Home » Eclipse Projects » Eclipse Platform » Eclipse 3.2 Problems View
Eclipse 3.2 Problems View [message #308906] Mon, 09 October 2006 18:36 Go to next message
Originally posted by: barlock.usDOT.ibmDOT.com
I recently upgraded from Eclipse 3.1 to 3.2. If I have an error or warning
in my Java source code, the Problems view now shows a narrow column with one
or more +/- icons. The Resource/Path/Location columns to its right are
blank. Following rows display warnings and errors. Is there supposed to be
some column title like Warning or Error next to the +/- icon to tell you
what the following messages are?
Chris
Re: Eclipse 3.2 Problems View [message #308908 is a reply to message #308906] Mon, 09 October 2006 19:01 Go to previous messageGo to next message
Originally posted by: zzhang.numericatech.com
Do you have it in an RCP application?
If so, this is a known bug..
https://bugs.eclipse.org/bugs/show_bug.cgi?id=155299
Unfortunately, there is no workaround reported. I have to stick my
development in eclipse 3.1.
Stan
"Chris Barlock" <barlock@usDOT.ibmDOT.com> wrote in message
news:egeitn$487$1@utils.eclipse.org...
>one or more +/- icons. The Resource/Path/Location columns to its right are
>be some column title like Warning or Error next to the +/- icon to tell you
> Chris
Re: Eclipse 3.2 Problems View [message #308919 is a reply to message #308908] Mon, 09 October 2006 23:11 Go to previous messageGo to next message
No, this is just the Eclipse IDE. One thing that might be significant: I
installed 3.2, but pointed it at the same workspace I was using for 3.1.
Chris
Re: Eclipse 3.2 Problems View [message #308920 is a reply to message #308919] Mon, 09 October 2006 23:15 Go to previous messageGo to next message
I ran a quick experiment, created a new workspace, project & class with an
error in it. The Problems view now looks right.
Chris
Re: Eclipse 3.2 Problems View [message #308935 is a reply to message #308906] Tue, 10 October 2006 10:23 Go to previous message
Yes, there is supposed to be.
Can you post somewhere a screenshot of what you're seeing?
By the way, I, too, pointed 3.2 at an existing 3.1 workspace but the
Problems view works correctly - so it might be something particular to
your workspace.
Hope this helps,
Eric
Previous Topic:Could not launch the product because the associated workspace is currently in use
Next Topic:Ability to execute a batch file before eclipse platform starts up??
Current Time: Tue Apr 29 01:55:57 EDT 2025
Powered by FUDForum. Page generated in 0.28988 seconds
