Home » Eclipse Projects » Remote Application Platform (RAP) » Working with images
Working with images [message #31585] Thu, 07 June 2007 08:35 Go to next message
Hi all, I have a doubt about how to work with Images.
Now I store images in Blob columns of my BBDD, I would like to convert
them in org.eclipse.swt.graphics.Image objects in order to display them
in a Label widget, well, I'm thinking about to use this method:
Image img = Image.find("/myimage_000", myBlob.getBinaryStream());
But then, I have 2 poblems:
1.- Image bytes are cached and I'm using a shared hosting provider with
a limited private heap size and if these images are stored in cache I
could have problems with memory limitations.
2.- An Image can be modified and I don't know how to "refresh" cached
image data with new data.
Is there any way for dispose an Image from cache ?
I'm thinking about alternatives, If i can't use a standard widget I can
implements my own ImageWidget or I can use a Browser with XML/XSLT
content to display an embebed serialized image.
Any other idea ?
Thanks in advance.
Roberto.
Re: Working with images [message #31791 is a reply to message #31585] Mon, 11 June 2007 04:36 Go to previous messageGo to next message
Originally posted by: fappel.innoopract.com
as RAP shares images between user sessions, it is currently not possible to
dispose of a single image instance. Sharing the images between sessions
instead of creating image instances of the same images for each session
should in fact reduce the needed heap size for image representation.
Currently it is only possible to clear the complete image buffer
(Image.clear()), but I am not sure, whether this is really a good way if
you only need to refresh one image. There is also a problem due to the SWT
subset API with that approach. So probably there will be some changes to the
Image stuff till 1.0.
Ciao
Frank
"Roberto S
Re: Working with images [message #31860 is a reply to message #31791] Mon, 11 June 2007 05:30 Go to previous messageGo to next message
Originally posted by: roberto.sanchez.autonomind.com
Hi Frank, there is a problem with this "approach", Sharing images
between sessions isn't a good idea if these images are "private", that
is, my application is a Curriculum vitae manager, and the images that i
have to store are user photos, they are "private info", of course an
user can change his own photo so I need to "refresh" that image.
Imagine, if I have 1000 users with photo, and every foto of 100 Kb, If
all photos are stored in Image cache, Every time an user login my
application his photo is shown and stored, I'll need 100 Mb only for
storing photos !! that is too much for my system (I'm using a shared
hosting provider), just for 1000 users, imagine 10000, ...
Besides I had another problem showing images in Labels, the size, I need
to show all photos with the same size and AFAIK this is not possible in
this moment with Label widget then I had to look for another solution:
I don't use Image objects, I've created a Photo control, which extends
from Composite and contain a Browser widget I need a new servlet as
well, this servlet reads the image from database and returns an image
content, i.e. "image/png", I set Browser url pointing to this servlet
adding "photo code" and It works fine. I use a minimal amount of heap
memory and images are shown with the size I need.
Regards.
Roberto.
Frank Appel wrote:
> Ciao
> Frank
> "Roberto Sá‡nchez" <roberto@autonomind.com> schrieb im Newsbeitrag
> news:f48u1p$49b$1@build.eclipse.org...
>> them in org.eclipse.swt.graphics.Image objects in order to display them in
>> 1.- Image bytes are cached and I'm using a shared hosting provider with a
>> limited private heap size and if these images are stored in cache I could
>> implements my own ImageWidget or I can use a Browser with XML/XSLT content
>> Any other idea ?
>> Thanks in advance.
>> Roberto.
Re: Working with images [message #32036 is a reply to message #31860] Tue, 12 June 2007 03:06 Go to previous message
I see your point that images are not reused between sessions in your case.
And as the Label does not fit your needs you have found a solution that
works fine for you. But just for clarification I think your memory
computation is not correct. We do not buffer the image's data, we only
buffer the link to the image's location. All in all we only have a String
and a Object reference which, if I remember our tests correctly, do not
consume more that a few Kb - let's say 5 to 10. So the1000 images would
consume 5 to 10 Mb.
In most cases images are reused application wide, so this is a memory
inprovement compared to that every session creates redundantly the same
images. There's also the possibility to implement an overflow strategy, say
we limit the buffer size and remove the images that are seldom used. Seeing
your use case I think also about creating the possibility to remove a image
explicitly from the buffer.
Thanks for your input, that helps us to improve RAP!
Ciao
Frank
"Roberto S
Previous Topic:updated rap from cvs and now get error with deploying in jboss
Next Topic:How can I use other projects?
Current Time: Sun Nov 02 11:51:20 EST 2025
Powered by FUDForum. Page generated in 0.03280 seconds
