PDE build failing with java 11. Missing Constraint: Bundle-RequiredExecutionEnvironment: JavaSE-11 Host plug-in JavaSE_0.0.0 has not been found. |
2835 |
Thu, 27 June 2024 11:53 By: Teodor Dimache ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
I am getting Error while calling Birt Report i want to call Birt report from spring mvc but got the below error |
544 |
Mon, 10 June 2024 17:04 By: Irfan Khan ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Can not able to Post thread on Birt Forum |
522 |
Mon, 10 June 2024 17:03 By: Irfan Khan ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
get Run History get Run History of Eclipse |
675 |
Fri, 31 May 2024 08:25 By: Art Zor ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Create Icon with Line number for every public static method in java file |
746 |
Mon, 13 May 2024 10:13 By: Rishabh Agrawal ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
touchpoint action when plugin updates By: Phil R on Tue, 27 March 2012 |
2812 |
Tue, 20 February 2024 08:50 By: Axel Stein ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Launch Java Agent in Eclipse PDE Get application launch configuration from LaunchShortcut and start instrumenting Java project to observe class, method, and variable |
2704 |
Mon, 29 January 2024 16:18 By: Tan Jun Wen ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Running debug launch produces white screen (macos) |
826 |
Mon, 15 January 2024 19:47 By: Levi Starrett ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
configuring 3rd party libraries to eclipse plugin project How to configure external 3rd party libraries to eclipse plugin project during runtime |
1852 |
Fri, 22 December 2023 06:36 By: Madhavilatha Boyana ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Could not find a org.eclipse.pde.core.targetLocations extension for type: Maven |
10320 |
Tue, 21 November 2023 17:18 By: Michael Haubenwallner ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Not familiar with PDE, need help building a plugin and a local update site |
1182 |
Fri, 15 September 2023 20:42 By: David M. Karr ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Cross tab with large data set |
5543 |
Mon, 04 September 2023 04:49 By: Basavaraj Balte ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Customize Package- or Project Explorer on a per-project base |
3180 |
Sun, 03 September 2023 09:29 By: Vasili Gulevich ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Eclipse ui development guide Eclipse wont build |
1531 |
Tue, 18 July 2023 15:39 By: nck nck ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Migration Wizard pops up inconsistently |
3840 |
Thu, 06 July 2023 19:20 By: Andrew Tram ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
RCP Application - Unresolved requirement Unresolved requirement |
1081 |
Thu, 29 June 2023 09:39 By: Scott Exton ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Load image based on Eclipse theme |
906 |
Wed, 24 May 2023 06:01 By: Joseph Adriane Cabrera ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Custom Eclipse Plugin compatibility issues due to changes in EclipseLauncher class Using older version of m2e-core plugin that has different signature for runMaven() method in IMavenLauncher interface |
1168 |
Sat, 29 April 2023 06:00 By: Kamalpreet Kaur ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to remove dependency to XServer in Linux for RCP product How to remove dependency to XServer in Linux for RCP product |
1209 |
Fri, 21 April 2023 03:57 By: Madhavi T ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
LinkageError with OSGI Bundle |
1077 |
Tue, 28 March 2023 05:50 By: Vladimir Guan ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Calling Extension Point Schema Compiler Headless Generating and testing extension point documentation |
1521 |
Fri, 03 March 2023 07:03 By: Jörn Guy Süß ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
implementing "inline" suggestions |
1745 |
Wed, 08 February 2023 15:10 By: Amir Tuval ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to use packages with different versions By: M R on Fri, 20 January 2023 |
1324 |
Fri, 20 January 2023 13:25 By: M R ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Understaning where java*.* imported packages Target Platform uses JRE and org.elipse.osgi and some missing |
1459 |
Tue, 08 November 2022 03:27 By: Chris Lake ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Building a plug-in from Eclipse SDK |
1818 |
