Search disabled
The Search function of this forum has been disabled, as it is currently the target of abuse. We apologize for the inconvenience.
  Problem with built-in APER codec with F1AP interface
By: Franciszek Maroszek on Thu, 04 July 2024
2 1036 Fri, 05 July 2024 09:53
  Native ASN.1 PER for CHOICE
It seems that native PER generator doesn't produce the PER_encode/decode for CHOICE types
By: Anton Kozhemyachenko on Wed, 29 May 2024
3 654 Fri, 31 May 2024 17:42
  Decoding array-like jsons
By: Erwan Toux on Wed, 10 April 2024
1 1623 Fri, 19 April 2024 13:16
By: Adam Knapp
  Templates with variable bindings support
By: Denis Filatov on Wed, 10 April 2024
0 1054 Wed, 10 April 2024 10:01
By: Denis Filatov
  Launching execute from config file with different parameters
By: Erwan Toux on Fri, 05 April 2024
2 1704 Wed, 10 April 2024 09:22
By: Erwan Toux
  Support for WebSocket in Eclipse Titan
By: Elemer Lelik on Wed, 12 July 2017
3 11348 Wed, 03 April 2024 12:25
By: Erwan Toux
  Re-usability of type filters to match received messages
By: Erwan Toux on Tue, 26 March 2024
1 2486 Tue, 02 April 2024 13:46
By: Gábor Szalai
  compiler segmentation fault on specific template usage [titan 10.0.0]
Compiler from Titan 10.0.0 segfault with specific template usage
By: Anton Kozhemyachenko on Mon, 04 December 2023
4 37023 Thu, 14 December 2023 10:36
  Improving developer experience, profitability and sustainability in TITAN's IDE
By: Kristof Szabados on Sun, 10 December 2023
0 1082 Sun, 10 December 2023 18:05
  Concatenation of templates
Error value was expected instead of template in concatenation of templates
By: Carlos Arroyo on Fri, 25 March 2022
7 5992 Wed, 29 November 2023 10:40
By: Carlos Arroyo
  Yang model to TTCN-3
TTCN-3 Typing Yang
By: Yann Garcia on Tue, 21 November 2023
1 537 Tue, 21 November 2023 09:19
By: Gábor Szalai
  Compiler issue: compilation is blocked using 100% of the CPU
TITAN Compiler
By: Yann Garcia on Tue, 17 October 2023
3 1824 Tue, 21 November 2023 07:12
By: Yann Garcia
  TTCN-3 standard compliancy
TTCN-3 3GPP NGAP ASN.1 anytype
By: Yann Garcia on Tue, 07 November 2023
2 1014 Wed, 08 November 2023 13:49
By: Yann Garcia
  Native ASN.1 PER encoding/decoding
By: Olaf Bergengruen on Sat, 25 March 2023
16 4147 Tue, 07 November 2023 09:43
  TTCN timers controlled via a virtual clock
By: Olaf Bergengruen on Wed, 25 October 2023
5 641 Wed, 25 October 2023 12:34
By: Gábor Szalai
  OpenAirInterface framework for testing TTCN ?
By: Olaf Bergengruen on Fri, 20 October 2023
1 511 Fri, 20 October 2023 12:25
By: Harald Welte
  COER encoding issue with EtsiTs102941Data
COER ASN.1 extensions codec
By: Yann Garcia on Fri, 08 September 2023
5 11430 Thu, 19 October 2023 12:39
By: Adam Knapp
  LibSip codec for IMS
Sip and other related codecs for 3gpp IMS test cases
By: Bipin V on Tue, 17 October 2023
3 1038 Wed, 18 October 2023 02:47
By: Bipin V
  Problems encoding SCCP LUDT (PDU_SCCP_LongUnitdata) with POINTERTO
By: Pau Espin Pedrol on Tue, 19 September 2023
9 1080 Thu, 21 September 2023 11:36
By: Adam Knapp
  dynamic test case errors in 3GPP testsuite
By: rujun gao on Fri, 17 March 2023
2 1421 Wed, 13 September 2023 14:48
By: Botond Baranyi
  Error executing make port in bin directory
By: zhang yuanli on Wed, 06 September 2023
1 426 Wed, 06 September 2023 13:28
By: Adam Knapp
