Get original mouse coordinates when opening context menu in headers |
1057 |
Thu, 04 January 2024 11:10 By: Jan-Philipp Steghöfer ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
NatTable 2.2.1 released |
956 |
Thu, 16 November 2023 07:16 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Issue with zoom out text size |
757 |
Thu, 26 October 2023 07:33 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
NatTable @ GitHub |
988 |
Fri, 20 October 2023 05:34 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Default corner style/painter |
577 |
Thu, 07 September 2023 16:24 By: Jonathan Menzies ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to programmatically select a cell in the row header? |
794 |
Wed, 06 September 2023 20:30 By: Jonathan Menzies ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
NatTable 2.2.0 released |
4974 |
Fri, 30 June 2023 13:11 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
NatTable : how to show a minimum of 10 rows if scrollable? NatTable : how to show a minimum of 10 rows if scrollable? |
616 |
Sat, 24 June 2023 19:25 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
EMF forms EMF forms with Multiselect Dropdown |
957 |
Fri, 12 May 2023 07:46 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Remove row number |
1034 |
Tue, 09 May 2023 14:58 By: Yann Binot ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Mysterious popup text editor on Linux - ComboBoxCellEditor |
1601 |
Thu, 27 April 2023 05:45 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
questions about LinkClickConfiguration |
881 |
Wed, 19 April 2023 15:22 By: Edit Mihancea ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
1074 |
Tue, 18 April 2023 08:16 By: Edit Mihancea ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
NatTable 2.1.0 released |
1271 |
Fri, 31 March 2023 08:07 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Buffering for tables |
786 |
Sun, 19 March 2023 06:50 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Formatting numbers in excel export |
3097 |
Fri, 24 February 2023 07:52 By: Uwe Peuker ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Any plans for Web/Theia based NatTable? |
1657 |
Thu, 19 January 2023 21:13 By: Jonathan Menzies ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
NatTable 2.0.5 released |
1488 |
Tue, 20 December 2022 16:10 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
NatTable 2.0.4 released |
1365 |
Wed, 14 December 2022 20:02 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Multiple Nattables inside one container |
1005 |
Mon, 12 December 2022 09:36 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
java.lang.IllegalStateException: Could not find any implementations of MutableSetFactory java.lang.IllegalStateException: Could not find any implementations of MutableSetFactory |
1025 |
Mon, 14 November 2022 15:41 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Vertical scroll bar is appearing when filter applied wrt base list with empty rows |
1202 |
Fri, 11 November 2022 15:14 By: Indana Amaresh ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to update row group header while filtering |
1977 |
Thu, 10 November 2022 17:00 By: Indana Amaresh ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Fill down function |
1214 |
Wed, 02 November 2022 20:51 By: nicolas Bunnet ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
TextCellEditor causes a "SWT Resource was not properly disposed" |
1775 |
Thu, 15 September 2022 20:13 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to add a button to a table cell How to add a button to a table cell and a pop-up window when the button is clicked |
3130 |
Tue, 13 September 2022 06:31 By: Tianyu Wu ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to remove or hide default row numbers when using row group header layer in composite layer |
3476 |
Sun, 28 August 2022 22:07 By: Indana Amaresh ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to create more than two level column grouping in nattable |
2856 |
Wed, 17 August 2022 11:01 By: Indana Amaresh ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
NatTable 2.0.3 released |
1706 |
Tue, 09 August 2022 06:34 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Support for Remote Application Plattform (RAP) |
1236 |
Wed, 27 July 2022 11:49 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Undo Changes Step by step is working fine but when we apply filter its Not working? |
976 |
Mon, 25 July 2022 05:58 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Once delete Nattable row cursor should goes for next line but after grouping its not happen.?? |
852 |
Mon, 25 July 2022 05:53 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Classloading issue with slf4j and nattable |
872 |
Thu, 21 July 2022 10:07 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Stop horizontal scrolling when extending selection mit Down-key |
4989 |
Thu, 14 July 2022 12:21 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
User resizing of columns is wrong |
4638 |
Wed, 22 June 2022 14:40 By: Mokhtar Alshubei ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Combo boxes for items with identical string representation |
2311 |
Thu, 16 June 2022 17:14 By: Louis Detweiler ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Freeze columns programmatically |
