Constantly asking to download index.html |
6836 |
Tue, 02 July 2024 09:32 By: Monaliza Monaliza ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[ANNOUNCEMENT] The MAT code repository has changed |
743 |
Wed, 08 May 2024 21:40 By: Krum Tsvetkov ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to calculate the deep object size in MAT? By: S J on Fri, 05 April 2024 |
942 |
Fri, 05 April 2024 17:48 By: S J ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
MAT 1.15.0.20231206-linux - seems blocked MAT never ending |
818 |
Sun, 31 March 2024 17:53 By: MARCO CORRENTI ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
MAT is not working on MAC Book PRO Apple M2 Max MAT is giving error and in second case crashing |
849 |
Tue, 26 March 2024 20:28 By: S J ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Does MAT run fully locally? |
8403 |
Mon, 18 March 2024 10:07 By: Krum Tsvetkov ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to find a thread in "thread_overview" that cased OutOfMemoryError? |
6425 |
Tue, 30 January 2024 02:04 By: Dmitry Katsubo ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Unknown host cbi.eclipse.org: Name or service not known Error while building Eclipse-mat Version 1.15.0 from source code using Tycho/Maven |
905 |
Thu, 25 January 2024 15:00 By: Ruthwik K ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Vulnerabilities in MAT 1.13 Vulnerabilities in MAT 1.13 |
3869 |
Fri, 17 November 2023 02:17 By: Byrd Franklin ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Question re: native threads and entires in coredump |
10474 |
Fri, 15 September 2023 09:39 By: Andrew Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Cannot group BigDecimals by value Cannot group BigDecimals by value |
1228 |
Wed, 06 September 2023 09:51 By: Andrew Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
IBM Semeru DFTJ incompatibility Caused by: java.lang.IllegalAccessError: Class com/ibm/dtfj/image/j9/ImageFactory(unnamed module 0x0000000701C2CA68) can not access class jdk/internal/module/Modules(java.base) because module java.bas |
1865 |
Wed, 30 August 2023 19:24 By: Gary Johnston ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
"Not a HPROF heap dump" with IBM .dmp on v1.14.0 |
836 |
Thu, 27 July 2023 21:29 By: Andrew Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
MAT in batch mode stuck at a subtask |
2656 |
Fri, 21 July 2023 07:58 By: Andrew Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
About size of Memory Analyzer of column dominator_tree view the column size |
2723 |
Mon, 17 July 2023 01:30 By: No Ralph ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Programmatically detect memory leaks using MAT API |
1132 |
Thu, 11 May 2023 13:45 By: Andrew Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to serialize ISnapshot object Unable to serialize ISnapshot |
3493 |
Sat, 22 April 2023 16:05 By: Andrew Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
MAT Histogram Objects count is not equal Android Studio Profiler MAT Histogram Objects count is not equal Android Studio Profiler |
2769 |
Thu, 06 April 2023 15:14 By: Dtuto Hai ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Errors deploying plugin |
2361 |
Thu, 23 March 2023 13:06 By: Richard Olson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
MAT not working on mac apple m1 pro MAT not working on mac apple m1 pro |
1979 |
Mon, 17 October 2022 16:45 By: Andrew Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Unable to build locally on linux |
1491 |
Mon, 03 October 2022 15:52 By: Andrew Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Unable to delete heap dump file after getting ISnapshot object |
1140 |
Thu, 29 September 2022 09:37 By: Mahesh D ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Issues using IBM Seamer DTFJ Problems reading .dmp files |
4163 |
Sat, 27 August 2022 15:09 By: Richard Olson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
how to get gc root of object using oql ? MAT OQL GC ROOT |
8506 |
Fri, 01 July 2022 06:08 By: Andrew Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to include retained size column (with precise or approximate values) in histogram command result Print Retained size column in histogram command, or Deeper levels in dominator_tree command |
1216 |
Thu, 30 June 2022 16:41 By: Andrew Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Locate Sockets How to locate sockets |
1947 |
Thu, 24 March 2022 15:39 By: Andrew Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
QuerySpec collapsed is it possible to construct a QuerySpec in collapsed mode By: G Xu on Thu, 17 March 2022 |
3885 |
Tue, 22 March 2022 14:30 By: Andrew Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
fields of objects not shown in inspector / attributes |
4023 |
Wed, 02 March 2022 15:02 By: German Corbetta ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Histogram comparison for identify memory issue on java classes Histogram Diff to identify the memory leaks on java class |
