eclipse and xdebug not working together Running a php program in console hangs when xdebug in on debug By: Eclipse User on Mon, 18 November 2024 |
1250 |
Mon, 18 November 2024 09:04 By: Eclipse User  |
How can I see the command line from the Eclipse IDE By: Eclipse User on Sat, 31 August 2024 |
4318 |
Wed, 11 September 2024 06:39 By: Eclipse User  |
PHP code folding functionality does not work despite configuring, PHP code folding does not work By: Eclipse User on Sat, 07 September 2024 |
4074 |
Sat, 07 September 2024 02:34 By: Eclipse User  |
The meaning of the PHP Version. By: Eclipse User on Sun, 25 August 2024 |
2462 |
Sun, 25 August 2024 16:19 By: Eclipse User  |
Best lightweight IDE for PHP programming? By: Eclipse User on Mon, 23 November 2020 |
8075 |
Tue, 20 August 2024 03:18 By: Eclipse User  |
Xdebug doesn't work Debugger PHP By: Eclipse User on Fri, 12 May 2023 |
5284 |
Sat, 03 August 2024 05:54 By: Eclipse User  |
PHP built in server wrong path and no files The server has a wrong path and no files are found when requested By: Eclipse User on Fri, 02 August 2024 |
1543 |
Sat, 03 August 2024 05:43 By: Eclipse User  |
New PHP Project from Composer Package can't see package version By: Eclipse User on Fri, 05 July 2024 |
11565 |
Fri, 05 July 2024 12:23 By: Eclipse User  |
How do I disable auto-completion pop-up By: Eclipse User on Thu, 21 March 2024 |
2528 |
Thu, 25 April 2024 04:06 By: Eclipse User  |
Quick Type Hierarchy not working anymore The quick type hierarchy command does not work anymore in .php-files in Eclipse 2024-03 on Mac OS By: Eclipse User on Mon, 15 April 2024 |
1667 |
Mon, 15 April 2024 11:41 By: Eclipse User  |
[GUIDE] Another Round at Configuring this Properly in debian-12.5.0-amd64 w/ apache2 & xdebug Major Attempt #2 Configuring Eclipse PDT in debian-12.5.0-amd64 w/ apache2, xdebug, mariadb By: Eclipse User on Wed, 10 April 2024 |
1827 |
Wed, 10 April 2024 19:18 By: Eclipse User  |
How do I change the default Run Web Browser? (Mine opens an Application that isn't a Web Browser) I am running Linux x64 (Debian-12.5.0-amd64 with sddm and lxqt) & Eclipse IDE PHP Developers 2024-03 (4.31.0) By: Eclipse User on Fri, 29 March 2024 |
2602 |
Fri, 29 March 2024 16:45 By: Eclipse User  |
Don't trigger Formatter when clipboard does not contain line break By: Eclipse User on Thu, 25 January 2024 |
2375 |
Wed, 21 February 2024 05:43 By: Eclipse User  |
Trying to "Run a simple HTTP Server locally to test your web pages" Using an Aptana feature in Eclipse PHP Perspective By: Eclipse User on Thu, 21 December 2023 |
4132 |
Tue, 30 January 2024 03:04 By: Eclipse User  |
Looking for ideas for IoT projects By: Eclipse User on Wed, 06 September 2023 |
12306 |
Mon, 22 January 2024 06:47 By: Eclipse User  |
How long does it take to review PDT bugs? I created a PDT bug report. How long does it usually take to process such applications? By: Eclipse User on Thu, 04 January 2024 |
1932 |
Thu, 04 January 2024 15:23 By: Eclipse User  |
Unable to find phpunit phar unable to find phpunit phar. check phpunit configuration By: Eclipse User on Fri, 29 December 2023 |
1882 |
Sat, 30 December 2023 15:04 By: Eclipse User  |
Auth Fail while synchronizing after Eclipse update By: Eclipse User on Thu, 21 December 2023 |
3158 |
Thu, 21 December 2023 06:15 By: Eclipse User  |
How to get eclipse with xdebug running? By: Eclipse User on Wed, 24 May 2023 |
4114 |
Wed, 06 December 2023 03:10 By: Eclipse User  |
Checking PHP code for vulnerabilities Checking PHP code for vulnerabilities By: Eclipse User on Fri, 10 November 2023 |
1882 |
Sun, 03 December 2023 13:01 By: Eclipse User  |
Empty Context Sensitive Help overlay windows Hovering over an identifier opens a CSH window frame, but it contains no text By: Eclipse User on Sun, 26 November 2023 |
1970 |
Sun, 26 November 2023 08:15 By: Eclipse User  |
Eclipse error after PHP project creation. Eclipse error after PHP project creation. By: Eclipse User on Wed, 25 October 2023 |
2121 |
Wed, 25 October 2023 06:18 By: Eclipse User  |
JavaScript support By: Eclipse User on Tue, 19 February 2019 |
12913 |
