Inquiry About Support for Java 21 |
3992 |
Sat, 20 April 2024 16:19 By: Maduranga Siriwardena |
p2.inf instructions don't use newly updated plugin, instead use the currently installed version During the update of a custom touchpoint action, the previous version of the action gets called instead of its new version. |
4307 |
Fri, 08 March 2024 17:14 By: Ed Merks |
requires org.eclipse.equinox.p2.iu |
30321 |
Wed, 06 March 2024 16:34 By: Florian Kellner |
Is there an easy way to install plugins? Find a way to install all plugins for a specific eclipse version |
1185 |
Wed, 18 October 2023 07:21 By: Ed Merks |
Suppress default behaviour of IApplication exit codes 23 and 24? Suppress default behaviour of IApplication exit codes 23 and 24? |
1077 |
Sun, 08 October 2023 17:31 By: Patrick van Berkel |
Source code for dll in launcher |
870 |
Wed, 06 September 2023 04:46 By: Ed Merks |
Export for org.osgi.util.tracker missing on org.eclipse.osgi plugin in version 3.18.400 |
714 |
Mon, 19 June 2023 14:58 By: Nitin Dahyabhai |
EquinoxClassLoader Monkey Patching |
697 |
Wed, 07 June 2023 13:52 By: Ed Merks |
Equinox User Use of .exsd files |
2412 |
Wed, 01 February 2023 08:25 By: Ed Merks |
EclipseLogListener Unhandled event loop exception - instance of org/eclipse/osgi/internal/baseadapto EclipseLogListener Unhandled event loop exception |
1577 |
Wed, 01 February 2023 08:14 By: floid costa |
Debug logging in org.eclipse.equinox.p2.metadata.repository.mirrorApplication |
4043 |
Mon, 26 September 2022 08:54 By: Ed Merks |
Issue with org.eclipse.equinox.p2.publisher.FeaturesAndBundlesPublisher Issue with org.eclipse.equinox.p2.publisher.FeaturesAndBundlesPublisher |
2060 |
Fri, 23 September 2022 19:23 By: Markus Oley |
Slow Classloading with many jars on the classpath |
1287 |
Wed, 31 August 2022 09:38 By: Hanno Wiegard |
Publishing artifacts throws error Publishing artifacts throws error |
2000 |
Thu, 18 August 2022 11:51 By: Virag Purnam |
Headless 'Install new Software' |
11359 |
Sat, 06 August 2022 17:32 By: Alexey Langer |
I have problem building my application because of artifact org.eclipse.osgi not found Snapshot artifact org.eclipse.platform:org.eclipse.osgi:jar:3.18.100-SNAPSHOT not found |
1871 |
Tue, 19 July 2022 14:54 By: Ed Merks |
RCP: Registering Jetty websocket servlets via HttpServiceImpl is broken after Jetty upgrade 9.4-> |
5260 |
Thu, 19 May 2022 06:57 By: Todor Dimitrov |
Accessing a P2 repository with SSO authentication |
2136 |
Fri, 06 May 2022 11:15 By: Elie Richa |
Debugging dependency resolution |
2187 |
Wed, 13 April 2022 07:05 By: Vaclav Hala |
Building and testing frameworks eclipse.c |
2120 |
Wed, 02 February 2022 15:32 By: Felix Van der Jeugt |
Regrading R4_19_maintenance branch Regrading R4_19_maintenance branch |
2927 |
Mon, 15 November 2021 03:41 By: Kuldeep Singh Budania |
OSGI Cache and Feature Dependency: How does it work? OSGI Cache and Feature Dependency: How does it work? |
2173 |
Fri, 24 September 2021 06:01 By: Ed Merks |
Configure Jetty to use HTTPS By: Eclipse User on Fri, 05 January 2007 |
7772 |
Fri, 02 July 2021 05:31 By: Ed Merks |
SimpleArtifactRepository file removal logic To clarify whether the logic in place is valid |
1368 |
