installation fails [message #308895] |
Sun, 08 October 2006 20:07 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: rfr-mailbox.gmx.de
After starting no eclipse but an error message was presented.
Currently i do not understand what must be done to get a working eclipse.
Can anyone help me? Thanka in advance.
The error log:
!SESSION 2006-10-02 18:23:40.94
eclipse.buildId=M20050929-0840
java.version=1.5.0_06
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=de_DE
Command-line arguments: -os linux -ws gtk -arch x86 -data
/home/rfr/.eclipse
!ENTRY org.eclipse.osgi 2006-10-02 18:23:47.450
!MESSAGE Application error
!STACK 1
java.lang.UnsatisfiedLinkError:
/home/rfr/.eclipse/org.eclipse.platform_3.1.1.1/configuratio n/org.eclipse.osgi/bundles/69/1/.cp/libswt-pi-gtk-3139.so:
wrong ELF class: ELFCLASS32
at java.lang.ClassLoader$NativeLibrary.load(Native Method)
at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1751)
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1660)
at java.lang.Runtime.loadLibrary0(Runtime.java:822)
at java.lang.System.loadLibrary(System.java:992)
at org.eclipse.swt.internal.Library.loadLibrary(Library.java:12 3)
at org.eclipse.swt.internal.gtk.OS.<clinit>(OS.java:19)
at org.eclipse.swt.internal.Converter.wcsToMbcs(Converter.java: 63)
at org.eclipse.swt.internal.Converter.wcsToMbcs(Converter.java: 54)
at org.eclipse.swt.widgets.Display.<clinit>(Display.java:122)
at org.eclipse.ui.internal.Workbench.createDisplay(Workbench.ja va:381)
at org.eclipse.ui.PlatformUI.createDisplay(PlatformUI.java:155)
org.eclipse.ui.internal.ide.IDEApplication.createDisplay(IDE Application.java:128)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:79)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
!ENTRY org.eclipse.osgi 2006-10-02 18:23:47.471
!MESSAGE Bundle
update@plugins/org.eclipse.platform.source.linux.gtk.x86_3.1.1/ [45] was
not resolved.
!SUBENTRY 1 org.eclipse.osgi 2006-10-02 18:23:47.471
!MESSAGE Missing host org.eclipse.platform.source_3.1.1.
!SESSION 2006-10-04 23:01:51.615
/home/rfr/.eclipse
!ENTRY org.eclipse.osgi 2006-10-04 23:01:59.505
!STACK 1
!ENTRY org.eclipse.osgi 2006-10-04 23:01:59.510
!MESSAGE Bundle
not resolved.
!SUBENTRY 1 org.eclipse.osgi 2006-10-04 23:01:59.511
Re: installation fails [message #308896 is a reply to message #308895] |
Mon, 09 October 2006 01:24 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Originally posted by: myersj.gmail.com
Are you running this on an x86-64 linux install? If so, you'll need to
download the appropriate version of Eclipse.
Hope this helps,
- Jeff
> The error log:
> /home/rfr/.eclipse
> !STACK 1
> at
> at
> at
> at
> at
> at
> at
> !MESSAGE Bundle
> not resolved.
> /home/rfr/.eclipse
> !STACK 1
> at
> at
> at
> at
> at
> at
> at
> !MESSAGE Bundle
> not resolved.
FUDForum. Page generated in 0.05678 seconds
