MyFirstTest: Unable to load SWTBotLaunchConfigurationDelegate By: Eclipse User on Tue, 29 October 2024 |
1031 |
Tue, 29 October 2024 06:51 By: Eclipse User  |
Unable to import local ZIP files No action is happening when I'm trying to import the local zip files and this is the below code I'm using By: Eclipse User on Fri, 04 October 2024 |
895 |
Fri, 04 October 2024 07:35 By: Eclipse User  |
Not able to access NatTables and it's operation By: Eclipse User on Sat, 06 July 2024 |
12644 |
Wed, 24 July 2024 08:06 By: Eclipse User  |
Access Tab Item in Properties tab By: Eclipse User on Sat, 06 July 2024 |
68 |
33362 |
Mon, 08 July 2024 22:43 By: Eclipse User  |
Access of tables or list in shell By: Eclipse User on Tue, 04 June 2024 |
1104 |
Thu, 06 June 2024 10:01 By: Eclipse User  |
Unavailabiltiy of 3.0.0 version By: Eclipse User on Mon, 18 September 2023 |
1118 |
Mon, 18 September 2023 06:45 By: Eclipse User  |
getting error for Contextmenu option selection in a table need to select a row and perform contextmenu() and select the options from that By: Eclipse User on Mon, 04 September 2023 |
1235 |
Wed, 06 September 2023 11:41 By: Eclipse User  |
ContextMenu option selection in SWTBOT unable to select option from contextmenu() inside the table By: Eclipse User on Mon, 04 September 2023 |
6214 |
Mon, 04 September 2023 06:37 By: Eclipse User  |
Executing a single SWTbot test from the headless runner By: Eclipse User on Wed, 18 January 2023 |
2088 |
Mon, 03 April 2023 08:04 By: Eclipse User  |
Headless Testing on Github Failed to inject or execute JavaScript By: Eclipse User on Mon, 20 March 2023 |
1954 |
Mon, 20 March 2023 05:39 By: Eclipse User  |
SWTBot via the Command Line By: Eclipse User on Fri, 23 December 2022 |
2027 |
Tue, 03 January 2023 11:06 By: Eclipse User  |
SWTBot doesn't seem to see the "Show View" Shell Running 4.22 with SWTBot 4.1.0, the Standard Eclipse 'Show View' Shell cannot be found By: Eclipse User on Wed, 03 August 2022 |
2391 |
Fri, 23 December 2022 09:24 By: Eclipse User  |
Can't access right-click menu items of project that have sub-menus By: Eclipse User on Mon, 03 May 2010 |
15702 |
Mon, 26 September 2022 16:33 By: Eclipse User  |
Triggering a mouse hover event on a toolbar item By: Eclipse User on Wed, 27 July 2022 |
2235 |
Wed, 27 July 2022 15:46 By: Eclipse User  |
Migration to SLF4J logging in SWTBot 4.0 By: Eclipse User on Sat, 04 June 2022 |
3640 |
Sat, 04 June 2022 11:14 By: Eclipse User  |
Test class not found when run from command line By: Eclipse User on Fri, 06 May 2022 |
3889 |
Tue, 10 May 2022 12:25 By: Eclipse User  |
SWTBot cannot be found by <my-test-plugin> in headless Running SWTBot test on existing application By: Eclipse User on Thu, 24 March 2022 |
5089 |
Thu, 24 March 2022 08:27 By: Eclipse User  |
How to test the Workspace launcher dialog How to test the Workspace launcher dialog By: Eclipse User on Mon, 15 November 2021 |
1514 |
Mon, 15 November 2021 10:04 By: Eclipse User  |
Find custom View with bot By: Eclipse User on Mon, 04 October 2021 |
1842 |
Mon, 04 October 2021 16:23 By: Eclipse User  |
test rcp application Plug-in com.ide.rcp was unable to load class com.ide.rcp.Application. By: Eclipse User on Fri, 30 July 2021 |
3080 |
Fri, 30 July 2021 05:28 By: Eclipse User  |
How to click on minimize/maximize view buttons By: Eclipse User on Wed, 14 July 2021 |
1936 |
Wed, 14 July 2021 11:07 By: Eclipse User  |
Regression with SWTBot By: Eclipse User on Wed, 23 June 2021 |
1713 |
Tue, 29 June 2021 18:03 By: Eclipse User  |
Example for running SWTBot tests with Tycho for an Eclipse 4 RCP app By: Eclipse User on Thu, 06 May 2021 |
2594 |
Mon, 21 June 2021 10:02 By: Eclipse User  |
Added support for Nebula CheckBoxGroup, Stepbar, RangeSlider By: Eclipse User on Fri, 23 April 2021 |
2537 |
Fri, 23 April 2021 10:44 By: Eclipse User  |
How to use Katalon Studio RCP application in SWTBoT how to launch katalon studio as RCP application in SWTBot By: Eclipse User on Tue, 13 April 2021 |
