Memory consumption for DirCacheCheckout Getting OutOfMemory on moderate-sized Git repostories |
538 |
Fri, 11 October 2024 14:27 By: Andriy Rysin |
CVE-2023-4759 workaround for JGit 4.1.1 Is there a way to set core.symlinks to false using the API? |
840 |
Tue, 08 October 2024 13:52 By: Mariusz Sobierski |
JGit orphan branch checkout |
2492 |
Thu, 26 September 2024 16:04 By: Iwan Zarembo |
Stackoverflow during Garbage collection in jGit !! Stackoverflow during Garbage collection in jGit |
620 |
Fri, 13 September 2024 06:57 By: Matthias Sohn |
CheckoutConflictException while Pull and merge Frequent CheckoutConflictException Error During Git Pull - How to Resolve? |
2295 |
Mon, 09 September 2024 12:36 By: Manish Pal |
Cannot Pull or Push from Git Repo - Git Upload Pack Not Permitted |
2640 |
Mon, 09 September 2024 04:48 By: Karan Parikh |
Not able to login on github (not authorized) issue authenticating on github using token |
1722 |
Fri, 23 August 2024 19:43 By: Andriy Boloshyn |
Conflicting File compare text Conflicts can occur after pull or merging branches. I would like to solve conflicts manually by comparing the two versions of the file |
2207 |
Wed, 21 August 2024 05:52 By: Dragos Puteanu |
How to overide the maxObjectSize in FetchCommand How to overide the maxObjectSize in FetchCommand |
752 |
Fri, 16 August 2024 17:27 By: tingting zhou |
Git's built-in garbage collection vs JGit handling of garbage collection operation Built-in Git vs JGit garbage collection mechanism By: Ajay K on Mon, 08 July 2024 |
12988 |
Tue, 30 July 2024 23:12 By: Matthias Sohn |
Writing commits into the git repository using jgit takes longer than expected |
1677 |
Tue, 30 July 2024 23:03 By: Matthias Sohn |
"not in sync" occasionally appears inconsistent/confusing behavior |
794 |
Tue, 09 July 2024 16:16 By: Ray Martin |
Simple "Assume Unchanged" example raises questions/suggestions |
793 |
Tue, 28 May 2024 18:44 By: Ray Martin |
Git Staging not populating with changes (they are History) I have made changes and have them in History; however, no changes are available in the Git Staging |
1534 |
Tue, 28 May 2024 07:46 By: Glyn Bartlett |
Enquiry on JGit vs Git and security vulnerabilities |
413 |
Mon, 27 May 2024 02:33 By: Newton To |
Any JGit DFSRepository implementation with database JGit DFSRepository implementation with database |
916 |
Mon, 13 May 2024 11:14 By: Joyjit Saha |
use Jgit to generate git command line |
695 |
Tue, 30 April 2024 13:58 By: Matthias Sohn |
diff is different in jgit and git some files show as deleted in jgit but shows rename in git |
838 |
Tue, 09 April 2024 23:18 By: shaen thangaraj |
API docs link broken? |
1321 |
Mon, 08 April 2024 12:39 By: Mark Waite |
Few questions about "cherry-pick" feature 1) Is EGit support cherry-pick "-x" option? 2) Is 3.7.1 don't cherry-picking multiple commits? |
3830 |
Mon, 08 April 2024 09:51 By: Dmitri Naumenko |
Egit seems to be losing its mind |
920 |
Wed, 03 April 2024 21:19 By: David M. Karr |
Customizing GitFlow Customizing GitFlow |
1096 |
Mon, 01 April 2024 16:19 By: Roger Spall |
All branches say # WARNING after merge |
2175 |
Tue, 26 March 2024 18:32 By: Ray Martin |
Executor has been shut down - help welcome EGit, Apache Mina SSH, Executors |
1381 |
Thu, 21 March 2024 07:56 By: kurt ablinger |
