Announcement: Forum closed By: Eclipse User on Tue, 05 December 2023 |
1863 |
Tue, 05 December 2023 11:54 By: Eclipse User  |
Announcement: LDT need new contributors/committers ! By: Eclipse User on Thu, 21 December 2017 |
53427 |
Mon, 04 December 2023 05:55 By: Eclipse User  |
Trouble with installation of Lua stable in latest Eclipse By: Eclipse User on Sun, 03 January 2021 |
2077 |
Tue, 05 December 2023 11:13 By: Eclipse User  |
Trouble installing Lua Development Tools missing dependency for LDT By: Eclipse User on Thu, 05 August 2021 |
3526 |
Tue, 05 December 2023 11:12 By: Eclipse User  |
Unable to install LDT to Eclipse 2019-12 (4.14.0) By: Eclipse User on Sun, 05 January 2020 |
13274 |
Tue, 05 December 2023 11:10 By: Eclipse User  |
Trouble understanding how to declare a field type. By: Eclipse User on Fri, 08 October 2021 |
22155 |
Fri, 08 October 2021 15:10 By: Eclipse User  |
Need help getting started with Lua & luaunit or MoreUnit in Eclipse lua, luaunit, moreunit By: Eclipse User on Fri, 08 January 2021 |
4050 |
Fri, 08 January 2021 19:54 By: Eclipse User  |
Cant start debugger Error: Debugging Engine takes too long to initialize By: Eclipse User on Sat, 13 April 2019 |
27630 |
Fri, 08 January 2021 00:48 By: Eclipse User  |
Moose debugging thru dcs connects but fails on lua code Lua code not recognized by jave somehow By: Eclipse User on Sun, 24 May 2020 |
2800 |
Mon, 25 May 2020 16:27 By: Eclipse User  |
just downloaded Lua development tools & no Autocorrect No autocorrect , can't find a sub dir it just created , can't find ERROR LOG By: Eclipse User on Thu, 21 May 2020 |
2208 |
Sun, 24 May 2020 20:22 By: Eclipse User  |
Tilde no longer working in LDT I lost the ability to write ~ in LDT several months ago By: Eclipse User on Mon, 04 May 2020 |
2892 |
Thu, 07 May 2020 14:11 By: Eclipse User  |
LDT and Roblox By: Eclipse User on Sun, 16 February 2020 |
3715 |
Mon, 17 February 2020 21:23 By: Eclipse User  |
Computer Algebra System Is it possible to add this CAS [Computer Algebra System] To the Project ? By: Eclipse User on Fri, 13 December 2019 |
5204 |
Fri, 13 December 2019 11:31 By: Eclipse User  |
Telerik User Interface Integration Is it possible to add Telerik User Interface to the project ? By: Eclipse User on Wed, 11 December 2019 |
4256 |
Fri, 13 December 2019 10:34 By: Eclipse User  |
Code formatter adds multiple blank lines in -[[ ]] blocks Code fomatter adds multiple blank lines in -[[ ]] blocks By: Eclipse User on Thu, 28 November 2019 |
3261 |
Thu, 28 November 2019 13:52 By: Eclipse User  |
Adding Numerical Methods (LNA) To the Project Is it possible to add Numerical Methods (LNA) To The Project Please By: Eclipse User on Thu, 26 September 2019 |
21 |
9640 |
Sat, 26 October 2019 16:41 By: Eclipse User  |
Select Lua 5.1? LDT has plugins for Lua 5.1 and 5.2. Can 5.1 be selected? By: Eclipse User on Fri, 19 July 2019 |
24292 |
Sat, 10 August 2019 10:15 By: Eclipse User  |
LDT shows error LDT won't open By: Eclipse User on Fri, 19 April 2019 |
6639 |
Wed, 24 April 2019 07:36 By: Eclipse User  |
Eclipse Plugin Manual Installation I need to be able to install the LDT Plugin without using the Install New Software Selection By: Eclipse User on Fri, 11 January 2019 |
3386 |
Fri, 11 January 2019 13:05 By: Eclipse User  |
Lua 5.3 support By: Eclipse User on Wed, 05 April 2017 |
13618 |
Fri, 28 September 2018 17:10 By: Eclipse User  |
luadoc and italic names of my variables... How can i avoid italic names of my variables in luadocumenter generated documentation? By: Eclipse User on Fri, 22 July 2016 |
9498 |
Tue, 22 May 2018 15:50 By: Eclipse User  |
luadoc: @{#AI_A2A_DISPATCHER} is wrongly displayed in html! By: Eclipse User on Wed, 14 June 2017 |
15561 |
Tue, 22 May 2018 15:29 By: Eclipse User  |
LDT Default Workpace File Position By: Eclipse User on Sun, 15 April 2018 |
5530 |
Sun, 15 April 2018 07:01 By: Eclipse User  |
