Forums will be read only after December 31st,2024 After 10 years of discussion and planning[1], these forums have been declared end of life, and will be replaced with a static read only copy on December 31, 2024.
INonRetargetable Class Not Found java.lang.NoClassDefFoundError: org/eclipse/gmf/runtime/common/ui/action/INonRetargetable |
1206 |
Tue, 22 October 2024 11:23 By: Ilma Rohma |
GMF Tooling Issue GMF Tooling update site link not accessible |
2101 |
Mon, 09 September 2024 15:13 By: Andrei La |
Help finishing the tutorial |
1892 |
Wed, 06 September 2023 10:16 By: Leonard Theisler |
GMF Tooling Update GMF Tooling Update with latest Apache Batik* Plugins |
5779 |
Fri, 28 July 2023 06:10 By: pavan kumar |
org.w3c.dom.events dependency issue with eclipse 2023-06( problem with gmf tooling running i eclipse 2023-6 java11 |
1577 |
Wed, 26 July 2023 13:53 By: pavan kumar |
org.w3c.dom.events dependency issue with eclipse 2023-06 problem with gmf tooling running i eclipse 2023-6 java11 |
1601 |
Wed, 26 July 2023 13:50 By: pavan kumar |
Unresolved Requirements |
1756 |
Mon, 26 June 2023 07:36 By: Kabiru Usman |
Parent-child layout problem By: Merlin on Thu, 06 September 2007 |
2949 |
Sat, 27 May 2023 23:30 By: Eclipse User |
bad certificate on eclipse repro server |
2776 |
Thu, 07 July 2022 05:48 By: Ed Merks |
Respond to item click in popup menu |
5278 |
Tue, 12 April 2022 06:11 By: Trupti Naik |
Creating a custom auto-layout |
2305 |
Mon, 29 November 2021 23:53 By: Jonathan Li |
GMF plan support to more recent eclipse releases |
2960 |
Tue, 13 July 2021 15:34 By: Pierre-Charles David |
Real time synchronization between GMF and Xtext |
2286 |
Thu, 25 February 2021 14:02 By: John Henbergs |
Xtext integration with GMF |
1975 |
Tue, 23 February 2021 20:37 By: John Henbergs |
generate code in python or javascript/typescript By: Ax Ch on Mon, 08 February 2021 |
15011 |
Mon, 08 February 2021 10:00 By: Ax Ch |
Java 11 Deprecated functions on GMF Gen GMF Gen code still use deprecated code |
5616 |
Wed, 27 January 2021 22:33 By: Che Bumagat |
Generate diagram code errors Generate diagram code errors |
4633 |
Sat, 23 January 2021 21:52 By: Shuting Chen |
SVG Error problem with SVG |
4598 |
Thu, 21 January 2021 09:29 By: Mariem Makni |
GMF Export to PNG Truncating text |
3774 |
Wed, 25 November 2020 12:21 By: Romain Bioteau |
gmfgraph with nodes empty Im trying to generate a gmfgraph but the nodes are empty |
2042 |
Sun, 08 November 2020 18:36 By: Xiaoyun Ma |
Cross-cutting in EuGENia-generated GMF Editor / diagram tab caption |
4182 |
Tue, 18 August 2020 21:37 By: Clever Alves |
Getting view for editpartProviders context |
4555 |
Wed, 25 March 2020 15:03 By: Claudia Irvine |
New upcoming version of GMF Notation & Runtime with metamodel changes |
4014 |
Mon, 23 March 2020 15:34 By: Pierre-Charles David |
Forum on Privacy and Data Protection Challenges in System Development |
3421 |
Thu, 27 February 2020 22:46 By: Philippe Krief |
Print diagram in custom size |
3774 |
Wed, 26 February 2020 16:39 By: Bernhard Edler |
GMF compatible to Eclipse e4 |
7609 |
Wed, 04 December 2019 10:06 By: Felix Bruckner |
Opening properties view on clicking on any figure in canvas Opening properties view on clicking on any figure in canvas |
3125 |
Wed, 30 October 2019 09:47 By: Vaibhav Vaibhav |
Connector Labels (Polyline Connection) PolylineConnection , Connector Label |
38956 |
Mon, 21 October 2019 10:15 By: Naveen R |
