Announcement: Call To Action: Secure the future maintenance of Xtext In a nutshell: the future maintenance of Xtext is a risk |
5827 |
Mon, 30 March 2020 11:46 By: Christian Dietrich |
Multiple prefix matchers for the ui plugin |
1223 |
Tue, 15 October 2024 19:58 By: Ammar Awad |
Portable JAVA+DSL installer with ecoretools diagram editor Problem getting ecoretools deiagram editor into Oomph |
415 |
Sat, 12 October 2024 11:20 By: Christian Dietrich |
dsl changes break incremental maven build |
2027 |
Tue, 08 October 2024 04:05 By: Christian Dietrich |
Trying to create boolean logic |
733 |
Tue, 01 October 2024 04:57 By: Christian Dietrich |
Xtext 2.37.0.M0 is out |
1306 |
Mon, 30 September 2024 13:40 By: Lorenzo Bettini |
LSP: How to trigger build after dependency changes |
429 |
Thu, 26 September 2024 09:18 By: Sebastian Waldhauser |
absolute paths in ._trace files |
6989 |
Thu, 19 September 2024 16:38 By: Lorenzo Bettini |
Error "Failed to create injector" By: Fadi J on Fri, 14 June 2013 |
55911 |
Fri, 13 September 2024 12:51 By: Ralph Hummeling |
Splitting grammar in multiple files, not projects How to split a grammar into multiple files |
781 |
Thu, 12 September 2024 17:19 By: Christian Dietrich |
Lua xText Grammar: Distinguish between variable reference and declaration By: Juan S on Wed, 04 September 2024 |
1546 |
Tue, 10 September 2024 03:19 By: Christian Dietrich |
Create object of dsl ecore classes programatically from generator (xtend) Cannot instantiate the interface type of DSL ecore sub-classes from generator.xtend |
794 |
Thu, 05 September 2024 06:27 By: Anders Ishoey |
[LSP]: How to support project configuration files |
767 |
Wed, 04 September 2024 14:44 By: Christian Dietrich |
Code Action Resource access Trying to use the resource to filter possible executable commands |
934 |
Mon, 26 August 2024 11:51 By: Christian Dietrich |
Xtext 2.36.0 is out |
1420 |
Sun, 25 August 2024 11:57 By: Eclipse User |
Xtext 2.36.0.M3 is out |
1348 |
Tue, 20 August 2024 05:25 By: Christian Dietrich |
Formatting conflict |
1670 |
Sat, 20 July 2024 03:38 By: Christian Dietrich |
Xtend java source version configuration (maven) |
902 |
Fri, 12 July 2024 09:26 By: Ansgar Radermacher |
Xtext 2.36.0.M1 is out |
29236 |
Tue, 09 July 2024 03:10 By: Eclipse User |
Mix more than one grammar elements in another grammar Grammar mixins |
1152 |
Tue, 02 July 2024 07:05 By: Christian Dietrich |
Xtend + tycho maven + JDK 17 ==> java.lang.IllegalArgumentException: java.lang.IllegalArgumentException: The annotation property 'deprecationPolicy' is not declared on t By: Venu J on Sun, 30 June 2024 |
1187 |
Tue, 02 July 2024 02:42 By: Christian Dietrich |
Embedding Comments in Custom DSL Files |
3113 |
Wed, 19 June 2024 04:23 By: Christian Dietrich |
Import Ecore model mapping |
1164 |
Sun, 09 June 2024 07:29 By: Ed Willink |
530 |
Thu, 06 June 2024 20:50 By: Alex Oli |
569 |
Thu, 06 June 2024 20:49 By: Alex Oli |
XMI to Xtext DSL |
2706 |
Thu, 06 June 2024 20:47 By: Alex Oli |
521 |
Thu, 06 June 2024 20:44 By: Alex Oli |
XMI to DSL |
1185 |
Mon, 03 June 2024 07:21 By: Tamas Miklossy |
Xtext 2.35.0 is released |
723 |
Tue, 28 May 2024 17:30 By: Christian Dietrich |
Quickfix does not appear in editor |
976 |
Fri, 24 May 2024 16:56 By: Christian Dietrich |
