Incremental transformations |
1937 |
Thu, 09 May 2024 08:53 By: Ed Willink |
Drops and Updates are now Builds |
944 |
Fri, 08 March 2024 20:13 By: Ed Willink |
Propagate warning information to ExecutionDiagnostic |
1483 |
Mon, 27 November 2023 13:41 By: Christopher Gerking |
Remove object in place transformation |
1352 |
Tue, 14 November 2023 08:38 By: Christopher Gerking |
Create QVTo project programmatically |
1157 |
Fri, 07 July 2023 13:31 By: Christopher Gerking |
Type references for nested EClasses |
1265 |
Tue, 13 June 2023 20:09 By: Ed Willink |
Transformation involving UML profiles |
730 |
Thu, 08 June 2023 16:59 By: Ed Willink |
Resolution operations for objects in other containers. |
862 |
Thu, 13 April 2023 14:53 By: Christopher Gerking |
Different URI |
859 |
Thu, 30 March 2023 17:25 By: Ed Willink |
Output model into separate files |
897 |
Fri, 27 January 2023 19:37 By: Ed Willink |
QVTo transformation with Xtext target models |
1169 |
Fri, 13 January 2023 20:15 By: Christopher Gerking |
Transform UML models with applied profile |
1405 |
Sat, 24 December 2022 05:58 By: Ed Willink |
EPX to Ecore and EMX to Xtext instances |
1447 |
Thu, 22 December 2022 14:27 By: Christopher Gerking |
Representing QVT-Operational transformations in XML, JSON or or any other serialized format I have a requirement where I need to parse the transformations defined in the QVT-Operational file. |
1305 |
Sat, 03 December 2022 12:08 By: Christopher Gerking |
Disjunction and inheritance |
2626 |
Mon, 25 April 2022 11:43 By: Christopher Gerking |
Access existing objects |
1329 |
Thu, 07 April 2022 19:01 By: Christopher Gerking |
Change value of ENum attribute depending on type of class |
1502 |
Thu, 10 March 2022 19:36 By: Ed Willink |
Wrong output model structure |
1358 |
Tue, 08 March 2022 16:46 By: Ed Willink |
Conditional mappings |
936 |
Mon, 07 March 2022 15:20 By: Christopher Gerking |
Qualified name of reference |
1336 |
Fri, 25 February 2022 16:39 By: Christopher Gerking |
Mono and multi valued attributes |
1402 |
Tue, 22 February 2022 11:32 By: Christopher Gerking |
Replace conditional statements with queries |
2482 |
Tue, 22 February 2022 10:57 By: Christopher Gerking |
Modeltype metamodel |
1980 |
Thu, 03 February 2022 18:58 By: Ed Willink |
[QVTo] Can a constructor call another constructor? |
1257 |
Wed, 02 February 2022 13:23 By: Ed Willink |
Can black-box library use metamodel from workspace? |
3417 |
Mon, 10 January 2022 19:03 By: Ed Willink |
how to transform a bidirectional relationship? |
1377 |
Wed, 29 December 2021 20:08 By: Ed Willink |
When to use . and -> |
1410 |
Thu, 16 December 2021 12:34 By: Ed Willink |
Autocomplete window colors in dark theme |
3062 |
Thu, 16 December 2021 10:41 By: Denis Nikiforov |
QVTo disjunct operation on abstract mappings |
1867 |
Mon, 29 November 2021 16:33 By: Christopher Gerking |
Compiled output A way for compiling and load/save processed compiler output |
1177 |
Mon, 29 November 2021 15:14 By: Christopher Gerking |
Element is not transformed inside its container |
2132 |
Mon, 22 November 2021 08:45 By: Christopher Gerking |
Compiling performance Poor compiling performance |
1505 |
Mon, 15 November 2021 08:54 By: Fabio Popcorn |
Create new element in target model |
1395 |
Wed, 03 November 2021 08:05 By: Christopher Gerking |
Can we map two abstract classes? |
1488 |
Mon, 01 November 2021 19:46 By: Christopher Gerking |
Only recognise the first model type |
1940 |
Mon, 18 October 2021 07:22 By: Christopher Gerking |