DocumentProvider::createElementInfo does not handle IFileEditorInput |
19880 |
Tue, 01 October 2019 09:05 By: Sonja Riethig |
how to "dynamically" load different images for nodes ? |
128190 |
Fri, 30 August 2019 18:09 By: Mohamed Ali Kallali |
GMF palatte drag and drop is not working in MAC OS with sudo permissions GMF palatte drag and drop is not working in MAC OS with sudo permissions |
20529 |
Sun, 25 August 2019 06:01 By: Veerababu Maragani |
Reposition of connections |
3556 |
Mon, 22 July 2019 10:49 By: Cristina Redriguez |
GMF Diagram : Workbench tool bar Font DropDown Disabled GMF Diagram : Workbench tool bar Font DropDown Disabled |
62488 |
Thu, 13 June 2019 11:59 By: Veerababu Maragani |
Palette tool is not visible if I change settings |
39789 |
Fri, 07 June 2019 04:35 By: Prajna VG |
Icon of Wrapping Label |
4305 |
Wed, 05 June 2019 10:59 By: Sonja Riethig |
34379 |
Tue, 04 June 2019 12:50 By: Veerababu Maragani |
Disable or Hide the Menubar items Disable or Hide the Menubar items |
36473 |
Tue, 04 June 2019 01:37 By: Jakkam Viswa |
Property Section |
57789 |
Wed, 29 May 2019 07:12 By: Sonja Riethig |
GraphicalViewer |
31900 |
Tue, 21 May 2019 07:17 By: Oliver Holdt |
Draw on GMF Canvas without updating the notation model |
17965 |
Tue, 07 May 2019 09:17 By: Felix Dorner |
Multiline Link |
2617 |
Fri, 01 March 2019 17:46 By: Emmanuel Silva |
GMF file By: Ale Tri on Sun, 10 February 2019 |
8859 |
Sun, 10 February 2019 17:47 By: Ale Tri |
Plugin not working on latest Eclipse versions Plugin which was built using Eclipse-rcp Neon is not working on Eclipse Photon |
3900 |
Sun, 13 January 2019 20:29 By: Ammad Ahmed |
Showing Only One Link for Bidirectional Connection |
2955 |
Fri, 11 January 2019 17:01 By: Eric Rapos |
GMF Transformation *.gmfmap to *.gmfgen fails Exception during final model transformation |
16562 |
Mon, 12 November 2018 09:11 By: Ed Willink |
Customizing GMF Diagram + Palette Correct way to construct another diagram By: PM PC on Sun, 07 October 2018 |
3860 |
Sun, 07 October 2018 11:44 By: PM PC |
GMF Editor How to access programmatically a GMF Diagram by reading its XML/XMI? By: PM PC on Thu, 31 May 2018 |
4037 |
Sat, 06 October 2018 10:56 By: PM PC |
GMF2 File Format GMF portability |
3340 |
Sat, 01 September 2018 15:34 By: Andrew L |
Programmatically create and open a GMF diagram |
11147 |
Mon, 06 August 2018 16:48 By: Maude Sabourin |
Limiting/changing the anchor points for the connections |
3455 |
Thu, 14 June 2018 21:40 By: Parsa Pourali |
Eugenia Eugenia Customization By: PM PC on Fri, 08 June 2018 |
2163 |
Sat, 09 June 2018 07:23 By: Dimitris Kolovos |
how to create view with existed element? By: Eclipse User on Tue, 01 August 2006 |
26056 |
Wed, 30 May 2018 16:40 By: Eclipse User |
Attach Other Figures/EditParts to a Connection |
3679 |
Fri, 25 May 2018 11:51 By: Parsa Pourali |
GMF tooling -- Problems with generating the gmfgen model |
5652 |
Wed, 11 April 2018 06:12 By: Pierre-Charles David |
Split Editor Split the eclipse editor programmatically |
3872 |
Mon, 09 April 2018 11:06 By: Saud Tahir |
Error Message:java.lang.NullPointerException at org.eclipse.oomph.setup.ui.SetupUIPlugin.performSta when i try to run the GMFProject it goes wrong with the following errors |
6289 |
Sun, 08 April 2018 08:09 By: wang shiyu |
Rotation of EditParts possible? |
8010 |
Fri, 16 March 2018 10:26 By: Felix Dorner |
DiagramLinkStyle example |
3383 |
Tue, 13 March 2018 09:40 By: Felix Dorner |