1357 |
Wed, 14 April 2021 02:45 By: Eclipse User  |
Accessing checkboxes from table By: Eclipse User on Fri, 09 April 2021 |
2502 |
Fri, 09 April 2021 07:07 By: Eclipse User  |
How to open a menu? By: Eclipse User on Mon, 30 April 2018 |
2958 |
Tue, 23 February 2021 08:08 By: Eclipse User  |
SWTBot() - Could not find a display - Eclipse 2020 By: Eclipse User on Mon, 02 November 2020 |
4380 |
Tue, 10 November 2020 14:26 By: Eclipse User  |
SWTBot _Tycho SWTBot _Tycho - Skip the Test Run But Bundle it By: Eclipse User on Wed, 09 September 2020 |
1876 |
Thu, 10 September 2020 00:32 By: Eclipse User  |
Problems with Keyboard when tests running headless By: Eclipse User on Fri, 12 June 2015 |
4329 |
Fri, 28 August 2020 02:05 By: Eclipse User  |
SWTBot on Jenkins Bitvise SSH-Server By: Eclipse User on Fri, 28 August 2020 |
9869 |
Fri, 28 August 2020 01:54 By: Eclipse User  |
SWTBotNatTable opens dialog twice By: Eclipse User on Fri, 29 May 2020 |
1591 |
Fri, 29 May 2020 17:07 By: Eclipse User  |
SWTBot with JUnit5? By: Eclipse User on Sun, 01 December 2019 |
4217 |
Tue, 07 April 2020 23:38 By: Eclipse User  |
popup menu in NatTable could'nt be found By: Eclipse User on Thu, 21 November 2019 |
3282 |
Wed, 04 December 2019 09:33 By: Eclipse User  |
Open SWTBot test Recorder with RCP application SWTBot test Recorder + RCP application doesn't work By: Eclipse User on Thu, 14 September 2017 |
17968 |
Fri, 22 November 2019 04:50 By: Eclipse User  |
How to press shortcuts containing numpad keys? By: Eclipse User on Tue, 08 October 2019 |
3373 |
Wed, 09 October 2019 05:16 By: Eclipse User  |
SWTBot with Cucumber By: Eclipse User on Thu, 25 October 2012 |
6772 |
Sun, 29 September 2019 05:03 By: Eclipse User  |
Validation of SWTBotTreeItem tooltip text By: Eclipse User on Wed, 18 September 2019 |
5471 |
Mon, 23 September 2019 09:28 By: Eclipse User  |
Test application with existing project data How can I start an application with a test project? By: Eclipse User on Wed, 21 August 2019 |
3729 |
Mon, 26 August 2019 14:52 By: Eclipse User  |
SWTBot test fails when creating xtext resource By: Eclipse User on Wed, 24 July 2019 |
3172 |
Sat, 27 July 2019 11:45 By: Eclipse User  |
SWTBot tests not running the correct application By: Eclipse User on Mon, 22 July 2019 |
26668 |
Mon, 22 July 2019 20:13 By: Eclipse User  |
SWTBot unable to access to "Table" By: Eclipse User on Wed, 12 June 2019 |
3219 |
Tue, 09 July 2019 03:25 By: Eclipse User  |
Unable to create run configuration with SWTBot The goal is to create a run configuration with SWTBot. By: Eclipse User on Tue, 05 February 2019 |
6447 |
Wed, 05 June 2019 17:24 By: Eclipse User  |
Wrong tested application is started when tests are running with Tycho By: Eclipse User on Fri, 21 December 2018 |
5176 |
Sat, 20 April 2019 11:17 By: Eclipse User  |
Draw2D Support in GEF By: Eclipse User on Thu, 02 July 2015 |
5237 |
Tue, 16 April 2019 06:01 By: Eclipse User  |
SWTBot now supports reading of Status Line messages By: Eclipse User on Mon, 18 March 2019 |
17406 |
Mon, 18 March 2019 11:35 By: Eclipse User  |
KeyStrokes don't work anymore with Mac By: Eclipse User on Mon, 21 January 2019 |
3782 |
Wed, 23 January 2019 13:13 By: Eclipse User  |
SWTBot and WebStart how to add test plugin to application SWTBot with WebStart By: Eclipse User on Fri, 23 November 2018 |
2795 |
Wed, 16 January 2019 11:26 By: Eclipse User  |
How to decrease warning message such as Widget is not enabled By: Eclipse User on Thu, 10 January 2019 |
2876 |
Thu, 10 January 2019 15:44 By: Eclipse User  |
bot().textWithLabel() does not found appropriated text field By: Eclipse User on Thu, 10 January 2019 |
2698 |
Thu, 10 January 2019 12:23 By: Eclipse User  |
2018-12 Issues By: Eclipse User on Fri, 21 December 2018 |
2123 |
Fri, 21 December 2018 10:26 By: Eclipse User  |
