Announcement: Sirius Desktop and Web support moved to GitHub Discussions |
944 |
Wed, 22 November 2023 15:19 By: Pierre-Charles David ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Announcement: Sirius Desktop has moved to GitHub |
3221 |
Fri, 11 August 2023 09:14 By: Pierre-Charles David ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
AdvoCATE - Assurance Case Automation Toolset can't get hold of this tool |
767 |
Wed, 26 June 2024 17:10 By: Miguel Marina ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Problems with EdgeCreation tool with ElementBased Edges |
719 |
Wed, 05 June 2024 20:29 By: Tom Westbury ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Create Representation Wizard, Session is not available Error Session is not available error |
498 |
Tue, 04 June 2024 12:16 By: Pierre-Charles David ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How can I use drop down selection list in Sirius edition table edition table |
1495 |
Fri, 31 May 2024 10:57 By: Mishal Tripathi ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Creating a graphical node after a selection is made on the selection wizard |
363 |
Mon, 27 May 2024 19:52 By: Hasan Kazerooni ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Too many tools and sections in Palette, make slow Node creation and search |
5862 |
Wed, 22 May 2024 18:38 By: Thomas Kaplan ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
List widget |
239 |
Thu, 09 May 2024 19:51 By: Alex Oli ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Sirius Web installation Errror while installing Sirius Web (instruction from GitHub) |
1479 |
Wed, 10 April 2024 07:07 By: Pierre-Charles David ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Change decorator size |
878 |
Fri, 08 March 2024 20:15 By: Thomas Chiang ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
sirius web sysml2 demo By: liu rui on Sun, 25 February 2024 |
380 |
Sun, 25 February 2024 18:13 By: Nitin Dahyabhai ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Deploy the sirius project I encountered a problem when I packaged the Xtext developed in Eclipse and the corresponding sirius project into an update site for release. |
2461 |
Wed, 21 February 2024 14:06 By: Pierre-Charles David ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Updating Model Attributes after changes in Diagram |
1256 |
Overriding/Replacing the default properties in Sirius Want to add some custom information in the properties view in my Sirius editor |
1067 |
Wed, 21 February 2024 14:05 By: Pierre-Charles David ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Use an entity as relationship (SIRIUS) EMF ecore to Sirius diagram |
494 |
Webinar: What's New and What's Next? |
750 |
Wed, 21 February 2024 13:59 By: Pierre-Charles David ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Deploy Sirius project to an Eclipse RCP application (or other) |
7867 |
Sat, 13 January 2024 09:42 By: peppa nwpu ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Edge alignment problem |
1058 |
Tue, 05 December 2023 15:40 By: peppa nwpu ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Classe-association with sirius |
976 |
Thu, 30 November 2023 13:45 By: Boukhari Angham ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
customize the style of the bordered node |
992 |
Tue, 28 November 2023 01:19 By: peppa nwpu ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Sirius Desktop: Node creation as well as Edge creation? |
323 |
Fri, 17 November 2023 19:01 By: Jonathan Menzies ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Is there any way to run automated tests in Sirius? |
8438 |
Thu, 16 November 2023 23:19 By: Steve Monnier ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Metamodeling Deep Neural Networks in Eclipse with Ecore and Transforming to Graph with Sirius In this project, I have developed a metamodel for Deep Neural Networks (DNN) using Eclipse and the Ecore modeling tool. The aim is to transform this metamodel into a graph representation utilizing the |
7712 |
Sat, 11 November 2023 06:12 By: Boukhari Angham ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to deploy sirius editor? |
2464 |
Fri, 10 November 2023 16:12 By: Ad Mal ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Sirius Desktop: Custom Styles and colors |
2878 |
Fri, 03 November 2023 15:38 By: Laurent Fasani ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Dynamically change container size depending on the number of bordered nodes |
1055 |
Fri, 03 November 2023 11:21 By: Leonard Theisler ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Vertical and horizontal stacks not showing children |
908 |
