src/javaLinux1.4.2_04/j2sdk1.4.2_04/jre/lib/i38 6/libnet.so
4cfac000-4cfad000 rw-p 0000f000 03:02 1537593 /home/agupta/src/javaLinux1.4.2_04/j2sdk1.4.2_04/jre/lib/i38 6/libnet.so
4cfad000-4cfb3000 r-xp 00000000 03:02 1537594 /home/agupta/src/javaLinux1.4.2_04/j2sdk1.4.2_04/jre/lib/i38 6/libnio.so
4cfb3000-4cfb4000 rw-p 00005000 03:02 1537594 /home/agupta/src/javaLinux1.4.2_04/j2sdk1.4.2_04/jre/lib/i38 6/libnio.so
4cfb4000-4cfc8000 r--s 00000000 03:02 2175895 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.equinox. common_3.2.0.v20060603.jar
4cfc8000-4cfdf000 r--s 00000000 03:02 2175869 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.update.c onfigurator_3.2.2.R32x_v20070111.jar
4cfdf000-4cff3000 r--s 00000000 03:02 2175861 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.core.run time_3.2.0.v20060603.jar
4cff3000-4d0be000 r--s 00000000 03:02 2175819 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.jface_3. 2.2.M20061214-1200.jar
4d0be000-4d3e0000 r--s 00000000 03:02 2175820 /home/agupta/eclipse3.2/eclipse/plugins/com.ibm.icu_3.4.5.20 061213.jar
4d3e0000-4d44a000 r--s 00000000 03:02 2175821 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.ltk.ui.r efactoring_3.2.2.r322_v20070124.jar
4d44a000-4d5e7000 r--s 00000000 03:02 2175822 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.ui.ide_3 .2.1.M20060915-1030.jar
4d5e7000-4d631000 r--s 00000000 03:02 2175823 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.ui.intro _3.2.2.R322_v20061214.jar
4d631000-4d652000 r--s 00000000 03:02 2175824 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.ui.exter naltools_3.1.101.r321_v20060802.jar
4d652000-4d6ab000 r--s 00000000 03:02 2175825 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.team.cor e_3.2.2.M20061114.jar
4d6ab000-4d73a000 r--s 00000000 03:02 2175826 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.update.c ore_3.2.3.R32x_v20070118.jar
4d73a000-4d7ab000 r--s 00000000 03:02 2175827 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.ui.edito rs_3.2.1.r321_v20060721.jar
4d7ab000-4d816000 r--s 00000000 03:02 2175828 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.ui.workb ench.texteditor_3.2.0.v20060605-1400.jar
4d816000-4d85b000 r--s 00000000 03:02 2175829 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.help.bas e_3.2.2.R322_v20061207.jar
4d85b000-4d897000 r--s 00000000 03:02 2175830 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.debug.co re_3.2.1.v20060823.jar
4d897000-4d8d2000 r--s 00000000 03:02 2175831 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.ui.forms _3.2.0.v20060602.jar
4d8d2000-4d8d6000 r--s 00000000 03:02 2175832 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.osgi.uti l_3.1.100.v20060601.jar
4d8d6000-4d945000 r--s 00000000 03:02 2175833 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.search_3 .2.1.r321_v20060726.jar
4d945000-4d9b9000 r--s 00000000 03:02 2175834 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.compare_ 3.2.1.M20060711.jar
4d9b9000-4d9c3000 r--s 00000000 03:02 2175835 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.jdt_3.2. 1.r321_v20060823.jar
4d9c3000-4dacb000 r--s 00000000 03:02 2175836 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.ant.ui_3 .2.1.r321_v20060828.jar
4dacb000-4dade000 r--s 00000000 03:02 2175837 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.core.job s_3.2.0.v20060603.jar
4dade000-4db2c000 r--s 00000000 03:02 2175838 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.jdt.apt. core_3.2.1.R32x_v20060822-2100.jar
4db2c000-4db3f000 r--s 00000000 03:02 2175839 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.core.con tenttype_3.2.0.v20060603.jar
4db3f000-4e078000 r--s 00000000 03:02 2175841 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.platform .doc.user_3.2.1.R32x_v200608101155.jar
4e078000-4e08f000 r--s 00000000 03:02 2175842 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.core.fil ebuffers_3.2.1.r321_v20060721.jar
4e08f000-4e3d8000 r--s 00000000 03:02 2175843 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.pde.ui_3 .2.1.v20060816-0800.jar
4e3d8000-4fc0b000 r--s 00000000 03:02 2175845 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.platform .doc.isv_3.2.2.R32x_v20070115.jar
4fc46000-4fc65000 r--s 00000000 03:02 2175846 /home/agupta/eclipse3.2/eclipse/plugins/com.jcraft.jsch_0.1. 28.jar
4fc65000-4fc88000 r--s 00000000 03:02 2175848 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.ui.conso le_3.1.100.v20060605.jar
4fc88000-4fc99000 r--s 00000000 03:02 2175849 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.ui.views _3.2.1.M20060906-0800.jar
4fc99000-4fd5b000 r--s 00000000 03:02 2175850 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.pde.core _3.2.1.v20060915-0800.jar
