Eclipse 3.1.x - plugin_configuration.ini [message #306716] |
Thu, 03 August 2006 19:02 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: An.nym.us
I want to deploy a custom RCP package with company intern settings
(tabsize and so on)
I googled around and found out, that with plugin_customization.ini I can
define the standard configuration of the properties.
However I have one problem.
We have a customized RCP which seems to create the
plugin_configuration.ini on each start in
\configuration\org.eclipse.osgi\bundles\...\plugin_customiza tion.ini
So if I edit the plugin_configuration.ini manually it it useless as it is
overriden on each program start.
I found out that I can define plugin_configuration.ini in the command line
Then my plugin_configuration.ini is used.
I do not want to use a custom command line.
Is there a way between the RCP level and the command line, where I can
specify the plugin_configuration.ini
e.g. in configuration/config.ini or similar , wich overrides the RCP
specific one ?
What about plugin.ini in the various pulgins ? (I don't like this as I
would prefer centralized customisation)
Thanks for you support
Sascha
Erstellt mit Operas revolutionärem E-Mail-Modul: http://www.opera.com/mail/
Re: Eclipse 3.1.x - plugin_configuration.ini [message #306752 is a reply to message #306716] |
Fri, 04 August 2006 07:58 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
You may put a plugin_customization.ini in your main/product/application
plugin. This is achieved by putting a new attribute in your product
definition like
<property
name="preferenceCustomization"
value="plugin_customization.ini"/>
Michael
Re: Eclipse 3.1.x - plugin_configuration.ini [message #306784 is a reply to message #306752] |
Fri, 04 August 2006 17:24 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Am 04.08.2006, 09:58 Uhr, schrieb Michael Illgner =
<michael.illgner@email.de>:
> Sascha wrote:
>> What about plugin.ini in the various pulgins ? (I don't like this as =
I =
> You may put a plugin_customization.ini in your main/product/applicatio=
n =
> plugin. This is achieved by putting a new attribute in your product =
> definition like
> <property
> name=3D"preferenceCustomization"
> value=3D"plugin_customization.ini"/>
> Michael
Hmm I am still not sure.
I realized that inside the <mainproduct>.jar file of the main product, =
there is already a "plugin_customization.ini".
However, I unpacked this and extended it with my customisation, and then=
added it to the <mainproduct>.jar with a zip programm.
Now I have the problem the with the new packed <mainproduct>.jar the =
Eclipse does not boot,
other parts of the product complain about not beeing "Singleton" ?
Would this be the correct way for a company adminstrator to adopt compan=
y =
specific settings for Eclipse and its RCP's ?
Thanks for your support.
Erstellt mit Operas revolution=E4rem E-Mail-Modul: http://www.opera.com/=
mail/
Re: Eclipse 3.1.x - plugin_configuration.ini [message #306892 is a reply to message #306716] |
Tue, 08 August 2006 17:53 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Originally posted by: dj_houghton.nospam.ca.ibm.com
Plug-in customization information can be found here:
http://www.eclipse.org/eclipse/platform-core/documents/user_ settings/plugin_customization.html
Sascha wrote:
> Hi
> (tabsize and so on)
> is overriden on each program start.
> line :
> specific one ?
> Sascha
> --Erstellt mit Operas revolutionärem E-Mail-Modul:
FUDForum. Page generated in 0.03011 seconds