[Solved] Synchronization error for project Unexpected end of file error when using synchronized fortran project |
1229 |
Sat, 02 March 2024 16:34 By: Gopal Krishna M |
egit Error Constant random popups that say "org/eclipse/egit/core/AdapterUtils" |
1554 |
Sat, 02 March 2024 15:14 By: Soyuz Bhattarai |
Periodic Fetch Feature in EGit By: K D on Tue, 13 February 2024 |
1139 |
Mon, 26 February 2024 15:50 By: Matthias Sohn |
Right click on submodule -> Team shows a 'Repository' sub-menu |
1243 |
Mon, 26 February 2024 15:49 By: Matthias Sohn |
Push command did not fail due to insufficient privileges |
1263 |
Mon, 26 February 2024 09:55 By: Matthias Sohn |
ShutdownHooks causing heap memory overflow In lock method of PidLock in GC, ShutDownHooks are getting added |
3860 |
Mon, 26 February 2024 09:37 By: Matthias Sohn |
EGIT gets a connection reset from azure Trying to clone a repository from AZURE and it fails after 80% |
948 |
Mon, 26 February 2024 09:36 By: Matthias Sohn |
Fetch via SSH, but keep connection open Fetch via SSH transport without closing connection |
956 |
Wed, 14 February 2024 11:40 By: Chumpa Wamba |
how to compare two LOCAL branch and then copy the content from one branch to another |
7650 |
Sat, 03 February 2024 11:53 By: Matthias Sohn |
Where to get the EGit/ JGit 5.13.3.202401111512-r update-site |
4254 |
Sat, 03 February 2024 11:51 By: Matthias Sohn |
Git connectivity via Proxy using JGit API Proxy Authentication during Git workflows using JGit API |
3788 |
Wed, 31 January 2024 18:52 By: Joyjit Saha |
how to show all branch in git prespective history view tab how to show all branch in git prespective history view tab |
450 |
Sat, 27 January 2024 17:11 By: Missing name Mising name |
JGit Merge Test Can JGit do a "dry run" merge? |
786 |
Sat, 27 January 2024 17:02 By: Matthias Sohn |
Security issue: CVE-2023-4759 on Java 8 How to fix CVE-2023-4759 on jgit |
1563 |
Sat, 27 January 2024 16:57 By: Matthias Sohn |
local eclipse php project git repository clone to another local directory question regarding best way to have two local development repositories for the same project |
925 |
Tue, 23 January 2024 15:01 By: Trevor Rose |
http.sslcainfo config option |
19812 |
Sat, 13 January 2024 14:02 By: Yusuke SATO |
JGit blobless clone: unable to fetch blobs later Jgit checkout fails on blobless clone whereas Git command line succeeds |
776 |
Wed, 10 January 2024 21:22 By: Matthias Sohn |
Git hooks in eclipse |
35 |
65631 |
Wed, 10 January 2024 21:17 By: Matthias Sohn |
Recreate Disaster |
928 |
Wed, 10 January 2024 21:15 By: Matthias Sohn |
GIT LFS with Github and https authentication Bug 575780 |
2024 |
Wed, 10 January 2024 21:09 By: Matthias Sohn |
Track File Location Change How to track file location change |
8693 |
Wed, 10 January 2024 20:56 By: Matthias Sohn |
Resources and File Scope |
517 |
Wed, 10 January 2024 20:37 By: Matthias Sohn |
"Clean" Included Tracked Files |
2523 |
Thu, 21 December 2023 03:15 By: Ray Martin |
[solved] jgit returns incorrect status |
501 |
Tue, 19 December 2023 07:17 By: Serhii Pro |
ssh password dialog on each git interaction since eclipse 2023-09 |
1459 |
Mon, 18 December 2023 07:56 By: Daniel Möller |
Doesn't always ask to replace editor contents |
794 |
Tue, 07 November 2023 22:56 By: Ray Martin |