Tue, 17 October 2023 07:31 By: Eclipse User  |
How to Enable JQuery Code Assistant on Eclipse? By: Eclipse User on Sat, 14 October 2023 |
2479 |
Sat, 14 October 2023 12:10 By: Eclipse User  |
Unable To Resolve Import By: Eclipse User on Fri, 25 March 2022 |
6461 |
Tue, 10 October 2023 07:02 By: Eclipse User  |
What is a better dev setup instead of xampp? dev setup By: Eclipse User on Thu, 03 August 2023 |
4060 |
Wed, 04 October 2023 01:12 By: Eclipse User  |
Initializing PHP Tooling Endless task By: Eclipse User on Wed, 15 March 2023 |
4294 |
Wed, 04 October 2023 01:04 By: Eclipse User  |
How do I get rid of the Proposals popup? Title says it all By: Eclipse User on Fri, 11 November 2022 |
3534 |
Mon, 02 October 2023 06:28 By: Eclipse User  |
Synchronized PHP project - synchronizations hangs By: Eclipse User on Thu, 08 June 2023 |
3499 |
Thu, 14 September 2023 03:56 By: Eclipse User  |
Syntax Errors not detected By: Eclipse User on Sat, 20 May 2023 |
3157 |
Fri, 08 September 2023 09:26 By: Eclipse User  |
What should a PHP developer know? By: Eclipse User on Sat, 05 December 2020 |
6027 |
Fri, 01 September 2023 02:32 By: Eclipse User  |
Show distinct column values in pyspark dataframe pyspark By: Eclipse User on Sat, 26 August 2023 |
4155 |
Mon, 28 August 2023 07:29 By: Eclipse User  |
SSHTunnel Configuration , How To setup? Need help By: Eclipse User on Fri, 25 August 2023 |
1944 |
Sun, 27 August 2023 15:10 By: Eclipse User  |
WORDPRESS Remote Debugging SSH Tunnel Putty Can't get it to work By: Eclipse User on Thu, 24 August 2023 |
2668 |
Sun, 27 August 2023 15:09 By: Eclipse User  |
Project Explorer NOT refresh By: Eclipse User on Fri, 30 June 2023 |
6634 |
Mon, 10 July 2023 08:18 By: Eclipse User  |
Eclipse IDE for PHP Developers By: Eclipse User on Fri, 07 July 2023 |
2745 |
Fri, 07 July 2023 10:58 By: Eclipse User  |
PHP reading of a file sent via a form I made the decision to write a super-simple php script that simply reads the form and emits one if it isn't submitted. However, if the form is submitted, I want my script to retrieve the data from the By: Eclipse User on Thu, 06 July 2023 |
6371 |
Thu, 06 July 2023 04:27 By: Eclipse User  |
Support for PHP 8 By: Eclipse User on Thu, 10 December 2020 |
18360 |
Thu, 29 June 2023 06:19 By: Eclipse User  |
Implement Laravel To My website By: Eclipse User on Thu, 22 June 2023 |
3084 |
Mon, 26 June 2023 21:15 By: Eclipse User  |
What can I do to become a better PHP programmer? By: Eclipse User on Sat, 12 February 2022 |
7555 |
Fri, 23 June 2023 02:01 By: Eclipse User  |
php Refactoring does not change references By: Eclipse User on Mon, 15 May 2023 |
2610 |
Mon, 15 May 2023 12:29 By: Eclipse User  |
[solved] Installation of PHP impossible Eclipse can't install Mylyn In tegration By: Eclipse User on Tue, 09 May 2023 |
2356 |
Thu, 11 May 2023 16:55 By: Eclipse User  |
How to configure Zend Debugger with Eclipce on Windows By: Eclipse User on Wed, 12 April 2023 |
3206 |
Wed, 12 April 2023 02:08 By: Eclipse User  |
How to configure (Run on server) and (PHP web application) on Windows By: Eclipse User on Tue, 11 April 2023 |
4905 |
Wed, 12 April 2023 01:40 By: Eclipse User  |
AWS SDK for PHP Eventbridge scheduler with api destination throws error as Provided Arn is not in co Hi I am trying to create a schedule with aws eventbridge schedule By: Eclipse User on Tue, 04 April 2023 |
2904 |
Tue, 04 April 2023 08:25 By: Eclipse User  |
RE: Recommended project layout? By: Eclipse User on Mon, 03 April 2023 |
2531 |
Mon, 03 April 2023 08:50 By: Eclipse User  |
Fatal Error Message while using mysql while uploading images Fatal Error By: Eclipse User on Wed, 29 March 2023 |
2546 |
Wed, 29 March 2023 13:29 By: Eclipse User  |
Eclipse 2022-12 issues Eclipse can't find a debugger By: Eclipse User on Wed, 15 February 2023 |
3460 |
Sat, 11 March 2023 18:58 By: Eclipse User  |
<html> <input type="text" label="name"> How to include the html equiv of text box By: Eclipse User on Fri, 28 October 2022 |
4258 |
Tue, 07 March 2023 11:02 By: Eclipse User  |
Must have tools while developing in PHP? By: Eclipse User on Tue, 07 March 2023 |
2832 |
