Forums will be read only after December 31st,2024
After 10 years of discussion and planning[1], these forums have been declared end of life, and will be replaced with a static read only copy on December 31, 2024. [1]https://gitlab.eclipse.org/eclipsefdn/helpdesk/-/issues/187
  Announcement: FORUM ARCHIVED
By: Eclipse Webmaster on Thu, 18 February 2021
0 5411 Thu, 18 February 2021 20:17
  Unable to access hudson-ci.org/....
URL not available hudson-ci.org/update-center3/downloads/plugins/xpath-provider/1.0.2/xpath-provider.hpi
By: Lav G on Wed, 10 June 2020
1 3293 Wed, 24 June 2020 13:07
By: Anant Chandna
  unable to install hudson with weblogic12.2.1.2
unable to open hudson dashboard after installation in weblogic12c
By: rakesh korada on Sat, 23 September 2017
1 11496 Tue, 15 October 2019 04:36
By: Rhonda Herbert
  Hudson exception after successful build
By: Raffi Simonian on Wed, 02 July 2014
8 14278 Wed, 10 July 2019 08:30
By: Randy Bonnette
  ClassNotFoundException on Hudson 3.3.3 using Maven 3.1.1
By: Shubhanshu Kumar on Mon, 29 April 2019
0 1688 Mon, 29 April 2019 18:10
  Build is taking very long time and failing
By: Nagarjuna Reddy Kurmayyagari on Wed, 11 July 2018
0 3632 Wed, 11 July 2018 20:54
  CIFS share failed to upload artifacts.
CIFS share
By: Mahesh Gowda on Tue, 20 January 2015
1 7721 Tue, 16 January 2018 08:09
By: Rolf Rosenbaum
  Launch the hudson-3.3.3 with Tomcat
By: karim toto on Sat, 16 December 2017
0 4107 Sat, 16 December 2017 14:01
By: karim toto
  what's the svnkit version used in Hudson 3.3.3 ?
By: Z W on Mon, 27 November 2017
0 5089 Mon, 27 November 2017 23:05
By: Z W
  Hudson 3.3.3 build issues
Shell commands not working
By: Tarak Chadaram on Mon, 30 October 2017
1 3521 Tue, 31 October 2017 13:55
By: Tarak Chadaram
  execute shell not working on Hudson 3.3.3
0 5501 Mon, 30 October 2017 15:46
By: Tarak Chadaram
  After upgrading hudson version older jobs are not showing up
By: Kugan Thangavel on Fri, 27 October 2017
2 3161 Fri, 27 October 2017 20:04
By: Kugan Thangavel
  Subversion cant install in hudson 3.3.3
I can't able to install subversion plugin in hudson3.3.3
By: Sibin Raj on Tue, 24 October 2017
0 4364 Tue, 24 October 2017 09:25
By: Sibin Raj
  hudson3.3.3 false buids
hudson3.3.3one job,buid twice
By: fuhua li on Fri, 08 September 2017
0 13870 Fri, 08 September 2017 02:28
By: fuhua li
icon8.gif Jenkinsfile with TFVC
Can you create/use a Jenkinsfile for pipeline with TFVC?
By: Benjamin Sykes on Thu, 20 April 2017
1 26074 Fri, 01 September 2017 20:15
By: Blake Peno
  Upgrading hudson from 1.347
By: Nick Wilkins on Wed, 09 August 2017
0 8666 Wed, 09 August 2017 20:16
By: Nick Wilkins
  Subversion issue('s)
By: Nick Wilkins on Tue, 08 August 2017
1 2736 Tue, 08 August 2017 22:14
By: Nick Wilkins
  Email jBehave reports or workspace artifacts as attachments
By: Leslie Palayil on Fri, 29 August 2014
3 10183 Wed, 05 July 2017 11:11
By: Amitesh Srivastava
  Reference SVN tagged job in second job
How to reference SVN Tag
By: Mark Boyer on Mon, 12 June 2017
0 11932 Mon, 12 June 2017 18:45
By: Mark Boyer
  httpPort=-1 does not work
By: Benjamin Gathmann on Fri, 09 June 2017
0 14707 Fri, 09 June 2017 10:22
  Setup Hudson to use SSL/HTTPS
By: Shelli Orton on Fri, 28 April 2017
1 3584 Fri, 28 April 2017 19:15
By: Bob Foster
  Build failed.. git project.. help me~~~
hudson, git, bonobo git, build
By: JEONG GONG on Tue, 11 April 2017
0 9094 Tue, 11 April 2017 04:34
By: JEONG GONG
  launch a Jenkins slave running off a docker image that runs on my Linux AMI (AWS)
I'm trying to figure out how to launch a Jenkins slave running off a docker image that runs on my Linux AMI (AWS)
By: John Okrasa on Sat, 08 April 2017
1 6098 Mon, 10 April 2017 07:27
By: Bob Foster
  Tagging a build in CVS via hudson...