multiple ssh keys |
23263 |
Tue, 31 October 2023 21:09 By: Jörn Guy Süß |
Specifying File Scope in the History view |
706 |
Mon, 30 October 2023 18:26 By: Ray Martin |
Git worktree support in egit Git worktree support in egit |
1201 |
Sat, 28 October 2023 12:29 By: Matthias Sohn |
Difficulty understanding Merge states and behavior |
472 |
Wed, 18 October 2023 20:58 By: Ray Martin |
QUARANTINE ENVIRONMENT in JGit |
1273 |
Tue, 17 October 2023 00:31 By: Conley Gao |
Upgradation to jakarta package in org.eclipse.jgit |
1333 |
Mon, 09 October 2023 08:24 By: Vaishnavi Kale |
Git showing files are changed, but content hasn't changed |
2862 |
Sat, 07 October 2023 09:49 By: Thomas Wolf |
How to manage multiple projects within the same repo With independent branch switching |
5346 |
Fri, 06 October 2023 19:34 By: Jack McKalling |
JGit update hook support |
566 |
Fri, 06 October 2023 19:08 By: Matthias Sohn |
Python script for search for factors of M1277 using random k-intervals By: Eclipse User on Tue, 03 October 2023 |
449 |
Tue, 03 October 2023 18:20 By: Matthias Sohn |
Absent and confused Ahead/Behind count |
1364 |
Thu, 28 September 2023 19:11 By: Ray Martin |
Using ProxyCommand on JGit How can I add a ProxyCommand to use ProxyTunnel for JGit By: oka be on Fri, 02 June 2023 |
4275 |
Thu, 14 September 2023 13:43 By: oka be |
Always getting 'remote hung up unexpectedly' when cloning eclipse.platform.ui over ssh Always get 'remote hung up unexpectedly' just before end of clone ssh://philippebrossel@git.eclipse.org:29418/platform/eclipse.platform.ui |
9236 |
Fri, 08 September 2023 18:29 By: Thomas Wolf |
Doesn't refresh history after deleting local branch GUI problem? |
736 |
Fri, 08 September 2023 18:15 By: Thomas Wolf |
KeyExchangeFactories not set KeyExchangeFactories not set error when trying to clone a repo on Android |
626 |
Sun, 03 September 2023 17:09 By: Thomas Wolf |
Using UltraCompare as external compare tool |
837 |
Sat, 02 September 2023 20:22 By: Thomas Wolf |
Strange EGit Staging Branches Ahead/Behind |
1869 |
Wed, 30 August 2023 18:36 By: Ray Martin |
Why does the New Branch dialog sometimes use the same name as the remote, and sometimes not? |
2189 |
Mon, 21 August 2023 21:40 By: David M. Karr |
Confused about repository with git submodule |
900 |
Tue, 01 August 2023 16:04 By: David M. Karr |
Unexpected reply from ssh-agent: SSH_AGENT_FAILURE Eclipse on Windows 10 to pull a GitHub repo using a YubiKey Hardware Ke |
53 |
11338 |
Sat, 22 July 2023 17:14 By: Thomas Wolf |
Create a main branch, not master |
2809 |
Sat, 22 July 2023 13:59 By: Sam Hobbs |
Using commit command on JGit cause no diff changes |
2634 |
Fri, 07 July 2023 03:09 By: xiao tang |
Pull doesnt work in Git Perpective By: K D on Fri, 30 June 2023 |
805 |
Fri, 30 June 2023 15:36 By: Matthias Sohn |
Unable to connect using SSH in JGit Unable to connect using SSH in JGit |
4822 |
Wed, 28 June 2023 19:27 By: Matthias Sohn |
Poll: How to view the diff of a file between a local file change and a local HEAD in JGIT in a text form How to view the diff of a file between a local file change and a local HEAD in JGIT in a text form let say I have a file readme.txt on branch Dev, and I am cloned that branch and make some changes in |
2476 |