Tue, 07 March 2023 03:04 By: Eclipse User  |
Function documentation Missing parameters in automatic function documentation By: Eclipse User on Wed, 01 March 2023 |
2498 |
Wed, 01 March 2023 15:01 By: Eclipse User  |
Required library cannot denote external folder or archive Error when creating a PHP remote project By: Eclipse User on Sat, 11 February 2023 |
3015 |
Sat, 11 February 2023 14:52 By: Eclipse User  |
Getting Error With PHP Code: Need Help By: Eclipse User on Tue, 31 January 2023 |
2859 |
Tue, 31 January 2023 07:03 By: Eclipse User  |
Internal Error When Debugging PHP Code An internal error occurs when debugging PHP code. By: Eclipse User on Wed, 25 March 2020 |
7431 |
Tue, 31 January 2023 00:54 By: Eclipse User  |
Incorrectly thinks a variable is global when renaming Renaming a variable in a file renames it in every file in the project By: Eclipse User on Mon, 23 January 2023 |
2532 |
Tue, 24 January 2023 06:45 By: Eclipse User  |
install issues getting the debugger to work By: Eclipse User on Wed, 10 June 2020 |
4676 |
Wed, 28 December 2022 20:35 By: Eclipse User  |
The best lightweight IDE for PHP programming? By: Eclipse User on Sat, 17 December 2022 |
2741 |
Sat, 17 December 2022 07:08 By: Eclipse User  |
PHP's array population from the Year Planner Is there an alternative way to do this that I haven't tried? By: Eclipse User on Fri, 16 December 2022 |
3078 |
Fri, 16 December 2022 07:32 By: Eclipse User  |
Update issue By: Eclipse User on Mon, 12 December 2022 |
3794 |
Tue, 13 December 2022 23:40 By: Eclipse User  |
Eclipse PDT crash when editing Javascript files Javascript Crashes Eclipse By: Eclipse User on Wed, 07 December 2022 |
3632 |
Wed, 07 December 2022 23:53 By: Eclipse User  |
Issues when tweaking settings I'm having a bad time using the plugin By: Eclipse User on Sun, 27 November 2022 |
3599 |
Wed, 30 November 2022 04:48 By: Eclipse User  |
Error installing PDT from Help -> Install new software I get a weird error when trying to install the plugin By: Eclipse User on Thu, 24 November 2022 |
2832 |
Sun, 27 November 2022 14:50 By: Eclipse User  |
[Solved] PHPUnit PHAR Invalid Getting invalid phar for anything post phpunit 7 By: Eclipse User on Fri, 25 November 2022 |
2310 |
Sat, 26 November 2022 13:02 By: Eclipse User  |
LAMP and XDebug/Eclipse-PDT on the same machine. Configuration is not quite right. "Test" button is not available. By: Eclipse User on Wed, 02 November 2022 |
3543 |
Wed, 02 November 2022 10:28 By: Eclipse User  |
How does one become a good PHP developer? By: Eclipse User on Thu, 20 October 2022 |
3667 |
Thu, 20 October 2022 06:13 By: Eclipse User  |
Error to Choose the type of server to create By: Eclipse User on Fri, 09 September 2022 |
3585 |
Sun, 11 September 2022 17:43 By: Eclipse User  |
Xdebug and RSE - wrong path (and other questions) Xdebug does not stop at my breakpoints, but seems to work otherwise By: Eclipse User on Sun, 10 June 2012 |
24442 |
Tue, 23 August 2022 10:02 By: Eclipse User  |
Code completion works occasionally - missing node.js By: Eclipse User on Mon, 22 August 2022 |
2565 |
Mon, 22 August 2022 19:54 By: Eclipse User  |
I need a donate button! By: Eclipse User on Sat, 25 June 2022 |
11812 |
Fri, 29 July 2022 08:47 By: Eclipse User  |
Best lightweight IDE for PHP programming? Hi, I have a very slow machine (Atom with 1 gig of ram). I normally use Notepad++ but now want more advance features like a debugger, code completition, etc. By: Eclipse User on Wed, 13 July 2022 |
5599 |
Fri, 29 July 2022 05:53 By: Eclipse User  |
Need Some Help Regarding Setup By: Eclipse User on Tue, 12 July 2022 |
5657 |
Mon, 25 July 2022 00:23 By: Eclipse User  |
Upgrade from Zend Studio 13.6 By: Eclipse User on Wed, 06 July 2022 |
2704 |
Wed, 06 July 2022 19:40 By: Eclipse User  |
Step back in debugger How to step back to previous instructions By: Eclipse User on Sun, 19 May 2013 |
30978 |
Thu, 28 April 2022 06:18 By: Eclipse User  |
Debug option By: Eclipse User on Fri, 15 April 2022 |
3866 |
Fri, 15 April 2022 08:37 By: Eclipse User  |
Termination of Debugging session hangs PDT By: Eclipse User on Tue, 20 March 2018 |