4fd5b000-5033a000 r--s 00000000 03:02 2175851 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.jdt.doc. user_3.2.0.v20060605-1400.jar
5033a000-50347000 r--s 00000000 03:02 2175852 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.osgi.ser vices_3.1.100.v20060601.jar
50347000-5037d000 r--s 00000000 03:02 2175853 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.text_3.2 ..0.v20060605-1400.jar
5037d000-508bf000 r--s 00000000 03:02 2175854 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.jdt.doc. isv_3.2.1.r322_v20070109.jar
508bf000-508de000 r--s 00000000 03:02 2175855 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.ui_3.2.1 .M20061108.jar
508de000-50909000 r--s 00000000 03:02 2175856 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.ui.brows er_3.2.0.v20060602.jar
50909000-50943000 r--s 00000000 03:02 2175857 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.jdt.laun ching_3.2.2.r322_v20061114.jar
50943000-50967000 r--s 00000000 03:02 2175858 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.equinox. registry_3.2.1.R32x_v20060814.jar
50967000-5097e000 r--s 00000000 03:02 2175859 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.equinox. preferences_3.2.1.R32x_v20060717.jar
5097e000-50a03000 r--s 00000000 03:02 2175860 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.team.cvs .core_3.2.2.M20061205.jar
50a03000-50a4c000 r--s 00000000 03:02 2175862 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.ui.cheat sheets_3.2.1.R321_v20060720.jar
50a4c000-50a63000 r--s 00000000 03:02 2175863 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.core.com mands_3.2.0.I20060605-1400.jar
50a63000-50a80000 r--s 00000000 03:02 2175864 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.core.res ources.compatibility_3.2.0.v20060603.jar
50a80000-50a9f000 r--s 00000000 03:02 2175865 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.help_3.2 .2.R322_v20061213.jar
50a9f000-50aae000 r--s 00000000 03:02 2175866 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.team.cvs .ssh2_3.2.1.M20061205.jar
50aae000-50ac5000 r--s 00000000 03:02 2175867 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.ui.prese ntations.r21_3.2.0.I20060605-1400.jar
50ac5000-50da2000 r--s 00000000 03:02 2175868 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.pde.doc. user_3.2.1.v20060816-0800.jar
50da2000-50e1b000 r--s 00000000 03:02 2175870 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.update.u i_3.2.2.R32x_v20070111.jar
50e1b000-50e31000 r--s 00000000 03:02 2175871 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.core.run time.compatibility_3.1.100.v20060603.jar
50e31000-50e92000 r--s 00000000 03:02 2175872 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.help.ui_ 3.2.0.v20060602.jar
50e92000-51192000 r--s 00000000 03:02 2175873 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.ui.workb ench_3.2.2.M20070119-0800.jar
51192000-511d7000 r--s 00000000 03:02 2175874 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.jface.da tabinding_1.0.0.I20060605-1400.jar
511d7000-5121e000 r--s 00000000 03:02 2175875 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.ui.navig ator_3.2.1.M20060913-0800.jar
5121e000-5122e000 r--s 00000000 03:02 2175876 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.pde_3.2. 1.v20060810-0800.jar
5122e000-5123b000 r--s 00000000 03:02 2175877 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.team.cvs .ssh_3.2.1.M20061205.jar
5123b000-513fa000 r--s 00000000 03:02 2175878 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.swt.gtk. linux.x86_3.2.2.v3236.jar
513fa000-51413000 r--s 00000000 03:02 2175879 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.ui.navig ator.resources_3.2.1.M20060906-0800b.jar
51413000-51424000 r--s 00000000 03:02 2175880 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.core.exp ressions_3.2.2.r322_v20070109a.jar
51424000-514e5000 r--s 00000000 03:02 2175881 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.jface.te xt_3.2.2.r322_v20070104.jar
514e5000-514ea000 r--s 00000000 03:02 2175883 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.core.run time.compatibility.auth_3.2.0.v20060601.jar
514ea000-514f3000 r--s 00000000 03:02 2175884 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.core.fil esystem_1.0.0.v20060603.jar
514f3000-51666000 r--s 00000000 03:02 2175885 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.team.cvs .ui_3.2.2.M20061121.jar
51666000-5167d000 r--s 00000000 03:02 2175886 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.ant.core _3.1.100.v20060531.jar
5167d000-51a52000 r--s 00000000 03:02 2175887 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.jdt.core _3.2.3.v_686_R32x.jar
51a52000-51a59000 r--s 00000000 03:02 2175888 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.update.s cheduler_3.2.2.R32x_v20061214.jar
