Jakarta Persistence 3 Support What is planned ? |
1983 |
Tue, 18 July 2023 18:33 By: Emmanuel Amblard ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
To partially Match cell against another partial cell |
8114 |
Wed, 01 February 2023 04:59 By: James Millere ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Cannot generate entities from existing MySQL db using JPA Tools |
7725 |
Thu, 21 November 2019 20:45 By: Russell Longo ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
JPQL Error: collection-valued path '...' cannot be resolved to a valid association field Defining a NamedQuery, the Validator signals me an Error but the query works well ... |
8810 |
Mon, 02 September 2019 07:29 By: Kim Sönksen ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Integer instead of int How to create custom default java datatypes in generated entities |
5102 |
Wed, 11 October 2017 21:02 By: marc feldman ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Can't create connection to SQL Server JPA Connection Issues |
10605 |
Wed, 23 August 2017 18:16 By: Chuck Williams ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Validating IN expression still incorrectly shown as error |
11443 |
Tue, 30 May 2017 11:35 By: Karsten Wutzke ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
![icon8.gif](images/message_icons/icon8.gif) |
JPA Diagram massive error error of entiry creation |
51104 |
Fri, 18 November 2016 16:52 By: Anirban Sanyal ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[NamedQuery/JPQL/Validation] - No Aggregatfunction possible within a SELECT |
21019 |
Tue, 08 November 2016 18:31 By: Stefan Jodl ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
31569 |
Wed, 31 August 2016 18:44 By: Eclipse Webmaster ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Why is the word DISPLAY handled as a reserved word reserved words in generate entities from tables |
4175 |
Wed, 22 June 2016 17:13 By: Luis Muñoz ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Don't see Diagram Editor in Mars No project > Tools > Diagram Editor |
9877 |
Fri, 05 February 2016 10:27 By: Petya Sabeva ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Create Entities from Table - column only of java type objects? |
7372 |
Wed, 21 October 2015 10:22 By: Britta Varwig ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Dali with hibernate generating tables error |
4302 |
Sun, 27 September 2015 21:42 By: Bea Perez ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Unable to add more than one Java Entity to diagram |
6348 |
Fri, 24 July 2015 09:12 By: Mini Cooler ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
mapping file is resource in a dependency...eclipse complains |
4768 |
Thu, 18 June 2015 16:15 By: John J. Franey ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
JPA Tools > Generate Entities from Tables, @Column strange format |
3243 |
Tue, 19 May 2015 14:29 By: Neil Hauge ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
The configured runtime is insufficient to provide an implementation for JAXB 2.2 |
13423 |
Thu, 26 March 2015 16:05 By: David Goodenough ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
SAXParseException when compiling through maven When I compile my project through mvn I get some SAXParse exceptions, even though I can build and run my project no problem |
3558 |
Mon, 09 March 2015 13:54 By: Paul Fullbright ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
JPA diagramm schema definition |
3419 |
Thu, 26 February 2015 23:59 By: Alexander Rotnov ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
JPA validation fails for EmbeddedId if Embeddable class is in another project |
3248 |
Tue, 20 January 2015 15:37 By: Neil Hauge ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
one-to-one foreign not primary key association mapping error in dali one-to-one foreign not primary key association mapping error in dali |
2927 |
Thu, 30 October 2014 17:37 By: Neil Hauge ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
JPA Diagram Editor 1.1.1 and Eclipse Luna 4.4.1 Should it work? |
11387 |
Fri, 06 February 2015 17:45 By: Nico Bachmann ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Generate Entities from Tables - Skips One Table |
4666 |
Fri, 15 August 2014 02:14 By: Brian Vosburgh ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
JPA Generate Entities From Tables Fails JPA Generate Entities From Tables Fails on Foreign Keys |
7682 |
Wed, 30 July 2014 15:35 By: Brad OHearne ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
"Generate entities from tables" with common attributes By: G M on Tue, 22 July 2014 |
4145 |