Tue, 20 September 2022 17:46 By: Gidi Gal ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Is it possible to auto-install plugin dependencies? Problem with installing some plugins due to lack of package dependencies |
5166 |
Fri, 02 September 2022 16:52 By: Yue Yang ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
2022-06 Product Launch JRE does not match Target Platform Unexpected default for product launch configuration JRE |
1717 |
Tue, 09 August 2022 17:07 By: Trae Bailey ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
PDE JUNIT4 Tests (headless via ANT) Test Automation for plug-ins and features |
1901 |
Thu, 21 July 2022 21:21 By: Che Bumagat ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Pin version of bundle over all location in target file |
2518 |
Wed, 29 June 2022 12:39 By: Vaclav Hala ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Trouble with javax.annotation |
5294 |
Tue, 10 May 2022 14:23 By: Lee Carver ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Eclipse PDE: dynamic StyleRange |
2250 |
Thu, 14 April 2022 15:30 By: Viacheslav Fateev ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Unable to launch Eclipse applications Launch of Hello World Command plugin blocked due to unresolved requirement |
2969 |
Tue, 05 April 2022 21:34 By: Richard Steiger ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Build Dependency Problem. Required Bundle does not work. |
2506 |
Wed, 30 March 2022 17:11 By: philipp huebner ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Exporting Eclipse Product in Version 2021-12 (4.22.0) - org.osgi.framework.BundleException Start of exported application results in org.osgi.framework.BundleException |
4947 |
Wed, 16 March 2022 16:34 By: Fabian Deitelhoff ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
RCP plugins source/Origin RCP plugins source/Origin |
3308 |
Wed, 26 January 2022 18:46 By: sridhar Mising name ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Tycho ignores versions defined in target file when the versions are not specified in Manifest.MF |
5479 |
Mon, 24 January 2022 12:08 By: Tural Malikli ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Tycho: requires 'osgi.ee; (&(osgi.ee=JavaSE)(version=11))' but it could not be found Porting Eclipse ATL to JavaSE-11 / latest Eclipse p2 repos |
2873 |
Mon, 10 January 2022 13:38 By: Dennis Wagelaar ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Tycho: Target - does only accept few maven artifacts? Some dependencies from maven are working for tycho, other don't... |
3170 |
Tue, 30 November 2021 08:41 By: Michael Fritscher ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Creating a plugin for Eclipse 4 |
3870 |
Mon, 29 November 2021 11:26 By: Jenny Strømmen ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Invoking the "run" button command in plugin |
7040 |
Tue, 09 November 2021 11:27 By: Gokilavani sivanantham ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Maven Dependency classes are not resolved in runtime eclipse during plugin development |
3410 |
Mon, 08 November 2021 06:54 By: Suseendran Jeevanantham ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Problems resolving dependency to packages "javax.servlet.*" |
2519 |
Thu, 04 November 2021 10:59 By: Matthias Fromme ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Design tab is not showing |
2226 |
Tue, 02 November 2021 12:38 By: Aniket Kumar ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to resolve the dependency on pdebuild.jar |
29107 |
Wed, 06 October 2021 09:41 By: Kengo TODA ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Publishing update site with Eclipse Tycho |
1539 |
Tue, 28 September 2021 09:08 By: Daomephsta - ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Unable to generate resolutions for marker I have implemented IMarkerResolutionGenerator, IMarkerResolution and added extension points as well. Still does not work properly. |
2875 |
Tue, 28 September 2021 00:37 By: Daomephsta - ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Can't type quotation marks with Mac international keyboard layout |
2935 |
Wed, 15 September 2021 09:19 By: Carl Witt ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Can't find library-file in eclipse-test-framework-4.8 |
2390 |
Sat, 21 August 2021 14:47 By: sadasd adasda ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Run As > Eclipse Application hangs Run Eclipse Application gets root exception Attempted to beginRule: R/, does not match outer scope rule |
1871 |
Thu, 12 August 2021 04:39 By: Ed Merks ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
What is option -bootclasspath in java eclipse? What is option -bootclasspath in java eclipse? |