Xtext 2.35.0.M2 for Eclipse 2024-06 M3 is available |
893 |
Mon, 20 May 2024 13:48 By: Christian Dietrich |
Custom Validator on Xtext Project From Existing Ecore Model |
1119 |
Sat, 04 May 2024 12:34 By: Christian Dietrich |
Context-specific scopeFor method dispatched without entering IScopeProvider.getScope |
3634 |
Fri, 03 May 2024 10:11 By: Kaan B. Y. |
How to restrict validator to the active working file? |
2187 |
Sun, 28 April 2024 10:16 By: Christian Dietrich |
Validation Test Fail after update to Xtext 2.34 and MWE 2.17 Validation is broken after update to the latest xtext |
687 |
Tue, 16 April 2024 13:03 By: José Ferreira |
Citizen user learning share : Starting MyDSL project Request for Comment on this project Folder structure & steps to start |
4369 |
Tue, 09 April 2024 05:38 By: Christian Dietrich |
Logging in xtext Using log4j in Xtext applications |
5460 |
Fri, 05 April 2024 17:32 By: Horacio Hoyos |
Standalone Custom Validation Not Being Called |
1966 |
Wed, 13 March 2024 11:34 By: Brandon Lewis |
Tree view on model file on the first run not working |
959 |
Wed, 28 February 2024 12:03 By: Francesco Bedini |
Xtext 2.34.0 is out |
3342 |
Tue, 27 February 2024 10:46 By: Christian Dietrich |
Upgrading Xtext/Xtend Versions Upgrading an old ant build project from Java 8/Xtext 2.7.3/Xtend 2.2 to Java 11/Xtext 2.32/Xtend 2.32 |
2741 |
Fri, 23 February 2024 13:43 By: Christian Dietrich |
Contributing patches |
1209 |
Thu, 22 February 2024 19:26 By: Ernesto Posse |
How to change the QualifiedNameProvider from another language By: jo ber on Fri, 16 February 2024 |
644 |
Fri, 16 February 2024 16:41 By: jo ber |
[Xtext] Default values for optional assignments? |
9766 |
Fri, 09 February 2024 17:12 By: Steve Hickman |
junit: NamesAreUniqueValidator does not work as eclipse junit but does work in Maven build? |
1174 |
Wed, 07 February 2024 05:46 By: Christian Dietrich |
Rendering problem (?) in runtime Eclipse application |
2714 |
Mon, 05 February 2024 07:33 By: Zhekai Jiang |
Eclipse platform URIs in command line How to deal with Eclipse platform URIs in command line By: Yusuf A on Wed, 24 January 2024 |
3270 |
Wed, 31 January 2024 05:50 By: Christian Dietrich |
Different indentation level in the same file |
18 |
4796 |
Fri, 26 January 2024 11:19 By: Christian Dietrich |
Remove the hierarchy from the name of cross reference |
776 |
Mon, 22 January 2024 19:58 By: Christian Dietrich |
Language server seems to trigger build twice during initialization |
1442 |
Thu, 18 January 2024 08:57 By: Christian Dietrich |
Dot '.' is not allowed inside double quote in Xtext Query Regarding Handling of Dot in Xtext Terminal Rules |
2000 |
Wed, 17 January 2024 06:59 By: Christian Dietrich |
Debugging Xtend2 generated Java |
849 |
Thu, 11 January 2024 19:51 By: Ernesto Posse |
Xtext 2.34.0.M1 is out |
1895 |
Tue, 09 January 2024 16:32 By: Christian Dietrich |
How to generate synchronized code |
618 |
Tue, 09 January 2024 07:08 By: Christian Dietrich |
How to include some multiline comments in the model instance ? |
1088 |
Mon, 08 January 2024 10:15 By: Ronan Babin |
Cross references I want to decide whether to cross-reference or not in a rule based on the content |
545 |
Tue, 02 January 2024 11:54 By: Christian Dietrich |