Tue, 22 June 2021 05:34 By: Ed Merks |
Activate capability when feature is installed |
2338 |
Fri, 11 June 2021 07:56 By: Felix Dorner |
Clean osgi cache folder after closing the application. Clean up the configuration/org.eclipse.osgi folder after closing E4 application. |
3501 |
Fri, 11 June 2021 07:13 By: Serguei Carrascosa |
Is there a way to clear the configuration area before launching an RCP app? |
2422 |
Fri, 21 May 2021 10:48 By: Phil Beauvoir |
Resolved Bundle Problem Class of Imported Package of Resolved Bundle not found |
2771 |
Fri, 21 May 2021 06:05 By: Patrick Schulz |
HttpWhiteboardFailureException logged as debug in equinox |
4596 |
Fri, 30 April 2021 07:21 By: Arnaud MERGEY |
[Http Service] Invalid session id change event |
6119 |
Thu, 29 April 2021 18:47 By: Arnaud MERGEY |
org.eclipse.equinox.http.servlet fails to get the right paths |
1050 |
Tue, 23 March 2021 18:33 By: Thomas Watson |
Controlling dependency startLevel Seeking help in configuring dependency bundle start levels. |
1132 |
Wed, 17 March 2021 14:38 By: Adam Saturna |
javax.annotation : osgi uses constraint violation problem after updat RCP from 4.6 to 4.14 |
3451 |
Wed, 17 March 2021 13:02 By: khalid kherrazi |
Problem with eclipse.publish.featuresAndBundles NullPointer exception due to p2.inf? |
3528 |
Tue, 16 March 2021 20:30 By: Adam Saturna |
Problem with org.eclipse.core.resources.ResourcesPlugin initialization Change from 2020-06 to >=2020-09 |
3117 |
Mon, 25 January 2021 06:47 By: Robert Schulk |
Equinox 4.18 not found |
1726 |
Fri, 22 January 2021 14:09 By: Thomas Watson |
ServletBridge returns multiple values for empty url parameters (?param=) |
1381 |
Fri, 18 December 2020 07:56 By: Linuxhippy Mising name |
how to Add local archive and install in eclipse by commands |
12277 |
Tue, 10 November 2020 11:05 By: Ed Merks |
Problem Restarting after RCP Update from Java 8 to Java 11 |
2276 |
Mon, 09 November 2020 15:33 By: Christian Damus |
Atomic update of artifacts and metadata in p2 repository |
1115 |
Mon, 12 October 2020 14:58 By: Ed Merks |
Server returned lastModified warning when installing plugin |
2355 |
Sun, 16 August 2020 06:51 By: Ed Merks |
Dependency from MANIFEST.MF does not show up in Plug-in Dependencies classpath container |
7596 |
Tue, 11 August 2020 05:56 By: Ed Merks |
No copyright or license information for feature-based product By: Eclipse User on Fri, 11 September 2009 |
6953 |
Tue, 23 June 2020 21:44 By: Nathan Tippy |
tearing out my hair trying to start the framework. |
3627 |
Sat, 06 June 2020 18:37 By: milly singh |
P2 Director fails to resolve Java 11 dependency |
3060 |
Wed, 03 June 2020 09:54 By: Ed Merks |
Axis2 plugin Installation problem |
1985 |
Sun, 10 May 2020 11:04 By: Md Masuqur Rahman |
Eclipse-milo client example To set manifest.mf for plug-in project |
2209 |
Wed, 06 May 2020 13:38 By: Ed Merks |
Using composites to resolve dependencies |
1903 |
Tue, 07 April 2020 12:48 By: Sina Madani |
RCP application failing on alternate runs via Java Web Start |
5193 |
Fri, 03 April 2020 18:37 By: Florian Kolbe |
TLS / Changing DH key |
2800 |
Tue, 10 March 2020 15:53 By: Maximilien Knopp |
Using sp_redeploy in SSL enabled environment Using sp_redeploy in SSL enabled environment By: Lam Ly on Wed, 04 March 2020 |
