Forums will be read only after December 31st,2024
After 10 years of discussion and planning[1], these forums have been declared end of life, and will be replaced with a static read only copy on December 31, 2024. [1]https://gitlab.eclipse.org/eclipsefdn/helpdesk/-/issues/187
  Building Virgo 3.6.4 ( 1 2)
By: qiang wang on Wed, 13 March 2024
326 39739 Tue, 31 December 2024 08:52
  Building Virgo 3.7.x
By: Alain Picard on Tue, 20 February 2018
7 14258 Thu, 14 March 2024 02:13
By: qiang wang
  AspectJ logs not printing issue with Open JDK 17
Issues encountered in AspectJ logs not printing due to Open JDK 17 upgrade
By: De Silva on Wed, 05 July 2023
1 8133 Thu, 06 July 2023 07:33
By: GianMaria Romanato
  XML parser implementation
By: Eva Troels on Fri, 14 January 2011
15 44710 Sun, 19 June 2022 14:14
By: KEERTHI BILWARAJ
  Virgo Future
By: Felix Schöpf on Mon, 01 April 2019
10 13647 Fri, 06 May 2022 10:36
By: Martin Zukal
  Build issue of master branch
By: rob li on Thu, 14 April 2022
0 2683 Thu, 14 April 2022 08:29
By: rob li
  Source code for Virgo
By: Craig Newman on Wed, 14 July 2021
2 2434 Mon, 19 July 2021 16:01
By: Craig Newman
  Tomcat Realm Security Almost Works but...
By: Brian Williamson on Sun, 31 January 2021
3 3177 Tue, 09 February 2021 13:14
  Virgo support for java 9
By: Nadeesh T V on Wed, 03 January 2018
6 10262 Thu, 14 November 2019 06:41
By: Florian Waibel
  Eclipse gradle import duplicate project names
By: Felix Schöpf on Sat, 31 August 2019
0 131656 Sat, 31 August 2019 20:46
By: Felix Schöpf
  FIXED: Unable to get REST sample to work
Errors regarding bundle not being available
By: Bill Mair on Sun, 28 May 2017
4 17253 Wed, 19 June 2019 10:33
By: nilesh pitale
  Multiple spring deployments on Virgo 3.7.2
By: Jesus Martinez on Wed, 25 July 2018
8 7146 Wed, 19 June 2019 10:31
By: nilesh pitale
  An issue with upgrading taglibs-standard to 1.2.5 in virgo-tomcat-server-3.6.4.RELEASE.zip
The absolute uri: http://java.sun.com/jsp/jstl/core cannot be resolved in either web.xml or the jar files deployed with this application
By: Stanislav Hristoskov on Mon, 22 April 2019
0 40111 Mon, 22 April 2019 20:17
  upgrade version of spring framework used in virgo
By: Martin Zukal on Sat, 02 February 2019
1 3420 Fri, 15 March 2019 15:08
By: Joel Traber
  Which Version Eclipse IDE for JSF2.2
By: TheNeandertaler Mising name on Thu, 14 February 2019
0 5795 Thu, 14 February 2019 14:03
  Virgo Management Console Password Encryption
By: Joel Traber on Mon, 28 January 2019
2 2711 Mon, 28 January 2019 15:22
  Problem deploying web bundle with latest Eclipse and Virgo 3.7.2
By: Matteo Cantarelli on Wed, 12 December 2018
5 3980 Wed, 12 December 2018 13:15
  Problem in loading Virgo bundles for vSphere v6.5
After upgrade of dev. env. from v5.5 to v6.5 bundles fail to load
By: David Oz on Wed, 27 June 2018
1 2124 Mon, 02 July 2018 21:00
By: Florian Waibel
  Error when launching Virgo using DCEVM patched JDK
By: Rafa E on Fri, 11 May 2018
2 7144 Tue, 12 June 2018 09:35
By: Rafa E
  Virgo & OSGi in the new "docker" and "micro services" world?
By: Bill Mair on Fri, 08 June 2018
2 3838 Mon, 11 June 2018 21:06
By: Bill Mair
  Resolver reported uses conflict for import constrained to bundle
By: li zhang on Wed, 07 March 2018
0 4903 Wed, 07 March 2018 10:05
By: li zhang
  Virgo and Spring Boot
Is there a possibility to run Spring Boot application on Virgo Tomcat server?
By: Vakhtang Laluashvili on Thu, 15 February 2018
1 3695 Wed, 21 February 2018 08:23
By: Florian Waibel
  Is Java 9 support sun.misc.ServiceConfigurationError?
By: Amit Mestha on Tue, 06 February 2018
0 4255 Tue, 06 February 2018 06:50
By: Amit Mestha
  Error while upgrading to Java 1.8 : Expecting a stackmap frame
By: Mathilde Ffrench on Mon, 18 December 2017
3 7143 Wed, 27 December 2017 15:22
By: Florian Waibel
  Provider org.apache.tomcat.websocket.server.DefaultServerEndpointConfigurator not found
ServiceLoader for jar in repository/ext not working for virgo-tomcat-server-3.7.1.RELEASE
By: Lukas Höllein on Wed, 13 December 2017
7 7939 Wed, 20 December 2017 23:52
By: Violeta Georgieva
  How to include a managed service factory configuration artifact in a plan?