Reference from xxxx will not be updated as the language has not registered an IReferenceUpdater Reference from xxxx will not be updated as the language has not registered an IReferenceUpdater |
29 |
2213 |
Sat, 30 December 2023 07:41 By: Christian Dietrich |
How do I implement the "Find References" function? How do I implement the "Find References" function? |
455 |
Thu, 28 December 2023 14:38 By: Christian Dietrich |
Grammar for extension equal to a keyword |
969 |
Tue, 19 December 2023 14:16 By: Ed Willink |
Xtend versus Java Imports Java code generation |
739 |
Sun, 17 December 2023 13:23 By: Franz Fehringer |
OutofMemoryError when trying to use Spring Boot OutofMemoryError when trying to use Spring Boot |
750 |
Sun, 17 December 2023 06:49 By: Christian Dietrich |
Nested Conditional Formatters always create Conflict |
929 |
Thu, 14 December 2023 13:26 By: Christian Dietrich |
Ambiguous rules and Predicate behavior |
1246 |
Mon, 11 December 2023 12:17 By: Oscar Ablinger |
Identity preservation in Xtend |
565 |
Fri, 08 December 2023 21:19 By: Christian Dietrich |
Code generation from DSL Lorenzo Bettini book |
1440 |
Wed, 06 December 2023 10:10 By: Franz Fehringer |
Creating an XText based Product |
41232 |
Tue, 05 December 2023 18:07 By: Steve Hickman |
TextMate file name and location Xtext - LSP Support documentation gives the content of a TextMate file but not name and location |
812 |
Thu, 30 November 2023 22:25 By: ANDREW CRAPO |
Failed to execute goal org.eclipse.xtend:xtend-maven-plugin:2.32.0:compile |
898 |
Wed, 29 November 2023 23:55 By: Steve Hickman |
Which type of problem is this? I want to translate PLC to C++. i use the 4 diac ST xtext file. but here come some problem |
816 |
Thu, 23 November 2023 13:24 By: Christian Dietrich |
Xtext 2.33.0 is available |
1042 |
Tue, 21 November 2023 16:24 By: Sebastian Zarnekow |
error: code too large for try statement + java heap |
2659 |
Tue, 14 November 2023 13:05 By: Tamas Miklossy |
Graphical display of DSL |
4541 |
Mon, 13 November 2023 04:08 By: Brandon Lewis |
Content validation depending on file extension By: jo ber on Fri, 03 November 2023 |
547 |
Fri, 03 November 2023 15:26 By: jo ber |
How to customize the scope of a reference |
731 |
Tue, 24 October 2023 10:41 By: Christian Dietrich |
Problem:Hierarchical Presentation of Referential Syntax in the Outline. The correct hierarchical structure is not obtained in the outline after using referential syntax. |
1867 |
Mon, 23 October 2023 08:54 By: Yechao SUN |
Xtext 2.33.0.M2 is out |
892 |
Sun, 22 October 2023 11:10 By: Christian Dietrich |
How can i disable backtracking ? I thought that using the code mentioned below in mwe2 code the backtracking will be disabled. |
4157 |
Sat, 21 October 2023 21:18 By: Mirko Raner |
Large if-then-else results in stack overflow in ANTLR parser |
1267 |
Fri, 13 October 2023 12:22 By: Simon Cockx |
compile error: InternalModelingDslParser: too much static variables |
1001 |
Thu, 12 October 2023 01:27 By: wang yan |
Default INT value to 0 not serialized in xmi |
636 |
Fri, 06 October 2023 12:53 By: Ronan Babin |
Inefficient Validation @Check Validation is called for entire DSL |
1947 |
Wed, 04 October 2023 16:44 By: Christian Dietrich |
Xtext 2.33.0.M1 is out |
879 |
Mon, 02 October 2023 10:18 By: Christian Dietrich |
