  Update error
Update error
By: Eclipse User on Wed, 26 June 2024
2 4363 Thu, 27 June 2024 09:58
  How to modify and save a BPMN model?
modify and save a BPMN model properly
By: Eclipse User on Fri, 10 November 2023
2 2505 Thu, 16 November 2023 04:15
  Question
By: Eclipse User on Sat, 04 March 2023
1 2176 Wed, 11 October 2023 14:33
  Installation not possible - Modeler no longer supported?
Cannot install Modeler Plugin into lastest Eclipse version
By: Eclipse User on Thu, 06 July 2023
0 6019 Thu, 06 July 2023 11:04
  How to extend modeler with custom features
By: Eclipse User on Fri, 07 April 2023
2 1736 Sun, 09 April 2023 09:30
  Visualize BPMN diagram using BPMN2 in a new java application
By: Eclipse User on Wed, 18 December 2013
4 4770 Mon, 13 February 2023 17:20
  How to mention software tool (MS Excel, SAP etc.) in an activity during process mapping
By: Eclipse User on Thu, 09 February 2023
1 1766 Mon, 13 February 2023 17:18
  Difference between new model and new generic diagram
By: Eclipse User on Sat, 15 October 2022
1 2785 Wed, 19 October 2022 15:45
  Subprocess issue on opening
Subprocesses when opening file are not in the status stored in the last save
By: Eclipse User on Fri, 30 September 2022
0 2240 Fri, 30 September 2022 04:13
  Does BPMN Editor generate invalid UniqueId? (id attribute in XML file)
id attribute in XML file is no valid NCName. JBPM refuses to accept.
By: Eclipse User on Fri, 23 September 2022
2 3477 Mon, 26 September 2022 03:33
  BPMN model
By: Eclipse User on Tue, 14 June 2022
4 4328 Wed, 15 June 2022 04:51
  BPMN live model execution
By: Eclipse User on Wed, 08 June 2022
0 3788 Wed, 08 June 2022 11:46
  Blurry context buttons on subsequent use
By: Eclipse User on Sun, 05 June 2022
2 3778 Tue, 07 June 2022 04:46
  using Bpmn2DiagramEditorInput to change the bp diagram programmatically
By: Eclipse User on Fri, 13 May 2022
2 4957 Thu, 26 May 2022 12:37
  Instantiating and Populating BP diagrams programmatically
By: Eclipse User on Thu, 05 May 2022
6 4401 Wed, 11 May 2022 09:10
  Moving JBPM componentes into separate Extension project
We plan to move the JBPM components of Eclipse-BPMN2 into a separate extension project.
By: Eclipse User on Sat, 18 December 2021
0 4056 Sat, 18 December 2021 01:03
  Exporting BPMN diagram to SVG
Exporting BPMN diagrams in SVG returns an error (BPMN2 modeller 1.5.3 on Eclipse 2021-09)
By: Eclipse User on Mon, 06 December 2021
3 3969 Sat, 18 December 2021 00:57
  ServiceTask should have only one incoming connection.