Wed, 30 July 2014 13:55 By: Neil Hauge ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Mistaken JPA Validation Error (Luna) |
4502 |
Mon, 14 July 2014 21:24 By: David Vree ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
![icon5.gif](images/message_icons/icon5.gif) |
Dali generates incomplete and corrupted JPA metamodel |
8477 |
Thu, 07 August 2014 06:29 By: Tobias Liefke ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
eclipse not creating table from jpa entities |
17199 |
Tue, 29 April 2014 10:46 By: assouane khadija ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
JPA Diagram Editor Preferences not available JPA Diagram Editor Preferences not available in the JPA section of Project Preferences |
36012 |
Wed, 14 May 2014 15:47 By: Tony Johnson ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Strange JAXB error message Eclipse JAXB project shows a strange error |
9327 |
Wed, 07 October 2015 07:46 By: Parthiban Annamalai ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Invoke JPA entity creation process from a script Invoke JPA entity creation process from a script By: Krz Pa on Fri, 11 April 2014 |
3107 |
Fri, 11 April 2014 14:47 By: Krz Pa ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Dali and custom Hibernate NamingStrategy |
7678 |
Mon, 13 January 2014 17:05 By: Menno Jansz ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
The runtime error on DALI generated compound primary key Generated entity does not work with EntityManagerFactory (with EclipseLinkJpaVendorAdapter) for compound primary key |
10579 |
Tue, 10 December 2013 21:58 By: Artem Belyaev ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Strange JAXB problem |
6906 |
Thu, 08 August 2013 13:07 By: Reino Ruusu ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Integrating Dali with a third party application |
3716 |
Tue, 06 August 2013 14:38 By: Neil Hauge ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Dali and Plug-in Tooling Conflicts Dali and Plug-in tools do not appear to work together By: Eclipse User on Mon, 15 July 2013 |
4246 |
Mon, 15 July 2013 18:58 By: Eclipse User ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Dali 3.3 released with Kepler |
6920 |
Wed, 26 June 2013 13:24 By: Neil Hauge ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
errors in entity classes generated from Table |
5944 |
Fri, 14 June 2013 15:22 By: Victor Germain ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Headless mode via ant or the like? |
10402 |
Mon, 10 June 2013 20:25 By: Neil Hauge ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
JPQL Refactoring? Is there any support for refactoring of JPQL queries? |
4280 |
Mon, 22 April 2013 17:07 By: Neil Hauge ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Hibernate to JPA 2.0 migration issues |
5403 |
Mon, 08 April 2013 19:05 By: Neil Hauge ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Missing join table in database using JPA Tools -> Generate Tables from Entities Difficulties with Generate Tables from Entities By: G M on Sun, 10 March 2013 |
6272 |
Wed, 13 March 2013 02:03 By: G M ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Reverse engineering - Problem with char columns When creating a bean from the DB, the char columns need to be annotated with @column with the attributes columnDefinition and length |
6273 |
Tue, 12 February 2013 22:29 By: Ramiro Serrato ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
![icon7.gif](images/message_icons/icon7.gif) |
JPA Entity Not Found JPA Problem with Code Migration |
7452 |
Thu, 24 January 2013 18:50 By: Randy Dennis ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Metamodel gets regenerated on Windows/Ubuntu |
7775 |
Wed, 19 September 2012 19:13 By: Brian Vosburgh ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
JPQL validation error: AS in SELECT (with constructor expession) |
9707 |
Mon, 06 August 2012 21:25 By: Pascal Filion ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
JPQL validation error: well-formed character data or markup |
12582 |
Sun, 05 August 2012 17:37 By: Karsten Wutzke ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
JPQL validation errors in named-queries.xml not ignored |
48642 |
Tue, 07 August 2012 16:04 By: Neil Hauge ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Status of how users with multiple projects should use dali/persistence.xml and <jar-file > |
6125 |
Tue, 07 August 2012 10:28 By: Boris Naguet ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Potentially spurious validation message about attribute mapping? |
9184 |
Wed, 01 August 2012 16:43 By: David Vree ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
duplicate post...admin please delete |
