[Acceleo] IDE Error during Acceleo Project Build in Eclipse 202403 Error during Acceleo project build in eclipse IDE |
1950 |
Wed, 01 May 2024 09:41 By: aga odias ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[Acceleo] Problems building Acceleo generator with latest Tycho 4.0.7 |
1384 |
Mon, 08 April 2024 09:22 By: Jad El-khoury ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[Acceleo] problem with primitive types when executed as Java application |
8046 |
Wed, 28 February 2024 18:46 By: Olivier Bourgeat ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[Acceleo] Generate code from SHACL Shapes |
5531 |
Mon, 18 September 2023 07:56 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Error on model to text transformation in Acceleo |
6791 |
Thu, 13 July 2023 18:14 By: Ayoub Ayoub ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[Acceleo] Problem when accessing a property of an instance of the meta-class PrimitiveType Template does not seem to access the 'name' property of an instance of the meta-class PrimitiveType |
5038 |
Tue, 04 July 2023 23:17 By: Ferenc Magnucz ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Query returns CamelCase string Definition of regex to convert a snake to came case string |
2794 |
Sun, 18 September 2022 17:48 By: Hamza Natek ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Call service wrapper function in the post() black Call service wrapper function in the post() black |
988 |
Wed, 24 August 2022 19:18 By: Oleg Cohen ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to overwrite previously generated file? How to overwrite previously generated file? |
1306 |
Tue, 23 August 2022 16:05 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[Acceleo] Null when accessing reference from a linked metamodel [Acceleo] Null when accessing reference from a linked metamodel |
1071 |
Thu, 11 August 2022 18:49 By: Oleg Cohen ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
using a map/dictionary data structure with Acceleo |
1094 |
Tue, 09 August 2022 20:08 By: Jad El-khoury ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Acceleo 4.0.0 ? roadmap? |
1496 |
Thu, 28 July 2022 18:18 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Acceleo getValue problem with port metaclass Acceleo papyrus profile data access for port metaclass |
2845 |
Thu, 28 July 2022 08:18 By: pere joseph rodríguez ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[Acceleo] Deploying Plug-In Problem |
2671 |
Tue, 28 June 2022 06:28 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[Acceleo] Execute Multiple model |
1911 |
Thu, 09 June 2022 15:10 By: MOUAD BEN MEKKI ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
M2T |
2763 |
Thu, 19 May 2022 19:02 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Question about loss of traceability in Acceleo |
1929 |
Thu, 28 April 2022 11:42 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[Acceleo] Execute without plugin |
1978 |
Thu, 31 March 2022 13:52 By: Carolo Pintarolho ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Generating seperate folders for the generated code |
1663 |
Sun, 27 March 2022 17:31 By: Atalay Özmen ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Compilation of Acceleo module failing using acceleo maven plugin |
2157 |
Thu, 17 March 2022 08:46 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Acceleo or Xtend , to be used for model to text transformation |
1802 |
Tue, 08 March 2022 13:47 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Acceleo issue- SSL Handshake Exception Acceleo Plugin not able to download to our Local repository and getting SSL Handshake Exception |
3788 |
Fri, 18 February 2022 11:44 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Acceleo Traceability By: M M on Tue, 15 February 2022 |
1596 |
Tue, 15 February 2022 05:50 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
log4j 1.X series high-risk vulnerability Is the log4j 1.X series high-risk vulnerability affect the xpand? |
6163 |
Mon, 24 January 2022 09:26 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[Acceleo] Are there tutorials / examples available? |
1842 |
Fri, 07 January 2022 20:36 By: Ilja Kraval ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
getLabel() behavior |
1277 |
Fri, 07 January 2022 17:25 By: Ilja Kraval ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
problem with remove method of xpand problem with remove method of xpand |
1638 |
Tue, 28 December 2021 22:13 By: Mera Mera ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
problem with oclIsKindOf() |
3283 |
Fri, 26 November 2021 09:19 By: Ilja Kraval ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
correct downcast from Element to other UML types |
1939 |
Thu, 25 November 2021 19:16 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
working with imported models |
1542 |
Tue, 23 November 2021 17:57 By: Ilja Kraval ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
M2T Acceleo M2T |
1429 |
Wed, 03 November 2021 19:28 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Acceleo & Maven Repository Missing Artifacts |
1657 |
Tue, 19 October 2021 13:30 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Acceleo: Custom Exception handler for IO exceptions How to detect if a file wasn't written |
2089 |
Thu, 14 October 2021 15:17 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Generate text on Annotation |
2996 |