By: Matt Magoffin on Wed, 01 November 2017
3 3897 Thu, 02 November 2017 10:14
By: daniel marthaler
  SLF4J distribution changed in 3.7.x
JCL and LOG4J binder instead of extender
By: Nikolas Falco on Thu, 07 September 2017
4 5438 Thu, 26 October 2017 08:33
  Virgo tooling and Oxygen
Tooling doesn't work after installation
By: Bill Mair on Sat, 29 July 2017
10 17906 Tue, 05 September 2017 21:26
By: Bill Mair
  Removal of "old" Virgo versions from Virgo Download page
Cleanup the Virgo Downloads page
By: daniel marthaler on Wed, 19 July 2017
2 14687 Sun, 30 July 2017 10:17
By: Bill Mair
  Virgo 3.7.2.RELEASE is available
By: daniel marthaler on Thu, 27 July 2017
0 12091 Thu, 27 July 2017 13:30
  Can't make per application log file work
By: dustContributor dustContributor on Sun, 09 July 2017
3 9692 Mon, 24 July 2017 11:24
  Virgo 3.7.0.M01 - multiple bundles into same plan generates a dump error
Deploy multiples bundles in on plan generates resolution error
By: Junior Sousa on Thu, 03 November 2016
10 16911 Thu, 13 July 2017 13:18
By: Raghuram Devarakonda
  Plan for Virgo 3.7.2?
Roadmap
By: Joel Traber on Thu, 06 July 2017
2 11558 Fri, 07 July 2017 11:27
By: Joel Traber
  Deployment of a plan fails
By: Bill Mair on Wed, 07 September 2016
16 24563 Tue, 27 June 2017 16:53
By: Bill Mair
  Wrong OSGi constraint in bundle org.springframework.web_4.3.9.RELEASE
By: Joel Traber on Tue, 27 June 2017
1 6592 Tue, 27 June 2017 10:57
By: Florian Waibel
  Virgo 3.7.1.RELEASE is available
By: daniel marthaler on Sat, 24 June 2017
1 13534 Mon, 26 June 2017 08:11
By: Joel Traber
  Example: Apache CXF in Virgo
Sample / Recipe / Strategy for SOAP Web Services with Apache CXF
By: Bill Mair on Tue, 20 June 2017
3 17000 Fri, 23 June 2017 05:09
By: Bill Mair
  Virgo tooling installation error from eclipse market place
irgo tooling from eclipse market place - Installation error for Mars
By: SREE YADAVALLI on Fri, 09 June 2017
2 10556 Fri, 16 June 2017 09:11
By: SREE YADAVALLI
  Removing plan from pickup no longer stops the plan
Behaviour changed in 3.7.0, bug or feature?
By: Bill Mair on Thu, 08 June 2017
2 10820 Fri, 09 June 2017 09:56
By: Bill Mair
  Virgo 3.7.0 change Spring framework in user region
By: Joel Traber on Wed, 24 May 2017
1 6883 Wed, 24 May 2017 08:46
  Plan for Virgo 3.7.1?
Roadmap
1 7556 Wed, 24 May 2017 08:34
  Virgo 3.7.0 Fragment host, resource loading fails with JSF 2.2
By: Joel Traber on Thu, 11 May 2017
2 48208 Mon, 22 May 2017 13:23
By: Joel Traber
  Virgo 3.7.0 Spring bundles from plugins conflicts with repo/ext bundles
Virgo 3.7.0 Spring bundles conflicts
By: Karoly Kotay-Szabo on Thu, 18 May 2017
1 10065 Fri, 19 May 2017 10:04
By: Florian Waibel
  Minor change requested for dmk.sh
Please read setenv.sh before calling setupClasspath.sh
By: Bill Mair on Mon, 08 May 2017
2 8942 Tue, 09 May 2017 09:18
By: Bill Mair
icon5.gif Configuring security context for "/admin"
Is is possible to override the default security without changing the jar?
By: Bill Mair on Thu, 04 May 2017
4 16843 Tue, 09 May 2017 09:03
By: Bill Mair
  Disable recursive jar manifest 'Class-Path' verification
By: Emanuel Couto on Mon, 03 April 2017
5 13467 Fri, 07 April 2017 11:13
By: Emanuel Couto
  Virgo 3.7.0.RELEASE has been shipped
By: Florian Waibel on Fri, 10 March 2017
2 9370 Thu, 16 March 2017 19:39
By: Junior Sousa
  Virgo nano p2 shell command
p2 shell
By: Jeremy KUHN on Wed, 08 March 2017
0 6549 Wed, 08 March 2017 23:24
By: Jeremy KUHN
  Virgo 3.7.0 and Java 8 support
Why does Virgo 3.7.0 not yet have java 1.8 support
By: Patrick Braakman on Wed, 08 March 2017
1 5952 Wed, 08 March 2017 15:29
  Virgo Nano shutdown.bat throws error
By: Chandre Gowda on Tue, 14 February 2017
5 8367 Fri, 03 March 2017 08:33
By: Chandre Gowda
  websocket and web application support in latest virgo milestone
By: Chandre Gowda on Thu, 16 February 2017
3 17044 Wed, 22 February 2017 14:56
  Eclipse Virgo 3.7.0 on the home stretch...RC01 arrived.