7879 |
Sat, 09 April 2022 00:37 By: Eclipse User  |
Is PDT being actively maintained? No merged PRs all year By: Eclipse User on Fri, 01 October 2021 |
7274 |
Wed, 16 March 2022 10:45 By: Eclipse User  |
SVN Version Error Can't connect Eclipse to SVN even after updating the version it uses By: Eclipse User on Wed, 16 February 2022 |
4287 |
Wed, 16 February 2022 22:26 By: Eclipse User  |
Auto closing parenthesis in php file By: Eclipse User on Wed, 02 February 2022 |
4879 |
Wed, 02 February 2022 10:05 By: Eclipse User  |
How do I synchronize my Eclipse PHP (Git) Directory with a Windows IIS localhost folder By: Eclipse User on Wed, 26 January 2022 |
4860 |
Wed, 26 January 2022 18:11 By: Eclipse User  |
Eclipse compains "Unable to generate valid launch configuration" Cannot run or debug any PHP file anymore. Eclipse compains ""Unable to generate valid launch configuration" By: Eclipse User on Sun, 23 January 2022 |
7831 |
Sun, 23 January 2022 15:23 By: Eclipse User  |
[Ignore topic] Avoid automatic start of debug when "calling" web application in browser A debug configuration is defined for test.php, but I do no wan the debugger to start when I "call" the file from the browser By: Eclipse User on Fri, 21 January 2022 |
3395 |
Sat, 22 January 2022 14:10 By: Eclipse User  |
PDT, MAMP, and Xdebug Web pages always go into debug mode By: Eclipse User on Tue, 28 December 2021 |
4530 |
Tue, 28 December 2021 09:57 By: Eclipse User  |
Stop Flex when first matching a TOKEN By: Eclipse User on Mon, 15 November 2021 |
3952 |
Mon, 15 November 2021 05:13 By: Eclipse User  |
How do i get started? By: Eclipse User on Thu, 14 October 2021 |
4123 |
Thu, 14 October 2021 06:50 By: Eclipse User  |
How to serve PHP pages on jetty server with Apache Karaf? By: Eclipse User on Wed, 06 October 2021 |
29086 |
Wed, 06 October 2021 05:59 By: Eclipse User  |
Error with Codeigniter 4.1.4 I cant execute php project with Codeigniter By: Eclipse User on Sat, 25 September 2021 |
5226 |
Tue, 28 September 2021 04:43 By: Eclipse User  |
How to prevent token matching inside strings Does Eclipse understand when the caret/cursor is inside a string or not By: Eclipse User on Tue, 21 September 2021 |
4625 |
Tue, 21 September 2021 02:41 By: Eclipse User  |
I want to learn how to be a proper PHP developer By: Eclipse User on Tue, 08 December 2020 |
5988 |
Tue, 31 August 2021 02:43 By: Eclipse User  |
Could not create the view: org.eclipse.rse.ui.view.systemView By: Eclipse User on Sat, 31 July 2021 |
4800 |
Thu, 12 August 2021 21:01 By: Eclipse User  |
Missing javascript support in 2021-06 By: Eclipse User on Thu, 15 July 2021 |
4729 |
Sun, 18 July 2021 00:14 By: Eclipse User  |
Need help By: Eclipse User on Sun, 06 December 2020 |
4992 |
Thu, 08 July 2021 05:35 By: Eclipse User  |
PHP Server on Elcipse PHP Server Error By: Eclipse User on Sun, 24 January 2021 |
8209 |
Thu, 27 May 2021 02:59 By: Eclipse User  |
Xdebug CLI mode ? Xdebug CLI By: Eclipse User on Mon, 17 May 2021 |
4067 |
Tue, 18 May 2021 11:12 By: Eclipse User  |
PHP generics support in Eclipse By: Eclipse User on Sun, 22 November 2020 |
12942 |
Mon, 17 May 2021 21:15 By: Eclipse User  |
PHP project creation fails Attempt to create a new PHP project fails in eclipse By: Eclipse User on Thu, 13 May 2021 |
3961 |
Thu, 13 May 2021 21:23 By: Eclipse User  |
Missing Inspect Element on last few versions Inspect Element no longer an option, Can not evaluate code By: Eclipse User on Mon, 03 May 2021 |
6427 |
Mon, 03 May 2021 04:59 By: Eclipse User  |
How to use PDT as a standalone tool By: Eclipse User on Fri, 16 April 2021 |
3760 |
Fri, 16 April 2021 09:17 By: Eclipse User  |
PHP class "cannot be resolved to a type" error Eclipse can't find the class declaration because the path is dynamic By: Eclipse User on Wed, 07 April 2021 |
4419 |
Sat, 10 April 2021 18:01 By: Eclipse User  |
Having multiple source folders sharing same output target By: Eclipse User on Sun, 04 April 2021 |
3458 |
Sun, 04 April 2021 11:14 By: Eclipse User  |
XDebug doesn't work properly By: Eclipse User on Thu, 04 February 2021 |
12470 |
Tue, 30 March 2021 10:57 By: Eclipse User  |