SWTBot test canot load class from application under testing ClassDefNotFoundError By: Eclipse User on Thu, 13 December 2018 |
2477 |
Thu, 13 December 2018 13:54 By: Eclipse User  |
Release planned for Eclipse 2018-12? By: Eclipse User on Wed, 28 November 2018 |
2696 |
Mon, 03 December 2018 09:44 By: Eclipse User  |
SWTBot in headless mode and java.lang.ExceptionInInitializerError headless problems By: Eclipse User on Tue, 06 November 2018 |
3979 |
Thu, 08 November 2018 02:48 By: Eclipse User  |
Run SWTBot test in Headless mode. RCP application is not started By: Eclipse User on Tue, 27 February 2018 |
4176 |
Fri, 02 November 2018 07:43 By: Eclipse User  |
Unable to read SWTBotBrowser text content < Photon By: Eclipse User on Mon, 01 October 2018 |
2131 |
Mon, 01 October 2018 10:31 By: Eclipse User  |
Improve AbstractSWTBot.dragAndDrop capability By: Eclipse User on Mon, 13 August 2018 |
4185 |
Fri, 21 September 2018 17:24 By: Eclipse User  |
SWTBotProgressBar is supported By: Eclipse User on Thu, 23 August 2018 |
3492 |
Thu, 23 August 2018 04:09 By: Eclipse User  |
Getting errormarkers of xtext editor Getting error markers of xtext editor By: Eclipse User on Thu, 26 July 2018 |
2824 |
Thu, 02 August 2018 06:50 By: Eclipse User  |
Filling a tree with test data? How can I fill a tree with test items? By: Eclipse User on Tue, 10 July 2018 |
2736 |
Tue, 10 July 2018 10:52 By: Eclipse User  |
How to get progress bar shell in swtbot? I am trying out to write swtbot test cases for my RCP Application. I am displaying a progress bar whenever a search is performed in the Application. To test the same using swtbot, I am using the fol By: Eclipse User on Mon, 09 July 2018 |
2888 |
Mon, 09 July 2018 06:10 By: Eclipse User  |
Working with FigureCanvas By: Eclipse User on Wed, 09 May 2018 |
1878 |
Wed, 09 May 2018 16:27 By: Eclipse User  |
SWTBot Command line Framework installation Installing Headless Testing Framework By: Eclipse User on Fri, 27 April 2018 |
3636 |
Wed, 09 May 2018 06:02 By: Eclipse User  |
How to make the Logger snippet work The Logger snippet in the documentation doesn't seem to work. How to fix it? By: Eclipse User on Fri, 13 April 2018 |
5060 |
Wed, 25 April 2018 05:54 By: Eclipse User  |
SWTBot tests do not work with maven, but with Eclipse Shell does not close By: Eclipse User on Thu, 05 April 2018 |
3848 |
Mon, 09 April 2018 14:23 By: Eclipse User  |
SWTBot and E4 RCP Applications - Status? How to combine E4 RCP Applications and SWTBot for GUI testing? By: Eclipse User on Sun, 01 April 2018 |
5148 |
Thu, 05 April 2018 08:54 By: Eclipse User  |
Automated test execution without showing display By: Eclipse User on Mon, 22 January 2018 |
3618 |
Fri, 26 January 2018 09:38 By: Eclipse User  |
SWTBot Recorder is not absolute SWTBot Recorder generated test cases are not good enough. By: Eclipse User on Mon, 09 March 2015 |
16793 |
Wed, 17 January 2018 01:00 By: Eclipse User  |
Not able to find swtbot plugin By: Eclipse User on Wed, 03 July 2013 |
6574 |
Tue, 02 January 2018 01:48 By: Eclipse User  |
RAP Automation RAP Automation By: Eclipse User on Sat, 23 December 2017 |
1769 |
Sat, 23 December 2017 10:39 By: Eclipse User  |
SWTBot + Selenium for SWT & browser testing? By: Eclipse User on Wed, 23 June 2010 |
8401 |
Fri, 24 November 2017 18:26 By: Eclipse User  |
SWTBot command line, my test doesn't start By: Eclipse User on Thu, 19 October 2017 |
3992 |
Thu, 19 October 2017 10:00 By: Eclipse User  |
Send a Drag and Drop between 2 node (from a Tree) Dnd, Drag and Drop, Tree, Node By: Eclipse User on Wed, 11 October 2017 |
3557 |
Wed, 11 October 2017 09:54 By: Eclipse User  |
How to modify Tree/table? By: Eclipse User on Tue, 26 September 2017 |
5569 |
Tue, 10 October 2017 04:10 By: Eclipse User  |
How to link a Part from an RCP App to SWTBot? By: Eclipse User on Thu, 21 September 2017 |
7386 |
Fri, 22 September 2017 06:57 By: Eclipse User  |
Testing FXCanvas with SWTBot By: Eclipse User on Wed, 13 September 2017 |
6328 |