Tue, 31 August 2021 21:52 By: Pascal PONSARD ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Share a (E)MTL file using a JAR dependency |
1018 |
Tue, 31 August 2021 16:00 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
From Ecore to Java |
1368 |
Tue, 31 August 2021 09:06 By: Laurent Goubet ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to access imported packages Acceleo Papyrus |
1781 |
Tue, 17 August 2021 08:18 By: Carsten Pitz ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Passing a Type as parameter in acceleo always results in AnyType |
1735 |
Sat, 31 July 2021 06:16 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
get the instance of the Main AcceleoGenerator class from query invoke |
2643 |
Tue, 08 June 2021 12:50 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Acceleo within Sirius To run an acceleo project from within a Sirius Viewpoint specification Project |
1836 |
Fri, 28 May 2021 11:17 By: Aon Safdar ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Acceleo 3 standalone with traceability |
1706 |
Thu, 20 May 2021 15:49 By: Elie Richa ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[Xtend] M2T transformation examples |
2890 |
Sun, 02 May 2021 06:40 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[Acceleo] Map data type? |
2094 |
Fri, 23 April 2021 06:27 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
java.lang.ClassCastException while transforming source EReference to Target ERefernce. |
1165 |
Sat, 27 February 2021 20:14 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[Acceleo] Where to get Acceleo 4? |
1404 |
Sat, 27 February 2021 08:15 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[Acceleo] - How to bundle Acceleo with Sirius How to bundle Acceleo project with Sirius project |
4642 |
Tue, 19 January 2021 16:04 By: mike hill ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Get XMI: ID of elements in sysml |
1350 |
Sat, 19 December 2020 09:06 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
UML/Sysml Profile.. |
1571 |
Fri, 11 December 2020 06:15 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[Acceleo][Xbase] Transforming Xbase expression into java How to transform Xbase types into java code with acceleo |
1372 |
Mon, 07 December 2020 05:49 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[Acceleo] Write in linked folder |
1699 |
Mon, 16 November 2020 09:30 By: Quentin Bourguignon d'herbigny ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
ClassNotFoundError of exception when running Acceleo in standalone mode |
1900 |
Tue, 10 November 2020 17:58 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Read Stereotype / compare Stereotype |
1461 |
Tue, 10 November 2020 07:55 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
how to read xmi:id fields in models files? |
1406 |
Wed, 04 November 2020 19:42 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Make Acceleo usable by non-programmers |
1543 |
Tue, 27 October 2020 20:07 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
how to read Eugenia diagram model in Acceleo? |
1663 |
Tue, 06 October 2020 18:07 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Acceleo xmi to java |
5215 |
Mon, 05 October 2020 14:41 By: Fatima Rani ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to start in acceleo? |
1835 |
Sat, 26 September 2020 18:29 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Yet another enquiry on Maven builds |
1290 |
Fri, 11 September 2020 18:16 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Acceleo build Showing error when I write in generate.mtl file |
2666 |
Thu, 10 September 2020 13:43 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to read model of any metamodel in Acceleo? |
1576 |
Thu, 10 September 2020 07:54 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Acceleo In new Acceleo project java file not create |
1383 |
Fri, 04 September 2020 13:52 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
JET keeps recreating template classes without modifications JET Behavior |
1335 |
Tue, 18 August 2020 04:34 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Best Model-to-text transformation tool Model-to-text tranformation from .xmi to .xml |
2594 |
Mon, 27 July 2020 18:13 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Acceleo Cannot access to the my matamodele attributes , references .. By: Sel ma on Wed, 01 July 2020 |
4754 |
Wed, 08 July 2020 11:44 By: Sel ma ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
- Acceleo - Check consistency - multi domain |
1870 |
Mon, 06 July 2020 18:32 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Acceleo [ Run problem] I want to generate Java code for my graphical model defined by sirius By: Sel ma on Wed, 24 June 2020 |
3323 |
Sat, 27 June 2020 17:51 By: Sel ma ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Importing a module from a plugin into a module of an Acceleo project |
1723 |
Mon, 22 June 2020 15:57 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
XPAND parser exception contains wrong line number org.eclipse.internal.xtend.xtend.parser.ParseException: no viable alternative at character '·' on line 9800291 |
1726 |
Thu, 04 June 2020 18:34 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Increment of Int in while loop? |
1568 |
Fri, 22 May 2020 12:01 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[Acceleo] Remove trailing white spaces in generated Java wrapper |
1857 |