Wed, 28 June 2023 19:19 By: Matthias Sohn |
Connection failed from Git to Eclipse |
1528 |
Wed, 28 June 2023 19:06 By: Matthias Sohn |
EGit Compare Viewer Shows ID of prior commit, not ID of last change |
1649 |
Fri, 16 June 2023 19:46 By: Thomas Wolf |
EGit still shows remote tracking branch after delete GUI doesn't update properly |
1078 |
Fri, 16 June 2023 17:14 By: Ray Martin |
Future expectations for https://git.eclipse.org/c/egit/egit-github.git/ |
8092 |
Mon, 08 May 2023 16:04 By: Ed Merks |
JGit does not delete temporary files created buy itself automatically JGit does not delete temporary files created buy itself automatically |
2216 |
Mon, 08 May 2023 13:22 By: Matthias Sohn |
How to synchronize all projects, like with Subclipse (SVN) ? |
758 |
Mon, 08 May 2023 13:20 By: Matthias Sohn |
planns for using jakarta EE 10 |
1130 |
Mon, 08 May 2023 09:27 By: Pariasadat Hosseiny |
[solved]JGIT Push takes a long time to add an empty commit (no changes) when executed from cloud |
1750 |
Fri, 05 May 2023 10:51 By: Vladimir Rosu |
Possible to use a SSH Public Key for Commit Signing? EGit not using ssh public key to sign even though GIT allows this |
3076 |
Wed, 26 April 2023 14:18 By: Pierre-Yves Bigourdan |
GIT Clone and branch switching operations are very slow in EGIT After normalization for a git repository, git clone and branch switch operations performance using EGIT is very slow |
1305 |
Mon, 24 April 2023 14:45 By: Matthias Sohn |
How to get GitHub Repo star count using jGit |
1641 |
Mon, 24 April 2023 14:41 By: Matthias Sohn |
How to get a list of added and removed commits after a push operation using JGit JGit |
1761 |
Mon, 24 April 2023 14:40 By: Matthias Sohn |
Semaphore timeout when attempting to clone gitlab repository Encountering a semaphore timeout issue when trying to clone a gitlab repository |
1128 |
Mon, 24 April 2023 13:26 By: Matthias Sohn |
Migrating jgit from 5.6 to 6.4 problems. Migrating jgit from 5.6 to 6.4 problems. |
1899 |
Mon, 24 April 2023 13:24 By: Matthias Sohn |
Double click in staging view doesn't open compare editor any more |
9867 |
Fri, 14 April 2023 07:26 By: Marco Descher |
Show Conflict Files using JGIT How to view the files involved in conflicts for solving them in a GUI. |
1311 |
Sat, 08 April 2023 14:12 By: Dragos Puteanu |
JGit initialization to a shared folder path fails in java 11 If Jgit initialized to a shared folder through Jgit, it fails |
1693 |
Mon, 20 March 2023 12:58 By: lakshmi rajam |
Sparse Checkout support |
6109 |
Tue, 14 March 2023 19:47 By: Chris Papademetrious |
Remove From View option - Keyboard shortcut Unable to bind keyboard shortcut for the Remove From View option within the Synchronize view |
1864 |
Sun, 05 March 2023 00:25 By: Pravin Jose |
JGit missing parents in Git Log |
2209 |
Tue, 14 February 2023 23:03 By: Matthias Sohn |
Possible to commit on multiple repo at the same time ? |
1747 |
Tue, 14 February 2023 22:51 By: Matthias Sohn |
git compare shows "no changes in git" Right-Click project and click Compare With > Committ: Synchronize View shows "No Changes" |
1380 |
Tue, 14 February 2023 22:49 By: Matthias Sohn |
Git-upload-pack not permitted on Github By: Alex C on Fri, 13 August 2021 |
22474 |
Sun, 12 February 2023 12:14 By: Mark Lawrence |
CVE-2022-41903, and CVE-2022-23521 By: Paulo F on Mon, 23 January 2023 |