Thu, 14 September 2017 16:23 By: Eclipse User  |
SWTBot and Dependency Injection By: Eclipse User on Mon, 11 September 2017 |
3850 |
Tue, 12 September 2017 18:14 By: Eclipse User  |
More wait conditions By: Eclipse User on Mon, 10 July 2017 |
10487 |
Mon, 10 July 2017 06:27 By: Eclipse User  |
StartupRecorder.openRecorder fails with NPE StartupRecorder.openRecorder fails with NPE By: Eclipse User on Thu, 15 June 2017 |
10580 |
Wed, 28 June 2017 13:21 By: Eclipse User  |
SWTBOT Spy View How to find the widget type in SWTBOT By: Eclipse User on Tue, 13 June 2017 |
6939 |
Wed, 14 June 2017 14:25 By: Eclipse User  |
Find Display in SWTUtils By: Eclipse User on Wed, 14 June 2017 |
5215 |
Wed, 14 June 2017 13:37 By: Eclipse User  |
SWTBot & acceptance tests tools run tests in Jenkins By: Eclipse User on Fri, 19 May 2017 |
9189 |
Fri, 09 June 2017 10:08 By: Eclipse User  |
Eclipse SWTBot generator with Nattable By: Eclipse User on Fri, 05 May 2017 |
4119 |
Mon, 08 May 2017 10:35 By: Eclipse User  |
Finding item in swtbottable fails if item not present in first column. Item present in table in other than first column is not found and returned false if SWTBotTable.containsItem(final String item) is used. By: Eclipse User on Mon, 08 May 2017 |
36022 |
Mon, 08 May 2017 06:03 By: Eclipse User  |
SWTBot support for Nebula TableCombo? Support by SWTBot for the Nebula TableCombo Widget By: Eclipse User on Tue, 04 April 2017 |
3798 |
Tue, 04 April 2017 15:41 By: Eclipse User  |
How to click on toolbar dropdown menu item using SWTBOT By: Eclipse User on Thu, 04 April 2013 |
12419 |
Mon, 03 April 2017 08:37 By: Eclipse User  |
Execute SWTBot in running IDE By: Eclipse User on Wed, 10 February 2016 |
6710 |
Thu, 23 March 2017 19:30 By: Eclipse User  |
Test failing with _cairo_format_from_content: Assertion `!"reached"' fail By: Eclipse User on Tue, 14 March 2017 |
5134 |
Wed, 15 March 2017 13:17 By: Eclipse User  |
SWTBotTreeItem.getTooltipText SWTBotTreeItem.getTooltipText() returns "" By: Eclipse User on Fri, 10 March 2017 |
6619 |
Mon, 13 March 2017 06:45 By: Eclipse User  |
Reference a target file as platform configuration By: Eclipse User on Thu, 09 March 2017 |
4133 |
Thu, 09 March 2017 04:04 By: Eclipse User  |
How to enable checkbox? bot.checkBox().click(); fails because checkBox is not enabled By: Eclipse User on Thu, 16 February 2017 |
18573 |
Thu, 23 February 2017 10:39 By: Eclipse User  |
Can't add Required plug-ins to MANIFEST.MF SWTBot on Mac By: Eclipse User on Thu, 02 February 2017 |
4138 |
Thu, 02 February 2017 16:43 By: Eclipse User  |
Sometimes SWTBotTable.select sends event.item=Null in SelectionEvent By: Eclipse User on Fri, 02 December 2016 |
5347 |
Mon, 05 December 2016 12:26 By: Eclipse User  |
Not able to access table view Not able to access table view By: Eclipse User on Fri, 11 November 2016 |
2697 |
Mon, 14 November 2016 10:47 By: Eclipse User  |
Bot Unable to find Comboviwer.. Hi, I am trying to test an eclipse RCP application. I want SWTBot to click on an item of a combo box (drop down box), I tried bot.combo,bot.ccombo, bot.comboboxwithId but I get a WidgetNotFoundExc By: Eclipse User on Mon, 14 November 2016 |
4758 |
Mon, 14 November 2016 09:33 By: Eclipse User  |
GEF / Draw2D unit tests By: Eclipse User on Wed, 02 November 2016 |
3420 |
Thu, 03 November 2016 04:13 By: Eclipse User  |
[solved] Eclipse-Plugin-Test: Log4J Error by using SWTBot WidgetNotFoundException caused by Initialize Error in Log4J By: Eclipse User on Thu, 22 September 2016 |
5966 |
Thu, 22 September 2016 01:42 By: Eclipse User  |
Flaky Tests How to handle Flaky Tests with SWTBot By: Eclipse User on Thu, 08 September 2016 |
3761 |
Thu, 08 September 2016 22:29 By: Eclipse User  |
2796 |
Wed, 31 August 2016 14:44 By: Eclipse Webmaster  |
Timeout Issues in SWTBot Tests How to handle Timeout Issues in SWTBot Tests By: Eclipse User on Mon, 22 August 2016 |
6874 |
Wed, 24 August 2016 02:19 By: Eclipse User  |