51a59000-51a95000 r--s 00000000 03:02 2175889 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.ltk.core .refactoring_3.2.1.r321_v20060823.jar
51a95000-51b37000 r--s 00000000 03:02 2175890 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.core.res ources_3.2.2.R32x_v20061218.jar
51b37000-51b3a000 r--s 00000000 03:02 2175891 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.rcp_3.2. 0.v20060605.jar
51b3a000-51b50000 r--s 00000000 03:02 2175892 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.ui.views .properties.tabbed_3.2.1.M20060830-0800.jar
51b50000-51b57000 r--s 00000000 03:02 2175893 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.core.var iables_3.1.100.v20060605.jar
51b57000-51b5b000 r--s 00000000 03:02 2175894 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.help.app server_3.1.100.v20060602.jar
51b5b000-51b7d000 r--s 00000000 03:02 2175896 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.pde.runt ime_3.2.0.v20060605.jar
51b7d000-51b8c000 r--s 00000000 03:02 2175897 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.jdt.apt. ui_3.2.1.R32x_v20060822-2100.jar
51b8c000-51b90000 r--s 00000000 03:02 2175898 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.core.fil esystem.linux.x86_1.0.0.v20060603.jar
51b90000-51ca9000 r--s 00000000 03:02 2175900 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.jdt.debu g.ui_3.2.2.r322_v20061205.jar
51ca9000-51db2000 r--s 00000000 03:02 2175901 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.team.ui_ 3.2.1.M200608151725.jar
51db2000-51f82000 r--s 00000000 03:02 2175902 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.debug.ui _3.2.2.r322_v20070202.jar
51f82000-51f85000 r--s 00000000 03:02 2175903 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.jdt.juni t4.runtime_1.0.1.r321_v20060905.jar
51f85000-52768000 r--s 00000000 03:02 2175904 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.jdt.ui_3 .2.2.r322_v20070124.jar
5278b000-5278d000 r--s 00000000 03:02 2175905 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.update.c ore.linux_3.2.0.v20060605.jar
5290d000-5290f000 r--s 00000000 03:02 769220 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.core.run time.compatibility.registry_3.2.1.R32x_v20060907/runtime_reg istry_compatibility.jar
5290f000-52910000 r--s 00000000 03:02 1979177 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.ui.workb ench.compatibility_3.2.0.I20060605-1400/compatibility.jar
52910000-5295b000 r-xp 00000000 03:02 3565517 /home/agupta/eclipse3.2/eclipse/configuration/org.eclipse.os gi/bundles/80/1/.cp/libswt-pi-gtk-3236.so
5295b000-5295d000 rw-p 0004a000 03:02 3565517 /home/agupta/eclipse3.2/eclipse/configuration/org.eclipse.os gi/bundles/80/1/.cp/libswt-pi-gtk-3236.so
5295d000-52963000 r--s 00000000 03:02 588870 /usr/lib/gconv/gconv-modules.cache
52963000-52964000 r-xp 00000000 03:02 654139 /usr/X11R6/lib/X11/locale/lib/common/xlcUTF8Load.so.2
52964000-52965000 rw-p 00000000 03:02 654139 /usr/X11R6/lib/X11/locale/lib/common/xlcUTF8Load.so.2
52965000-52966000 r-xp 00000000 03:02 588814 /usr/lib/gconv/ISO8859-1.so
52966000-52967000 rw-p 00001000 03:02 588814 /usr/lib/gconv/ISO8859-1.so
52967000-5296f000 r-xp 00000000 03:02 2338391 /usr/X11R6/lib/libXcursor.so.1.0
5296f000-52970000 rw-p 00007000 03:02 2338391 /usr/X11R6/lib/libXcursor.so.1.0
52970000-52bb9000 r-xp 00000000 03:02 359984 /usr/lib/libgtk-x11-2.0.so.0.200.1
52bb9000-52bc2000 rw-p 00248000 03:02 359984 /usr/lib/libgtk-x11-2.0.so.0.200.1
52bc4000-52bc8000 r-xp 00000000 03:02 359781 /usr/lib/libgthread-2.0.so.0.200.1
52bc8000-52bc9000 rw-p 00003000 03:02 359781 /usr/lib/libgthread-2.0.so.0.200.1
52bc9000-52bcd000 r-xp 00000000 03:02 2338417 /usr/X11R6/lib/libXtst.so.6.1
52bcd000-52bce000 rw-p 00004000 03:02 2338417 /usr/X11R6/lib/libXtst.so.6.1
52bce000-52be0000 r-xp 00000000 03:02 359980 /usr/lib/libgdk_pixbuf-2.0.so.0.200.1
52be0000-52be1000 rw-p 00011000 03:02 359980 /usr/lib/libgdk_pixbuf-2.0.so.0.200.1
52be1000-52c4a000 r-xp 00000000 03:02 359978 /usr/lib/libgdk-x11-2.0.so.0.200.1
52c4a000-52c4f000 rw-p 00069000 03:02 359978 /usr/lib/libgdk-x11-2.0.so.0.200.1
52c4f000-52c6f000 r-xp 00000000 03:02 359976 /usr/lib/libpangoxft-1.0.so.0.200.1
52c6f000-52c70000 rw-p 0001f000 03:02 359976 /usr/lib/libpangoxft-1.0.so.0.200.1
52c70000-52c7c000 r-xp 00000000 03:02 359974 /usr/lib/libpangox-1.0.so.0.200.1
52c7c000-52c7d000 rw-p 0000b000 03:02 359974 /usr/lib/libpangox-1.0.so.0.200.1
52c7d000-52ca4000 r-xp 00000000 03:02 359970 /usr/lib/libpango-1.0.so.0.200.1
52ca4000-52cb0000 rw-p 00026000 03:02 359970 /usr/lib/libpango-1.0.so.0.200.1
52cb0000-52cc7000 r-xp 00000000 03:02 359946 /usr/lib/libatk-1.0.so.0.200.0