Thu, 02 November 2023 13:35 By: Thomas Chiang ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Code of Services.java in PropertiesViewTutorial Could not find the code in file Services.java |
7442 |
Tue, 31 October 2023 16:46 By: peppa nwpu ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Integrating Xtext and Sirius When adding a node, how to set the type of element represented by this node |
1751 |
Tue, 31 October 2023 06:21 By: peppa nwpu ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Code Generation Problems Bug By: Ning Ma on Sun, 29 October 2023 |
810 |
Sun, 29 October 2023 00:18 By: Ning Ma ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
AQL query fails in change context |
970 |
Fri, 27 October 2023 10:22 By: Leonard Theisler ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to bundle a Sirius modeler after creating the .aird |
1493 |
Fri, 27 October 2023 08:15 By: skander turki ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Moving elements to the back on creation |
1273 |
Wed, 25 October 2023 14:47 By: Pierre-Charles David ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Domain/Element-based edge issue |
7588 |
Wed, 25 October 2023 13:52 By: Pierre-Charles David ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
creating services with lambda arguments |
1482 |
Wed, 18 October 2023 14:51 By: Tom Westbury ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Adding a node does not work By: Ad Mal on Tue, 10 October 2023 |
1243 |
Tue, 17 October 2023 17:51 By: Ad Mal ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Step by step instructions for embedding xtext into Sirius |
1271 |
Tue, 17 October 2023 10:38 By: peppa nwpu ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Setting properties of child in properties tab of parent |
1139 |
Mon, 16 October 2023 10:35 By: Leonard Theisler ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Tuning genmodel parameters to change XMI file |
1172 |
Thu, 12 October 2023 14:24 By: Pierre-Charles David ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Invoking java services on a double click action |
1378 |
Thu, 12 October 2023 13:09 By: Pierre-Charles David ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Get semantic element of a selected Sirius element in command handler without depending on Sirius? |
895 |
Wed, 11 October 2023 09:53 By: Matt Windsor ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
1183 |
Mon, 09 October 2023 09:06 By: Leonard Theisler ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Viewpoint Selection is empty Sirius does not allow to select a Viewpoint in the Viewpoint Selection |
3086 |
Tue, 03 October 2023 09:48 By: Frédéric Cadier ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Creating multiple views for an element |
906 |
Fri, 29 September 2023 10:16 By: Lukas-Angelo Meier ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Java Service |
782 |
Thu, 21 September 2023 09:50 By: Frédéric Cadier ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Sirius at EclipseCon 2023 |
1285 |
Tue, 19 September 2023 08:25 By: Pierre-Charles David ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to programmatically edit style |
1318 |
Mon, 18 September 2023 08:38 By: Leonard Theisler ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[ANN] Sirius Desktop 7.2.1 |
1244 |
Thu, 14 September 2023 06:46 By: Pierre-Charles David ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Rounded corners and bordered nodes |
820 |
Wed, 13 September 2023 09:50 By: Leonard Theisler ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Adding to collections using the Set operation How do you add an item to a collection feature using the Set operation? |
1093 |
Thu, 07 September 2023 14:55 By: Michael Grubb ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Bundled image shape could not be found Usage of extension points org.eclipse.sirius.diagram.bundledImageShape and org.eclipse.sirius.diagram.customBundledImageShape |
448 |
Sat, 02 September 2023 09:32 By: Elena Larina ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Workspace Image SVG conversion - compatibility issue with PDF |
1576 |
Fri, 01 September 2023 17:08 By: Jonathan Menzies ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Multiple auto-arrange Is there a way to easily apply different auto-arrange options to the same diagram? |
1139 |
Tue, 29 August 2023 13:51 By: Avi Shaked ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Eclipse Sirius Web's Diagram manupulation by chatbot I am expecting a chatbot taking user input to handle multiple built-in properties of the diagram. How to attach chatbot with a Sirius Web? |
966 |
Fri, 25 August 2023 13:07 By: Suhas Devmane ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Get the label/value of an item selected from a Sirius List How can I get the label/value of the item selected from the list? |
