Home » Eclipse Projects » Eclipse Platform » don't show error dialog on problem marker in Eclipse 3.2?
don't show error dialog on problem marker in Eclipse 3.2? [message #306401] Thu, 27 July 2006 20:12 Go to next message
Originally posted by: zzhang.numericatech.com
I just upgrade my eclipse to 3.2.
I have an editor which will mark some errors (IMarker.PROBLEM) on the file,
using
MarkerUtilities.createMarker(file, map, IMarker.PROBLEM)
Now in 3.2, everytime, when a marker is created for the file, an error
dialog will popout
title: Error
msg: An error has occured. See error log for more details.
while previously in 3.1, it doesn't show such dialog.
Is there a flag that I can turn off the error dialog?
Thanks a lot.
Sincerely,
Stan
Re: don't show error dialog on problem marker in Eclipse 3.2? [message #306402 is a reply to message #306401] Thu, 27 July 2006 20:18 Go to previous messageGo to next message
Originally posted by: wharley.bea.com
"zzhang" <zzhang@numericatech.com> wrote in message
news:eabkpf$lm3$1@utils.eclipse.org...
> file, using
> dialog will popout
> title: Error
Have you looked in the error log? It sounds like maybe something else is
broken - that is, maybe there are actually errors happening, perhaps because
of some problem in your marker implementation. Maybe the error log would
contain an exception stack trace showing where the error is.
Re: don't show error dialog on problem marker in Eclipse 3.2? [message #306406 is a reply to message #306402] Thu, 27 July 2006 22:50 Go to previous message
Thanks, Walter. You're right.
I started another thread "Error on displaying Problem Marker in Problem View
in Eclipse 3.2"
Sincerely,
Stan
"Walter Harley" <wharley@bea.com> wrote in message
news:eabl4j$n31$1@utils.eclipse.org...
>> file, using
>> dialog will popout
>> title: Error
> because of some problem in your marker implementation. Maybe the error
> log would contain an exception stack trace showing where the error is.
Previous Topic:How do I add a shell within the editor window and move it with my mouse.
Next Topic:Error in xDoclet Page
Current Time: Tue Jul 01 05:57:53 EDT 2025
Powered by FUDForum. Page generated in 0.03596 seconds