905 |
Mon, 23 January 2023 14:43 By: Ed Merks |
How to set GIT_LFS_SKIP_SMUDGE=1 for CloneCommand |
1811 |
Thu, 19 January 2023 01:40 By: Jeremy Dorne |
Transport Error: Cannot get remote repository refs. Not able to access a remote gitHub repository |
2833 |
Tue, 17 January 2023 08:38 By: Ed Merks |
Cannot launch nested eclipse |
1244 |
Thu, 12 January 2023 14:42 By: Pavel Salamon |
Git clone of a source code into a parent C project doesn't appear to work? Git clone of a source code into a parent C project doesn't appear to work? |
3583 |
Thu, 12 January 2023 12:23 By: James Poli |
Paths with spaces in .gitconfig Not working in JGit/EGit |
1874 |
Wed, 11 January 2023 14:36 By: Rob Benton |
Exit from Eclipse Git Eclipse Java GIT |
1869 |
Sun, 08 January 2023 18:24 By: David M. Karr |
Behavior changed when pushing a new branch? |
3793 |
Thu, 22 December 2022 22:51 By: Thomas Wolf |
Discussion on default values of "Configure upstream for push and pull" |
2504 |
Mon, 19 December 2022 09:19 By: Rice Bauer |
Wrong file after jgit apply command |
1677 |
Sat, 17 December 2022 15:30 By: Thomas Wolf |
Java code to create new github repo and push some code Create new github repo and push some code |
2114 |
Wed, 14 December 2022 16:41 By: Yuriy Mitrofanov |
How to install egit Mylyn Github Connector? |
2010 |
Fri, 09 December 2022 23:43 By: Matthias Sohn |
Transport Error: Cannot get remote repository refs. file:// ... not found Error attempting to configure Push Reference Specifications |
2488 |
Fri, 09 December 2022 23:40 By: Matthias Sohn |
EGit - Windows Share as Remote Repository Over SSH |
1560 |
Sat, 05 November 2022 20:24 By: Thomas Wolf |
How to avoid reading the global user git config |
2786 |
Fri, 28 October 2022 10:05 By: Kirill Likhodedov |
Jgit pgm cli |
1349 |
Tue, 25 October 2022 21:37 By: Yuriy Mitrofanov |
EGit ignores my attempt to stage files in one repository |
3240 |
Tue, 25 October 2022 21:37 By: David M. Karr |
Could not connect to SSH agent via socket Cannot connect to Github repo using Egit SSH on Linux |
2919 |
Sat, 15 October 2022 06:28 By: Benoit Blancard |
'Checkout this version' on files in a Stash issues with new or deleted files |
1727 |
Wed, 05 October 2022 08:47 By: p Bakker |
Setting Default Remote Branch Destination Setting Original Remote Branch Destination |
1614 |
Tue, 04 October 2022 11:35 By: Nicolas Fleming |
git diff and jgit-cli diff have different results |
859 |
Sat, 01 October 2022 19:52 By: Thomas Wolf |
Authentication Error when cloning Private Repo Unable to Clone Private Repo in Egit(Works in command line) |
1535 |
Sat, 01 October 2022 13:39 By: Thomas Wolf |
Getting Transport Exception: cannot git upload pack |
880 |
Fri, 30 September 2022 21:38 By: Matthias Sohn |
Differences between Merge Modes |
2053 |
Mon, 26 September 2022 15:53 By: Nenad Jovanovic |
Limit blob size with cloneRepository (equivalent to --filter=blob:limit=) |
1199 |
Thu, 22 September 2022 19:24 By: Thomas Wolf |
Mismatch between git clone and JGit's cloneRepository |
3243 |
Thu, 22 September 2022 19:02 By: Thomas Wolf |
Most efficient way to retrieve diffentries across all commits |
2188 |
Wed, 21 September 2022 08:24 By: Alexander Reelsen |
