Exception in Test Perspective [message #31413] |
Wed, 14 September 2005 16:57 |
--------------070707080408040704090302
After starting Eclipse, and switching to the Test Perspective, I get an entry in the log file (attached) showing an exception:
!MESSAGE java.lang.Throwable: The factory id: NonEMFResourceProxyFactory should be instanceof IPersistableFileProxyFactory
Things appear to be working OK, but I'm pretty new to TPTP, and just working through the tutorials, so I cannot be sure.
Perhaps I've mis configured something. Any ideas?
David Read.
name="eclipse.log"
Content-Disposition: inline;
filename="eclipse.log"
!SESSION 2005-09-14 21:37:31.203 -----------------------------------------------
eclipse.buildId=I20050627-1435
java.version=1.5.0_04
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_GB
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.hyades.test.ui 4 0 2005-09-14 21:38:07.125
!STACK 0
at org.eclipse.hyades.test.ui.UiPlugin.logError(UiPlugin.java:3 08)
at org.eclipse.hyades.test.ui.internal.navigator.proxy.FileProx yManager.buildProxy(FileProxyManager.java:174)
at org.eclipse.hyades.test.ui.internal.navigator.proxy.FileProx yManager.loadProxyState(FileProxyManager.java:138)
at org.eclipse.hyades.test.ui.internal.navigator.proxy.FileProx yManager.getProxy(FileProxyManager.java:88)
at org.eclipse.hyades.test.ui.navigator.TestFolderProxyNode.bui ldChildren(TestFolderProxyNode.java:131)
at org.eclipse.hyades.test.ui.navigator.TestFolderProxyNode.<init >(TestFolderProxyNode.java:98)
at org.eclipse.hyades.test.ui.internal.navigator.proxy.TestAsse tGroupProxyNode. <init>(TestAssetGroupProxyNode.java:51)
at org.eclipse.hyades.test.ui.internal.navigator.proxy.TestAsse tGroupProxyManager.getTestAssetGroup(TestAssetGroupProxyMana ger.java:155)
at org.eclipse.hyades.test.ui.internal.navigator.proxy.TestAsse tGroupProxyManager.getTestAssetGroups(TestAssetGroupProxyMan ager.java:137)
at org.eclipse.hyades.test.ui.internal.navigator.LogicalTestNav igatorProvider.getChildren(LogicalTestNavigatorProvider.java :62)
at org.eclipse.hyades.test.ui.internal.navigator.LogicalTestNav igatorProvider.hasChildren(LogicalTestNavigatorProvider.java :52)
at org.eclipse.jface.viewers.AbstractTreeViewer.isExpandable(Ab stractTreeViewer.java:1378)
at org.eclipse.jface.viewers.AbstractTreeViewer.updatePlus(Abst ractTreeViewer.java:1845)
at org.eclipse.jface.viewers.AbstractTreeViewer.createTreeItem( AbstractTreeViewer.java:536)
at org.eclipse.jface.viewers.AbstractTreeViewer$1.run(AbstractT reeViewer.java:514)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at org.eclipse.jface.viewers.AbstractTreeViewer.createChildren( AbstractTreeViewer.java:494)
at org.eclipse.jface.viewers.AbstractTreeViewer$5.run(AbstractT reeViewer.java:983)
at org.eclipse.jface.viewers.StructuredViewer.preservingSelecti on(StructuredViewer.java:1201)
at org.eclipse.jface.viewers.AbstractTreeViewer.inputChanged(Ab stractTreeViewer.java:973)
at org.eclipse.jface.viewers.ContentViewer.setInput(ContentView er.java:248)
at org.eclipse.jface.viewers.StructuredViewer.setInput(Structur edViewer.java:1417)
at org.eclipse.hyades.ui.internal.navigator.Navigator.createPar tControl(Navigator.java:254)
at org.eclipse.ui.internal.ViewReference.createPartHelper(ViewR eference.java:305)
at org.eclipse.ui.internal.ViewReference.createPart(ViewReferen ce.java:180)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:552)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:28 3)
at org.eclipse.ui.internal.ViewPane.setVisible(ViewPane.java:51 2)
at org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:126)
at org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(PresentablePartFolder.java:268)
at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftToRightTabOrder.java:65)
at org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(TabbedStackPresentation.java:391)
at org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1102)
at org.eclipse.ui.internal.PartStack.createControl(PartStack.ja va:591)
at org.eclipse.ui.internal.PartStack.createControl(PartStack.ja va:528)
at org.eclipse.ui.internal.PartSashContainer.createControl(Part SashContainer.java:485)
at org.eclipse.ui.internal.PerspectiveHelper.activate(Perspecti veHelper.java:230)
at org.eclipse.ui.internal.Perspective.onActivate(Perspective.j ava:813)
at org.eclipse.ui.internal.WorkbenchPage.setPerspective(Workben chPage.java:2928)
at org.eclipse.ui.internal.WorkbenchPage.busySetPerspective(Wor kbenchPage.java:902)
at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPag e.java:887)
at org.eclipse.ui.internal.WorkbenchPage$12.run(WorkbenchPage.j ava:3051)
at org.eclipse.ui.internal.WorkbenchPage.setPerspective(Workben chPage.java:3049)
at org.eclipse.ui.internal.PerspectiveBarContributionItem.selec t(PerspectiveBarContributionItem.java:109)
at org.eclipse.ui.internal.PerspectiveBarContributionItem$1.wid getSelected(PerspectiveBarContributionItem.java:81)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:90)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3080)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2713)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
at org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
!ENTRY org.eclipse.hyades.test.ui 4 0 2005-09-14 21:38:07.156
!STACK 0
at org.eclipse.hyades.test.ui.navigator.TestFolderProxyNode.bui ldChildren(TestFolderProxyNode.java:121)
!STACK 0
!STACK 0
--------------070707080408040704090302--
FUDForum. Page generated in 0.07645 seconds