By: Nick Wilkins on Fri, 03 February 2017
3 10431 Sat, 11 February 2017 01:18
By: Nick Wilkins
  TFS tab not showing up in Configure system
By: Tarak Chadaram on Wed, 25 January 2017
0 21185 Wed, 25 January 2017 21:42
By: Tarak Chadaram
  After upgrading hudson from version 1.379 to 3.1.1 views and jobs are missing from dashboard
One of our SW product uses Hudson for build. When I tried upgrading hudson to 3.1.1 version all jobs and views are missing in dashboard.
By: Chit vish on Wed, 18 January 2017
2 5055 Thu, 19 January 2017 05:02
By: Chit vish
  Continuous integration
Continuous integration using Hudson and Git - implementation
By: Sharan Basappa on Tue, 27 December 2016
0 8726 Tue, 27 December 2016 11:40
By: Sharan Basappa
icon9.gif Hudson execute maven plugin failed
By: jianrui ding on Tue, 07 June 2016
1 7001 Tue, 13 December 2016 13:12
By: Andreas Sewe
icon1.gif Manual for plot?
By: ihave question on Wed, 30 November 2016
0 5940 Wed, 30 November 2016 22:35
By: ihave question
  FATAL: org/jaxen/NamespaceContext java.lang.NoClassDefFoundError: org/jaxen/NamespaceContext
getting Hudson error FATAL: org/jaxen/NamespaceContext java.lang.NoClassDefFoundError: org/jaxen/NamespaceContext
By: gil zapatka on Thu, 03 November 2016
2 4905 Thu, 03 November 2016 23:38
By: gil zapatka
  Whic cacerts File Does Hudson Use?
By: Shelli Orton on Thu, 27 October 2016
1 3572 Fri, 28 October 2016 20:13
By: Shelli Orton
  Configure HTTPS on Hudson?
By: Shelli Orton on Fri, 28 October 2016
1 2560 Fri, 28 October 2016 17:15
By: Bob Foster
  Hudson Starteam plugin fails after switching from http to https config
Starteam plugin problem?
By: gil zapatka on Thu, 27 October 2016
2 3392 Thu, 27 October 2016 17:53
By: gil zapatka
  Hudson Git Job Calling Hg Status
By: Shelli Orton on Mon, 18 July 2016
2 5453 Thu, 22 September 2016 21:55
By: Shelli Orton
icon3.gif Hudson 3.4.0 Planning
By: Duncan Mills on Thu, 25 February 2016
1 8080 Tue, 20 September 2016 21:30
By: Colin Ritchie
  Issues while installing Jenkins 1.596
multiple errors shown in websphere logs after the jenkins start
By: newBee Jenkins on Thu, 25 August 2016
0 5891 Thu, 25 August 2016 18:57
By: newBee Jenkins
  How to specify different branches for job build using multiple git repositories?
By: Marcin Jedrzejewski on Wed, 17 August 2016
1 3640 Thu, 18 August 2016 19:19
By: Bob Foster
  Git url of repository with parameter
By: Francois Le Fevre on Fri, 05 August 2016
2 3898 Mon, 08 August 2016 16:24
By: Frederic Gurr
  Steps to migrate from v2.2.1 to 3.3.2 ?
By: Z W on Thu, 07 July 2016
2 2924 Mon, 11 July 2016 17:44
By: Winston Prakash
  When multi modules maven project merge, all modules' Hudson jobs were starting
When multi modules maven project merge, all modules' jobs were starting
By: Ersin Karatas on Wed, 18 May 2016
0 5292 Wed, 18 May 2016 09:17
By: Ersin Karatas
  Hudson 3.0.0 + Active Directory
By: Dirk Hamm on Tue, 08 January 2013
11 16276 Wed, 27 April 2016 11:02
By: Goutham Nithyananda
  Hudson Central Authentication Service
Interface Hudson to the standard cas 3
By: huson cas3 on Mon, 18 April 2016
2 7126 Wed, 20 April 2016 17:27
By: Winston Prakash
  Team based Authorization Strategy not work after restart, hudson3.3.3, centos6.7
By: Alex Rhino on Mon, 07 March 2016
0 5955 Mon, 07 March 2016 02:46
By: Alex Rhino
  How to add new users via command line with Hudson ?
