Search disabled
The Search function of this forum has been disabled, as it is currently the target of abuse. We apologize for the inconvenience.
Forums will be read only after December 31st,2024
After 10 years of discussion and planning[1], these forums have been declared end of life, and will be replaced with a static read only copy on December 31, 2024. [1]https://gitlab.eclipse.org/eclipsefdn/helpdesk/-/issues/187
  ATL Error "mismatched input '(' expecting SEMI"
By: jouini fatma on Tue, 05 November 2024
1 430 Tue, 05 November 2024 22:09
By: Dennis Wagelaar
  x.resolve('rule_name') vs thisModule.rule_name(x)
By: Yves BERNARD on Tue, 15 October 2024
4 1427 Fri, 18 October 2024 12:23
By: Yves BERNARD
  Accessing inherited tag values from applied stereotypes
By: Yves BERNARD on Thu, 03 November 2022
10 5394 Mon, 14 October 2024 14:16
By: Yves BERNARD
  Containers deletion in Refinement mode
By: Yves BERNARD on Thu, 12 September 2024
12 2772 Mon, 30 September 2024 07:40
By: Yves BERNARD
  Issue with cached Helpers
Duplicate Entry exception with Association Classes
By: Yves BERNARD on Tue, 22 August 2023
6 3486 Thu, 12 September 2024 13:55
By: Yves BERNARD
  ATL 4.10.0 released
By: Dennis Wagelaar on Mon, 24 June 2024
2 984 Tue, 25 June 2024 17:13
By: Dennis Wagelaar
  Listing inputs models
By: Yves BERNARD on Tue, 04 June 2024
2 1388 Fri, 21 June 2024 06:42
By: Yves BERNARD
  OCL closure operation
By: Yves BERNARD on Wed, 01 June 2022
17 8601 Fri, 21 June 2024 06:30
By: Yves BERNARD
  Working with profiles as metamodels
By: Yves BERNARD on Tue, 14 May 2024
7 2927 Mon, 10 June 2024 10:20
By: Dennis Wagelaar
  Bug in the ATL editor?
1 910 Sun, 09 June 2024 15:32
By: Dennis Wagelaar
  Some created elements are not serialized
What can prevent it?
By: Yves BERNARD on Wed, 07 February 2024
2 1122 Tue, 13 February 2024 16:23
By: Yves BERNARD
  How do I get the runtime of a model transformation?
By: Hongbin Xiao on Mon, 29 January 2024
1 6636 Wed, 07 February 2024 20:04
By: Dennis Wagelaar
0 6437 Mon, 29 January 2024 06:35
By: Hongbin Xiao
  ATL 4.8.0 released
By: Dennis Wagelaar on Mon, 26 June 2023
4 1737 Thu, 04 January 2024 07:34
By: Yves BERNARD
  Applying Profiles in ATL: applyStereotype and applyProfile
Applying Profiles in ATL: how to use applyStereotype and applyProfile?
By: Giulia Pascale on Wed, 22 November 2023
9 2754 Wed, 13 December 2023 21:26
By: Dennis Wagelaar
  ATL: How can I insert a class into another class using ATL?
How can I insert a class into another class using ATL? How to use Feature package, packagedElement?
By: Giulia Pascale on Fri, 24 November 2023
1 891 Tue, 28 November 2023 12:28
By: Dennis Wagelaar
  ATL rules doesn't match
ATL matched rules
By: Giulia Pascale on Sat, 04 November 2023
4 1662 Wed, 08 November 2023 15:57
By: Giulia Pascale
  Assigning values to a Map owned by a target element
creation of an EAnnotation
By: Yves BERNARD on Mon, 04 September 2023
3 1156 Fri, 15 September 2023 08:29
By: Yves BERNARD
  How to run ATL transformation programmatically
move our of the Eclipse Cocoon for ATL Model-2-model transformations
By: Vladimir Estivill-Castro on Wed, 23 October 2019
5 3271 Thu, 06 July 2023 17:41
By: Dennis Wagelaar
  Bug in default trace resolution?
In that case the default trace cannot be resolved. What is wrong?
By: Yves BERNARD on Thu, 20 October 2022
12 5792 Sat, 13 May 2023 06:07
By: Dennis Wagelaar
  Setting a multi-valued tagged value
By: Yves BERNARD on Mon, 17 April 2023
3 1497 Wed, 19 April 2023 06:35
By: Yves BERNARD
  Sharing a library module over several projects
Where to find a complete ATL syntax reference?