How to include workspcace project folder in run URLs in Ecplise for PHP? By: Eclipse User on Wed, 03 March 2021 |
3938 |
Wed, 03 March 2021 04:12 By: Eclipse User  |
Font in JavaScript Editor in Eclipse PDT 2020-012 (4.18.0) By: Eclipse User on Mon, 15 February 2021 |
4714 |
Mon, 01 March 2021 08:18 By: Eclipse User  |
Eclipse - problem with two runing php web applications from two different projects Eclipse - problem with two runing php web applications from two different projects - each project is in a separate Eclipse instance - problem with interference? By: Eclipse User on Tue, 09 February 2021 |
16014 |
Tue, 09 February 2021 18:25 By: Eclipse User  |
Generate Methods in PHP class Automatically generate some Methods in PHP Class By: Eclipse User on Fri, 05 February 2021 |
4164 |
Mon, 08 February 2021 02:35 By: Eclipse User  |
Eclipse PHP Tools and Existing Development Site By: Eclipse User on Wed, 03 February 2021 |
11759 |
Wed, 03 February 2021 09:36 By: Eclipse User  |
How about Eclipse PDT as PHP IDE? By: Eclipse User on Tue, 19 January 2021 |
6410 |
Mon, 01 February 2021 22:23 By: Eclipse User  |
Trigger CSS autocomplete Trigger CSS autocomplete in Eclipse PHP By: Eclipse User on Mon, 28 September 2020 |
3402 |
Thu, 21 January 2021 07:27 By: Eclipse User  |
PHP Debug - Highlight code - Context->Inspect Context Menu -> Inspect By: Eclipse User on Tue, 22 October 2019 |
6966 |
Tue, 22 December 2020 02:55 By: Eclipse User  |
xdebug session is lost after some time without debugging it xdebug or eclipse debug session stops after some minutes without debugging it By: Eclipse User on Thu, 14 June 2012 |
14089 |
Wed, 16 December 2020 05:47 By: Eclipse User  |
DomDocument cannot be resolved to a class cannot resolve to a type By: Eclipse User on Fri, 20 November 2020 |
11483 |
Fri, 20 November 2020 12:01 By: Eclipse User  |
PDT 5.x Composer support PSR-4 syntax By: Eclipse User on Sat, 14 November 2020 |
2962 |
Sat, 14 November 2020 03:32 By: Eclipse User  |
[xdebug] Change value in "variables" pane get wrong result By: Eclipse User on Sat, 24 October 2020 |
3230 |
Sat, 24 October 2020 10:22 By: Eclipse User  |
How to Debug with Eclipse and PDT, specifically how to use the Built-in Server By: Eclipse User on Sat, 09 May 2020 |
19 |
14340 |
Wed, 21 October 2020 04:40 By: Eclipse User  |
Can I use bootstrap and PHP together? By: Eclipse User on Fri, 16 October 2020 |
3021 |
Fri, 16 October 2020 09:44 By: Eclipse User  |
Eclipse for PHP Developers 2020-06 - Can JavaScript Task Tags Be Shown in the Task View? By: Eclipse User on Sat, 20 June 2020 |
3239 |
Thu, 01 October 2020 06:42 By: Eclipse User  |
Open declaration don't open file in write mode editor By: Eclipse User on Wed, 22 April 2020 |
6978 |
Wed, 30 September 2020 06:42 By: Eclipse User  |
Renaming variable renamed in ALL files of the project By: Eclipse User on Sat, 26 September 2020 |
3065 |
Sat, 26 September 2020 07:39 By: Eclipse User  |
Generate Getters and Setters not working Nothing happens when I click Generate Getters and Setters By: Eclipse User on Thu, 25 June 2020 |
8568 |
Wed, 23 September 2020 07:56 By: Eclipse User  |
Can display errors with undefined variables in class By: Eclipse User on Wed, 16 September 2020 |
4189 |
Wed, 16 September 2020 02:53 By: Eclipse User  |
Xdebug - breakpoints don't work By: Eclipse User on Thu, 01 November 2018 |
7566 |
Tue, 01 September 2020 05:47 By: Eclipse User  |
[SOLVED] PDT and Xdebug 2.9.4 By: Eclipse User on Wed, 15 April 2020 |
10975 |
Tue, 01 September 2020 05:37 By: Eclipse User  |
Custom name for anoymous methods in outline view By: Eclipse User on Thu, 27 August 2020 |
8983 |
Thu, 27 August 2020 04:53 By: Eclipse User  |
Remote debugging .... what have I got wrong? Thought I knew what Iw as doing but ... By: Eclipse User on Wed, 26 August 2020 |
3045 |
Wed, 26 August 2020 04:26 By: Eclipse User  |
xdebug for Eclipse IDE PHP ver R 2020-06 Eclipse IDE PHP Debugging Server Setup By: Eclipse User on Tue, 25 August 2020 |
3564 |
Tue, 25 August 2020 05:03 By: Eclipse User  |
