Home » Eclipse Projects » Eclipse Platform » Visualizing project depedencies
Visualizing project depedencies [message #310542] Thu, 07 December 2006 07:40 Go to next message
does anybody known a tool for visualizing project dependencies in Eclipse
(preferrably an Eclipse plugin)?
I know tools for visualizing package dependencies like Bark, but as far as
I known there is nothing for whole projects.
Background: Eclipse warns you if there are cycles in the classpath, but if
the cycle is a little bit more complex then "a to b", "b to c" and "c to
a" it might be very difficult to find the cycle. Therefor I am looking for
a support by a tool.
Thanks in advance,
Ole
Re: Visualizing project depedencies [message #310549 is a reply to message #310542] Thu, 07 December 2006 10:34 Go to previous messageGo to next message
Ole Laurisch wrote:
> Hello,
> Eclipse (preferrably an Eclipse plugin)?
> as I known there is nothing for whole projects.
> if the cycle is a little bit more complex then "a to b", "b to c" and "c
> to a" it might be very difficult to find the cycle. Therefor I am
> looking for a support by a tool.
> Thanks in advance,
> Ole
Right-click your plugin project -> PDE Tools -> Open Dependencies might
be what you need.
The Plug-in Dependencies view has buttons to toggle between viewing what
plug-ins the selected plug-in depends on, and viewing which plug-ins
depend on the selected plug-in.
Hope this helps,
Matthew
Re: Visualizing project depedencies [message #310553 is a reply to message #310549] Thu, 07 December 2006 11:11 Go to previous messageGo to next message
> be what you need.
Unfortunetely I have no plugin projects. Just pure java projects. Any
other guess?
Ole
Re: Visualizing project depedencies [message #310565 is a reply to message #310542] Fri, 08 December 2006 04:21 Go to previous messageGo to next message
Originally posted by: list.daniel-hirscher.de
Ole,
I am currently writing such a plug-in to show:
- require-bundle
- import-package
- usage of extension points
in a graphically way.
I have not much time and I am new to draw2d/GEF.
You may want to compile the plug-in yourself or
join my SourceForge project.
It is currently only available in CVS:
http://pdetools.cvs.sourceforge.net/pdetools/de.hackerdan.pd e.dependencies
Daniel
Re: Visualizing project depedencies [message #310586 is a reply to message #310542] Sun, 10 December 2006 22:25 Go to previous message
Originally posted by: eclipse5.rizzoweb.com
Ole Laurisch wrote:
> Hello,
The Metrics plugin (http://metrics.sourceforge.net/) might show things
at the project level, I can't remember for sure.
Hope this helps,
Eric
Previous Topic:[Install/Update] proxy settings
Next Topic:what triggers the eclipse to clean output directory
Current Time: Wed Oct 29 20:12:05 EDT 2025
Powered by FUDForum. Page generated in 0.04964 seconds
