Adding markers to eclipse resources outside eclipse through batch program [message #308778] |
Tue, 03 October 2006 09:07 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: prashanto.chatterjee.softwareag.com
I am in the midst of writing a validation framework for our custom project.
This validation mechansim is called either when eclipse is running via
project build or in a batch environment outside eclipse.
The validation mechanism basically performs semantic validation on the
models and reflects the validations in the form of markers. I wish to
somehow use the marker aspect outside eclipse when running as a batch
program.
So, my question to the group is whether it is possible to add markers to
eclipse resources from a batch program outside eclipse?
I would sincerely appreciate any help in this regard.
Prashanto
Re: Adding markers to eclipse resources outside eclipse through batch program [message #308812 is a reply to message #308778] |
Wed, 04 October 2006 06:36 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hi Guys,
Is this the right forum to ask such queries? If not can you please direct me
to the correct forum?
Prashanto
"Prashanto Chatterjee" <prashanto.chatterjee@softwareag.com> wrote in
message news:eft98g$ov0$1@utils.eclipse.org...
> project. This validation mechansim is called either when eclipse is
> running via project build or in a batch environment outside eclipse.
> program.
> Prashanto
Re: Adding markers to eclipse resources outside eclipse through batch program [message #308824 is a reply to message #308812] |
Wed, 04 October 2006 16:28 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Originally posted by: john.eclipsefaq.org
This is the right forum, but there is no way to do it. You can only
create markers via the API available on the org.eclipse.core.resources
plugin.
Prashanto Chatterjee wrote:
> Hi Guys,
> Prashanto
>>Hi,
>>program.
>>Regards,
>>Prashanto
FUDForum. Page generated in 0.04328 seconds