Support of metamodels referencing other metamodels |
3327 |
Fri, 18 June 2021 15:14 By: Christopher Gerking |
M2M trasformation hel about MoWebA approach I'm looking for experts about M2M trasformation with QVT operational mappings language |
1248 |
Mon, 14 June 2021 17:00 By: Ed Willink |
Problems with color themes in Eclipse Strange behaviour of color themes settings in Eclipse |
6490 |
Fri, 30 April 2021 11:53 By: Antonio Cicchetti |
Define infix arithmetic operations for a custom class |
1056 |
Tue, 06 April 2021 12:45 By: Ed Willink |
QVTo correct map references |
1338 |
Sun, 07 March 2021 15:35 By: Ed Willink |
QVTo apply stereotype |
1292 |
Sat, 06 March 2021 13:32 By: Ed Willink |
allSubobjectsOfType works with some types. |
2105 |
Mon, 01 February 2021 09:36 By: Ed Willink |
QVTo transformation from command line |
6672 |
Fri, 13 November 2020 19:00 By: Ed Willink |
Multiple source objects to single target object |
2678 |
Fri, 13 November 2020 16:17 By: pere joseph rodríguez |
Create references between models |
1461 |
Fri, 13 November 2020 15:31 By: pere joseph rodríguez |
Compilation errors found in unit when calling QVTo transform calling QVTo transform from standalone java |
3854 |
Tue, 18 August 2020 11:33 By: Christopher Gerking |
Could not find unit 'platform:/resource QVTO Transformation |
3385 |
Tue, 18 August 2020 11:25 By: Christopher Gerking |
Adding EAttributes to EStructuralfeatures |
37853 |
Tue, 18 August 2020 11:18 By: Christopher Gerking |
[QVTo] No constructor defined, using implicit constructor |
1033 |
Tue, 18 August 2020 09:09 By: Francesco Bedini |
Problems when applying UML profile to an UML model Profiling and stereotyping an UML model |
10528 |
Fri, 13 September 2019 20:49 By: Ed Willink |
UML activity diagram to Simulink |
37107 |
Fri, 13 September 2019 20:40 By: Ed Willink |
Executing query standalone mode and retrieve results Get empty List |
23290 |
Sun, 04 August 2019 03:26 By: Daniel San Martín |
Announce QVTo 3.9.2 |
18475 |
Wed, 20 March 2019 15:21 By: Ed Willink |
Eclipse QVTo latest P2 repos |
2689 |
Tue, 04 December 2018 07:05 By: Ed Willink |
Error while generating Diagram Editor Gen Model in Luna SR2 |
3465 |
Mon, 12 November 2018 09:10 By: Ed Willink |
Announce QVTo 3.9.0 |
5684 |
Wed, 19 September 2018 15:32 By: Ed Willink |
[QVTo] How to mapp association between two classes |
6406 |
Mon, 17 September 2018 07:10 By: Ed Willink |
creating operation parameters creating operation parameters with ParameterDirectionKind return |
2261 |
Thu, 06 September 2018 17:19 By: Ed Willink |
2320 |
Thu, 06 September 2018 14:51 By: Siegfried Nolte |
About Family2Person Transformation |
4703 |
Fri, 13 July 2018 08:03 By: ashrafur rahman |
Using QVTo with Xtext |
4406 |
Wed, 25 April 2018 10:55 By: Ed Willink |
How to use an external class as a black-box library? |
3091 |
Sat, 14 April 2018 14:38 By: Denis Nikiforov |
generating .qvtotrace file fails when i try to run the operational QVT Project it goes wrong with the following errors |
5928 |
Tue, 03 April 2018 10:04 By: Ed Willink |
a wrong with qvt When I new a *.qvto file , it goes wrong |
4668 |
Fri, 30 March 2018 08:47 By: wang shiyu |
How to import a library |
3593 |
Fri, 23 March 2018 14:28 By: Ed Willink |
Running a QVT transformation headless or from JUnit Running a QVT transformation headless or from JUnit |
2383 |
Wed, 21 March 2018 10:18 By: Ed Willink |
QVTO - Calling a mapping versus clone Calling a mapping versus clone |
2490 |
Thu, 15 March 2018 09:37 By: Bruce Trask |