By: Yves BERNARD on Wed, 05 April 2023
3 1048 Wed, 05 April 2023 17:01
By: Dennis Wagelaar
  Trace Model ATL
How to get trace model for a model transformation execution
By: Juri Di Rocco on Tue, 04 April 2023
1 720 Tue, 04 April 2023 16:51
By: Dennis Wagelaar
  Conditional Breakpoints in ATL?
By: Bert Bert on Wed, 22 March 2023
2 1250 Thu, 23 March 2023 09:41
By: Bert Bert
  Transformation parameters
By: Yves BERNARD on Fri, 10 February 2023
4 1789 Fri, 17 March 2023 13:21
By: Yves BERNARD
  Is it possible to increment and store a variable in helper context declerative part?
By: Burak Karaduman on Sat, 25 June 2022
8 3527 Sun, 04 December 2022 20:16
By: Dennis Wagelaar
  How to collect all of the iteration results?
By: Burak Karaduman on Sun, 04 December 2022
1 749 Sun, 04 December 2022 18:49
By: Burak Karaduman
  Does the regexReplaceAll operation work?
By: Yves BERNARD on Fri, 09 September 2022
1 1040 Fri, 09 September 2022 07:41
By: Yves BERNARD
  helper context overlap for base data types?
By: Gunnar Arndt on Mon, 25 July 2022
7 3866 Wed, 17 August 2022 15:45
By: Dennis Wagelaar
  How can I tranform a feature of the Parent class accessing from the chield class?
By: Burak Karaduman on Mon, 11 July 2022
1 4378 Mon, 25 July 2022 13:55
By: Gunnar Arndt
  [ATL] Library in EMFTVM launch config?
How to load a library required by a module in an EMFTVM launch configuration?
By: Gunnar Arndt on Thu, 05 December 2013
6 5318 Mon, 25 July 2022 13:30
By: Gunnar Arndt
  Collecting all instances and calculating the values
By: Burak Karaduman on Thu, 02 June 2022
6 6517 Sun, 03 July 2022 09:01
By: Burak Karaduman
  Accessing referring elements?
By: Burak Karaduman on Wed, 22 June 2022
2 18799 Sun, 03 July 2022 08:52
By: Burak Karaduman
  Is this an ATL bug?
By: M M on Thu, 09 June 2022
5 2691 Thu, 23 June 2022 13:34
By: M M
  How to reference external modules?
By: Yves BERNARD on Fri, 03 June 2022
2 4676 Fri, 10 June 2022 05:58
By: Yves BERNARD
  ATL Helper Context Assignment
By: Burak Karaduman on Wed, 01 June 2022
6 3729 Thu, 09 June 2022 17:13
By: Dennis Wagelaar
  Default value serialization in XMI
2 3594 Sat, 04 June 2022 14:38
By: Dennis Wagelaar
  Create target UML Association with conditions
By: Ivy Tran on Thu, 02 June 2022
2 3899 Fri, 03 June 2022 04:26
By: Ivy Tran
  Strange error with the __xmiID__ field
By: Yves BERNARD on Tue, 22 February 2022
4 2861 Thu, 28 April 2022 15:52
By: Yves BERNARD
  How to print output of ATL programs to eclipse console
By: Lavya Thippabathini on Mon, 25 April 2022
1 1377 Mon, 25 April 2022 19:10
By: Dennis Wagelaar
  About stereotype management
Change request
By: Yves BERNARD on Fri, 01 April 2022
3 1439 Mon, 18 April 2022 19:43
By: Dennis Wagelaar
  Execution Time of ATL transformations
By: Qurat ul ain Ali on Mon, 11 April 2022
1 2258 Thu, 14 April 2022 21:05
By: Dennis Wagelaar
  About ATL engine
By: Yanhong Dong on Tue, 01 March 2022
13 10299 Fri, 18 March 2022 01:42
By: Yanhong Dong
  Does eclipse still support the AMMA platform?
