Home » Eclipse Projects » Eclipse Platform » Autosave before Ant build
Autosave before Ant build [message #312334] Wed, 07 February 2007 01:39 Go to next message
Is there any way to configure Eclipse to automatically save changed
resources before an Ant build rather than prompting whether I'd like tosave
them? I ALWAYS want to save changed resources, and have never once had a
false alarm in this case where I've saved something I didn't want to be
saved (and if I did I could easily correct it by restoring from local
history).
I do enough builds that this small change will save a little time and a lot
of annoyance...(really :)
How could this be done? (Surely something as configurable as Eclipse makes
this easy...)
Re: Autosave before Ant build [message #312349 is a reply to message #312334] Wed, 07 February 2007 10:43 Go to previous messageGo to next message
Window>Preferences>Launching>Save required dirty editors before
launching>Always
HTH
Darins
"VK" <veerukrishnan@hotmail.com> wrote in message
news:eqbs68$7u4$1@utils.eclipse.org...
> tosave them? I ALWAYS want to save changed resources, and have never once
> had a false alarm in this case where I've saved something I didn't want to
> be saved (and if I did I could easily correct it by restoring from local
> history).
> lot of annoyance...(really :)
> this easy...)
Re: Autosave before Ant build [message #312403 is a reply to message #312349] Thu, 08 February 2007 20:36 Go to previous messageGo to next message
Thanks, that worked.
Another inconvenience Ant in Eclipse has is when I type ALT+SHIFT+X, Q
(keyboard shortcut for Ant build), if I'm in any file it'll default to
execute build.xml. However, when I'm editing an XML document (which I am
doing a lot of nowadays) and type the keyboard shortcut, it tries to execute
that XML file as an Ant build. Meaning that I first have to switch to a
non-XML file before hitting the shortcut.
Is there any way to tell Eclipse/Ant only to look at build.xml as an Ant
file?
Again, a slight inconvenience but it'll end up saving me so much time.
Thanks.
"Darin Swanson" <Darin_Swanson@us.ibm.com> wrote in message
news:eqcs2t$t6k$1@utils.eclipse.org...
> launching>Always
> HTH
> Darins
>> to be saved (and if I did I could easily correct it by restoring from
>> local history).
>> makes this easy...)
Re: Autosave before Ant build [message #312440 is a reply to message #312403] Fri, 09 February 2007 20:55 Go to previous message
Originally posted by: varavamu.yahoo.com
--------------070802040401030805030203
The most likely cause of this is that your xml file editor is set to the
ant editor maybe? Try editing your xml file with a different xml plugin.
thanks,
Vijay
> file?
> Thanks.
>> launching>Always
>> HTH
>> Darins
>>> local history).
>>> makes this easy...)
<html>
<head>
</head>
the ant editor maybe? Try editing your xml file with a different xml
plugin.<br>
<br>
thanks,<br>
Vijay<br>
<br>
VK wrote:
<blockquote cite="mid:eqgj7j$us3$1@utils.eclipse.org" type="cite">
<pre wrap="">Thanks, that worked.
file?
Thanks.
"Darin Swanson" <a class="moz-txt-link-rfc2396E" href="mailto:Darin_Swanson@us.ibm.com">&lt;Darin_Swanson@us.ibm.com&gt;</a> wrote in message
<a class="moz-txt-link-freetext" href="news:eqcs2t$t6k$1@utils.eclipse.org">news:eqcs2t$t6k$1@utils.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Window&gt;Preferences&gt;Launching&gt;Save required dirty editors before
launching&gt;Always
HTH
Darins
"VK" <a class="moz-txt-link-rfc2396E" href="mailto:veerukrishnan@hotmail.com">&lt;veerukrishnan@hotmail.com&gt;</a> wrote in message
<a class="moz-txt-link-freetext" href="news:eqbs68$7u4$1@utils.eclipse.org">news:eqbs68$7u4$1@utils.eclipse.org</a>...
</pre>
<pre wrap="">Is there any way to configure Eclipse to automatically save changed
local history).
makes this easy...)
</pre>
</blockquote>
<pre wrap="">
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
</body>
</html>
--------------070802040401030805030203--
Previous Topic:Bug in open type?
Next Topic:RCP using JDT
Current Time: Thu Apr 24 23:12:36 EDT 2025
Powered by FUDForum. Page generated in 0.02422 seconds