3562 |
Tue, 01 February 2022 13:44 By: Andrew Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Unable to open openj9 coredump file via Eclipse project |
2400 |
Tue, 12 October 2021 17:51 By: Richard Olson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Issues with MAT reading AdoptJDK openj9 core.dmp files open the core.dmp file using MAT 1.11 or 1.12 and during index creation MAT generates a .threads file. The .threads file's missing thread stack traces and locals, |
2296 |
Fri, 23 July 2021 12:53 By: Richard Olson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Inspect objects from comparison For example, suppose +100 java.lang.String found, be able to see those specific strings |
1415 |
Thu, 22 July 2021 10:43 By: Andrew Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
HTML Report How to include mat://object/0x7f8d7c60f188 |
1392 |
Sat, 17 July 2021 10:42 By: Andrew Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Leak Suspect Report makes huge file I wanted to make a Leak Suspect Report of a hprof file and got an html file which filled my SSD whoch |
6537 |
Wed, 14 July 2021 13:59 By: Electric Eel ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Mat Linux Command Line Usage with Discard Feature Mat Linux Command Line Usage with Discard Feature |
2196 |
Mon, 14 June 2021 23:55 By: Louis Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Not A HPROF heap dump when parsing PHD files Facing this errors while parsing PHD dumps using ParseHeapDump.sh on Linux |
6933 |
Sat, 12 June 2021 12:31 By: Andrew Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
MAT command line with IBM PHD files? |
3715 |
Sun, 02 May 2021 17:15 By: Ruchir Verma ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
MAT Blank Screen when using MacOS Big Sur |
2573 |
Fri, 15 January 2021 09:16 By: Scott Sue ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
MAT doesn't respond to any mouse click on Mac OS MAT doesn't respond to any mouse click on Mac OS |
3220 |
Mon, 30 November 2020 14:36 By: Andrew Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Problems with getting reports running remotely Problems with getting reports running remotely |
2516 |
Thu, 19 November 2020 09:41 By: Gregor Kofler ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Creating MAT Plugin guidance |
1894 |
Thu, 05 November 2020 18:56 By: Richard Olson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Web UI for Memory Analyzer web based heap dump analysis for remote heap dumps. |
3411 |
Mon, 14 September 2020 08:06 By: Andrew Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Using MAT ExportPROF in normal java application How to use the MAT ExportPROF plugin functionality in normal java application? |
1988 |
Sun, 30 August 2020 07:12 By: Andrew Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to import google gson in eclipse MAT Need help for adding google gson dependency in eclipse MAT. |
2981 |
Mon, 29 June 2020 19:39 By: Andrew Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Auto launch an user defined query Auto launch an user defined query By: G Xu on Thu, 18 June 2020 |
2013 |
Fri, 19 June 2020 13:11 By: G Xu ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
OOM error Finalizer OOM error Finalizer |
5176 |
Sat, 06 June 2020 14:30 By: Romit Saha ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
OQL: Why is the returned object not a String but "com.ibm.wps.state.keymanager.ValueImpl"? OQL question on type of returned object type |
2298 |
Fri, 29 May 2020 11:27 By: Andrew Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
DTFJ Error Opening Core Dump |
5649 |
Wed, 27 May 2020 07:01 By: Hermann Huebler ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Memoryanalyzer.exe won't boot after editing .ini file |
3629 |
Sun, 05 April 2020 09:27 By: Andrew Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
MAT Heap Dump Comparison Algorithm Description of the |
4750 |
Thu, 26 March 2020 12:57 By: Andrew Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Retained heap calculated incorrectly in dominator tree? Question about the retained heap being shown |
2345 |
Fri, 28 February 2020 16:15 By: Andrew Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Get list_objects in a custom mat report Memory analyzer:Custom reports- get html report |
3721 |
Mon, 24 February 2020 05:22 By: Mihir Solanki ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Query: Group By Value shows no values |
4806 |
Tue, 18 February 2020 08:06 By: Andrew Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Two security issues fixed in Memory Analyzer |
200713 |
Fri, 17 January 2020 21:09 By: Krum Tsvetkov ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
OQL Enhancements Improvements to Object Query Language |
2871 |
Thu, 28 November 2019 14:49 By: Andrew Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Query returns 0 results |