Basic syntax question in mapping Basic syntax question in mapping |
3005 |
Wed, 14 March 2018 12:50 By: Ed Willink |
Documentation for QVTO Documentation for QVTO |
7589 |
Tue, 13 March 2018 14:22 By: Bruce Trask |
How to trigger XMI transformation in programed java EMF, QVT, Ecore |
3840 |
Fri, 28 July 2017 17:07 By: Ed Willink |
EMF to EMF Transformation Creating custom EClass objects |
3790 |
Wed, 28 June 2017 18:03 By: Ed Willink |
apply stereotype on element Problem! I use applySereotype(),but there's no corresponding element. |
11319 |
Thu, 30 March 2017 14:30 By: Siegfried Nolte |
Semantics of xmap on a null value |
3349 |
Mon, 20 February 2017 15:24 By: Ed Willink |
Serialization of QVT-O Traces |
4421 |
Mon, 09 January 2017 09:43 By: Stephan Seifermann |
set XMI id of object during a QVTo transformation |
3356 |
Wed, 04 January 2017 10:48 By: Ed Willink |
Refine profiled model in QVT-OML |
4088 |
Mon, 07 November 2016 16:40 By: Ferdinando Sodano |
How to set tagged values after applying a profile |
3557 |
Tue, 01 November 2016 10:21 By: Ed Willink |
setValue() a Stereotype with another Stereotype |
4911 |
Mon, 31 October 2016 12:57 By: Ferdinando Sodano |
Passing external variables from eclipse External variables in QVTo |
4828 |
Mon, 26 September 2016 20:05 By: Sergey Boyko |
Cannot add stereotypes when launching the QVTo transform programmatically from Java I provide a minimal example to try out. Any help on how to make it work? |
4085 |
Tue, 30 August 2016 08:04 By: Christopher Gerking |
Metemodel registry |
4834 |
Thu, 28 July 2016 05:55 By: Ed Willink |
QVT 1.3 |
4832 |
Wed, 13 July 2016 09:42 By: Ed Willink |
Incremental transformation not working because input traces are ignored |
9793 |
Tue, 05 July 2016 12:47 By: Christian Damus |
Model Abstrction |
3420 |
Fri, 17 June 2016 13:39 By: Laurence Robert |
Mapping reference |
3302 |
Mon, 30 May 2016 09:29 By: Ed Willink |
Use of quotations |
3441 |
Fri, 27 May 2016 21:07 By: Ed Willink |
QVTO - Import Works in 3.4 but not in 3.6 |
5792 |
Sun, 22 May 2016 10:23 By: Christopher Gerking |
Difference between arrow(->) and dot(.) in qvto |
3396 |
Fri, 13 May 2016 13:24 By: Ed Willink |
Qvt Simple Question Error solving |
3325 |
Tue, 10 May 2016 16:21 By: Ed Willink |
Generate QVTo-file |
8009 |
Tue, 05 April 2016 13:22 By: Uwe Ritzmann |
Cannot find imported compilation unit |
8328 |
Fri, 18 March 2016 15:01 By: Christopher Gerking |
BlackBox: can not find .class files even in neon (qvt 3.5) |
6438 |
Fri, 18 March 2016 14:55 By: Christopher Gerking |
QVT to attach elements as children to a root element |
5082 |
Tue, 01 March 2016 18:52 By: Ed Willink |
[QVTo] How to load separated (externalized) profile applications in QVTo transformations ? |
6434 |
Tue, 09 February 2016 20:23 By: Toni Siljamäki |
QVTo standalone: EMF package registries w/o maven/testng? By: Eclipse User on Thu, 28 January 2016 |
10895 |
Tue, 09 February 2016 14:46 By: Eclipse User |
Keeping xmi:id for migration |
4166 |
Fri, 08 January 2016 17:35 By: Ed Willink |
[QVTo] Transform an object by a condition. |
4992 |
Fri, 08 January 2016 10:52 By: Ed Willink |
QVTo Trace Editor doesn't show properties of elements |
3400 |
Tue, 15 December 2015 13:45 By: Ed Willink |
Implicit conversion of string literals into instances of custom data types |
6371 |
Wed, 09 December 2015 14:29 By: Ed Willink |
bpmn2uml |
4847 |
Thu, 26 November 2015 14:30 By: Srdjan Tica |
Run multiple transformations in parallel |
3332 |
Wed, 25 November 2015 14:56 By: Ed Willink |