By: Eclipse User on Mon, 08 November 2021
2 2296 Mon, 08 November 2021 19:10
  Migrating Eclipse BPMN2 Modeler to web
By: Eclipse User on Wed, 18 August 2021
2 3266 Tue, 24 August 2021 08:23
  How to pick an Icon in a CustomTask
Questions about how to specify custom Elements as an Extension of the BPMN2 Modeler
By: Eclipse User on Mon, 03 May 2021
3 2708 Tue, 10 August 2021 17:42
  Code snippet for export diagram feature
Is that possible to write a java api to export a image from bpmn2 model
By: Eclipse User on Fri, 12 December 2014
2 6158 Tue, 10 August 2021 17:38
  BPMN 2.0 Modeler Plugin
Failure to run plugin
By: Eclipse User on Fri, 21 May 2021
1 2746 Tue, 25 May 2021 06:35
  Survey as part of my bachelor thesis
topic: Diffusion rate of open source business software
2 1825 Tue, 04 May 2021 02:43
  Create a new BPM Project
By: Eclipse User on Wed, 18 November 2020
1 2181 Wed, 18 November 2020 12:21
  Problem install BPMN2 Modeler Core
I have problem install BPMN2 Modeler Core 1.5.1.Final-v20190425-2005-B1 into Red Hat CodeReady Studio
By: Eclipse User on Wed, 22 July 2020
2 5836 Thu, 23 July 2020 02:55
  Anyone ever couple (Import/Export) a BPMN(2.0) diagram to UML(Papyrus)
UML, Papyrus, BPMN 2.0 Modeler and interop (Import/Export) per spec 8.3.4
By: Eclipse User on Tue, 14 July 2020
2 2737 Wed, 15 July 2020 16:51
  HowTo question
Collaboration, Choreography, Conversations, Process, and inter-op within BPMN Modeler2
By: Eclipse User on Sun, 12 July 2020
3 2308 Wed, 15 July 2020 12:10
  triage usage before file a bug
Bug Choreography ChoreographyTask Add Participant
By: Eclipse User on Mon, 13 July 2020
1 2248 Wed, 15 July 2020 12:00
  Import dataobjects?
Is ist possible to import data objects
By: Eclipse User on Mon, 22 June 2020
2 2098 Tue, 23 June 2020 02:44
  BPMN 2.0 Modeler for Eclipse 2020-03
By: Eclipse User on Wed, 25 March 2020
1 2542 Wed, 25 March 2020 09:36
  How do i retrieve the xml code ?
By: Eclipse User on Wed, 18 March 2020
1 2128 Wed, 18 March 2020 09:26
  help with a deadlock
By: Eclipse User on Mon, 16 March 2020
1 2622 Wed, 18 March 2020 08:10
  BPMN2 Create new tab for the Task class
By: Eclipse User on Fri, 06 March 2020
3 2401 Wed, 11 March 2020 14:01
  BPMN2 Modeler extensions
Interesting blog about BPMN2 Modeler extensions
By: Eclipse User on Wed, 13 March 2019
2 4042 Tue, 15 October 2019 11:10
  Question parameters from .wid file tab "I/O Parameters"
why are the parameters and results from the wid-file not in the tab "I/O-Paramters"?
By: Eclipse User on Wed, 03 July 2019
3 4546 Wed, 28 August 2019 04:41
  BPMN2 Property Page Redraw Loop
By: Eclipse User on Wed, 06 March 2019
1 3171 Wed, 13 March 2019 16:31
  Can I extend twice the same object using modelExtension ?
By: Eclipse User on Thu, 01 November 2018
1 3363 Mon, 05 November 2018 14:29
  Can anyone tell me how to debug the Eclipse BPMN2 Modeler source code
By: Eclipse User on Thu, 16 August 2018
2 5268 Wed, 26 September 2018 08:56
  How to extract the part of source code of Eclipse BPMN2 Modeler that automatically generates DI info
By: Eclipse User on Mon, 13 August 2018
0 4318 Mon, 13 August 2018 15:18
  Why can't I display processes in my BPMN file with collaboration ?
I create an xml bpmn file with collaboration info and no BPMN Diagram info. The modeler only generate empty pools for me
By: Eclipse User on Thu, 09 August 2018
3 5525 Fri, 10 August 2018 17:21
  Poll: Who will attend EclipseCon Europe 2018?
By: Eclipse User on Wed, 01 August 2018
0 8407 Wed, 01 August 2018 07:59
  java.lang.ClassCastException: org.eclipse.bpmn2.impl.ExpressionImpl incompatible with org.eclipse.bp
save and close the diagram, and reopen it, and double click user task
By: Eclipse User on Tue, 24 July 2018
0 4074 Tue, 24 July 2018 10:08
  Loss of my shape decoration
By: Eclipse User on Wed, 25 April 2018
7 5863 Sun, 22 July 2018 12:06
  Key 'namespace' ignored when generating genmodel
By: Eclipse User on Sat, 21 July 2018
0 3578 Sat, 21 July 2018 08:22
  Creating process documentation
By: Eclipse User on Sun, 01 July 2018
0 3528 Sun, 01 July 2018 09:13
  Does the customtasks example work ?