5726 |
Mon, 13 June 2022 14:23 By: Mokhtar Alshubei ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
FreezeColumn Nattable 2.0.2 not working not working the way it was in 1.5.0 |
3138 |
Mon, 13 June 2022 11:53 By: Mokhtar Alshubei ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Custom GridLineCellLayerPainter issue with RowReorderLayer |
3834 |
Thu, 09 June 2022 21:55 By: Louis Detweiler ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
RichTextPainter with subscript and superscript Text formatting with subscript and superscript |
1668 |
Fri, 20 May 2022 13:17 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Row Filtering issue Problems getting filtering to work |
2019 |
Tue, 10 May 2022 14:45 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Nattable fill by drag selection data How to get drag copied data |
1532 |
Fri, 06 May 2022 04:14 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Nebula NatTable Integer column Sorting Registering custom comparator for integer column sorting does not work |
2091 |
Fri, 29 April 2022 12:18 By: Tejamurthy Shivakumar ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Highlight Row reorder swapping of rows Highlighting swapped rows uses old label |
1190 |
Thu, 21 April 2022 17:50 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Combine Excel-like filters and drop-down lists with text search in the same table The ComboBoxFilterRowHeaderComposite seems to have problems when we try to replace the CellEditor for some columns |
1534 |
Tue, 12 April 2022 04:14 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Column Width Listener Is it possible to add a column width listener? |
2270 |
Wed, 06 April 2022 14:10 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to hide Images (Labels) Icons are replacing column headers, how to switch back and forth |
1910 |
Mon, 21 March 2022 09:24 By: Peter Vilhelmsen ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
ComboBoxCellEditor events on linux, a follow up to the mac issue |
1652 |
Wed, 09 March 2022 05:35 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
NatTable 2.0.2 released |
4161 |
Fri, 14 January 2022 06:56 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How we can undo changes in Nattable like we did in excel? is it possible to undo changes in nattable? |
1990 |
Wed, 17 November 2021 11:10 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How we can apply filter by color on Nattable like we did in excel? is it possible ? if yes then could you please tell me how we can achieve it. Thanks in Advance |
1532 |
Mon, 15 November 2021 06:55 By: Prashant Pawar ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
natTable Focus natTable selection |
894 |
Tue, 09 November 2021 09:05 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
dynamic coloring of cells using CellOverrideLabelAccumulator with filtering/grouping/sorting Issue with coloring cells using CellOverrideLabelAccumulator when filtering/sorting/grouping is applied |
824 |
Mon, 20 September 2021 13:54 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
natExporter.exportMultipleNatTables tables are overlapping |
1223 |
Wed, 15 September 2021 10:55 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
filter filtered data |
2086 |
Mon, 06 September 2021 09:38 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Nattable added keybindings |
897 |
Thu, 02 September 2021 03:29 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Closing combo box dropdowns when leaving NatTable editor |
1195 |
Thu, 02 September 2021 03:24 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
coloring of nattable cells dynamically coloring of nattable cells dynamically with row and column index during runtime |
943 |
Wed, 25 August 2021 18:29 By: Vinod Gangal ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Drag and Drop in a TreeLayer How to do drag and drop in a TreeLayer |
1426 |
Mon, 16 August 2021 14:59 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
UpdateDataCommand + ViewportLayer |
1021 |
Thu, 05 August 2021 14:04 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Is Nattable Java 11 compatible ? |
1043 |
Thu, 05 August 2021 03:25 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Create a tree dynamically with NatTable NatTable tree without GlazedLists |
914 |
Tue, 15 June 2021 23:33 By: Laksono Adhianto ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
NatTable 2.0.1 released |
2124 |
Mon, 07 June 2021 10:47 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Table cell is moving after Return |
732 |
Thu, 27 May 2021 21:09 By: Ralf Heydenreich ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Filter Not working when column cell value contains "*" If filter is applied on my Nattable column, if that column has a value which contains "*" in it at any position, then filter does not work correctly. |
2967 |
Thu, 13 May 2021 07:04 By: Aswin Kumar ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
ComboBoxCellEditor events on mac ComboBoxCellEditor |
2078 |
Thu, 06 May 2021 04:40 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Possible Bug Report for Single Select + Use Checkbox Combobox Cell Editors |
2856 |
Thu, 29 April 2021 05:10 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