Headless Test with Maven/Tycho Headless Test with Maven/Tycho By: Eclipse User on Mon, 25 July 2016 |
5960 |
Mon, 01 August 2016 13:04 By: Eclipse User  |
Combination of Parameterized and SWTBotJunit4 runners By: Eclipse User on Tue, 19 July 2016 |
3448 |
Wed, 27 July 2016 00:22 By: Eclipse User  |
How to launch my SWTbot tests from console? By: Eclipse User on Thu, 06 June 2013 |
23 |
34451 |
Fri, 22 July 2016 08:54 By: Eclipse User  |
Unable to access Toolbar View Menu Unable to access Toolbar View Menu By: Eclipse User on Wed, 20 July 2016 |
2697 |
Wed, 20 July 2016 13:24 By: Eclipse User  |
Nebula Grid and SWTBot Support for Nebula Grid in SWTBot By: Eclipse User on Mon, 11 July 2016 |
2847 |
Mon, 11 July 2016 17:07 By: Eclipse User  |
Open SWTBot test Recorder with custom RCP application By: Eclipse User on Wed, 08 June 2016 |
7989 |
Tue, 14 June 2016 15:29 By: Eclipse User  |
Recorder/Generator for non RCP app By: Eclipse User on Tue, 24 May 2016 |
4697 |
Fri, 27 May 2016 07:44 By: Eclipse User  |
Replacement for deprecated SWTBotView.menus method? deprecated SWTBotViewMenu By: Eclipse User on Thu, 05 May 2016 |
4354 |
Thu, 05 May 2016 15:54 By: Eclipse User  |
How to click on Message dilogue "OK" Button At the Time of Saving content Message Dilogue appears with OK and Cancel,I want to click on OK button.please reply By: Eclipse User on Thu, 21 April 2016 |
7759 |
Thu, 28 April 2016 12:48 By: Eclipse User  |
Nebula NatTable is now supported SWTBotNatTable By: Eclipse User on Thu, 28 April 2016 |
6326 |
Thu, 28 April 2016 03:03 By: Eclipse User  |
using @Category annotation with SWTBot is it possible to use @Category annotation in SWTBot tests By: Eclipse User on Wed, 06 April 2016 |
7631 |
Mon, 11 April 2016 07:35 By: Eclipse User  |
How to Set or type text in TextField of Table..? I have Tree which is Table/Cell Format. After clicking a particular Cell aTextField appears. I want to Type or Set Text in that table cell. By: Eclipse User on Wed, 06 April 2016 |
7421 |
Thu, 07 April 2016 09:29 By: Eclipse User  |
How to select an Item in ComboBox of a Tree.. By: Eclipse User on Tue, 30 April 2013 |
11801 |
Tue, 05 April 2016 01:42 By: Eclipse User  |
Does SWTBot supports JavaFx Does SWTBot supports JavaFx By: Eclipse User on Tue, 22 March 2016 |
5382 |
Wed, 23 March 2016 06:29 By: Eclipse User  |
run tests with maven/tycho headless By: Eclipse User on Tue, 29 December 2015 |
15577 |
Wed, 09 March 2016 01:01 By: Eclipse User  |
Testing External Application with SWBot By: Eclipse User on Wed, 26 May 2010 |
7931 |
Tue, 08 March 2016 02:45 By: Eclipse User  |
Edit NatTable cell Using SWTBOT Edit NatTable cell Using SWTBOT By: Eclipse User on Wed, 16 December 2015 |
9600 |
Tue, 23 February 2016 04:12 By: Eclipse User  |
SWTBot tests inconsistent for Kepler in Windows Virtualized Environment Latest SWTBot release breaks with Kepler - Is there any solution ? - Can I get the "old" content of the update site ? By: Eclipse User on Mon, 29 June 2015 |
4736 |
Mon, 22 February 2016 16:04 By: Eclipse User  |
Test used to work. Failing now. By: Eclipse User on Mon, 22 February 2016 |
8267 |
Mon, 22 February 2016 13:05 By: Eclipse User  |
SWTBot Video Tutorials By: Eclipse User on Fri, 10 July 2009 |
5950 |
Thu, 18 February 2016 12:26 By: Eclipse User  |
[Problem]No context available outside of the request service lifecycle By: Eclipse User on Thu, 11 February 2016 |
4203 |
Fri, 12 February 2016 08:06 By: Eclipse User  |
drag and drop from FigureCanvas Is there a way to drag and drop elements from FigureCanvas By: Eclipse User on Fri, 11 December 2015 |
7051 |
Sun, 31 January 2016 16:50 By: Eclipse User  |
Testing a dialog with Browse button > DirectoryDialog By: Eclipse User on Thu, 07 January 2016 |
7282 |
Sun, 31 January 2016 16:46 By: Eclipse User  |
Not able to detect Combo box with org.eclipse.jface.fieldassist.SimpleContentProposalProvider By: Eclipse User on Wed, 09 September 2015 |
