  [EMF Search] Source code
By: Eclipse User on Wed, 27 November 2024
3 1578 Fri, 29 November 2024 04:19
  An error occurred during the release
Can not release a history of an ecore file
By: Eclipse User on Tue, 09 July 2024
3 1952 Thu, 11 July 2024 07:42
  Converting/exporting EMF generated projects into maven artefacts
By: Eclipse User on Sun, 25 February 2024
2 1769 Mon, 26 February 2024 02:37
  No Model Importer available for EMF Generator Model
By: Eclipse User on Fri, 12 January 2024
2 941 Fri, 12 January 2024 17:06
  EmfForms TreeMasterViewer Validate Icon Image
EmfForms TreeMasterViewer Validate Icon Image Not Changed
By: Eclipse User on Wed, 13 December 2023
1 1408 Wed, 20 December 2023 18:54
  [Edapt] Migrating cross reference classcast issue
CCE Eobject cannot cast to Eclassifier because they are in an unnamed model of loader
By: Eclipse User on Mon, 27 November 2023
3 1648 Wed, 06 December 2023 03:37
  [Edapt] Adding a new EPackage cause NPE during Migration
By: Eclipse User on Fri, 13 May 2022
2 6152 Wed, 29 November 2023 07:27
  Negative values for Enum entries create an warning in the editor.
By: Eclipse User on Mon, 21 August 2023
0 1743 Mon, 21 August 2023 16:28
  [Edapt] No metamodel found error, need additional information besides tutorial
By: Eclipse User on Sun, 30 July 2023
4 2033 Tue, 08 August 2023 10:16
  [EMF FORMS] View no content update
No update of data content in view when generating form with no data initially
By: Eclipse User on Wed, 01 March 2023
1 2409 Wed, 08 March 2023 06:57
  Design information on Ecore2Ecore, Ecore2XML
Help to understand intention, Code read pointers
By: Eclipse User on Mon, 20 February 2023
0 2150 Mon, 20 February 2023 20:02
  EMF Forms evaluation
By: Eclipse User on Wed, 21 December 2022
1 2740 Wed, 04 January 2023 07:16
  EMF Forms Services
EMFForms
By: Eclipse User on Thu, 22 December 2022
1 1430 Fri, 23 December 2022 00:55
  How to display a reference
EMFForms
1 1278 Thu, 22 December 2022 09:19
  Best tooling to replace Texo
By: Eclipse User on Wed, 17 August 2022
5 2447 Wed, 21 December 2022 11:58
  Linking an actor to a use case
By: Eclipse User on Thu, 27 October 2022
1 2783 Fri, 28 October 2022 03:10
  [EMF Forms] EMF Combo Box in GenericEditor
By: Eclipse User on Tue, 06 September 2022
1 3331 Tue, 13 September 2022 07:24
  Cannot download EMF forms latest updates -> website page bug?
By: Eclipse User on Thu, 02 June 2022
6 5677 Thu, 21 July 2022 05:20
  EMF diff Merge usage on this folder?
By: Eclipse User on Fri, 20 May 2022
0 5152 Fri, 20 May 2022 09:30
  Is there a way to automatically display the classes children of other classes?
2 2535 Mon, 16 May 2022 03:31
  (To be deleted)
By: Eclipse User on Wed, 11 May 2022
0 5942 Wed, 11 May 2022 05:22
  Broken link - ecp documentation tutorial
By: Eclipse User on Mon, 09 May 2022
2 2452 Tue, 10 May 2022 05:35
  Deriving a property value from another derived property using OCL
By: Eclipse User on Fri, 29 April 2022
1 2215 Fri, 29 April 2022 14:58
  Compile stand-alone Java application containing JET-Templates outside of eclipse GUI
How to compile with eclipse version >2020 JET-Templates in a shell script or ant-build,...
By: Eclipse User on Mon, 04 April 2022
4 2526 Tue, 05 April 2022 10:39
  validation display in TreeMasterDetailSWTRenderer
TreeMasterDetailSWTRenderer validation
By: Eclipse User on Tue, 15 March 2022
3 4958 Tue, 22 March 2022 01:47
  Class Diagram for CAPELLA?