Code completion - missing features? By: Eclipse User on Mon, 12 March 2018 |
3431 |
Mon, 12 March 2018 10:06 By: Eclipse User  |
How to config LDT to support a big number of functions in one doclua file? By: Eclipse User on Fri, 01 September 2017 |
9675 |
Tue, 09 January 2018 08:21 By: Eclipse User  |
Range-based indenting? By: Eclipse User on Thu, 23 November 2017 |
6136 |
Thu, 21 December 2017 10:34 By: Eclipse User  |
Cant do Existing Install - Repository Empty By: Eclipse User on Sat, 18 November 2017 |
5580 |
Thu, 21 December 2017 10:21 By: Eclipse User  |
Add luaglut or luagl to LDT By: Eclipse User on Tue, 10 October 2017 |
5077 |
Tue, 10 October 2017 21:19 By: Eclipse User  |
Running application error By: Eclipse User on Fri, 06 October 2017 |
3744 |
Fri, 06 October 2017 20:31 By: Eclipse User  |
Debugger process was unexpectedly terminated with custom Lua 5.1 on Windows 10 Not possible to debug in LDT on Windows 10 with a customer Lua 5.1 build By: Eclipse User on Thu, 14 September 2017 |
9558 |
Sun, 17 September 2017 03:39 By: Eclipse User  |
remote development: csv and other file extensions filter in remote runs and debug sessions non-lua files are missing By: Eclipse User on Fri, 05 May 2017 |
27203 |
Thu, 01 June 2017 10:46 By: Eclipse User  |
identification of debug ide host setting DBGP_IDEHOST helps but has to be set per project By: Eclipse User on Sat, 06 May 2017 |
25223 |
Sat, 06 May 2017 04:31 By: Eclipse User  |
Outline missing functions if they are called By: Eclipse User on Sun, 30 April 2017 |
17881 |
Sun, 30 April 2017 06:47 By: Eclipse User  |
Debug LDT source scripts By: Eclipse User on Wed, 26 April 2017 |
21248 |
Wed, 26 April 2017 05:32 By: Eclipse User  |
Empty project - "This file probably contains a syntax error" By: Eclipse User on Mon, 04 July 2016 |
6592 |
Wed, 26 April 2017 05:17 By: Eclipse User  |
Empty outline No outline is displayed for a .lua file By: Eclipse User on Mon, 17 April 2017 |
5877 |
Mon, 17 April 2017 05:05 By: Eclipse User  |
LDT crashes immediately in debug mode debugger bug-report By: Eclipse User on Wed, 15 March 2017 |
8550 |
Mon, 27 March 2017 12:33 By: Eclipse User  |
Debug Globals a bit of a mess By: Eclipse User on Sun, 12 February 2017 |
5734 |
Thu, 16 March 2017 06:51 By: Eclipse User  |
Debug configuration issue and extra variables By: Eclipse User on Sat, 25 February 2017 |
12590 |
Sat, 25 February 2017 19:30 By: Eclipse User  |
Debugging external app opens source file separately By: Eclipse User on Sun, 12 February 2017 |
4378 |
Mon, 13 February 2017 14:26 By: Eclipse User  |
How to document lists with the luadcoumentor? By: Eclipse User on Wed, 04 January 2017 |
17413 |
Wed, 04 January 2017 04:21 By: Eclipse User  |
eclipse debug nginx in lua eclipse debug nginx in lua By: Eclipse User on Fri, 16 December 2016 |
19800 |
Fri, 16 December 2016 02:31 By: Eclipse User  |
LDT installation on Eclipse on Mac failed LDT installation on Eclipse on Mac failed By: Eclipse User on Sun, 11 December 2016 |
7652 |
Sun, 11 December 2016 19:30 By: Eclipse User  |
"Gnuplot terminal is not set stack traceback" error By: Eclipse User on Sat, 30 April 2016 |
6681 |
Mon, 26 September 2016 19:09 By: Eclipse User  |
slow code parse and auto-completion for "self" By: Eclipse User on Tue, 23 August 2016 |
3487 |
Wed, 24 August 2016 12:10 By: Eclipse User  |
Installation Problem By: Eclipse User on Tue, 23 August 2016 |
3672 |
Tue, 23 August 2016 10:43 By: Eclipse User  |
Autocomplete without CTRL+SPACE By: Eclipse User on Wed, 06 July 2016 |
8150 |
Tue, 12 July 2016 08:38 By: Eclipse User  |
Debugger crashes with Torch and Mars By: Eclipse User on Mon, 04 January 2016 |
12083 |
Wed, 06 July 2016 06:32 By: Eclipse User  |
Crash when upgrading to new debugger.lua By: Eclipse User on Tue, 14 June 2016 |
5310 |
Wed, 06 July 2016 06:14 By: Eclipse User  |