6634 |
Fri, 20 July 2012 19:21 By: David Vree ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
6787 |
Fri, 20 July 2012 19:20 By: David Vree ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
cannot use eclipselink 2.x |
17 |
17889 |
Thu, 26 July 2012 16:49 By: Konstantin Komissarchik ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
what is the relationship between Dali and EclipseLink |
4167 |
Thu, 19 July 2012 14:37 By: Neil Hauge ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Eclipselink JPA named query not ignoring white spaces. Eclipselink JPA named query not ignoring white spaces. |
5614 |
Tue, 10 July 2012 20:25 By: Chandra Narasimha ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Dali 3.2 released as part of Eclipse Juno! |
12388 |
Sun, 21 October 2012 03:32 By: Ari Meyer ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
JPA entites from tables |
10376 |
Mon, 25 June 2012 11:07 By: jimmy pannier ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Poll: Setting level to warning for all validations Is there an easy way to set level to warning for all validations By: Ali K on Thu, 07 June 2012 |
10299 |
Thu, 07 June 2012 13:30 By: Ali K ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
JPA + Hibernate + Sybase ASE Can't make reverse engineering with a Sybase database |
12914 |
Thu, 07 June 2012 13:22 By: Neil Hauge ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Entity Bean Generation from Postgres 8.4 database |
33003 |
Tue, 10 April 2012 07:57 By: shalin lazar ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Bug or a feature? @Column annotation is not always generated. @Column annotations do not get created for unused columns by the entity generation wizard. |
5522 |
Thu, 22 March 2012 06:41 By: Matej Liszka ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
![icon4.gif](images/message_icons/icon4.gif) |
Generate entities from tables across multiple Oracle schemas Foreign keys across Oracle schemas cannot be mapped to entities. Any workaround except manual editing? |
6587 |
Wed, 21 March 2012 13:58 By: Neil Hauge ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Configure Default on New JPA Project Wizard |
4358 |
Thu, 15 March 2012 21:39 By: Paul Fullbright ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
JPA validation error on JPQL long state field path |
18411 |
Tue, 07 June 2016 21:46 By: David Vree ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Preselected JPA Platform and Implementation on JPA Facet page? |
10263 |
Thu, 15 March 2012 14:25 By: Paul Fullbright ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Can't add entity class that doesn't have @table into the diagram |
5235 |
Thu, 08 March 2012 16:57 By: Cristiano Gavião ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Generate tables from entities stop to work after convert JPA into a OSGi project |
6939 |
Sat, 10 March 2012 16:56 By: Cristiano Gavião ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Calls to ClasspathHelper in JPA facet install delegate |
5532 |
Wed, 07 March 2012 20:22 By: Paul Fullbright ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
JPA Diagram Editor and JEE INDIGO error. How enabled JPA Diagram Editor for JEE INDIGO? |
7826 |
Wed, 07 March 2012 16:20 By: Oscar Vasquez ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
NPE in Indigo SR2 when adding JPA facet |
10521 |
Tue, 06 March 2012 23:06 By: Neil Hauge ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Eclipse JPA problem on a named query that doesn't have a problem |
7354 |
Tue, 28 February 2012 06:24 By: David Vree ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Unable to generate JAXB classes Unable to find the main class: java.util.Arrays.useLegacyMergeSort=true |
14050 |
Thu, 23 February 2012 20:01 By: Neil Hauge ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Sybase ASE 15: User data types mapped to java Object type |
5633 |
Wed, 08 February 2012 22:18 By: Brian Vosburgh ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
New JPA Project Wizard Platform filtering possible? |
4949 |
Thu, 02 February 2012 22:09 By: Neil Hauge ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Generated classes recreated after delete |
9743 |
Thu, 15 December 2011 17:49 By: Neil Hauge ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Help with Porting over to Indigo |
9047 |
Tue, 27 October 2015 18:33 By: Brian Vosburgh ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
JPA-Diagram Editor + JUnit4 Test Synch By: al on Mon, 24 October 2011 |
9330 |
Sun, 30 October 2011 01:19 By: al ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