By: Z W on Sat, 05 March 2016
0 6766 Sat, 05 March 2016 17:35
By: Z W
  Hudson 3.3.3 Oracle Linux rpm -> Service running, status wrong
In the rpm-file for Oracle Linux the service status is not working
By: Denis Schettl on Mon, 22 February 2016
1 4290 Mon, 22 February 2016 13:21
By: Denis Schettl
icon14.gif Hudson 3.3.3 - Regessiontest Bug 463047 -> Error still exist => solved
Hudson Maven3 Plugin version 3.0.5 and maven 3.3.x -> Missing file mvn.bat when starting build
By: Denis Schettl on Fri, 19 February 2016
4 6086 Mon, 22 February 2016 06:54
By: Denis Schettl
icon14.gif Hudson 3.3.3 -> Oracle Linux - rpm package has error => solved
oel distro-file hudson-3.3.3-1.1.noarch.rpm seems to be an package for suse
By: Denis Schettl on Thu, 18 February 2016
3 6600 Fri, 19 February 2016 06:49
By: Denis Schettl
  Hudson job that does not block
By: Jacob Thomas on Fri, 19 February 2016
0 7630 Fri, 19 February 2016 04:26
By: Jacob Thomas
icon14.gif Releasenotes for Hudson 3.3.3 missing => solved
Upgrade to hudson 3.3.3 on apt-repo, but no info about version available
By: Denis Schettl on Mon, 15 February 2016
2 4116 Mon, 15 February 2016 10:25
By: Duncan Mills
  Hudson 3.3.3 Release is now available
Release
By: Duncan Mills on Mon, 15 February 2016
0 8751 Mon, 15 February 2016 10:21
By: Duncan Mills
  Cannot Clone from Git/Stash
By: Shelli Orton on Thu, 11 February 2016
2 9071 Fri, 12 February 2016 15:51
By: Shelli Orton
  No artifacts are recorded. Is this a Maven project?
By: Andreas Löhr on Thu, 11 February 2016
0 6342 Thu, 11 February 2016 18:06
By: Andreas Löhr
  Cobertura plugin not understanding my XML
By: Paavo Helde on Tue, 02 February 2016
1 5479 Thu, 04 February 2016 21:04
By: Paavo Helde
  how to omit building steps
By: no sources on Tue, 02 February 2016
0 7605 Tue, 02 February 2016 10:09
By: no sources
icon5.gif Cannot get Hudson and Stash pull requests to play nice
By: Henrik Lynggaard Hansen on Sun, 10 May 2015
2 4509 Tue, 26 January 2016 17:14
By: Shelli Orton
  Rebuilder plugin does not work
The rebuild option is not displayed
By: Alberto Garcia on Tue, 19 January 2016
2 4048 Wed, 20 January 2016 09:24
By: Alberto Garcia
  Hudson Plugins Documentation Page Broken
Hudson plugins documentation page is borken
By: ManChun Lam on Tue, 12 January 2016
5 4780 Tue, 19 January 2016 19:33
By: Nahuel Iglesias
  Missing Jobs
Hudson Save Forever Jobs Disappeared
By: Grif Rosser on Tue, 12 January 2016
4 3723 Wed, 13 January 2016 18:06
By: Grif Rosser
  disabling anonymous user blocking users to loginto hudson 3.3
By: prudhvi konda on Wed, 13 January 2016
1 2849 Wed, 13 January 2016 17:23
By: Winston Prakash
  How to check the Console Output for a specific string and raise an error on the Build?
By: Joao Pedro on Tue, 12 January 2016
1 2831 Tue, 12 January 2016 22:08
By: Winston Prakash
  Embeddable Build Status plugin for Hudson
Displaying build status in GitHub README.md
By: James Sutton on Fri, 08 January 2016
0 6417 Fri, 08 January 2016 10:42
By: James Sutton
  Possible to Export Jobs?
By: Shelli Orton on Tue, 15 December 2015
2 3775 Thu, 17 December 2015 16:55
By: Shelli Orton
  java.lang.NoClassDefFoundError: org/eclipse/core/launcher/Main
By: Harshad Ghorpade on Thu, 17 December 2015
0 7094 Thu, 17 December 2015 09:13
  Hudson problem after interuption on slave
By: Elko Kinlechner on Thu, 10 December 2015
0 6874 Thu, 10 December 2015 08:39
By: Elko Kinlechner
  Hudson slave on Windows use a bad path for maven
By: Elko Kinlechner on Thu, 19 November 2015
2 3346 Thu, 10 December 2015 08:19
By: Elko Kinlechner
  Missing Jobs after Downgrade
By: Shelli Orton on Fri, 27 November 2015
2 4119 Thu, 03 December 2015 17:46
By: Shelli Orton
  Hudson execute threads are getting dead
By: kumar madhina on Tue, 24 November 2015
0 4901 Tue, 24 November 2015 20:34
By: kumar madhina
  Build failed : Java error
By: assil benchaaben on Thu, 13 August 2015
4 7872 Tue, 24 November 2015 16:35
By: Winston Prakash
  Output folder contains only Suite folder under test-output
By: Sivaraj Thava on Fri, 20 November 2015
0 4134 Fri, 20 November 2015 05:55
By: Sivaraj Thava
  Missing Plugins: Dynamic Build Parameter, CodeSonar, MQTT
Migrating from Jenkins to Hudson, I missing Dynamic Build Parameter plugin MQTT plugin, CodeSonar Plugin
By: Christof Hahn on Tue, 17 November 2015
1 3862 Wed, 18 November 2015 17:20
By: Winston Prakash
  Hudson 3.3.2 + Sonar Plugin Failures
By: Shelli Orton on Fri, 06 November 2015
1 6348 Tue, 17 November 2015 20:36
By: Shelli Orton
  Normal to Lose Plugins on Upgrade
By: Shelli Orton on Mon, 02 November 2015
2 3294 Wed, 04 November 2015 20:41
By: Shelli Orton
icon11.gif i am not able to build the jobs using Hudson com.bea.wli.config.component.CreateException: java.io.I
i am getting an issue com.bea.wli.config.component.CreateException: java.io.IOException: The system cannot find the file specified
By: madhusudhanareddy chilipi on Tue, 03 November 2015
0 6326 Tue, 03 November 2015 13:45
  Workspace Removed and Git SCM Fails
By: Dylan Underwood on Tue, 06 October 2015
1 6243 Mon, 02 November 2015 16:53
By: Ashwin Chandra
  WagonRepositoryConnector Using Wrong URL During Build
By: Shelli Orton on Fri, 23 October 2015
2 4964 Thu, 29 October 2015 17:34
By: Shelli Orton
  Hudson equivalent of Jenkins Sonar Gerrit
By: Matthew Khouzam on Sun, 25 October 2015
0 5784 Sun, 25 October 2015 00:08
By: Matthew Khouzam
icon11.gif Unable to load Hudson homepage
insufficient threads configured for SelectChannelConnector@0.0.0.0:8080
By: Worship Work on Fri, 23 October 2015
0 4899 Fri, 23 October 2015 05:28
By: Worship Work
  Json format issue for input parameters.