A good example of luadoc usage ... For those interested in how to use luadoc in your lua code using LDT By: Eclipse User on Thu, 26 May 2016 |
6061 |
Thu, 26 May 2016 08:34 By: Eclipse User  |
for id, element in pairs( table ) do -- How to use luadoc? How to get element exposed with intellisense? By: Eclipse User on Thu, 26 May 2016 |
2758 |
Thu, 26 May 2016 05:54 By: Eclipse User  |
Possible to install NodeMCU in LDT Need assistance in installing NodeMCU in LDT By: Eclipse User on Wed, 15 April 2015 |
7419 |
Sun, 22 May 2016 06:13 By: Eclipse User  |
mongo_module.so: undefined symbol: lua_checkstack Lua; mongo; mongorover By: Eclipse User on Tue, 26 April 2016 |
6026 |
Wed, 27 April 2016 06:52 By: Eclipse User  |
Configuring 'Lips of Suna' Lua modules Programming newbie wants help getting Lua modules recognized, & other Lua related issues By: Eclipse User on Tue, 12 April 2016 |
5831 |
Tue, 12 April 2016 15:09 By: Eclipse User  |
How to create html documentation pages from the luadoc ltd documentation style? luadoc By: Eclipse User on Sat, 02 April 2016 |
7333 |
Mon, 04 April 2016 04:42 By: Eclipse User  |
Torch - Lua Debugger Error (variable value inspection) ERROR: cannot resume running coroutine By: Eclipse User on Thu, 24 March 2016 |
8557 |
Thu, 24 March 2016 20:30 By: Eclipse User  |
ldoc documentation in LDT 1.3.1 How to properly document types consisting our of multiple levels. By: Eclipse User on Wed, 23 March 2016 |
5568 |
Thu, 24 March 2016 06:35 By: Eclipse User  |
Short References Something is not working correctly with short references in LuaDoc By: Eclipse User on Tue, 15 March 2016 |
6091 |
Tue, 15 March 2016 05:00 By: Eclipse User  |
Use code beautifier programmatically By: Eclipse User on Mon, 30 November 2015 |
6940 |
Mon, 30 November 2015 13:36 By: Eclipse User  |
Problem with number literals follow-up Eager to have this repair asap By: Eclipse User on Wed, 23 September 2015 |
4843 |
Fri, 02 October 2015 16:04 By: Eclipse User  |
Slow debugging By: Eclipse User on Wed, 12 August 2015 |
7560 |
Fri, 25 September 2015 06:02 By: Eclipse User  |
Code Templates User variable with predefined values Enable Ctrl+Space on user variables to autocomlete its value from a list of predefined values. By: Eclipse User on Thu, 13 August 2015 |
4474 |
Mon, 17 August 2015 08:42 By: Eclipse User  |
Make .xml files to highlight the code By: Eclipse User on Wed, 23 January 2013 |
8304 |
Thu, 30 July 2015 04:50 By: Eclipse User  |
Where can I find the debugger files (./debugger/xxx.lua) By: Eclipse User on Sun, 19 July 2015 |
3660 |
Mon, 20 July 2015 09:16 By: Eclipse User  |
How do I instal luasql into Eclipse (koneki ldt win32) By: Eclipse User on Fri, 03 July 2015 |
4159 |
Fri, 03 July 2015 04:59 By: Eclipse User  |
Create a simple Execution Environment from an existing Execution Environment By: Eclipse User on Fri, 05 June 2015 |
5421 |
Tue, 30 June 2015 10:49 By: Eclipse User  |
issue with LDT requirement of glibc 2.7 vs glib 2.5 present on RHEL 5.x By: Eclipse User on Wed, 20 May 2015 |
4223 |
Mon, 08 June 2015 11:04 By: Eclipse User  |
LDT 1.3 RC2 Check it out By: Eclipse User on Mon, 25 May 2015 |
4136 |
Mon, 25 May 2015 06:15 By: Eclipse User  |
LDT 1.3 RC1 By: Eclipse User on Mon, 18 May 2015 |
3995 |
Mon, 18 May 2015 03:51 By: Eclipse User  |
lua development tool without auto-complete problem with auto-complete By: Eclipse User on Thu, 29 January 2015 |
5423 |
Thu, 07 May 2015 18:40 By: Eclipse User  |
Stop attached debugger by code? By: Eclipse User on Sat, 25 April 2015 |
3267 |
Sat, 25 April 2015 15:24 By: Eclipse User  |
LDT - How to stop the file tab, showing the full path text? The text in the file tab shows the full path rather than just the filename. By: Eclipse User on Thu, 18 April 2013 |
9801 |
Wed, 08 April 2015 04:18 By: Eclipse User  |
Help with Love2D EE (enums, function overloading) By: Eclipse User on Fri, 03 April 2015 |
5564 |