By: Florian Waibel on Mon, 13 February 2017
2 4131 Tue, 21 February 2017 20:32
By: Jay Hamilton
  Virgo 3.7.0.M04 - Snaps is not available for download
By: Junior Sousa on Mon, 30 January 2017
3 4030 Tue, 14 February 2017 15:38
By: Junior Sousa
  Virgo 3.7.0.M03 - Repository/org.springframework.spring-library-4.2.1.RELEASE.libd incompatible
Spring version available into file does not match with current spring version
By: Junior Sousa on Thu, 10 November 2016
3 37303 Thu, 26 January 2017 15:49
By: Florian Waibel
  Virgo 3.7.0.M04 has been shipped
By: Florian Waibel on Thu, 26 January 2017
0 22794 Thu, 26 January 2017 15:09
By: Florian Waibel
  Virgo 3.7.0.M3 - KernelBundleClassLoader Concurrency during service startup
Multiples bundles loading simultaneously cause class loader issue
By: Junior Sousa on Wed, 18 January 2017
0 102488 Wed, 18 January 2017 02:41
By: Junior Sousa
  Virgo 3.7.0.M03 - Class loader management
Virgo does no load some dependencies classes from bundles before starting services
By: Junior Sousa on Mon, 16 January 2017
0 67617 Mon, 16 January 2017 13:29
By: Junior Sousa
  Multiple spring deployments on Virgo 3.7.M03?
By: Matteo Cantarelli on Tue, 10 January 2017
7 6958 Thu, 12 January 2017 10:31
icon4.gif Discontinuation of VNF and VJS distributions beginning with the 3.7.0.M04 release
By: daniel marthaler on Thu, 12 January 2017
0 27432 Thu, 12 January 2017 09:30
  Virgo 3.7.0 M02
Has anyone used this milestone yet?
By: Jay Hamilton on Thu, 24 March 2016
8 13020 Tue, 10 January 2017 13:34
  Problem with Virgo 3.6.4 + Spring 3.1.3 + Jackson 2
By: Matteo Cantarelli on Wed, 04 January 2017
6 7086 Tue, 10 January 2017 12:56
  External Integration of 3rd party non OSGI jars
By: Martin Kallinger on Tue, 27 December 2016
1 2969 Fri, 30 December 2016 09:46
  Virgo 3.7.0.M03 - Repository/ext spring-webmvc requires jstl 1.2.1
Failed to invoke JSTL Utils due to missing dependency
2 36393 Mon, 28 November 2016 16:33
By: Junior Sousa
  Alternative of using of snaps with Virgo 3.7.0.M3
Upgrade to virgo with a modular web app that use snaps in previous version
By: Junior Sousa on Tue, 27 September 2016
13 14632 Sat, 26 November 2016 15:58
  error when installing Snaps 3.0.2 on VTS 3.0.2
By: hserai on Wed, 30 November 2011
6 8684 Tue, 22 November 2016 00:03
By: nooshin noroozi
  How to find out when a plan is successfully started?
By: Raghuram Devarakonda on Fri, 11 November 2016
3 5187 Mon, 14 November 2016 15:44
  Eclipse Virgo vs Pax-web
What is the difference of these two projects
By: Pavel No on Wed, 02 November 2016
2 3210 Wed, 02 November 2016 13:07
By: Pavel No
  F2F Meeting at EclipseCon Europe on the 25th of October in Ludwigsburg
By: daniel marthaler on Wed, 12 October 2016
0 9548 Wed, 12 October 2016 19:48
icon11.gif virgo Package uses conflict
By: Jingtian Shen on Tue, 20 September 2016
0 4434 Tue, 20 September 2016 09:42
By: Jingtian Shen
  Virgo kernel fails to start
Kernel failed to start within XXX seconds.
By: Bisser P on Mon, 06 June 2016
12 14190 Thu, 15 September 2016 10:21
By: Tony Ganchev
  Cannot find plan 'org.eclipse.virgo.kernel.userregion.blueprint' on startup
By: Stefan Zugal on Thu, 01 September 2016
2 33639 Wed, 14 September 2016 14:17
By: Stefan Zugal
icon9.gif Wrong version of HttpClient in spring-web bundle 4.2.4 (Virgo 3.7M03)
The version in the manifest points to non-existent packages
By: Sven Panko on Wed, 03 August 2016
2 3897 Wed, 10 August 2016 17:07
By: Sven Panko
  How to Take Thread Dumps on Virgo-Jetty Server
Thread Dumps
By: BUNTY RAY on Wed, 15 June 2016
2 2984 Thu, 04 August 2016 10:14
By: mike james
  Plan with CXF DOSGi 3.1.6 fails to start
By: Bill Mair on Wed, 27 July 2016
4 3970 Thu, 28 July 2016 11:11
By: Bill Mair
  Active production installations?