Tue, 12 May 2020 17:41 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Getting NullPointerException while running JET Transformation Project in Eclipse JET2Transformation |
2010 |
Wed, 06 May 2020 16:35 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Find property value over a set By: Eclipse User on Wed, 06 May 2020 |
1566 |
Wed, 06 May 2020 15:15 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How can I get a class which is inherited from another class in acceleo |
2809 |
Wed, 06 May 2020 13:29 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
how to read EAnnotations separately in for loop? |
3176 |
Mon, 04 May 2020 08:41 By: Fatima Rani ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to read the graphical notations? |
1453 |
Mon, 27 April 2020 13:38 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to get the child classes only? |
1914 |
Mon, 20 April 2020 05:02 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Compile Accelo with Maven&Tycho&Travis Compile Accelo with Maven&Tycho&Travis |
1604 |
Wed, 15 April 2020 20:44 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
JET Editor By: Eclipse User on Wed, 26 September 2007 |
9623 |
Mon, 13 April 2020 13:10 By: Eclipse User ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[Acceleo] Suppress some warnings |
1901 |
Thu, 26 March 2020 11:11 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[Acceleo] Order of TemplateParameterSubstitution in TemplateBindings |
5637 |
Thu, 13 February 2020 08:32 By: Michael Nestler ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Acceleo source generator always replaces target file The Acceleo default writer 'AcceleoFileWriter' doesn't handles the case when generated content is equal to the existing file content |
1490 |
Wed, 12 February 2020 15:12 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Error in running Acceleo project |
2742 |
Thu, 06 February 2020 10:24 By: Elie Richa ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Access to target folder from within Acceleo generation |
2281 |
Tue, 03 December 2019 03:14 By: Jad El-khoury ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[Acceleo] standalon vs plugin execution time |
1964 |
Thu, 28 November 2019 06:40 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
problem to access to applied profiles on UML elements with Acceleo when a request the applied stereotypes on some elements , I receive an empty set |
2010 |
Sat, 09 November 2019 13:32 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Error while creating Acceleo project |
2512 |
Tue, 29 October 2019 14:02 By: rima learnerinf ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Code Generation via NLP This topic can be described as text to source code generation |
2348 |
Wed, 23 October 2019 13:09 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[Acceleo] A question on building product with Maven/Tycho |
3793 |
Mon, 07 October 2019 20:12 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Parsing OCL constraints in Acceleo |
2239 |
Thu, 03 October 2019 12:41 By: Fritz Solms ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Error while creating Acceleo project Eclipse sirius ecore Model to text transformation using Acceleo |
1859 |
Thu, 26 September 2019 09:52 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Code for Model created in Sirius editor |
1849 |
Wed, 25 September 2019 19:58 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Model to text transformation Eclipse Sirius, Acceleo |
5691 |
Fri, 20 September 2019 13:21 By: Adil Bhatti ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
UML diagrams in XML + JET = Java? |
8392 |
Thu, 19 September 2019 08:26 By: Karsten Thoms ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[Acceleo] allInstances operator not available? |
1954 |
Wed, 21 August 2019 12:10 By: Nico Jansen ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[Acceleo] Loop over empty OrderedSet creates empty lines Or: How to ask if something != null |
3836 |
Thu, 01 August 2019 15:49 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[acceleo] Standalone compiler (ant task) |
6926 |
Sat, 27 July 2019 04:51 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Specify folder for resolving dsl model files? |
8295 |
Thu, 25 July 2019 04:41 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Acceleo standalone generation |
7951 |
Sat, 20 July 2019 10:16 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Refer one mtl file in another Refer one mtl file in another |
2956 |
Wed, 10 July 2019 17:02 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Loop in the query of acceleo Loop in the query of acceleo |
1986 |
Mon, 08 July 2019 13:16 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Class properties from Element |
3490 |
Wed, 03 July 2019 06:37 By: Mohammad Inayatullah ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[Acceleo] Problems migrating a project from Acceleo 3.7.3/Java 9.0.4 to Acceleo 3.7.8/Java 11.0.2 Problems building the project's code when trying different ways to migrate the source code from one version to another |
6121 |
Tue, 02 July 2019 18:21 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[Acceleo] Circular dependencies |
3663 |
Mon, 01 July 2019 17:09 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How can I reuse the template from a super metaclass |
3833 |