Fri, 03 April 2015 13:15 By: Eclipse User  |
step over c function luaL_error By: Eclipse User on Tue, 17 February 2015 |
3483 |
Mon, 23 March 2015 11:49 By: Eclipse User  |
Lua Attach Debug Issue Attempt to debug with OpenResty is problematic By: Eclipse User on Thu, 26 February 2015 |
4685 |
Mon, 23 March 2015 11:37 By: Eclipse User  |
LDT 1.3 M2 By: Eclipse User on Fri, 20 March 2015 |
3786 |
Fri, 20 March 2015 15:57 By: Eclipse User  |
LDT 1.3 M1 By: Eclipse User on Fri, 30 January 2015 |
4179 |
Fri, 30 January 2015 09:46 By: Eclipse User  |
Disable Error Markers or Add to Parser/Validation By: Eclipse User on Wed, 14 January 2015 |
5317 |
Fri, 30 January 2015 05:58 By: Eclipse User  |
Build failure I don't understand how to build By: Eclipse User on Thu, 08 May 2014 |
23132 |
Tue, 06 January 2015 08:21 By: Eclipse User  |
Change keywords How to change keywords By: Eclipse User on Tue, 29 July 2014 |
6117 |
Mon, 05 January 2015 09:41 By: Eclipse User  |
How to SOLELY change LDT editor font size? LDT fontsize By: Eclipse User on Sun, 21 December 2014 |
6139 |
Mon, 05 January 2015 06:18 By: Eclipse User  |
Build failure Problems with building By: Eclipse User on Sat, 03 January 2015 |
5611 |
Sat, 03 January 2015 12:58 By: Eclipse User  |
Will ldt support debug hover to inspect local vairables? By: Eclipse User on Sat, 13 December 2014 |
4237 |
Tue, 16 December 2014 01:26 By: Eclipse User  |
Luadoc converts some numbers to ASCII characters If there is certain numbers in a .doclua comment block, Luadoc translate them to ASCii characters By: Eclipse User on Wed, 10 December 2014 |
3541 |
Thu, 11 December 2014 10:53 By: Eclipse User  |
mark occurrences? By: Eclipse User on Fri, 05 December 2014 |
3364 |
Mon, 08 December 2014 09:39 By: Eclipse User  |
Where is Code Formatter in LDT? LDT says there's a code formatter, but where is it? By: Eclipse User on Tue, 25 November 2014 |
4741 |
Tue, 25 November 2014 04:47 By: Eclipse User  |
LDT and Classes Implementing classes in Lua and using them in LDT By: Eclipse User on Thu, 06 November 2014 |
3413 |
Thu, 06 November 2014 09:30 By: Eclipse User  |
Problems with LuaDoc View Problems with LuaDoc View (and autocompletion window) while running linux, By: Eclipse User on Fri, 10 October 2014 |
5678 |
Tue, 14 October 2014 09:18 By: Eclipse User  |
Windows 64 or 32 bit Does LDT run as a 64 bit application? By: Eclipse User on Tue, 30 September 2014 |
9430 |
Thu, 02 October 2014 16:47 By: Eclipse User  |
not able to create a Lua Application run configuration By: Eclipse User on Sun, 28 September 2014 |
5309 |
Mon, 29 September 2014 08:16 By: Eclipse User  |
Programmatically Installing Execution Environments, Adding them to Project Build Paths By: Eclipse User on Thu, 25 September 2014 |
4045 |
Fri, 26 September 2014 05:13 By: Eclipse User  |
Custom Execution Environment Autocompletion By: Eclipse User on Tue, 23 September 2014 |
5223 |
Wed, 24 September 2014 11:26 By: Eclipse User  |
Problem Creating a Custom Lua Execution Environment By: Eclipse User on Tue, 23 September 2014 |
3278 |
Tue, 23 September 2014 12:38 By: Eclipse User  |
Debugger with launch script By: Eclipse User on Wed, 30 July 2014 |
4534 |
Fri, 01 August 2014 10:34 By: Eclipse User  |
Unable to Launch Unable to Launch By: Eclipse User on Fri, 25 July 2014 |
10973 |
Mon, 28 July 2014 08:37 By: Eclipse User  |
Some scripts got 'This file probably contains a syntax error' after upgrading from 1.1 to 1.2 By: Eclipse User on Wed, 16 July 2014 |
7223 |
Mon, 21 July 2014 08:39 By: Eclipse User  |
crash in debugger.lua package.preload crash in debugger.lua By: Eclipse User on Wed, 09 July 2014 |
5026 |
Fri, 11 July 2014 05:59 By: Eclipse User  |
The highlighting color is changed when typing. The editor do syntax checking when i am typing. By: Eclipse User on Thu, 03 July 2014 |
7693 |
Fri, 04 July 2014 05:23 By: Eclipse User  |