Reference customers for Virgo platform?
By: Bill Mair on Mon, 25 July 2016
2 2910 Mon, 25 July 2016 23:02
By: Bill Mair
  Virgo upgrade from 3.6.3 on Java 7 to 3.6.4 on Java 8
By: ronit reichman on Thu, 21 July 2016
1 3434 Thu, 21 July 2016 14:36
  Virgo 3.6.4 + Apache CXF 3.1.4 = ClassNotFound
When deploying a service a ClassNotFoundException is thrown
By: Bill Mair on Thu, 07 July 2016
2 3345 Thu, 07 July 2016 10:26
By: Florian Waibel
  How to modify a web app context path at runtime?
By: Laurent Delamare on Wed, 29 June 2016
0 5945 Wed, 29 June 2016 00:26
  Classes not being found
Standard Java classes not being found
By: Bill Mair on Tue, 03 May 2016
3 6626 Thu, 26 May 2016 00:41
  OSGI fragment bundle not connected to websockets deployed in Virgo nano
By: Chandre Gowda on Wed, 04 May 2016
7 8780 Thu, 12 May 2016 08:35
  HttpService and ServiceTracker
The ServiceTracker is started but no HttpService is found?
By: Bill Mair on Mon, 09 May 2016
3 6390 Wed, 11 May 2016 19:00
By: Bill Mair
  How do I configure SPNEGO authentication?
How to configure Virgo Tomcat Server 3.6.4 to use SPNEGO authentication with Windows AD
By: Bill Mair on Wed, 04 May 2016
4 6210 Thu, 05 May 2016 16:21
By: Bill Mair
  Undelopying a Spring MVC bundle also leads to undeploying the other bundles
Using the DispacherServlet results in undeploying problem
By: Vlad Muresan on Tue, 03 May 2016
0 6526 Tue, 03 May 2016 09:42
By: Vlad Muresan
icon10.gif From OSGi to Blueprints & Virgo?
Changes to the bundles when working with Virgo
By: Bill Mair on Fri, 15 April 2016
11 14358 Wed, 20 April 2016 15:44
  VIRGO -NANO 3.6.4 Tomcat version
By: Chandre Gowda on Tue, 12 April 2016
9 10640 Mon, 18 April 2016 07:55
By: Chandre Gowda
icon5.gif PDE OSGi bundles and Virgo tooling
Shouldn't both tools use that same basis?
By: Bill Mair on Sat, 16 April 2016
3 7627 Sun, 17 April 2016 12:19
  Bundle-NativeCode selection-filter not properly supported
By: GianMaria Romanato on Wed, 13 April 2016
0 7911 Wed, 13 April 2016 13:13
  Virgo Tutorial
Getting Started with Eclipse Virgo
By: Florian Waibel on Wed, 16 April 2014
3 45818 Thu, 07 April 2016 10:39
By: Florian Waibel
  100% brand new Virgo 3.6.4 will not start.
By: Paul Roubekas on Tue, 22 March 2016
6 8099 Wed, 23 March 2016 15:03
By: Paul Roubekas
  VIRGO Server consumes 100% CPU Usage
By: Chandre Gowda on Wed, 16 March 2016
3 6890 Mon, 21 March 2016 13:13
By: Chandre Gowda
  Virgo Tools for Eclipse Luna and Mars
By: Vincenzo Caselli on Thu, 25 June 2015
10 13143 Tue, 02 February 2016 12:06
By: Florian Waibel
icon9.gif Virgo tooling and servlet 3.0
Virgo tooling does not allow to deploy servlet 3.0 aplications
By: Anti Alman on Mon, 18 January 2016
5 5816 Thu, 28 January 2016 20:04
By: Anti Alman
icon4.gif Virgo tooling with Mars
Failed to read manifest for bundle
By: Jeff Power on Thu, 07 January 2016
2 6651 Fri, 15 January 2016 08:57
  Virgo 3.6.4.RELEASE is now available
By: Violeta Georgieva on Fri, 28 August 2015
8 10250 Wed, 13 January 2016 18:07
By: Chi Shih Chang
  Virgo release schedule?
When and what is going to be released next?