2451 |
Tue, 10 August 2021 06:14 By: Sushmitha v ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Getting compliance error while trying to export feature project from my eclipse rcp workspace Getting compliance error while trying to export feature project |
1913 |
Wed, 14 July 2021 07:35 By: Sushmitha v ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Target Platform |
2246 |
Sun, 04 July 2021 11:15 By: philipp huebner ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to add theme switching support, for standalone app. eclipse plugin, mission control, theme |
2502 |
Wed, 09 June 2021 13:32 By: Missing name Mising name ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Listen to plugin uninstall hook |
2332 |
Tue, 18 May 2021 21:20 By: Ernesto Pin ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
An internal error has occurred java.lang.IllegalArgumentException: Comparison method violates its general contract! |
3505 |
Thu, 22 April 2021 17:43 By: Nuchem Katz ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to Trigger "Build All" for site.xml via ANT task |
1875 |
Sat, 03 April 2021 00:33 By: Peter Dell ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
JNA call hangs until OSGI exit Native FMU / FMI integration into OSGI environment |
2097 |
Mon, 29 March 2021 09:23 By: Christian Derksen ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Custom toolbar for plugin perspective By: Eclipse User on Sat, 27 February 2021 |
2472 |
Mon, 15 March 2021 13:33 By: Thomas Barth ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Plugin Development unresolved 'org.eclipse.ui' |
2016 |
Fri, 12 March 2021 09:07 By: Pelle Svensson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Eclipse e4 application wizard The created app has a reference to an old project |
2138 |
Sat, 27 February 2021 16:58 By: Udi Kalifon ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
The font color in SWT Checkbox Button cannot be grayed out if disabled Button Color Issue |
1022 |
Tue, 02 February 2021 03:46 By: Nitin Dahyabhai ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Limitations of running plugins as jars (packed) or dirs (upacked) |
4364 |
Fri, 22 January 2021 09:52 By: Martin Lemnian ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
SVG error |
4326 |
Thu, 21 January 2021 09:31 By: Mariem Makni ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Apache batik SVG error |
4482 |
Tue, 19 January 2021 13:31 By: Mariem Makni ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[Solved] PDE version out of sync with JDT? How is this resolved? |
1893 |
Tue, 12 January 2021 12:37 By: Duncan Field ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Is it possible to redirect to browser URL on splash image click? |
1917 |
Sun, 10 January 2021 19:37 By: sadasd adasda ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
AccessControlException in eclipse-based product when using New Plugin Project wizard |
1907 |
Mon, 09 November 2020 15:54 By: Missing name Mising name ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Product Export with JDK 11 Missing requirement: plugin requires 'osgi.ee; (&(osgi.ee=JavaSE)(version=11))' but it could not be found |
2332 |
Mon, 02 November 2020 05:40 By: Chris Lake ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
PDE Build can't find dependency to Java 11 |
3791 |
Fri, 30 October 2020 01:02 By: Chris Lake ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Error when starting Runtime Eclipse |
942 |
Wed, 14 October 2020 14:51 By: Udo Walker ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Is there are way to set max supported version of eclipse for Eclipse plugin? |
1095 |
Thu, 01 October 2020 10:49 By: Elena Kyorova ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
I can't run Eclipse IDE Eclipse 1.5.800.v20200727-1323 do not run |
1451 |
Fri, 25 September 2020 14:08 By: Juliano Jardim ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Eclipse product export fails if plug-ins have different EEs and "Generate p2 repository" s |
2752 |
Sun, 06 September 2020 09:38 By: Phil Beauvoir ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Ant ClassNotFoundException While Exporting A Plug-In |
9445 |
Thu, 27 August 2020 21:03 By: Rob Hatcherson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
PDE Build vs. Maven + Tycho |
3917 |
Mon, 24 August 2020 08:44 By: Pit Friedrich ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
QuickFix (Marker Resolutions) not available in the Editor, only in Problems-View? Marker-Resolutions from the extension point "org.eclipse.ui.ide.markerResolution" only show up in the "Problems"-View, not on the editors Annotations. |