Working Tree must not be numerical sorted Like other views in Eclipse, the working tree sort must be sorted literally. |
3696 |
Tue, 20 September 2022 12:47 By: Thomas Wolf |
SSHSessionFactory with Auth fail with token SSHSessionFactory with Auth fail with token |
4139 |
Thu, 08 September 2022 05:24 By: Thomas Wolf |
RDi (Rational Developer Eclipse) using egit not finding git execs: bsh: git-receive-pack: not foun RDi (an eclipsed for specific for IBM i platform) error finding Git commands |
3217 |
Wed, 07 September 2022 14:46 By: johan Wigh |
option to delete untracked files on git reset |
2404 |
Tue, 16 August 2022 14:38 By: Vito De Tullio |
Need JGit help Need JGit help to perform specific operations |
2921 |
Tue, 09 August 2022 06:52 By: Matthias Sohn |
Git Clone Wizard Very Slow Vs. Git Command Line Very Slow Cloning Using Git Clone Wizard By: Mike K on Mon, 08 August 2022 |
1704 |
Tue, 09 August 2022 06:29 By: Matthias Sohn |
Suddenly getting "No more authentication methods available" with ssh auth to git repo |
21369 |
Mon, 08 August 2022 17:35 By: Thomas Wolf |
JGIT LS Remote Repositor using SSH JGIT with SSH Keys |
1012 |
Sat, 06 August 2022 20:19 By: Thomas Wolf |
Cherry pick a range of commit |
27035 |
Thu, 14 July 2022 07:06 By: Matthias Sohn |
is GIT required Will Jgit work without GIT on server |
2810 |
Thu, 14 July 2022 07:02 By: Matthias Sohn |
jgit checkout cost too long time |
2548 |
Tue, 12 July 2022 13:03 By: Matthias Sohn |
What is the proper way to stage / unstage specific lines in a diff? |
19832 |
Thu, 30 June 2022 07:12 By: Thomas Wolf |
JGit Maintenance Api to run maintenance tasks using JGit |
1707 |
Tue, 28 June 2022 19:40 By: Hrushikesh Rao |
Modify author date in JGit |
2072 |
Tue, 28 June 2022 16:43 By: Matthias Sohn |
Retrieve User Name and Email Address from the Git Repo Jgit API to Retrieve User Name and Email Address from the Git Repo |
3406 |
Mon, 27 June 2022 07:19 By: Pratap Meka |
How to get User info from personal access token How to get User info from personal access token |
5219 |
Fri, 24 June 2022 12:55 By: Thomas Wolf |
Does JGIT allow for running commands in parallel? |
4855 |
Tue, 21 June 2022 06:03 By: Matthias Sohn |
jgit.sh on wsl Unable to find ZIP central directory |
3904 |
Fri, 17 June 2022 03:23 By: Paul Brooks |
jgit.sh in a Window Command Prompt ClassNotFoundException |
2989 |
Wed, 15 June 2022 11:53 By: Paul Brooks |
File Property Set & Read API in Jgit equivalent to SVN's SvnSetProperty Do we have any API in Jgit equivalent to SVN's SvnSetProperty |
3107 |
Thu, 09 June 2022 07:41 By: Pratap Meka |
Feature Wish: more descriptive Information instead of "Ours"/"Theirs" |
3190 |
Fri, 03 June 2022 10:16 By: Ernst Blecha |
Remote hung up unexpectedly on clone repository |
7312 |
Mon, 30 May 2022 14:29 By: Thomas Wolf |
Egit showing all .class file in unstaged changes after building workspace |
4376 |
Fri, 20 May 2022 00:59 By: hyejin kim |
Search all versions of a file with jgit log takes long By: M Mt on Fri, 06 May 2022 |
5613 |
Sun, 15 May 2022 21:52 By: Matthias Sohn |
Adding JGIT to AEM results in dependency resolving issue |
1491 |
Sun, 15 May 2022 21:48 By: Matthias Sohn |
Update AmazonS3 to authenticate with AWS Signature Version 4 Need help updating AmazonS3 to authenticate with AWS Signature Version 4 |
1719 |