First key press deleted on macOS |
1177 |
Mon, 12 April 2021 09:32 By: Thomas Krause ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Tracking of data changes |
1199 |
Mon, 12 April 2021 09:22 By: Alexandra Tritean ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to realize print preview? |
1675 |
Wed, 07 April 2021 02:21 By: kevent smith ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Editing UTF-8 text |
1433 |
Mon, 22 March 2021 06:19 By: Alexandra Tritean ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Summary row layer with mutliple rows |
697 |
Thu, 25 February 2021 14:37 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
NatTable is not redrawn when ShowRowPositionsEvent is triggered |
1128 |
Thu, 18 February 2021 14:23 By: Yann Mortier ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Multi Cell Editor Multi Cell Editor - Different cells with Different LOV values |
1105 |
Wed, 27 January 2021 09:29 By: Aswin Kumar ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
NatTable add header row cell How can I add a header row cell with an image, that triggers a delete row action? |
1965 |
Sat, 23 January 2021 06:44 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Hierarchical Nat table Dynamic column |
1162 |
Wed, 06 January 2021 04:42 By: anu singh ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Nattable Dark theme and white patch |
1770 |
Tue, 22 December 2020 20:03 By: Santhosh Kumar ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
NatTable 2.0 released |
3312 |
Wed, 16 December 2020 17:43 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Scrolling changing indexes |
1481 |
Wed, 09 December 2020 05:45 By: Alexandra Tritean ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Please test the latest NatTable 2.0 SNAPSHOT |
2049 |
Thu, 03 December 2020 21:03 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Column widths - scaled / unscaled |
1483 |
Thu, 26 November 2020 10:52 By: Klaus Reger ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Drag the mouse to select multiple row headers to select multiple rows |
2018 |
Thu, 19 November 2020 01:36 By: kevent smith ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Unit Tests - Issues with timeout |
1077 |
Wed, 11 November 2020 15:33 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
TreeLayer and RowReorderLayer -> supported? |
1154 |
Thu, 15 October 2020 11:58 By: Vincent Lorenzo ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
StackOverFlow Error |
3382 |
Fri, 02 October 2020 10:10 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Same package in multiple versions javax.annotation is twice in p2 repo |
913 |
Fri, 25 September 2020 04:32 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to get the selected object from the tree table not able to get the exact selected object from the tree table |
3450 |
Mon, 14 September 2020 10:08 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Scrolling changing style |
1302 |
Tue, 08 September 2020 07:07 By: Alexandra Tritean ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to change the color of the only some part of the string in the cell to change the color of the only some part of the string |
1424 |
Mon, 31 August 2020 05:23 By: Chinniah Govindasamy ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
FilterLayer is it possible to add filterLayer at each root level attribute By: P M on Wed, 12 August 2020 |
925 |
Thu, 13 August 2020 03:36 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to change the color of the grid lines in the nattable I want to change the color of all the lines inside the table in to white or disappear |
1514 |
Fri, 31 July 2020 18:00 By: Chinniah Govindasamy ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to remove alternate row colors. I want all my rows in same color |
1122 |
Thu, 30 July 2020 05:54 By: Chinniah Govindasamy ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Nattable compatibility with OpenJDK Migration from Oracle JDK to OpenJDK |
1049 |
Thu, 23 July 2020 16:55 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Right-Click-Selection-Update with open Context Menu |
2311 |
Thu, 23 July 2020 11:59 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
FormText in Cell |
1323 |
Tue, 21 July 2020 09:20 By: Benedict Wright ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Row spanning not working when table is scrolled Row span displays as individual row when nattable is scrolled |
1307 |
Thu, 16 July 2020 09:42 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
summary row add summary row in hierarchical nat table |
1671 |
Wed, 08 July 2020 11:06 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Adding item to a filtered List |
1492 |
Thu, 11 June 2020 11:23 By: Ralf Heydenreich ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Automatically Wrap the text in a Gridlayer Wrap Text in Grid Layer |
2023 |
Tue, 19 May 2020 09:57 By: Palraj Jayaraj ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
problem with column hide reproduceable with modified example |
1509 |
Thu, 14 May 2020 10:20 By: Ludwig Moser ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
update/refresh NatTable after updating the POJO |
7656 |
Wed, 13 May 2020 16:23 By: Chinniah Govindasamy ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to detect, if underlying data has changed, when editing a cell |