6102 |
Wed, 04 March 2020 21:29 By: Lam Ly |
Issue with OSGi Config Admin, DS and component factory After bundle restart factory instances don't become active again |
1856 |
Wed, 19 February 2020 13:30 By: Thomas Watson |
Stuck progress bar while installing p2 artifacts |
3249 |
Mon, 30 December 2019 06:18 By: Ed Merks |
Http Whiteboard propertytypes annotation support does Equinox support things like @HttpWhiteboardServletPattern etc |
2041 |
Tue, 10 December 2019 14:48 By: Erwin De Ley |
Re https://www.eclipse.org/forums/index.php?t=rview&goto=1817477#msg_1817477 |
5132 |
Sat, 23 November 2019 01:34 By: Helen Keller |
Debugging eclipse binaries How can I get a hold onto .pdb files for eclipse's own .dlls and .exe ? |
3780 |
Wed, 23 October 2019 12:23 By: Alexandre Borgoltz |
Problem setting up target platform for multi-platform builds |
9102 |
Fri, 13 September 2019 14:06 By: Ed Merks |
Error when launching marketplace Error when launching marketplace |
2777 |
Tue, 10 September 2019 14:06 By: Jacob Fluke |
How to consume OSGi based product outside OSGi container I need tips and ideas about how to make use of OSGi based product (classes and resources) an outside OSGi container such as Spark. |
2620 |
Thu, 29 August 2019 15:49 By: Regent LArcheveque |
125932 |
Wed, 28 August 2019 13:17 By: Regent LArcheveque |
Problem mirroring a p2 repository mirrorApplication not found despite the required bundles are present |
4113 |
Sat, 10 August 2019 15:38 By: Christian Derksen |
Create p2 site: ProductPublisher can't find the product file [SOLVED] |
12568 |
Tue, 06 August 2019 08:59 By: Ismael Olea |
Add "DynamicImport-Package" at runtime / by API? |
29310 |
Mon, 05 August 2019 12:13 By: Thomas Watson |
Querying product's plugins under debug |
17476 |
Fri, 05 July 2019 03:42 By: Ed Merks |
Logger log level LogService belonging to the Equinox Framework seems to be logging only ERROR messages |
1955 |
Thu, 27 June 2019 10:40 By: Kewaan E |
[HttpService] Filter registration behavior change in 2019-03 |
2688 |
Wed, 29 May 2019 16:32 By: Horst Scheruga |
Running part of bundles in separate process |
55876 |
Mon, 27 May 2019 19:21 By: Tim Sibirsky |
P2 query to get list of plugins contained in a feature |
4498 |
Thu, 09 May 2019 16:19 By: Zakir Meer |
Can't install features in RCP read-only installation |
3332 |
Fri, 05 April 2019 13:26 By: Julien Dehaudt |
Servlet Bridge broken in 2018-03 |
8785 |
Mon, 01 April 2019 14:26 By: Arnaud MERGEY |
p2 .settings |
4093 |
Wed, 20 March 2019 09:33 By: ayman salah |
DS Services being activated multiple times |
5032 |
Wed, 27 February 2019 05:56 By: Aistis Kaikaris |
Java Util Logging and OSGI - custom formatter not used By: Terry H on Fri, 22 February 2019 |
10466 |
Fri, 22 February 2019 13:52 By: Terry H |
Eclipse can't load all bundles after upgraded to eclipse 4.10 |
4953 |
Tue, 15 January 2019 08:29 By: Phil Beauvoir |
Help > About Eclipse IDE > Installation details.... is part of P2? Looking for the Installation details dialog sources |
2694 |
Sun, 16 December 2018 07:35 By: Ed Merks |
Create p2 site mirror without references to origin sites Create p2 site mirror without references to origin sites |
3614 |