By: Eclipse User on Fri, 18 March 2022
1 3846 Fri, 18 March 2022 11:12
  Ecore for mapping metamodel
By: Eclipse User on Thu, 02 September 2021
1 2688 Fri, 03 September 2021 07:47
  Use Edapt to migrate one model to another one?
By: Eclipse User on Sun, 29 August 2021
1 1404 Sun, 29 August 2021 11:02
  [EMF Forms] Renderer or Factory
Adjusting functionality to the treemasterdetail
By: Eclipse User on Wed, 02 June 2021
3 3382 Thu, 10 June 2021 03:39
  [EMF Forms]
View models not rendered
By: Eclipse User on Tue, 23 March 2021
3 2078 Tue, 30 March 2021 03:44
  EMF - adding new model objects programmatically
By: Eclipse User on Wed, 10 February 2021
2 1986 Thu, 11 February 2021 01:24
  [Edapt] replace attribute with existing abstract class
What operation to use to replace an attribute with and existing abstract class which has the same attribute
By: Eclipse User on Tue, 22 December 2020
1 2146 Wed, 23 December 2020 05:10
  Status of Texo
Is Texo still viable?
By: Eclipse User on Thu, 12 November 2020
2 1976 Fri, 13 November 2020 04:41
  Texo support for fluent methods?
By: Eclipse User on Tue, 29 September 2020
0 1897 Tue, 29 September 2020 19:54
  Edapt migration for proxy ID changes between variables on element
By: Eclipse User on Fri, 26 June 2020
1 3056 Mon, 29 June 2020 09:23
  Unrecognized variable: (name) error in Acceleo
getting Unrecognized variable: (name) error in Acceleo
By: Eclipse User on Thu, 25 June 2020
1 1911 Fri, 26 June 2020 00:53
  [EMF Forms] TreeMasterDetail view priority issue
TreeMasterDetail not displaying in makeithappen example
By: Eclipse User on Fri, 19 June 2020
4 3110 Wed, 24 June 2020 06:17
  EMF form editor not available
EMF form editor
By: Eclipse User on Sun, 21 June 2020
2 2290 Tue, 23 June 2020 08:09
  Upgrade to 2019-06 -> Every Right Clock causes CoreException Now
By: Eclipse User on Mon, 27 April 2020
2 2163 Thu, 07 May 2020 07:23
  EMF + Multiple inheritance with Interfaces
By: Eclipse User on Thu, 30 April 2020
0 5470 Thu, 30 April 2020 11:32
  Ecore to Emfatic conversion standalone application
Questions regarding standalone application of Ecore to Emfatic conversion
By: Eclipse User on Tue, 26 December 2017
4 4869 Wed, 15 April 2020 04:54
  EMF Forms drop-down
Strings based drop-down
By: Eclipse User on Fri, 13 March 2020
2 2813 Wed, 18 March 2020 12:54
  Template model editor issue
The template model editor fails to open a template model after eclipse restart.
By: Eclipse User on Thu, 13 February 2020
14 5910 Thu, 12 March 2020 18:28
  [ECP] Model Explorer e4
By: Eclipse User on Sat, 04 April 2015
8 6165 Tue, 18 February 2020 06:27
  Generate actor system from an EMF meta-model
How to generate an "EMF aware" actor system from a meta-model ?
By: Eclipse User on Mon, 20 August 2018
5 4727 Wed, 29 January 2020 10:16
  Are Sirius and EMF Forms mutually exclusive?
By: Eclipse User on Fri, 03 January 2020
5 3880 Wed, 15 January 2020 06:20
By: Eclipse User on Thu, 26 December 2019
3 4008 Thu, 09 January 2020 03:47
  Can EMF Forms change an Ecore model?