By: qiaosen liu on Mon, 14 March 2022
2 2330 Tue, 15 March 2022 06:18
By: qiaosen liu
  About using JAVA call ATL engine
By: Yanhong Dong on Mon, 07 March 2022
0 4511 Mon, 07 March 2022 11:52
By: Yanhong Dong
  ATL question
By: Yanhong Dong on Thu, 24 February 2022
1 2924 Tue, 01 March 2022 20:19
By: Dennis Wagelaar
  how to use lazy rule to output various value
By: Yanhong Dong on Wed, 23 February 2022
2 2421 Thu, 24 February 2022 08:57
By: Yanhong Dong
  how to generate emftvm file
By: Yanhong Dong on Mon, 21 February 2022
5 3573 Wed, 23 February 2022 18:03
By: Dennis Wagelaar
  Applying Profiles and stereotypes
Custom and Standard Profile
By: Yves BERNARD on Fri, 21 January 2022
2 2248 Fri, 28 January 2022 07:38
By: Yves BERNARD
  Wrong Uris in the target model
By: Torben Eckwert on Thu, 06 January 2022
2 1989 Mon, 10 January 2022 15:45
By: Torben Eckwert
  String express
how to express '&'
By: Yanhong Dong on Mon, 27 December 2021
1 1432 Tue, 28 December 2021 18:11
By: Dennis Wagelaar
  Using metamodels expressed in UML
Supported formalism for metamodels
By: Yves BERNARD on Tue, 14 December 2021
2 1313 Tue, 14 December 2021 17:53
By: Yves BERNARD
  Call the ATL engine
By: Yanhong Dong on Tue, 07 December 2021
1 1901 Thu, 09 December 2021 21:01
By: Dennis Wagelaar
  enabling "inter-model references" when running ATL emftvm transformations
A solution t enable "inter-model references" when running an ATL transformation using emftvm
By: nour nour on Sat, 27 November 2021
3 2032 Mon, 29 November 2021 14:39
By: Dennis Wagelaar
  question about ATL
By: Yanhong Dong on Tue, 09 November 2021
2 1670 Wed, 17 November 2021 11:13
By: Yanhong Dong
  ATL automatic transformation of multiple input models into multiple output models at the same time
run multiple ATL transformations on different input models to produce different output models at the same time automatically
By: nour nour on Mon, 01 November 2021
1 891 Mon, 01 November 2021 17:56
By: Dennis Wagelaar
  ATL 4.5.0 release
ATL 4.5.0 has been released yesterday!
By: Dennis Wagelaar on Tue, 19 October 2021
0 2540 Tue, 19 October 2021 19:00
By: Dennis Wagelaar
  Enumeration literal and reserved words
How to refer to enumeration literals that have names matching reserved words?
By: Yves BERNARD on Wed, 13 October 2021
3 2078 Fri, 15 October 2021 16:00
By: Yves BERNARD
  ATL question
Unable to get the desired file
By: Yanhong Dong on Mon, 04 October 2021
1 28018 Tue, 12 October 2021 20:16
By: Dennis Wagelaar
  ATL question
0 28181 Mon, 04 October 2021 02:50
By: Yanhong Dong
  ATL String handling issues
How to express that two strings are not equal?
By: Yanhong Dong on Tue, 28 September 2021
3 1593 Wed, 29 September 2021 18:26
By: Dennis Wagelaar
  ATL question
How to access each element in the sequence in turn
By: Yanhong Dong on Sun, 26 September 2021
2 1363 Tue, 28 September 2021 13:01
By: Yanhong Dong
  References to enumerations defined in a profile
By: Yves BERNARD on Fri, 03 September 2021
2 1004 Fri, 03 September 2021 20:07
By: Yves BERNARD
  Issue with assignment of a String
By: Yves BERNARD on Fri, 27 August 2021
4 1905 Fri, 03 September 2021 09:30
By: Yves BERNARD
  ATL to ATL transformation: Order of source elements is getting changed in the output transformation
By: Nour Gritli on Fri, 27 August 2021
1 1133 Sat, 28 August 2021 10:10
By: Dennis Wagelaar
  GUIDE ATL
use ATL
By: Billal LETTIFI on Tue, 25 May 2021
10 2731 Fri, 04 June 2021 16:22
By: Dennis Wagelaar
  Executing ATL Launcher with 2 MetaModels as input
By: Zr Sami on Tue, 06 April 2021
2 1587 Tue, 25 May 2021 09:51
By: Zr Sami
  mutual calling relationship
By: 永祺 卜 on Mon, 17 May 2021
1 1461 Tue, 18 May 2021 16:03
By: Dennis Wagelaar
  ATL 4.4.0 release
By: Dennis Wagelaar on Tue, 04 May 2021
0 4850 Tue, 04 May 2021 14:33
By: Dennis Wagelaar
  An ATL Freelancer
By: Mona Jammal on Wed, 17 August 2016
1 5749 Sun, 02 May 2021 20:29
By: ionel stefanuca
  Compilation of rule
By: jo ber on Fri, 23 April 2021
1 1355 Sat, 24 April 2021 21:03
By: Dennis Wagelaar
  Null-safe navigator operator
By: jo ber on Thu, 15 April 2021
4 1302 Fri, 16 April 2021 20:32
By: jo ber
  Listing Format of ATL Rules in Latex
What is the language name?