Grammar Modularity |
1514 |
Sun, 01 October 2023 10:04 By: Ed Willink |
VSCode extension retrieve workspace configuration |
1554 |
Thu, 21 September 2023 07:03 By: Christian Dietrich |
How can I prevent my Xtext Maven build from breaking every 3 months? |
2616 |
Wed, 13 September 2023 10:56 By: Christian Dietrich |
Trouble Launching Language Server Jar in VSCode Extension |
1650 |
Tue, 12 September 2023 18:24 By: Christian Dietrich |
New Xpand free Xpect version. |
1339 |
Tue, 12 September 2023 09:30 By: Christian Dietrich |
Xtext 2.32.0 was released |
1327 |
Mon, 28 August 2023 11:07 By: Sebastian Zarnekow |
Configure Standalone Problem Xtext program standalone no JAR file |
3562 |
Tue, 22 August 2023 03:21 By: Christian Dietrich |
Formatting: Best practices around ownership of surrounding hidden regions Who should own the hidden regions specifically around conditional formatting |
1998 |
Thu, 17 August 2023 09:05 By: Oscar Ablinger |
How to implement nested conditional formatting? |
3459 |
Mon, 14 August 2023 15:00 By: Oscar Ablinger |
Efficiently getting EObjects of a particular type given only their parent Xtext+Sirius IProject |
2268 |
Mon, 14 August 2023 09:32 By: Matt Windsor |
LSP Support: Multiple Languages in one Server |
2759 |
Thu, 10 August 2023 14:44 By: Sebastian Waldhauser |
Eclipse DSL: Change formatter for projects By: Ad Ge on Tue, 01 August 2023 |
523 |
Tue, 01 August 2023 16:22 By: Christian Dietrich |
Xtext 2.32.0.M2 is out |
1776 |
Sun, 30 July 2023 07:43 By: Christian Dietrich |
Description for the Content Assist of File Cross-References |
2738 |
Fri, 28 July 2023 12:37 By: Atul Krishnan |
Arithmetic defined in xtext |
1651 |
Tue, 25 July 2023 03:52 By: Christian Dietrich |
Accessing Enum from imported ECore model |
1558 |
Mon, 24 July 2023 19:17 By: Thomas Chiang |
Vscode plugin issue (OutPutStream issue) Vscode plugin issue (OutPutStream issue) |
2302 |
Mon, 24 July 2023 17:49 By: Christian Dietrich |
Restricting scope to files that are currently open |
1024 |
Mon, 24 July 2023 12:15 By: Christian Dietrich |
LSP Support: Binding for custom ResourceSet is not considered during runtime |
1104 |
Mon, 24 July 2023 10:59 By: Sebastian Waldhauser |
How to disable the language servers automatic building/code generation? |
950 |
Sun, 09 July 2023 08:07 By: Sascha aka. GlancingMind |
Hover service on keywords (language server) |
1179 |
Fri, 07 July 2023 16:56 By: Christian Dietrich |
How to remove the '\' before each single quote in a string added by the formatter ? |
1323 |
Thu, 06 July 2023 13:34 By: Ronan Babin |
File extension conflict Problem when other plugins register a file extension for xtext that is also used in my plugin. |
2891 |
Wed, 05 July 2023 18:30 By: Eclipse User |
[SOLVED] A (very stupid?) beginner problem I cannot run the 15min code generation tutorial |
971 |
Tue, 04 July 2023 08:25 By: Christian Dietrich |
Calling IReferenceFinder.findAllReferences in tests |
858 |
Thu, 29 June 2023 12:22 By: Łukasz Grabski |
Library in VS Code extension |
1327 |
Thu, 29 June 2023 08:45 By: Cyril Vrousos |
Xtext 2.32.0.M0 is out |
1305 |
Sun, 25 June 2023 17:17 By: Christian Dietrich |
Custom scope provider |
1695 |
Sat, 24 June 2023 20:15 By: Łukasz Grabski |
Encountering EProxies after building projects in new workspace |