Sun, 30 June 2019 13:58 By: Elder Rodrigues ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Comparison for upperbound is not working |
3062 |
Sun, 30 June 2019 13:29 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Find Multiplicity of association in acceleo Find Multiplicity of association in acceleo |
2859 |
Sat, 29 June 2019 21:47 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Read the value of properties of stereotype in Acceleo Read the value of properties of stereotype in Acceleo |
3783 |
Thu, 27 June 2019 20:19 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[Acceleo] For loop on Set<Class> is not working |
3457 |
Thu, 27 June 2019 16:56 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Best way to use "separator" in an if chain |
51426 |
Wed, 26 June 2019 20:57 By: Elder Rodrigues ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Attributes of Custom Datatype is not seen in papyrus Attributes of Custom Datatype is not seen in papyrus |
2999 |
Wed, 26 June 2019 17:39 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[Acceleo] Assigning a Template Result to a Variable |
2471 |
Tue, 25 June 2019 15:40 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
p.type.name is not transforming in the code p.type.name is not transforming in the code |
7804 |
Sat, 22 June 2019 04:54 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Runner : Acceleo Plug-in Applications Due to changes in the Eclipse platform in Luna, the Acceleo Plug-in Application strategy may not work |
2476 |
Sun, 16 June 2019 18:25 By: Illés Attila ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[Acceleo] For loop generate extra white line iterating on Set<Association> |
3407 |
Mon, 10 June 2019 09:32 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
M2T Ecore2XML / Ecore2JSON Tutorial/Guide/Help I'm clueless how to perform the transformations |
3972 |
Fri, 24 May 2019 09:47 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[Acceleo] Disambiguate class reference |
3808 |
Thu, 09 May 2019 06:52 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
a difficult query to solve find all the routes between one class and another |
7935 |
Thu, 02 May 2019 18:05 By: Jonathan Marino ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Invoke method cannot used for OrderedSet ? |
6554 |
Fri, 19 April 2019 15:07 By: Burak Karaduman ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[xpand + xtend]: how to access MWE workflow properties in Xpand templates, with xtend 2.17.x? |
3750 |
Fri, 19 April 2019 07:35 By: Mauro Antonaci ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[Acceleo] proper signature of template |
3111 |
Wed, 03 April 2019 07:08 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Does the Acceleo model-to-text transformation support different kind of input models in .mtl file? M2T |
2957 |
Tue, 02 April 2019 19:21 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Installing Acceleo on Eclipse 2018-12 Installing Acceleo on Eclipse 2018-12 |
4907 |
Tue, 02 April 2019 15:08 By: Tomasz abczy?ski ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Errors running builder 'Acceleo Builder' |
5284 |
Mon, 01 April 2019 13:07 By: Laurent Goubet ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Acceleo UI Launcher cannot find Java Services and UML Profile |
10148 |
Fri, 08 March 2019 13:18 By: Thomas Pusztai ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Using AQL Programmatically : is it really discouraged? |
27122 |
Fri, 01 March 2019 13:56 By: Benoît Héricher ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Complex query question acceleo queries |
4036 |
Fri, 01 March 2019 05:52 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[Acceleo 3.7.7] How to Acceleo seems having problem of type checking dealing with Sequence(Sequence(...)) |
2882 |
Sun, 17 February 2019 11:34 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Is it possible to generate Java code from a resource only loaded in memory? MoDisco - Acceleo |
2210 |
Fri, 08 February 2019 15:47 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Error UML to Java Example Error UML to Java Example |
2376 |
Sat, 02 February 2019 09:39 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Changes in metamodel is not recognized by Acceleo? Acceleo and Metamodel is not synchronized |
2158 |
Sat, 26 January 2019 17:18 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
java.lang.NullPointerException in MTL |
2799 |
Sat, 26 January 2019 10:14 By: Burak Karaduman ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[Acceleo] Generator works with Papyrus, but fails with MagicDraw |
2494 |
Thu, 24 January 2019 06:12 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
The problems occurs when I follow the Acceleo Getting Started guidance in the wiki to generate java Problems of Acceleo getting start. |
6789 |
Fri, 18 January 2019 06:22 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[Acceleo] Dependency on a Reusable Base Generator not Working Reuse code in a base generator project in several other generators |
4877 |
Mon, 10 December 2018 17:52 By: Thomas Pusztai ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Generate Output files in a different folder than the project |
2186 |
Fri, 07 December 2018 19:27 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Unresolved compilation error, expression was null. |
3058 |
Wed, 05 December 2018 20:49 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Strange behaviour on generating text - Indentations do not match |