7016 |
Mon, 14 December 2015 01:46 By: Eclipse User  |
How to Access a Tree inside a CTab? How to Access a Tree inside a CTab? By: Eclipse User on Tue, 03 March 2015 |
4674 |
Fri, 11 December 2015 18:48 By: Eclipse User  |
Injecting an object in a Context in SWTBot test By: Eclipse User on Fri, 04 December 2015 |
5726 |
Fri, 04 December 2015 05:46 By: Eclipse User  |
Testing Nebula's Nat Table functionality through SWTBot. Testing Nebula's Nat Table functionality through SWTBot (Robot Framework Eclipse Library -> Interface between Robot Framework and SWTBot) By: Eclipse User on Fri, 27 November 2015 |
5390 |
Fri, 27 November 2015 00:20 By: Eclipse User  |
Code coverage showing partial coverage Code coverage showing partial coverage in eclipse luna using eclemma By: Eclipse User on Wed, 04 November 2015 |
5998 |
Mon, 09 November 2015 07:40 By: Eclipse User  |
auto compile plugin By: Eclipse User on Wed, 09 September 2015 |
6125 |
Wed, 09 September 2015 09:40 By: Eclipse User  |
Integrate SWTBOT test cases with Jenkins By: Eclipse User on Thu, 06 August 2015 |
4493 |
Sat, 22 August 2015 08:24 By: Eclipse User  |
NPE in HandledContributionItem when testing application on eclipse 4.5 By: Eclipse User on Tue, 18 August 2015 |
10890 |
Wed, 19 August 2015 04:17 By: Eclipse User  |
SWTBot executed in parallel? By: Eclipse User on Thu, 13 August 2015 |
4602 |
Thu, 13 August 2015 15:00 By: Eclipse User  |
Using SWTBot for Jface tableViewer By: Eclipse User on Wed, 12 August 2015 |
4874 |
Wed, 12 August 2015 08:35 By: Eclipse User  |
TreeView to GEF editor drag n drop By: Eclipse User on Tue, 28 July 2015 |
4785 |
Tue, 28 July 2015 11:37 By: Eclipse User  |
swtbot command line plugins By: Eclipse User on Tue, 14 July 2015 |
3264 |
Mon, 27 July 2015 07:47 By: Eclipse User  |
Headless SWTBot tests fail on Windows By: Eclipse User on Fri, 19 June 2015 |
5917 |
Wed, 22 July 2015 05:03 By: Eclipse User  |
Still cannot get Mars working with Kali Linux Mars dosent like Kali By: Eclipse User on Tue, 21 July 2015 |
6073 |
Tue, 21 July 2015 09:15 By: Eclipse User  |
SWTBot Test throws WidgetNotFoundException only when run with Maven By: Eclipse User on Thu, 09 July 2015 |
4486 |
Wed, 15 July 2015 02:43 By: Eclipse User  |
SWTBot for Indigo By: Eclipse User on Fri, 03 July 2015 |
4389 |
Mon, 13 July 2015 08:33 By: Eclipse User  |
Problem with Mars on Kali Kali Instalation of eclipse fails to launch By: Eclipse User on Wed, 08 July 2015 |
3096 |
Wed, 08 July 2015 17:06 By: Eclipse User  |
How to test context or popup Menus for a Composite. By: Eclipse User on Mon, 06 July 2015 |
5048 |
Mon, 06 July 2015 13:28 By: Eclipse User  |
RCP Testing -- Contribution Identities By: Eclipse User on Wed, 24 June 2015 |
3898 |
Thu, 25 June 2015 14:34 By: Eclipse User  |
Selecting a Part from a Part Stack By: Eclipse User on Fri, 12 June 2015 |
4763 |
Mon, 22 June 2015 11:38 By: Eclipse User  |
swtbot-how to change the facet version in Project Facets wizard modifying project facets version By: Eclipse User on Mon, 24 December 2012 |
5088 |
Thu, 04 June 2015 07:15 By: Eclipse User  |
org.eclipse.swt.SWTError: No more handles getting "No more handles" error with no resource leak |
8745 |
Wed, 20 May 2015 11:23 By: Eclipse User  |
SWTBot tests for an SWTBrowser component SWTBot tests for an SWTBrowser component By: Eclipse User on Wed, 20 May 2015 |
2664 |
Wed, 20 May 2015 08:35 By: Eclipse User  |
SWTBot run application in another mode then exported apllication Correct run configuration for SWTBot By: Eclipse User on Thu, 07 May 2015 |
3400 |
Sun, 10 May 2015 11:52 By: Eclipse User  |
What SWTBOT tests exist for Eclipse? Existing SWTBOT tests By: Eclipse User on Thu, 23 April 2015 |
4246 |
Wed, 29 April 2015 03:33 By: Eclipse User  |
Unable to access context menus in sub classes of an Xviewer tree By: Eclipse User on Thu, 16 April 2015 |
5151 |
Thu, 23 April 2015 14:28 By: Eclipse User  |