1099 |
Thu, 22 June 2023 10:35 By: Christian Dietrich |
Generate Xtext grammar from Ecore file without the project wizard |
1767 |
Fri, 16 June 2023 15:09 By: Christian Dietrich |
xtext - Eclipse Application launch issue |
639 |
Fri, 09 June 2023 17:13 By: Christian Dietrich |
Detect index out of sync |
976 |
Fri, 09 June 2023 15:17 By: Christian Dietrich |
N-to-N code generation |
2260 |
Wed, 07 June 2023 11:31 By: Simon Cockx |
Xtext 2.31.0 is out |
1767 |
Mon, 29 May 2023 07:43 By: Christian Dietrich |
Xtext 2.31.0.M3 is out |
1576 |
Mon, 22 May 2023 05:56 By: Christian Dietrich |
Keycloak Integration By: z232 I on Thu, 18 May 2023 |
1227 |
Thu, 18 May 2023 08:03 By: Christian Dietrich |
Xtext and (binary) backwards compatibility |
1474 |
Wed, 17 May 2023 06:50 By: Christian Dietrich |
Xtext Inactive rule generates error |
1874 |
Fri, 12 May 2023 09:49 By: Christian Dietrich |
Include classpath of plugin dependencies in xtext-maven-plugin |
1257 |
Thu, 11 May 2023 09:14 By: Simon Cockx |
Check unique names only in the provided scope |
5102 |
Tue, 09 May 2023 16:37 By: Horacio Hoyos |
Adding a standard library to a DSL |
2392 |
Mon, 08 May 2023 07:44 By: Simon Cockx |
Missing fsa.deleteFile implementation in generator of language server |
10697 |
Sun, 07 May 2023 12:40 By: Sascha aka. GlancingMind |
Xtext 2.31.0.M2 is out |
1524 |
Thu, 04 May 2023 06:22 By: Lorenzo Bettini |
Keyword clashing with terminal rule |
1509 |
Tue, 02 May 2023 19:56 By: Luong Tiet |
Syntactic predicates and proposal provider execution time |
1077 |
Mon, 24 April 2023 09:05 By: Sebastian Zarnekow |
Design question: resolving dependency between Ecore and builtin types |
1597 |
Fri, 21 April 2023 10:00 By: Simon Cockx |
Auto format Xtext textual model |
1518 |
Fri, 14 April 2023 03:13 By: Christian Dietrich |
IProposalConflictHelper not respecting Module binding IProposalConflictHelper not being bound to AntlrProposalConflictHelper |
1604 |
Thu, 13 April 2023 14:02 By: Horacio Hoyos |
Xtext 2.31.0.M0 is out |
1720 |
Sun, 09 April 2023 10:57 By: Christian Dietrich |
Tracing resource location |
726 |
Thu, 06 April 2023 14:08 By: Christian Dietrich |
Maven build does not find xcore lib? |
756 |
Wed, 05 April 2023 14:44 By: Axel Guckelsberger |
Identation in xtend template with tracing |
775 |
Tue, 04 April 2023 18:25 By: Frank Benoit |
Xtext tracing |
858 |
Tue, 04 April 2023 13:31 By: Christian Dietrich |
Create a jar/war file in xtext with websupport Create a jar/war file in xtext with websupport By: z232 I on Fri, 31 March 2023 |
1780 |
Fri, 31 March 2023 16:49 By: z232 I |
The annotation CheckType.NORMAL does not work The annotation CheckType.NORMAL does not work |
1144 |
Fri, 31 March 2023 13:08 By: David Sun |
Generating edit/editor project |
1279 |
Thu, 30 March 2023 07:00 By: Wilbert Alberts |
Load Resources |
2048 |
Mon, 27 March 2023 17:13 By: Ed Willink |
Behaviour of terminals |
986 |
Wed, 22 March 2023 09:35 By: Christian Dietrich |
Perplexing Verilog Operator Grammar: Replication Operator |
1583 |
Mon, 13 March 2023 13:38 By: Brandon Lewis |
AST-Question |
1000 |
Sun, 12 March 2023 11:24 By: Christian Dietrich |
Invalid plugin configuration: sourceRoots |
1157 |
Sun, 12 March 2023 06:25 By: Christian Dietrich |
Some questions. |