two links being shown when diagrams are connected By: govind on Wed, 14 November 2007 |
6607 |
Mon, 12 March 2018 02:38 By: wang shiyu |
Error message: Node is referenced from multiple containers with different 'List Layout' value |
4102 |
Sun, 11 March 2018 06:25 By: wang shiyu |
Label positioning By: Ran Wei on Fri, 02 February 2018 |
5291 |
Fri, 02 February 2018 12:03 By: Ran Wei |
Multiple Diagrams for a single file By: Ran Wei on Sun, 28 January 2018 |
5846 |
Sun, 28 January 2018 12:56 By: Ran Wei |
Not able to modify model By: Ran Wei on Tue, 23 January 2018 |
3944 |
Thu, 25 January 2018 15:53 By: Ran Wei |
RenderedMapModeGraphics has not implemented graphics rotate function |
6691 |
Wed, 17 January 2018 03:00 By: lee lucky |
How to Apply a Search Filter in GMF tool palette How to Apply a Search Filter in GMF tool palette |
6116 |
Tue, 19 December 2017 01:44 By: tong ming |
Multiple diagram diagramB is associated with diagramA |
7107 |
Tue, 12 December 2017 08:28 By: tong ming |
GMF RCP palette customization - seperator and custom icons how to edit palette and add custom design |
15953 |
Tue, 12 September 2017 08:40 By: Hassan Ali |
Drag and Drop one ShapeCompartmentEditPart into another ShapeCompartmentEditPart inner children node of ShapeCompartmentEditPart get rearranged when we drag and drop one ShapeCompartmentEditPart into another ShapeCompartmentEditPart |
15802 |
Thu, 07 September 2017 05:56 By: karthik krishnamoorthy |
How to resize a label in a figure? By: Eclipse User on Tue, 18 March 2008 |
10552 |
Wed, 26 July 2017 10:16 By: kerbiche oussama |
South Position of Child in GEF |
6896 |
Sun, 23 July 2017 09:28 By: asma Sendesni |
GMF tooling disappeared from Oxygen |
10673 |
Tue, 18 July 2017 13:18 By: Pierre-Charles David |
[SOLVED] Connections make nodes disappear |
16732 |
Mon, 22 May 2017 14:05 By: Marco Latona |
GMF, Graphiti or just GEF for a "Form Designer" tool ? |
10081 |
Thu, 18 May 2017 12:36 By: Aurélien Pupier |
Graphical Definition Wizard shows no Checkboxes in Attribute column Attributes for the graphical definition cannot be selected |
30927 |
Mon, 08 May 2017 16:39 By: Andreas Hestermeyer |
Error 'the import org.eclipse cannot be resolved' Eclipse won't compile the program and is giving me the error "The import org.eclipse cannot be resolved" |
18493 |
Sun, 30 April 2017 16:21 By: kerbiche oussama |
Plugin .tests Plugin .tests |
22402 |
Tue, 25 April 2017 08:05 By: sarah sh |
GMF diagram breaking after being copied (in editor) |
20614 |
Sat, 22 April 2017 14:53 By: Kanwal Gill |
Different views of the same model different diagrams, same model |
40844 |
Tue, 14 March 2017 00:46 By: Lina 20 |
Create Node without EClass? Question about how to define a pure graphical node |
39795 |
Mon, 13 March 2017 15:07 By: Christian Bodenbender |
create node using outgoing connection handle Unable to create nodes using outgoing connection handles By: V Set on Tue, 05 January 2016 |
8834 |
Fri, 10 March 2017 07:02 By: Rohit Sonawat |
Link style doesnt work My changes in link annotation style does not work |
12422 |
Thu, 02 March 2017 13:27 By: Lainis 20 |
Solution for exceeding the 65535 bytes limit error |
10138 |
Mon, 20 February 2017 07:40 By: Aurélien Pupier |
How to manipulate the contents of a GMF diagram programmatically? |
25450 |
Thu, 09 February 2017 15:08 By: Kanwal Gill |
Disable Palette Element |
3787 |
Thu, 09 February 2017 14:55 By: Umut Kazan |