Using SWTBot with an existing RCP application By: Eclipse User on Mon, 20 April 2015 |
3942 |
Wed, 22 April 2015 07:56 By: Eclipse User  |
problems with viewByTitle in Mars By: Eclipse User on Tue, 14 April 2015 |
5106 |
Tue, 21 April 2015 07:18 By: Eclipse User  |
Assert the text inside the MessageDialog How to assert the text inside the MessageDialog box in #SWTBot? By: Eclipse User on Tue, 10 March 2015 |
4438 |
Tue, 07 April 2015 04:41 By: Eclipse User  |
Unable to instantiate SWTWorkbenchBot in Eclipse E4 By: Eclipse User on Mon, 15 December 2014 |
4983 |
Wed, 01 April 2015 08:55 By: Eclipse User  |
Robotframework tool using SWTBot By: Eclipse User on Mon, 07 March 2011 |
11767 |
Fri, 27 March 2015 02:23 By: Eclipse User  |
SWTBot on RCP Trying to use SWTBot test on my RCP application By: Eclipse User on Tue, 03 March 2015 |
3472 |
Tue, 03 March 2015 04:42 By: Eclipse User  |
An error occurred while automatically activating bundle uitest Error when doing SWTBot or even simple Junit test By: Eclipse User on Wed, 18 February 2015 |
3430 |
Wed, 18 February 2015 07:27 By: Eclipse User  |
running swtbot on linux luna By: Eclipse User on Fri, 06 February 2015 |
3462 |
Mon, 16 February 2015 04:38 By: Eclipse User  |
view not really closing By: Eclipse User on Wed, 11 February 2015 |
3387 |
Thu, 12 February 2015 06:24 By: Eclipse User  |
SWTBot Figurecanvas use Selecting node of a mapping using SWTBot By: Eclipse User on Tue, 27 January 2015 |
3420 |
Tue, 27 January 2015 01:49 By: Eclipse User  |
Cannot launch RCP app second time with Webstart Webstart RCP application launches successfully then attempts to run the downloaded JNLP fail By: Eclipse User on Thu, 22 March 2012 |
18137 |
Wed, 21 January 2015 18:29 By: Eclipse User  |
Problems Description too short Compiler By: Eclipse User on Tue, 13 January 2015 |
3353 |
Tue, 13 January 2015 02:57 By: Eclipse User  |
How to work on TableViewer in Swtbot By: Eclipse User on Tue, 23 December 2014 |
4964 |
Mon, 12 January 2015 05:03 By: Eclipse User  |
select 2 nodes of tree SWTbot select 2 nodes of tree SWTbot By: Eclipse User on Thu, 08 January 2015 |
2607 |
Thu, 08 January 2015 12:46 By: Eclipse User  |
Clicking on menu Eclipse in Mac OSX By: Eclipse User on Wed, 12 November 2014 |
5325 |
Wed, 31 December 2014 09:52 By: Eclipse User  |
Seletion on Nebula gridview Select combobox element from nebula gridview. By: Eclipse User on Thu, 04 December 2014 |
2897 |
Thu, 04 December 2014 08:43 By: Eclipse User  |
Changing font and background color of only header in SWT table Changing font and background color of only header in SWT table By: Eclipse User on Tue, 25 November 2014 |
6574 |
Fri, 28 November 2014 03:28 By: Eclipse User  |
@RunWith(SWTBotJunit4ClassRunner.class) won't catch screenshots on failure By: Eclipse User on Wed, 30 May 2012 |
11391 |
Mon, 24 November 2014 07:16 By: Eclipse User  |
SWTBotTreeItem's context menu click gives TimeoutException SWTBotTreeItem's context menu click gives TimeoutException By: Eclipse User on Thu, 04 September 2014 |
8173 |
Thu, 13 November 2014 05:06 By: Eclipse User  |
Anyone knows a way to click on submenus of a view menu? By: Eclipse User on Mon, 10 November 2014 |
3246 |
Wed, 12 November 2014 02:41 By: Eclipse User  |
waituntil some condition waituntil is not working everywhere By: Eclipse User on Thu, 06 November 2014 |
4111 |
Mon, 10 November 2014 09:14 By: Eclipse User  |
wait for the project complete By: Eclipse User on Tue, 04 November 2014 |
4131 |
Thu, 06 November 2014 03:58 By: Eclipse User  |
Display not found in framework By: Eclipse User on Wed, 03 September 2014 |
6310 |
Tue, 04 November 2014 04:45 By: Eclipse User  |
Context Menu on CDT expressions view ( Luna and SWTBot2.2.1) Attempt to access expressions view context menu through SWTBotleads to exception By: Eclipse User on Mon, 29 September 2014 |
6220 |
Wed, 22 October 2014 16:54 By: Eclipse User  |
SWTBot in Mars By: Eclipse User on Fri, 17 October 2014 |