2922 |
Mon, 26 November 2018 20:10 By: Parsa Pourali ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[Acceleo] Java service wrapper problem/reflection |
3368 |
Mon, 26 November 2018 12:59 By: Shimon Zadok ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[acceleo] Find the root element |
3645 |
Fri, 23 November 2018 12:05 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
programmatically check if the generation Was successfull |
3145 |
Thu, 22 November 2018 17:42 By: Parsa Pourali ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
input model |
2205 |
Thu, 18 October 2018 11:11 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
c.getAppliedStereotypes().name doesn't work in acceleo template |
2507 |
Wed, 17 October 2018 17:18 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[Acceleo]Run Problem |
2676 |
Wed, 17 October 2018 17:10 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[Acceleo] Problem of type with empty collections By: Mad Vin on Mon, 01 October 2018 |
3310 |
Tue, 02 October 2018 08:12 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Papyrus SysML model to text Some help requested with registration of SysML resources/profile |
3381 |
Thu, 27 September 2018 16:47 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Papyrus SysML model to text |
2585 |
Sat, 22 September 2018 12:28 By: Robbert Jongeling ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Papyrus UML to Java using Acceleo |
7312 |
Mon, 03 September 2018 05:30 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Load 2 differents input models an Acceleo template I have been trying to load two models conforming to the metamodels taken at the input of my m2t transformation module, but to no avail |
4161 |
Sat, 01 September 2018 17:59 By: Gerard Nzebop ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[Acceleo] [Luna] Launching acceleo problem |
13708 |
Wed, 08 August 2018 11:21 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[Acceleo] Maximum size of a module Is there a maximum size for an Acceleo module ? |
3355 |
Mon, 06 August 2018 16:33 By: Mad Vin ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[ACCELEO] Big integers Problems handling big numbers |
21 |
11991 |
Tue, 17 July 2018 09:30 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Self(Operation).setType(newType: Type) Kindly reply me how to use this function |
3935 |
Tue, 03 July 2018 09:02 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Acceleo creating a UI launcher "Acceleo Model to text"not found I follow this link http://wiki.eclipse.org/Acceleo/Getting_Started in the final step " Creating a UI launcher " - I don't have Acceleo Model to text . |
4408 |
Wed, 13 June 2018 12:21 By: wang shiyu ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Acceleo - Reference to another model Using Acceleo on a model wich contains references to another model |
3818 |
Fri, 08 June 2018 13:57 By: Flora Ferreira ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Does Acceleo support Break and Continue in for loops ? |
2665 |
Fri, 08 June 2018 05:29 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Iterate on classes using associations |
24074 |
Wed, 30 May 2018 19:17 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Problem in selecting SoaML MetaModel Uri while creating Acceleo Project? I am selecting SoaML metamodel uri while creating acceleo project but there is something wrong and meta model not selected. How I can resolve this issue? |
3307 |
Sat, 26 May 2018 09:31 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Access to Esuper classes of an Eclass in Acceleo |
3348 |
Mon, 21 May 2018 14:48 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
obtain class from operation |
2620 |
Sat, 19 May 2018 05:23 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Acceleo Code Generation? Metamodel (Ecore), Model (XMI) create code through Acceleo? |
2376 |
Wed, 16 May 2018 18:50 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to export my Acceleo code generator as a standalone desktop application ? |
5837 |
Mon, 14 May 2018 19:49 By: mamad . ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Convert Sequence to String in Acceleo |
4881 |
Mon, 14 May 2018 14:32 By: mamad . ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How pass string array[] as argument of a java service wrapper in acceleo ? |
3870 |
Mon, 14 May 2018 05:38 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Acceleo transformation how to register schemas |
6717 |
Thu, 03 May 2018 10:14 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Obtain the xmi:id using ACCELEO Obtain the xmi:id using ACCELEO |
4085 |
Mon, 30 April 2018 13:11 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
4540 |
Mon, 30 April 2018 12:27 By: Julieth Castellanos ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Test if an attribute have a default value |
2817 |
Fri, 27 April 2018 06:21 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Import data to acceleo project |
3075 |
Mon, 23 April 2018 08:47 By: khouloud AYARI ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
generate arduino code from UML/MARTE models using Acceleo |
5018 |
Fri, 20 April 2018 09:51 By: Raoudha Saida ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Different in Acceleo Different in Acceleo |
3079 |