Sat, 15 December 2018 00:04 By: Mario Jauvin |
Multiple dependency chain error for package in same bundle |
4502 |
Wed, 28 November 2018 10:59 By: Jaseem M |
Performance degradation after upgrade from org.eclipse.osgi 3.9.1 to higher versions 3.10+ |
3680 |
Tue, 13 November 2018 18:00 By: Duch Bechlegor |
[p2] use p2.inf to configure bundles within feature By: Eclipse User on Tue, 18 August 2009 |
9429 |
Tue, 09 October 2018 12:35 By: ilke Muhtar |
p2.inf to define optional dependency from feature to plugin? |
6902 |
Tue, 09 October 2018 08:37 By: ilke Muhtar |
Conflicting touchpoint actions |
5655 |
Mon, 08 October 2018 13:19 By: ilke Muhtar |
How to trigger multiple changes via different p2.inf files in eclipse? multiple p2.inf files does not run in different plug-ins |
3447 |
Mon, 08 October 2018 13:12 By: ilke Muhtar |
[Equinox] [java 10] Missing service: org.eclipse.osgi.service.resolver.PlatformAdmin |
4290 |
Mon, 01 October 2018 13:09 By: Thomas Watson |
3719 |
Thu, 27 September 2018 06:15 By: Tharindu Wijewardane |
Prototype service instances in the console How can I display distinct instances of service prototypes in the gogo console? |
5556 |
Thu, 20 September 2018 09:38 By: Mike Rumpf |
Equinox java 10 compatibility |
9157 |
Thu, 06 September 2018 12:24 By: Ed Merks |
Bug or Feature: Unexpected activation of Prototype service Issue with SCR Prototype services |
2780 |
Mon, 03 September 2018 07:20 By: Mike Rumpf |
Accessing nested dirname inside NestedDirBundleFile |
2175 |
Tue, 07 August 2018 14:13 By: Thomas Watson |
What happen with the comp and ls commands ? |
2841 |
Thu, 12 July 2018 05:36 By: Dirk Fauth |
Controlling the installation of plugins using HookConfigurator Controlling the installation of plugins using HookConfigurator |
6807 |
Wed, 27 June 2018 04:03 By: Raghava Rao |
Problem with Secure Storage |
3870 |
Tue, 12 June 2018 13:31 By: Ed Merks |
Overriding JVM packages declared in org.osgi.framework.system.packages |
3331 |
Tue, 12 June 2018 13:24 By: Thomas Watson |
[p2] When bundles aren't loaded |
15406 |
Mon, 04 June 2018 12:07 By: Christoph Laeubrich |
HTTP Status 404 - ProxyServlet: /app |
7215 |
Mon, 23 April 2018 09:15 By: Vincenzo Caselli |
DS ignores service.ranking? |
16314 |
Fri, 13 April 2018 12:26 By: P Palm |
Problem importing mysql JDBC driver java.sql.SQLException: No suitable driver found for jdbc:mysql://localhost:3306 |
6889 |
Thu, 22 March 2018 08:36 By: Aistis Kaikaris |
how to get bundle context in the servlet registered by the org.eclipse.equinox.http.registry By: Eclipse User on Sun, 11 November 2007 |
5639 |
Thu, 01 March 2018 14:27 By: Selim Dincer |
How to build Vega on Windows [open source] How to build Vega on Windows [open source] |
5684 |
Tue, 20 February 2018 10:12 By: ahihi do ngoc |
(Servlet bridge) cannot use equinox on tomcat 9 |
5043 |
Wed, 07 February 2018 09:53 By: Arnaud MERGEY |
Cannot transient start the bundle error starting the bundle if org.eclipse.equinox.frameworkadmin.equinox started in transient mode with the default-start level |
3595 |
Mon, 15 January 2018 19:23 By: Thomas Watson |
p2 - dropins deprecated? What are the plans for the future. Is the dropins directory for installation of plugins officially deprecated? |