selecting one Node (along with inside edges) from CSSDiagramImpl file and saving it in a new file get a node with all edges and save in a separate file with .henshin_diagram extension |
25338 |
Thu, 09 February 2017 13:44 By: Kanwal Gill |
Update programmatically figure with EditPart |
5310 |
Sat, 04 February 2017 21:46 By: Yin Ya |
Problem in generating Code |
18770 |
Thu, 02 February 2017 07:04 By: Marco Bonilla |
Have questions about GMF. |
11783 |
Wed, 01 February 2017 10:18 By: Yang Seokwoo |
GMF Multiple Editor with RCP error pls help me to solve this issue By: Yin Ya on Wed, 11 January 2017 |
22827 |
Wed, 11 January 2017 14:58 By: Yin Ya |
TESSSS JSP |
5383 |
Fri, 09 December 2016 20:02 By: rupaboppana rupaboppana |
Show layers from a CDO reprensentation file |
6155 |
Tue, 06 December 2016 14:35 By: Henry Marchand |
Modelling Childs on Border of Parent |
35172 |
Thu, 10 November 2016 10:38 By: korbinian werner |
Sequence Diagram Editor in GMF Sequence Diagram Editor in GMF |
8832 |
Wed, 09 November 2016 21:17 By: Klementina Josifovska |
i can't generate mapping model from domain model??? please teach me. |
5269 |
Mon, 07 November 2016 11:10 By: Ángel Moreno |
'diagramLabel' of 'Feature Label Mapping false' |
8399 |
Sat, 05 November 2016 16:41 By: Ira Syahirah |
Getting matcher from elementType instance? |
6798 |
Sat, 22 October 2016 11:05 By: Patrik Nandorf |
Sequence diagram with GMF? |
15843 |
Wed, 19 October 2016 12:45 By: Pierre-Charles David |
Simple constraint using OCL Need help |
5089 |
Thu, 13 October 2016 15:03 By: Ralph Gerbig |
Generate Code Back From Diagram |
7660 |
Thu, 15 September 2016 13:41 By: Niklas Klipphahn |
3052 |
Wed, 31 August 2016 18:44 By: Eclipse Webmaster |
Add GMF editor to a multipage editor |
5321 |
Mon, 22 August 2016 14:16 By: Konstantinos Angelopoulos |
How to implemente Drag'n Drop fonctionnality in GMF |
6328 |
Sun, 14 August 2016 20:43 By: Alex Van Brostek |
Drag'n Drop under GMF |
4270 |
Sat, 06 August 2016 16:01 By: Taher Mohamed Yhd |
Label Mapping |
2743 |
Fri, 05 August 2016 16:42 By: Wendy Wendy |
How can i represent the GMF shortcuts as part of the domain model? |
4244 |
Wed, 03 August 2016 18:35 By: Taher Mohamed Yhd |
How to Add a Shortcut to the Domain Model |
13615 |
Wed, 03 August 2016 16:20 By: Taher Mohamed Yhd |
DropDown Menu GMF adding dropdown menu to a link |
4301 |
Wed, 03 August 2016 12:27 By: Wendy Wendy |
error while generator model "java.lang.NullpointerException" |
4364 |
Tue, 26 July 2016 14:40 By: meriem mhmi |
GMF Eclipse 4 Batik dependency Problem Problem, managing dependencies to mulitiple versions of the same Plug-In |
4364 |
Fri, 08 July 2016 11:43 By: Stephan Rehfeld |
Add Element to parent, when an Element is added to child |
4798 |
Thu, 07 July 2016 14:12 By: Niklas Klipphahn |
How to get all Editparts from a Sirius Diagram |
4169 |
Mon, 04 July 2016 07:35 By: Pierre-Charles David |
LayoutManager add unwanted Border Lines between nested Rectangles |
5168 |
Fri, 01 July 2016 12:41 By: Niklas Klipphahn |
How to Generate notation model for a domain model |
5552 |
Wed, 15 June 2016 14:37 By: Habtamu Tolera |
OCL audit rule message not displayed OCL rule in GMF doesn't show a message when breaking this rule, although the OCL code is executed. |
6121 |
Tue, 07 June 2016 08:47 By: Alexandre Honorat |
GMF editor - Mouse cursor is opaque - How to make it transparent |
7434 |
Fri, 03 June 2016 08:35 By: Awanthika Senarath |
