Home » Eclipse Projects » Eclipse Platform » What on earth is causing "Type Foo is not accessible due to restriction on required project bar
What on earth is causing "Type Foo is not accessible due to restriction on required project bar [message #306599] Wed, 02 August 2006 15:52 Go to next message
Paul E. Keyser is currently offline Paul E. KeyserFriend
R3.1.2, WinXP
Normally when I add a new package to a plugin, I need also to add it to the MANIFEST.MF (runtime
tab), and immediately all is fine. Just now however, adding an otherwise totally ordinary package
caused the error "Type Foo is not accessible due to restriction on required project bar.bar.bar" on
every class that imports a class Foo in the new package. What hidden Eclipse setting is causing
this? (I've tried rebuild all and suchlike.)
thanks,
Paul
Re: What on earth is causing "Type Foo is not accessible due to restriction on required project [message #306601 is a reply to message #306599] Wed, 02 August 2006 16:22 Go to previous messageGo to next message
Originally posted by: eclipse.bettsockentraeger.de
You are trying to import a package that is not intended to be used by
your plugin.
In the export package tab you can restrict the visibility of a package
to certain plugins. The TypeFoo is probably only visible to certain
plugins and is not intended to be accessed publicly.
Stefan
Paul Keyser wrote:
> R3.1.2, WinXP
> the MANIFEST.MF (runtime tab), and immediately all is fine. Just now
> however, adding an otherwise totally ordinary package caused the error
> bar.bar.bar" on every class that imports a class Foo in the new package.
> What hidden Eclipse setting is causing this? (I've tried rebuild all and
> suchlike.)
> thanks,
> Paul
Re: What on earth is causing "Type Foo is not accessible due to restriction on required project [message #306611 is a reply to message #306601] Wed, 02 August 2006 17:17 Go to previous messageGo to next message
Thanks for quick ereply -- with a sensible interpretation, that doesn't work here.
The new package was created by me; I did not add any restriction.
The new package contains only classes that I moved from its parent, where they were being
succesfully and correctly exported.
So somehow Eclipse its own self got the idea to prevent exporting those classes -- why?
Paul
Re: What on earth is causing "Type Foo is not accessible due to restriction on required project [message #306620 is a reply to message #306611] Wed, 02 August 2006 20:56 Go to previous messageGo to next message
Originally posted by: wharley.bea.com
"Paul Keyser" <rolarenfan@earthlink.net> wrote in message
news:eaqmnu$975$1@utils.eclipse.org...
> work here.
> they were being succesfully and correctly exported.
> classes -- why?
Paul, can you be more specific about the details of your case? E.g., post
the contents of your manifest.mf? For instance, it's unclear from your
initial posting what "bar.bar.bar" is - I don't know whether that's actually
a package in your project or not, I don't know whether that's the package
that Foo is contained in, I don't know the name of the project. I think
more detail will help people give you a better answer.
Re: What on earth is causing "Type Foo is not accessible due to restriction on required project [message #306623 is a reply to message #306620] Wed, 02 August 2006 23:27 Go to previous messageGo to next message
Well, I have quite a few plugins, somewhat complexly-related. But the basic situation involves the
main plugin, com.mun.ist.main, and a plugin on which main depends, com.mun.ist.service. The
MANIFEST.MF of main includes:
Require-Bundle: org.eclipse.core.runtime,
org.eclipse.core.expressions,
org.eclipse.ui,
org.eclipse.ui.forms,
com.mun.ist.service,
And the MANIFEST.MF of service includes:
Export-Package: .,
com.mun.ist.first.third.party.jar.code,
com.mun.ist.service.fails,
com.mun.ist.service.works,
com.mun.ist.some.other.third.party.jar.code,
When I added com.mun.ist.service.works (the package) I made sure to add that package to
service/MANIFEST.MF, and all was fine. Time passed, bits changed; I needed to add
com.mun.ist.service.fails, and did so, and added it to service/MANIFEST.MF (after, of course, adding
a few new classes).
I then took some other classes, call them Foo and Bar, both of which were imported by the plugin
"main", and *MOVED* them from com.mun.ist.service down into com.mun.ist.service.fails (using the
refactoring tool); the imports were correctly adjusted in those classes of "main" that imported Foo
and/or Bar.
But I also got the error I mentioned. Now, truly weirdly, when I redo the operation (after having
shut down and restarted Eclipse), all happens as I expected it would ... and no error.
Go figure, eh?
Paul
Re: What on earth is causing "Type Foo is not accessible due to restriction on required project [message #306624 is a reply to message #306623] Thu, 03 August 2006 00:55 Go to previous message
news:earcdc$ard$1@utils.eclipse.org...
> operation (after having shut down and restarted Eclipse), all happens as I
It seems that Eclipse caches some information about classloading from
plug-ins; I have never looked into the details, but I have found that at
times classes that "I know are there" in a deployed instance (including even
a debug runtime instance) don't get successfully resolved until I start
Eclipse with -clean. I wish I could be more specific about exactly what is
cached when and how to clear it, but I don't know the answers.
When in doubt reboot...
Previous Topic:PDE "organize manifests"
Next Topic:Wait for job when workbench is closed
Current Time: Wed Jan 15 07:08:09 GMT 2025
Powered by FUDForum. Page generated in 0.09759 seconds