1405 |
Tue, 05 May 2020 13:28 By: Klaus Reger ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
NatTable 2.0 Release Plans |
1509 |
Tue, 31 March 2020 20:04 By: Patrick Paulin ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Cell Editors not showing up |
1624 |
Wed, 25 March 2020 15:27 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
NatTable 2.0 - dynamic scaling |
5836 |
Thu, 05 March 2020 21:05 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Modified values of a cell is getting set into other cell when columns are hidden/shown Modified values of a cell is getting set into other cell when columns are hidden/shown |
1750 |
Fri, 14 February 2020 11:02 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Repository link for latest release |
1290 |
Wed, 22 January 2020 09:11 By: Aparna Argade ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Last Group headers not appearing for performance ColumnGroupHeaderLayer |
1596 |
Thu, 16 January 2020 13:39 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Row height and icon scaling in Nattable with eclipse 19-09 |
4504 |
Thu, 09 January 2020 10:48 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Instances of NatTable are beeing kept in memory after composite is disposed |
1311 |
Mon, 30 December 2019 08:26 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
NPE while saving State (with Filters |
1657 |
Sat, 28 December 2019 07:53 By: Ludwig Moser ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
how to create a custom filter |
2093 |
Sat, 21 December 2019 06:59 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Nattable saveState and loadState issue |
1235 |
Fri, 20 December 2019 22:29 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
"Widget is disposed" from NatTable.handleLayerEvent() |
1696 |
Fri, 20 December 2019 12:26 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Displaying Dialog for multi edit of checkbox. |
1675 |
Fri, 20 December 2019 08:08 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Row and column header disappear |
2594 |
Wed, 18 December 2019 09:08 By: Ralf Heydenreich ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Sorting a TreeTable at first level |
1448 |
Mon, 16 December 2019 10:28 By: Ralf Heydenreich ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Customize/Configure ColumnChooser |
1598 |
Wed, 04 December 2019 07:19 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
CellOverrideLabelAccumulator CellOverrideLabelAccumulator |
1285 |
Tue, 03 December 2019 20:58 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Validation error style |
1534 |
Sat, 30 November 2019 07:34 By: zida wang ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
2351 |
Fri, 29 November 2019 02:10 By: zida wang ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
FormulaGrid |
1872 |
Thu, 28 November 2019 04:19 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
background image not showing in column header background image not showing in column header |
1907 |
Wed, 27 November 2019 05:45 By: dhruba kumar ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
SWTBot and Nattable: wait until all pending updates are performed |
1572 |
Thu, 21 November 2019 13:55 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
List view is not updated while filtering Using GlazedListTreeData and ITreeRowModel |
1565 |
Thu, 21 November 2019 10:01 By: Ralf Heydenreich ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Changing the color of the freeze grid line |
1653 |
Mon, 18 November 2019 10:59 By: Stefan T ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Styling Grid : Windows OS Style |
1488 |
Fri, 15 November 2019 19:36 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Select a row without the actual cell selection |
1512 |
Fri, 15 November 2019 15:19 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Unbind cell selection with selected row |
1712 |
Mon, 11 November 2019 13:21 By: Alexey Kazakov ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Row Spanning |
1730 |
Fri, 15 November 2019 13:32 By: dhruba kumar ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Generating PDF in NatTable |
1006 |
Tue, 12 November 2019 12:46 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Trouble with content assist in TextCellEditor |
1834 |
Tue, 05 November 2019 09:44 By: Maria Fardig ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Comboboxcelleditor combo values based on cell value Comboboxcelleditor combo values based on cell value |
1061 |
Thu, 31 October 2019 21:05 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Filter converted data |
4360 |
Wed, 30 October 2019 17:24 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to track drown RowSelectionEvents |
2915 |
Mon, 14 October 2019 10:41 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Validation dialog popup multiple times |
5649 |
Wed, 25 September 2019 13:06 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Custom TextMatchingMode Add new TextMatchingModes which could handle simple star regex. |
1420 |
Tue, 24 September 2019 14:01 By: Nikolai Chebanov ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Misbehaving two-level column groups |
28 |
13251 |