Modified parameter 'self' is input only |
3518 |
Mon, 23 November 2015 13:44 By: Christopher Gerking |
Tracing QVT interpreter Tracing QVT interpreter |
3146 |
Thu, 05 November 2015 14:59 By: Ed Willink |
Installing QVTo 3.5 on Eclipse Kepler |
5571 |
Sat, 31 October 2015 19:18 By: Ed Willink |
RAP in combination with QVT (com.ibm.icu issue) |
5136 |
Fri, 09 October 2015 09:48 By: Karel Gardas |
QVTo object serialization manipulating QVT Operational object |
2764 |
Tue, 15 September 2015 20:30 By: Ed Willink |
QVTo Abstract Syntax Tree Fetch I want to fetch the AST |
2556 |
Thu, 27 August 2015 13:52 By: Ed Willink |
Mapping of classes N to 1 |
9219 |
Thu, 20 August 2015 12:37 By: Abhishek Kappattanavar |
Javadocs Are the QVTo Javadocs available? |
2977 |
Wed, 19 August 2015 13:17 By: Gunnar Teege |
[QVTo] Transform a unique element of the model I need to conserve all the model structure but transform one element only. |
10345 |
Thu, 06 August 2015 14:38 By: Gonzalo Bressan Zuber |
[QVTo] Mapping that needs to modify initial Model I am having troubling figuring out how to make a mapping function that needs to create dependencies which did not exist on the initial metamodel |
2905 |
Thu, 23 July 2015 16:03 By: João Bastos |
objectsOfType problem in Mars release |
3492 |
Sat, 27 June 2015 05:49 By: Ed Willink |
Run qvto transformation I need run a transformation |
3844 |
Sat, 27 June 2015 05:41 By: Ed Willink |
Map one object into two models |
4470 |
Thu, 25 June 2015 08:11 By: Denis Nikiforov |
Blackbox library in a standalone QVTo transformation |
10491 |
Thu, 25 June 2015 05:29 By: Denis Nikiforov |
java M2MT I nedd transform a java model in another java model |
5959 |
Fri, 19 June 2015 13:13 By: Gonzalo Bressan Zuber |
Java model transformation with qvto Transform a java models |
4108 |
Fri, 12 June 2015 08:39 By: Ed Willink |
Call qvto in Java : applyStereotype() does not work |
3780 |
Fri, 29 May 2015 08:24 By: Thanh Liem Phan |
intermediate classes in library? |
6761 |
Wed, 27 May 2015 14:14 By: Ed Willink |
Transformation via Java class: Import Library? |
4768 |
Wed, 27 May 2015 13:14 By: Christopher Gerking |
applyStereotype() and using uml stereotype bug resolved but still not working as expected ... Is there any example to show the correct way of using uml stereotype |
5193 |
Tue, 26 May 2015 06:26 By: Thanh Liem Phan |
QVTo Trying to convert EDate into DateTime (XMLGregorianCalendar)) |
5661 |
Thu, 07 May 2015 13:17 By: Christopher Gerking |
library or example for good logging |
3870 |
Tue, 05 May 2015 07:53 By: Thomas Busch |
template function in QVT? |
3766 |
Tue, 05 May 2015 07:41 By: Thomas Busch |
transformation to adopt on metamodel-change? |
5292 |
Mon, 04 May 2015 06:28 By: Thomas Busch |
UML Tool + QVT An integration between UML Tool and QVT |
7582 |
Thu, 16 April 2015 11:04 By: eunjung park |
Sequence Diagrams Repository |
4270 |
Sat, 11 April 2015 19:02 By: Andreza Mising name |
Execute QVTo transformation using a product configuration |
4004 |
Fri, 10 April 2015 08:01 By: Carlos Gomez |
QVT 1.2 |
2934 |
Fri, 27 February 2015 16:24 By: Ed Willink |
determinism on QVTo execution |
3629 |
Wed, 28 January 2015 10:26 By: Thomas Busch |
Compilation errors found when running a transformation inside the jboss container |
5225 |
Mon, 26 January 2015 13:04 By: Christopher Gerking |
handling of abstract types |
3702 |
Wed, 17 December 2014 16:40 By: Daniele Pala |
Including UML primitive types in result of transformation |
3437 |
Tue, 02 December 2014 18:11 By: Ed Willink |