Rotate Figure in GMF Rotation GMF |
7233 |
Wed, 11 May 2016 08:28 By: xiongtao xia |
Multiple Plugins, same Domain Model, DND |
9218 |
Tue, 10 May 2016 13:50 By: Taher Mohamed Yhd |
How to Add a Shortcut to the Domain Model By: Elle on Mon, 11 April 2011 |
10410 |
Thu, 05 May 2016 10:38 By: Taher Mohamed Yhd |
GMF editor not saving changes |
10216 |
Sun, 01 May 2016 21:24 By: Taher Mohamed Yhd |
Compartment size and saving problem |
4862 |
Sun, 01 May 2016 17:55 By: Taher Mohamed Yhd |
Zoom Toolbar not working on Ubuntu 14.04LTE |
6298 |
Thu, 28 April 2016 18:53 By: Tom Brus |
Add key listener on an element of diagram |
7329 |
Thu, 17 March 2016 05:02 By: Tuan Hoang Anh |
Scalable Polygon Line Style changing Scalable Polygon Line Style changing |
5977 |
Mon, 07 March 2016 13:49 By: Klementina Josifovska |
Adding menu to the palette |
7706 |
Wed, 02 March 2016 07:53 By: Nguyen Xuan Nhan |
Links does not get deleted from the model |
7925 |
Wed, 02 March 2016 05:45 By: Susinda Perera |
Change picture of node based on their type |
6303 |
Sun, 28 February 2016 18:42 By: jakub rehak |
Adding instances in runtime from another diagram editor |
7969 |
Thu, 18 February 2016 11:34 By: Ángel Moreno |
GMF Runtime Tutorial Is there a comprehensive tuorial/documentation on GMF Runtime? |
4363 |
Mon, 15 February 2016 16:36 By: Barr Taiwo |
How to remove corners of the EditPartFigure (which appears when selected) |
4993 |
Fri, 12 February 2016 06:47 By: Susinda Perera |
Extending an editor |
6676 |
Thu, 11 February 2016 09:21 By: Davide Profeta |
How to display the referenced element of a connection as a label in GMF |
7319 |
Wed, 10 February 2016 20:07 By: AHOT Mising name |
removing GMF toolbar |
6667 |
Wed, 10 February 2016 12:55 By: Mana Taghdiri |
Grid problem on Linux |
20140 |
Mon, 08 February 2016 17:27 By: Thomas Muller |
How to import physical model structure from EMX files Problem with interpretation of XML representation of diagram layout |
13140 |
Thu, 14 January 2016 11:23 By: Fran Jimenez |
How to make CDO changes update GMF diagrams? The default GMF editor does not seem to recognize CDO changes |
6231 |
Mon, 11 January 2016 21:40 By: Paul C. Brown |
Sharing the same domain between different diagrams |
6409 |
Thu, 07 January 2016 21:41 By: Paul C. Brown |
Did anyone met crash issue with SVG? How to solve? |
6562 |
Wed, 06 January 2016 09:50 By: leen shi |
Problem with interpretation of XML representation of diagram layout how to use the attributes (bendpoints/points, targetAnchor/id, targetAnchor/id) to redraw the connections By: nana eb on Mon, 16 November 2015 |
4527 |
Mon, 04 January 2016 11:59 By: nana eb |
GMF integrating with MultiPageEditorPart? |
2803 |
Thu, 31 December 2015 04:55 By: Rafhael Cunha |
reference ecore model path of a different ecore model |
7128 |
Tue, 22 December 2015 03:00 By: Rafhael Cunha |
Inheritance among nodes in different diagrams |
2520 |
Mon, 21 December 2015 03:15 By: Rafhael Cunha |
2823 |
Mon, 21 December 2015 03:11 By: Rafhael Cunha |
7058 |
Mon, 21 December 2015 01:09 By: Rafhael Cunha |
7049 |
Mon, 21 December 2015 00:50 By: Rafhael Cunha |
generate various diagrams on the same project |
5733 |
Sun, 20 December 2015 02:53 By: Rafhael Cunha |
Adding Menus when running an activity diagram Adding Menus when running an activity diagram |
6185 |
Sun, 13 December 2015 22:17 By: Nikos Margaritis |
"Generate Diagram Code" - Programmatically |
2715 |
Sun, 13 December 2015 11:51 By: Florian Goenner |