11721 |
Tue, 05 November 2019 15:32 By: Richard Olson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
What do mean Ref as Table in Mat ? What do mean Ref as Table in Mat ? |
10912 |
Mon, 16 September 2019 11:23 By: Krum Tsvetkov ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Is there a command line argument or an API to access the dominator tree in Eclipse MAT analyzer tool |
32921 |
Sun, 08 September 2019 07:15 By: Andrew Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Pie chart does not display in overview tab of Memory Analyzer Pie chart does not display in overview tab of Memory Analyzer |
123619 |
Sun, 08 September 2019 06:56 By: Andrew Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
cannot load hprof file with heap dump error heap exhaust running analyzer...1.9 |
10654 |
Thu, 18 July 2019 08:57 By: Taly Elani ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to write MAT Custom Reports? Where is the documentation for writing custom reports with the intent of running them using ParseHeapDump.sh |
5585 |
Tue, 18 December 2018 19:22 By: Mark Malynn ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Meaning of Overview->Details->Size |
3216 |
Wed, 07 November 2018 06:47 By: Jonathan Lu ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Does Eclipse OQL support map access? |
7187 |
Wed, 24 October 2018 00:24 By: Jeffery Yuan ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
MAT dependency Adding Maven dependency to MAT |
4444 |
Sat, 15 September 2018 08:10 By: Andrew Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
MAT report from command line I would like to run MAT to generate report from command line |
3708 |
Fri, 14 September 2018 19:13 By: Andrew Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
MAT report with all rows from query (more than 25) |
4140 |
Fri, 14 September 2018 06:24 By: Mikolaj Habdank ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Huge heap dump, but no content? Huge JVM heap dump but MAT shows not content |
14638 |
Tue, 21 August 2018 10:34 By: sasmita dash ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Memory Analyzer 1.8.0 was released! |
4691 |
Thu, 28 June 2018 07:36 By: Krum Tsvetkov ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Analyzing metaspace memory OOME |
20345 |
Sun, 17 June 2018 08:42 By: Andrew Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Unable to see objects when clicking classes from class histogram |
7864 |
Sat, 28 April 2018 10:20 By: Andrew Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Can't use MAT on Mac High Sierra |
11479 |
Mon, 09 April 2018 21:30 By: Jan Monterrubio ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
17417 |
Mon, 09 April 2018 21:42 By: Jan Monterrubio ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Need Help in Launching MAT 1.7 on AIX 7.1 Issue launching the Tool on AIX |
6045 |
Mon, 27 November 2017 15:57 By: Ajay Rnb ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Memory Analyzer 1.7.0 Released |
13588 |
Thu, 02 November 2017 14:09 By: Andrew Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
does MAT work on java 9? question to see if errors noticed in java 9 vm are expected |
6208 |
Thu, 02 November 2017 13:54 By: Andrew Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
ParseHeapdump.sh throws error |
6019 |
Mon, 30 October 2017 17:42 By: Gautham K ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Need help to fix the Spring SessionFactoryImpl Memory leak with Eclipse Memory Analyser Need help to fix the Spring SessionFactoryImpl Memory leak with Eclipse Memory Analyser |
20482 |
Mon, 23 October 2017 08:43 By: Haribabu Puppala ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Strange unknown string instance |
3796 |
Wed, 18 October 2017 02:27 By: jilen zhang ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Examples of eval function use Can't find any info :( |
24317 |
Thu, 01 June 2017 12:02 By: Andrew Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Eclipse memory analyzer unit of measurement |
41727 |
Thu, 01 June 2017 11:37 By: Andrew Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Row colors make rows unreadable |
41235 |
Tue, 14 March 2017 15:44 By: Vladimir Matveev ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Group by attribute |
6661 |
Thu, 19 January 2017 15:22 By: Andrew Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Memory Analyzer 1.6.1 Released |
7004 |
Thu, 08 December 2016 16:29 By: Krum Tsvetkov ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Using MAT to analyze Eclipse OOME (headless) |
8479 |
Thu, 29 September 2016 15:00 By: Krum Tsvetkov ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to extend Memory Analyzer |
6839 |
Wed, 28 September 2016 09:47 By: Francesco Fucci ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