Mon, 23 September 2019 20:12 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Column group header problem I have a problem trying to identify column groups with the same name |
3465 |
Mon, 23 September 2019 15:35 By: krishna kalvakuri ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
EPL v2 |
11066 |
Fri, 20 September 2019 10:09 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
NatTable 1.6.0 |
9682 |
Wed, 18 September 2019 18:57 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Custom Scrollbar Mousewheel Support |
16122 |
Tue, 03 September 2019 06:35 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to correctly register an Action on the GridRegion.Body Mouse.RMB |
1575 |
Fri, 30 August 2019 08:55 By: Ludwig Moser ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Wrong order after inserting a row into a NatTable |
2796 |
Tue, 27 August 2019 08:07 By: Ralf Heydenreich ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
excel export excel export is creating formul from string |
4706 |
Thu, 22 August 2019 13:49 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Alternatives for Nattable Alternatives for Nattable |
8566 |
Wed, 14 August 2019 06:35 By: girijanandan nucha ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
can we span column Header cells using spanningDataLayer in Nattable can we span column Header cells using spanningDataLayer in Nattable |
2574 |
Mon, 12 August 2019 21:36 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Focus next widget below NatTable How to focus-exit in NatTable? |
1741 |
Tue, 06 August 2019 14:59 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Changing Font type of NatTable header dynamically MakingFont type of NatTable header as BOLD and NON-BOLD dynamically |
4701 |
Tue, 06 August 2019 10:02 By: Sharmila Naik ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
SelectAll does not select all rows [solved] |
24196 |
Wed, 31 July 2019 07:24 By: Klaus Reger ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to get notified, that the DataLayer has finished loading data |
2781 |
Wed, 24 July 2019 14:29 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Sorting Not honoring applied style labels On single click sort the applied column labels are not getting arranged correctly |
2058 |
Sat, 22 June 2019 12:36 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Labels not working with sorting Labels applied at Row level is not carry forward with Sorting |
3901 |
Mon, 17 June 2019 10:44 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Adding a summary header for columns and rows |
4813 |
Fri, 07 June 2019 15:10 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Nattable create cell value Nattable create cell value |
2997 |
Mon, 03 June 2019 09:26 By: Balachandran Palanisamy ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Prevent sort column |
5704 |
Fri, 24 May 2019 08:36 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Vertical scrollbar shifts to the top after user clicks on cell at the bottom Vertical scrollbar shifts to the top after user clicks on cell at the bottom |
2957 |
Fri, 10 May 2019 11:13 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Ad a overlay such as a "glaspane" over the whole table |
2339 |
Thu, 09 May 2019 13:30 By: Benedict Wright ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Date cell editor - set null for date column i want to set null date , but date picker does not show up if we do not set any date value |
4085 |
Thu, 09 May 2019 05:11 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Duplicate elements created on sorting a tree implemented using Nattable Duplicate elements created on sorting a tree implemented using Nattable |
1478 |
Wed, 08 May 2019 14:18 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Filtering combo box filtering |
11783 |
Mon, 29 April 2019 05:24 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Filter column values using custom FILTER_DISPLAY_CONVERTER |
2764 |
Wed, 24 April 2019 18:52 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Display loading state in table |
14339 |
Wed, 17 April 2019 14:06 By: Benedict Wright ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Multi Value Editor in NATTable How to add Multi Value editor in NAT table |
1735 |
Fri, 12 April 2019 20:11 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Canonical way of clearing the content of a cell? By: na na on Thu, 11 April 2019 |
2503 |
Thu, 11 April 2019 14:13 By: na na ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to reorder multiple columns via one mouse drag action |
2105 |
Mon, 08 April 2019 10:47 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to restore a column selection after hiding a row (via context menu or via api) |
2312 |
Mon, 08 April 2019 09:56 By: Hilger Steenblock ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Spanned Cells show not always the data of the first column |
2095 |
Fri, 15 March 2019 11:53 By: Niklas Kellner ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Filter restarting the row numbers from "1" After applying filter the displayed row numbers/ id's are starting from "1" |
2589 |
Wed, 20 February 2019 05:43 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to re-configure the column group header without a recreation of the layer stack |