1 2778 Tue, 07 January 2020 06:24
  [EEF]
IEEFLifecycleManagerProvider contribution
By: Eclipse User on Mon, 02 December 2019
2 2174 Thu, 05 December 2019 05:02
  Edapt migrate the class with slots in inverse order
By: Eclipse User on Mon, 21 October 2019
5 8684 Wed, 27 November 2019 11:07
  No property tester contributes a property org.eclipse.emf.ecp.core.project.open
No property tester contributes a property org.eclipse.emf.ecp.core.project.open to type class org.eclipse.core.internal.resources.Project
By: Eclipse User on Sun, 10 November 2019
6 6756 Tue, 12 November 2019 05:50
  EMFForms: selecting different viewmodels programatically
1 6760 Wed, 23 October 2019 11:07
  How to set Enum value in custom edapt migration
By: Eclipse User on Wed, 11 September 2019
2 15720 Mon, 21 October 2019 07:52
  [EMF Forms] Enum Dropdown: Value not set on keyboard input if Enter is not pressed
By: Eclipse User on Thu, 06 December 2018
2 3046 Mon, 14 October 2019 11:56
  [Edapt] ClassCastException when migrating models with InstanceClassName-attributes
By: Eclipse User on Wed, 18 September 2019
2 6708 Tue, 08 October 2019 04:43
  [EMF Forms] Showing reference value from another EObject in a Table Control
Does EMF Forms support showing a value from another entity in a view within a table control ?
By: Eclipse User on Wed, 02 October 2019
4 3286 Tue, 08 October 2019 03:54
  [EMF Facet] On the immediate future of the EMF Facet project
By: Eclipse User on Thu, 03 October 2019
0 20893 Thu, 03 October 2019 00:38
  How to include EMF Forms into the workbench editor
By: Eclipse User on Mon, 09 September 2019
2 4677 Wed, 11 September 2019 07:59
  Input validation in EMF Forms - How to compare two attributes
By: Eclipse User on Fri, 30 August 2019
2 227483 Tue, 03 September 2019 08:36
  Modeling Symposium @ EclipseCon Europe 2019
By: Eclipse User on Mon, 19 August 2019
0 4073 Mon, 19 August 2019 06:33
  [EEF]
Generate EEF Architecture error
By: Eclipse User on Wed, 12 June 2019
2 6733 Thu, 13 June 2019 08:27
  EMF Refactor & Modisco Java model
is it possible to using EMF Refactor with modisco java model ?!
By: Eclipse User on Fri, 03 May 2019
0 31750 Fri, 03 May 2019 11:35
  How to unbind F2 key programatically in eclipse java plugin development
By: Eclipse User on Wed, 24 April 2019
1 5301 Wed, 24 April 2019 10:12
  [EMF Search] How to use from RCP app
Using EMF Search
By: Eclipse User on Mon, 08 April 2019
2 2714 Mon, 08 April 2019 03:18
  First steps to Edapt with multiple ecore models
By: Eclipse User on Wed, 20 March 2019
4 3903 Thu, 04 April 2019 09:14
  [EMFStore] Performance Measure
The performance of EMFStore becomes slower as the number of elements increases
By: Eclipse User on Sat, 09 March 2019
2 16736 Tue, 12 March 2019 08:58
  EMF Neon problem
Unable to build a working run configuration with Neon EMF.
By: Eclipse User on Tue, 02 August 2016
7 8906 Tue, 05 March 2019 09:55
  Unable to update the URI fragment of proxy element on Edapt Migration
By: Eclipse User on Wed, 27 February 2019
3 4347 Tue, 05 March 2019 04:30
  Edapt doesn't do specialize reference type while ecore migration changes
By: Eclipse User on Fri, 08 February 2019
5 4165 Wed, 27 February 2019 04:20
  [EDAPT] Edapt in a Spring application
3 5850 Mon, 18 February 2019 09:27
  [EMF Forms] Problem with rendering of Collapsible Group
Complement topic https://www.eclipse.org/forums/index.php/t/1097445/
By: Eclipse User on Wed, 06 February 2019
1 3129 Thu, 07 February 2019 03:40
Problem with rendering of Collapsible Group in a View Proxy
1 3586 Thu, 07 February 2019 03:39
  [EMF Forms] ViewModel, FeaturePath and Table controls
[EMF Forms] ViewModel, FeaturePath and Table control Questions
By: Eclipse User on Thu, 31 January 2019
3 3517 Mon, 04 February 2019 04:30
  sub metamodel detection
By: Eclipse User on Wed, 05 December 2018
7 4771 Mon, 24 December 2018 15:37
  [EMF Forms] EMFFormsSWTLayoutDelayed: invalid thread accsess
Multiple Ui Sessions with emf
By: Eclipse User on Wed, 12 December 2018
2 3440 Fri, 14 December 2018 04:03
  [EMF FORMS] TableControl WithDialog
2 2826 Thu, 13 December 2018 09:06
  [EMF Forms] New custom controls
By: Eclipse User on Mon, 10 December 2018
2 3214 Tue, 11 December 2018 10:25
  Use of ecore2xml mappings
By: Eclipse User on Wed, 28 November 2018
5 3733 Thu, 29 November 2018 08:17
  [Edapt] Unexpected behavior by defaultValueLiteral change
By: Eclipse User on Wed, 14 November 2018
1 4660 Mon, 19 November 2018 04:20
  [Facet] Support additional query language
Add support for additional query languages
By: Eclipse User on Fri, 16 November 2018
0 4252 Fri, 16 November 2018 09:07
  [Edapt] UI freezes when comparing ecore files (with history)
By: Eclipse User on Tue, 02 October 2018
3 3964 Mon, 15 October 2018 08:54
  [EMF Forms] Maven artefacts
Is there a public maven repository containing ECP/EMF Forms artefacts?