Storing and loading .qvtox A problem in loading previously stored .qvtox files |
8345 |
Mon, 24 November 2014 13:06 By: Trajche Masinov |
Transform qvto file standalone |
4626 |
Tue, 11 November 2014 13:47 By: Ed Willink |
Error while generating Diagram Editor Gen Model |
6578 |
Thu, 06 November 2014 12:52 By: Christopher Gerking |
QVT standard library extension |
4207 |
Thu, 16 October 2014 10:55 By: Ed Willink |
Build with Jenkins |
3372 |
Wed, 08 October 2014 20:58 By: Lindung Manik |
Running QVTo in a web-based application |
4074 |
Mon, 08 September 2014 11:00 By: Ed Willink |
Dynamic set of input models |
6863 |
Mon, 08 September 2014 08:03 By: Sama Elrawy |
Run exported transformation |
4127 |
Thu, 31 July 2014 07:35 By: Rolf Theunissen |
How to evaluate OCL expression that is part of the input model |
4683 |
Tue, 29 July 2014 15:29 By: Wilbert Alberts |
Obtain URI from evaluation environment in RC4 |
4054 |
Fri, 13 June 2014 12:36 By: Sergey Boyko |
How to use QVTo transformation |
3069 |
Thu, 12 June 2014 09:51 By: Ed Willink |
Use of Libraries in different Projects |
6713 |
Thu, 01 May 2014 16:00 By: Christine Gerpheide |
Error with abstract mapping with lastest version of QVTo |
5091 |
Fri, 18 April 2014 06:43 By: Sergey Boyko |
I want to give you a QVTo test coverage plugin |
4194 |
Wed, 16 April 2014 21:35 By: Christine Gerpheide |
Change in Helper/Mapping behaviour from QVTO 3.2.2 to 3.3.0 |
7332 |
Tue, 25 March 2014 13:36 By: Gunnar Teege |
Pass a type as an argument |
3041 |
Thu, 20 March 2014 09:41 By: Ed Willink |
Swapping out EvaluationVisitor to add instrumentation (dependency injection...?) |
7410 |
Wed, 19 March 2014 19:53 By: Sergey Boyko |
Adding qvto editor in RCP application |
6153 |
Wed, 12 March 2014 15:40 By: ModelGeek Mising name |
helper with side effect in QVT - OML helper with side effect in QVT - OML |
4251 |
Wed, 12 March 2014 07:38 By: Sergey Boyko |
Running qvto Transformations with in/out Metamodels registered by Metamodel-Plugins |
4199 |
Mon, 10 March 2014 15:39 By: Ed Willink |
Research survey to improve quality of QVTo code Please consider contributing if you have experience in QVTo |
3413 |
Sun, 09 March 2014 10:57 By: Christine Gerpheide |
Invalid transformation Problem |
8157 |
Mon, 03 March 2014 15:49 By: ModelGeek Mising name |
Transformations chaining for inout model passing the updated model (inout) in calling another transformation |
7092 |
Thu, 27 February 2014 14:45 By: Sergey Boyko |
QVTo code samples for project Have any transformations lying around? |
23709 |
Tue, 18 February 2014 10:35 By: Christine Gerpheide |
Input model to be used by Operational QVT Interpreter By: Eclipse User on Wed, 29 August 2012 |
5797 |
Tue, 18 February 2014 10:15 By: ModelGeek Mising name |
Unit testing tools for QVTo? |
8541 |
Tue, 18 February 2014 09:24 By: Christine Gerpheide |
Failed to save model to platform:/resource Error while running a qvto transformation |
6750 |
Sun, 16 February 2014 18:00 By: Ed Willink |
Stereotype not applied to the xmi output file ! applyStereotype() does not really apply/add stereotype to the output xmi file even getAppliedStereotypes() return correct result |
19340 |
Fri, 14 February 2014 01:50 By: Naif Mokhayesh |
Setting a configuration property from Java |
7528 |
Tue, 28 January 2014 07:57 By: nicholas pacini |
Transforming two model instances into a single model instance Parameter passing QVTO |
6868 |
Thu, 23 January 2014 16:53 By: Ed Willink |
Posible enhacements in the QVT code |
10697 |