52cc7000-52cc9000 rw-p 00016000 03:02 359946 /usr/lib/libatk-1.0.so.0.200.0
52cc9000-52cfc000 r-xp 00000000 03:02 359779 /usr/lib/libgobject-2.0.so.0.200.1
52cfc000-52cfe000 rw-p 00032000 03:02 359779 /usr/lib/libgobject-2.0.so.0.200.1
52cfe000-52d01000 r-xp 00000000 03:02 359777 /usr/lib/libgmodule-2.0.so.0.200.1
52d01000-52d02000 rw-p 00002000 03:02 359777 /usr/lib/libgmodule-2.0.so.0.200.1
52d02000-52d6b000 r-xp 00000000 03:02 359775 /usr/lib/libglib-2.0.so.0.200.1
52d6b000-52d6c000 rw-p 00069000 03:02 359775 /usr/lib/libglib-2.0.so.0.200.1
52d6c000-52d79000 r-xp 00000000 03:02 2338393 /usr/X11R6/lib/libXext.so.6.4
52d79000-52d7a000 rw-p 0000c000 03:02 2338393 /usr/X11R6/lib/libXext.so.6.4
52d7a000-52e56000 r-xp 00000000 03:02 2338383 /usr/X11R6/lib/libX11.so.6.2
52e56000-52e59000 rw-p 000db000 03:02 2338383 /usr/X11R6/lib/libX11.so.6.2
52e59000-52e5c000 r-xp 00000000 03:02 2338411 /usr/X11R6/lib/libXrandr.so.2.0
52e5c000-52e5d000 rw-p 00002000 03:02 2338411 /usr/X11R6/lib/libXrandr.so.2.0
52e5d000-52e64000 r-xp 00000000 03:02 2338401 /usr/X11R6/lib/libXi.so.6.0
52e64000-52e65000 rw-p 00006000 03:02 2338401 /usr/X11R6/lib/libXi.so.6.0
52e65000-52e76000 r-xp 00000000 03:02 2338399 /usr/X11R6/lib/libXft.so.2.1
52e76000-52e77000 rw-p 00010000 03:02 2338399 /usr/X11R6/lib/libXft.so.2.1
52e77000-52e7e000 r-xp 00000000 03:02 2338413 /usr/X11R6/lib/libXrender.so.1.2
52e7e000-52e7f000 rw-p 00006000 03:02 2338413 /usr/X11R6/lib/libXrender.so.1.2
52e7f000-52ea0000 r-xp 00000000 03:02 359893 /usr/lib/libfontconfig.so.1.0
52ea0000-52ea3000 rw-p 00021000 03:02 359893 /usr/lib/libfontconfig.so.1.0
52ea4000-52ef0000 r-xp 00000000 03:02 359889 /usr/lib/libfreetype.so.6.3.2
52ef0000-52ef4000 rw-p 0004c000 03:02 359889 /usr/lib/libfreetype.so.6.3.2
52ef5000-52f13000 r-xp 00000000 03:02 359765 /usr/lib/libexpat.so.0.4.0
52f13000-52f15000 rw-p 0001e000 03:02 359765 /usr/lib/libexpat.so.0.4.0
52f15000-52f3b000 r-xp 00000000 03:02 3565518 /home/agupta/eclipse3.2/eclipse/configuration/org.eclipse.os gi/bundles/80/1/.cp/libswt-gtk-3236.so
52f3b000-52f3d000 rw-p 00025000 03:02 3565518 /home/agupta/eclipse3.2/eclipse/configuration/org.eclipse.os gi/bundles/80/1/.cp/libswt-gtk-3236.so
52f3e000-52f4a000 r-xp 00000000 03:02 997576 /usr/lib/gtk-2.0/2.2.0/engines/libbluecurve.so
52f4a000-52f4b000 rw-p 0000b000 03:02 997576 /usr/lib/gtk-2.0/2.2.0/engines/libbluecurve.so
52f4b000-52f5d000 r--p 00000000 03:02 4676870 /usr/X11R6/lib/X11/fonts/Type1/l048013t.pfa
52f5d000-52f5f000 r-xp 00000000 03:02 3041542 /usr/lib/pango/1.2.0/modules/pango-basic-xft.so
52f5f000-52f60000 rw-p 00001000 03:02 3041542 /usr/lib/pango/1.2.0/modules/pango-basic-xft.so
52f60000-52f72000 r--p 00000000 03:02 4676872 /usr/X11R6/lib/X11/fonts/Type1/l048016t.pfa
52f72000-52f74000 r-xp 00000000 03:02 2437396 /home/agupta/eclipse3.2/eclipse/configuration/org.eclipse.os gi/bundles/104/1/.cp/os/linux/x86/liblocalfile_1_0_0.so
52f74000-52f75000 rw-p 00001000 03:02 2437396 /home/agupta/eclipse3.2/eclipse/configuration/org.eclipse.os gi/bundles/104/1/.cp/os/linux/x86/liblocalfile_1_0_0.so
52ff5000-52ffb000 r-xp 00000000 03:02 3565519 /home/agupta/eclipse3.2/eclipse/configuration/org.eclipse.os gi/bundles/80/1/.cp/libswt-atk-gtk-3236.so
52ffb000-52ffc000 rw-p 00005000 03:02 3565519 /home/agupta/eclipse3.2/eclipse/configuration/org.eclipse.os gi/bundles/80/1/.cp/libswt-atk-gtk-3236.so
52ffc000-5303b000 r-xp 00000000 03:02 3565520 /home/agupta/eclipse3.2/eclipse/configuration/org.eclipse.os gi/bundles/80/1/.cp/libcairo-swt.so
5303b000-5303c000 rw-p 0003f000 03:02 3565520 /home/agupta/eclipse3.2/eclipse/configuration/org.eclipse.os gi/bundles/80/1/.cp/libcairo-swt.so
5303c000-53045000 r-xp 00000000 03:02 3565521 /home/agupta/eclipse3.2/eclipse/configuration/org.eclipse.os gi/bundles/80/1/.cp/libswt-cairo-gtk-3236.so
53045000-53046000 rw-p 00009000 03:02 3565521 /home/agupta/eclipse3.2/eclipse/configuration/org.eclipse.os gi/bundles/80/1/.cp/libswt-cairo-gtk-3236.so
53046000-53048000 r-xp 00000000 03:02 3368770 /usr/local/mozilla/libplds4.so
53048000-53049000 rw-p 00001000 03:02 3368770 /usr/local/mozilla/libplds4.so
53049000-5304d000 r-xp 00000000 03:02 3368769 /usr/local/mozilla/libplc4.so
5304d000-5304e000 rw-p 00003000 03:02 3368769 /usr/local/mozilla/libplc4.so
5304f000-5305b000 r-xp 00000000 03:02 359809 /usr/lib/libz.so.1.1.4
5305b000-5305d000 rw-p 0000b000 03:02 359809 /usr/lib/libz.so.1.1.4
530dd000-530f0000 r--s 00000000 03:02 3124244 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.ui.intro .universal_3.2.1.R321_v20060905/universal.jar
530f0000-53103000 r-xp 00000000 03:02 3565523 /home/agupta/eclipse3.2/eclipse/configuration/org.eclipse.os gi/bundles/80/1/.cp/libswt-mozilla-gcc3-gtk-3236.so