  COER encoding/decoding issue on EtsiTs102941Data ASN.1
TITAN COER
By: Yann Garcia on Thu, 31 August 2023
1 1432 Wed, 06 September 2023 13:03
By: Adam Knapp
  Issue while decoding COER packet
TTCN-3 ASN.1 COER CODEC
By: Yann Garcia on Mon, 17 April 2023
7 4181 Thu, 27 July 2023 05:44
By: Yann Garcia
  Crosstag with nested elements
By: Moritz Klass on Fri, 23 June 2023
3 620 Fri, 23 June 2023 17:39
By: Moritz Klass
  Reference for a non-defined simpleType or complexType type: http://www.w3.org/2001/XMLSchema|anyType
can't convert xsd to ttcn for 3gpp TS 36.579-5
By: Ruffy Zarookian on Sat, 17 June 2023
2 940 Mon, 19 June 2023 17:48
By: Ruffy Zarookian
  JSON key name with dash (-)
By: Lars Udd on Tue, 13 June 2023
6 870 Wed, 14 June 2023 10:46
By: Lars Udd
  Compiler error on in-line template as parameter of a function
TTCN-3 Compiler In-line template
By: Yann Garcia on Tue, 30 May 2023
8 1628 Sun, 04 June 2023 12:39
By: Yann Garcia
  TITAN g++ compiler error
TITAN C++ code issue
By: Yann Garcia on Thu, 25 May 2023
4 1555 Wed, 31 May 2023 06:43
By: Yann Garcia
  Fields declared after extension (...) are not set as optional
TTCN-3 ASN.1 compiler
By: Yann Garcia on Wed, 12 April 2023
4 1764 Thu, 25 May 2023 07:19
By: Yann Garcia
  Issue with XSD files (tool v8.3.0)
Import of ttcn module "http_www_w3_org_XML_1998_namespace" (as according to the import statement in the included xsd file RFC4479_common_schema) is missing in the output of tool xsd2ttcn
By: Carlos Arroyo on Wed, 08 March 2023
2 1324 Mon, 22 May 2023 10:15
By: Carlos Arroyo
  Ethernet
I am not able to receive a packet from the ethernet port
By: Utsav Agarwal on Fri, 24 March 2023
0 1246 Fri, 24 March 2023 13:00
By: Utsav Agarwal
  TITAN compiler error
By: Yann Garcia on Wed, 15 March 2023
4 1742 Fri, 24 March 2023 10:30
By: Lenard Nagy
  WITH SUCCESSOR not supported
By: Yann Garcia on Tue, 07 March 2023
3 1830 Thu, 16 March 2023 10:55
By: Adam Knapp
  ASN.1 Information Objects parsing error
By: Yann Garcia on Thu, 09 February 2023
3 2738 Sun, 19 February 2023 06:59
By: Yann Garcia
  Assignment of ASN.1 based template
By: Olaf Bergengruen on Wed, 15 February 2023
2 1482 Fri, 17 February 2023 17:20
  Titan 8.3.0 release notification
By: Lenard Nagy on Fri, 03 February 2023
0 1226 Fri, 03 February 2023 09:51
By: Lenard Nagy
  XSD anyElement trouble
TTCN-3 XSD xs:any tag
By: Yann Garcia on Thu, 24 November 2022
5 3185 Tue, 29 November 2022 08:59
By: Yann Garcia
  GRE-in-UDP for MCData IP Connectivity
By: Olaf Bergengruen on Mon, 31 October 2022
4 2604 Sat, 05 November 2022 17:48
  XER: Untagged optional union decoding
By: Moritz Klass on Wed, 23 February 2022
4 4793 Fri, 04 November 2022 09:10
By: Moritz Klass
  XML Encoding issue with namespaces
By: Moritz Klass on Fri, 14 January 2022
8 7434 Fri, 04 November 2022 09:09
By: Moritz Klass
  ctags for TTCN-3 / vim?
By: Harald Welte on Tue, 03 March 2020
3 1793 Sat, 29 October 2022 21:29
By: Alexander Rehbein
  The generation a of template containing 'ifpresent'' param
By: Anatolii Pankevych on Tue, 20 September 2022
0 2725 Tue, 20 September 2022 11:15
  Reserved keywords on Table A.5 of the core specs
Question, does the tool currently support ETSI ES 201 873-1 V4.13.1 (2021-08) "Table A.5: List of TTCN-3 terminals which are reserved words in extension packages" ?