By: Eclipse User on Thu, 27 September 2018
1 3475 Sun, 30 September 2018 03:46
  [EMF Forms] Non-ASCII viewmodel generation
By: Eclipse User on Tue, 29 May 2018
2 45158 Sun, 30 September 2018 03:24
  [EMF Forms] Dynamic Auto-Complete on a single details page
By: Eclipse User on Wed, 22 August 2018
6 5842 Tue, 25 September 2018 06:15
  Texo bi-directional association.
By: Eclipse User on Thu, 20 September 2018
0 5926 Thu, 20 September 2018 04:26
  EMF Extended meta data annotation
Use Of extended meta data
By: Eclipse User on Wed, 19 September 2018
1 2610 Wed, 19 September 2018 07:14
  [EMF Forms] Sorting numbers in a table control
3 4252 Thu, 23 August 2018 05:47
  Modeling Symposium @ EclipseCon Europe 2018
By: Eclipse User on Mon, 06 August 2018
0 4169 Mon, 06 August 2018 10:16
  Ecore to EMF Editor Plugin - Error in serialization
By: Eclipse User on Mon, 23 July 2018
0 3135 Mon, 23 July 2018 16:38
  [EMF Forms] View Proxy on feature-level
By: Eclipse User on Wed, 25 July 2018
2 3540 Thu, 26 July 2018 10:36
  [Emf Forms] Tooltips in Views
By: Eclipse User on Tue, 16 February 2016
13 12279 Wed, 25 July 2018 04:48
  EMF Forms custom file extension/file type
By: Eclipse User on Mon, 21 May 2018
8 7680 Fri, 06 July 2018 06:23
  Pb change version ECP
org.eclipse.emf.ecp.ui.view.ECPRendererException: No EMFFormsRendererService available! at org.eclipse.emf.ecp.view.internal.swt.ECPSWTViewRendererImpl.render(ECPSWTViewRendererImpl.java:95)
By: Eclipse User on Tue, 03 July 2018
10 6086 Wed, 04 July 2018 17:53
icon5.gif [EMFForms] Get label + control from view model elements as SWT control?
By: Eclipse User on Mon, 20 February 2017
6 8809 Wed, 04 July 2018 03:22
  [Edapt] XML parsing issue when migrating older model
createFromString() is called on EFactoryImpl not on MyModelFactoryImpl
By: Eclipse User on Wed, 06 June 2018
6 7901 Mon, 25 June 2018 02:50
  [EEF] Trouble getting custom properties view to update model
By: Eclipse User on Wed, 20 June 2018
1 3148 Fri, 22 June 2018 07:54
  [Edapt] Feature not found when migrating
Feature not found exception is thrown during migration or when loading the reasource
By: Eclipse User on Fri, 08 June 2018
6 8815 Tue, 19 June 2018 09:06
  [EMF Forms] Changing visible columns and their order in a table
By: Eclipse User on Thu, 14 June 2018
6 5799 Mon, 18 June 2018 09:14
  [EMF Forms] Move from 1.9 to 1.17
Moving from 1.9 to 1.17 produces errors
5 5154 Mon, 18 June 2018 04:05
  how to display eStructuralFeatures based on certain condition
can test fields be rendered on GUI screen depending upon configuration or condition
By: Eclipse User on Tue, 12 June 2018
3 4092 Thu, 14 June 2018 03:30
  [EMF Forms] Generic Editor and RAP
By: Eclipse User on Thu, 31 May 2018
3 4437 Sun, 03 June 2018 06:34
icon5.gif [EMF Forms] What happened to the JavaFX renderer between version 1.7.2 and 1.8.0?