53103000-53104000 rw-p 00012000 03:02 3565523 /home/agupta/eclipse3.2/eclipse/configuration/org.eclipse.os gi/bundles/80/1/.cp/libswt-mozilla-gcc3-gtk-3236.so
53104000-531d8000 r-xp 00000000 03:02 3368778 /usr/local/mozilla/libxpcom.so
531d8000-531df000 rw-p 000d3000 03:02 3368778 /usr/local/mozilla/libxpcom.so
531df000-5320f000 r-xp 00000000 03:02 3368766 /usr/local/mozilla/libnspr4.so
5320f000-53211000 rw-p 00030000 03:02 3368766 /usr/local/mozilla/libnspr4.so
53212000-5321a000 r-xp 00000000 03:02 3565526 /home/agupta/eclipse3.2/eclipse/configuration/org.eclipse.os gi/bundles/80/1/.cp/libswt-mozilla14-profile-gcc3-gtk-3236.s o
5321a000-5321b000 rw-p 00008000 03:02 3565526 /home/agupta/eclipse3.2/eclipse/configuration/org.eclipse.os gi/bundles/80/1/.cp/libswt-mozilla14-profile-gcc3-gtk-3236.s o
5321b000-5321d000 r-xp 00000000 03:02 588858 /usr/lib/gconv/UTF-16.so
5321d000-5321e000 rw-p 00001000 03:02 588858 /usr/lib/gconv/UTF-16.so
5321e000-53221000 r-xp 00000000 03:02 3368760 /usr/local/mozilla/libgtkxtbin.so
53221000-53222000 rw-p 00003000 03:02 3368760 /usr/local/mozilla/libgtkxtbin.so
53222000-53223000 r-xp 00000000 03:02 1177359 /usr/kerberos/lib/libcom_err.so.3.0
53223000-53224000 rw-p 00001000 03:02 1177359 /usr/kerberos/lib/libcom_err.so.3.0
53225000-532ce000 r-xp 00000000 03:02 359847 /usr/lib/libstdc++.so.5.0.3
532ce000-532d3000 rw-p 000a9000 03:02 359847 /usr/lib/libstdc++.so.5.0.3
532d8000-532df000 r-xp 00000000 03:02 3908190 /lib/libgcc_s-3.2.2-20030225.so.1
532df000-532e0000 rw-p 00007000 03:02 3908190 /lib/libgcc_s-3.2.2-20030225.so.1
532e0000-53302000 r-xp 00000000 03:02 3368758 /usr/local/mozilla/libgkgfx.so
53302000-53304000 rw-p 00021000 03:02 3368758 /usr/local/mozilla/libgkgfx.so
53304000-53372000 r-xp 00000000 03:02 3368763 /usr/local/mozilla/libmozjs.so
53372000-53376000 rw-p 0006e000 03:02 3368763 /usr/local/mozilla/libmozjs.so
53376000-5339f000 r-xp 00000000 03:02 1358018 /usr/local/mozilla/components/libembedcomponents.so
5339f000-533a1000 rw-p 00029000 03:02 1358018 /usr/local/mozilla/components/libembedcomponents.so
533a1000-533b1000 r-xp 00000000 03:02 1358097 /usr/local/mozilla/components/libtypeaheadfind.so
533b1000-533b2000 rw-p 00010000 03:02 1358097 /usr/local/mozilla/components/libtypeaheadfind.so
533b2000-533c4000 r-xp 00000000 03:02 1357952 /usr/local/mozilla/components/libpref.so
533c4000-533c5000 rw-p 00012000 03:02 1357952 /usr/local/mozilla/components/libpref.so
533c5000-533d0000 r-xp 00000000 03:02 3368764 /usr/local/mozilla/libmozz.so
533d0000-533d2000 rw-p 0000a000 03:02 3368764 /usr/local/mozilla/libmozz.so
533d2000-5348a000 r-xp 00000000 03:02 1357946 /usr/local/mozilla/components/libnecko.so
5348a000-53491000 rw-p 000b7000 03:02 1357946 /usr/local/mozilla/components/libnecko.so
53491000-53883000 r-xp 00000000 03:02 1357997 /usr/local/mozilla/components/libgklayout.so
53883000-538ba000 rw-p 003f1000 03:02 1357997 /usr/local/mozilla/components/libgklayout.so
538c0000-538d4000 r-xp 00000000 03:02 1357954 /usr/local/mozilla/components/libcaps.so
538d4000-538d5000 rw-p 00014000 03:02 1357954 /usr/local/mozilla/components/libcaps.so
538d5000-53913000 r-xp 00000000 03:02 1357912 /usr/local/mozilla/components/libxpconnect.so
53913000-53917000 rw-p 0003d000 03:02 1357912 /usr/local/mozilla/components/libxpconnect.so
54117000-5414f000 r-xp 00000000 03:02 1357922 /usr/local/mozilla/components/libi18n.so
5414f000-54152000 rw-p 00038000 03:02 1357922 /usr/local/mozilla/components/libi18n.so
54152000-5417a000 r-xp 00000000 03:02 1357956 /usr/local/mozilla/components/librdf.so
5417a000-5417c000 rw-p 00027000 03:02 1357956 /usr/local/mozilla/components/librdf.so
5417c000-541a6000 r-xp 00000000 03:02 1357966 /usr/local/mozilla/components/libimglib2.so
541a6000-541a8000 rw-p 00029000 03:02 1357966 /usr/local/mozilla/components/libimglib2.so
541a8000-541b9000 r-xp 00000000 03:02 1358069 /usr/local/mozilla/components/libjsd.so
541b9000-541ba000 rw-p 00010000 03:02 1358069 /usr/local/mozilla/components/libjsd.so
541ba000-541c2000 r-xp 00000000 03:02 1358088 /usr/local/mozilla/components/libsystem-pref.so
541c2000-541c3000 rw-p 00008000 03:02 1358088 /usr/local/mozilla/components/libsystem-pref.so
541c3000-541d4000 r-xp 00000000 03:02 1358020 /usr/local/mozilla/components/libwebbrwsr.so
541d4000-541d5000 rw-p 00011000 03:02 1358020 /usr/local/mozilla/components/libwebbrwsr.so
541d6000-54224000 r-xp 00000000 03:02 2338415 /usr/X11R6/lib/libXt.so.6.0
54224000-54228000 rw-p 0004d000 03:02 2338415 /usr/X11R6/lib/libXt.so.6.0
54228000-54230000 r-xp 00000000 03:02 2338381 /usr/X11R6/lib/libSM.so.6.0
54230000-54231000 rw-p 00007000 03:02 2338381 /usr/X11R6/lib/libSM.so.6.0
54231000-54245000 r-xp 00000000 03:02 2338377 /usr/X11R6/lib/libICE.so.6.3
54245000-54246000 rw-p 00013000 03:02 2338377 /usr/X11R6/lib/libICE.so.6.3