By: Carlos Arroyo on Wed, 06 April 2022
4 2856 Mon, 19 September 2022 16:21
By: Carlos Arroyo
  Abstract syntax tree of ttcn
AST of ttcn types
By: Bipin V on Mon, 04 April 2022
3 1821 Sat, 06 August 2022 08:26
By: Matthias Simon
  Cross level indicates whether the optional field exists
By: lou ban on Fri, 05 August 2022
1 1036 Sat, 06 August 2022 01:27
By: lou ban
  error: `@SBC-AP-Containers.ProtocolIE-Container' is a parameterized type assignment"
By: Pau Espin Pedrol on Tue, 02 August 2022
0 1541 Tue, 02 August 2022 13:01
  the cfg of tft in 3gpp
By: lou ban on Mon, 18 July 2022
2 2317 Thu, 21 July 2022 10:30
By: lou ban
  JSON decode error - float values
JSON decoding errors for certain float values
By: Fabian Sow on Sun, 26 June 2022
3 3840 Sat, 02 July 2022 06:33
By: Fabian Sow
  usage of LENGTHTO and UNIT(elements)
By: lou ban on Fri, 17 June 2022
8 5093 Tue, 21 June 2022 07:13
By: Gábor Szalai
  usage of PRESENCE
how to descripe && in PRESENCE
By: lou ban on Wed, 15 June 2022
4 1836 Wed, 15 June 2022 09:17
By: lou ban
  Ghost field in record to help RAW encoder choose union member
By: Pau Espin Pedrol on Thu, 09 June 2022
1 1596 Thu, 09 June 2022 11:34
By: Gábor Szalai
  Improving logging of match failures
By: Pau Espin Pedrol on Wed, 18 May 2022
2 4239 Fri, 20 May 2022 16:09
  Accessing members of super class
Subclass cannot access member of superclass
By: Fabian Sow on Fri, 08 April 2022
10 5425 Fri, 13 May 2022 12:58
By: Adam Knapp
  Titan 8.2.0 release notification
By: Lenard Nagy on Mon, 09 May 2022
2 2748 Wed, 11 May 2022 14:03
  using optional implicit omit
implicit omit
By: Bipin V on Wed, 06 April 2022
2 2324 Thu, 07 April 2022 06:07
By: Bipin V
  Use of octetstring in LENGTHTO
By: Anton Kozhemyachenko on Tue, 08 June 2021
6 1653 Tue, 05 April 2022 13:53
By: Adam Knapp
  Choosing multiple encoders
How to choose a codec at runtime from ttcn
2 1444 Tue, 05 April 2022 07:20
By: Bipin V
  TTCN_Location in adapters (C++ code)
Printing detailed source log for own C++ code similarly to generated code from TTCN
By: Anton Kozhemyachenko on Sat, 19 March 2022
1 4600 Fri, 01 April 2022 11:59
By: Gergo Ujhelyi
  the PRESENCE useage
how to determine if an optional field exists
By: lou ban on Sat, 26 March 2022
1 3882 Mon, 28 March 2022 08:47
By: Gergo Ujhelyi
  the doubt about the function encvalue()
encoding bitstring and octetstring differently
By: lou ban on Mon, 21 March 2022
5 5750 Thu, 24 March 2022 11:02
By: lou ban
  TAG in RAW
how to control the decode order in a struct with RAW
By: lou ban on Wed, 23 March 2022
0 4863 Wed, 23 March 2022 07:32
By: lou ban
  Crush when using allowed cyclic imports
Allowed cyclic definitions
By: Miguel Angel Reina Ortega on Fri, 18 March 2022
1 3903 Fri, 18 March 2022 13:56
By: Miklos Magyari
  Checking syntax when having virtual folders as source
Virtual folders as source
By: Miguel Angel Reina Ortega on Thu, 17 March 2022
1 3956 Fri, 18 March 2022 12:16
By: Miklos Magyari
  Formal parameter default value
Component variable as formal parameter default value
By: Miguel Angel Reina Ortega on Wed, 16 March 2022
3 2819 Thu, 17 March 2022 09:16
  How to get the component name from PORT?
TTCN-3 PCTs
By: Yann Garcia on Mon, 07 March 2022
3 2485 Tue, 15 March 2022 07:37
By: Yann Garcia
  Any interest in a TTCN/TITAN related conference?
By: Harald Welte on Tue, 30 April 2019
18 6941 Fri, 11 March 2022 09:48
By: Matthias Simon
  Encode/Decode enable for all ttcn modules
Is there a compiler option to enable particular encode decode funtions for ttcn modules
By: Bipin V on Tue, 08 March 2022
3 1907 Wed, 09 March 2022 03:01
By: Bipin V
  Serial-Port "hex-mode"
Interpreting the data send via serial port as octetstring
By: Fabian Sow on Tue, 01 March 2022
2 1507 Wed, 02 March 2022 11:58
By: Fabian Sow
  How to find memory leaks using MEMORY_DEBUG
There are memory leak messages in debug mode
By: Petro Shevchenko on Fri, 11 February 2022
5 2390 Mon, 14 February 2022 11:19
By: Gábor Szalai
  ETSI TTCN-3 Tests
DPM, dPMR TTCN-3 Tests
By: Ertugrul Cavdur on Thu, 03 February 2022
1 2938 Sat, 05 February 2022 15:45
By: Ertugrul Cavdur
  5G/NG-RAN, O-RAN testing with Titan
By: Andre Puschmann on Thu, 20 January 2022
2 2017 Fri, 21 January 2022 08:41
By: Andre Puschmann
  titan.TestPorts.IPL4asp SCTP socket returning wrong sinfo_ppid=0 when receiving data chunk
By: Pau Espin Pedrol on Mon, 22 November 2021
13 4429 Thu, 20 January 2022 15:22
By: Gábor Szalai
  PTC logging
How to log only one particular PTC
By: Olaf Bergengruen on Thu, 09 December 2021
2 877 Thu, 09 December 2021 21:33
  Strategies for shutting down complex component hierarchy
By: Harald Welte on Wed, 20 January 2021
18 3891 Thu, 09 December 2021 21:33
By: Harald Welte
  Compiler core dump on Linux and Windows
TITAN Compiler ASN.1
By: Yann Garcia on Fri, 01 October 2021
7 3020 Thu, 09 December 2021 15:59
By: Yann Garcia
  TTCN-3 record with a field of type "port"
TTCN-3
By: Yann Garcia on Thu, 02 December 2021
2 1920 Wed, 08 December 2021 12:47
By: Yann Garcia
  Eclipse Titan 8.1.0 Release announcement
By: Lenard Nagy on Tue, 30 November 2021
0 3361 Tue, 30 November 2021 14:19
By: Lenard Nagy
  Finalize a test result before teardown
By: Daniel Willmann on Tue, 30 November 2021
0 3396 Tue, 30 November 2021 12:14
By: Daniel Willmann
  CROSSTAG conditioned on several fields
By: Pau Espin Pedrol on Thu, 25 November 2021
1 2049 Fri, 26 November 2021 07:43
By: Gábor Szalai
  ttcn3_makefilegen with TPD files for hello world project
By: David Rupprecht on Thu, 18 November 2021
4 1528 Fri, 19 November 2021 17:03
By: David Rupprecht
  Segmentation fault occured
SSL is enabled with -DAS_USE_SSL, but observed segmentation fault
By: Suresh Banne on Mon, 01 November 2021
1 1141 Tue, 02 November 2021 07:13
By: Gábor Szalai
  Titan Java IPL4 example project
An example project how to use Java version of IPL4 testport with Titan Java version.