JPA-Diagram Editor + XMI ? By: al on Fri, 14 October 2011 |
6236 |
Mon, 21 November 2011 18:58 By: al ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Tool to run JPQL queries on the fly |
8048 |
Wed, 02 November 2011 17:31 By: sergio.e.samayoa ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
validation error |
21 |
28568 |
Mon, 07 May 2012 14:30 By: Karen Butzke ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Table Generation from Entities with Embeddable Inheritance By: Hannes on Wed, 14 September 2011 |
5115 |
Wed, 21 September 2011 15:18 By: Neil Hauge ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
long & BigDecimal mappings in entities from tables |
6371 |
Wed, 07 September 2011 16:29 By: Steve Maring ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Using Dali annotation processor from a maven build |
15444 |
Mon, 29 August 2011 14:43 By: Neil Hauge ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
JPA Facet doesn't recognize Hibernate as legitmate By: yurchp on Thu, 04 August 2011 |
59910 |
Sat, 30 June 2012 20:40 By: Pawel Wloch ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
JPA Diagram editor 0.5.0 not working with Graphiti 0.8.0 Issues with JPA diagram: org.eclipse.swt.SWTException |
7239 |
Wed, 03 August 2011 07:33 By: Olivier Mising name ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
JPA 2.0 metamode gen and orm.xml |
4964 |
Thu, 21 July 2011 15:42 By: Neil Hauge ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Dali New Feature Planning for Juno - JPA Matadata Conversion By: Nan Li on Thu, 07 July 2011 |
12508 |
Thu, 07 July 2011 21:14 By: Nan Li ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Dali 3.0 released as part of Indigo! |
11983 |
Wed, 22 June 2011 14:11 By: Neil Hauge ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
entity not generated for 1 table (sql server 2008) By: Lionel on Tue, 14 June 2011 |
5145 |
Thu, 16 June 2011 18:19 By: Neil Hauge ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Error: Dali not correctly validating @EmbeddedId ID classes |
6969 |
Thu, 19 May 2011 10:35 By: Karsten Wutzke ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
JPA Tools -> Entity from Tables Does not generate any @Id or Foreign key |
10588 |
Mon, 16 May 2011 16:12 By: Neil Hauge ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
No persistence.xml file found in project? |
32871 |
Tue, 17 May 2011 10:07 By: Karsten Wutzke ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
"Generate Table from Entities" and reserved words |
7859 |
Tue, 03 May 2011 14:57 By: Brian Vosburgh ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Add JPA validator to JavaSE project |
9740 |
Mon, 16 May 2011 16:08 By: Paul Fullbright ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Can't browse schemas |
4639 |
Wed, 27 April 2011 14:18 By: Neil Hauge ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
provisional API changes |
10924 |
Tue, 26 April 2011 14:40 By: Brian Vosburgh ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Unable to get Entity back from database as the Entity object. Data is returned as a java.lang.Object not my Entity object. By: ekim on Wed, 13 April 2011 |
6233 |
Thu, 14 April 2011 22:35 By: ekim ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Unable to generate JAXB classes Using Jdk 1.6 xjcfacade not flound |
42433 |
Sun, 24 July 2011 00:14 By: Dan ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Generate entity from table programmly By: Marou on Thu, 24 March 2011 |
5279 |
Fri, 25 March 2011 14:39 By: Brian Vosburgh ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[SOLVED] Limited number of tables Data source view show limited number of tables By: Enrico on Wed, 16 March 2011 |
4291 |
Wed, 16 March 2011 14:44 By: Enrico ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Force specify persistence provider for generate tables Problems generating tables from entities due to incorrect persistence provider |
6616 |
Tue, 15 March 2011 21:28 By: Neil Hauge ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
orphanRemoval=true By: Reny on Thu, 18 November 2010 |
5978 |
Fri, 19 November 2010 14:52 By: Neil Hauge ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[SOLVED] MySql Mapping BOOL -> byte must involve in BOOL -> Boolean [SOLVED] Customize type mapping generation By: Reny on Fri, 05 November 2010 |
6421 |
Mon, 08 November 2010 11:55 By: Reny ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Exporting UML profiles from RSA in Ecore format By: Pejman on Fri, 10 September 2010 |
5743 |
Mon, 13 September 2010 12:01 By: Pejman ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Auto Generate Comments |