By: Markku Tienhaara on Tue, 28 April 2015
4 5484 Wed, 13 January 2016 09:54
By: Florian Waibel
  Newbie experiences with Virgo
By: Kees Pieters on Wed, 30 December 2015
1 7586 Mon, 11 January 2016 16:19
By: Florian Waibel
  VIRGO NANO doesn't respond for multiple requests
By: Chandre Gowda on Wed, 30 December 2015
0 7087 Wed, 30 December 2015 12:05
By: Chandre Gowda
Intermittenly getting java.util.ServiceConfigurationError Exception
By: Setya Nugdjaja on Sun, 06 December 2015
3 5843 Sun, 20 December 2015 15:49
By: Setya Nugdjaja
  Problem with Spring NamespaceHandler
Unable to locate Spring NamespaceHandler
By: Setya Nugdjaja on Fri, 27 November 2015
9 9097 Mon, 07 December 2015 07:02
By: Setya Nugdjaja
  Initial Bulk Hot Deploy
By: Felix Schöpf on Tue, 17 November 2015
4 4983 Tue, 01 December 2015 09:45
By: Felix Schöpf
  Duplicate jars
Found duplicate jars
By: Setya Nugdjaja on Thu, 26 November 2015
1 3151 Fri, 27 November 2015 12:02
By: Florian Waibel
  java.lang.ClassNotFoundException on virgo
java.lang.ClassNotFoundException: javax.crypto.Mac excpetiin in Virgo 3.6.4
By: Kees Pieters on Wed, 21 October 2015
2 6941 Fri, 23 October 2015 15:56
By: Kees Pieters
  Install Virgo Tools without internet access
By: Deepa Joby on Tue, 29 September 2015
2 3637 Thu, 01 October 2015 13:23
By: Deepa Joby
  Virgo 3.6.4 and Debian package or puppet integration
By: Marco Descher on Thu, 27 August 2015
1 3713 Fri, 28 August 2015 19:32
  Proposal for global JNDI support in future Virgo releases
By: GianMaria Romanato on Thu, 06 August 2015
0 5682 Thu, 06 August 2015 12:40
  Neo4j on Eclipse Virgo
By: Mathilde Ffrench on Mon, 20 July 2015
1 6552 Thu, 06 August 2015 11:53
By: Florian Waibel
  Synthetic Context bundle loading while migrating from Virgo 3.0.1 to 3.5.0
Import bundles are not loading through Bundle Synthetic Context(PAR) while migrating from Virgo version 3.0.1 to 3.5.0
By: Hemendra Yadav on Fri, 24 July 2015
1 3738 Fri, 24 July 2015 17:15
  Define the order to pickup jars in pickup folder of Virgo Nano
By: Chandre Gowda on Tue, 21 July 2015
1 3089 Tue, 21 July 2015 10:51
  Virgo / Equinox console usage
By: Franck Mising name on Thu, 25 April 2013
20 20830 Mon, 20 July 2015 18:12
  Virgo 3.6.3 and Java 8 support
Does Virgo 3.6.3 support Java 8?
By: Elbert van Dijk on Fri, 06 February 2015
12 12589 Thu, 16 July 2015 09:14
  Jaas login module service
By: Jacob Hameiri on Thu, 17 March 2011
8 11548 Fri, 12 June 2015 12:47
By: Brian Brooks
  Virgo doesn't start if installed in a path containing a space
By: Chandre Gowda on Fri, 05 June 2015
1 3256 Fri, 05 June 2015 09:01
By: Florian Waibel
  Admin Console for Nano Web?
nano web
By: Marshall Benfield on Mon, 22 September 2014
1 5625 Tue, 05 May 2015 09:03
By: Florian Waibel
  Virgo Nano latest version with WebSocket support
By: Chandre Gowda on Tue, 05 May 2015
1 3201 Tue, 05 May 2015 09:02
By: Florian Waibel
  Install bundles located in the provisioning repositories programmatically
By: Marco Gerber on Wed, 13 July 2011
9 20574 Sat, 02 May 2015 00:52
By: Ellen Strnod
  Virgo Tomcat 3.6.3 - Websocket JSR 356 - 404 error?
By: Patrick Payer on Fri, 10 April 2015
6 7786 Thu, 23 April 2015 06:58
  Requesting to be started bundle list to virgo
By: Mathilde Ffrench on Sat, 11 April 2015
5 6491 Tue, 21 April 2015 07:43
  java.io.tmpdir points to an unexsiting folder
By: GianMaria Romanato on Thu, 16 April 2015
6 6336 Thu, 16 April 2015 16:54
  Virgo 3.6.2 library load error (folder is expected as jar archive)
Load of Primefaces library log an error, but everything works fine.
By: Jan Horky on Mon, 16 March 2015
2 4025 Mon, 16 March 2015 15:11
By: Jan Horky
  Import-Package error for already-deployed dependency
By: Ryan Bennett on Fri, 20 February 2015
5 8374 Tue, 24 February 2015 16:09
By: Ryan Bennett
  How build Tomcat OSGi Bundle
By: shuiping li on Sun, 22 June 2014
10 9483 Sun, 11 January 2015 13:45
  Tomcat 7.0.52 in Virgo 3.6.2
By: Jan Fetyko on Fri, 14 March 2014
4 6677 Thu, 08 January 2015 10:49
By: Florian Waibel
  how to update logback version in virgo?