Json format issue for input parameters, while porting a plugin from Jenkins.
By: Subramanyam Iyer on Mon, 19 October 2015
1 3632 Wed, 21 October 2015 16:36
By: Winston Prakash
  Hudson Build getting Hold
While deploying Hudson i am getting deployment hold
By: madhusudhanareddy chilipi on Fri, 16 October 2015
0 7102 Fri, 16 October 2015 11:14
  Job configs cleared on restart
By: John Misinco on Thu, 08 October 2015
1 5528 Wed, 14 October 2015 08:44
By: Kaz Nishimura
  --httpPort=-1 does not work in Hudson 3.3.0 anymore
Running Hudson
By: Ajay Gupta on Tue, 06 October 2015
0 4876 Tue, 06 October 2015 22:55
By: Ajay Gupta
icon5.gif Configure TestNG report for hudson in POM
Hudson says "TestNG must be configured to generate XML reports using org.testng.reporters.XMLReporter for this plug-in to function." but How to do it in my case
By: Rahul Tyagi on Mon, 05 October 2015
0 5675 Mon, 05 October 2015 12:16
By: Rahul Tyagi
  Hudson Artifact Publish
Hudson auto deploy artifacts to servers
By: Nagavijay Sivakumar on Mon, 28 September 2015
1 3160 Thu, 01 October 2015 17:15
By: Winston Prakash
  Is there a way to get the queued item ID in 3.1.0?
API
By: Michael Yang on Wed, 30 September 2015
0 4929 Wed, 30 September 2015 14:10
By: Michael Yang
  Hudson 3.3.1 Patch Release is now available
Release Information
By: Duncan Mills on Wed, 30 September 2015
0 5849 Wed, 30 September 2015 11:58
By: Duncan Mills
  checksum error from OpenSuse repo
By: Tamas Csabina on Fri, 25 September 2015
0 6893 Fri, 25 September 2015 06:29
By: Tamas Csabina
  Hudson error, E200015: No Credentials to try.
Hudson is not saving credentials to visualsvn (https)
By: Andrew Lucas on Mon, 21 September 2015
2 4857 Tue, 22 September 2015 16:06
By: Andrew Lucas
  git/subversion plugins enhancements
By: Martin Roth on Sat, 24 May 2014
5 50887 Tue, 22 September 2015 11:31
By: Martin Roth
  Tool property not saved?
By: Kaz Nishimura on Tue, 15 September 2015
4 4424 Sat, 19 September 2015 02:46
By: Winston Prakash
  Is it OK to build Hudson plugins for Java SE 7?
By: Kaz Nishimura on Fri, 18 September 2015
6 4210 Fri, 18 September 2015 17:16
By: Kaz Nishimura
  Hudson 3.3.0 no longer supports Maven builds with Java 6?
By: Kaz Nishimura on Thu, 17 September 2015
0 5415 Thu, 17 September 2015 12:25
By: Kaz Nishimura
icon13.gif Mercurial plugin 1.45 fails to clone by Tag
By: Vahe Hovhannisyan on Fri, 04 September 2015
5 6207 Thu, 17 September 2015 06:57
  Automatic min-length workspace root
By: Konstantin Komissarchik on Wed, 16 September 2015
2 3374 Thu, 17 September 2015 01:36
  Hudson 3.3.0 MsBuild plugin fails with NullPointerException
By: Vahe Hovhannisyan on Thu, 10 September 2015
5 5885 Fri, 11 September 2015 13:48
  Deploying WAR to WildFly 8?