5018 |
Wed, 01 September 2010 15:07 By: Neil Hauge ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Why so few users for such a fantastic project ? |
7293 |
Thu, 15 December 2011 17:40 By: Neil Hauge ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
What's new in Dali Helios - Demo |
11620 |
Fri, 09 July 2010 19:42 By: Neil Hauge ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Not able to generate the JPA Manager Bean By: Umesh on Thu, 08 July 2010 |
12029 |
Thu, 08 July 2010 18:22 By: Umesh ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Does Dali work with property access? |
11097 |
Tue, 06 July 2010 05:46 By: David Vree ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Indigo feature planning - Refactoring participation |
11516 |
Mon, 28 June 2010 15:06 By: Karen Butzke ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Dali 2.3 released with Helios! |
11325 |
Wed, 23 June 2010 13:25 By: Neil Hauge ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Eclipse RCP et JPA |
4141 |
Mon, 07 June 2010 17:26 By: Shaun Smith ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Re: Creating New JPA Project - Configuration Options |
11117 |
Thu, 20 May 2010 19:00 By: Paul Fullbright ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
4581 |
Thu, 20 May 2010 18:57 By: Paul Fullbright ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Question about default JPA platform |
3716 |
Wed, 17 March 2010 21:28 By: Paul Fullbright ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
EclipseLink, DDL and INTERACT_WITH_DB |
5545 |
Wed, 17 March 2010 22:55 By: Andrew Hume ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
using synonyms resolving to tables in another schema |
10978 |
Fri, 26 February 2010 10:08 By: Ari Meyer ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Mapping file "META-INF/orm.xml" does not have ORM content |
11154 |
Fri, 26 February 2010 09:09 By: Ari Meyer ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
javax.naming.NoInitialContextException using "generate tables from entities" By: MJ on Mon, 01 February 2010 |
5432 |
Tue, 02 February 2010 12:18 By: MJ ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Activate 'Java Persistence' and 'JPA Development' Perspective in Eclipse 3.3 By: Markx on Sun, 31 January 2010 |
4439 |
Mon, 01 February 2010 19:51 By: Neil Hauge ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
JPA facet and the utility facet as fixed vs required |
6389 |
Fri, 29 January 2010 21:25 By: Paul Fullbright ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Re: Restricting certain JPA facet versions for particular runtimes |
11031 |
Wed, 20 January 2010 19:23 By: Paul Fullbright ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
6286 |
Wed, 20 January 2010 19:18 By: Leonard Theivendra ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Re: Eclipse JPA project - defining connection to Oracle RAC |
10841 |
Fri, 15 January 2010 20:46 By: No real name ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
5339 |
Fri, 15 January 2010 20:37 By: Neil Hauge ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Run JPA Project without Server |
3874 |
Fri, 15 January 2010 20:26 By: Neil Hauge ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
JPA NamedQuery Result By: Larry on Thu, 10 December 2009 |
3534 |
Thu, 10 December 2009 16:12 By: Neil Hauge ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
resync Tables to Entities? By: Matty on Wed, 09 December 2009 |
5342 |
Thu, 10 December 2009 19:47 By: Neil Hauge ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Customize Composite Key Names By: Dan on Thu, 12 November 2009 |
3875 |
Fri, 13 November 2009 22:04 By: Neil Hauge ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Extensibility of GenerateEntityWizard and GenerateEntityFromShemaWizard |
3631 |
Thu, 05 November 2009 17:53 By: Neil Hauge ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Problem with generating entity from table By: Ludovic on Mon, 02 November 2009 |
4448 |
Fri, 06 November 2009 03:50 By: Ludovic ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Validating OneToMany references to composite key components |
3364 |
Tue, 20 October 2009 15:08 By: Karen Butzke ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
IllegalStateException thrown by Dali By: Dan on Fri, 16 October 2009 |
3823 |
Tue, 20 October 2009 15:23 By: Karen Butzke ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Is it possible to configure Dali By: Gilbert on Wed, 14 October 2009 |
3364 |
Tue, 20 October 2009 15:32 By: Karen Butzke ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How can Primary Key classes be automatically generated? |