By: Eclipse User on Thu, 28 June 2018
3 3364 Fri, 29 June 2018 04:47
  Other problems when saving BPMN models
The Process ID is Invalid: Sub20%process20%AB
By: Eclipse User on Fri, 15 June 2018
2 3419 Wed, 20 June 2018 04:02
  Problem when saving a model
By: Eclipse User on Sat, 26 May 2018
2 3888 Tue, 29 May 2018 18:04
  problem with displaying large diagram
By: Eclipse User on Wed, 22 November 2017
8 11920 Sun, 27 May 2018 04:36
  Trigger the update of an other instance of my extension
By: Eclipse User on Thu, 03 May 2018
2 5023 Thu, 10 May 2018 10:23
  BPMN Plugin extraction
1 2802 Thu, 26 April 2018 03:44
  Feature null
By: Eclipse User on Thu, 01 March 2018
6 4214 Thu, 05 April 2018 17:19
  Icon in the customTask shape
By: Eclipse User on Fri, 30 March 2018
12 6697 Thu, 05 April 2018 05:59
  Receive Task validation error vs. BPMN specification
1 4129 Tue, 06 March 2018 04:46
  Example: Implementing an Extension
We would like to implement an extension to bpmn2-modeler
By: Eclipse User on Mon, 26 February 2018
1 3305 Wed, 28 February 2018 03:59
  I can't get the defined properties
By: Eclipse User on Sun, 03 December 2017
6 8014 Thu, 08 February 2018 07:55
  Extende Palette Tool
I would like to configure Palette to easily add callActivity and userTask with predefined input and output
By: Eclipse User on Thu, 18 January 2018
0 5253 Thu, 18 January 2018 08:06
  Generated custom workeditors are using invalid imports
By: Eclipse User on Fri, 15 December 2017
0 6014 Fri, 15 December 2017 09:39
  Build Error
Lots of building errors
By: Eclipse User on Fri, 01 December 2017
1 4898 Mon, 11 December 2017 07:15
  Creating more than one extension
0 5645 Wed, 22 November 2017 09:58
  Create Elements Programmatically
By: Eclipse User on Mon, 30 October 2017
5 7297 Tue, 21 November 2017 03:46
  I want to add an customxml editor.
By: Eclipse User on Sun, 19 November 2017
0 5676 Sun, 19 November 2017 20:38
  Problem in ExtendingRuntime tutorial
By: Eclipse User on Thu, 16 November 2017
1 2808 Sat, 18 November 2017 06:33
  How to cofigurate ServiceTask?
Configuration of 'serviceTask'
By: Eclipse User on Wed, 13 September 2017
2 14149 Mon, 30 October 2017 11:05
  Diagrams in BPMN2 distorted
By: Eclipse User on Fri, 27 October 2017
0 4279 Fri, 27 October 2017 14:47
  Pattern implementation
By: Eclipse User on Fri, 13 October 2017
2 3311 Fri, 13 October 2017 07:45
  Extend Annotation
Extend Annotations Element
By: Eclipse User on Thu, 14 March 2013
7 11985 Fri, 13 October 2017 07:29
  Loss of type information?