54248000-54279000 r-xp 00000000 03:02 1357985 /usr/local/mozilla/components/libwidget_gtk2.so
54279000-5427d000 rw-p 00030000 03:02 1357985 /usr/local/mozilla/components/libwidget_gtk2.so
5427d000-54280000 r-xp 00000000 03:02 3908155 /lib/libnss_dns-2.3.2.so
54280000-54281000 rw-p 00003000 03:02 3908155 /lib/libnss_dns-2.3.2.so
54281000-54290000 r-xp 00000000 03:02 3908167 /lib/libresolv-2.3.2.so
54290000-54291000 rw-p 0000f000 03:02 3908167 /lib/libresolv-2.3.2.so
54293000-542c6000 r-xp 00000000 03:02 359986 /usr/lib/libgconf-2.so.4.1.0
542c6000-542c9000 rw-p 00033000 03:02 359986 /usr/lib/libgconf-2.so.4.1.0
542c9000-54302000 r-xp 00000000 03:02 359962 /usr/lib/libORBit-2.so.0.0.0
54302000-5430b000 rw-p 00038000 03:02 359962 /usr/lib/libORBit-2.so.0.0.0
5430b000-54312000 r-xp 00000000 03:02 359960 /usr/lib/liblinc.so.1.0.0
54312000-54313000 rw-p 00006000 03:02 359960 /usr/lib/liblinc.so.1.0.0
54313000-5431a000 r-xp 00000000 03:02 359792 /usr/lib/libpopt.so.0.0.0
5431a000-5431b000 rw-p 00006000 03:02 359792 /usr/lib/libpopt.so.0.0.0
5431b000-54385000 r-xp 00000000 03:02 1357964 /usr/local/mozilla/components/libgfx_gtk.so
54385000-5438b000 rw-p 00069000 03:02 1357964 /usr/local/mozilla/components/libgfx_gtk.so
54394000-5439b000 r-xp 00000000 03:02 1358041 /usr/local/mozilla/components/libpipboot.so
5439b000-5439c000 rw-p 00007000 03:02 1358041 /usr/local/mozilla/components/libpipboot.so
5439c000-543a5000 r--s 00000000 03:02 3058850 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.platform _3.2.2.r322_v20070117b/startup.jar
543a7000-543ae000 r-xp 00000000 03:02 2338407 /usr/X11R6/lib/libXp.so.6.2
543ae000-543af000 rw-p 00006000 03:02 2338407 /usr/X11R6/lib/libXp.so.6.2
543af000-5440d000 r-xp 00000000 03:02 1358001 /usr/local/mozilla/components/libdocshell.so
5440d000-54410000 rw-p 0005e000 03:02 1358001 /usr/local/mozilla/components/libdocshell.so
54410000-5442b000 r-xp 00000000 03:02 3368777 /usr/local/mozilla/libxpcom_compat.so
5442b000-5442c000 rw-p 0001b000 03:02 3368777 /usr/local/mozilla/libxpcom_compat.so
5442c000-54497000 r-xp 00000000 03:02 1358066 /usr/local/mozilla/components/libappcomps.so
54497000-5449b000 rw-p 0006a000 03:02 1358066 /usr/local/mozilla/components/libappcomps.so
5449b000-544e8000 r-xp 00000000 03:02 1357983 /usr/local/mozilla/components/libjsdom.so
544e8000-544ee000 rw-p 0004c000 03:02 1357983 /usr/local/mozilla/components/libjsdom.so
544ef000-54506000 r-xp 00000000 03:02 3368761 /usr/local/mozilla/libjsj.so
54506000-54508000 rw-p 00017000 03:02 3368761 /usr/local/mozilla/libjsj.so
54508000-5451f000 r-xp 00000000 03:02 1357926 /usr/local/mozilla/components/liboji.so
5451f000-54520000 rw-p 00017000 03:02 1357926 /usr/local/mozilla/components/liboji.so
54520000-5454f000 r-xp 00000000 03:02 1357968 /usr/local/mozilla/components/libgkplugin.so
5454f000-54551000 rw-p 0002e000 03:02 1357968 /usr/local/mozilla/components/libgkplugin.so
54551000-54555000 r--s 00000000 03:02 3058854 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.platform _3.2.2.r322_v20070117b/platform.jar
556d5000-55793000 r-xp 00000000 03:02 1357916 /usr/local/mozilla/components/libuconv.so
55793000-5579a000 rw-p 000bd000 03:02 1357916 /usr/local/mozilla/components/libuconv.so
557a4000-557be000 r-xp 00000000 03:02 1357958 /usr/local/mozilla/components/libchrome.so
557be000-557bf000 rw-p 00019000 03:02 1357958 /usr/local/mozilla/components/libchrome.so
557bf000-5580e000 r-xp 00000000 03:02 1357960 /usr/local/mozilla/components/libhtmlpars.so
5580e000-55814000 rw-p 0004e000 03:02 1357960 /usr/local/mozilla/components/libhtmlpars.so
55814000-5581f000 r-xp 00000000 03:02 1357923 /usr/local/mozilla/components/libjar50.so
5581f000-55820000 rw-p 0000b000 03:02 1357923 /usr/local/mozilla/components/libjar50.so
55820000-55823000 r-xp 00000000 03:02 3565528 /home/agupta/eclipse3.2/eclipse/configuration/org.eclipse.os gi/bundles/80/1/.cp/libswt-gnome-gtk-3236.so
55823000-55824000 rw-p 00002000 03:02 3565528 /home/agupta/eclipse3.2/eclipse/configuration/org.eclipse.os gi/bundles/80/1/.cp/libswt-gnome-gtk-3236.so
55827000-5583a000 r-xp 00000000 03:02 359992 /usr/lib/libgnome-2.so.0.200.0
5583a000-5583b000 rw-p 00013000 03:02 359992 /usr/lib/libgnome-2.so.0.200.0
5583b000-55872000 r-xp 00000000 03:02 359988 /usr/lib/libgnomevfs-2.so.0.0.0
55872000-55874000 rw-p 00036000 03:02 359988 /usr/lib/libgnomevfs-2.so.0.0.0
55874000-55953000 r-xp 00000000 03:02 359902 /usr/lib/libxml2.so.2.5.4
55953000-5595e000 rw-p 000de000 03:02 359902 /usr/lib/libxml2.so.2.5.4
5595f000-559ad000 r-xp 00000000 03:02 359968 /usr/lib/libbonobo-2.so.0.0.0
559ad000-559b6000 rw-p 0004e000 03:02 359968 /usr/lib/libbonobo-2.so.0.0.0
559b6000-559c7000 r-xp 00000000 03:02 359966 /usr/lib/libbonobo-activation.so.4.0.0