5802 |
Fri, 21 August 2020 17:51 By: Artsiom Chapialiou ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Eclipse Plugin Console Launch Buttons |
3599 |
Tue, 18 August 2020 15:06 By: Aykut Yüksek ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Problem running app with multiple versions of the same bundle selected Possibly an incorrect config.ini generated By: Mark . on Mon, 06 February 2012 |
6577 |
Thu, 30 July 2020 17:35 By: Hubert Guerard ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to listen to file events |
1839 |
Wed, 22 July 2020 16:29 By: Viacheslav Fateev ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How can I get the path of the my file (I need to write to a CVS file in my project folder) How can I get the path of the my file (I need to write to a CVS file in my project folder) |
2373 |
Tue, 14 July 2020 20:10 By: zakarias fridriksson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Bundle activation visualization tool |
2054 |
Mon, 13 July 2020 15:01 By: Stefan Winkler ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Missing Installed Software tab |
3938 |
Fri, 10 July 2020 16:56 By: Mark Millard ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to include product copyright info |
6644 |
Tue, 23 June 2020 21:44 By: Nathan Tippy ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
product-based P2 install missing copyright and license info By: Eclipse User on Fri, 04 September 2009 |
3575 |
Notification on help invoked |
2753 |
Tue, 23 June 2020 14:02 By: ganesh rao ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Rendering an ITextEditor inside a SWT Composite Trying to embed a Generic Text Editor inside a SWT Composite |
2558 |
Thu, 18 June 2020 23:43 By: Martin D'Aloia ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Plugin with Tycho and 2020-03 but I want it to work on JRE 8 My Plugin works great on 11 but some clients are still on 8 |
1990 |
Fri, 05 June 2020 21:59 By: Nathan Tippy ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to intercept main window creation? |
2212 |
Mon, 01 June 2020 20:11 By: Teymuraz Khazaradze ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
What API indicate that Eclipse startup is finished |
3516 |
Mon, 01 June 2020 19:38 By: Teymuraz Khazaradze ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Text editor with coloring I try to figure out the easiest way to color my text |
2232 |
Sat, 30 May 2020 09:44 By: alex bav ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
DS Annotations missing from permanent build path Nothing removes this warning! |
1953 |
Fri, 29 May 2020 00:46 By: Chris Lake ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Missing dependency while product export |
8647 |
Tue, 14 April 2020 23:31 By: Kunal Harkare ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Tycho build fails using version 1.4.0 Tycho build fails using version 1.4.0 |
4896 |
Fri, 20 March 2020 12:59 By: Nitin Dahyabhai ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
DeviceResourceException on "sample.png" JFace looks for "sample.png", which is not referenced from any code I know of. |
1771 |
Tue, 17 March 2020 09:02 By: Magnus Marthinsen ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to implement this method in a eclipse command handler for a context menu contribution? |
945 |
Sat, 25 January 2020 11:24 By: Abu BAkar Saadat ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Plug-In to Create a new Project Tutorial for plug-in to create a new Eclipse project??? |
1522 |
Tue, 14 January 2020 02:10 By: Ken George ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Dependency required and class I could extend for warning signs in import statments Building an eclipse plugin. What dependency and which class could I extend to implement warning signs in Java and Effective pom files for a project? By: Ron Don on Fri, 10 January 2020 |
996 |
Fri, 10 January 2020 05:27 By: Ron Don ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Creating a context menu entry for projects in the Project Explorer (E4) By: Eclipse User on Mon, 30 December 2019 |
2688 |
Mon, 30 December 2019 00:44 By: Eclipse User ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Plugin code can't find "javax.inject.Inject" in rpc 2019-12 |
2393 |
Sat, 28 December 2019 06:38 By: David M. Karr ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Reminder of steps to load Eclipse plugin in test instance so I can debug it? |
1360 |