1867 |
Fri, 04 August 2023 09:16 By: Prospero nasca ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Lost access to variables in Popup Menu definitions on upgrade to 7.0.7 |
3570 |
Thu, 03 August 2023 19:52 By: Jonathan Menzies ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Copy a Model with His representations in Obeo Designer Comunity Copying a Model in Obeo Designer Community |
1304 |
Wed, 26 July 2023 17:05 By: David Ahumada ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Sirius Web - how to get document IDs with GraphQL |
1053 |
Thu, 20 July 2023 15:42 By: Pierre-Charles David ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Copying the Interpreter results? |
2456 |
Fri, 07 July 2023 06:21 By: Wilbert Alberts ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Sirius Web Product Tour (free webinar) |
1170 |
Tue, 27 June 2023 13:48 By: Pierre-Charles David ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Creating a Trust Boundary |
3710 |
Wed, 14 June 2023 09:53 By: Lukas-Angelo Meier ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Can't Undo Sirius deletion in RCP Can't Undo Sirius deletion in RCP |
1015 |
Tue, 13 June 2023 00:38 By: Jerry Zh ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Derived Relations in Ecore Derived Relations in Ecore |
1185 |
Fri, 09 June 2023 19:07 By: Pierre-Charles David ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
"List Mode" check box and "Shape" drop-down menu in Sirius web? |
724 |
Fri, 09 June 2023 18:10 By: Dusan Pavlovic ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Sirius Desktop: Black background for hover icon on links on linux |
1342 |
Fri, 09 June 2023 17:07 By: Pierre-Charles David ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[ANN] Sirius Desktop 7.2.0 |
1325 |
Fri, 09 June 2023 06:48 By: Pierre-Charles David ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Setting choice of fonts Setting choice of fonts |
1250 |
Wed, 10 May 2023 14:12 By: Jad El-khoury ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Saving AQL queries for use in Sirius model |
1208 |
Thu, 04 May 2023 06:53 By: Jad El-khoury ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
MTL query result don't match when tested in Sirius Interpreter The mtl query used in the Sirius Project displayed some weird bugs/behavior |
1273 |
Mon, 01 May 2023 12:33 By: Qalbun Salim ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Sirius Desktop: Direct Edit Label on Linux Possible bug: Sirius Desktop 7.0.5 Linux Mint |
924 |
Tue, 25 April 2023 23:52 By: Jonathan Menzies ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Sirius Desktop: Elements to Select |
1475 |
Wed, 19 April 2023 01:20 By: Jonathan Menzies ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Activate Spell Checker in properties? |
962 |
Wed, 12 April 2023 15:13 By: Jonathan Menzies ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Sirius Web in a Github Codespaces Container Sirius Web in a Github Codespaces Container |
1490 |
Wed, 12 April 2023 13:54 By: Neil Mackenzie ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Missing artifacts from sirius-components |
1129 |
Fri, 31 March 2023 16:56 By: Niclas20 Lautenschlaeger ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
error while downloading sirius source code |
757 |
Fri, 31 March 2023 13:33 By: Lucia Klincova ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[ANN] Sirius Desktop 7.1.0 |
1351 |
Thu, 30 March 2023 07:27 By: Pierre-Charles David ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
ECore Tools not working when Sirius 7 installed |
1642 |
Wed, 29 March 2023 13:40 By: Tom Westbury ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Cross-referencing over models Using siriusweb for graphical work on resource sets. |
1424 |
Tue, 28 March 2023 02:24 By: Jörn Guy Süß ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Inhibit shape highlight when creating an edge |
1542 |
Sun, 19 March 2023 13:50 By: Tim Duncan ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Import element to diagram individually |
1461 |
Sat, 18 March 2023 14:30 By: Tim Duncan ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Eclipse Sirius - Overriding/Customisation of Native Features Advice on layout algorithm, popup menu and widget customisation |
1166 |
Sat, 11 March 2023 07:01 By: Ed Merks ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Adding attributes to a class via modeling workbench |
2199 |
Fri, 10 March 2023 21:17 By: Java User ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Not showing references for Ecore diagrams the following mapping semantic candidates expression could not be correctly evaluated : service:getE |