559c7000-559c9000 rw-p 00011000 03:02 359966 /usr/lib/libbonobo-activation.so.4.0.0
559c9000-559d0000 r-xp 00000000 03:02 359950 /usr/lib/libesd.so.0.2.28
559d0000-559d1000 rw-p 00006000 03:02 359950 /usr/lib/libesd.so.0.2.28
559d1000-559f3000 r-xp 00000000 03:02 359948 /usr/lib/libaudiofile.so.0.0.2
559f3000-559f6000 rw-p 00021000 03:02 359948 /usr/lib/libaudiofile.so.0.0.2
559f6000-55a28000 r-xp 00000000 03:02 3908200 /lib/libssl.so.0.9.7a
55a28000-55a2b000 rw-p 00032000 03:02 3908200 /lib/libssl.so.0.9.7a
55a2b000-55b07000 r-xp 00000000 03:02 3908199 /lib/libcrypto.so.0.9.7a
55b07000-55b19000 rw-p 000db000 03:02 3908199 /lib/libcrypto.so.0.9.7a
55b1c000-55b22000 r-xp 00000000 03:02 3908169 /lib/librt-2.3.2.so
55b22000-55b24000 rw-p 00005000 03:02 3908169 /lib/librt-2.3.2.so
55b2e000-55b32000 r-xp 00000000 03:02 359964 /usr/lib/libORBitCosNaming-2.so.0.0.0
55b32000-55b33000 rw-p 00004000 03:02 359964 /usr/lib/libORBitCosNaming-2.so.0.0.0
55b33000-55b45000 r-xp 00000000 03:02 1177365 /usr/kerberos/lib/libgssapi_krb5.so.2.2
55b45000-55b46000 rw-p 00011000 03:02 1177365 /usr/kerberos/lib/libgssapi_krb5.so.2.2
55b46000-55ba2000 r-xp 00000000 03:02 1177379 /usr/kerberos/lib/libkrb5.so.3.1
55ba2000-55ba4000 rw-p 0005c000 03:02 1177379 /usr/kerberos/lib/libkrb5.so.3.1
55ba4000-55bb3000 r-xp 00000000 03:02 1177369 /usr/kerberos/lib/libk5crypto.so.3.0
55bb3000-55bb4000 rw-p 0000f000 03:02 1177369 /usr/kerberos/lib/libk5crypto.so.3.0
55c34000-55c60000 r-xp 00000000 03:02 1357998 /usr/local/mozilla/components/libmork.so
55c60000-55c62000 rw-p 0002c000 03:02 1357998 /usr/local/mozilla/components/libmork.so
55c62000-55c6c000 r-xp 00000000 03:02 1358071 /usr/local/mozilla/components/libcookie.so
55c6c000-55c6d000 rw-p 0000a000 03:02 1358071 /usr/local/mozilla/components/libcookie.so
55c6d000-55c7a000 r--s 00000000 03:02 1292810 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.jdt.debu g_3.2.2.r322_v20070130/jdi.jar
55c9a000-55cae000 r--p 00000000 03:02 4676864 /usr/X11R6/lib/X11/fonts/Type1/l047016t.pfa
55cae000-55cc2000 r--p 00000000 03:02 4676866 /usr/X11R6/lib/X11/fonts/Type1/l047033t.pfa
55cc9000-55d51000 r-xp 00000000 03:02 360002 /usr/lib/libgnomeui-2.so.0.200.0
55d51000-55d54000 rw-p 00088000 03:02 360002 /usr/lib/libgnomeui-2.so.0.200.0
55d54000-55db3000 r-xp 00000000 03:02 360000 /usr/lib/libbonoboui-2.so.0.0.0
55db3000-55db6000 rw-p 0005f000 03:02 360000 /usr/lib/libbonoboui-2.so.0.0.0
55db6000-55de2000 r-xp 00000000 03:02 359994 /usr/lib/libgnomecanvas-2.so.0.200.0
55de2000-55de3000 rw-p 0002c000 03:02 359994 /usr/lib/libgnomecanvas-2.so.0.200.0
55de3000-55df8000 r-xp 00000000 03:02 359956 /usr/lib/libart_lgpl_2.so.2.3.11
55df8000-55df9000 rw-p 00015000 03:02 359956 /usr/lib/libart_lgpl_2.so.2.3.11
55df9000-55e1a000 r-xp 00000000 03:02 359972 /usr/lib/libpangoft2-1.0.so.0.200.1
55e1a000-55e1b000 rw-p 00021000 03:02 359972 /usr/lib/libpangoft2-1.0.so.0.200.1
55e1b000-55e38000 r-xp 00000000 03:02 359895 /usr/lib/libjpeg.so.62.0.0
55e38000-55e39000 rw-p 0001d000 03:02 359895 /usr/lib/libjpeg.so.62.0.0
55e39000-55e4c000 r--p 00000000 03:02 4676862 /usr/X11R6/lib/X11/fonts/Type1/l047013t.pfa
55e60000-55eda000 r--p 00000000 03:02 2894439 /usr/share/fonts/bitmap-fonts/6x13.pcf
55eda000-55f92000 r--s 00000000 03:02 1292811 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.jdt.debu g_3.2.2.r322_v20070130/jdimodel.jar
56212000-5626f000 r--s 00000000 03:02 2862610 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.jdt.juni t_3.2.1.r321_v20060810/junitsupport.jar
566ef000-56733000 r--s 00000000 03:02 2600964 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.pde.buil d_3.2.1.r321_v20060823/pdebuild.jar
Heap at VM Abort:
Heap
def new generation total 2560K, used 1856K [0x44740000, 0x44a00000, 0x44c20000)
eden space 2304K, 74% used [0x44740000, 0x448eeab0, 0x44980000)
from space 256K, 52% used [0x44980000, 0x449a1858, 0x449c0000)
to space 256K, 0% used [0x449c0000, 0x449c0000, 0x44a00000)
tenured generation total 33496K, used 27495K [0x44c20000, 0x46cd6000, 0x48740000)
the space 33496K, 82% used [0x44c20000, 0x466f9c58, 0x466f9e00, 0x46cd6000)
compacting perm gen total 33024K, used 33012K [0x48740000, 0x4a780000, 0x4c740000)
the space 33024K, 99% used [0x48740000, 0x4a77d0d8, 0x4a77d200, 0x4a780000)
Local Time = Tue Mar 13 04:20:49 2007
Elapsed Time = 143
# The exception above was detected in native code outside the VM
# Java VM: Java HotSpot(TM) Client VM (1.4.2_04-b05 mixed mode)
--------------080100080405050707040208--
Re: VM constantly crashes with Eclipse 3.2.2 on Linux [message #313359 is a reply to message #313338] |
Wed, 14 March 2007 11:54 |
Nicolas Bihan Messages: 49 Registered: July 2009 |
Member |
If you use Sun JVMs you can try to set -XX:MaxPermSize=128m.