10681 |
Fri, 02 October 2009 16:22 By: Alexander Paluch ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
optional property listener |
3447 |
Fri, 25 September 2009 17:02 By: Karen Butzke ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
error: Invalid content (no root node) |
10591 |
Wed, 16 September 2009 17:19 By: Philippe Marschall ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Copied entities to another project, now I get an error message |
10467 |
Fri, 21 August 2009 13:42 By: Torben Putkonen ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
JPA implementation library warning |
10586 |
Wed, 05 August 2009 14:47 By: Leonard Theivendra ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Dali Galileo - Entities and properties naming stragety By: Lionel on Tue, 28 July 2009 |
10604 |
Tue, 28 July 2009 12:50 By: Lionel ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
How do I turn off JPA validation? |
10872 |
Sun, 26 July 2009 23:11 By: Dean Schulze ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Thoughts on JPA 2.0 metamodel generation in Dali 3.0 |
11042 |
Tue, 21 July 2009 15:28 By: Leonard Theivendra ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
JPA dali, moving the persistence.xml |
10503 |
Sat, 18 July 2009 21:06 By: harpritt ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Need your criticism By: sergey on Fri, 26 June 2009 |
10590 |
Fri, 26 June 2009 06:01 By: sergey ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Dali 2.2 (Galileo) is now available! |
10579 |
Wed, 24 June 2009 13:47 By: Neil Hauge ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Validating inner classes marked with @Embeddable |
10793 |
Thu, 11 June 2009 21:22 By: Spencer Uresk ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Extensibility of new entity gen wizard? |
10603 |
Thu, 28 May 2009 19:27 By: Leonard Theivendra ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
EclipseCon 09: Building your First JPA Application with Dali JPA Tools |
10558 |
Thu, 14 May 2009 18:35 By: Neil Hauge ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Question about executing JPQL? |
10618 |
Mon, 11 May 2009 08:43 By: kiril mitov ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Bug 197069 Support for entities in Jars |
10373 |
Mon, 06 April 2009 21:39 By: Brian Vosburgh ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Entity generation wizard does not detect relationships involving composite keys |
10435 |
Wed, 01 April 2009 19:33 By: Kevan Holdaway ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Are synonyms suppose to show up in the entity wizard? |
10078 |
Wed, 18 March 2009 21:00 By: Kevan Holdaway ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Entity Wizard omits columns in entity if foreign key |
7855 |
Tue, 17 March 2009 19:52 By: Kevan Holdaway ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Project without annotaions in the model classes |
7222 |
Sun, 15 March 2009 22:17 By: Heiko Ahlig ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Dali 2.1.1 Released |
4651 |
Tue, 03 March 2009 19:14 By: Neil Hauge ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Generate Entities from Tables not working |
4440 |
Fri, 13 February 2009 16:02 By: Karl Stenerud ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Generate Entities not adding @Table or @Column annotations |
4609 |
Wed, 11 February 2009 20:55 By: Rick Crawford ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
no JPA implentation information in "modify JPA facet" dialog By: Tom H on Thu, 05 February 2009 |
4622 |
Thu, 05 February 2009 07:27 By: Tom H ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Help setting up Dali in eclipse 3.5 on fedora 10, for use with RAP OSGI platform By: Tom H on Thu, 05 February 2009 |
4448 |
Thu, 05 February 2009 07:06 By: Tom H ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
what would it meant to use "Generic" as the JPA platform By: Tom H on Thu, 05 February 2009 |
4332 |
Thu, 05 February 2009 01:51 By: Tom H ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
question on ResourceModelListener |
4495 |
Fri, 30 January 2009 05:18 By: Brian Vosburgh ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Dali 2.2 and JPA 2.0 tolerance |
4266 |
Tue, 20 January 2009 15:01 By: Leonard Theivendra ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
NPE when generating entities from Oracle 11g DB |
4406 |
Mon, 19 January 2009 23:12 By: Chris Jaun ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Dali reports that some fields cannot be resolved |
4294 |