Thu, 12 May 2022 15:47 By: Eric Steele |
Setting Transfer Protocol Via Code |
3233 |
Fri, 29 April 2022 07:58 By: Thomas Wolf |
How can send custom error message after git push from local git server by using jgit api |
2944 |
Thu, 28 April 2022 09:47 By: Matthias Sohn |
Performance issue to a shared network drive from Windows. Git repository size is about 46m and takes approximately 47 minutes. |
6772 |
Fri, 15 April 2022 18:19 By: Thomas Wolf |
Github.com RSA key with SHA-1 no longer allowed jGit connects with SHA1 instead of SHA256 |
7274 |
Tue, 12 April 2022 18:36 By: Martin Braun |
JGit exception java.security.spec.InvalidKeySpecException only when running unit test |
2222 |
Thu, 07 April 2022 22:15 By: Thomas Wolf |
Idiomatic way of saving a file |
3479 |
Wed, 06 April 2022 12:03 By: Kirill Yankov |
Idiomatic way to check for bare repos while cloning |
3823 |
Wed, 06 April 2022 11:05 By: Sahil Marwaha |
autogc async operations in JGit-WorkQueue |
2508 |
Wed, 30 March 2022 13:06 By: David Cerbino |
While Cloning the Git LFS Repository getting error While Cloning the Git LFS Repository getting error |
3434 |
Mon, 28 March 2022 11:26 By: Mounika Mantri |
A way to show empty unmanaged folders in EGit? |
4437 |
Wed, 16 March 2022 23:26 By: Vladimir Grishchenko |
SQL file SHA1 id is different based on OS Windows and Linux OS same SQL file generating different SHA1 ids where the content is same but observed the extra line feed added at end |
5186 |
Sun, 13 March 2022 21:58 By: Thomas Wolf |
Login to GitHub failed both HTTPS and SSH GitHub won't take my credentials over either HTTPS or SSH |
11222 |
Thu, 03 March 2022 15:00 By: Neil Aggarwal |
Does JGit has LFS file locking APIs Hi Team, We are exploring java client which to connect to git server and perform git lfs operations like acquire the lock and release the lock.Could you please provide APIs for file LFS file locking |
1489 |
Fri, 25 February 2022 22:38 By: Thomas Wolf |
Authentication/Transport Error Login Window does not take my credentials |
18291 |
Sat, 19 February 2022 17:50 By: Thomas Wolf |
How to implement a breadth-first rev walker to find closest branch for HEAD |
4040 |
Mon, 07 February 2022 15:16 By: Julien HENRY |
Unable to delete .pack file from submodule git folder |
5559 |
Thu, 03 February 2022 10:55 By: Hossam Ali |
[Feature request] Show commit message in Revision Information |
1326 |
Tue, 01 February 2022 09:32 By: Matthias Sohn |
Clone a private repo in GitHub.com with JGIT in java Clone a private repo in Github.com with JGIT in java By: Jack hk on Fri, 21 January 2022 |
3514 |
Mon, 24 January 2022 14:02 By: Jack hk |
How to create a new tag? |
12916 |
Sun, 23 January 2022 17:35 By: Thomas Wolf |
Git Staging view not updating on adding/removing files to/from the index |
11892 |
Fri, 07 January 2022 18:50 By: Thomas Wolf |
Unable to clone repo in ssh or https in Eclipse(2021-12) Unable to clone repo in ssh or https in Eclipse(2021-12) |
4434 |
Thu, 06 January 2022 20:34 By: Thomas Wolf |
Using jgit for help How to implement "push origin HEAD:refs/for/master " in jgit? |
2669 |
Wed, 29 December 2021 00:38 By: Matthias Sohn |
all github/gitlab java projects become "NO_HEAD" after upgrade git plugin |
2131 |
Mon, 27 December 2021 09:24 By: Thomas Wolf |
ReceivePack and preReceiveHook |