Thu, 19 April 2018 12:49 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Getting instance from the slot.value using Acceleo Code |
3213 |
Mon, 16 April 2018 19:52 By: Muhammad Nouman Zafar ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[ACCELEO] wrong parameter value |
2750 |
Mon, 16 April 2018 16:13 By: Nicola Serreli ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Save the text file generated in other project Save the text file generated in other project |
4162 |
Sun, 15 April 2018 14:07 By: Emilie Lanau ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
guery name |
4165 |
Fri, 13 April 2018 07:59 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to get the location of the currently executing template in java wrapper Trying to get the path in the file system where the template that called a java service wrapper is located |
4298 |
Fri, 13 April 2018 06:11 By: Thomas Petrou ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Retrieve target folder during generation |
6761 |
Wed, 11 April 2018 15:18 By: Thomas Petrou ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Error while generating A UML code |
7302 |
Wed, 11 April 2018 07:27 By: khouloud AYARI ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Acceleo Code code to get the reltionship (association between blocks) |
2914 |
Thu, 05 April 2018 05:26 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Different types of files that acceleo can generate Acceleo is able to generate all sorts of text files so how can I choose the type of the generated file? |
6095 |
Wed, 04 April 2018 07:56 By: khouloud AYARI ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
unable to install new softwares Cannot complete the install because one or more required items could not be found. |
2996 |
Sun, 01 April 2018 09:51 By: khouloud AYARI ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Can't install UML to java generator |
2739 |
Sat, 31 March 2018 08:43 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
UML2JAVA |
4525 |
Thu, 29 March 2018 14:22 By: khouloud AYARI ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to Refresh Acceleo Project when change the Metamodel ? |
3368 |
Thu, 29 March 2018 13:25 By: mamad . ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Error while installing UML2JAVA |
5043 |
Wed, 28 March 2018 20:41 By: khouloud AYARI ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
No .uml model found No examples for Acceleo ! |
3310 |
Wed, 28 March 2018 08:27 By: khouloud AYARI ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Acceleo and QML does acceleo generate a .qml file? |
5157 |
Tue, 27 March 2018 13:31 By: khouloud AYARI ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[Acceleo] Working with multiple input models and metamodels [Acceleo] How can I generate code from two models having two different underlying metamodels or from two models having the same underlying metamodel? |
4285 |
Fri, 23 March 2018 18:15 By: Mad Vin ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Acceleo How to get the label of dependency |
5415 |
Thu, 22 March 2018 11:26 By: Emilie Lanau ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Acceleo How to get the name of the relationship stereotype |
7103 |
Thu, 22 March 2018 09:43 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
how to get the name of the relationship dependency How to get the name of the relationship stereotype applied in a model |
5562 |
Wed, 21 March 2018 14:04 By: Emilie Lanau ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Acceleo Tool Acceleo installation ans exploration |
2255 |
Tue, 13 March 2018 14:12 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[Acceleo 3.4.1] Call a query on a String element from another project doesn't work at execution |
3500 |
Mon, 12 March 2018 13:02 By: Mad Vin ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[Acceleo] I can't get the attributes added by the stereotype in the requirement |
6019 |
Mon, 05 March 2018 13:47 By: karim Boudaoud ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Template returns "invalid" after switching from "Acceleo Plug-in Application" to Template returns "invalid" after switching from "Acceleo Plug-in Application" to "Java Application" |
7967 |
Fri, 02 March 2018 16:36 By: Frank Poppen ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
unable get SysML stereotypes SysML; Acceleo; Papyrus |
14449 |
Fri, 02 March 2018 15:03 By: Frank Poppen ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
External JAR works with Java Application, not Acceleo Plugin External JAR works with Java Application, not Acceleo Plugin |
3061 |
Fri, 02 March 2018 14:55 By: Ed Willink ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Is Accello mature enough for a productive environment? Is Accello mature enough for a productive environment? |
4559 |
Thu, 01 March 2018 10:06 By: Mad Vin ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Accelleo project does not recompile changed Java code |
8208 |
Wed, 28 February 2018 08:12 By: Frank Poppen ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[Acceleo] i can't get Requirement id,text in Acceleo |
3683 |
Tue, 27 February 2018 11:12 By: karim Boudaoud ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[Acceleo] Bad behaviour with Java classes with Acceleo runner By: Mad Vin on Thu, 22 February 2018 |
5514 |
Mon, 26 February 2018 10:37 By: Laurent Goubet ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