PHPUnit tests in Eclipse generates a java.util.ConcurrentModificationException PHPUnit tests in Eclipse generates a java.util.ConcurrentModificationException By: Eclipse User on Wed, 10 July 2019 |
9498 |
Mon, 17 August 2020 17:13 By: Eclipse User  |
css content assist behavior By: Eclipse User on Tue, 04 August 2020 |
6724 |
Tue, 11 August 2020 16:25 By: Eclipse User  |
Is an update site archive available for PDT? By: Eclipse User on Mon, 10 August 2020 |
3159 |
Mon, 10 August 2020 18:33 By: Eclipse User  |
Cryptic error message about "The selection cannot be launched..." By: Eclipse User on Mon, 15 October 2018 |
4587 |
Wed, 29 July 2020 03:52 By: Eclipse User  |
Eclipse formats style code within {} Problem with code formatting By: Eclipse User on Tue, 30 June 2020 |
3486 |
Tue, 30 June 2020 11:12 By: Eclipse User  |
Eclipse 2020-06 - JavaScript Content Assist By: Eclipse User on Sat, 20 June 2020 |
3132 |
Sat, 20 June 2020 11:58 By: Eclipse User  |
htaccess files By: Eclipse User on Mon, 23 March 2020 |
5725 |
Tue, 16 June 2020 02:07 By: Eclipse User  |
New Composer Project -> Configure PHP Executable Error Message: Unable to run Composer By: Eclipse User on Tue, 14 April 2020 |
12566 |
Fri, 05 June 2020 12:17 By: Eclipse User  |
Composer Vendor Folder being removed Vendor Folder is removed everyday when using Eclipse By: Eclipse User on Wed, 12 December 2018 |
7245 |
Thu, 04 June 2020 02:58 By: Eclipse User  |
Can't find references to variables or constant any-more The "find references" functionnality seems broken for variables and constants By: Eclipse User on Wed, 05 February 2020 |
6707 |
Wed, 03 June 2020 10:29 By: Eclipse User  |
Operation lockout after starting multiple operations By: Eclipse User on Tue, 26 May 2020 |
3385 |
Wed, 27 May 2020 11:03 By: Eclipse User  |
Autocomplete does not work with backslash Autocomplete does not work with backslash By: Eclipse User on Fri, 15 May 2020 |
3908 |
Sat, 16 May 2020 02:39 By: Eclipse User  |
Project developing moved to GitHub By: Eclipse User on Thu, 14 May 2020 |
3717 |
Thu, 14 May 2020 11:45 By: Eclipse User  |
Php is not running on my computer. Somebody Help!! php is not running By: Eclipse User on Sun, 03 May 2020 |
4754 |
Sat, 09 May 2020 09:04 By: Eclipse User  |
CSS selectors in Outline Panel By: Eclipse User on Fri, 08 May 2020 |
3566 |
Fri, 08 May 2020 16:19 By: Eclipse User  |
SVN integration by default? SVN Subversive Plugin request By: Eclipse User on Wed, 29 April 2020 |
4736 |
Wed, 29 April 2020 09:03 By: Eclipse User  |
the IDE does not autocomplete by calling the methods. By: Eclipse User on Mon, 27 April 2020 |
4680 |
Tue, 28 April 2020 16:51 By: Eclipse User  |
Color white on white background unreadable colors By: Eclipse User on Mon, 20 April 2020 |
5265 |
Mon, 20 April 2020 07:14 By: Eclipse User  |
Facing Certain PHP Security Issue I Am Facing Butter Overflows Security Issue in PHP By: Eclipse User on Sat, 18 April 2020 |
4170 |
Sat, 18 April 2020 07:04 By: Eclipse User  |
javascript font color too dark By: Eclipse User on Thu, 09 April 2020 |
7110 |
Thu, 09 April 2020 11:50 By: Eclipse User  |
eclipse checks syntax inside of quoted string erormessages By: Eclipse User on Wed, 08 April 2020 |
6659 |
Wed, 08 April 2020 10:15 By: Eclipse User  |
PROBLEMA CON PHP ERROR 404 By: Eclipse User on Tue, 24 March 2020 |
4794 |
Tue, 24 March 2020 15:28 By: Eclipse User  |
PHP built in Server How to run symfony project in php inbuilt server By: Eclipse User on Mon, 23 March 2020 |
4209 |
Mon, 23 March 2020 00:33 By: Eclipse User  |
mysql_fetch_array()/mysql_fetch_assoc()/mysql_fetch_row()/mysql_num_rows etc... expects parameter 1 By: Eclipse User on Mon, 23 March 2020 |
4358 |
Mon, 23 March 2020 00:01 By: Eclipse User  |
ptp-sync folder size The folder size is very large, doesn't make sense... By: Eclipse User on Tue, 18 February 2020 |
6740 |
Wed, 26 February 2020 10:13 By: Eclipse User  |
[URGENT] Synchronization error for project My project cannot sync !!! By: Eclipse User on Wed, 26 February 2020 |
5275 |
Wed, 26 February 2020 10:11 By: Eclipse User  |
Run and debug configurations Problem with run/debug By: Eclipse User on Mon, 24 February 2020 |