By: Eclipse User on Thu, 05 October 2017
0 7217 Thu, 05 October 2017 07:29
  Pop-up sub-process
Pop-up sub-process doesn't work
By: Eclipse User on Fri, 25 August 2017
1 7434 Sat, 26 August 2017 05:23
  Extending SubChoreography [context button pad]
By: Eclipse User on Wed, 26 July 2017
1 10230 Mon, 31 July 2017 15:41
icon3.gif New Tutorial - How To Start Contributing
By: Eclipse User on Sat, 13 May 2017
0 51910 Sat, 13 May 2017 09:14
  jBPM with BPMN 2.0 modeler
Process execution of BPMN 2.0 process in eclipse with jBPMN
By: Eclipse User on Mon, 17 April 2017
1 27587 Wed, 26 April 2017 17:52
  Example Models
Looking for example models
By: Eclipse User on Tue, 11 April 2017
2 6513 Wed, 26 April 2017 17:47
  CDATA in Sequence Flow Condition
By: Eclipse User on Wed, 22 March 2017
3 8828 Thu, 23 March 2017 08:55
  BPMN Element Labels
By: Eclipse User on Thu, 16 February 2017
2 25776 Mon, 13 March 2017 01:47
  Transfert message between activities in two pool
By: Eclipse User on Sat, 11 March 2017
0 9461 Sat, 11 March 2017 09:31
  BPMN1.2 to BPMN2.0
By: Eclipse User on Wed, 01 March 2017
1 3590 Wed, 01 March 2017 08:41
  BPMN to BPMT
By: Eclipse User on Sat, 25 February 2017
0 11796 Sat, 25 February 2017 17:33
  haw add pool in BMPT
By: Eclipse User on Thu, 23 February 2017
6 5105 Fri, 24 February 2017 17:21
  Error, please check if there is a FeatureModel/exemple_FM.xml
Error
By: Eclipse User on Wed, 22 February 2017
2 3349 Wed, 22 February 2017 11:07
  Internal Error: propertyTab
By: Eclipse User on Mon, 20 February 2017
0 12522 Mon, 20 February 2017 03:26
  NullPointerException : public class MytaskPropertySection extends DefaultPropertySection
By: Eclipse User on Fri, 17 February 2017
0 15976 Fri, 17 February 2017 18:13
  How to open/convert/import/transform old STP BPMN models to BPMN 2.0 Modeler?
By: Eclipse User on Thu, 09 February 2017
2 5331 Thu, 16 February 2017 03:58
  new properties to existing BPMN elements
By: Eclipse User on Sun, 12 February 2017
2 6016 Tue, 14 February 2017 04:35
  PropertyExtension
entending ResourceRole
By: Eclipse User on Wed, 08 February 2017
5 5332 Mon, 13 February 2017 08:02
  Namespace prefix in definitions
By: Eclipse User on Tue, 07 February 2017
2 5063 Sun, 12 February 2017 16:17
  Extending ResourceRole
0 28868 Sun, 12 February 2017 03:46
  CustomTaskFeautureContainer is missing
By: Eclipse User on Sun, 05 February 2017
1 2653 Tue, 07 February 2017 12:23
  Adding attributes, specifying their type at runtime
By: Eclipse User on Wed, 03 September 2014
2 4280 Mon, 06 February 2017 12:43
  how to execute a business process
By: Eclipse User on Mon, 06 February 2017
3 4280 Tue, 07 February 2017 10:18
  how to set Custom Task default value
By: Eclipse User on Wed, 21 December 2016
1 13255 Fri, 13 January 2017 03:15
  Multiple Instances Embedded SubProcess Input Instance Parameter Problem
By: Eclipse User on Thu, 24 November 2016
0 7122 Thu, 24 November 2016 07:28
  In memory 2 sequence flow created while loading the resource file.
Reloading the bpmn file with custom task is showing duplicate sequence flow.
By: Eclipse User on Fri, 11 November 2016
0 42610 Fri, 11 November 2016 00:31
  Several identical elements in <extensionElements> tag
By: Eclipse User on Mon, 26 September 2016
1 8539 Mon, 07 November 2016 09:10
  Latest Stable Channel
By: Eclipse User on Fri, 21 October 2016
1 3062 Fri, 21 October 2016 11:07
  Save the progress of a Model
By: Eclipse User on Wed, 12 October 2016
6 5192 Thu, 20 October 2016 14:59
  Problem I/O Parameter.
3 4359 Wed, 12 October 2016 20:23
icon5.gif how add a pattern of workflow by means of code?