By: bill bill on Wed, 24 December 2014
0 5429 Wed, 24 December 2014 09:38
By: bill bill
  Update Virgo with org.eclipse.osgi_3.9.1
By: Laurent Delamare on Fri, 14 November 2014
2 4757 Fri, 14 November 2014 16:48
  Virgo, Java 8, Blueprint/Spring 4.x, Tooling
Plans to update to latest versions?
By: Eddie Mc Greal on Fri, 22 August 2014
4 7727 Fri, 14 November 2014 08:46
  Support for Spring 4.0
Looking for plan to support Spring Framework 4.0 and Java 8
By: benoit besson on Fri, 24 January 2014
4 6722 Thu, 09 October 2014 11:47
By: Florian Waibel
  Bundle Error:Import-package:xxxx can not be resovled
SpringSource Bundle Dependency Ploblem
By: xmuysa on Sun, 24 July 2011
5 12169 Sun, 28 September 2014 07:58
By: wang chuanyin
  Bundlor and 'static resources'
By: Daniel McGreal on Mon, 18 February 2013
5 7699 Thu, 25 September 2014 17:51
By: Hüseyin Kartal
  Any owners of the #virgo IRC channel on Freenode around?
By: Justin Gallardo on Wed, 24 September 2014
3 4044 Thu, 25 September 2014 11:11
By: Florian Waibel
  Virgo and Java 1.7 bundles
Resolver error data <Bundle-RequiredExecutionEnvironment: JavaSE-1.7>
By: Thorsten Hilker on Mon, 01 September 2014
6 8348 Thu, 18 September 2014 14:51
By: Florian Waibel
  Configure Tomcat to serve static files directly from filesystem
By: Jean-Pierre Bergamin on Tue, 21 February 2012
4 12332 Mon, 15 September 2014 14:18
By: Chris Werner
  Bundles in usr and pickup behave differently
By: guofeng zhang on Fri, 17 September 2010
2 5774 Mon, 15 September 2014 11:23
By: Chris Werner
  Tomcat 8.0.12 integration
By: Matteo Cantarelli on Fri, 12 September 2014
1 5147 Fri, 12 September 2014 17:01
  bundlor and shade in maven environment
creation of Export-Package entries for depending jars
By: Hüseyin Kartal on Tue, 02 September 2014
0 4209 Tue, 02 September 2014 19:16
By: Hüseyin Kartal
icon11.gif Virgo Bundlor 1.1.2 RELEASE Error
By: pan gao on Thu, 31 July 2014
2 7697 Tue, 02 September 2014 18:09
By: Hüseyin Kartal
  eclipse and bundlor 'Bundle-Classpath File Detection Criteria'
By: Jacob Hameiri on Sat, 19 November 2011
1 16439 Tue, 02 September 2014 16:23
By: Hüseyin Kartal
  JMS: Blueprint and DefaultMessageListener
By: Patrick Payer on Sat, 30 August 2014
0 5738 Sat, 30 August 2014 18:41
By: Patrick Payer
  Spring Framework 3.2.10.RELEASE - Bundlor and Eclipse EBR templates for generating OSGi metadata
By: Violeta Georgieva on Sat, 30 August 2014
0 6606 Sat, 30 August 2014 04:21
  where is catalina.base property defined?
By: Laurent Delamare on Sun, 03 August 2014
4 11501 Fri, 29 August 2014 16:15
By: Gary Zharzhavsky
  JVM exited while loading the application. (Virgo Service error)
By: John Joseph on Wed, 27 August 2014
1 8399 Thu, 28 August 2014 19:58
By: Eric Rizzo
  virgo 3.6.x and p2
How to provision using p2 on virgo
By: Missing name Mising name on Mon, 18 August 2014
1 3784 Tue, 19 August 2014 07:07
  Installation of pax logging in Virgo failing
By: Timothy Vogel on Mon, 11 August 2014
1 4647 Tue, 12 August 2014 11:25
By: Timothy Vogel
  plan command in shell
By: Timothy Vogel on Sun, 10 August 2014
5 6215 Tue, 12 August 2014 10:18
By: Timothy Vogel
  Cannot declare service
By: Missing name Mising name on Sun, 10 August 2014
0 5514 Sun, 10 August 2014 17:41
  Dynamic PAR extension
By: Missing name Mising name on Thu, 07 August 2014
2 4001 Thu, 07 August 2014 10:30
  VIRGO OSGI
Support OS - IBM AIX ?
By: Bini Prabhakar on Mon, 04 August 2014
1 3995 Tue, 05 August 2014 13:57
By: Eric Rizzo
  Share Virgo OGSi deploy Application service
By: shuiping li on Fri, 01 August 2014
0 4943 Fri, 01 August 2014 00:30
By: shuiping li
icon8.gif install virgo tooling in eclipse LUNA
virgo tooling eclipse4.4 luna
By: liu peng on Wed, 23 July 2014
2 11636 Tue, 29 July 2014 01:25
By: liu peng
  Virgo 3.6.3 RELEASE is now available
By: Violeta Georgieva on Sun, 20 July 2014
1 3992 Mon, 21 July 2014 01:24
By: shuiping li
  Error "not a valid URI or file path" when deploying on drive D:
By: Laurent Delamare on Sat, 19 July 2014
0 8435 Sat, 19 July 2014 14:17
  Has Virgo plan or bundle OGSi deployment service?