1273 |
Sat, 11 March 2023 10:16 By: Frank Behr |
How to replace DefaultFoldingRegionProvider How to replace DefaultFoldingRegionProvider |
1839 |
Fri, 10 March 2023 07:46 By: Ed Merks |
Parser wants spaces |
1082 |
Tue, 07 March 2023 05:25 By: Frank Behr |
Xtext 2.30.0 is out |
1649 |
Mon, 27 February 2023 15:19 By: Christian Dietrich |
Xtext 2.30.0.RC2 is out |
1533 |
Sat, 25 February 2023 18:27 By: Christian Dietrich |
Xtext 2.30.0.RC1 is out |
1509 |
Fri, 24 February 2023 15:50 By: Christian Dietrich |
Xtext 2.30.0.M3 is out |
1421 |
Mon, 20 February 2023 20:57 By: Christian Dietrich |
DSL Type Parameter is not used in extends |
1665 |
Fri, 17 February 2023 09:34 By: Sebastian Zarnekow |
InMemoryJavaCompiler: test for Java 8 compatibility |
2008 |
Thu, 16 February 2023 11:37 By: Simon Cockx |
Data Type Rule By: jo ber on Wed, 15 February 2023 |
1007 |
Wed, 15 February 2023 15:22 By: jo ber |
Language server respond with error missing header in mac Language server respond with error missing header in mac |
2485 |
Thu, 02 February 2023 06:25 By: Nagaraj Kandoor |
Xtext 2.30.0.M2 is out |
1831 |
Mon, 30 January 2023 09:55 By: Christian Dietrich |
generator output relative to dsl file generator output relative to dsl file |
1805 |
Mon, 30 January 2023 09:51 By: Christian Dietrich |
Content assist is not showing available dsl files for import |
1073 |
Mon, 30 January 2023 06:55 By: Christian Dietrich |
Downloading XText, sdk not found Unable to find the sdk in the eclipse download |
1040 |
Mon, 30 January 2023 06:52 By: Christian Dietrich |
Split textual models into multiple files |
964 |
Fri, 27 January 2023 19:44 By: Ed Willink |
Import a dsl language which is not present in the same workspace |
1384 |
Thu, 26 January 2023 08:11 By: Loredana Hozan |
How to implement Formatter maxLineWidth? |
3159 |
Mon, 16 January 2023 16:07 By: Simon Cockx |
Formatting: respect newlines |
1220 |
Fri, 13 January 2023 15:47 By: Simon Cockx |
exec-maven-plugin with Xtext SecurityException on org.eclipse.core.runtime.OperationCanceledException |
2593 |
Wed, 11 January 2023 13:08 By: Christian Dietrich |
Grammar solution request Grammar solution request |
1336 |
Tue, 10 January 2023 14:22 By: Christian Dietrich |
Xtext 2.30.0.M1 is out |
1903 |
Mon, 09 January 2023 07:45 By: Christian Dietrich |
Problem while adding libraries to xtext Project The building process runs fine, but when executing, eclipse generates error |
7817 |
Sat, 07 January 2023 10:00 By: Christian Dietrich |
Only allow explicit imports |
1717 |
Fri, 23 December 2022 08:51 By: Christian Dietrich |
Parser rule for floating points with scientific notation |
2498 |
Mon, 19 December 2022 20:14 By: Simon Cockx |
Xtend IDE 2.21 editor doesn't open and can't build workspace By: Leo K on Wed, 07 December 2022 |
1364 |
Thu, 08 December 2022 18:55 By: Christian Dietrich |
Code completion is leading to validation execution in language server Code completion is leading to validation execution in language server |
1602 |
Thu, 08 December 2022 15:33 By: Nagaraj Kandoor |
Xcore and mwe2 Is it possible to use Xcore in our workflow? |
1615 |
Thu, 08 December 2022 06:46 By: Ed Merks |
Dependency injection of ResourceDescriptionsProvider failed |
2536 |
Wed, 07 December 2022 16:21 By: Christian Dietrich |