1390 |
Thu, 02 March 2023 14:22 By: Faezeh Khorram ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Getting Error with create a bordered node when creating a new bordered node |
1484 |
Sun, 26 February 2023 15:35 By: saadbin abid ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
M2T on Sirius Web M2T on Sirius Web |
627 |
Fri, 24 February 2023 18:17 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
graphical modification of a viewpoint with code |
633 |
Tue, 21 February 2023 15:43 By: Pierre-Charles David ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Service Calls - Errors being caught |
1157 |
Mon, 20 February 2023 21:22 By: Jonathan Menzies ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Sirius 7.0 migration |
723 |
Mon, 20 February 2023 17:55 By: Laurent Redor ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Hiding zorder menu on edges |
1276 |
Fri, 10 February 2023 21:45 By: Jonathan Menzies ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Sirius default font preferences not respected |
2996 |
Sat, 04 February 2023 04:51 By: Louis Detweiler ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
container nesting |
4061 |
Wed, 01 February 2023 12:33 By: Horacio Hoyos ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Dependency problem in sirius-web |
1608 |
Thu, 26 January 2023 14:45 By: Pierre-Charles David ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Moving from Sirius Desktop to Sirius Web |
1713 |
Thu, 26 January 2023 14:38 By: Pierre-Charles David ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Messy diagram layout when creating programmatically representations |
1109 |
Fri, 20 January 2023 21:04 By: Christoforos Zolotas ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Create diagram programmatically How to Create diagram programmatically ? |
5304 |
Fri, 20 January 2023 20:22 By: Christoforos Zolotas ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[ANN] Sirius 7.0.7 |
1303 |
Fri, 20 January 2023 14:19 By: Pierre-Charles David ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Obeo Designer - can't modify Enumeration property value in Main section |
2016 |
Thu, 12 January 2023 10:12 By: Michel RAOUX ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Share style data between nodes |
1813 |
Thu, 05 January 2023 02:06 By: Jonathan Menzies ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How do I track the source of each user signup for B2B SaaS product? |
710 |
Mon, 02 January 2023 11:05 By: Pierre-Charles David ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Trying to push semantic source of edge to root of model |
1621 |
Sat, 10 December 2022 19:24 By: Thomas Chiang ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
If statement for edge creation not working as expected |
1585 |
Fri, 09 December 2022 20:57 By: Thomas Chiang ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
porting sirius prototype from eclipse 3 to eclipse 4 java.lang.IllegalStateException: Workbench has not been created yet. |
2073 |
Tue, 06 December 2022 11:00 By: Arnault Bonafos ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Opening a sirius aird with an E4 application |
1169 |
Thu, 01 December 2022 17:46 By: Omar Tazi ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to add new PaletteToolEntry to PaletteToolBar? I want add new PaletteToolEntry to PaletteToolBar |
1639 |
Tue, 29 November 2022 12:24 By: Peddaiah Golla ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Property validation rules |
6702 |
Tue, 29 November 2022 09:50 By: Denis Nikiforov ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[ANN] Sirius 7.0.6 |
1464 |
Mon, 28 November 2022 10:41 By: Pierre-Charles David ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Radio Button clicking does not work if you click only once (Important Ergonomic issue) |
3913 |
Mon, 14 November 2022 15:34 By: Namea lasta ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Image Export Bug in Sirius 6.3.0 -> 6.6.0 The Image Exporter for representations incorrectly scales for certain image formats |
2951 |
Tue, 08 November 2022 17:28 By: Jonathan Menzies ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Xtext Editors within Sirius Diagrams - Cannot select editable features |
2338 |
Tue, 01 November 2022 15:25 By: Maximilian Wolf ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Unable to create diagram description inside Viewpoint Sirius |
1807 |
Sat, 29 October 2022 15:34 By: Diana Barros ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
BorderedNode Container, is it possible ? |
2444 |
Wed, 26 October 2022 14:09 By: Maxime Porhel ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Sirius 6.6 Export Representation as Image Scaling |