By: Mohammed Hamdi on Wed, 14 April 2021
2 1582 Thu, 15 April 2021 22:25
By: Mohammed Hamdi
  Source attachment
By: jo ber on Sat, 10 April 2021
1 886 Sat, 10 April 2021 13:35
By: Dennis Wagelaar
  Calling EMFTVM programmatically error
By: Rafael Durelli on Mon, 11 May 2015
11 9453 Tue, 06 April 2021 12:08
By: Zr Sami
  Mapping large source model
best practice
By: jo ber on Wed, 17 March 2021
8 2552 Wed, 31 March 2021 07:34
By: jo ber
  Public2Private Example
How to run it?
By: Mohammed Hamdi on Mon, 22 March 2021
3 1356 Wed, 24 March 2021 22:50
By: Mohammed Hamdi
  Potential bug with resolveTemp()
it may generate RTE depending on where it is located
By: Yves BERNARD on Wed, 24 March 2021
1 767 Wed, 24 March 2021 20:00
By: Dennis Wagelaar
  Redefinitions in an extending rule
By: Yves BERNARD on Wed, 17 February 2021
2 1278 Wed, 17 March 2021 15:23
By: Yves BERNARD
  Set Real to NaN
By: Gunnar Arndt on Fri, 26 February 2021
2 1044 Tue, 02 March 2021 15:45
By: Gunnar Arndt
  org.eclipse.m2m.atl.engine.emfvm.VMException
exception raise while running an atl file
By: shehla zeb on Mon, 17 March 2014
3 4659 Mon, 01 March 2021 10:18
By: Nada Stitou
  ATL 4.3.0 release
By: Dennis Wagelaar on Sun, 07 February 2021
1 14566 Mon, 22 February 2021 08:16
By: Dennis Wagelaar
  the Set::-(Set) operation generates a Java exception
t
By: Yves BERNARD on Fri, 12 February 2021
4 4339 Sun, 14 February 2021 17:17
By: Yves BERNARD
  Java API information
Looking for javadoc
By: Yves BERNARD on Mon, 11 January 2021
2 1305 Fri, 12 February 2021 17:57
By: Yves BERNARD
  ATL to EMFTVM migration problems
By: Burak Karaduman on Sat, 26 December 2020
2 1368 Mon, 11 January 2021 18:27
By: Burak Karaduman
  Module and Library inclusion problem
One of the included module cannot include additional library.
By: Burak Karaduman on Fri, 25 December 2020
3 1390 Wed, 30 December 2020 19:25
By: Burak Karaduman
  One-to-many with 0..1 cardinality possible?
By: Burak Karaduman on Wed, 23 December 2020
2 1222 Thu, 24 December 2020 20:23
By: Burak Karaduman
  Multiple ATL files to Single XMI file output possible?
By: Burak Karaduman on Sat, 05 December 2020
4 1623 Thu, 10 December 2020 13:11
By: Burak Karaduman
  Using paths in a "uses" statement
Dealing with tree of modules
By: Yves BERNARD on Mon, 07 December 2020
2 998 Wed, 09 December 2020 07:15
By: Yves BERNARD
  Merging multiple Instance Models
How do you specify multiple instance models as input in ATL
By: Joel Joel on Tue, 22 May 2012
3 9724 Sat, 05 December 2020 12:11
By: Burak Karaduman
  Multiple Metamodel ATL transformation to Single File
By: Burak Karaduman on Mon, 30 November 2020
4 1433 Sat, 05 December 2020 12:11
By: Burak Karaduman
  Can I have two output models from one input model using ATL transformation?
By: zz lalou on Wed, 26 July 2017
4 14947 Tue, 01 December 2020 08:09
By: Dennis Wagelaar
  counting the number of occurences ofan eReference in an ATL transformation
By: nour nour on Sun, 22 November 2020
1 953 Sun, 22 November 2020 15:36
By: Dennis Wagelaar
  transform .atl file to .java file
transform an atl model into java code
1 1210 Sun, 22 November 2020 15:13
By: Dennis Wagelaar
  One model to many with composations ?
By: Burak Karaduman on Sat, 17 October 2020
3 1234 Mon, 19 October 2020 17:31
By: Dennis Wagelaar
  Multiple Input models / metamodels (Model Fusion)
By: Samia Bachir on Tue, 15 September 2020
1 3136 Tue, 29 September 2020 18:45
By: Dennis Wagelaar
  Run refining transformation programatically
By: Andreas Bäuerle on Sun, 23 August 2020
4 1502 Fri, 04 September 2020 14:38
By: Neeraj Bhusare
  [Solved] Using an extended set of primitive ECore types
By: Michael Relby on Thu, 03 September 2020
2 2786 Fri, 04 September 2020 13:49
By: Michael Relby
  Need help with thisModule.resolveTemp(...)