By: Eclipse User on Thu, 01 September 2016
3 33683 Mon, 10 October 2016 11:25
  Change font of selected elements
By: Eclipse User on Fri, 23 September 2016
1 4055 Fri, 23 September 2016 10:54
  Change default drag/drop of task to abstract from script
How do I Change default drag/drop of task to abstract from script
By: Eclipse User on Mon, 29 August 2016
5 4374 Tue, 13 September 2016 10:05
  Can't create new BPMN2 model - project does not exist? Select parent folder?
By: Eclipse User on Wed, 02 January 2013
3 8014 Wed, 31 August 2016 15:07
  Add pattern with Subprocess
I need to add a pattern in the tool palette...
3 3596 Tue, 30 August 2016 11:54
  Need Help understand Call Activity.
By: Eclipse User on Tue, 26 July 2016
2 4722 Fri, 19 August 2016 06:02
  output BPMN standard
version of generated BPMN format
By: Eclipse User on Mon, 15 August 2016
1 5125 Wed, 17 August 2016 14:15
  No Default Tabs from BPMN2.0 Modeller
I am trying to fix the order of the Tab when it is repaced by Custom Task.
By: Eclipse User on Mon, 08 August 2016
5 4842 Tue, 16 August 2016 08:51
icon4.gif It miss cases/icons into End event list : Cancel End event and multiple End event
You don't respect BPM notation v2.0 : it miss 2 cases.
By: Eclipse User on Thu, 28 July 2016
1 5346 Tue, 09 August 2016 16:49
  Import of BPMN Models on server
By: Eclipse User on Thu, 14 July 2016
1 5013 Tue, 09 August 2016 16:46
  Using BPMN2 Model in maven
By: Eclipse User on Wed, 06 July 2016
1 4899 Fri, 08 July 2016 11:33
  Dynamically update the layout of a customTaskElement
By: Eclipse User on Tue, 31 May 2016
10 11040 Thu, 23 June 2016 13:30
  How to place a second icon into a CustomShapeFeatureContainer
By: Eclipse User on Sat, 04 June 2016
4 8130 Mon, 20 June 2016 10:14
  How to use a custom icons?
2 6876 Sun, 19 June 2016 03:55
  How to open bpmn files properly
By: Eclipse User on Tue, 14 June 2016
2 5752 Wed, 15 June 2016 17:40
  Help save the BPMN2 Modeler Project from extinction!
By: Eclipse User on Thu, 03 March 2016
8 12653 Tue, 14 June 2016 10:08
  Overriding Validation Through Constraint
Way to figure out to override the BPMN Model Validation.
By: Eclipse User on Mon, 30 May 2016
1 4819 Tue, 31 May 2016 07:08
  Neon M2 build is not available
By: Eclipse User on Thu, 26 May 2016
0 4394 Thu, 26 May 2016 11:53
  Validation Error Decorations do not show
By: Eclipse User on Wed, 25 May 2016
3 5964 Sat, 28 May 2016 08:43
  change color with code
By: Eclipse User on Tue, 24 May 2016
6 7137 Sat, 04 June 2016 12:21
icon1.gif How refresh diagram?
I need to refresh the diagram to update a task
By: Eclipse User on Mon, 16 May 2016
2 3532 Tue, 17 May 2016 19:44
  Cannot collapse subtask
By: Eclipse User on Sat, 14 May 2016
3 4671 Thu, 26 May 2016 09:51
  Format : any for uploaded bpmn file in workbench
I am unable to open Uploaded bpmn file in kie workbench. Found that in metadata format:any
By: Eclipse User on Thu, 05 May 2016
2 3919 Thu, 26 May 2016 01:41
  EventBasedGateway with catch events always shows validation errors
EventBasedGateway always shows validation error (Gateway sequence should have condition) when used with catch events
By: Eclipse User on Fri, 22 April 2016
1 4553 Sun, 24 April 2016 13:45
  How do I create a custom editor with the BPMN2 Modeler?