missing GMF dashboard |
6058 |
Thu, 03 December 2015 22:33 By: Williams Mising name |
add complex text to a connection add complex text to a connection |
4225 |
Fri, 27 November 2015 07:07 By: Aaron Chang |
GMF Palette Stack Tool Group I made a new Tool Group, but an error occurred when I generated the *.gmfgen model |
3250 |
Thu, 19 November 2015 10:45 By: Xiao Zhang |
GMF Palette Stack Tool Group |
8985 |
Thu, 19 November 2015 09:17 By: Xiao Zhang |
Old GMF application confilicting with Papyrus GMF Papyrus |
4779 |
Tue, 17 November 2015 18:14 By: Paul C. Brown |
Move connected elements together to hold initial position of creation When a node is moved, I would like its connected element to move along with it. By: V Set on Thu, 12 November 2015 |
4454 |
Mon, 16 November 2015 16:50 By: V Set |
Create node's children programmatically on drag&drop |
10788 |
Thu, 12 November 2015 17:42 By: Gin Sul |
Right way to specify Fonts? |
10344 |
Sun, 01 November 2015 17:22 By: Sebastiaan Blommers |
Problem with the deletion of a child view - Delete-EditPolicy is not called |
7959 |
Mon, 19 October 2015 14:00 By: Murat C. |
connection line plus rectangle |
5344 |
Mon, 12 October 2015 14:29 By: wassim chtourou |
Create UMLDiagramEditor without opening it (like in OffscreenEditPartFactory) |
6028 |
Mon, 05 October 2015 12:25 By: Raimund Konnerth |
Errors on creation diagram editor (Eclipse Luna 4.4.1) Some classes wasn't generated By: Rom A on Tue, 16 December 2014 |
4990 |
Mon, 21 September 2015 03:06 By: Yi Wang |
Failed to create part's control - Eclipse GMF While switching from one perspective to another , I am getting an error message "Failed to create part's control" |
5871 |
Fri, 04 September 2015 11:55 By: Sibendu Dey |
Having customized forms or Adding Menus/Toolbars/Context Menus and etc. when running GMF as a plugin |
6806 |
Fri, 07 August 2015 15:52 By: Parsa Pourali |
Split Generated Method |
5455 |
Tue, 04 August 2015 10:21 By: Aurélien Pupier |
Application error java.lang.RuntimeException: Application "org.eclipse.ui.ide.workbench" c By: 55 66 on Wed, 13 May 2015 |
6485 |
Tue, 04 August 2015 10:19 By: Aurélien Pupier |
Creating Diagram and model file programmatically Creating Diagram and model file programmatically |
7758 |
Tue, 04 August 2015 10:16 By: Aurélien Pupier |
How Can I add a new tab in property section of GMF editor with table or grid layout |
3714 |
Tue, 04 August 2015 10:13 By: Aurélien Pupier |
Switching Diagram Label Icon during runtime on/off By: Phil H on Wed, 03 April 2013 |
9450 |
Mon, 03 August 2015 17:24 By: Paul C. Brown |
How can i customize a dialog box in GMF Customize dialog box in GMF |
3941 |
Mon, 03 August 2015 15:04 By: Aurélien Pupier |
node generated as link By: 55 66 on Thu, 04 June 2015 |
5162 |
Thu, 30 July 2015 12:39 By: Anton Antonenko |
Dynamic Node Color Change Changing the color of a node based on an attribute |
4662 |
Wed, 29 July 2015 20:52 By: Anton Antonenko |
Executable GMF diagrams Executable GMF diagrams |
3945 |
Wed, 29 July 2015 09:09 By: Ángel Moreno |
No palette icons after installing plugin into host |
4105 |
Wed, 22 July 2015 10:33 By: Ángel Moreno |
Drag and Drop from view to GEF editor Drag and drop not happening at location where we click on mouse pointer after some point |
5454 |
Sun, 19 July 2015 12:35 By: Rahul Ghatak |
Mapping uml model to XML file |
4032 |
Sat, 13 June 2015 10:58 By: Nikos Margaritis |