By: Kaz Nishimura on Thu, 27 August 2015
8 8305 Mon, 07 September 2015 23:19
By: Kaz Nishimura
  Multiple git repos required for 1 hudson job
By: Douglas Moore on Tue, 01 September 2015
0 5153 Tue, 01 September 2015 21:09
By: Douglas Moore
  Eclipse connection plugin
A question about developing an Eclipse plugin that would provide the user with controls to manage Jenkins
By: Matic Pajni269 on Fri, 28 August 2015
1 4275 Tue, 01 September 2015 07:23
By: Duncan Mills
  Integrating Docker with Hudson
Availability of the Jenkins Docker Plugins for Hudson
By: Timo Rohrberg on Mon, 24 August 2015
0 6127 Mon, 24 August 2015 12:07
By: Timo Rohrberg
  Is there a way to send email notification upon "aborted" build?
By: Michael Yang on Fri, 21 August 2015
0 10272 Fri, 21 August 2015 18:25
By: Michael Yang
  bitbucket plugin issue
By: Bart De Boeck on Fri, 21 August 2015
0 4484 Fri, 21 August 2015 16:40
By: Bart De Boeck
  Mobile usability improvement (not-yet official project)
By: Kaz Nishimura on Thu, 20 August 2015
0 9840 Thu, 20 August 2015 09:51
By: Kaz Nishimura
  Job aborted when updating the config.xml from API
By: Michael Yang on Tue, 11 August 2015
4 4028 Fri, 14 August 2015 18:14
By: Michael Yang
  Online Hudson Java API documents?
By: Kaz Nishimura on Sat, 08 August 2015
2 4719 Mon, 10 August 2015 18:37
By: Winston Prakash
  v2.2.1 Hudson - workspace jobs folders wiped out daily
By: Z W on Wed, 22 July 2015
2 3635 Wed, 05 August 2015 16:19
By: Z W
  Planning to rewrite a Mercurial plugin
By: Kaz Nishimura on Sun, 02 August 2015
1 2730 Mon, 03 August 2015 05:29
By: Winston Prakash
  "Cascading job name set but the instance is not set." errors
By: Kaz Nishimura on Thu, 30 July 2015
0 5106 Thu, 30 July 2015 07:49
By: Kaz Nishimura
icon4.gif Error installing using yum on CentOS
By: Trevor Cole on Tue, 08 January 2013
3 5003 Tue, 28 July 2015 14:53
By: Winston Prakash
  Not able to start Hudson Slave
While starting Hudson its looking another Hudson URL in the same network
By: madhusudhanareddy chilipi on Mon, 20 July 2015
1 4169 Tue, 21 July 2015 21:45
By: Winston Prakash
  Advice requested: Best route for upgrade from version 2.2.1?
By: Matthew Titmus on Mon, 20 July 2015
1 2890 Tue, 21 July 2015 21:40
By: Winston Prakash
  Trying to upgrade from Hudson 3.2.2 to 3.3.0
By: Gary Sturgeon on Fri, 17 July 2015
2 4194 Tue, 21 July 2015 21:19
By: Winston Prakash
icon3.gif Announcement: Hudson 3.3.0 is now available
By: Duncan Mills on Mon, 13 July 2015
0 4411 Mon, 13 July 2015 12:03
By: Duncan Mills
icon4.gif Announcement: Pre-Eclipse Versions of Hudson
0 3317 Mon, 13 July 2015 11:50
By: Duncan Mills
  Subversion Checkout - File Modified Time
Hudson svn checkout to preserve commit time of files
By: lea ilagan on Thu, 09 July 2015
0 3667 Thu, 09 July 2015 09:00
By: lea ilagan
  Perform testing (protactor / selenium) with jenkins with 1024x768 resolution
By: Erick Macedo on Thu, 18 June 2015
2 4208 Sat, 20 June 2015 16:27
By: Erick Macedo
  Cron thread throw an exception
By: Konrad Zielinski on Thu, 20 March 2014
4 6394 Sun, 14 June 2015 05:12
By: Christopher Trevarthen
  Internal Server Error with the Google Login Plugin on Hudson 3.3.0-RC1
By: Kaz Nishimura on Sat, 13 June 2015
1 3430 Sat, 13 June 2015 06:59
By: Kaz Nishimura
  Hudson 3.3.0 Release Candidate is available for Testing
New Release
By: Duncan Mills on Thu, 11 June 2015
4 5646 Sat, 13 June 2015 06:32
By: Kaz Nishimura
icon5.gif Old Hudson cannot checkout from Cloudforge - what is the simplest way to fix?
Hudson 1.345 cannot checkout from Cloudforge bacause doesn't support TLS
By: Vitaly Karasik on Fri, 12 June 2015
0 9038 Fri, 12 June 2015 13:36
By: Vitaly Karasik
  change report plugin
By: Douglas Moore on Mon, 01 June 2015
2 3196 Wed, 03 June 2015 12:57
By: Raymond Breuer
  Hudson 3.2.2 Login error
Http Error 500 when Login to Hudson
By: William Chow on Tue, 02 June 2015
1 3668 Tue, 02 June 2015 20:25
By: Eric Rizzo
  jira plugin 1.36-h-1
By: Douglas Moore on Thu, 07 May 2015
3 3189 Mon, 01 June 2015 15:48
By: Douglas Moore
  Dos trigger jobs throwing exception on save
By: Raymond Breuer on Wed, 27 May 2015
0 3717 Wed, 27 May 2015 08:14
By: Raymond Breuer
  Code collaborator support
Any Hudson plugin support code collaborator tool for peer code review
By: rajeev ranjan on Wed, 13 May 2015
2 4024 Thu, 14 May 2015 16:21
By: Eric Rizzo
Hudson support for Code collaborator
0 3557 Wed, 13 May 2015 20:21
By: rajeev ranjan
icon5.gif Git plugin not working with branch names containing /
By: Henrik Lynggaard Hansen on Wed, 21 January 2015
2 5561 Sun, 10 May 2015 16:42
  Unable to show latest console output
By: Sascha Horn on Wed, 29 April 2015
2 6760 Mon, 04 May 2015 08:34
By: Sascha Horn
  How to evaluate label expressions in a Builder?