By: Eclipse User on Wed, 20 April 2016
2 5194 Thu, 21 April 2016 06:06
  Change Process ID, BPMN2 elements ID
By: Eclipse User on Thu, 14 April 2016
7 9587 Wed, 04 May 2016 01:19
  Extending a Participant
1 3973 Thu, 14 April 2016 11:50
  Pallete Customization
Removing existing Palette
By: Eclipse User on Tue, 12 April 2016
2 6294 Tue, 12 April 2016 23:29
  add a constraint to a custom task
By: Eclipse User on Fri, 08 April 2016
1 4897 Mon, 11 April 2016 09:27
  Looking for translations
1 3919 Sat, 09 April 2016 08:29
  Generate an image of bpmn file
By: Eclipse User on Wed, 06 April 2016
3 4838 Wed, 06 April 2016 15:59
  Replacing Tab doesn't work
By: Eclipse User on Mon, 21 March 2016
1 3801 Mon, 21 March 2016 07:28
  Customtask features no longer recognized
By: Eclipse User on Sun, 20 March 2016
2 4329 Mon, 21 March 2016 13:04
  BPMN2 Modeler 1.2.4.CR1 - looks good to me!
By: Eclipse User on Fri, 18 March 2016
1 3063 Fri, 18 March 2016 15:02
  ClassCastException for console view from BPMEditor
1 4493 Fri, 18 March 2016 10:07
  New builds available for Mars and Luna
By: Eclipse User on Thu, 17 March 2016
0 5720 Thu, 17 March 2016 15:57
  bindAttribute did not work in case of copy&pase
By: Eclipse User on Sat, 12 March 2016
2 4852 Tue, 15 March 2016 03:40
  v1.3.0: Strange Behavior of 'Edit Script Task'
v1.3.0 / Edit Script Task
By: Eclipse User on Thu, 10 March 2016
2 2986 Thu, 10 March 2016 12:36
  Text box height of the Script field of Script Tasks
Script Task/Properties View/Script field
4 4254 Sat, 12 March 2016 03:33
  open wizard bpmn2
By: Eclipse User on Wed, 09 March 2016
0 5207 Wed, 09 March 2016 12:28
  NPE While creating SequenceFlow between events after Mars.2 update
15 9382 Tue, 15 March 2016 07:14
  Creating new features in my elements for some actions
By: Eclipse User on Tue, 08 March 2016
6 9041 Tue, 05 April 2016 15:33
  Exception while opening bpmn Editor After Mars.2 Update
BPMN Editor Opening Issue
18 16172 Thu, 21 April 2016 05:45
  Custom Task
By: Eclipse User on Wed, 02 March 2016
3 5775 Tue, 08 March 2016 12:22
  add a new workflow pattern bpmn 2.0
By: Eclipse User on Fri, 26 February 2016
0 7940 Fri, 26 February 2016 07:50
  Add a new workflow pattern
12 16141 Tue, 26 April 2016 17:06
  NoClassDefFoundError DefaultBpmn2RuntimeExtension$RootElementParser - after update to 1.2.3
By: Eclipse User on Wed, 10 February 2016
2 4667 Wed, 10 February 2016 17:01
  Schema Read Problem After Update
After updating plugin I get schema_reference.4: Failed to read schema document
By: Eclipse User on Fri, 08 January 2016
1 7449 Fri, 15 January 2016 17:15
  Import existing Pool from other file to Collaboration diagram
By: Eclipse User on Thu, 07 January 2016
1 8088 Thu, 18 February 2016 15:23
  Is anyone using WSIL support?
By: Eclipse User on Fri, 13 November 2015
0 5246 Fri, 13 November 2015 11:49
  Sources - Which Tag for current development in 1.2.1
By: Eclipse User on Thu, 12 November 2015
9 5125 Mon, 30 November 2015 13:01
  Some things we're working on for Neon
0 5071 Thu, 12 November 2015 11:47
  Using @Autowired in User Task > On Exit Script to call Spring Service
JBPM 6.2 :: Calling Spring Service from Eclipse BPMN2 Modeller Screen for User Task > Exit Script
By: Eclipse User on Sat, 17 October 2015
1 4727 Tue, 20 October 2015 07:58
  Bpmn2 diagram editor - Properties, constraint field is not showing up
By: Eclipse User on Fri, 25 September 2015
1 4193 Sat, 26 September 2015 07:02
  BIRT Publishing
BIRT Publishing
By: Eclipse User on Mon, 07 September 2015
1 2700 Tue, 08 September 2015 11:22
  Cannot add Called Element containing a hyphen
Getting error message 'The Activity ID is not valid.'