By: Eclipse User on Wed, 26 October 2016
5 6645 Mon, 28 May 2018 03:29
  [EMF FORMS]Dead loop for 'TreeMasterDetailSWTRenderer'
Using tree master detail in emf forms
By: Eclipse User on Thu, 19 April 2018
4 5581 Thu, 26 April 2018 10:13
  [EMF Forms] Question about Table Custom Control
By: Eclipse User on Mon, 16 April 2018
1 3581 Tue, 17 April 2018 03:27
  [EMF Forms] Extending Table Control - improved support for tables in 1.8.0?
By: Eclipse User on Thu, 10 March 2016
4 4954 Thu, 29 March 2018 08:26
  Model as a Backend?
By: Eclipse User on Tue, 27 March 2018
0 5492 Tue, 27 March 2018 10:05
  EMF Forms Widget Disposed Exception
I get Widget Disposed Exception when using a ECPSWTViewRenderer.INSTANCE.render(...);
By: Eclipse User on Tue, 20 February 2018
1 4436 Fri, 23 February 2018 09:49
  Generated *FactoryImpl is not an instance of Resource.Factory
Could the problem be in the source XSD?
By: Eclipse User on Fri, 16 February 2018
4 4493 Sat, 17 February 2018 01:23
  Model Explorer view reload
By: Eclipse User on Tue, 19 December 2017
6 5383 Fri, 16 February 2018 04:40
  [Edapt] Can't get values in Custom Migration
By: Eclipse User on Wed, 31 January 2018
4 6585 Tue, 13 February 2018 07:37
  EMFStore produce deployable WAR-File with Tycho
By: Eclipse User on Mon, 29 January 2018
4 6091 Tue, 06 February 2018 09:19
  [EMFStore][Edapt] Meta Model evolution
By: Eclipse User on Thu, 17 March 2016
4 7387 Tue, 23 January 2018 03:22
  Using EMF Resource to iterate over contents of model file
By: Eclipse User on Wed, 03 January 2018
5 4701 Thu, 04 January 2018 03:03
  JavaFX support for ECP
By: Eclipse User on Thu, 21 December 2017
1 5907 Wed, 27 December 2017 05:46
  Example implementation of ECPModelElementOpener
Request for example implementation for ECPModelElementOpener suggested in ECP tutorial
By: Eclipse User on Wed, 22 November 2017
3 6903 Tue, 19 December 2017 05:02
  Select renderer in view model
Support selection rules for renderers
By: Eclipse User on Wed, 08 November 2017
1 6421 Thu, 14 December 2017 10:20
  Toolbar actions for GenericEditor
Access to the editing domain and control enablement
1 6174 Thu, 14 December 2017 10:13
  [EMF Forms] Issue with serialisation code in Generic Editor
3 4270 Thu, 16 November 2017 03:14
  editor.getEditorInput()
By: Eclipse User on Thu, 19 October 2017
2 3593 Wed, 25 October 2017 11:30
  [Edapt] Extend migration engine
By: Eclipse User on Wed, 04 October 2017
2 7458 Thu, 19 October 2017 09:46
  [Edapt] Strange behavior in Classifiers ID
By: Eclipse User on Mon, 21 August 2017
1 11943 Fri, 13 October 2017 05:47
  [Edapt] Can't migrate model after referenced model is migrated?
By: Eclipse User on Sun, 19 March 2017
6 9855 Fri, 13 October 2017 05:31
  Path through an EMF graph
Is there something similar to XPath for EMF?