Debug though co-routines By: Eclipse User on Wed, 25 June 2014 |
5565 |
Fri, 27 June 2014 12:27 By: Eclipse User  |
Unable to make autocoplete working Cocos2d-x 3.x Lua ee By: Eclipse User on Sun, 15 June 2014 |
5945 |
Fri, 27 June 2014 09:19 By: Eclipse User  |
Problems with Lua Remote Application By: Eclipse User on Thu, 26 June 2014 |
5281 |
Fri, 27 June 2014 05:21 By: Eclipse User  |
How document multi inherit By: Eclipse User on Wed, 25 June 2014 |
3222 |
Wed, 25 June 2014 07:00 By: Eclipse User  |
Unable to creat Lua Project Lua By: Eclipse User on Mon, 09 June 2014 |
4634 |
Wed, 11 June 2014 17:07 By: Eclipse User  |
Debug on a microcontroller Debug embedded Lua on a microcontroller By: Eclipse User on Fri, 30 May 2014 |
37360 |
Wed, 11 June 2014 10:51 By: Eclipse User  |
How do I check a Function for Syntax Errors Using Error Markers(?) By: Eclipse User on Wed, 21 May 2014 |
9024 |
Thu, 22 May 2014 05:29 By: Eclipse User  |
Can't Start LuaDevelopmentTools.exe Using Standalone Product (v1.1) By: Eclipse User on Sat, 17 May 2014 |
7884 |
Wed, 21 May 2014 16:57 By: Eclipse User  |
koneki OMA-DM client as a library on Android By: Eclipse User on Mon, 12 May 2014 |
15472 |
Wed, 14 May 2014 10:02 By: Eclipse User  |
Missing dll By: Eclipse User on Sat, 26 April 2014 |
23859 |
Mon, 28 April 2014 09:19 By: Eclipse User  |
Koneki LDT moving in his own project. By: Eclipse User on Wed, 23 April 2014 |
48930 |
Wed, 23 April 2014 10:14 By: Eclipse User  |
How to document inherit relation By: Eclipse User on Thu, 09 January 2014 |
12902 |
Wed, 09 April 2014 11:07 By: Eclipse User  |
Parsing files not commented in luadocs Request for information By: Eclipse User on Mon, 24 March 2014 |
3905 |
Wed, 26 March 2014 11:15 By: Eclipse User  |
[LDT 1.0] load a module written in Java By: Eclipse User on Thu, 20 March 2014 |
4864 |
Wed, 26 March 2014 10:49 By: Eclipse User  |
Is somebody home?? By: Eclipse User on Mon, 17 March 2014 |
3624 |
Tue, 18 March 2014 16:19 By: Eclipse User  |
Mihini - Execute Problems By: Eclipse User on Mon, 17 March 2014 |
2913 |
Mon, 17 March 2014 10:52 By: Eclipse User  |
Koneki - Mihini By: Eclipse User on Sat, 15 March 2014 |
2808 |
Sat, 15 March 2014 10:58 By: Eclipse User  |
Koneki / Mihini Mac OSX install By: Eclipse User on Wed, 12 March 2014 |
2833 |
Wed, 12 March 2014 11:59 By: Eclipse User  |
Limited autocomplete issue on multiple globals By: Eclipse User on Mon, 10 March 2014 |
4591 |
Tue, 11 March 2014 17:32 By: Eclipse User  |
Lua Socket library Source files for luasocket-2.0.2-lua-5.1.2-Win32-vc8.zip By: Eclipse User on Thu, 06 March 2014 |
4994 |
Mon, 10 March 2014 12:34 By: Eclipse User  |
LDT with goto support lua 5.2 is supported goto statement while LDT is not. By: Eclipse User on Mon, 24 February 2014 |
4137 |
Tue, 25 February 2014 05:22 By: Eclipse User  |
Autocomplete in eclipse with MOAI Lua By: Eclipse User on Sun, 16 February 2014 |
6550 |
Tue, 18 February 2014 05:25 By: Eclipse User  |
ldt debugger.lua in android or IOS platform By: Eclipse User on Wed, 12 February 2014 |
7909 |
Fri, 14 February 2014 01:23 By: Eclipse User  |
Lua Modules I can't seem to get it to work By: Eclipse User on Tue, 11 February 2014 |
8975 |
Wed, 12 February 2014 09:37 By: Eclipse User  |
LuaDocumentor help please By: Eclipse User on Wed, 15 January 2014 |
12556 |
Mon, 20 January 2014 09:45 By: Eclipse User  |
How to set remote system for remote debug ldt;remote; By: Eclipse User on Fri, 03 January 2014 |
18800 |
Thu, 09 January 2014 00:18 By: Eclipse User  |
Metalua integration with LDT Code analysis integration code with metalua By: Eclipse User on Sat, 28 December 2013 |
76322 |
Tue, 07 January 2014 04:52 By: Eclipse User  |
How to compile LUA scripts with Koneki? How to compile LUA scripts with Koneki? By: Eclipse User on Thu, 02 January 2014 |
15000 |
Mon, 06 January 2014 10:03 By: Eclipse User  |