By: Eclipse User on Fri, 28 August 2015
2 4229 Mon, 31 August 2015 18:15
  Warnings and error badges not being displayed
Warnings and errors for a diagram I'm creating aren't being displayed.
By: Eclipse User on Tue, 25 August 2015
7 5435 Thu, 27 August 2015 11:12
  Extending Resoure element
By: Eclipse User on Thu, 13 August 2015
0 4986 Thu, 13 August 2015 15:13
  Eclipse BPMN2 Modeler and Activiti Designer metamodels question
About the tools mentioned compatibility at the metamodel level
By: Eclipse User on Wed, 29 July 2015
1 8175 Tue, 20 October 2015 08:03
icon3.gif Eclipse Mars on Debian Jessie with Gnome 3
By: Eclipse User on Sat, 04 July 2015
1 4387 Tue, 07 July 2015 16:05
  Mars, Luna and the Graphiti dependencies....
By: Eclipse User on Fri, 26 June 2015
2 4697 Sat, 04 July 2015 05:58
  The referenced BPMN element does not exist.
By: Eclipse User on Thu, 18 June 2015
3 3997 Wed, 10 February 2016 12:43
  Developer Tutorial: Validation
By: Eclipse User on Tue, 16 June 2015
0 4165 Tue, 16 June 2015 19:22
icon5.gif Ctrl + A (select all ) + [delete] operations caused Exception.
2 3285 Sun, 21 June 2015 18:15
  Using BPMN2 modeler API
Using API in java project
By: Eclipse User on Sun, 14 June 2015
1 3948 Mon, 15 June 2015 12:36
icon5.gif We want to create a custom validation logic
4 4341 Sun, 21 June 2015 18:25
icon5.gif generate org.eclipse.bpmn2 source code from BPMN20.genmodel
By: Eclipse User on Mon, 01 June 2015
2 5202 Thu, 18 June 2015 23:41
  Re: Exception while opening diagram
By: Eclipse User on Wed, 27 May 2015
1 4249 Wed, 10 June 2015 13:28
icon9.gif Custom SequenceFlow's extended properties doesn't work for bpmn2.
By: Eclipse User on Sat, 23 May 2015
3 4538 Mon, 15 June 2015 12:31
  Difference between BPEL and BPMN
By: Eclipse User on Tue, 19 May 2015
1 5189 Fri, 29 May 2015 02:21
  Copy/pasting pools between diagrams are supposed to work?
By: Eclipse User on Thu, 07 May 2015
2 4523 Fri, 08 May 2015 04:52
  Vertical align doesn't work between lanes?
2 3940 Fri, 08 May 2015 04:46
  Breaking Eclipse with a model made with Modeler
The model I've created seems to have some inconsistence it breaks Eclipse
By: Eclipse User on Wed, 06 May 2015
3 3973 Fri, 08 May 2015 04:55
  Problem adding attributes to Conversation
Attributes not visible in properties window
By: Eclipse User on Thu, 30 April 2015
0 4659 Thu, 30 April 2015 03:40
  Export diagram as html file
I wanna know if it's possible to export a diagram to html file (like a web file that can be "surfed / navigable"), as we can do with the Bizagi publishing as web.
By: Eclipse User on Mon, 27 April 2015
1 6261 Wed, 29 April 2015 05:04
  Developer Tutorial : ToolPalettes
By: Eclipse User on Wed, 22 April 2015
1 4504 Wed, 29 April 2015 11:58
  Bpmn2ResourceImpl stores different output than the modeler
0 4496 Wed, 22 April 2015 08:42
  One or two runtimes?...