By: Gergo Ujhelyi on Mon, 11 October 2021
1 2131 Wed, 13 October 2021 12:35
By: Gustavo Gonnet
  Certificate issues while accepting incoming connection
TITAN OpenSSL Abstract_Socket
By: Yann Garcia on Fri, 24 September 2021
7 2568 Tue, 28 September 2021 15:26
  [SOLVED] Build Titan with FUNCTION_TEST_RUNTIME := yes
By: Emilien Bourdy on Tue, 21 September 2021
0 2798 Tue, 21 September 2021 12:30
By: Emilien Bourdy
  Is it posible to execute linux command or executing a bash script using TTCN3?
By: nguyen nam on Tue, 07 September 2021
5 1368 Thu, 09 September 2021 06:43
By: Gábor Szalai
  titan 8 no release?
By: Kurt Cent on Fri, 06 August 2021
4 2385 Tue, 07 September 2021 08:00
By: Carlos Arroyo
  Eclipse Titan 8.0.0 release announcement
By: Lenard Nagy on Mon, 30 August 2021
0 2157 Mon, 30 August 2021 14:13
By: Lenard Nagy
  How to activate SSL debug mode using Abstract_Socket
By: Yann Garcia on Mon, 16 August 2021
7 2699 Tue, 24 August 2021 12:16
  Communicate Rise V2G with raspberry pi
By: Weetara Wangsuknirun on Tue, 10 August 2021
1 1599 Wed, 11 August 2021 08:02
By: Adam Knapp
  A more enjoyable, productive and resource efficient way for working with TTCN-3
Improving productivity on the compiler level
By: Kristof Szabados on Mon, 02 August 2021
2 1811 Wed, 04 August 2021 20:21
  Custom encoding name with spaces is not compiled
4 1161 Tue, 27 July 2021 15:18
  Project management tool for TTCN-3 project
By: Yen le on Wed, 19 December 2018
2 2189 Mon, 12 July 2021 12:20
By: Diana Hudson
  Ericsson support for titan lower?
By: Kurt Cent on Sat, 05 June 2021
3 1124 Tue, 08 June 2021 09:28
By: Adam Knapp
  RAW decoding with variant "TAG" doesn't work
By: Anton Kozhemyachenko on Mon, 07 June 2021
2 1733 Mon, 07 June 2021 08:21
  TTCN-3 typing for RFC 7946 (GeoJSON)
GeoJSON TTCN-3
By: Yann Garcia on Thu, 20 May 2021
5 1033 Mon, 07 June 2021 08:02
By: Gábor Szalai
  Error when installing TITAN on windows10
By: Mariam LAHAMI on Tue, 20 April 2021
3 1471 Wed, 02 June 2021 17:09
By: Jeno Attila Balasko
  Eclipse Titan repositories will migrate to GitLab
By: Lenard Nagy on Wed, 07 April 2021
3 2794 Fri, 28 May 2021 07:57
By: Lenard Nagy
  TCCIPsec handling functions
The TCCIPsec handling functions work fine on OpenSuse but seem not to work on Ubuntu
By: Olaf Bergengruen on Thu, 13 May 2021
6 1271 Mon, 17 May 2021 09:33
  ANTLR version will be upgraded for Eclipse Titan Executor plugin
By: Lenard Nagy on Fri, 07 May 2021
1 1929 Wed, 12 May 2021 19:14
  Variables used in several .cfg files
By: Julien Deltour on Fri, 05 March 2021
5 1443 Tue, 11 May 2021 08:58
By: Julien Deltour
  Can not add Titan in Eclipse
By: Julien Deltour on Thu, 06 May 2021
2 1194 Fri, 07 May 2021 06:51
By: Julien Deltour
  Compiler Version could not be determined
By: Mariam LAHAMI on Thu, 22 April 2021
5 1630 Thu, 22 April 2021 13:22
By: Adam Knapp
  Generating message sequences after execution
How to generate nice message sequences?