Rename A diagram file and then some Rename a file, first element and all its shortcuts By: V Set on Tue, 21 April 2015 |
6470 |
Fri, 12 June 2015 19:13 By: V Set |
OCL and GMF graphic instance It is possible to make a OCL expression on my model generated by GMF editor? |
4160 |
Mon, 18 May 2015 17:15 By: Marcos Furriel |
Export EMF Model to custom XML file Export Model to custom XML file |
4082 |
Tue, 12 May 2015 07:30 By: Daniel Kim |
GMF Help |
4948 |
Wed, 06 May 2015 12:52 By: Luca Salemio |
DiagramParserProvider Accepts only EAttribute Features DiagramParserProvider Accepts only EAttribute Features because MessageFormatParser Constructor accepts only EAttribute Features |
4341 |
Wed, 06 May 2015 11:53 By: Basheer Jasser |
How can I create the connection line like in the figure |
3352 |
Fri, 24 April 2015 16:37 By: Nikos Margaritis |
How to Set Default Grid line style, line color, and "on top" |
13233 |
Sat, 18 April 2015 22:48 By: Nikos Margaritis |
org.eclipse.core.runtime.AssertionFailedException: |
13906 |
Sat, 18 April 2015 21:04 By: Nikos Margaritis |
How to create an EReference programmatically? |
4596 |
Sat, 18 April 2015 21:00 By: Nikos Margaritis |
GMF multidiagram editor - avoid data lost GMF multidiagram editor - avoid data lost |
6008 |
Sat, 18 April 2015 15:08 By: Gregorio Barberio |
Graphical Modeling Framework/Tips Graphical Modeling Framework/Tips |
4594 |
Fri, 17 April 2015 14:48 By: Marcelo Salas |
Conflicting handlers with combined EMF/GMF Editor By: Phil H on Wed, 11 September 2013 |
7746 |
Fri, 17 April 2015 11:23 By: Nikos Margaritis |
GMF with vaadin |
6495 |
Wed, 15 April 2015 22:59 By: Nikos Margaritis |
GMF Diagram Editor & Runnable JAR |
4273 |
Tue, 14 April 2015 21:11 By: Nikos Margaritis |
customize gmf editor |
4993 |
Tue, 14 April 2015 21:06 By: sayeb khaoula |
Generating PDFs from forms |
4889 |
Sun, 12 April 2015 09:09 By: Philippe de Rochambeau |
Place connection anchors on a circle, but such that connections are on a line with the node's center |
78750 |
Wed, 08 April 2015 09:13 By: Sebastiaan Blommers |
GMF Code Generation customization Is there any way to customize code generation or reuse already customized GMF code with newer version of eclipse/GMF? |
4093 |
Mon, 30 March 2015 11:25 By: Aurélien Pupier |
gmf : Problems encountered durning Validation problem with a class consisting of other calse |
3930 |
Sat, 28 March 2015 20:03 By: Leonardo Bravo |
Truncate External Label |
4588 |
Wed, 25 March 2015 15:25 By: Jimmy Lu |
Diagram editor support for model extensions Adding editor tools for contributed metamodel extension |
6050 |
Fri, 20 March 2015 17:39 By: Mathias K |
(XXXXX)DiagramEditPartFactory not invoked DiagramEditPartFactory class is not runnable or invokable |
4058 |
Mon, 16 March 2015 12:42 By: Basheer Jasser |
Figure view different from Figure Gallery (during run-time) Ellipse Figure in Gmfgraph but different rectangle Figure view during run-time |
3576 |
Fri, 13 March 2015 13:57 By: Basheer Jasser |
Generate a palette Generate a palette from a profile |
3614 |
Fri, 13 March 2015 11:50 By: Emna Dammak |
Adding GMF editor to multipage editor |
3123 |
Mon, 09 March 2015 19:18 By: Nikos Margaritis |
How to recreate transient model and view objects? By: Swavek on Wed, 07 April 2010 |
10371 |
Thu, 05 March 2015 22:10 By: Jimmy Lu |
Adding a node between connections By: Eclipse User on Mon, 04 December 2006 |
3797 |
Wed, 04 March 2015 16:07 By: dorra daddou |