Fri, 27 December 2019 16:52 By: David M. Karr ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
TFS extension in Eclipse Plugin Development How to programmatically Detect Local changes |
2933 |
Tue, 17 December 2019 21:41 By: Che Bumagat ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Signing the plugin content Signing the plugin content - Error message "SHA-256 hash is not as expected" |
3144 |
Sun, 15 December 2019 14:49 By: George Azzam ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Http Whiteboard propertytypes annotation support does PDE support things like @HttpWhiteboardServletPattern etc |
4833 |
Tue, 10 December 2019 14:48 By: Erwin De Ley ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Problem with dependency resolution in PDE 2019-06? My build works in 2019-03 but not in 06 |
4984 |
Mon, 18 November 2019 10:10 By: Thomas Berger ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
RCPTT linux compatibility RCPTT Linux |
3384 |
Mon, 18 November 2019 04:02 By: Vivien Jovet ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Refresh TextEditor without close/open |
11329 |
Mon, 18 November 2019 03:59 By: Vivien Jovet ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Eclipse p2 repository is not accessible Eclipse 2018-12 p2 repository is not accessible as tycho repository |
3678 |
Fri, 15 November 2019 10:33 By: Aruna Deshpande ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Dynamically loading plugins |
9399 |
Sun, 22 September 2019 06:33 By: Mathew Benson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Unable to resolve the targetplatform Unable to resolve the targetplatform |
3908 |
Wed, 21 August 2019 12:25 By: Veerababu Maragani ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
NPE in ColumnViewerEditor due to cellEditor is null when I switch the focus from one tree cell to another, the NPE occurs in ColumnViewerEditor |
25231 |
Wed, 24 July 2019 10:21 By: Sanket W ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Compiler compliance in build.properties limited to Java 8? |
59119 |
Tue, 28 May 2019 17:46 By: Glenn Burkhardt ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Exporting product While exporting product illegal character in path |
43697 |
Tue, 07 May 2019 12:29 By: Ramesh Javalagatti ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to unbind F2 key programatically in eclipse java plugin development How to unbind F2 key programatically in eclipse java plugin development |
4644 |
Wed, 24 April 2019 14:11 By: Sharmila D ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Compile behaviour of OSGI DS annotation support |
69571 |
Mon, 01 April 2019 13:20 By: Peter Nehrer ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Eclipse Application causing Desktop Heap allocation failure Desktop Heap allocation failure in Windows |
61826 |
Wed, 27 February 2019 04:48 By: Priyadharshini K ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Pre-work on a file before opening |
34033 |
Sun, 24 February 2019 15:38 By: Martin Rud ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Custom project with existing features |
10860 |
Mon, 18 February 2019 20:41 By: Martin Rud ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Plugin not working on latest Eclipse versions Plugin which was built using Eclipse-rcp Neon is not working on Eclipse Photon |
3597 |
Sun, 13 January 2019 23:12 By: Ammad Ahmed ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
P2 requirements/information |
2770 |
Wed, 28 November 2018 18:28 By: Jan Jansen ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Reference the latest IU in target file |
3387 |
Wed, 21 November 2018 07:57 By: Moritz Aleithe ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Plugin development how to for beginners develop a plugin for a program originally written in C |
1972 |
Fri, 16 November 2018 07:02 By: Moritz Aleithe ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Solution to sign plugin jar with less cost Ask to find solution that helps FOSS project to distribute signed plugin |
2186 |
Fri, 09 November 2018 08:06 By: Kengo TODA ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Weblogic Connection Issues using SSL & Admin Port Issues connecting to WebLogic admin port 9002 with SSL enabled |
3547 |
Mon, 29 October 2018 06:28 By: Rohit Pujar ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Unable to run nodejs from eclipse plugin using J2V8 |
1821 |
Wed, 26 September 2018 05:43 By: Naveena Bellamkonda ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Debugging plugin does not work with photan |
3578 |