Adapting model to ECore
By: Neeraj Bhusare on Fri, 21 August 2020
2 1457 Thu, 03 September 2020 12:46
By: Neeraj Bhusare
  Select the features to be transformed using if else statements in rules
By: Burak Karaduman on Wed, 12 August 2020
1 1374 Mon, 17 August 2020 12:57
By: Dennis Wagelaar
  Access to UML stereotypes from ATL EMFTVM script...
By: Olivier Hurez-Martin on Sat, 01 February 2020
3 4226 Sat, 15 August 2020 14:58
By: souhila amina
  How to certain rules with entered paramter to an Attribute?
By: Burak Karaduman on Thu, 30 July 2020
2 2545 Wed, 12 August 2020 13:51
By: Burak Karaduman
  ATL Generic Type Helper ?
2 1208 Wed, 12 August 2020 13:51
By: Burak Karaduman
  How to Conditional Transformation in Rules ?
By: Burak Karaduman on Mon, 20 July 2020
3 2664 Tue, 11 August 2020 12:53
By: Burak Karaduman
  Casting in ATL
By: Marshall Charron on Tue, 23 July 2019
3 27043 Tue, 11 August 2020 12:50
By: Burak Karaduman
  Problem with refining mode in ATL (2)
By: Andreas Bäuerle on Mon, 03 August 2020
4 1866 Tue, 04 August 2020 18:49
By: Dennis Wagelaar
0 4851 Mon, 03 August 2020 11:26
By: Andreas Bäuerle
  Value is not legal : ATL Launch Java
ATL Transformation goes through with Launch Configuration, but fails through Java
By: Antonio Oliva on Tue, 23 June 2020
1 2864 Sat, 01 August 2020 14:11
By: Dennis Wagelaar
  Plaintext Children
By: Andreas Bäuerle on Fri, 01 May 2020
2 2184 Sat, 01 August 2020 13:33
By: Dennis Wagelaar
  ATL problem with nested source model
By: Andreas Bäuerle on Mon, 20 April 2020
1 3313 Sat, 01 August 2020 13:28
By: Dennis Wagelaar
  Problem with tags including ":"
By: Andreas Bäuerle on Wed, 08 April 2020
1 5316 Sat, 01 August 2020 13:24
By: Dennis Wagelaar
  if else statment in a rule transformation
By: achraf lyazidi on Tue, 09 July 2013
3 6484 Thu, 30 July 2020 14:45
By: Burak Karaduman
  UTF-8 encoding problem in output
By: Gunnar Arndt on Tue, 02 June 2020
1 4487 Mon, 08 June 2020 14:57
By: Gunnar Arndt
  [ATL /AM3 XML Extractor ]
By: kicha bicha on Tue, 01 October 2013
16 7795 Wed, 06 May 2020 06:00
By: Paul Hernandez
  OWL2XML wrong output
By: Paul Hernandez on Thu, 30 April 2020
1 4726 Tue, 05 May 2020 13:42
By: Paul Hernandez
  Problem with Child and Parent Elements in resulting XMI File
By: Andreas Bäuerle on Tue, 14 April 2020
1 8485 Tue, 21 April 2020 15:47
By: Andon¡ Reteg¡
  Obscure error while saving an output model...
By: Olivier Hurez-Martin on Sun, 22 December 2019
14 9069 Mon, 06 April 2020 13:35
  ATL plugin - stereotype is not applicable error
By: Khoa Nguyen on Tue, 03 September 2019
2 10767 Mon, 16 March 2020 08:14
By: Mubeen Aslam
  [Quick Question] Composition and Referance Difference?
By: Burak Karaduman on Sun, 01 September 2019
2 186847 Sun, 05 January 2020 13:33
By: Burak Karaduman
  ATL 4.2.0 has been released!
By: Dennis Wagelaar on Wed, 18 December 2019
0 3219 Wed, 18 December 2019 18:05
By: Dennis Wagelaar
  Need help with programmatic ATL module loading...
Running into an exception while loading a test ATL EMFTVM module from a standalone Java application.
By: Olivier Hurez-Martin on Tue, 26 November 2019
9 3810 Wed, 04 December 2019 22:18
By: Dennis Wagelaar
  Issue with string comparison in helper...
By: Olivier Hurez-Martin on Wed, 27 November 2019
2 1587 Fri, 29 November 2019 18:18
  executon of atl with java program :Problem with =loading BPMN resource
Program does not load a bpmn model
By: Cristina Redriguez on Sun, 01 July 2018
6 6664 Wed, 13 November 2019 19:23
By: Lucas Pereyra
  atl Sequence
By: Yassmine Gara Hellal on Mon, 23 September 2019
0 10817 Mon, 23 September 2019 14:49
  Multiple source model
By: Yassmine Gara Hellal on Tue, 17 September 2019
0 12416 Tue, 17 September 2019 06:38
  HOT helpers
By: Yassmine Gara Hellal on Fri, 06 September 2019
1 11943 Fri, 13 September 2019 19:26
By: Dennis Wagelaar
  One model to output model with multiple instances?