By: Eclipse User on Wed, 11 October 2017
1 3592 Thu, 12 October 2017 10:23
  Instantiating and EMF object
I need to instantiate an EMF object using only names and byte arrays
By: Eclipse User on Mon, 18 September 2017
3 16895 Thu, 05 October 2017 05:40
  [EMF Forms] Editing optional domain elements
How to edit optional elements and have them created only if some inner fields are set?
By: Eclipse User on Fri, 15 September 2017
6 22195 Wed, 27 September 2017 10:27
  Dynamic creation of EObject
I am missing something wrt EPackages
By: Eclipse User on Wed, 20 September 2017
1 4585 Wed, 20 September 2017 10:27
  Edapt sych on Ecore editor
By: Eclipse User on Fri, 08 September 2017
1 9525 Mon, 11 September 2017 07:57
  [Teneo] Problem with Enumerated Key in EMap
EMap with Enumerated Key is ignored
0 14599 Fri, 08 September 2017 11:33
  [EMF Forms] Performance Issues with Master-Detail controls (Tree and Table)
By: Eclipse User on Tue, 05 September 2017
1 7290 Wed, 06 September 2017 03:57
  [EMF Forms] Reference Selection Popup Behaviour Curious
By: Eclipse User on Sat, 26 August 2017
3 8077 Mon, 28 August 2017 16:53
  Install EEF 2.0.0
HowTo install it?
By: Eclipse User on Wed, 23 August 2017
1 13123 Mon, 28 August 2017 03:50
  Browse EMF Registry
1 10303 Fri, 25 August 2017 02:07
  [Texo] Latest version of texo not published to maven?
By: Eclipse User on Thu, 24 August 2017
0 10938 Thu, 24 August 2017 18:39
  Null Pointer Exception after Migrating an Ecore model instance using EDapt
After EDapt migrated my model instance, I got a Null Pointer Exception (generated by org.eclipse.jface plugin when trying to render an icon image) as shown in the attached image files. I tried to debu
By: Eclipse User on Sun, 20 August 2017
4 13089 Wed, 23 August 2017 07:26
  Execute migration with Edapt
By: Eclipse User on Wed, 25 July 2012
7 16030 Tue, 22 August 2017 05:56
  Change all References from One Resource to another
0 12321 Mon, 21 August 2017 04:48
  Modeling Symposium @ EclipseCon Europe 2017
By: Eclipse User on Thu, 17 August 2017
0 11484 Thu, 17 August 2017 06:28
  [Proposal] Project EMF Feature Model approved
By: Eclipse User on Wed, 14 October 2009
2 10977 Mon, 14 August 2017 12:52
  [EMF Forms] Target Platform Update Site for 1.13 unavailable?
By: Eclipse User on Fri, 04 August 2017
2 6188 Mon, 07 August 2017 13:57
  checking one of the references can be created
By: Eclipse User on Sun, 06 August 2017
3 8603 Mon, 07 August 2017 09:59
  [EMF Forms] EClass from View model cannot be resolved
By: Eclipse User on Thu, 20 July 2017
3 11695 Mon, 31 July 2017 13:10
  Resource
By: Eclipse User on Fri, 07 July 2017
31 37487 Mon, 31 July 2017 10:00
  [Edapt] Format of resourceURI to get the Releases from the Migrator?