MAT 1.6 OQL object de-reference problem - yields blank row values Ex: "select s.name.toString() from someClass s" yields blanks |
10047 |
Wed, 24 August 2016 15:18 By: Andrew Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
OQL nested list flattening and filtering Trying to find deeply nested in sublists based on object properties |
7824 |
Sat, 02 July 2016 00:10 By: ken marx ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Memory Analyzer 1.6.0 Released |
5490 |
Fri, 24 June 2016 11:19 By: Krum Tsvetkov ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Same reports after application/device restart? |
5092 |
Mon, 30 May 2016 20:51 By: mr Antback ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
![icon3.gif](images/message_icons/icon3.gif) |
Will us support Android format hprof dump in the furture?(version 1.0.3) |
6266 |
Mon, 02 May 2016 12:10 By: han jinwei ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Memory Analyzer for Embedded C projects |
9231 |
Tue, 01 March 2016 07:03 By: Krishna R ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
retained of linkedhashmap does not include values? |
5617 |
Thu, 28 January 2016 20:08 By: Michael Reiche ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Mat 1.50 failed on NullPointerException when parsing HPROF MAT failed on NPE By: II HH on Fri, 15 January 2016 |
7502 |
Mon, 18 January 2016 18:44 By: Philippe Kernevez ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
MAT stuck at Computing Dominators MAT stuck at Computing Dominators |
8911 |
Sat, 26 December 2015 13:48 By: Erik Brangs ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Do not open customize perspective |
6741 |
Sun, 13 December 2015 02:40 By: Yuuki Masato ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
![icon4.gif](images/message_icons/icon4.gif) |
Numerical values are not shown in Dominator Tree In Dominator Tree Table, the numberic values in Shallow Heap, Retained Heap and Percentage are not shown |
7897 |
Thu, 15 October 2015 06:36 By: Isuru Perera ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
toString a LinkedList Java Collections > Extract List Value fails with a NullPointerException - is OQL possible |
6138 |
Thu, 08 October 2015 00:34 By: Faraz Ali ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to retrieve objects which implements interface! How to retrieve objects which implements interface! |
5510 |
Tue, 22 September 2015 09:17 By: Krum Tsvetkov ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
gc_roots count correct? |
7266 |
Fri, 18 September 2015 06:44 By: Krum Tsvetkov ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
error when opening a heap dump in eclipse MAT (1.5) I created a dump using below command jmap -heap:format=b <process id> and getting the below error when I open it from Eclipse memory analyzer. java.io.EOFException at org.eclipse.mat.parser.io. |
8582 |
Thu, 17 September 2015 15:04 By: Krum Tsvetkov ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Heap dump instances count differs for Visualvm and Eclipse Memory Analyzer Heap dump instances count differs for Visualvm and Eclipse Memory Analyzer |
7861 |
Tue, 08 September 2015 10:27 By: Sergey Maslov ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
![icon10.gif](images/message_icons/icon10.gif) |
5282 |
Mon, 07 September 2015 02:50 By: Xie GuoJun ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Unable to open .bin files generated by jmap with 1.8.0_u60 |
5769 |
Mon, 17 August 2015 15:34 By: Johan Kaving ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
After stopping my test the growth of heap never come down After stopping my test the growth of heap never come down |
4138 |
Mon, 27 July 2015 04:52 By: Manas Jena ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Memory Analyzer 1.5 Released |
3210 |
Wed, 24 June 2015 14:43 By: Krum Tsvetkov ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to extend MAT to simulate select "Show objects by class" -> select "by outgo |
3001 |
Fri, 22 May 2015 14:37 By: Zou Xiao ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Command Line processing of hprof |
22017 |
Fri, 24 April 2015 07:14 By: Kapil Goyal ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Where to download SAP enhancements? By: Eclipse User on Wed, 22 April 2015 |
4324 |
Wed, 22 April 2015 14:43 By: Eclipse User ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Comparing Objects from heap dumps of a process |
3513 |
Sun, 19 April 2015 04:15 By: Quest Heap ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Indicating how old an object is |
4059 |
Mon, 13 April 2015 16:16 By: Mark Robbins ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Export How to? |
3431 |
Thu, 26 March 2015 18:38 By: Kevin Singleton ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Internal error While trying to open a hprof file, internal error |
4636 |
Thu, 26 March 2015 18:32 By: Kevin Singleton ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