3695 |
Mon, 20 October 2014 15:54 By: Eclipse User  |
How to get the menu which is poped up by right click natTable? By: Eclipse User on Thu, 09 October 2014 |
3129 |
Thu, 09 October 2014 04:12 By: Eclipse User  |
Switch workspace problem By: Eclipse User on Thu, 09 August 2012 |
5701 |
Thu, 09 October 2014 02:16 By: Eclipse User  |
Eclipse Newsletter Article about SWTBot published By: Eclipse User on Fri, 26 September 2014 |
4910 |
Thu, 02 October 2014 08:14 By: Eclipse User  |
How to test RCP application with login screen? By: Eclipse User on Thu, 25 September 2014 |
5795 |
Wed, 01 October 2014 08:30 By: Eclipse User  |
How to Click on a link under a CTabFolder? How to Click on a link under a TabFolder? or right click on the empty space or link to get context menu? By: Eclipse User on Wed, 24 September 2014 |
6764 |
Tue, 30 September 2014 17:39 By: Eclipse User  |
"WorkbenchTestable - No Classloader found for plug-in By: Eclipse User on Mon, 29 September 2014 |
4235 |
Tue, 30 September 2014 16:54 By: Eclipse User  |
Cannot use ClickContextMenu on a extended SWTBot widget By: Eclipse User on Mon, 29 September 2014 |
5097 |
Mon, 29 September 2014 08:50 By: Eclipse User  |
testing content assist on a text field By: Eclipse User on Sun, 21 September 2014 |
6170 |
Mon, 29 September 2014 04:45 By: Eclipse User  |
5158 |
Mon, 29 September 2014 03:20 By: Eclipse User  |
How to Click on a Label using swtbot ?? By: Eclipse User on Fri, 19 September 2014 |
7755 |
Mon, 29 September 2014 03:12 By: Eclipse User  |
SWTBotRadio method click() doesn't work properly SWTBotRadio method click() doesn't work properly By: Eclipse User on Tue, 16 September 2014 |
5740 |
Tue, 16 September 2014 08:56 By: Eclipse User  |
Unable to click a label in DatePicker By: Eclipse User on Tue, 16 September 2014 |
5859 |
Tue, 16 September 2014 03:53 By: Eclipse User  |
Any Plans for Support in Eclipse LUNA ?? By: Eclipse User on Thu, 11 September 2014 |
4356 |
Fri, 12 September 2014 05:32 By: Eclipse User  |
How to select a TREE item in a TABLE? By: Eclipse User on Wed, 10 September 2014 |
4466 |
Thu, 11 September 2014 14:18 By: Eclipse User  |
How to handle unpredictable shells By: Eclipse User on Thu, 28 August 2014 |
5714 |
Thu, 11 September 2014 06:43 By: Eclipse User  |
Unable to identify/Click On Shell By: Eclipse User on Thu, 14 March 2013 |
7209 |
Thu, 11 September 2014 06:28 By: Eclipse User  |
How to wait until context menu is visible By: Eclipse User on Tue, 02 September 2014 |
4634 |
Thu, 11 September 2014 06:24 By: Eclipse User  |
How to wait until next label is visible By: Eclipse User on Tue, 02 September 2014 |
7432 |
Thu, 11 September 2014 06:21 By: Eclipse User  |
Context menu in project explorer view. How to get right click menu option in project explorer view. By: Eclipse User on Tue, 09 September 2014 |
5977 |
Thu, 11 September 2014 06:16 By: Eclipse User  |
How to get failed test cases in the middle. By: Eclipse User on Tue, 09 September 2014 |
6146 |
Thu, 11 September 2014 06:10 By: Eclipse User  |
How to click a button under a CTabFolder? By: Eclipse User on Wed, 19 June 2013 |
4345 |
Wed, 10 September 2014 19:22 By: Eclipse User  |
[Maven/Tycho] First editor activation event not delivered? By: Eclipse User on Tue, 02 September 2014 |
3984 |
Thu, 04 September 2014 11:39 By: Eclipse User  |
java.lang.NoClassDefFoundError when using bot.waitUntil(ICondition) By: Eclipse User on Wed, 30 May 2012 |
11776 |
Thu, 04 September 2014 00:46 By: Eclipse User  |
wait until some condition Wait until the shell disappears. By: Eclipse User on Thu, 28 August 2014 |
5400 |
Mon, 01 September 2014 12:18 By: Eclipse User  |
How to test NatTable using swtbot? How to test natTable automatically |
3928 |
Mon, 25 August 2014 06:01 By: Eclipse User  |
metacity sometimes makes SWTBot tests fail in Jenkins By: Eclipse User on Fri, 08 August 2014 |
5574 |
Fri, 22 August 2014 08:51 By: Eclipse User  |