3145 |
Mon, 24 February 2020 23:42 By: Eclipse User  |
Importing Wordpress into Eclipse Importing Wordpress into Eclipse By: Eclipse User on Wed, 12 September 2018 |
9184 |
Mon, 24 February 2020 07:13 By: Eclipse User  |
How create a PDT connection to mysql database By: Eclipse User on Sun, 29 December 2019 |
6717 |
Fri, 14 February 2020 01:39 By: Eclipse User  |
settings for debugging php with eclipse mars What I have done to arrange and install php eclipse: There is somthing wrong By: Eclipse User on Mon, 03 February 2020 |
3163 |
Tue, 04 February 2020 12:32 By: Eclipse User  |
How to run a HTML page with occasional PHP scripts? By: Eclipse User on Sat, 18 January 2020 |
3422 |
Mon, 20 January 2020 11:00 By: Eclipse User  |
Javascript code assist shows MISSING By: Eclipse User on Sun, 29 December 2019 |
4235 |
Mon, 30 December 2019 05:21 By: Eclipse User  |
Remote Development Server - Local Configuration IDE Configuration By: Eclipse User on Fri, 20 December 2019 |
5101 |
Fri, 20 December 2019 12:54 By: Eclipse User  |
Content assist for functions not working Functions in a main program By: Eclipse User on Thu, 05 September 2019 |
13031 |
Fri, 20 December 2019 03:26 By: Eclipse User  |
Weird debug issue When I use xdebug the debugger stops at the first line of php in my index.php By: Eclipse User on Mon, 10 November 2014 |
5933 |
Tue, 17 December 2019 06:34 By: Eclipse User  |
Formatter: Prevent comment manipulation?? Formatter: Prevent comment manipulation?? By: Eclipse User on Fri, 06 December 2019 |
3500 |
Fri, 06 December 2019 04:31 By: Eclipse User  |
Project import from Mars to Orion - Variable never used or undefined I migrated a PHP project (Silex µframework) from Mars to last Eclipse for PHP.... Raising thousands of warnings and errors By: Eclipse User on Sun, 17 November 2019 |
4521 |
Sun, 17 November 2019 17:03 By: Eclipse User  |
Find Function within PHP project By: Eclipse User on Fri, 19 October 2018 |
4839 |
Sat, 16 November 2019 01:15 By: Eclipse User  |
How to optimize build process Project contains many classes but not all of these need to rebuild By: Eclipse User on Wed, 06 November 2019 |
4664 |
Wed, 06 November 2019 00:26 By: Eclipse User  |
Best PHP Development Tool Best PHP Development Tool By: Eclipse User on Fri, 21 June 2019 |
17126 |
Tue, 05 November 2019 07:30 By: Eclipse User  |
Debug Conceptual Question for Eclipse 2019-03 Concept Confusion By: Eclipse User on Wed, 30 October 2019 |
4254 |
Sat, 02 November 2019 13:37 By: Eclipse User  |
Is PDT Built in Eclipse IDE for Web and JavaScript Developers? PDT and Eclipse IDE for Web and JavaScript Developers By: Eclipse User on Mon, 28 October 2019 |
3259 |
Tue, 29 October 2019 09:13 By: Eclipse User  |
PHPUnit not working (thus far) on Oxygen.1 PHPUnit not working (thus far) on Oxygen.1 By: Eclipse User on Thu, 19 October 2017 |
19950 |
Tue, 29 October 2019 06:10 By: Eclipse User  |
Eclipse PDT IIS 7 and xdebug!!!!! By: Eclipse User on Sat, 13 July 2019 |
21479 |
Tue, 15 October 2019 09:19 By: Eclipse User  |
Help! Cannot be solved to a type By: Eclipse User on Wed, 22 November 2017 |
7420 |
Wed, 09 October 2019 00:12 By: Eclipse User  |
I want to enable .php_cs.dist php,laravel By: Eclipse User on Tue, 08 October 2019 |
17706 |
Tue, 08 October 2019 21:21 By: Eclipse User  |
Setting up Eclipse to debug PHP (with WAMP & Xdebug) for Joomla! and web applications By: Eclipse User on Tue, 08 October 2019 |
4946 |
Tue, 08 October 2019 01:18 By: Eclipse User  |
Occasional Internal Server Error By: Eclipse User on Tue, 01 October 2019 |
7487 |
Mon, 07 October 2019 17:32 By: Eclipse User  |
Where Is Should I Put My php_mysqli.dll File? Where should I put my php_mysqli.dll file so eclipse doesn't throw unknown function mysqli? By: Eclipse User on Thu, 03 October 2019 |
26994 |
Thu, 03 October 2019 15:25 By: Eclipse User  |
Imports and types can't be resolved when a Composer project is created By: Eclipse User on Wed, 02 October 2019 |
7192 |
Thu, 03 October 2019 13:28 By: Eclipse User  |
Eclipse PDT Windows An internal error occurred during: Modifying Include Path Looks an Eclipse PDT bug By: Eclipse User on Wed, 25 September 2019 |