By: Eclipse User on Fri, 14 July 2017
4 19027 Tue, 25 July 2017 04:59
  [EMF Forms] Text field active for unsettable features
1 6570 Mon, 24 July 2017 06:18
  can not open the model
By: Eclipse User on Wed, 19 July 2017
3 9265 Thu, 20 July 2017 03:19
  EMF Forms
Text Control selects the text on focus gained
1 5195 Wed, 19 July 2017 11:51
  [Edapt] Unmodeled XML attributes got lost during migration
By: Eclipse User on Tue, 11 July 2017
2 9600 Tue, 18 July 2017 08:24
  [EMF Forms] Table: Single column for different EStructuralFeatures
2 8257 Wed, 12 July 2017 07:45
  StackOverflowError on EPackageRegistryImpl
Unable to launch product due to EMF initialization issue
By: Eclipse User on Wed, 05 July 2017
2 9044 Thu, 06 July 2017 04:19
  [Edapt] DiagnosticException while migrating
By: Eclipse User on Thu, 29 June 2017
7 16836 Tue, 04 July 2017 09:41
  Distinguishing "logical" Ecore elements from additional "technical" ones
By: Eclipse User on Sun, 25 June 2017
5 11515 Mon, 26 June 2017 06:08
  distinguish between EClasses
By: Eclipse User on Thu, 22 June 2017
8 11337 Fri, 23 June 2017 09:43
  EMF to USE
By: Eclipse User on Fri, 09 June 2017
5 13574 Thu, 22 June 2017 14:19
  [EMF Forms] Ecore and Genmodel editor issues
By: Eclipse User on Mon, 19 June 2017
4 16161 Wed, 21 June 2017 03:30
  modeling attribute as enum in ecore
By: Eclipse User on Tue, 06 June 2017
1 10185 Tue, 06 June 2017 23:31
  can-not open xmI files
By: Eclipse User on Wed, 31 May 2017
10 25404 Fri, 02 June 2017 20:24
  EMFStore on Tomcat: How to set it up using MongoDB?
By: Eclipse User on Wed, 24 May 2017
3 20744 Fri, 02 June 2017 10:26
  How to add a map with generics?
By: Eclipse User on Thu, 01 June 2017
2 7124 Thu, 01 June 2017 05:33
  Question Generating from XSD
EMF can't read XML that conforms to schema
By: Eclipse User on Fri, 26 May 2017
9 20201 Wed, 31 May 2017 10:30
  EMFStore: Is EPackage registration at runtime supported?
1 18150 Wed, 31 May 2017 03:52
  [ECP: Update content of boton of ecp forms]
Update default boton of ecp forms
By: Eclipse User on Tue, 30 May 2017
1 9395 Wed, 31 May 2017 02:53
  Location of LDAP server logs at Startup
3 7146 Thu, 25 May 2017 16:37
  Create diagram view of model
By: Eclipse User on Fri, 05 May 2017
5 11384 Fri, 19 May 2017 02:01
  convert ecore to xmi
4 15498 Fri, 19 May 2017 01:53
  Cannot create genmodel from valid schema.
two xs:IDs causes error
By: Eclipse User on Tue, 16 May 2017
1 4282 Tue, 16 May 2017 14:38
  [EMFStore]: What do I to invoke LADPUserVerifier Class
How do I define es.properties file to invoke LADPUserVerifier Class
By: Eclipse User on Tue, 09 May 2017
3 13017 Thu, 11 May 2017 12:46
  [EMFStore]: How do you extend loginService
Extension point to extend ServiceLogin Class
By: Eclipse User on Thu, 04 May 2017
2 21182 Wed, 10 May 2017 07:53
  [EMFStore]:How do you configure LDAP properties
By: Eclipse User on Wed, 03 May 2017
6 11051 Mon, 08 May 2017 15:54
  [EMFStore]:
How do I configure EMFStore
By: Eclipse User on Wed, 26 April 2017
4 14317 Fri, 05 May 2017 08:52
  [EMF Forms] Writing JUnit Tests for EMF Forms Use Case
1 11309 Thu, 04 May 2017 02:52
  [EMFStore] e4 RCP
Unable to create + connect to EMF Store in e4 RCP
By: Eclipse User on Thu, 27 April 2017
1 7452 Thu, 27 April 2017 11:39
  [EMFStore] Sharing same EditingDomain between Eclipse Workspace and EMFStore Workspace
Experiencing problem with differing CommandStacks
By: Eclipse User on Tue, 11 April 2017
7 28078 Thu, 27 April 2017 03:47
  [EMF Forms] - Custom Control Area
Unable to create Custom Control Areas
By: Eclipse User on Thu, 20 April 2017
5 17171 Wed, 26 April 2017 11:34
  [Edapt] Creating history from existing metamodel versions
Can you create migration operations for externally maintained metamodels?