1870 |
Mon, 17 October 2022 17:01 By: Jonathan Menzies ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Diagram elements are hidden after the tool migration to a newer sirius and obeonetwork version |
3996 |
Wed, 05 October 2022 09:28 By: Razvan Prisca ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Svg background color |
2033 |
Sat, 01 October 2022 07:40 By: Vikram Vaswani ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Do not populate Diagrams |
1436 |
Wed, 28 September 2022 12:38 By: Ludovic Stumme ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Using Sirius table to create element |
1180 |
Tue, 27 September 2022 21:30 By: Ludovic Stumme ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Tooltips on Decorators |
1671 |
Tue, 27 September 2022 15:27 By: Jonathan Menzies ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Automatic Viewpoint Activation |
1642 |
Tue, 27 September 2022 12:12 By: Ludovic Stumme ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
workspace image style question Reopen diagram bound of node is not correct |
2721 |
Fri, 23 September 2022 09:42 By: GAN JIANAN ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to Set Width and Height of The Containers? |
2084 |
Thu, 22 September 2022 13:39 By: Hakan Yüksek ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to set height and width |
3539 |
Thu, 22 September 2022 13:36 By: Hakan Yüksek ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Refreshing diagram nodes based on preference change |
2707 |
Mon, 19 September 2022 23:53 By: Jonathan Menzies ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Sirius Webinar: CaMCOA Studio, the Rolls-Royce's Workbench to Deploy Engine Control Software Thu, 15/09/2022 · 5:00 PM | Paris (GMT +2:00) |
2682 |
Wed, 14 September 2022 08:38 By: Pierre-Charles David ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Processing LinkedHashMap (Json) Object with AQL Exists any way to process directly a LinkedHashMap Object from AQL |
2744 |
Wed, 14 September 2022 07:20 By: Ángel Moreno ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Extending Sirius UI (tab-bar) Extending Sirius in a Java Plugin |
1504 |
Fri, 02 September 2022 22:31 By: Steve Monnier ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[Sirius] Access to local resources of modeling project |
2460 |
Fri, 02 September 2022 22:22 By: Steve Monnier ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Adding a "Load Resources" tool to Sirius diagram viewpoint, unsure how to do so. Looking for help with creating a "Load Resources" equivalent in a Sirius diagram viewpoint. |
1879 |
Wed, 31 August 2022 13:25 By: Joost Mertens ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Usage of java services defined inside a different viewpoint - is that possible? |
3614 |
Fri, 19 August 2022 15:42 By: Namea lasta ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Labeling Relation Edges Using a Java Service to return a String label based on a source and a target |
3002 |
Thu, 18 August 2022 20:06 By: Bruno Curzi-Laliberté ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Sirius Web backend build failing in terminal Unable to generate the jar file when I try to build the example application on my own. |
2707 |
Sat, 13 August 2022 03:48 By: Mercy Asamoah ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Validation markers on children represented as 'list' |
1624 |
Fri, 12 August 2022 13:38 By: Wilbert Alberts ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Sirius Web add a java service |
1525 |
Tue, 09 August 2022 07:43 By: Michael C ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Reconnect tool Precondition : I can't access to otherEnd and edgeView variables |
4835 |
Fri, 05 August 2022 07:30 By: Pierre-Charles David ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[ANN] Sirius 7.0.2 |
1660 |
Sync font styling for all nodes in a container |
2738 |
Fri, 05 August 2022 06:14 By: Louis Detweiler ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Documentation on the DiagramCreationTool in the Viewpoint Specification Editor |
718 |
Fri, 29 July 2022 23:43 By: Steve Monnier ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Sirius Web automatic layout |
2955 |
Wed, 27 July 2022 09:24 By: Niko Dac ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Setting somethings in semantic model during validation |
3054 |
Wed, 27 July 2022 08:15 By: Simon Tulia ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Using ELK layouts in a Sirius based product |
1712 |
Tue, 26 July 2022 17:12 By: Avi Shaked ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Sirius web front end selection tool |