By: shuiping li on Fri, 18 July 2014
0 4667 Fri, 18 July 2014 02:34
By: shuiping li
  Problems resolving "sun.reflect.generics.reflectiveObjects"
By: Raghuram Devarakonda on Wed, 02 July 2014
1 4450 Thu, 03 July 2014 01:52
  updating configuration properties via OSGi console
By: JC Carrillo on Tue, 01 July 2014
4 4023 Wed, 02 July 2014 13:39
By: JC Carrillo
  Gemini Web 2.2.3 RELEASE is now available
By: Violeta Georgieva on Tue, 01 July 2014
2 3689 Wed, 02 July 2014 06:45
  virgo tooling not suport eclipse 4.4 release
virgo tooling not work in eclipse 4.4
By: oumi casha on Thu, 26 June 2014
2 5618 Wed, 02 July 2014 01:03
By: oumi casha
  Virgo Tomcat and static web content context
By: Mathilde Ffrench on Fri, 20 June 2014
4 7353 Sun, 29 June 2014 15:31
  registering servlet using httpService via blueprint declaration in Virgo
By: Johnson Abraham on Wed, 25 June 2014
2 6477 Thu, 26 June 2014 20:52
By: Johnson Abraham
icon8.gif new version of virgo
0 5994 Thu, 26 June 2014 02:24
By: oumi casha
  How to apply Gemini weaving
By: nguyen van on Wed, 25 June 2014
0 4656 Wed, 25 June 2014 07:19
By: nguyen van
  Dynamic Web Module version 3.0 on Virgo tools
Why not?
By: Santiago Ruiz on Fri, 20 June 2014
2 5128 Mon, 23 June 2014 12:29
  Tomcat CVE
CVE in tomcat 7
By: Brian Blasko on Thu, 29 May 2014
1 31674 Tue, 03 June 2014 12:05
  Deploy Web bundle in Virgo Nano full
By: Vasanth Kumar on Mon, 26 May 2014
0 61099 Mon, 26 May 2014 09:18
By: Vasanth Kumar
  Org.eclipse.persistence.jpa deployment issue in VIRGO
java.lang.NoClassDefFoundError: javax/resource/ResourceException
By: Chandre Gowda on Mon, 19 May 2014
2 6435 Tue, 20 May 2014 10:15
By: Chandre Gowda
  REST Apis for Administration
Virgo Administration
By: JC Carrillo on Fri, 16 May 2014
3 5592 Mon, 19 May 2014 11:39
By: Chris Frost
  Ready, Steady, Vir...Go!
A blog post about moving to immutable, atomic deployment units
By: Florian Waibel on Thu, 15 May 2014
0 27570 Thu, 15 May 2014 13:17
By: Florian Waibel
  Virgo 3.6.1 + Spring 3.2.2 + org.springframework.osgi.core
By: Maarten Winkels on Tue, 07 May 2013
4 9020 Tue, 06 May 2014 09:19
By: Ferdinand Mising name
  Subdomain and virtual host configuration on Virgo
By: Matteo Cantarelli on Thu, 24 April 2014
1 36686 Wed, 30 April 2014 07:45
  Virgo project about to be deleted!
By: Glyn Normington on Wed, 02 October 2013
28 29084 Mon, 28 April 2014 20:56
By: Florian Waibel
  Virgo 3.5+ hibernate 4 + spring 3.1.1 unknown entity problem
By: Jay Huang on Mon, 05 March 2012
2 8963 Fri, 25 April 2014 06:01
By: Rajiv Croos
  Moving from 3.5.0 to 3.6.2.RELEASE results in "not visible from classloader"
By: Randy Cuaycong on Tue, 08 April 2014
6 8610 Wed, 23 April 2014 09:05
By: Florian Waibel
  Can Spring be used in host and in snaps?
By: Bojan Kraut on Tue, 08 January 2013
9 10150 Sat, 19 April 2014 10:35
By: Rajiv Croos
  [resolved] CXF failed to publish endpoints in Eclipse 4.2.2 OSGi, Jetty 8.1.14 and Spring 3.0.7 env
By: zhou3r Mising name on Mon, 07 April 2014
1 5455 Fri, 18 April 2014 17:17
  Virgo 3.6.2 JAASRealm Valve LoginModule
Problem using an userdefined LoginModule
By: Klaus Ungerhofer on Wed, 29 January 2014
3 51378 Thu, 17 April 2014 06:09
  Cannot find declaration of element beans
Parsing of activemq configuration files
By: rajesh ullal on Thu, 03 April 2014
0 8152 Thu, 03 April 2014 10:14
By: rajesh ullal
  Get the status of application deployment..