By: Olaf Bergengruen on Wed, 17 March 2021
6 1443 Thu, 18 March 2021 21:03
  Experimental Titan build for Raspberry Pi
By: Elemer Lelik on Fri, 07 October 2016
10 7771 Thu, 11 March 2021 11:58
By: Fabian So
  Question regarding mapping of components and parameters
By: Moritz Klass on Fri, 14 August 2020
19 3329 Mon, 08 March 2021 12:09
By: Gábor Szalai
  RFC: Configurable warnings / errors for ttcn3_compiler
By: Harald Welte on Thu, 04 February 2021
8 2797 Fri, 05 March 2021 08:14
By: Harald Welte
  TTCN-3 syntax highlighting in gerrit
By: Harald Welte on Fri, 12 February 2021
12 2414 Fri, 05 March 2021 08:03
By: Harald Welte
  TTCN-3 Language Server
A universal TTCN-3 language plugin for virtually any editor or IDE
By: Matthias Simon on Sat, 20 February 2021
4 1776 Thu, 25 February 2021 14:39
By: Matthias Simon
  Template evaluation time
When templates are evaluated: at initialization or when they are used?
By: Olaf Bergengruen on Sat, 06 February 2021
6 2151 Mon, 08 February 2021 16:16
  use of select() and file-descriptor limit
By: Harald Welte on Tue, 02 February 2021
5 2263 Thu, 04 February 2021 14:28
By: Gábor Szalai
  Log FileMask / ConsoleMask filter by component type?
By: Harald Welte on Wed, 03 February 2021
4 2263 Thu, 04 February 2021 14:20
By: Gábor Szalai
  TTCN-3 specification version supported
Which version of the TTCN-3 spec supports Titan v7.2.0 ?
By: Olaf Bergengruen on Mon, 25 January 2021
2 2094 Tue, 26 January 2021 13:16
  Internal error: Setting the verdict in invalid state.
By: David Rupprecht on Thu, 14 January 2021
3 1334 Mon, 18 January 2021 14:28
By: David Rupprecht
  TestPort.PIPEasp
By: Evelina Ivanova on Thu, 12 November 2020
3 1589 Fri, 13 November 2020 16:20
By: Elemer Lelik
  OpenApi 3 support- generator script
By: Gábor Szalai on Thu, 12 November 2020
1 1132 Thu, 12 November 2020 13:15
By: Elemer Lelik
  OpenApi 3 support
0 2438 Thu, 12 November 2020 10:16
By: Gábor Szalai
  Unexpected behavior of port.halt?
By: Anton Vikstrom on Wed, 04 November 2020
2 2529 Fri, 06 November 2020 10:41
By: Elemer Lelik
  DNS Example from book
By: Evelina Ivanova on Thu, 05 November 2020
8 3186 Thu, 05 November 2020 13:33
By: Evelina Ivanova
  The type of the expression must be union or anytype
Issue found while building the 3gpp conformance code in ttcn.
By: Gajula Lalithaditya on Wed, 14 October 2020
24 3223 Fri, 30 October 2020 16:44
By: Elemer Lelik
  Changes in shipping of Editline library with Titan
editline, libedit
By: Elemer Lelik on Mon, 12 October 2020
3 3483 Mon, 26 October 2020 08:11
By: Yann Garcia
  Compilation on Windows with Cygwin
Proper settings in Makefile.cfg
By: Bela Varkonyi on Sat, 24 October 2020
1 744 Sat, 24 October 2020 16:00
By: Elemer Lelik
  Wrong decoding of matched / unmatched messages paths in log files
log files
By: Michael Josenhans on Fri, 09 October 2020
3 1621 Tue, 13 October 2020 16:50
By: Elemer Lelik
  OpenSSL 1.1.1.g not supported
TITAN OpenSSL
By: Yann Garcia on Thu, 01 October 2020
3 2162 Thu, 01 October 2020 07:32
By: Yann Garcia
  Request for an actual SUT with its TTCN-3 tests
By: Faezeh Khorram on Tue, 22 September 2020
1 1204 Tue, 22 September 2020 10:35
By: Elemer Lelik
  The Titan runtime configuration file
By: Elemer Lelik on Thu, 23 June 2016
8 7628 Sat, 12 September 2020 15:21
By: Elemer Lelik
  Using GDB debugger for debugging CC files
By: Mujeeb Ur Rehman on Fri, 28 August 2020
7 1770 Fri, 04 September 2020 06:54
By: Gábor Szalai
  Titan compiler for windows
By: Faezeh Khorram on Thu, 27 August 2020
3 1917 Wed, 02 September 2020 11:56
By: Elemer Lelik
  Eclipse Titan Issue The executable file does not exist
By: Felix B on Tue, 25 August 2020
1 1039 Tue, 25 August 2020 13:18
  Getting Started with the SocketCAN J1939 Test Port on the example of Isobus
Test port, SocketCAN, J1939, ISOBUS, NMEA2000,etc.