By: Kaz Nishimura on Thu, 23 April 2015
4 5985 Fri, 01 May 2015 01:15
By: Kaz Nishimura
  Hudson error 500
There's no "app" attribute in the application context.
By: Guilherme Oliveira on Wed, 22 April 2015
1 3686 Wed, 22 April 2015 20:53
By: Winston Prakash
  Mercurial with Cascading Jobs
By: Kaz Nishimura on Thu, 19 February 2015
7 7144 Wed, 22 April 2015 02:52
By: Winston Prakash
  Hudson Integration with ClearCase on linux box
Getting issues with Hudson configuration with ClearCase on linux box
By: Venugopal Kodumagulla on Tue, 14 April 2015
3 4207 Fri, 17 April 2015 17:26
By: Winston Prakash
  Hudson v2.2.0 can I manually change config settings?
By: mike theriault on Thu, 16 April 2015
1 2559 Thu, 16 April 2015 20:58
By: mike theriault
0 5582 Tue, 14 April 2015 10:44
  Deploy from Hudson-ci server to remote windows server
By: Dmitry Yurin on Fri, 10 April 2015
2 4444 Mon, 13 April 2015 04:51
By: Dmitry Yurin
  Changing PWD in a Builder
By: Kaz Nishimura on Wed, 01 April 2015
2 4449 Thu, 09 April 2015 01:26
By: Kaz Nishimura
  Ignore failures of some configurations in a matrix project?
By: Kaz Nishimura on Thu, 09 April 2015
0 4778 Thu, 09 April 2015 01:20
By: Kaz Nishimura
  Password in Query or Cookie Data
A password was found in the query string of a GET request or Set-Cookie Header.
By: Queenie Chow on Mon, 06 April 2015
1 3358 Tue, 07 April 2015 14:49
By: Denis Roy
  Hudson 3.2.1 and Maven 3.3.1 with Win7 missing mvn.bat-file
Change in Hudson maven3 runner needed to support maven 3.3.1
By: Denis Schettl on Tue, 24 March 2015
2 4529 Wed, 25 March 2015 08:12
By: Denis Schettl
  Hudson polling git on unrelated jobs
By: Peter Janes on Mon, 02 March 2015
2 4883 Tue, 24 March 2015 15:10
By: Peter Janes
  "Tag this build" missing when using Team-based authentication
By: ETHAN HALLBEYER on Fri, 20 March 2015
3 3304 Mon, 23 March 2015 22:56
By: Winston Prakash
  Access SCM on only one node and build elsewhere, is it possible?
By: Kaz Nishimura on Thu, 19 March 2015
3 4172 Mon, 23 March 2015 09:16
By: Kaz Nishimura
  Hudson 'wipe out workspace' and job config 'save' do not complete
By: mike theriault on Wed, 18 March 2015
2 3968 Thu, 19 March 2015 17:25
By: mike theriault
  Build per branch
Do we need to create a job for each branch in a git repo?
By: Kiran Kumar Thuthika on Thu, 30 October 2014
2 4887 Thu, 19 March 2015 16:04
By: Roman .
  Keep users logged-in with federated login services?
By: Kaz Nishimura on Sun, 08 March 2015
2 4974 Thu, 19 March 2015 00:21
By: Kaz Nishimura
  Active Directory configuration problem
Can't configure AD to work properly.
By: Jorge Campos on Tue, 17 September 2013
8 14245 Wed, 18 March 2015 20:50
By: Winston Prakash
  Git Parameter Plugin is missing in Hudson
By: k z on Thu, 17 October 2013
10 9043 Wed, 18 March 2015 03:59
By: Winston Prakash
icon5.gif Hudson cannot find cmake
By: assil benchaaben on Mon, 02 March 2015
1 4251 Sat, 07 March 2015 23:17
By: Kaz Nishimura
  Hudson support
Is Hudson support stops ?
By: Nimi Sukumaran on Tue, 18 November 2014
7 8059 Tue, 03 March 2015 11:34
By: Ravindra Reddy
  NullPointerException in Hudson
By: Eclipse User on Mon, 16 February 2015
3 4913 Tue, 17 February 2015 20:17
By: Winston Prakash
  java.lang.LinkageError: loader constraint violation
By: bunny new on Sun, 25 January 2015
3 7712 Wed, 11 February 2015 20:19
By: Winston Prakash
  How does Hudson know a configuration change with a cascading job?