1444 |
Tue, 19 February 2019 10:36 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Sorting removes applied filters |
4809 |
Mon, 18 February 2019 13:42 By: Andreas Sturm ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
NPE in SelectionLayer NPE in SelectionLayer |
2640 |
Mon, 18 February 2019 09:55 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How show the Tooltip for part display cell(xxx...) |
6325 |
Tue, 12 February 2019 17:34 By: Alexander Till ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
NatTableContentTooltip constructor for testing |
2369 |
Sat, 09 February 2019 06:15 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Filtering Custom filtering using own DataProvider |
1880 |
Wed, 06 February 2019 16:11 By: Hallvard Traetteberg ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
NatTable version 1.1.0 and Glazelist version 1.8.0 compatibility NatTable version 1.1.0 and Glazelist version 1.8.0 compatibility |
1326 |
Mon, 04 February 2019 09:25 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
ColumGroupHeader-Styling Issue |
1889 |
Mon, 28 January 2019 10:00 By: Mathias Jankow ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to disable the empty vertical scrollbar painting if no row data is defined |
2021 |
Fri, 25 January 2019 12:25 By: Hilger Steenblock ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
ComboBox Multiselect/Use Checkbox question |
3768 |
Wed, 23 January 2019 12:05 By: Parth Desai ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Font color for a substring in a cell Need to highlight a part of cell value with different colors |
1638 |
Thu, 17 January 2019 10:31 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Problem with Tree and Hide Row The tree structure is broken by hiding rows |
3906 |
Thu, 10 January 2019 07:32 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Dynamically set column span for a cell i want to randomly set column span for a cell based on value in other column |
1903 |
Tue, 08 January 2019 09:41 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Problem with Column Group Reorder and Column Grouping by Value Using default configuration, column reorder seems broken |
2493 |
Tue, 11 December 2018 19:34 By: Yves Prelot ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to configure the DefaultSelectionLayerConfiguration How to configure the DefaultSelectionLayerConfiguration to select additionally the next row with SHIFT+Arrow-Down |
2199 |
Sat, 08 December 2018 09:15 By: Hilger Steenblock ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to configure the Selection Style to not override the text foreground color of a selected cell Selection Handling |
3263 |
Tue, 04 December 2018 15:41 By: Hilger Steenblock ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
NatTable Tree Filtering Show path to parent, when child is selected from filter combo |
2947 |
Mon, 26 November 2018 10:46 By: Richie Martin Pasupuleti ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Sorting on large data-set Sorting performance |
2738 |
Fri, 23 November 2018 16:40 By: chaitanya tangudu ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
how to add a new row in the filter list, if rows are already filttered. By: SD Khan on Thu, 31 October 2013 |
4045 |
Wed, 21 November 2018 08:30 By: Richie Martin Pasupuleti ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to use CellPainterDecorator class |
4711 |
Tue, 20 November 2018 10:11 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to configure the borderline of ColumnGroups Theme Configuration Column Group |
1845 |
Tue, 20 November 2018 09:01 By: Hilger Steenblock ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Coloring grid lines with GridLineCellLayerPainter |
2156 |
Tue, 20 November 2018 06:27 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Release date Release date v1.6 |
3183 |
Tue, 20 November 2018 06:21 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
NatTable context menus with Eclipse menus |
3604 |
Sat, 20 October 2018 17:42 By: Luc H ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to read Map in Nattable |
1686 |
Wed, 24 October 2018 09:56 By: karthykeyan Palanisamy ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to restore default value after setting a css property |
3430 |
Fri, 19 October 2018 16:21 By: Pauline Deville ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Resizing Columns for a Single Row When only one row / single row selected, a single column resize resizes all columns |
3088 |
Fri, 28 September 2018 07:34 By: Martin Schmidt ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
NatTable eample EditorExmple not visible in Composite (ViewPart Eclipse 3.7) |
1965 |
Wed, 26 September 2018 18:27 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
What is the best way to lock/unlock rows for editing |
2196 |
Wed, 15 August 2018 01:53 By: PK Mising name ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to paint over header cell boundaries via an own cHeaderCellPainter |
1843 |
Thu, 02 August 2018 10:28 By: Dirk Fauth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to select rows with matching text in whole row or single column |
2758 |
Thu, 12 July 2018 11:18 By: Markus Barbey ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