1 271948 Fri, 06 September 2019 09:33
By: Burak Karaduman
  ATL 4.1.0 has been released!
By: Dennis Wagelaar on Tue, 03 September 2019
0 9937 Tue, 03 September 2019 20:51
By: Dennis Wagelaar
  ATL plugin out with missing xmi:id
By: Khoa Nguyen on Wed, 28 August 2019
2 2830 Tue, 03 September 2019 16:07
By: Khoa Nguyen
  Multiple values for the source pattern
By: Guisella Angulo on Thu, 25 July 2019
2 10085 Sat, 27 July 2019 13:09
By: Guisella Angulo
  [solved] xmi:id and xmi:type tags in SysML
How to transform structural tags of SysML is ATL
By: Hargurbir Singh on Tue, 08 August 2017
2 12907 Sat, 27 July 2019 10:59
By: Dennis Wagelaar
  What is 'var' in resolveTemp(var, target_pattern_name) ?
By: Marshall Charron on Wed, 17 July 2019
1 26515 Sat, 27 July 2019 10:26
By: Dennis Wagelaar
  Use of refInvokeOperation
By: Marshall Charron on Thu, 25 July 2019
1 9872 Sat, 27 July 2019 09:43
By: Dennis Wagelaar
  resolvetemp and Sequence
By: Marshall Charron on Tue, 16 July 2019
7 5445 Sun, 21 July 2019 17:37
By: Dennis Wagelaar
  How to refine a model from another ?
By: Marshall Charron on Thu, 04 July 2019
3 3952 Sun, 07 July 2019 08:38
By: Dennis Wagelaar
  EMFTVM programmatically ?
1 2510 Thu, 04 July 2019 04:54
By: Dennis Wagelaar
  Documentation: __xmiID__
By: jo ber on Tue, 02 July 2019
1 15540 Wed, 03 July 2019 21:12
By: Dennis Wagelaar
  TXT document as input for ATL transformation
Model to model transformation (UML model)
By: Waflaa Green on Wed, 08 May 2019
1 47633 Sun, 30 June 2019 11:11
By: Dennis Wagelaar
  Transforming model elements to model elements with next reference
By: Baris Tekin Tezel on Tue, 14 May 2019
1 49438 Sun, 30 June 2019 11:09
By: Dennis Wagelaar
  Read data from text file
Text file input
By: Waflaa Green on Thu, 16 May 2019
1 42287 Sun, 30 June 2019 10:55
By: Dennis Wagelaar
  extract ATL transformation from ecore model
By: Yassmine Gara Hellal on Thu, 16 May 2019
1 43266 Sun, 30 June 2019 10:52
By: Dennis Wagelaar
  transformation problem (root class)
By: Merlin WANE on Fri, 17 May 2019
1 5479 Sun, 30 June 2019 10:35
By: Dennis Wagelaar
  NoSuchElement exception when programmatically executing transformation
By: G LG on Wed, 05 June 2019
1 38553 Sun, 30 June 2019 10:33
By: Dennis Wagelaar
  Invalid Context error in ATL
By: Marshall Charron on Sun, 02 June 2019
1 46424 Sun, 30 June 2019 10:29
By: Dennis Wagelaar
  Add an element to a sequence
By: Marshall Charron on Fri, 28 June 2019
1 2629 Fri, 28 June 2019 15:22
By: Dennis Wagelaar
  no viable alternative at input...
By: Marshall Charron on Wed, 26 June 2019
2 20320 Fri, 28 June 2019 08:08
  how to get xmi:type of UML in atl rule
the type is OclUndefined
By: Beatus Ding on Fri, 04 January 2013
4 5637 Fri, 31 May 2019 08:28
By: xiaoxiao Yi
By: Yassmine Gara Hellal on Mon, 20 May 2019
1 15375 Thu, 23 May 2019 20:55
By: Dennis Wagelaar
  Match rule returning existing object ?
By: G LG on Wed, 06 March 2019
4 3034 Thu, 16 May 2019 07:21
By: G LG
  HOT transformation examples
By: Yassmine Gara Hellal on Wed, 15 May 2019
1 6472 Thu, 16 May 2019 06:54
By: Dennis Wagelaar
  KM3 uri not found
By: Yassmine Gara Hellal on Tue, 30 April 2019
3 2474 Wed, 15 May 2019 15:49
  Problem collect ATL emftvm
exception error on collect
By: Jérémy Cavron on Mon, 06 May 2019
6 3902 Sun, 12 May 2019 07:55
By: Jérémy Cavron
  How Eclipse resolves URIs ?