40976 |
Fri, 12 January 2018 09:57 By: Jeevan Sunkersett |
Error updating product with p2 By: Eclipse User on Wed, 15 July 2009 |
10959 |
Wed, 03 January 2018 15:14 By: owen gerig |
Servet bridge: tomcat severe logs about possible memory leak |
4014 |
Tue, 05 December 2017 15:09 By: Arnaud MERGEY |
Unhandled event loop exception - interface is not visible from class loader PDE Equinox classloader error |
21336 |
Thu, 24 August 2017 18:21 By: Alex Burdusel |
Unable to see plugin in fresh Eclipse instance Plugin loading not working |
9581 |
Fri, 18 August 2017 15:04 By: Patrick Mulder |
Support jar:file protocol in OSGI Storage ? creating self contained executable jar with headless OSGI application |
10201 |
Tue, 08 August 2017 16:49 By: Jakub Siberski |
Installing plugins using command line Failing Installing plugins using command line Failing |
8563 |
Wed, 19 July 2017 17:35 By: Raju Mising name |
class moved from plugin A to plugin B, and OSGi cannot find it |
8299 |
Tue, 11 July 2017 15:42 By: Dinko Ivanov |
Documentation on how the tycho plugin works |
9776 |
Mon, 10 July 2017 12:05 By: Kasun Siyambalapitiya |
Running tycho plugin using Go language |
7063 |
Fri, 07 July 2017 09:22 By: Kasun Siyambalapitiya |
Occasional Error When Deploying Occasional Error When Deploying |
32840 |
Sat, 17 June 2017 17:22 By: Setya Nugdjaja |
Fetching duplicates library(jar files and plugins) from different-different mirrors and sites Fetching duplicates library(jar files and plugins) from different-different mirrors and sites |
17357 |
Fri, 09 June 2017 06:57 By: uma nayak |
p2 mechanism cannot work as expected (Plug-in installation failed when using p2 mechanism |
14207 |
Tue, 06 June 2017 09:06 By: Devin Xin |
Synchonizing with EventAdmin |
6199 |
Fri, 02 June 2017 13:00 By: Stefan Winkler |
Can't find org.eclipse.equinox.security.win32.x86 plugin equinox security plugin on 2.2.0 site |
17023 |
Mon, 22 May 2017 10:29 By: Christophe ANDRE |
Wrong bundle loaded after update on macosx |
16974 |
Wed, 17 May 2017 08:46 By: Guillaume Papon |
Optional dependencies not resolved for some plugins |
15266 |
Tue, 16 May 2017 16:08 By: Abel Hegedus |
Timeout from ds.SCRManager By: Eclipse User on Sun, 10 August 2008 |
18363 |
Sat, 06 May 2017 13:43 By: Kees Pieters |
OSGI Whiteboard registered Resource not working |
45463 |
Wed, 19 April 2017 07:34 By: Dirk Fauth |
Decoded URI in equinox |
16341 |
Fri, 14 April 2017 10:39 By: Arnaud MERGEY |
[p2]Location must be absolute error although it is an absolute path |
14695 |
Sat, 01 April 2017 08:31 By: Ed Merks |
p2 - can't resolve org.eclipse.equinox.internal.provisional.configurator |
7740 |
Fri, 31 March 2017 09:58 By: Jack Mising name |
Why doesn't ConfigAdmin start? |
9261 |
Wed, 22 March 2017 14:00 By: Thomas Quarendon |
Supply Subject to login modules using LoginContextFactory |
11978 |
Mon, 06 March 2017 08:22 By: Ulrik Rasmussen |
ProvisioningAction not Found |
5697 |
Mon, 06 March 2017 05:56 By: Marcel Bruch |
My bundles need a library in two versions, but only one is deployed. |
16426 |
Thu, 23 February 2017 09:48 By: Jens Rabe |
Force buddy classloading programmatically |
3717 |
Mon, 20 February 2017 13:58 By: Thomas Watson |