1138 |
Tue, 26 July 2022 14:27 By: Michael C ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Sirius Web import project with customs representations |
1461 |
Tue, 26 July 2022 13:00 By: Michael C ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Is it possible to add a java extension in odesign model (for Property Value Description)? |
1544 |
Thu, 21 July 2022 15:07 By: Laurent Redor ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Validation only FAST and NORMAL |
1862 |
Wed, 20 July 2022 15:53 By: Tim Duncan ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Validating all diagrams in a session |
2850 |
Wed, 20 July 2022 15:45 By: Tim Duncan ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Propertiesview of sirius-web showing elements of other documents in the same project |
2106 |
Sun, 17 July 2022 19:27 By: AMir Taghizadegan ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
casting EObject in java service failed |
1596 |
Fri, 15 July 2022 06:47 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Set element to readonly |
2215 |
Thu, 14 July 2022 19:25 By: AMir Taghizadegan ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to NOT display a widget? |
2627 |
Tue, 12 July 2022 12:58 By: Namea lasta ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Edition Table Description breaking into multiple lines whenever a cell contains linebreaks |
3024 |
Mon, 11 July 2022 11:48 By: Namea lasta ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
hide some properties of an element in the properties-view of sirius-web properties-view of sirius-web |
3327 |
Mon, 11 July 2022 09:44 By: AMir Taghizadegan ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Strike Through Not working on Conditional Styles for Checkboxes labels? |
2957 |
Mon, 11 July 2022 07:15 By: Namea lasta ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
get the documentId of a representation in sirius-web |
2360 |
Fri, 08 July 2022 19:39 By: AMir Taghizadegan ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Cannot apply "Label Foreground Color" to not "Enabled" widgets? |
2940 |
Thu, 07 July 2022 16:23 By: Namea lasta ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Sirius web representationId |
2271 |
Thu, 07 July 2022 14:55 By: Pierre-Charles David ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Sirius Web Subscription |
1356 |
Tue, 05 July 2022 14:23 By: Michael C ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Tables support in Sirius Web |
1683 |
Thu, 30 June 2022 15:13 By: Denis Nikiforov ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Double Click supported in sirius-web? |
3527 |
Thu, 30 June 2022 09:35 By: Pierre-Charles David ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Problem with Custom Widgets at higher display scaling |
5819 |
Thu, 30 June 2022 02:19 By: Louis Detweiler ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Possibility to choose a custom endpoint in an edge? |
5525 |
Tue, 28 June 2022 19:54 By: Wenqing Gu ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Reconnect Edge Tool in Sirius web supported? Reconnect Edge Tool in Sirius web supported |
1466 |
Mon, 27 June 2022 11:49 By: Pierre-Charles David ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
The discussion tab of PropertiesViewTutorial does not exist. |
2938 |
Mon, 27 June 2022 06:24 By: Pierre-Charles David ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Hiding edges with layer |
7121 |
Thu, 23 June 2022 09:25 By: Francesco Bedini ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Add a listener to a diagram element on sirius web |
17681 |
Tue, 21 June 2022 14:05 By: AMir Taghizadegan ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
add a listener to a diagram element |
6748 |
Tue, 21 June 2022 13:39 By: AMir Taghizadegan ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Validation of the odesign file fails |
5030 |
Mon, 20 June 2022 09:39 By: AMir Taghizadegan ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
invalid type literal exception in aql expression An error has occurred with the expression aql:self.nodes.ocllsTypeOf |
2457 |
Tue, 14 June 2022 16:37 By: AMir Taghizadegan ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to create an eclipse plugin that registers my metamodel in the current eclipse instance |
2634 |
Tue, 14 June 2022 15:15 By: AMir Taghizadegan ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
EMF Model Creation Wizard fail Model creation fails |
3686 |
Tue, 14 June 2022 09:32 By: AMir Taghizadegan ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Specify path for plugin.properties file |
2673 |
Tue, 14 June 2022 08:31 By: AMir Taghizadegan ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