1471 |
Tue, 21 December 2021 09:46 By: Maxim Kozlov |
EGit 5.12 SSH clone failing due to Signature encoding error SSH clone fails: DefaultAuthFuture[ssh-connection]: Failed (SignatureException) to execute: Signature encoding error |
28 |
9737 |
Sun, 19 December 2021 18:12 By: Thomas Wolf |
Exact equivalent to "git clone -b <branch> <repository>" in jgit |
2197 |
Wed, 01 December 2021 14:58 By: Matthias Sohn |
Eclipse keeps asking password and user when pushing GitHub Eclipse keeps asking password and user when pushing GitHub |
8817 |
Mon, 08 November 2021 20:04 By: Thomas Wolf |
Missing the EGIT Menu Items How to get the EGit menu items in my custom editor |
1100 |
Tue, 12 October 2021 21:32 By: Yigal Spinner |
How to retrieve merge conflict info using conflicting files How to retrieve merge conflict info using conflicting files returned by JGit Status |
3026 |
Tue, 12 October 2021 16:41 By: ABDUR BILLAH |
Performing RevWalk on repo without downloading entire repo Downloading metadata to just perform a RevWalk. |
115729 |
Sat, 09 October 2021 03:28 By: Shmuel Newmark |
Reproduction of CI Build Building Feature patches for slow bugs and forks |
2908 |
Tue, 05 October 2021 01:22 By: Matthias Sohn |
performance improvement to get stats |
28375 |
Mon, 04 October 2021 16:48 By: Daniel Mejia |
How can google gerrit project to be clone so fast? By: Y C on Tue, 14 September 2021 |
1634 |
Wed, 15 September 2021 08:40 By: Y C |
JGit DFS repository with HEAD pointing to main instead of master |
2291 |
Tue, 14 September 2021 13:31 By: Matthias Sohn |
Blobless clones fail in Eclipse/Egit Blobless clones |
2552 |
Mon, 06 September 2021 03:00 By: Amanda Jackson |
Problem regarding Existing project was support by Mylyn |
1507 |
Fri, 03 September 2021 00:01 By: Md Mubdiul Hasan |
Why is repo in SAFE state when applying a stash results in conflict |
2040 |
Wed, 25 August 2021 16:27 By: Sorin Carbunaru |
Read the tags from repo without cloning |
1581 |
Fri, 20 August 2021 15:37 By: Ashwin D |
Transport Error :: Egit :: clone repository fail clone repository in Egit throws Transport Error |
20281 |
Mon, 16 August 2021 16:13 By: CHANDAN BHAGAT |
Wrong file hash |
2144 |
Mon, 09 August 2021 23:45 By: Yuriy Mitrofanov |
Cannot revert commit |
2152 |
Sat, 31 July 2021 18:04 By: Yuriy Mitrofanov |
Create binary diff and apply binary diff |
1662 |
Tue, 27 July 2021 22:41 By: Yuriy Mitrofanov |
Export/import of commits and diff between repositories in binary form |
2134 |
Thu, 22 July 2021 22:34 By: Yuriy Mitrofanov |
EGit cannot find the signing key |
2751 |
Wed, 21 July 2021 19:49 By: Thomas Wolf |
EGit 5.13 clone TFS repository with SSH fail (Unable to negotiate key exchange for kex algorithms) |
2959 |
Fri, 16 July 2021 15:19 By: Thomas Wolf |
What else can cause "[lock failed]" besides branches that are dups except for case? |
7297 |
Fri, 16 July 2021 14:07 By: David M. Karr |
PostCommitHook |
1821 |
Fri, 09 July 2021 19:20 By: Suraj Arja |
Is there a way to use the Object Inserter and have it show up in the File system |
2794 |
Wed, 30 June 2021 13:16 By: Christian Halstrick |
Having Not Responding messages while using Git Staging view Having Not Responding messages while using Git Staging view |
1438 |
Tue, 29 June 2021 13:46 By: Matthias Sohn |