equinox uninstall eclipse features by command line equinox uninstall eclipse features by command line |
27690 |
Sat, 18 February 2017 08:31 By: Ed Merks |
plugin load from dropins folder suddenly stopped working plugin fails to load |
5289 |
Thu, 02 February 2017 20:32 By: Baback Nemazie |
Director: Cannot resolve (existing) dependency |
24474 |
Wed, 25 January 2017 17:30 By: Timofei Sablin |
site.xml - controlling "feature url" attribute in a headless build Trying to set file name that does not consist the version number |
6959 |
Wed, 07 December 2016 12:04 By: Gidi Gal |
java.lang.IllegalStateException: Module has been uninstalled issue with org.eclipse.osgi.internal.framework.EquinoxBundle |
8331 |
Wed, 30 November 2016 14:09 By: Thomas Watson |
Multiple versions of a dependency |
11666 |
Fri, 14 October 2016 11:44 By: aurel pestell |
CategoryPublisher app and xz compress |
2831 |
Wed, 05 October 2016 14:09 By: Mickael Istria |
Thousands of exceptions during boot, yet application is running - harmless or should be addressed? Equinox OSGi runtime based application throws thousands of exceptions during boot yet runs - harmless or symptom of issues which should be addressed? |
2864 |
Mon, 03 October 2016 19:38 By: Thomas Watson |
Bridging Equinox To A Legacy Build System Bridging Equinox to a legacy build system using programmatic bundle creation and loading. |
3367 |
Wed, 28 September 2016 17:54 By: Rob Hatcherson |
ClassNotFoundException: java.sql.* when running Eclipse IDE on Java 9 Early Access |
6073 |
Thu, 22 September 2016 11:28 By: Andreas Sewe |
Revert to Previous Configuration list is missing in eclipse Revert to Previous Configuration list is missing in eclipse |
4769 |
Fri, 16 September 2016 14:45 By: Raju Mising name |
Problem loading plugin with other plugin in Eclipse Application execution |
4309 |
Thu, 15 September 2016 16:13 By: Ribasanka Handi |
2845 |
Wed, 31 August 2016 18:44 By: Eclipse Webmaster |
Help finding javax.ws and javax.xml components By: Eclipse User on Fri, 22 August 2008 |
8528 |
Tue, 30 August 2016 15:05 By: Mario CC |
How to configure p2 httpclient in order to disable hostname verification |
8384 |
Tue, 30 August 2016 13:36 By: Klara Ward |
Linkageerror in Equinox but no error in Eclipse |
6249 |
Tue, 09 August 2016 16:05 By: aurel pestell |
Unable to delete uninstalled bundle from filesystem. On win I get "file is open in Java Platform SE binary" when attempting to delete an uninstalled bundle. |
4766 |
Fri, 05 August 2016 12:23 By: Thomas Watson |
HttpSessionAdapter |
6159 |
Mon, 25 July 2016 06:47 By: Konstantinos Apostolou |
Uninstall an eclipse plugin programmatically |
3561 |
Wed, 20 July 2016 13:09 By: Thomas Watson |
Missing code signer information for third party JAR |
3421 |
Tue, 12 July 2016 07:42 By: Martin Aulich |
BundleException: Error reading bundle content |
5474 |
Wed, 06 July 2016 15:47 By: Thomas Watson |
Why cannot run IN-CSE and MN-CSE in defferent PC |
4978 |
Wed, 29 June 2016 11:30 By: Trung Luu |
process to reconciler dropins process to reconciler dropins |
4056 |
Tue, 28 June 2016 08:47 By: Juan Carlos Perez |
Can't run P2 director using EclipseStarter |
4632 |
Mon, 13 June 2016 21:55 By: Ned Twigg |