Insert instructions / keyword in DLTK Update DLTK definitions By: Eclipse User on Mon, 30 December 2013 |
65608 |
Mon, 06 January 2014 05:49 By: Eclipse User  |
How to get tabs instead of spaces (Koneki) How to get tabs instead of spaces ((Koneki)) By: Eclipse User on Thu, 02 January 2014 |
16929 |
Mon, 06 January 2014 04:51 By: Eclipse User  |
Koneki LDT plugins Unable to install LDT plugins By: Eclipse User on Wed, 18 December 2013 |
9425 |
Thu, 19 December 2013 04:41 By: Eclipse User  |
unpack and table.unpack for Lua 5.2 table.unpack doesn't exist for Lua 5.2 By: Eclipse User on Fri, 13 December 2013 |
19927 |
Tue, 17 December 2013 11:17 By: Eclipse User  |
LDT 1.1RC2 and LuaDocumentor 0.1.3 are out. By: Eclipse User on Fri, 13 December 2013 |
35716 |
Fri, 13 December 2013 10:34 By: Eclipse User  |
Proper method to debug Lua script from Luaj project By: Eclipse User on Tue, 03 December 2013 |
13781 |
Wed, 11 December 2013 12:01 By: Eclipse User  |
Breakpoint not hit after attaching to Java application By: Eclipse User on Tue, 10 December 2013 |
9569 |
Wed, 11 December 2013 11:47 By: Eclipse User  |
Sample code used in LDT to generate AST how to generate ast in ldt By: Eclipse User on Fri, 29 November 2013 |
4729 |
Mon, 02 December 2013 12:06 By: Eclipse User  |
Autocompletion for external API By: Eclipse User on Sun, 03 November 2013 |
392883 |
Thu, 28 November 2013 06:43 By: Eclipse User  |
Editing Syntax Coloring Unable to change colors By: Eclipse User on Mon, 25 November 2013 |
6035 |
Thu, 28 November 2013 05:31 By: Eclipse User  |
Limited autocomplete issue @return statement doesn't seem to work By: Eclipse User on Sat, 21 September 2013 |
10343 |
Thu, 14 November 2013 06:15 By: Eclipse User  |
Spellcheck Support Request for spellcheck support in the LDT By: Eclipse User on Tue, 29 October 2013 |
5107 |
Wed, 30 October 2013 09:38 By: Eclipse User  |
Vendor specific debug protocol commands By: Eclipse User on Mon, 21 October 2013 |
5660 |
Thu, 24 October 2013 07:25 By: Eclipse User  |
Koneki LDT stops after stepping twice By: Eclipse User on Mon, 21 October 2013 |
6137 |
Wed, 23 October 2013 11:31 By: Eclipse User  |
LDT build failure LDT build failure By: Eclipse User on Wed, 16 October 2013 |
4714 |
Wed, 23 October 2013 11:08 By: Eclipse User  |
Debugging issue with standalone interpreter DEBUGGER ERROR Command context_get caused: (998) ....osgi\bundles\173\1\.cp\script\external\debugger.lua:187: attempt to call field 'encode' (a nil value) By: Eclipse User on Sat, 19 October 2013 |
7794 |
Wed, 23 October 2013 10:42 By: Eclipse User  |
LDT with an external library (winapi.dll) How to incorporate a .dll library within LDT. By: Eclipse User on Sun, 20 October 2013 |
7173 |
Mon, 21 October 2013 12:54 By: Eclipse User  |
Debugging issue with Lua standalone interpreter with LDT1.0 DEBUGGER ERROR Command context_get caused: (998) ....osgi\bundles\173\1\.cp\script\external\debugger.lua:187: attempt to call field 'encode' (a nil value) By: Eclipse User on Sat, 19 October 2013 |
6246 |
Sat, 19 October 2013 02:00 By: Eclipse User  |
LDT debugger more broader explanationn of LDT debugger By: Eclipse User on Mon, 16 September 2013 |
7325 |
Fri, 20 September 2013 12:52 By: Eclipse User  |
LuaSocket How do I add LuaSocket to Lua Developement Tool By: Eclipse User on Mon, 12 August 2013 |
6519 |
Mon, 12 August 2013 12:47 By: Eclipse User  |
[LDT1.0] link a dynamic library , Help ! By: Eclipse User on Sat, 10 August 2013 |
7220 |
Mon, 12 August 2013 11:26 By: Eclipse User  |
Koneki LDT 1.0 (on Windows): Debugging not working By: Eclipse User on Sun, 04 August 2013 |
6073 |
Mon, 12 August 2013 00:52 By: Eclipse User  |
Could not initialize class com.naef.jnlua.LuaState The application has failed to start because its side-by-side configuration is incorrect. By: Eclipse User on Fri, 02 August 2013 |
6466 |
Thu, 08 August 2013 05:31 By: Eclipse User  |