By: Eclipse User on Wed, 15 April 2015
3 3966 Fri, 17 April 2015 09:51
  Adding default information for new process files
3 3964 Fri, 17 April 2015 09:54
  How to change the Label of a extended featureContainer
2 3899 Wed, 22 April 2015 16:06
icon3.gif Documentation about extending the BPMN 2.0 Modeler
Where to find documentation about extending the BPMN 2.0 Modeler?
By: Eclipse User on Tue, 14 April 2015
5 5300 Wed, 22 April 2015 13:26
  Routing problem with Lanes since version 1.1.2?
By: Eclipse User on Mon, 13 April 2015
1 3576 Mon, 13 April 2015 21:29
icon5.gif How to validate incoming connections?
By: Eclipse User on Sat, 11 April 2015
6 6651 Wed, 15 April 2015 13:30
  Creating a documentation of BPMN 2.0 model
BPMN 2.0 modeller, documenting model
By: Eclipse User on Tue, 07 April 2015
3 4635 Thu, 09 April 2015 12:01
  Replacing property tab did overwrite all model objects?
By: Eclipse User on Thu, 02 April 2015
3 4061 Fri, 03 April 2015 12:29
  TextObjectEditor - setMultiLine(true) not working as expected?
By: Eclipse User on Tue, 24 March 2015
2 3501 Fri, 27 March 2015 12:37
  GMF/EFM BPMN2 Modeler project
We are find GMF/EFM BPMN2 Modeler project
3 3868 Mon, 30 March 2015 09:46
  User task with notification
By: Eclipse User on Fri, 20 March 2015
1 3924 Mon, 23 March 2015 15:34
  default sequence flow gets lost when adding new condition
By: Eclipse User on Wed, 18 March 2015
2 5185 Tue, 24 March 2015 05:15
  Create the updatesite
By: Eclipse User on Sat, 14 March 2015
7 6563 Wed, 25 March 2015 03:17
  Finally, some tutorials explaining how to use all of this cra... stuff
By: Eclipse User on Wed, 11 March 2015
0 4370 Wed, 11 March 2015 18:06
  Updated Custom Task example
By: Eclipse User on Tue, 10 March 2015
0 4368 Tue, 10 March 2015 12:22
  No, I haven't been hit by a bus...
...I've just been very busy lately
By: Eclipse User on Sat, 07 March 2015
1 3191 Sat, 07 March 2015 18:08
icon5.gif How to append a text node to a EObject
8 7205 Mon, 30 March 2015 09:32
  Define a customized BPMN modeler palette
By: Eclipse User on Fri, 06 March 2015
0 4430 Fri, 06 March 2015 17:59
  What is the difference between bindAttribute() and bindReference() ?
1 3797 Tue, 10 March 2015 10:02
  Process level ioSpecification
Will modeler support ioSpecification under process element?
By: Eclipse User on Thu, 05 March 2015
1 4636 Tue, 10 March 2015 10:08
icon5.gif How to extend a EventDefinition ?
By: Eclipse User on Wed, 04 March 2015
2 4853 Mon, 09 March 2015 20:51
icon9.gif Latest BPMN2 modeler not working for JBPM
By: Eclipse User on Tue, 03 March 2015
4 9506 Tue, 01 December 2015 01:21
icon5.gif opening extended bpmn file
about re-opening bpmn file created with Bpmn-Modeler extension plugin
By: Eclipse User on Sun, 01 March 2015
7 8069 Sat, 14 March 2015 12:29
  How to extend a model entry at runime
1 3552 Sun, 01 March 2015 16:41
  How to implement a custom property section?
By: Eclipse User on Fri, 27 February 2015
1 3438 Tue, 03 March 2015 15:40
icon5.gif Who can help me to extend the BPMN2 Plugin?
How to extend the BPMN Modler to work with Imixs-Workflow?
By: Eclipse User on Sun, 22 February 2015
4 5572 Tue, 10 March 2015 08:26
Current Time: Tue Oct 21 08:20:42 EDT 2025
Powered by FUDForum. Page generated in 0.04417 seconds