Current Neon version seems to prevent JDKs JAX-WS implementation from working |
6193 |
Mon, 06 June 2016 13:59 By: Max Bureck |
Slow classloading after second start of equinox |
12180 |
Wed, 01 June 2016 13:47 By: Thomas Watson |
Equinox Launcher EXE vs. bundle jar |
6756 |
Mon, 30 May 2016 06:41 By: Dirk Fauth |
osgi.dev property in eclipse 4.5.2 osgi.dev property seems not to work anymore in 4.5.2 |
4314 |
Fri, 27 May 2016 08:10 By: Dominik Brandl |
Tomcat with Equinox OSGi Bridge and Gemini Blueprint Running Spring & Gemini Blueprint in Equinox OSGi Bridge in Tomcat |
4374 |
Wed, 25 May 2016 03:26 By: Samuel Hull |
How to pass attributes from java filter to doFilter PLEASE HELP... I have a filter that gets the LDAP info, I'm just trying to pass the empid from the public boolean isUserAuthorized section to the doFilter section empid = attributes.get("empid&qu |
5654 |
Sun, 15 May 2016 18:29 By: Deon Gee |
!MESSAGE [SCR] Method was not found: ds with equinox and eclipse PDE, unbind method not found |
4603 |
Sun, 15 May 2016 17:22 By: BJ Hargrave |
Creating custom product/site/repository |
5288 |
Sun, 15 May 2016 10:31 By: Daniel Giron |
Any plans to support DS 1.3 in Equinox |
4604 |
Wed, 11 May 2016 15:17 By: Dirk Fauth |
e4 selfupdate |
23714 |
Wed, 04 May 2016 09:35 By: Kees Pieters |
Server shutdown: Kill only terminates Equinox launcher, not spawned JVM processes |
2932 |
Fri, 29 April 2016 15:36 By: Andreas Sewe |
"Framework stop" thread |
7533 |
Tue, 26 April 2016 10:18 By: Gidi Gal |
Galileo - No action found for: addRepository. |
12894 |
Thu, 07 April 2016 07:58 By: Awanthika Senarath |
Version 1.6.0_65 of the JVM is not suitable for this product. Version: 1.7 or greater is required. |
47520 |
Tue, 29 March 2016 23:29 By: George Barz |
Eclipsecon06 OSGi tutorials |
7743 |
Mon, 28 March 2016 17:10 By: Diego Visentin |
Capabilities and startup order |
9685 |
Tue, 22 March 2016 12:34 By: Dirk Fauth |
Why can a plug-in project Execution Environment not change from JavaSE-1.8 to OSGi/Minimum-1.2? Why can a plug-in project Execution Environment not change from JavaSE-1.8 to OSGi/Minimum-1.2. |
6574 |
Mon, 21 March 2016 20:34 By: Paul Roubekas |
What JRE is considered the "Perfect Match" for OSGi 1.2 What JRE is considered the "Perfect Match" for OSGi 1.2 |
6407 |
Mon, 21 March 2016 18:58 By: Paul Roubekas |
Use same Package/Class in System Classloader and Bundle Classloader Getting the same class instance in all bundles |
6270 |
Mon, 07 March 2016 16:54 By: Bill Mair |
What is a SSCCE using EclipseStarter to launch Equinox with a osgi.java.profile? |
4986 |
Mon, 07 March 2016 14:08 By: Charles Gould |
Profile is not current and update problems |
7955 |
Tue, 01 March 2016 16:51 By: Thorsten Meinl |
config.ini deleted by Mac generated RCP p2-enabled app |
10398 |
Thu, 18 February 2016 08:13 By: Sathish Kumar |
Build Equinox Framework Project and import it into eclipse commiters Build, equinox, framework, eclipse |
6435 |
Tue, 16 February 2016 00:09 By: mohamed chebbi |
servletbridge and org.osgi.framework.system.packages.extra |
9891 |
Fri, 12 February 2016 10:03 By: Ya Lo |
ClassNotFoundException if injecting an own service |
3353 |
Thu, 04 February 2016 21:08 By: Ralf Heydenreich |