Execution Environment imported by default By: Eclipse User on Thu, 01 August 2013 |
6485 |
Mon, 05 August 2013 06:29 By: Eclipse User  |
Strange problem trying to use LDT on second machine cannot load liblua52.so By: Eclipse User on Mon, 22 July 2013 |
5877 |
Thu, 25 July 2013 20:53 By: Eclipse User  |
Variable Reference Issue Unable to go to the declaration of a variable in another file By: Eclipse User on Fri, 12 July 2013 |
4323 |
Mon, 15 July 2013 03:25 By: Eclipse User  |
LDT - Execution Environment. Help! variable detection. By: Eclipse User on Sun, 07 July 2013 |
10510 |
Wed, 10 July 2013 05:49 By: Eclipse User  |
cannot execute simulator cannot install required libraries By: Eclipse User on Wed, 26 June 2013 |
3253 |
Wed, 26 June 2013 03:25 By: Eclipse User  |
Can't install my execution environment My zip file doesn't seem to be formatted in a way LDT expects By: Eclipse User on Tue, 25 June 2013 |
4773 |
Tue, 25 June 2013 08:20 By: Eclipse User  |
Issues debugging variables in Love2D with LuaJIT By: Eclipse User on Thu, 20 June 2013 |
8049 |
Mon, 24 June 2013 23:31 By: Eclipse User  |
Code Assist for Corona SDK By: Eclipse User on Thu, 18 October 2012 |
9085 |
Mon, 24 June 2013 11:53 By: Eclipse User  |
Does code assistance only work if you have the lua module associated with the documents Code assistance and Execution Environments By: Eclipse User on Thu, 20 June 2013 |
4098 |
Thu, 20 June 2013 12:52 By: Eclipse User  |
running Lua Remote Application - Permission denied By: Eclipse User on Tue, 11 June 2013 |
9414 |
Wed, 12 June 2013 00:45 By: Eclipse User  |
Windows Koneki and Corona first steps setup By: Eclipse User on Thu, 16 May 2013 |
18781 |
Thu, 30 May 2013 21:30 By: Eclipse User  |
userdata types and detail formatter Viewing userdata types in the expressions window By: Eclipse User on Tue, 28 May 2013 |
6596 |
Wed, 29 May 2013 07:54 By: Eclipse User  |
debugger hangs up and windows too By: Eclipse User on Mon, 13 May 2013 |
7411 |
Tue, 21 May 2013 06:13 By: Eclipse User  |
Debugging with Corona SDK (Juno) By: Eclipse User on Thu, 29 November 2012 |
8507 |
Mon, 20 May 2013 19:00 By: Eclipse User  |
error loading module 'stagedb.core' Seek help By: Eclipse User on Tue, 14 May 2013 |
7247 |
Fri, 17 May 2013 04:32 By: Eclipse User  |
Better LuaJIT FFI support With cdata introspection By: Eclipse User on Sun, 14 April 2013 |
9042 |
Thu, 16 May 2013 21:35 By: Eclipse User  |
A Truly Newbie Question - How to Get Started? By: Eclipse User on Sun, 12 May 2013 |
6001 |
Thu, 16 May 2013 18:24 By: Eclipse User  |
[SOLVED] lua attach debugger not working By: Eclipse User on Wed, 15 May 2013 |
6148 |
Thu, 16 May 2013 14:43 By: Eclipse User  |
[SOLVED] Debugger attaches, but nothing else happens Trying to debug embedded scripts, debugger attaches but nothing else happens until it terminates. By: Eclipse User on Wed, 08 May 2013 |
7142 |
Fri, 10 May 2013 07:52 By: Eclipse User  |
Can't use the editor under Mac OS Mac OS X 10.6, Eclipse 3.7 By: Eclipse User on Wed, 14 December 2011 |
13617 |
Thu, 02 May 2013 14:08 By: Eclipse User  |
Run external program on save Feature request By: Eclipse User on Tue, 30 April 2013 |
5463 |
Tue, 30 April 2013 12:32 By: Eclipse User  |
Can LDT debug Lua in a C app? By: Eclipse User on Wed, 24 April 2013 |
10972 |
Mon, 29 April 2013 07:41 By: Eclipse User  |
LDT with luabind By: Eclipse User on Tue, 16 April 2013 |
5862 |
Thu, 25 April 2013 09:42 By: Eclipse User  |
Documenting a Function That Returns an Array By: Eclipse User on Tue, 09 April 2013 |
8359 |
Fri, 12 April 2013 12:18 By: Eclipse User  |
Problem using Mihini EE with LDT 0.9 under Win 7 By: Eclipse User on Tue, 09 April 2013 |
5200 |
Tue, 09 April 2013 10:10 By: Eclipse User  |
Working without the .lua file extention[LDT] Is there a way to make LTD treat files without a file extension like .lua file By: Eclipse User on Fri, 05 April 2013 |