By: Chandre Gowda on Thu, 27 March 2014
1 3984 Thu, 27 March 2014 08:24
By: Florian Waibel
  3.5.0.M04 Cannot determine the artifact identity of the file
By: Rich Mayfield on Fri, 04 May 2012
5 15825 Fri, 21 March 2014 14:47
By: Leonid Ilyevsky
  Websocket on Virgo Tomcat Server
By: QQ Wang on Fri, 07 March 2014
3 7218 Fri, 21 March 2014 05:27
  Spring Java Based Configuration
Configure Spring Context via Java
By: Thorsten Hilker on Mon, 17 March 2014
5 6859 Thu, 20 March 2014 09:50
By: gustavo monarin
  struts2-virgo-plugin
struts2 virgo plugin OSGi
By: liu peng on Thu, 20 March 2014
1 4071 Thu, 20 March 2014 09:31
By: liu peng
  Virgo contribution and github
By: Mathilde Ffrench on Thu, 13 March 2014
2 4943 Fri, 14 March 2014 07:35
  Virgo 3.6.2 uses snaps and struts2
By: liu peng on Wed, 12 March 2014
6 8305 Fri, 14 March 2014 06:58
By: liu peng
  Order of bundle installation
How does Virgo determine what order to install bundles after a restart?
By: Virgo Noob on Tue, 04 March 2014
6 7320 Thu, 13 March 2014 06:50
By: Tin N/A
  Virgo 3.7 RELEASE
RELEASE 3.7 DEAD
By: liu peng on Tue, 11 March 2014
1 4254 Tue, 11 March 2014 09:29
By: Florian Waibel
  Virgo tooling support for Virgo Nano
Virgo OSGi bundle projects are not deployable on Virgo Nano
By: R R on Mon, 10 March 2014
0 3201 Mon, 10 March 2014 16:36
By: R R
  how to use virgo to publish my rap application
By: fu duhui on Mon, 03 March 2014
2 4848 Fri, 07 March 2014 03:36
By: fu duhui
  A Require-Bundle could not be resolved
By: fu duhui on Wed, 05 March 2014
2 4947 Thu, 06 March 2014 02:42
By: fu duhui
  javax.xml jar processing takes more time in VIRGO
By: Chandre Gowda on Tue, 12 November 2013
4 6883 Mon, 03 March 2014 10:59
By: Murthy Bhat
  javax.mail issues with multipart messages
By: Franck Mising name on Wed, 22 January 2014
1 16526 Thu, 27 February 2014 12:59
By: Martin Baumgartner
  How are bundle jars copied to stage dir?
By: Barbara Rosi-Schwartz on Fri, 21 September 2012
7 10242 Thu, 27 February 2014 12:52
icon11.gif virgo:UnableToSatisfyBundleDependenciesExcept
By: fu duhui on Thu, 27 February 2014
1 4199 Thu, 27 February 2014 08:44
By: Florian Waibel
  Virgo Server failed to start
When starting Virgo server 3.5.0.RELEASE, it failed to start due to org.springframework.beans.factory.BeanDefinitionStoreException: Unexpected exception parsing XML document from OSGi resource
By: Bharat Mania on Sun, 23 February 2014
4 6238 Thu, 27 February 2014 04:56
By: Bharat Mania
  Spring Security and Virgo
Share a ThreadLocal Variable between bundles
By: Miguel Salinas Gancedo on Fri, 21 February 2014
2 4266 Mon, 24 February 2014 12:06
  Implement something like virgo snaps using virgo jetty server
By: taozi yin on Mon, 17 February 2014
0 8494 Mon, 17 February 2014 03:18
By: taozi yin
  Configuration artifacts management
By: Mathilde Ffrench on Fri, 14 February 2014
1 8842 Sun, 16 February 2014 20:36
By: Chris Frost
  Can the Maven Tomcat7 Plugin Be Used
By: Kevin Coy on Wed, 04 December 2013
4 8426 Fri, 07 February 2014 17:18
By: Frieder Heugel
  virgo servie with Apache Daemon (prunsrv.exe)
How to install virgo as service with Apache Daemon (prunsrv.exe)
By: Gary Zharzhavsky on Fri, 03 January 2014
1 19694 Tue, 04 February 2014 17:57
  Blueprint and property-placeholders
By: Franck Mising name on Sat, 01 February 2014
1 31290 Sun, 02 February 2014 19:33
By: Scott Brand
  Where to download the virgo form tags sample?
By: Rice Yeh on Sun, 11 March 2012
5 6877 Sat, 18 January 2014 01:03
By: Jaime Hablutzel
  JBoss AS drops OSGI support
By: Franck Mising name on Wed, 15 January 2014
3 6552 Thu, 16 January 2014 09:07
By: Glyn Normington
  3.6 migration issues
By: Jacob Hameiri on Tue, 14 January 2014
4 8114 Wed, 15 January 2014 09:35
By: Glyn Normington
Current Time: Thu Jan 02 16:19:39 GMT 2025
Powered by FUDForum. Page generated in 0.10537 seconds