By: Kaz Nishimura on Fri, 06 February 2015
2 3110 Fri, 06 February 2015 23:57
By: Kaz Nishimura
  Recent Changes is not showing on Hudson Dashboard
After build failure recent changes are not showing for successful builds.
1 5706 Tue, 03 February 2015 07:00
By: Mahesh Gowda
  Error Connecting Oracle Team Productivity Center
By: bunny new on Thu, 29 January 2015
1 3763 Thu, 29 January 2015 10:29
By: Geoff Waymark
  3.1.2: StackOverflowError on creating/mod jobs
StackOverflowError on creating or modifing jobs after upgrade to Hudson 3.1.2
By: Denis Schettl on Mon, 17 February 2014
7 11899 Tue, 27 January 2015 18:54
By: a goettl
  Faster delete / Clean workspace
By: Jeff Foege on Thu, 22 January 2015
1 5459 Fri, 23 January 2015 23:24
By: Winston Prakash
  Advice in moving from java 1.6 to java 1.8
plugins to choose
By: Stephane Tallard on Wed, 14 January 2015
3 5076 Wed, 21 January 2015 13:21
icon5.gif Pushing from Hudson to SCM?
By: Kaz Nishimura on Mon, 19 January 2015
2 3925 Wed, 21 January 2015 00:10
By: Kaz Nishimura
  Hudson on Java EE 7 (CDI 1.1)
Issues when deploying Hudson on a Java EE 7 servers
By: Kaz Nishimura on Tue, 20 January 2015
1 3627 Tue, 20 January 2015 01:43
By: Kaz Nishimura
icon5.gif What is injected to the SmoothiePluginStrategy constructor?
4 3875 Mon, 19 January 2015 23:36
By: Kaz Nishimura
  GoogleTest (gtest) output xunit-Plugin
By: Simon Sareika on Mon, 19 January 2015
0 7523 Mon, 19 January 2015 13:01
By: Simon Sareika
  User Configurations page support for Google Login Plugin?
By: Kaz Nishimura on Thu, 15 January 2015
1 4482 Sat, 17 January 2015 10:48
By: Kaz Nishimura
  Delay loading "Configure Job"
Hudson 3.2.1
By: Juan Carlos Sipan Robles on Thu, 15 January 2015
2 4001 Fri, 16 January 2015 12:18
  Looking forward to Hudson 3.3.0 - Java 7 and Above
By: Duncan Mills on Thu, 15 January 2015
3 4812 Fri, 16 January 2015 07:55
By: Kaz Nishimura
icon4.gif Planned Maintenance on Hudson-ci infrastructure
0 4737 Thu, 15 January 2015 12:57
By: Duncan Mills
  Deploying WAR unarchived?
By: Kaz Nishimura on Sun, 11 January 2015
2 4495 Wed, 14 January 2015 09:43
By: Kaz Nishimura
icon5.gif Dynamically setting job name in ${COPYARTIFACT_BUILD_NUMBER_XXX}
I am using Paramterized Build , and copying artifacts from other build. From this job I am publishing the artifacts to remote folder having JobName/Build# folder structure
By: Ravikumar Ganugapanta on Mon, 05 January 2015
1 5469 Sun, 11 January 2015 03:04
By: Kaz Nishimura
  sctmexecutor plugin
hudson always records jobs success even if test had failures
By: Douglas Moore on Thu, 08 January 2015
2 3160 Fri, 09 January 2015 22:40
By: Winston Prakash
  New FitNesse Instance - FitNesse plugin
By: Ben Pearse on Thu, 01 August 2013
1 4912 Thu, 08 January 2015 13:41
By: gareth curtis
  Hudson 3.2.1 Error
Error during Build when using maven
By: Amit Mawkin on Wed, 31 December 2014
2 6297 Wed, 07 January 2015 21:28
By: Amit Mawkin
  GitHub repository?
By: Kaz Nishimura on Thu, 01 January 2015
3 6123 Tue, 06 January 2015 18:51
By: Winston Prakash
  Current page path in jelly?
By: Kaz Nishimura on Thu, 25 December 2014
3 7590 Tue, 06 January 2015 12:14
By: Kaz Nishimura
  Accessing Google APIs from plugins?
By: Kaz Nishimura on Thu, 18 December 2014
7 5895 Tue, 06 January 2015 02:56
By: Kaz Nishimura
  git repository symlinks get replaced by text files
By: Ludwin Fuchs on Thu, 18 December 2014
2 4523 Tue, 06 January 2015 02:00
By: Winston Prakash
  ANN: Google Login Plugin (Beta)
Release announcement of Google Login Plugin (Beta)
By: Kaz Nishimura on Sun, 21 December 2014
1 7206 Tue, 06 January 2015 01:52
By: Winston Prakash
  Plugin development for Jenkins and Hudson (Json structure differs?!)