By: Michael Josenhans on Mon, 24 August 2020
0 4159 Mon, 24 August 2020 15:22
  Porting 3gpp test suites to Titan
By: Elemer Lelik on Fri, 18 May 2018
6 8130 Fri, 21 August 2020 10:50
  Unable to walk through C++ Files in Eclipse
By: Mujeeb Ur Rehman on Tue, 11 August 2020
3 1265 Thu, 13 August 2020 07:15
By: Elemer Lelik
  J1939 Synchronizing Parallel Test Components of different type
Parallel Test Component Synchronization
By: Michael Josenhans on Thu, 23 July 2020
14 3288 Tue, 11 August 2020 07:42
By: Elemer Lelik
  External functions using universal charstrings
How to correctly cast universal charstrings into char *
By: Olaf Bergengruen on Mon, 10 August 2020
4 1265 Tue, 11 August 2020 06:45
  TTCN-3 compiler error on activate() function
TTCN-3 default activate
By: Yann Garcia on Mon, 10 August 2020
3 1247 Mon, 10 August 2020 13:31
By: Yann Garcia
  Translation ports vs dual-faced ports part1
SNMP over UDP with translation port
By: Elemer Lelik on Thu, 11 May 2017
10 71080 Fri, 24 July 2020 21:58
By: Masayuki Ito
  Debugging using Titan Debugger
Debugging ttcn3/compiled C++ files using Titan debugger
By: Mujeeb Ur Rehman on Wed, 15 July 2020
9 2764 Thu, 23 July 2020 12:24
  decvalue for RFC4826 XML fails
Example code for demostrating an issue with decvalue for simple XML
By: Olaf Bergengruen on Thu, 11 June 2020
9 2417 Tue, 14 July 2020 13:54
By: Elemer Lelik
  Some problem of compiling TTCN suit of LTE
LTE 3GPP TTCN 36.523-3
By: yang xi on Tue, 07 July 2020
4 1504 Wed, 08 July 2020 00:39
By: yang xi
  compiler.exe -s0 for Windows
How to build a compiler.exe from the Titan repository
By: Olaf Bergengruen on Tue, 07 July 2020
2 1115 Tue, 07 July 2020 19:42
  Encode FIELDORDER Attribute over b8 type
Encode FIELDORDER Attribute in B12_type
By: yin kaizhong on Mon, 06 July 2020
1 1036 Mon, 06 July 2020 05:25
By: Elemer Lelik
  Implementing components in C++
By: Harald Welte on Thu, 02 July 2020
1 1144 Fri, 03 July 2020 15:59
  Relaxing the C/C++ compiler version check for Titan 7.1.1
compiler, version, gcc, clang
By: Elemer Lelik on Thu, 02 July 2020
1 1212 Thu, 02 July 2020 21:37
By: Harald Welte
  Java code generator/executor of Titan
Java, C/C++, TTCN-3, codegenerator , workflow
By: Elemer Lelik on Tue, 12 November 2019
11 5044 Tue, 30 June 2020 11:48
By: Elemer Lelik
  Running TTCN 3 Test cases (WebSocket ) on windows machine using Eclipse TITAN plugin
Need help in executing TTCN3 Test cases related to applicaton based on Web Socket connection
By: Anuj gautam on Fri, 26 June 2020
3 1863 Fri, 26 June 2020 12:19
By: Elemer Lelik
  TTCN-3 NBIOT Test Case Execution using Eclipse Titan
Step by Step NBIOT Test Case Execution using Eclipse Titan
By: Mujeeb Ur Rehman on Wed, 24 June 2020
4 1512 Thu, 25 June 2020 08:37
  Decoding J1939 name fails
decoding integer & bitstring records
By: Michael Josenhans on Sat, 13 June 2020
18 4520 Tue, 23 June 2020 07:20
  Eclipse Titan 7.1.0 release announcement
By: Kristof Szabados on Mon, 15 June 2020
2 1214 Tue, 16 June 2020 07:04
By: Jan S
  Titan for UE testing for 3GPP Release 15 and beyond
By: Andre Puschmann on Thu, 04 April 2019
8 4645 Wed, 10 June 2020 20:11
By: Andre Puschmann
  External functions returning templates
How to set omit in the return value of an external function implementation
By: Olaf Bergengruen on Tue, 26 May 2020
2 1144 Tue, 26 May 2020 14:19
  TITAN installation tutorial video for Windows with compiling on Cygwin.
Installation tutorial for the TITAN TTCN-3 toolset on Windows with compiling on Cygwin.
By: Balázs Sándor on Sat, 09 May 2020
10 4051 Thu, 21 May 2020 09:17
  Installation problems on Window 10 Cygwin
Install problems
By: Didi He on Fri, 15 May 2020
6 1996 Mon, 18 May 2020 07:59
  Cannot make Demo Example from Titan
By: Muhammad Burhan Hassan on Mon, 09 November 2015
31 15675 Sun, 10 May 2020 16:39
By: Elemer Lelik
  How to generate java file from command line through ttcn test cases.