![icon11.gif](images/message_icons/icon11.gif) |
Parsing heap dump has encountered a problem |
17215 |
Tue, 27 January 2015 20:58 By: subhrajit senapati ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Dominator tree The entry code for generating dominator tree |
5984 |
Tue, 13 January 2015 08:51 By: Andrew Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Stopping command line report opening Windows error dialog Command line report issues |
3822 |
Wed, 03 December 2014 15:24 By: Chris Hurst ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Help in analyzing java.lang.ref.Finalizer in Heap dump analysis Help in analyzing java.lang.ref.Finalizer in Heap dump |
19702 |
Thu, 20 November 2014 19:33 By: Todd Carmichael ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Unsupported Segment Type 0 errors MAT cannot load an .hprof from Java 1.7 |
6792 |
Wed, 05 November 2014 09:50 By: Andrew Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Can object address help to give me generation info ? |
5056 |
Wed, 22 October 2014 11:10 By: Andrew Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Hash Entries throwing Java_Version error Field 'java_version' of 'class sun.misc.Version contains an illegal object reference: |
6593 |
Wed, 22 October 2014 11:00 By: Andrew Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Multithreading characteristics of MAT API |
4760 |
Wed, 22 October 2014 10:49 By: Andrew Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Heap Analyzer java.lang.OutofMemoryError:java heap space |
9857 |
Fri, 05 September 2014 09:40 By: Julius van ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Leak Suspects Report on Linux How to get a Leak Suspects Report on Linux |
7470 |
Mon, 11 August 2014 08:55 By: Andrew Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Error when opening *.hprof file: No parser registered No parser registered |
6354 |
Sat, 19 July 2014 23:59 By: gunther herbson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Memory Analyzer 1.4.0 is now released! |
5245 |
Wed, 25 June 2014 13:36 By: Krum Tsvetkov ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Using MemoryAnalyzer api's in Java Using MemoryAnalyzer api's in Java By: pradeep on Fri, 30 September 2011 |
18892 |
Wed, 11 June 2014 13:44 By: Maria G ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to create heap dump for spring based web application running in weblogic How to create heap dump for spring based web application running in weblogic |
25462 |
Mon, 09 June 2014 09:00 By: Andrew Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
![icon5.gif](images/message_icons/icon5.gif) |
Extracting large String values from an array (or Collection) |
23110 |
Thu, 01 May 2014 11:23 By: Dan Gravell ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to find a value by map key in by OQL How to find a value by map key in by OQL |
29764 |
Thu, 24 April 2014 10:05 By: Andrew Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
user classes in MAT Way to show user classes in leak suspects |
4853 |
Fri, 07 February 2014 11:16 By: Vitaly Puchkov ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Incorrect(?) retained heap for com.google.common.base.Optional |
8337 |
Wed, 29 January 2014 13:52 By: Lars Oppermann ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Memory Analyzer 1.3.1 Released |
5596 |
Wed, 22 January 2014 15:00 By: Krum Tsvetkov ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Unable to install Memory Analyzer Memory Analyzer install problem |
8263 |
Fri, 20 December 2013 22:14 By: Lori Cook ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
java.io.EOFException with Memory Analyzer 1.3.0 EOF file while opening 5gb Hprof with Memory Analyzer 1.3.0 |
13492 |
Thu, 12 December 2013 08:20 By: Andrew Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
OQL: Need help with query involving object array and sub-select |
13513 |
Mon, 09 December 2013 17:33 By: Andrew Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Newbie: MAT / C++ |
8316 |
Wed, 20 November 2013 17:48 By: Geoff Alexander ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
reachability / retained set |
7837 |
Fri, 15 November 2013 22:41 By: Mighdoll Mising name ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Which algrithm is used for dominator tree calculation? By: f d on Thu, 26 September 2013 |
6032 |
Fri, 27 September 2013 06:22 By: Krum Tsvetkov ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
What would you do if you could run code on heap dumps? |
13524 |
Fri, 13 September 2013 20:11 By: Robin Salkeld ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
OQL: how to define JS functions |
23202 |
Fri, 13 September 2013 20:00 By: Robin Salkeld ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
![icon9.gif](images/message_icons/icon9.gif) |
heap dump file size larger than the heap size heap dump file size larger than the heap size |