By: Marshall Charron on Wed, 08 May 2019
1 9827 Fri, 10 May 2019 06:39
By: Dennis Wagelaar
  Problem Change ATL Class name
How change ATL class name?
By: Jérémy Cavron on Tue, 07 May 2019
2 12353 Thu, 09 May 2019 14:43
By: Jérémy Cavron
  How to reverse an ATL transformation
is it possible to reverse an ATL transformation easily ?!
By: Ali Sardarian on Sun, 05 May 2019
2 4213 Mon, 06 May 2019 17:27
By: Ali Sardarian
  Problem with a simple transformation using EMFTVM
I'm using the Compiler EMFTVM and I can't transform a Model
By: Guisella Angulo on Sat, 27 April 2019
6 9184 Mon, 06 May 2019 08:13
By: Dennis Wagelaar
  computing the time complexity of the atl transformation rules
how computing the time complexity of the atl transformation rules
By: Cristina Redriguez on Fri, 22 March 2019
1 19673 Sun, 28 April 2019 16:13
By: Dennis Wagelaar
  open ATL editor programmatically
By: Banafsheh Azizi on Sun, 07 April 2019
3 15918 Fri, 12 April 2019 13:43
By: Banafsheh Azizi
  Importing a model from a model
By: Marshall Charron on Sun, 17 March 2019
2 6812 Thu, 21 March 2019 08:25
  Using custom Java Methods with emftvm
While using ATL i reached a point where java methods would be helpful, but i get some errors.
By: Tai Ly on Wed, 20 March 2019
1 3659 Wed, 20 March 2019 20:18
By: Dennis Wagelaar
  Group by name (to created Element)
In context of a tree model, I'm asking to group nodes with same name
By: Tai Ly on Mon, 18 February 2019
2 6445 Sun, 10 March 2019 13:31
By: Tai Ly
  Move an element
I need to move an element already created to another instance
By: Cesar Bernabe on Tue, 05 February 2019
2 6035 Thu, 21 February 2019 12:53
By: Cesar Bernabe
  Problem to reference to an existing model
I can´t create a validate model referencing to an other model
By: Sebastian Friedl on Sun, 03 February 2019
1 5317 Sun, 10 February 2019 16:28
By: Dennis Wagelaar
  Create multiple from one
Create multiple elements in output model based on one element from source model
By: Cesar Bernabe on Fri, 07 December 2018
3 2960 Tue, 05 February 2019 12:32
By: Cesar Bernabe
  [ATL] Matching in a called rule
clarification about the language
By: Jeremy Buisson on Wed, 16 January 2019
3 2948 Fri, 25 January 2019 09:06
By: Dennis Wagelaar
  Meaning of '<:='
By: jo ber on Tue, 22 January 2019
1 1839 Tue, 22 January 2019 21:09
By: Dennis Wagelaar
  java.lang.IncompatibleClassChangeError?
By: jo ber on Tue, 15 January 2019
1 1601 Tue, 15 January 2019 17:37
By: jo ber
  Is XMI required to provide model instances?
By: jo ber on Fri, 17 August 2018
1 2973 Sat, 05 January 2019 12:40
By: jo ber
  How to get a .xmi file from .xml?
Problem of ATL getting start
By: zhang xh on Fri, 04 January 2019
2 4622 Sat, 05 January 2019 03:29
By: zhang xh
  allInstances()?
By: jo ber on Thu, 03 January 2019
3 2879 Fri, 04 January 2019 22:05
By: Dennis Wagelaar
  [EMFTVM] Multi-valued field
By: jo ber on Mon, 24 December 2018
1 1822 Mon, 24 December 2018 19:53
By: jo ber
  how to define rules with unique outputs?