How to customize generated eclass from a grammar? By: jo ber on Sun, 04 December 2022 |
1777 |
Mon, 05 December 2022 20:27 By: jo ber |
Error creating PDA for syntactic sequencer (2.29.0) |
3975 |
Tue, 29 November 2022 15:15 By: Sebastian Waldhauser |
Language server is not loading resource and doing build with lsp4j 0.15 Language server is not loading resource and doing build with lsp4j 0.15 |
1688 |
Mon, 28 November 2022 19:17 By: Christian Dietrich |
Grammar: operation with optional left argument |
1758 |
Thu, 24 November 2022 11:15 By: Simon Cockx |
Subset of Xtext grammar |
1123 |
Wed, 23 November 2022 17:06 By: Ed Willink |
Xtext 2.29.0 is released |
1960 |
Mon, 21 November 2022 13:17 By: Christian Dietrich |
Using custom URI's |
1832 |
Tue, 15 November 2022 04:14 By: Christian Dietrich |
Xtext 2.29.0.M3 is out |
1749 |
Mon, 14 November 2022 13:52 By: Christian Dietrich |
Removing insecure log4j dependency |
2169 |
Wed, 09 November 2022 19:55 By: Christian Dietrich |
Load models of imported Ecore in Xtext Language Server Using library approach |
1481 |
Fri, 04 November 2022 12:32 By: Byron Trollip |
Trying to resolve all cross-references of an EObject model from an .aadl file. Resolve all cross-references of an EObject from a loaded .aadl file processed with Xtext. |
1282 |
Wed, 02 November 2022 14:17 By: Christian Dietrich |
grammar for ignore string xtext grammar |
3621 |
Wed, 26 October 2022 04:59 By: Ed Willink |
Xtext 2.29.0.M2 is out |
3041 |
Mon, 24 October 2022 09:11 By: Christian Dietrich |
Resource not present in the ResourcesSet We have .properties files that we use to set the prefix of a table for example. I'm using eResource.getResourceSet() to access these files, but the resource set ignores the .properties file. |
1656 |
Thu, 20 October 2022 18:19 By: Christian Dietrich |
Non editable elements |
1835 |
Thu, 20 October 2022 09:19 By: Christian Dietrich |
whether Xtext/Xtend have some ways to develop DSL debugger |
1463 |
Thu, 20 October 2022 07:19 By: Christian Dietrich |
Limitation on recursive objects? Limitation on recursive objects? |
2727 |
Thu, 20 October 2022 05:46 By: Ed Willink |
Create and configure instances Declare a entity and create and configure an instance of the declared entity |
1630 |
Wed, 12 October 2022 09:30 By: Christian Dietrich |
Modern Gradle Setup Using the Gradle Plugin |
1045 |
Wed, 05 October 2022 14:43 By: Christian Dietrich |
Xtext 2.29.0.M1 is out |
2111 |
Wed, 05 October 2022 10:44 By: Rubén Porras Campo |
Upgrade Xtext to 2.27: UI tests crash |
3330 |
Mon, 03 October 2022 07:59 By: Simon Cockx |
state for support of Python-like whitespace-/newline-sensitive languages |
1956 |
Fri, 23 September 2022 11:46 By: Christian Dietrich |
Grammar with a post-fix operator Is it possible to describe this grammar with xtext? |
5208 |
Sun, 18 September 2022 11:07 By: Ed Willink |
Semantic Token support on Xtext LSP |
4267 |
Sat, 17 September 2022 05:40 By: Christian Dietrich |
Xtext & Xtend for Java 17: please help testing |
2625 |
Fri, 16 September 2022 16:34 By: Christian Dietrich |
Maven build By: jo ber on Sat, 10 September 2022 |
1212 |
Sat, 10 September 2022 09:05 By: jo ber |
Write grammars for SQL and Cypher languages |
2687 |
Sun, 04 September 2022 00:18 By: Tamas Miklossy |