12635 |
Mon, 30 September 2019 03:13 By: Eclipse User  |
How to correctly configure Eclipse and/or Xdebug for remote debugging By: Eclipse User on Wed, 24 July 2019 |
30807 |
Mon, 23 September 2019 04:01 By: Eclipse User  |
keyboard can't write quotation mark By: Eclipse User on Wed, 24 July 2019 |
27565 |
Wed, 24 July 2019 07:55 By: Eclipse User  |
Shortcut lost when changing Appereance or code formatter Shortcut lost when changing Appereance or code formatter By: Eclipse User on Mon, 01 July 2019 |
3650 |
Thu, 04 July 2019 12:11 By: Eclipse User  |
xdebug starts automatically i want xdebug to debug only when i press debug-button By: Eclipse User on Thu, 27 June 2019 |
46918 |
Thu, 27 June 2019 05:28 By: Eclipse User  |
Debugging PHP with Eclipse 2019-03 How do I invoke XDebug in Eclipse? By: Eclipse User on Wed, 05 June 2019 |
40902 |
Wed, 05 June 2019 21:46 By: Eclipse User  |
braces allways on starting next line By: Eclipse User on Sun, 14 April 2019 |
30285 |
Mon, 06 May 2019 05:51 By: Eclipse User  |
2 ide installed two eclipse By: Eclipse User on Tue, 30 April 2019 |
30579 |
Tue, 30 April 2019 19:52 By: Eclipse User  |
Keep getting error error By: Eclipse User on Fri, 12 April 2019 |
22807 |
Fri, 12 April 2019 22:22 By: Eclipse User  |
FTP Sync on SAVE Synchronize php project with one ftp automatically every time you save a file. By: Eclipse User on Mon, 08 April 2019 |
20666 |
Mon, 08 April 2019 14:32 By: Eclipse User  |
Install Eclipse without any Features By: Eclipse User on Mon, 01 April 2019 |
21281 |
Mon, 01 April 2019 00:31 By: Eclipse User  |
Problems with auto formatting and HEREDOC By: Eclipse User on Fri, 29 March 2019 |
13391 |
Fri, 29 March 2019 04:49 By: Eclipse User  |
Problems in XDEBUG with path mapper xdebug issue By: Eclipse User on Wed, 27 March 2019 |
17296 |
Wed, 27 March 2019 03:13 By: Eclipse User  |
HTML Tags in PHP Files Matching Tags Dead By: Eclipse User on Sat, 15 April 2017 |
17348 |
Wed, 20 March 2019 04:11 By: Eclipse User  |
Single quotes and php 7.3 Single quotes not displaying correctly when migrated from php 5 to 7.3 By: Eclipse User on Mon, 18 March 2019 |
19125 |
Mon, 18 March 2019 13:27 By: Eclipse User  |
New install of Eclipse IDE for PHP Developers failed to open stream: No such file or directory By: Eclipse User on Fri, 08 March 2019 |
33894 |
Fri, 08 March 2019 12:44 By: Eclipse User  |
php,html and mysql plugin By: Eclipse User on Wed, 06 March 2019 |
3142 |
Wed, 06 March 2019 09:03 By: Eclipse User  |
How to use Eclipse for both Java and PHP? By: Eclipse User on Mon, 25 February 2019 |
27387 |
Mon, 25 February 2019 01:47 By: Eclipse User  |
Validator not catching a variable via PHPDoc comment Validator warns about undefind variable even when an array is defined via PHPDoc comment By: Eclipse User on Wed, 20 February 2019 |
6690 |
Wed, 20 February 2019 17:47 By: Eclipse User  |
PHP Conditionals Formatter Can find the option By: Eclipse User on Sat, 05 January 2019 |
4948 |
Fri, 15 February 2019 02:47 By: Eclipse User  |
Cannot connect to Debugger (i.e. SDM) Couldn't start parallel debugger By: Eclipse User on Mon, 21 January 2019 |
4807 |
Wed, 06 February 2019 17:10 By: Eclipse User  |
outline javascript in Eclipse PDT outline javascript do no view function By: Eclipse User on Fri, 01 February 2019 |
4875 |
Fri, 01 February 2019 04:15 By: Eclipse User  |
Problem setting up 2 eclipse UTF8 and ISO-8859-1 Problem setting up 2 eclipse UTF8 and ISO-8859-1 By: Eclipse User on Wed, 23 January 2019 |
5128 |
Wed, 23 January 2019 05:45 By: Eclipse User  |
SPL Classes not found Standard Php Library classes not found By: Eclipse User on Mon, 21 January 2019 |
4783 |
Mon, 21 January 2019 12:24 By: Eclipse User  |
Eclipse Photon Incredibly Laggy and Unusable Eclipse Photon PHP IDE running on Windows 10 is incredibly laggy and basically unusable By: Eclipse User on Thu, 04 October 2018 |
5538 |
Tue, 15 January 2019 11:56 By: Eclipse User  |
Jump to errors By: Eclipse User on Sat, 12 January 2019 |
4753 |
Sat, 12 January 2019 09:39 By: Eclipse User  |