By: Ganesh Pahade on Wed, 06 May 2020
2 1645 Thu, 07 May 2020 09:19
  TITAN Utility from java using eclipse
How to make TITAN Utility from java using eclipse
By: Ganesh Pahade on Tue, 05 May 2020
1 1162 Wed, 06 May 2020 09:24
  Conversion from CharString to Universal Charstring
By: SUBHAJIT SAHA on Fri, 17 January 2020
4 2135 Tue, 28 April 2020 07:00
  Incorrect decoding of an unaligned bit-field (BIT5)
By: Vadim Yanitskiy on Sat, 25 April 2020
4 2307 Mon, 27 April 2020 17:38
By: Vadim Yanitskiy
  Problem executing STF525 CAM Test
I am having problems executing the STF525 tool found in forge.etsi.org and I am asking for help or advice
By: Pedro Rios on Thu, 26 March 2020
4 2209 Thu, 23 April 2020 08:43
By: Yann Garcia
  more strict 'ifpresent' handling in titan 6.6.x compared to previous versions
By: Harald Welte on Mon, 20 April 2020
3 1712 Wed, 22 April 2020 08:50
By: Gyorgy Rethy
  IPsec over UDP
How to configure an UDP port to use a fixed src port number
By: Olaf Bergengruen on Tue, 31 March 2020
7 12423 Sat, 18 April 2020 04:43
  Alternative to GTP_Tunnel_Daemon: osmo-uecups
By: Harald Welte on Thu, 16 April 2020
4 11495 Fri, 17 April 2020 08:07
By: Harald Welte
  RDF-related encodings in Titan
By: Sascha Hackel on Tue, 14 April 2020
6 1815 Thu, 16 April 2020 14:47
By: Sascha Hackel
  xsd2ttcn on RFC5874
xsd2ttcn fails to convert the XSD in RFC 5874
By: Olaf Bergengruen on Fri, 10 April 2020
2 1883 Fri, 10 April 2020 16:33
  Eclipse Titan product structure part 3
protocol daemon, SCTP, SCTP daemon , SCTP client, SCTP server
By: Elemer Lelik on Wed, 08 April 2020
0 8961 Wed, 08 April 2020 08:41
By: Elemer Lelik
  Eclipse Titan product structure part 2
protocol daemon, dynamic daemon, dynamic vs. static, persistent vs. transient, TRI, transport layer, SCTP
By: Elemer Lelik on Tue, 31 March 2020
0 3665 Tue, 31 March 2020 10:24
By: Elemer Lelik
  Eclipse Titan product structure part 1
test port, protocol module, protocol emulation, SCTP
By: Elemer Lelik on Tue, 24 March 2020
0 3831 Tue, 24 March 2020 12:05
By: Elemer Lelik
  SCTP support in Eclipse Titan part 4
SCTP, IPL4asp, NCAT, netcat, test port, SCTP server
By: Elemer Lelik on Thu, 12 March 2020
0 2938 Thu, 12 March 2020 10:43
By: Elemer Lelik
  Support of JSON module
Titan seems not to support the JSON module in Part 11 of the TTCN specification
By: Olaf Bergengruen on Wed, 06 November 2019
13 3274 Mon, 09 March 2020 07:41
  Eclipse Titan 6.6.1 release announcement
By: Kristof Szabados on Fri, 17 January 2020
3 200579 Fri, 06 March 2020 13:08
By: Quan Dinh Viet
  SCTP support in Eclipse Titan part 3
SCTP, IPL4asp, SCTP client, NCAT, test port, transport layer, IP layer 4, MTU, SCTP fragmentation
By: Elemer Lelik on Thu, 05 March 2020
0 5999 Thu, 05 March 2020 16:19
By: Elemer Lelik
  keeping larger state tables in something more efficient than arrays
By: Harald Welte on Sun, 01 March 2020
2 1320 Mon, 02 March 2020 10:19
By: Elemer Lelik
  SCTP support in Eclipse Titan part 2
SCTP, ASP, PDU, SCTPasp, SCTP client, NCAT, test port, normal mode
By: Elemer Lelik on Sat, 29 February 2020
0 5920 Sat, 29 February 2020 08:00
By: Elemer Lelik
  SCTP support in Eclipse Titan part 1
SCTP, SCTPasp, SIGTRAN, SCTP client, NCAT, test port, simple mode
By: Elemer Lelik on Sat, 22 February 2020
0 5225 Sat, 22 February 2020 16:17
By: Elemer Lelik
  Trouble getting SCTP to work with IPL4
By: Andre Puschmann on Tue, 18 February 2020
3 1561 Thu, 20 February 2020 18:34
By: Elemer Lelik
  Using JSON in TTCN-3 and Titan Part I: Testing REST / JSON web services:
Test of JSON -based REST web services
By: Elemer Lelik on Wed, 22 July 2015
10 13893 Thu, 20 February 2020 06:06
By: Elemer Lelik
1 923 Tue, 18 February 2020 19:51
By: Andre Puschmann
  test port for stdio of external tool?