By: Faezeh Khorram on Sat, 08 September 2018
1 3860 Mon, 19 November 2018 10:57
By: Dennis Wagelaar
  Using profiles as Metamodels in ATL EMFTVM
By: omar hassane on Mon, 01 October 2018
1 3998 Mon, 19 November 2018 10:50
By: Dennis Wagelaar
  Inject a resource instead of loading it
By: Gunnar Arndt on Thu, 20 September 2018
2 6255 Mon, 19 November 2018 10:37
By: Dennis Wagelaar
  containment in atl
By: annachiara marano on Mon, 12 November 2018
1 4132 Mon, 19 November 2018 10:31
By: Dennis Wagelaar
  DEVS to UPPAL
Model 2 model transformation
By: Kehinde SAMUEL on Mon, 08 October 2018
2 2449 Mon, 22 October 2018 09:05
By: Dennis Wagelaar
  launching has encountered a problem
By: Faezeh Khorram on Tue, 16 October 2018
1 4680 Wed, 17 October 2018 10:23
By: Dennis Wagelaar
  Traceability support in ATL
By: omar hassane on Tue, 09 October 2018
1 3155 Tue, 16 October 2018 04:52
By: Dennis Wagelaar
  BPMN to UPPAAL: problem with the target generated model
By: im hello world on Wed, 19 April 2017
2 32316 Tue, 16 October 2018 04:42
By: Dennis Wagelaar
  ATL EMFTVM no entries available when trying to select module from workspace
By: omar hassane on Wed, 26 September 2018
1 3014 Thu, 27 September 2018 20:11
By: omar hassane
  Main thread of debugging terminated immediately
By: Faezeh Khorram on Wed, 19 September 2018
3 7882 Wed, 26 September 2018 16:06
By: Dennis Wagelaar
  Couldn`t get access to some documentation of ATL transformation
By: Faezeh Khorram on Tue, 04 September 2018
1 2395 Wed, 05 September 2018 15:53
By: Dennis Wagelaar
  Question about imperative do blocks in ATL
Effect of using a specific command in imperative do blocks of ATL rules
By: Gehan Mustafa Kamel Selim on Thu, 23 August 2018
7 5423 Thu, 30 August 2018 13:09
By: Sylvain EVEILLARD
  Writing to a specific LOG file
How to let ATL Log output be saved in a file
By: Till Paplowski on Fri, 17 August 2018
1 3824 Sat, 25 August 2018 15:15
By: Till Paplowski
  Exception while loading module in emftvm
By: Till Paplowski on Tue, 10 July 2018
1 3742 Mon, 20 August 2018 11:14
By: Till Paplowski
  Problem when running a custom plugin
model unknown
By: Gonzalo López on Wed, 08 August 2018
1 4578 Sun, 19 August 2018 21:48
By: Gonzalo López
  Create cartesian product from list
By: Alexis BOUFFIES on Fri, 13 July 2018
0 3209 Fri, 13 July 2018 14:51
By: Alexis BOUFFIES
  Refining Transformation on OCL constraints
By: Sidra Iftikhar on Thu, 12 July 2018
0 2619 Thu, 12 July 2018 10:48
By: Sidra Iftikhar
  Long ATL file taking much time to save in Eclipse
By: Ruchika Kumar on Thu, 28 June 2018
5 3569 Tue, 10 July 2018 07:44
By: Frederic Jouault
  Input model element copied many times in target model
By: Gonzalo López on Fri, 06 July 2018
0 2825 Fri, 06 July 2018 21:33
By: Gonzalo López
  Ignore Stereotypes of custom profile
By: Steven Schmock on Wed, 27 June 2018
2 3070 Fri, 06 July 2018 10:49
By: Steven Schmock
  Lazy Rules for nested Model elements
By: Steven Schmock on Fri, 06 July 2018
0 3382 Fri, 06 July 2018 10:36
By: Steven Schmock
  Modular Design
General Information
By: fabio Mising name on Mon, 02 July 2018
1 2185 Tue, 03 July 2018 16:06
By: Dennis Wagelaar
  About ATL headless mode
By: ashrafur rahman on Mon, 25 June 2018
2 4131 Sat, 30 June 2018 07:20
By: ashrafur rahman
  MDA
M2M Transformation
By: DJITOG IGNACE on Thu, 31 May 2018
1 4599 Fri, 29 June 2018 17:31
By: Dennis Wagelaar
  UML profile to Ecore transformation
By: Steven Schmock on Fri, 22 June 2018
2 3244 Sun, 24 June 2018 22:48
By: Steven Schmock
  Microsoft Office Excel Extractor Problem
By: ashrafur rahman on Wed, 20 June 2018
2 2996 Sat, 23 June 2018 08:55
By: ashrafur rahman
  Output model creation and extraction problem
By: Gonzalo López on Sat, 26 May 2018
1 28609 Sun, 03 June 2018 22:57
By: Gonzalo López
  ATL Transformation Zoo
Broken link to the zoo
By: Till Paplowski on Fri, 25 May 2018
4 4384 Fri, 01 June 2018 06:45
By: ashrafur rahman
  Prevent the ATL build to overwrite the properties file
By: Michele Tucci on Tue, 29 May 2018
0 27787 Tue, 29 May 2018 14:13
By: Michele Tucci
Current Time: Thu Nov 07 12:26:52 GMT 2024
Powered by FUDForum. Page generated in 0.05521 seconds