Wed, 26 September 2018 05:41 By: Naveena Bellamkonda ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Access JavaFX from a eclipse plug-in code in Java 8 |
2558 |
Thu, 13 September 2018 15:10 By: chaitanya tangudu ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Exporting Feature Fails - Photon 4.8.0 circular dependency problem despite checking box "Allow for binary cylces in target platform" |
4048 |
Tue, 11 September 2018 20:50 By: Miriam H. ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
TextEditor AnnotationModel not supporting multiple Documents ? |
3375 |
Mon, 27 August 2018 14:26 By: Jakob Sachs ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
File in the folder don't associated with the editor |
3430 |
Mon, 27 August 2018 13:53 By: Jakob Sachs ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
IWorkbenchBrowserSupport plugin is not working in Oxygen4.7.3a Created a plugin using IWorkbenchBrowserSupport, opens a browser in it, is not working in Oxygen4.7.3.a |
2261 |
Fri, 24 August 2018 07:03 By: navn rddy ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Creating custom JUnit launch configuration in eclipse This topic deals with creating custom run/debug JUnit launch configuration in eclipse for Plugins |
2064 |
Wed, 22 August 2018 05:55 By: prithivraj s ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Different behaviour when running a plugin when using "Launch an Eclipse application", when installed it fails |
4174 |
Sun, 19 August 2018 21:50 By: Gonzalo López ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
binding two explorers binding two explorers |
3861 |
Fri, 03 August 2018 06:33 By: Sharmila D ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
![icon5.gif](images/message_icons/icon5.gif) |
PDE Headless build with Eclipse 4.6 missing laucher The native Launcher files missing if headless pde build is used. |
4920 |
Tue, 31 July 2018 18:54 By: Saravanan S ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Eclipse PDE build not generating launcher file Eclipse PDE build not generating any launcher file |
4019 |
Mon, 30 July 2018 14:00 By: Sunil Kumar ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Eclipse Photon : PDE headless build PDE Build Eclipse Photon RCP Development |
4142 |
Mon, 30 July 2018 09:54 By: Sunil Kumar ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
TreeViewer controls in custom ContentOutlinePage |
28817 |
Thu, 12 July 2018 15:54 By: Nitin Dahyabhai ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
New CDT Wizard does not close Invoking an existing CDT new project wizard works but it doesn't close after finish. |
2403 |
Fri, 15 June 2018 13:22 By: Bjarne Johannsen ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
'Install the Job' has encountered a problem [Export Wizard] |
9688 |
Tue, 05 June 2018 22:03 By: Scott Willis ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Is this the newsgroup for PDE |
26414 |
Wed, 30 May 2018 16:23 By: Eclipse User ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Delete Working Set button never enabled. Is it just me or does anyone else have the same issue with the Delete Working Set button never getting enabled? |
1763 |
Mon, 28 May 2018 17:02 By: Paul Roubekas ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Not able to launch eclipse application from application.product but working from run configuration |
5981 |
Fri, 11 May 2018 11:14 By: monika jain ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Plugin for JMS compliant server How to create plugin for JMS compliant server |
4422 |
Tue, 08 May 2018 10:20 By: Pravin J ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
PDS Filter Creation using API PDS Filter Creation using API |
4104 |
Fri, 04 May 2018 11:58 By: RAVI KUMAR PATNALA ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
MultiPageEditorPart not found when testing RCP app MultiPageEditorPart not found when testing RCP app |
4512 |
Fri, 20 April 2018 20:44 By: Bill Blalock ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Plug-in install on other Eclipses Trying to install my plugin on other Eclipses but not istalling due to missing requirements |
6116 |
Thu, 12 April 2018 06:32 By: Vivek Selvaraj ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
No Application Id found No Application Id found error starting with Java 1.7_45 |
5858 |
Fri, 06 April 2018 15:53 By: Rajiv Pattanaik ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to set chaild of org.eclipse.jface.text.source.SourceViewer as dirty |
5354 |
Tue, 03 April 2018 15:41 By: kozhaev Vladimir ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Missing icon for Java Project when running custom product |