display supertype in the selection popup |
3272 |
Tue, 14 June 2022 07:59 By: AMir Taghizadegan ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Invalid Type Literal error when using AQL Expression |
4192 |
Mon, 13 June 2022 08:11 By: AMir Taghizadegan ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
EMF Model Instance is null |
1666 |
Mon, 13 June 2022 07:06 By: AMir Taghizadegan ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Is there a way to show alphabetically sorted candidate names? |
3060 |
Sun, 12 June 2022 15:50 By: Akira Tanaka ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
edge creation fails: Object is not contained in a resource. The Object is not contained in a resource. |
3341 |
Wed, 08 June 2022 13:04 By: Glenn Plouhinec ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Sirius-web - errors when deploying custom model |
3690 |
Sat, 04 June 2022 09:21 By: AMir Taghizadegan ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Sirius web problems with loading workspace Image |
3917 |
Sat, 04 June 2022 09:20 By: AMir Taghizadegan ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Elements in example.basicfamily are not shown basicfamily.sample |
2362 |
Sat, 04 June 2022 07:11 By: AMir Taghizadegan ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Arrange action not moving nodes if they are on top of each other |
4383 |
Fri, 03 June 2022 02:38 By: Erik Danielsson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
The Space allocated for Label Text Stays SMALL, even if he Font Size is INCREASED. A BUG? |
3934 |
Thu, 02 June 2022 08:50 By: Namea lasta ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Help with Element Based Edge |
6150 |
Tue, 31 May 2022 06:54 By: Pierre-Charles David ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Highlight shortest path between two selected nodes |
4063 |
Wed, 25 May 2022 13:16 By: Zsófia Nagy ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Close dialog box from Control Buttons |
10690 |
Wed, 25 May 2022 13:13 By: Hakan Yüksek ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to save the value of a checkbox? (Sirius Specifier) |
5004 |
Tue, 17 May 2022 08:18 By: Namea lasta ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[Sirius Web] Grouping Node/Edge creation buttons |
2605 |
Mon, 16 May 2022 19:03 By: Pierre-Charles David ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Create path with element-based edges |
4076 |
Mon, 16 May 2022 07:22 By: Zsófia Nagy ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Z-order when the diagram is first time opened |
1899 |
Fri, 13 May 2022 19:18 By: Wenqing Gu ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Is there a way to automatically display the classes children of other classes? |
4791 |
Fri, 13 May 2022 14:47 By: Namea lasta ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to apply validation defined in the ecore file By: jo ber on Tue, 03 May 2022 |
2133 |
Tue, 03 May 2022 12:44 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
SiriusCon Live 2022: the program is available |
3334 |
Mon, 02 May 2022 13:43 By: Pierre-Charles David ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Creating a Property View Description |
2876 |
Fri, 29 April 2022 13:58 By: Arnaud Dieumegard ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[ANN] Sirius 7.0.0 |
5336 |
Thu, 28 April 2022 12:29 By: Avi Shaked ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Obeo Designer, don't start on windows 11 |
1922 |
Thu, 28 April 2022 08:29 By: Glenn Plouhinec ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Removing default target of another diagram decoration |
3470 |
Wed, 27 April 2022 00:49 By: Louis Detweiler ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Flow page moved halfway across the node |
1416 |
Mon, 25 April 2022 19:18 By: Erik Danielsson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Why the editor I created cannot display relation based edges? By: Su Su on Sat, 16 April 2022 |
2794 |
Sat, 23 April 2022 07:13 By: Su Su ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Does the Property View Sirius Specifier work in Capella ? Yes or No? |
4101 |
Tue, 19 April 2022 09:45 By: Namea lasta ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to access/override a property page, if it has been described outside of the Sirius Specifier? |
2209 |
Fri, 15 April 2022 15:20 By: Namea lasta ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Index of all Sirius Tutorials |
1124 |
Fri, 15 April 2022 09:20 By: Namea lasta ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
(To be deleted) |
2497 |
Mon, 11 April 2022 14:18 By: Namea lasta ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