6737 |
Mon, 08 April 2013 15:20 By: Eclipse User  |
how to create a debug-able lua interpreter for LDT By: Eclipse User on Wed, 27 March 2013 |
6408 |
Mon, 08 April 2013 06:39 By: Eclipse User  |
LDT 0.9 Support for Eclipse Helios 3.6.2 (64-bit) By: Eclipse User on Tue, 26 March 2013 |
6241 |
Mon, 08 April 2013 05:17 By: Eclipse User  |
Importing Rocks Better Documentation needed for beginners regarding LuaRocks Integration By: Eclipse User on Mon, 25 March 2013 |
5637 |
Tue, 26 March 2013 07:21 By: Eclipse User  |
LDT error when creating Lua project By: Eclipse User on Thu, 21 March 2013 |
9604 |
Mon, 25 March 2013 06:28 By: Eclipse User  |
Lua 5.2 Support By: Eclipse User on Sat, 23 March 2013 |
4825 |
Mon, 25 March 2013 05:54 By: Eclipse User  |
Debugger broken By: Eclipse User on Thu, 14 March 2013 |
5201 |
Tue, 19 March 2013 06:53 By: Eclipse User  |
LDT/Wireshark: Breakpoints don't work Lua Attach to Application/Breakpoints do not work with Wireshark By: Eclipse User on Wed, 06 March 2013 |
7190 |
Thu, 07 March 2013 16:09 By: Eclipse User  |
Lua and C++ exception: will my scripts be still debuggable? By: Eclipse User on Wed, 06 March 2013 |
3902 |
Thu, 07 March 2013 10:50 By: Eclipse User  |
Help understanding code assist I need help understand what can an cannot autocomplete |
14446 |
Thu, 07 March 2013 04:47 By: Eclipse User  |
LUA development tools not running in order LuaDevelopmentTools not running in order By: Eclipse User on Mon, 25 February 2013 |
4343 |
Tue, 26 February 2013 07:55 By: Eclipse User  |
LDT doesn't show up (ubuntu) By: Eclipse User on Tue, 06 November 2012 |
6283 |
Tue, 19 February 2013 03:52 By: Eclipse User  |
io.read waits before any print() output? Problems getting print to output before calls to io.read |
6522 |
Fri, 15 February 2013 12:02 By: Eclipse Guest  |
How to remote debug By: Eclipse User on Sun, 03 February 2013 |
4774 |
Tue, 05 February 2013 08:54 By: Eclipse User  |
Initial impressions of 0.9 release By: Eclipse User on Fri, 18 January 2013 |
8253 |
Thu, 24 January 2013 12:43 By: Eclipse User  |
How can i create my own execution environments for LDT execution environment By: Eclipse User on Tue, 22 January 2013 |
6418 |
Wed, 23 January 2013 00:29 By: Eclipse User  |
Unofficial Lua Execution Environments Continuously Updated Unofficial Lua Execution Environments By: Eclipse User on Sun, 05 August 2012 |
7667 |
Tue, 22 January 2013 05:26 By: Eclipse User  |
Thank you for the improvements in 0.9 By: Eclipse User on Fri, 18 January 2013 |
4249 |
Sat, 19 January 2013 13:28 By: Eclipse User  |
We want your inputs for the next release of Koneki! Collecting ideas for Koneki 0.9 By: Eclipse User on Tue, 03 July 2012 |
24 |
26721 |
Sat, 19 January 2013 13:22 By: Eclipse User  |
Several questions about LDT Outlining, unicode, folding etc. By: Eclipse User on Sun, 30 September 2012 |
19 |
30092 |
Wed, 09 January 2013 11:20 By: Eclipse User  |
How to use LuaFileSystem in LDT? By: Eclipse User on Mon, 10 December 2012 |
10076 |
Thu, 03 January 2013 07:53 By: Eclipse User  |
Can I debug lua at android By: Eclipse User on Tue, 25 December 2012 |
6767 |
Thu, 03 January 2013 05:50 By: Eclipse User  |
No way to code to make code hinting to work After 2 days of tries give it up By: Eclipse User on Thu, 01 November 2012 |
7098 |
Thu, 20 December 2012 09:01 By: Eclipse User  |
how to debug like the tool "decoda"? I want to debug the lua file called by a C program, how to do that? By: Eclipse User on Fri, 09 November 2012 |
10519 |
Mon, 10 December 2012 10:53 By: Eclipse User  |
LDT debugging the LÖVE framework Support for debugging would be nice By: Eclipse User on Fri, 16 November 2012 |
4658 |
Mon, 10 December 2012 05:37 By: Eclipse User  |
External Lib : Lua LOOP not running integrating external lib and LDT By: Eclipse User on Mon, 03 December 2012 |
7363 |
Tue, 04 December 2012 05:50 By: Eclipse User  |