By: Ivo Carola on Tue, 23 December 2014
2 4184 Mon, 05 January 2015 09:59
By: Ivo Carola
  Embedded Status Badge
Hudson build status badge
By: ioannis Latousakis on Wed, 31 December 2014
0 6364 Wed, 31 December 2014 12:01
  ANN: Google Login Plugin 2.0 Released
By: Kaz Nishimura on Mon, 29 December 2014
0 7557 Mon, 29 December 2014 05:50
By: Kaz Nishimura
  Implementing page transition in the User Configurations page
By: Kaz Nishimura on Fri, 19 December 2014
1 3875 Fri, 19 December 2014 13:24
By: Kaz Nishimura
  How to deploy Maven artifacts from matrix build
By: Andreas Sewe on Thu, 18 December 2014
0 5612 Thu, 18 December 2014 17:05
By: Andreas Sewe
  Is Hudson Mercurial Plugin actively maintained?
By: Kaz Nishimura on Sun, 07 December 2014
7 7553 Tue, 16 December 2014 19:23
By: Winston Prakash
  ANN: Tool Labels Plugin 3.0
New version announcement
By: Kaz Nishimura on Mon, 15 December 2014
1 3679 Mon, 15 December 2014 19:52
By: Winston Prakash
  What is Latest Maven Build Information page?
By: Kaz Nishimura on Thu, 04 December 2014
6 7069 Sat, 13 December 2014 04:16
By: Kaz Nishimura
  Hudson jobs lose working directory sporadically
By: Christoph Schmitz on Mon, 08 December 2014
2 4421 Thu, 11 December 2014 07:47
  Node priority
By: Mario Charest on Tue, 25 November 2014
1 6073 Thu, 11 December 2014 00:52
By: Winston Prakash
  hudson job failing
By: nagesh shenishetty on Fri, 06 December 2013
5 60958 Thu, 11 December 2014 00:30
By: Winston Prakash
  GIT - clean checkout fails
By: k z on Mon, 13 May 2013
22 40574 Thu, 11 December 2014 00:26
By: Winston Prakash
  Hudson with HTTPS
By: Frederic Filiatrault on Tue, 23 April 2013
4 5841 Wed, 10 December 2014 20:37
By: Winston Prakash
  "Build when Maven dependencies have been updated" uses transitive dependencies?
Seems that the maven dependency support includes transitive deps.
By: Joel F on Mon, 17 November 2014
0 4933 Mon, 17 November 2014 22:40
By: Joel F
icon2.gif How to test REST Client using Hudson
By: Xtreme Sony on Sun, 26 October 2014
3 6856 Wed, 12 November 2014 00:04
By: Winston Prakash
  change to default port
I need to change the default port of Hudson -8080
By: Nimi Sukumaran on Fri, 24 October 2014
3 7296 Sat, 25 October 2014 04:23
By: Winston Prakash
  NoClassDefFoundError after successful build
Sending test results to Oracle Team Productivity Team Server
By: z s on Wed, 08 October 2014
7 10868 Thu, 16 October 2014 14:26
By: Geoff Waymark
icon2.gif New plugin hosting request
broadcast-message-plugin
By: Patryk Szczęch on Tue, 16 September 2014
15 14509 Wed, 01 October 2014 08:14
  3.2.1?
By: Serge Burlyga on Fri, 26 September 2014
1 3495 Fri, 26 September 2014 21:47
By: Winston Prakash
  .nfs file lock
.nfs file lock issue
By: Nimi Sukumaran on Wed, 24 September 2014
6 8212 Thu, 25 September 2014 14:43
By: Nimi Sukumaran
  Multi configuration project for two different builds
By: alban hudson on Tue, 23 September 2014
0 6226 Tue, 23 September 2014 09:30
By: alban hudson
  How to configure remote location deployment
By: Preejith Kuppadakath on Mon, 17 February 2014
3 5226 Mon, 22 September 2014 10:03
By: gagan singh
  hudson hg clone --branch
hudson hg clone a branch
By: Lina Muryanto on Wed, 17 September 2014
1 7457 Thu, 18 September 2014 13:34
By: Eric Rizzo
  Team Members Privilege Assignment
I have created team in Hudson by enabling Security and under Manage team created a team. I created users as well. I want to assign these users to newly created team. I don't see option of add team mem
By: Charandeep Hora on Tue, 16 September 2014
3 4864 Wed, 17 September 2014 19:24
By: Winston Prakash
  Hudson Clearcase plugin not showing up
By: Subramanyan Swaminathan on Mon, 08 September 2014
2 4143 Tue, 09 September 2014 16:07
  Hudson 3.2.0 Final is now available
By: Greg Stachnick on Tue, 19 August 2014
14 10912 Fri, 05 September 2014 06:18
By: Gerry Deng
  Hudson Migration Steps from 2.2.0 to 3.0.1 on windows2008 server
hudsom migration
By: Mahesh Gowda on Fri, 23 August 2013
4 10092 Mon, 01 September 2014 10:12
By: Mahesh Gowda
Current Time: Mon Dec 30 16:54:39 GMT 2024
Powered by FUDForum. Page generated in 0.04341 seconds
