Exceptions while running eclipse binary for new platform [message #309599] |
Thu, 02 November 2006 05:33 |
Virender Kumar![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=virender.kumar%40hp.com) Messages: 29 Registered: July 2009 |
Junior Member |
Hi folks
I'm posting to this newsgroup for the first time. In case this is not a
good place for this question, please let me know where to post it.
I want to port Eclipse 3.2 to HPUX with GTK. For that I took the source
build drop, and then followed the steps which I found from different
sources. The eclipse binary that I get after building SWT libraries, and
platform launcher, does not run. I get exceptions in log file - which is
attached at end of this mail. So I have following questions regarding
this: 1. What all libswtXXX.so files need to be built for a new port. I
was able to build following libraries with the setup that I have :
libswt-atk-gtk-3232.so
libswt-awt-gtk-3232.so
libswt-cairo-gtk-3232.so
libswt-cde-gtk-3232.so
libswt-gtk-3232.so
libswt-mozilla-gtk-3232.so
libswt-pi-gtk-3232.so
I took following libraries directly from source dump, just in case:
libcairo-swt.so
libswt-gnome-gtk-3232.so
libswt-glx-gtk-3232.so
I copied all these libraries according to the instructions. So my
questions is do all these libraries need to be built on my platform, or
does it vary from platform to platform ?
2. After following all the steps, when I unzip the eclipse SDK, the
plugins folder has org.eclipse.swt_3.2.0.v3232o.jar. But it does not have
anything like org.eclipse.swt.<ws>.<os>.<arch>XXX.jar. I see such a jar
file in other eclipse installations. So, my question is that is such a jar
file always there ? Any clues about why this jar file might not be coming
would be very helpful.
Virender.
!ENTRY org.eclipse.osgi 4 0 2006-10-30 17:31:42.805 !MESSAGE An error
occurred while automatically activating bundle org.eclipse.ui.workbench
(81).
!STACK 0
org.osgi.framework.BundleException: The activator
org.eclipse.ui.internal.WorkbenchPlugin for bundle
org.eclipse.ui.workbench is invalid
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:141)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:966)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:317)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:256)
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .preFindLocalClass(EclipseLazyStarter.java:86)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:409)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:188)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:339)
org.eclipse.osgi.framework.internal.core.SingleSourcePackage .loadClass(SingleSourcePackage.java:37)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:388)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:352)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at java.lang.ClassLoader.loadClass(ClassLoader.java:235)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:302 )
at java.lang.ClassLoader.defineClass0(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:537)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.def ineClass(DefaultClassLoader.java:160)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineC lass(ClasspathManager.java:498)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findCla ssImpl(ClasspathManager.java:468)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClassImpl(ClasspathManager.java:427)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:410)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:391)
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:276)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:134)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1245)
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:147)
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:759)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:74)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Caused by: java.lang.NoClassDefFoundError: org/eclipse/swt/SWTError
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Class.java:16 44)
at java.lang.Class.getConstructor0(Class.java:1956)
at java.lang.Class.newInstance0(Class.java:278)
at java.lang.Class.newInstance(Class.java:261)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:136)
... 60 more
Root exception:
..... And so on
FUDForum. Page generated in 0.05196 seconds