By: Eclipse User on Mon, 24 April 2017
1 8292 Mon, 24 April 2017 05:31
  TreeViewerSWTFactory drag and drop exceptions
default drag and drop causes null pointer exceptions
By: Eclipse User on Tue, 04 April 2017
2 10594 Wed, 05 April 2017 18:08
  [Edapt] Migrating a file with multiple model namespaces
By: Eclipse User on Thu, 23 March 2017
6 17705 Wed, 05 April 2017 04:42
  [EMF Forms] Multiple views for one type
By: Eclipse User on Mon, 03 April 2017
1 7706 Tue, 04 April 2017 04:57
  [EMF Forms] Iterating over properties
By: Eclipse User on Mon, 20 March 2017
10 15480 Tue, 04 April 2017 03:25
  [EMF Forms] Multiple views of a model class with e4
By: Eclipse User on Tue, 28 March 2017
4 13419 Fri, 31 March 2017 17:40
  [EMF/EMF Forms] RCP Dependencies / Requirements
Which features are required to run a standalone E4 RCP product with EMF Forms
4 7759 Tue, 28 March 2017 13:04
  [EMF Forms] integrate Buttons for operations
By: Eclipse User on Sun, 05 March 2017
5 9641 Sat, 25 March 2017 14:32
  EMF Refactor
By: Eclipse User on Wed, 08 March 2017
4 13381 Fri, 17 March 2017 20:43
  EMF Forms: PackageNotFoundException for view proxy model
emfforms viewproxy model seems not to be there
By: Eclipse User on Fri, 10 March 2017
4 12547 Thu, 16 March 2017 05:07
  [EMF Forms]Unusual Model element creation
By: Eclipse User on Tue, 28 February 2017
5 11771 Thu, 16 March 2017 04:18
  [EMF Transaction] How to correctly handle changes on the file level in EMF?
By: Eclipse User on Tue, 14 March 2017
1 6010 Wed, 15 March 2017 04:54
  [EMF Forms] : EEnum ComboCellEditor in TableControl?
2 7103 Mon, 13 March 2017 15:05
  EMF Forms: Format correctly a custom field
By: Eclipse User on Fri, 03 March 2017
8 12987 Fri, 10 March 2017 10:14
  EMF Forms: Customize derived field - Modification is ignored
9 9796 Thu, 09 March 2017 11:19
  EMF Forms: How to disable the add button for references field
4 8029 Mon, 06 March 2017 08:43
  Extending ECPReferenceService
By: Eclipse User on Wed, 15 February 2017
10 17345 Tue, 28 February 2017 07:11
  [Xcore] Generate code in Tycho build
By: Eclipse User on Sun, 26 February 2017
2 5536 Tue, 28 February 2017 06:26
  [Xcore] Project does not build anymore after git clean -fdx
Project is missing required source folder: 'src' despite it exists
By: Eclipse User on Fri, 24 February 2017
4 4824 Fri, 24 February 2017 07:24
  [EMFForms] Support for Nebula's GeoMap widget
Is there interest for support for Nebula's GeoMap widget?
By: Eclipse User on Sat, 18 February 2017
5 12414 Thu, 23 February 2017 03:17
  [EMF Forms] Working with TransactionalEditingDomain
Getting exceptions in EMF forms when the editor uses TransactionalEditingDomain
By: Eclipse User on Thu, 16 February 2017
2 5635 Fri, 17 February 2017 03:10
  [EMFForms]Disable Create and Link button in Table Control
By: Eclipse User on Mon, 14 November 2016
5 14188 Thu, 16 February 2017 09:07
  Need to Filter some objects in Select Element dialog.
Select Element Dialog filteration is required.
1 9628 Thu, 16 February 2017 03:17
  [EMF Forms] TableFactory with EditingSupport
By: Eclipse User on Thu, 09 February 2017
1 12371 Tue, 14 February 2017 04:24
  Genmodel Dynamic Template Empty Class File
Using dynamic template with default Class.javajet generates an empty class file.
By: Eclipse User on Fri, 10 February 2017
1 6973 Mon, 13 February 2017 04:03
  [EMF Forms] Instance model changes in e4
By: Eclipse User on Fri, 03 February 2017
6 10127 Wed, 08 February 2017 11:19
  [EMF Forms] Render asynchronously
By: Eclipse User on Wed, 04 January 2017
2 4349 Tue, 07 February 2017 05:58
Current Time: Wed Apr 16 04:31:50 EDT 2025
Powered by FUDForum. Page generated in 0.03793 seconds