Wed, 08 January 2014 18:19 By: Victor Roldan Betancort |
Plz help me [ QVT Relational] |
3532 |
Fri, 03 January 2014 14:49 By: Ed Willink |
goal for new objects in a transformation |
8071 |
Thu, 02 January 2014 07:44 By: Ed Willink |
Execute native OCL query in qvt-o code |
18119 |
Sun, 22 December 2013 16:35 By: Ed Willink |
OCL Errors in StandAlone QVTo |
6171 |
Fri, 13 December 2013 15:36 By: Ed Willink |
How to create javax.xml.namespace.QName? |
36196 |
Fri, 13 December 2013 05:45 By: Denis Nikiforov |
Redirect log to stdout in standalone QVTo-script |
5058 |
Wed, 04 December 2013 04:50 By: Denis Nikiforov |
Does Eclipse QVTo implementation support typedef? |
3208 |
Tue, 26 November 2013 12:15 By: Ed Willink |
Writing it as extension for QVTo in Java Writing it as extension for QVTo in Java |
8416 |
Sun, 24 November 2013 08:27 By: Ed Willink |
one input model and variable number of output models one input model and variable number of output model |
4177 |
Tue, 29 October 2013 07:17 By: Ed Willink |
metamodel declaration & UML profile |
5300 |
Mon, 14 October 2013 07:14 By: BaiChuan Nie |
Creating objects in secondary extents |
9241 |
Mon, 23 September 2013 10:07 By: Vlad Gheorghe |
Retrivieving stereotypes tagged values |
4801 |
Wed, 04 September 2013 09:10 By: saadia dhouib |
Problem with Stereotype application Problem with Stereotype application |
7640 |
Mon, 02 September 2013 09:59 By: Ed Willink |
Ideas for higher-order in QVTo |
5451 |
Sat, 20 July 2013 21:50 By: Christopher Gerking |
Object type issues can't resolve objects from type |
3523 |
Wed, 10 July 2013 18:05 By: lin zhang |
Shortcut for subpackages? |
5582 |
Mon, 08 July 2013 15:19 By: Ed Willink |
Applying Stereotype to model element |
7625 |
Tue, 18 June 2013 10:06 By: Thorsten Koch |
Can a mapping call itself? By: Emre T on Mon, 03 June 2013 |
5417 |
Mon, 17 June 2013 11:04 By: Christopher Gerking |
Libraries necessary to execute transformation programmatically in Juno |
6592 |
Thu, 13 June 2013 20:17 By: juan velez |
[Announce] Eclipse QVT Operational 3.3.0 (Kepler) RC3 is now available |
7900 |
Tue, 04 June 2013 10:09 By: Ed Willink |
Manual transformation vs. programmatic transformation By: Emre T on Mon, 03 June 2013 |
5120 |
Mon, 03 June 2013 14:40 By: Ed Willink |
Jumping over abstract model elements of source By: Emre T on Fri, 31 May 2013 |
11214 |
Sat, 01 June 2013 00:23 By: Alan McMorran |
A case scenario regarding the selection of mappings based on composed model elements By: Emre T on Thu, 30 May 2013 |
11742 |
Sat, 01 June 2013 00:14 By: Alan McMorran |
how to use two target sources? By: Emre T on Mon, 27 May 2013 |
6807 |
Thu, 30 May 2013 22:49 By: Emre T |
Stereotypes and multi-valued attributes Can't get the value of a multi-valued attribute defined in a Stereotype |
12790 |
Sun, 26 May 2013 08:48 By: Sergey Boyko |
Generalization relationship between stereotypes |
10329 |
Sat, 25 May 2013 22:08 By: Sergey Boyko |
[Announce] Eclipse QVT Operational 3.3.0 (Kepler) RC1 is now available |
38843 |
Tue, 21 May 2013 14:39 By: Ed Willink |
QVT project organization |
7346 |
Wed, 15 May 2013 14:56 By: Ed Willink |
Accessing stereotypes defined in SysML profiles with packages ERROR: stereotype XXX::YYY::ZZZ is not applicable to element org.eclipse.uml2.uml.internal.impl.PortImpl@... |
7731 |
Wed, 15 May 2013 12:05 By: Matteo M. |
[Announce] Eclipse QVT Operational 3.3.0 (Kepler) M7 is available |
3089 |
Wed, 08 May 2013 09:41 By: Adolfo Sanchez-Barbudo Herrera |
3064 |
3441 |
3174 |
4033 |
3188 |
3127 |