By: Harald Welte on Mon, 17 February 2020
2 1237 Tue, 18 February 2020 10:27
By: Harald Welte
  problems contributing to DIAMETER_ProtcolModule_Generator / gerrit out of sync?
By: Harald Welte on Fri, 10 January 2020
4 6536 Tue, 21 January 2020 09:38
  OpenAPI TTCN code generation?
By: Harald Welte on Sat, 11 January 2020
2 1210 Sun, 12 January 2020 07:02
By: Elemer Lelik
  The "Christmas refactoring"
By: Kristof Szabados on Mon, 06 January 2020
1 2049 Fri, 10 January 2020 14:57
By: Harald Welte
  ttcn3 in container environment
ttcn3 inside Docker
By: Vardan Saakian on Thu, 28 November 2019
10 3973 Thu, 19 December 2019 10:22
By: Elemer Lelik
  The Titan SocketCAN test port
CAN bus, J1939, CAN RAW, CAN BCM, ISOTP
By: Elemer Lelik on Tue, 17 December 2019
0 3293 Tue, 17 December 2019 14:45
By: Elemer Lelik
  Design of Broadband Micro-Power Wireless Communication Test System Based on TTCN-3
By: Elemer Lelik on Mon, 25 November 2019
0 3583 Mon, 25 November 2019 10:00
By: Elemer Lelik
  Pattern "(*)(%[0-9a-fA-F]#2)*"
Pattern "(*)(%[0-9a-fA-F]#2)*" results in strange log output
By: Olaf Bergengruen on Thu, 14 November 2019
2 1743 Fri, 15 November 2019 16:57
  Eclipse Titan presence on UCAAT 2019
By: Elemer Lelik on Sat, 26 October 2019
0 2709 Sat, 26 October 2019 05:38
By: Elemer Lelik
  A TTCN-3/Titan based test framework for V2G communications
By: Elemer Lelik on Sat, 28 September 2019
0 12588 Sat, 28 September 2019 18:14
By: Elemer Lelik
  import error while module exists
By: Ali Shirvani on Sun, 22 September 2019
2 1328 Mon, 23 September 2019 14:41
By: Elemer Lelik
  Support for HTTP/2 in Eclipse Titan- with a twist
@decoded and decmatch
By: Elemer Lelik on Fri, 06 October 2017
17 12030 Fri, 13 September 2019 04:27
By: Elemer Lelik
  How to reference union value in another module?
By: Sean Kuo on Wed, 11 September 2019
1 1637 Wed, 11 September 2019 05:19
By: Elemer Lelik
By: Elemer Lelik on Thu, 28 September 2017
8 23497 Fri, 06 September 2019 15:07
By: Elemer Lelik
  Titan 6.6.0 in Debian testing/unstable
By: Elemer Lelik on Thu, 05 September 2019
2 4565 Fri, 06 September 2019 04:05
By: Elemer Lelik
  How to know what network interface I'm using is?
By: Sean Kuo on Fri, 30 August 2019
10 206362 Tue, 03 September 2019 14:39
By: Elemer Lelik
  Need help to run a DNS test for ttcn3
By: Sean Kuo on Thu, 08 August 2019
12 4647 Wed, 28 August 2019 04:20
By: Elemer Lelik
  Function eveluation in template
TTCN-3 Template Function Evaluation
By: Yann Garcia on Thu, 08 August 2019
3 1799 Fri, 09 August 2019 08:18
By: Yann Garcia
  TCP ASPs over TLS
How to use the titan.TestPorts.TCPasp with TLS
By: Olaf Bergengruen on Thu, 01 August 2019
4 8048 Mon, 05 August 2019 09:34
  IMS traffic
IMS
By: David Laurent on Thu, 30 May 2019
18 13395 Sun, 28 July 2019 09:40
By: Elemer Lelik
  Dual-faced test ports: architectural considerations
Why and how to use dual-faced test ports
By: Elemer Lelik on Thu, 30 June 2016
8 10963 Fri, 26 July 2019 06:27
By: Aishwarya Kumar
  Result after running Executable
By: Matthew Swanson on Thu, 25 July 2019
3 2366 Thu, 25 July 2019 20:03
By: Matthew Swanson
  Dynamic test case errors with template after replacing a BIT3 with enum
By: Oliver Smith on Fri, 19 July 2019
4 11804 Tue, 23 July 2019 06:38
  Q: TTCN3 and templates / lists of templates
By: Harald Welte on Thu, 09 May 2019
6 28412 Thu, 18 July 2019 08:52
By: Botond Baranyi
  Minimalistic assistance for CSN.1 L/H in the RAW codec?
By: Harald Welte on Mon, 27 May 2019
7 4415 Tue, 09 July 2019 09:34
By: Harald Welte
Current Time: Fri Jul 26 03:52:14 GMT 2024
Powered by FUDForum. Page generated in 0.04416 seconds