13822 |
Mon, 02 April 2018 04:56 By: Priti Baldawa ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Plugin not auto starting in Eclipse Plugin start on Eclipse Mars (Release 4.5.1) but does not start Eclipse PHP (Oxygen.3 Release 4.7.3) |
5038 |
Fri, 23 March 2018 01:54 By: Eli Barbosa ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
p2 director install fails after successful compilation p2 director PDE headless build |
5659 |
Thu, 15 March 2018 10:42 By: Johannes Faltermeier ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Detect view in which a dynamic pulldown menu was opened |
5553 |
Thu, 08 March 2018 22:41 By: Marian Schedenig ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How can use native library in my Eclipse Plug-in project native library;Eclipse Plug-in project |
4712 |
Thu, 08 March 2018 05:35 By: Chunlin Guan ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Getting Started with plugin development start and stop plugin from another |
3143 |
Tue, 27 February 2018 19:43 By: Tim Baalmann ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to change the icon tab of the text editor on the fly |
5589 |
Fri, 23 February 2018 16:33 By: kozhaev Vladimir ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to refresh view after desired getting value from addSelectionListener method |
4697 |
Tue, 20 February 2018 21:54 By: luft swift ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
PDE Build - conflicting dependency message with no details |
2702 |
Fri, 16 February 2018 13:54 By: John Dallaway ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Eclipse 4.6.3 compilation issues Eclipse 4.6.3 compilation issues |
4767 |
Mon, 12 February 2018 19:29 By: Rohit Pujar ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[New Plugin] Files/Class Favorites or Recents I want a plugin : Favorites Files Explorer's in Eclipse |
4241 |
Mon, 05 February 2018 15:19 By: Hector Daniel ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to repackage Eclipse with default custom code formatter profile? |
5119 |
Tue, 30 January 2018 23:06 By: Gaurav Chodwadia ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
TargetPlatform: org.apache.commons.logging-1.2 does not Show up in run configuration |
5875 |
Tue, 30 January 2018 12:50 By: Christian Eugster ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
View generated by wizard crashes |
5607 |
Mon, 29 January 2018 11:54 By: Vlad Dumitrescu ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
NullPointerException when dragging tab to a new location with custom perspectives |
3854 |
Fri, 12 January 2018 11:06 By: Márk Mátray ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
MacOS and Launching a new Eclipse Application Eclipse application doesn't react |
4209 |
Wed, 03 January 2018 12:05 By: Mehmet Karaman ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Using target definition in headless pde build? |
12980 |
Mon, 01 January 2018 23:51 By: Moritz Aleithe ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Can another Plugin be triggered after creating a new project |
14521 |
Mon, 01 January 2018 23:35 By: Moritz Aleithe ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Select one literal in an enumeration |
5386 |
Sun, 17 December 2017 15:24 By: Christian Eugster ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Not able to call Activator.start method for non java project Not able to call Activator.start method for non java project |
4420 |
Sun, 17 December 2017 15:08 By: Christian Eugster ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Strange Behavior of ade tools |
5457 |
Fri, 15 December 2017 15:30 By: Christian Eugster ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Eclipse editors save as functionality |
2325 |
Wed, 13 December 2017 14:16 By: ayman salah ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
The appearance of markers depend on the editor. Is it possible to get the same maker appearance in both java and JavaScript editors? |
7221 |
Mon, 11 December 2017 13:02 By: ruchira supipi ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Dynamic Menu Contribution on View ToolBar thru plugin.xml |
7433 |
Fri, 08 December 2017 08:38 By: Annamalai Mising name ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Resolve dependencies of an external jar By: 15_ 11 on Wed, 15 November 2017 |
5668 |
Wed, 15 November 2017 04:09 By: 15_ 11 ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
bundle.findEntries(path, pattern, recurse) does not find entries in fragment |