Prevent installation of product 1 'on top of' product 2 Mark a p2 artifact as incompatible with another? |
5787 |
Thu, 28 January 2016 21:59 By: Steve Donie |
Serving resources from different bundles with HttpContextId defined |
6602 |
Mon, 04 January 2016 19:30 By: Sean Willis |
Runtime arguments to verify digitally signed bundles |
7273 |
Mon, 04 January 2016 14:39 By: Thomas Watson |
[p2] Querying Babel p2 repository for language packs |
7181 |
Thu, 10 December 2015 19:31 By: Wayne Beaton |
Register Servlet as Service vs using equinox servlet registry |
7059 |
Wed, 09 December 2015 18:45 By: Arnaud MERGEY |
Creates dropins folder in my product. |
7776 |
Wed, 09 December 2015 10:30 By: labine labine |
How do I access current user in ssh session? How to identify the current user in a ssh session on the server. |
5419 |
Tue, 08 December 2015 17:27 By: Bill Mair |
configuration file transfer to equinox launcher don't work |
6264 |
Wed, 02 December 2015 17:10 By: Daniel Brenner |
P2: problems with updating feature-based product |
9410 |
Thu, 19 November 2015 14:24 By: Franck Malartic |
specifying java / jre location for web start in JNLP can we use server jre / network jre on JNLP file with out using client machine's jre |
5074 |
Tue, 17 November 2015 13:24 By: Sudhakar Lingutla |
Setup a custom dropins folder Setup a custom dropins folder in a specified file path location |
5355 |
Tue, 17 November 2015 07:06 By: Chiranga Alwis |
p2 slicingoption "resolve" Is there documentation for the new slicingoption "resolve" |
3623 |
Mon, 16 November 2015 19:26 By: Peter Kirschner |
RCP: p2 update handler no updates found. |
11801 |
Mon, 16 November 2015 12:11 By: ALex W |
Versioning for RCP update pom and MF versioning |
4455 |
Mon, 16 November 2015 07:40 By: Ludwig Moser |
Exporting Service from Composite Subsystem Exporting Service from Composite Subsystem does not work. Any ideas? |
5310 |
Fri, 13 November 2015 13:57 By: Timo Rohrberg |
Configuring a ManagedServiceFactory with org.eclipse.equinox.cm |
3812 |
Fri, 13 November 2015 07:56 By: Antoni Mylka |
[P2] Avoid recreation of config.ini, update other files then Bundles |
7459 |
Thu, 12 November 2015 13:43 By: ilke Muhtar |
Development of dropins bundle deployment capability Developing the process of reading the OSGi bundles in the dropins directory and updating the existing bundles.info file |
5592 |
Sun, 08 November 2015 07:36 By: Chiranga Alwis |
Standard OSGi launch configuration Equinox 3.11 Is it still possible to run an standard OSGi in Eclipse 4.5? |
7579 |
Tue, 27 October 2015 20:07 By: Pablo Gomez |
org.eclipse.equinox.http.servlet 1.2.0.v20150519-1816 NOT compatible to javax.servlet 2.3.0 |
7600 |
Wed, 21 October 2015 08:30 By: Mitch B. |
Unexpected build results for rt.equinox.framework |
5550 |
Tue, 13 October 2015 15:06 By: Adrian Pr |
Bundle Pooling vs Shared Configuration Bundle Pooling vs Shared Configuration |
7292 |
Sat, 10 October 2015 10:03 By: Konstantin Komissarchik |
Using OSGI LogReaderService with SLF4J/Logback Redirect error messages By: ALex W on Thu, 08 October 2015 |
5763 |
Thu, 08 October 2015 18:11 By: ALex W |
Missing binaries when building rt.equinox.framework |
5165 |
Wed, 07 October 2015 09:37 By: Adrian Pr |