6211 |
Mon, 26 August 2013 17:03 By: Michael Makram ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Getting Path to GC through command line |
3801 |
Tue, 23 July 2013 22:46 By: Yu Yang Lai ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Further analysis on memory heap By: ss ss on Fri, 05 July 2013 |
14878 |
Fri, 19 July 2013 11:58 By: ss ss ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Memory Analyzer 1.3.0 Released! |
5899 |
Tue, 16 July 2013 06:50 By: Krum Tsvetkov ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
mem analyzer not coming up |
6187 |
Thu, 11 July 2013 09:00 By: Andrew Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Displaying field/attribute names in Dominator Tree |
5588 |
Thu, 04 July 2013 14:15 By: Krum Tsvetkov ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
OQL: calling Java methods |
11573 |
Tue, 18 June 2013 19:15 By: Robin Salkeld ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Memory analyzer not opening hprof |
8588 |
Mon, 27 May 2013 09:38 By: Andrew Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Thread Details/Overview won't open: Object 0x2aab50739d48 not found. Cannot open the Thread Details or Thread Overview and Stacks options |
13837 |
Sun, 26 May 2013 16:34 By: John Guerrero ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
MAT Main Menu Missing |
10595 |
Thu, 23 May 2013 12:19 By: Rob Shepherd ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Help in analysis Memory analysis. By: ss ss on Sat, 06 April 2013 |
13476 |
Thu, 16 May 2013 09:30 By: ss ss ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to open a HTML report via MAT in Eclipse? HTML leak suspect report |
9205 |
Thu, 16 May 2013 08:12 By: Andrew Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
where I can download some docs about the MAT |
7018 |
Thu, 16 May 2013 08:07 By: Andrew Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to install IEMA into MAT? How to install IEMA into MAT? |
7299 |
Thu, 16 May 2013 08:05 By: Andrew Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
HeapDump HeapDump does not show complete hprof data |
8724 |
Mon, 13 May 2013 09:25 By: Gopabandhu Sahu ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
how to Install Mat on Linux via Terminal Installation and Run MAT |
36753 |
Wed, 13 March 2013 08:02 By: Krum Tsvetkov ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Custom MAT plugin not loaded on startup Custom MAT plugin not loaded on startup |
6084 |
Tue, 12 March 2013 20:37 By: Andrew Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Problem with Memory Analyzer Memory Analyzer doesn't read .hprof file |
6937 |
Fri, 08 March 2013 08:13 By: Jane Tech ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Viewing Stackframes in hprof dumps |
5183 |
Mon, 11 February 2013 11:18 By: Michael Böckling ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
The dreaded 'XPCOM error -2147467259' |
11745 |
Wed, 06 February 2013 05:04 By: rajeshwaran raja ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Live objects in MAT histogram? Memory Analyzer Tool (Android dev) |
6911 |
Fri, 25 January 2013 08:45 By: Krum Tsvetkov ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Sorry, Extreme Beginner here Please if you are seeing this, try to help. I'm very very new. By: Chris L on Sat, 19 January 2013 |
4670 |
Sat, 19 January 2013 01:29 By: Chris L ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Limited formats - hprof vs phd Cannot open some formats that others can |
6805 |
Fri, 18 January 2013 13:27 By: Krum Tsvetkov ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Differences in supported dump file formats Are there differences between linux/windows formats? |
7529 |
Fri, 18 January 2013 13:25 By: Krum Tsvetkov ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to start MAT |
21077 |
Wed, 02 January 2013 15:01 By: Jonathan Lawrence ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
application throws NoClassDefFoundError for some classes of org.eclipse.mat.api jar |
7803 |
Wed, 19 December 2012 12:32 By: rits Mising name ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
uptime |
7617 |
Wed, 12 December 2012 08:26 By: Bernt Formella ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
OQL for thread locals (matching locals to threads) |
11116 |
Fri, 30 November 2012 15:16 By: Andy Carlson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Skip subtasks when generating MAT reports |
6634 |
Fri, 16 November 2012 10:08 By: Hsin-Yin Chou ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
dump correctly generated? |
5762 |
Fri, 16 November 2012 08:47 By: Bernt Formella ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
OQL enhancements |
5262 |
Thu, 15 November 2012 17:55 By: Andrew Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
OQL query problem |
13594 |
Fri, 09 November 2012 15:59 By: Andrew Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Memory Analyzer 1.2.1 is released |