4749 |
Mon, 30 October 2017 19:33 By: Christian Eugster ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
org.eclipse.ui.actions |
2574 |
Mon, 30 October 2017 10:07 By: Leonid Novikov ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
assign shortcut of modifier keys only (double ctrl) Is it possible to assign a double ctrl shortcut to my command? By: Shai A on Thu, 19 October 2017 |
3750 |
Thu, 19 October 2017 09:06 By: Shai A ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
3882 |
Eclipse Oxygen - Uninstall of a plugin doesn't delete from plugins folder Eclipse Oxygen - Uninstall of a plugin doesn't delete from plugins folder |
5565 |
Wed, 11 October 2017 06:33 By: Suresh P ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
error Build path specifies execution environment CDC-1.0/Foundation-1.0. There are no compatible JREs installed in the workspace. |
5443 |
Tue, 10 October 2017 08:14 By: Chari Per ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Misanderstending of org.eclipse.jface.text.Position behaviour Incorrect code folding |
6525 |
Thu, 05 October 2017 14:58 By: kozhaev Vladimir ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
6561 |
Thu, 05 October 2017 14:56 By: kozhaev Vladimir ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Problems parsing the feature Error with equinox when exporting my plugin or feature |
11044 |
Thu, 05 October 2017 13:04 By: Hugo Courtes ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
IDE contribution in PDE Built |
12093 |
Thu, 28 September 2017 15:27 By: philipp huebner ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Pop-up context menus in different views |
15486 |
Tue, 19 September 2017 12:23 By: Daniel Clarke ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to Activate a Plugin when leaving the "New Project" Wizard |
15514 |
Tue, 12 September 2017 16:04 By: Faisal Tariq ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to invoke mwe2 workflow run within plugin |
9933 |
Tue, 29 August 2017 16:46 By: Hung Nguyen ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Alert messaging Messaging |
6285 |
Fri, 18 August 2017 21:23 By: Nadav Givoni ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[Feature Proposal / Discussion] Enhance Analysis of compile-time classpath I want to propose an feature to enhance the the root cause analysis capabilities in case of unwanted jars in the plugins classpath |
9843 |
Sun, 13 August 2017 18:31 By: Sebastian Sickelmann ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Code folding, where is my problem? Problem of the patrition code folding. |
9898 |
Wed, 02 August 2017 19:03 By: kozhaev Vladimir ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Tutorial to implement eclipse outline content provider |
10673 |
Wed, 02 August 2017 17:04 By: kozhaev Vladimir ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How do I install the PDE examples? PDE Examples are not obvious to install. |
8027 |
Sun, 23 July 2017 21:40 By: Bill White ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
RCP 3 Fragment does not resolve classes in the host |
13925 |
Wed, 19 July 2017 21:46 By: David Wynter ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to create projection support with contributor class MultiPageEditorContributor |
8314 |
Wed, 19 July 2017 11:45 By: kozhaev Vladimir ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
INamedHandleStateIds.NAME does not work |
5395 |
Tue, 18 July 2017 23:47 By: Chris So ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Defer Plugin Loading on Eclipse Startup Delaying Start/Loading of plugin while eclipse starts up |
3415 |
Sat, 15 July 2017 09:47 By: anu chawla ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to populate custom list data (two levels) using CheckedTreeSelectionDialog How to populate custom list data (two levels) using CheckedTreeSelectionDialog |
11457 |
Wed, 05 July 2017 12:38 By: Suresh P ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How get list of files by a pattern |
9010 |
Wed, 28 June 2017 12:00 By: saravanakumar Mohanasundaram ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to programmatically access to workspace preferences |
19131 |
Wed, 28 June 2017 11:29 By: saravanakumar Mohanasundaram ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How to implement code folding in the custom editor |
13911 |
Wed, 28 June 2017 11:06 By: saravanakumar Mohanasundaram ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Build tab |
12518 |
Mon, 19 June 2017 06:25 By: Banafsheh Azizi ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
