Develop multiple versions of a plugin at once [message #305944] |
Mon, 17 July 2006 09:30 |
Originally posted by: contact.noelios.com
I'm developing two versions of the same plugin at the same time: A1 and
A2. Also A1 depends on another plugin B1 and A2 depends on the same
plugin, but a latter version: B2.
When I have all four plugins open at the same time in Eclipse 3.2, it
seems that the classpath entries overlap and conflict. I have to close
A1 and B1 if I want to work on A2 and B2, or the other way around.
It there a solution to this problem? If not, could this be directly
supported in the future?
Jerome
Restlet, a REST framework for Java
http://www.restlet.org
Re: Develop multiple versions of a plugin at once [message #306048 is a reply to message #305986] |
Wed, 19 July 2006 07:19 |
Thanks Sunny, that's a good workaround. It is even used by Eclipse IDE
to deal with the two versions of JUnit (3.8 and 4.1).
Jerome
sunnyawake wrote :
> seems you have to change plugin id as a temp hack to make that works.
> Sunny Sun
> "Jerome Louvel" <contact@noelios.com>
> ??????:e9flav$7df$1@utils.eclipse.org...
>> seems that the classpath entries overlap and conflict. I have to close A1
Re: Develop multiple versions of a plugin at once [message #306049 is a reply to message #306005] |
Wed, 19 July 2006 07:22 |
Walter Harley wrote :
> "Jerome Louvel" <contact@noelios.com> wrote in message
> news:e9flav$7df$1@utils.eclipse.org...
> Why not use multiple workspaces?
Because I really need to quickly switch from one plugin version to the
other. I have other plugins that can use any available version, A1 or A2.
Idieally, I would like Eclipse to use the dependency constraints based
on min/max versions to use the best plugin. Unfortunately, this version
resolution seems to be only supported at runtime.
Jerome
FUDForum. Page generated in 4.45922 seconds