Nicolas Bihan
Anima Gupta a écrit :
> Hi -
> java files.
> Thanks -
> Anima.
> # C 0x00010206
> Registers:
> 0x000101f6:
> Stack:
> Other Threads:
> 0x080b4db0 VMThread
> Heap
> Function=[Unknown.]
> Library=(N/A)
> Dynamic libraries:
> 5295b000-5295d000 rw-p 0004a000 03:02 3565517 /home/agupta/eclipse3.2/eclipse/configuration/org.eclipse..o sgi/bundles/80/1/.cp/libswt-pi-gtk-3236.so
> Heap at VM Abort:
> Heap
> Elapsed Time = 143
Re: VM constantly crashes with Eclipse 3.2.2 on Linux [message #313385 is a reply to message #313359] |
Wed, 14 March 2007 16:44 |
Member |
Hi -
I just started it using the -XX:MaxPermSize=128m vmarg, but it crashed
instantly after displaying the welcome screen -
Is there any other param I should specify along with it?
Thanks!
Anima.
JVM terminated. Exit code=6
/home/agupta/src/javaLinux1.5.0_05/bin/java
-jar /home/agupta/eclipse3.2/eclipse/./startup.jar
-os linux
-ws gtk
-arch x86
-launcher /home/agupta/eclipse3.2/eclipse/./eclipse
-name Eclipse
-showsplash 600
-exitdata 50c0008
-vm /home/agupta/src/javaLinux1.5.0_05/bin/java
-vmargs
Nicolas Bihan wrote:
> Nicolas Bihan
>> Hi -
>> the no matter I am able to crash it after couple of minutes or opening
>> 5-10 java files.
>> etc
>> issues -
>> Thanks -
>> Anima.
>> # C 0x00010206
>> Registers:
>> 0x000101f6:
>> Stack:
>> Other Threads:
>> 0x080b4db0 VMThread
>> Heap
>> SIGILL: ,
>> SIGHUP: ,
>> SIGINT: ,
>> SIGQUIT: ,
>> SIGTERM: ,
>> libc:glibc 2.3.2 NPTL 0.29 rlimit: STACK 8192k, CORE 0k, NPROC 7168,
>> Function=[Unknown.]
>> Library=(N/A)
>> Dynamic libraries:
>> Heap at VM Abort:
>> Heap
>> 0x44c20000)
>> 0x46cd6000)
>> 0x4a780000)
>> Elapsed Time = 143
Re: VM constantly crashes with Eclipse 3.2.2 on Linux [message #313508 is a reply to message #313385] |
Thu, 15 March 2007 22:21 |
Originally posted by: nicolas.bihan.free.fr
Do you put your VM args in the eclipse.ini file ?
I'm suprise to read this :
"/home/agupta/src/javaLinux1.5.0_05/bin/java
-XX:MaxPermSize=128m"
Nicolas Bihan
> Hi -
> Thanks!
> Anima.
> -os linux
> -ws gtk
> -arch x86
> -name Eclipse
> -showsplash 600
> -exitdata 50c0008
> -vmargs
>> Nicolas Bihan
>>> Hi -
>>> opening 5-10 java files.
>>> 6 etc
>>> issues -
>>> Thanks -
>>> Anima.
>>> # C 0x00010206
>>> Registers:
>>> 0x000101f6:
>>> Stack:
>>> Other Threads:
>>> 0x080b4db0 VMThread
>>> Heap
>>> sa_flags=0x14000004
>>> SIGILL: ,
>>> sa_flags=0x14000004
>>> SIGHUP: ,
>>> SIGINT: ,
>>> SIGQUIT: ,
>>> SIGTERM: ,
>>> release)
>>> Function=[Unknown.]
>>> Library=(N/A)
>>> Dynamic libraries:
>>> Heap at VM Abort:
>>> Heap
>>> 0x46cd6000)
>>> 0x4a780000)
>>> Elapsed Time = 143
Re: VM constantly crashes with Eclipse 3.2.2 on Linux [message #313566 is a reply to message #313508] |
Mon, 19 March 2007 17:53 |
Member |
yes they are in the eclipse.ini file - is there something I am missing?
Additionally I increased it to 256M - it runs for a longer time, but
then still crashes eventually -
I am so puzzled what the problem is -
I do not see any outofmemory errors in the log -
Right now I have given up and gone back to eclipse3.1 :-(
Anima
> Nicolas Bihan
>> Hi -
>> Thanks!
>> Anima.
>> -os linux
>> -ws gtk
>> -arch x86
>> -name Eclipse
>> -showsplash 600
>> -exitdata 50c0008
>> -vmargs
>>> Hi,
>>> Nicolas Bihan
>>>> Hi -
>>>> Linux (redhat 9, gtk) - It crashes after sometime.
>>>> 6 etc
>>>> issues -
>>>> me some pointers? Attached are 2 logfiles on different jvms I have
>>>> tried -
>>>> Thanks -
>>>> Anima.
>>>> # C 0x00010206
>>>> Registers:
>>>> 0x000101f6:
>>>> Stack:
>>>> Other Threads:
>>>> 0x080b4db0 VMThread
>>>> Heap
>>>> sa_flags=0x14000004
>>>> sa_flags=0x14000004
>>>> sa_flags=0x14000004
>>>> SIGILL: ,
>>>> sa_flags=0x14000004
>>>> SIGHUP: ,
>>>> SIGINT: ,
>>>> SIGQUIT: ,
>>>> SIGTERM: ,
>>>> release)
>>>> VM.
>>>> Function=[Unknown.]
>>>> Library=(N/A)
>>>> Dynamic libraries:
&g
Current Time: Tue Jul 30 19:30:03 GMT 2024
Powered by FUDForum. Page generated in 0.39062 seconds