5127 |
Thu, 08 November 2012 12:39 By: Krum Tsvetkov ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Does Heap dump includes Thread dump? MAT heap dump and thread dumps |
22184 |
Fri, 28 September 2012 09:39 By: Andrew Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Any way of connecting a MAT standalone client to a remote MAT headless instance |
8317 |
Mon, 24 September 2012 07:04 By: Krum Tsvetkov ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Error displaying Histogram By: John C on Sat, 08 September 2012 |
6345 |
Sat, 08 September 2012 13:32 By: John C ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to open previous results of analyze? |
10993 |
Wed, 05 September 2012 20:02 By: Krashan Brahmanjara ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Unable to Open Heap Dump |
4722 |
Wed, 05 September 2012 16:15 By: Mustafa Cayci ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Full memory usage By: Tom on Thu, 01 September 2011 |
9899 |
Mon, 03 September 2012 12:56 By: Henning Tegner ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to analyze the leak occur for the problem of android dalikvm GREF |
5729 |
Mon, 03 September 2012 08:39 By: chongxi shen ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
histogram objects vs dominator tree entries what's the difference between histogram objects and dominator tree entries |
5048 |
Thu, 30 August 2012 19:00 By: Tim Thwing ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Is heap dump file platform dependant? |
3745 |
Tue, 28 August 2012 16:03 By: Tim Thwing ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Can I see the contents of the generations? |
4860 |
Wed, 15 August 2012 05:41 By: Krum Tsvetkov ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Cannot get extension report to be found. |
11034 |
Wed, 01 August 2012 06:45 By: Krum Tsvetkov ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Leak suspect report Leak suspects referenced from one instance of "java.util.WeakHashMap$Entry[]" |
9657 |
Wed, 01 August 2012 06:37 By: Krum Tsvetkov ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Object references How to find out who is holding reference(s) to a given object |
12901 |
Wed, 01 August 2012 06:30 By: Krum Tsvetkov ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Parsing Heap Dump Error in MAT |
16896 |
Wed, 25 July 2012 12:31 By: Jonathan Lawrence ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Help! com.ibm.j9ddr.InvalidDataTypeException: U_32 contains value larger than Integer.MAX_VALUE |
6986 |
Wed, 11 July 2012 17:14 By: Pete Robbins ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Memory Analyzer 1.2.0 is released |
6210 |
Thu, 28 June 2012 08:42 By: Krum Tsvetkov ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
No way to run the MAT Whatever I do it fails because of memory |
6693 |
Tue, 12 June 2012 09:18 By: Jon Locke ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Some Paths to GC root not found? Some Paths to GC root not found? |
7152 |
Thu, 31 May 2012 03:33 By: Xavier Appe ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
java.lang.NoClassDefFoundError: org/eclipse/mat/ui/snapshot/editor/ISnapshotEditorInput Trying to create a MAT Plugin to display Android Bitmaps as Images |
9295 |
Tue, 29 May 2012 05:32 By: Andrew Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
My plugin is not loaded |
9711 |
Sun, 27 May 2012 00:40 By: Fred Granger ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Parse large Heapdump OOM: Java heap space |
10393 |
Thu, 24 May 2012 14:03 By: Andrew Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Steps to write a plugin of ParseSnapshotApp and deploy to MAT MCP |
6089 |
Tue, 15 May 2012 20:30 By: Erik Brangs ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
can't aquire or open dump with MAT 1.1 on IBM SDK J9 can't aquire or open dump with MAT 1.1 on IBM SDK J9 |
10858 |
Sun, 22 April 2012 20:05 By: Andrew Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
MAT on Linux Running MAT on Linux By: Gopi V on Mon, 06 February 2012 |
19361 |
Thu, 05 April 2012 17:21 By: Simon Kelly ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
OQL Find all objects which belong to a HttpSession |
8050 |
Wed, 07 March 2012 15:14 By: Krum Tsvetkov ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
J2RE 1.3.1 IBM AIX build ca131-20030618 DUMP How to parse IBM 1.3.1 for MAT |
7484 |
Thu, 01 March 2012 16:10 By: michel adam ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Identify list of jar files loaded by a classloader list of jar files loaded by a classloader and the jar file name of a class in MAT |
8040 |
Wed, 15 February 2012 16:46 By: Aurélien Pupier ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Import Index Files? |
14574 |
Sat, 11 February 2012 07:35 By: Krum Tsvetkov ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