Wed, 14 January 2009 19:46 By: Cesar Perez ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Confused: JPA Tools >generate tables from entities |
6239 |
Mon, 12 January 2009 18:12 By: Wolfgang ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Dali 2.1 is now available! |
4448 |
Mon, 22 December 2008 21:39 By: Neil Hauge ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Dali 2.2 Planning |
4247 |
Wed, 10 December 2008 23:54 By: Neil Hauge ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Generating annotations in getters |
4435 |
Tue, 09 December 2008 13:38 By: Marcelo Alcantara ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Join Table cannot be resolved |
4640 |
Mon, 08 December 2008 20:28 By: Marcelo Alcantara ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
API changes in recent Dali 2.1 builds |
4362 |
Fri, 05 December 2008 15:12 By: Leonard Theivendra ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[Fwd: [dali-dev] Many to many relationship problem] |
4911 |
Tue, 02 December 2008 20:47 By: Brian Vosburgh ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Migration from Dali 2.0 to 2.1 |
4455 |
Tue, 02 December 2008 20:06 By: Paul Fullbright ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
[Fwd: [dali-dev] questions on monitoring changes on JPA Model] |
4246 |
Mon, 24 November 2008 14:59 By: Brian Vosburgh ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Problems running WTP 3.0.3 in Eclipse 3.4.1 |
4772 |
Sat, 22 November 2008 00:22 By: Steve Kuo ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
"This mapped class is not specified in persistence unit" and related issues |
5312 |
Tue, 18 November 2008 01:06 By: Steve Kuo ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Shared persistence.xml |
6173 |
Mon, 03 November 2008 17:59 By: Felipe Kamakura ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
session bean generation? By: Ulrich on Tue, 21 October 2008 |
4634 |
Tue, 21 October 2008 17:36 By: Ulrich ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
JPA Catalog Explorer and JPQL Query Builder |
4624 |
Wed, 08 October 2008 11:27 By: Philippe Weber ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Dali 2.1M2 Declared |
4466 |
Mon, 29 September 2008 20:58 By: Neil Hauge ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
SQL Server 200 tinyint mapping to Object By: Krishna on Sun, 14 September 2008 |
4591 |
Sun, 14 September 2008 18:21 By: Krishna ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
@Entity gives mapped class not specified error with 2 persistence units |
4605 |
Mon, 08 September 2008 23:12 By: Bill Blalock ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Collection enum By: Edward on Mon, 08 September 2008 |
4308 |
Mon, 08 September 2008 21:12 By: Edward ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Typesafe JPQL query in EclipseLink By: Rakesh on Sun, 03 August 2008 |
4268 |
Sun, 03 August 2008 08:41 By: Rakesh ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Dali 2.0 New Feature Highlights |
5809 |
Thu, 17 July 2008 14:52 By: Neil Hauge ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Dali on Macos By: bob on Thu, 17 July 2008 |
4504 |
Thu, 17 July 2008 08:32 By: bob ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
persistence.xml and orm.xml are not copied to build folder By: Eclipse User on Wed, 16 July 2008 |
5042 |
Wed, 16 July 2008 06:59 By: Eclipse User ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
"Unresolved generator name" if no class is not annotated with @Entity |
4770 |
Mon, 14 July 2008 09:58 By: Vadim Dmitriev ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Hibernate @GenericGenerator is not recognized by @GeneratedValue By: Eclipse User on Fri, 11 July 2008 |
5390 |
Fri, 11 July 2008 03:08 By: Eclipse User ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Dali 2.0 is now available! |
4838 |
Mon, 07 July 2008 22:36 By: Neil Hauge ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Probem getting basic sample running |
4768 |
Fri, 04 July 2008 09:11 By: Joel Rosi-Schwartz ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Re: embedding JPQL in a typesafe manner |
4771 |
Fri, 04 July 2008 08:57 By: Miguel Garcia ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
4804 |
Tue, 01 July 2008 14:12 By: Miguel Garcia ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Dali fails with Entity's from JAR |
4779 |
Sat, 24 May 2008 05:10 By: Jason Drake ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Problems with Eclipse Europa and DB2 By: Eclipse User on Mon, 12 May 2008 |
4594 |
Mon, 12 May 2008 19:21 By: Eclipse User ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
EclipseUML 2008 is now fully Dali Compliant |
4635 |
Sun, 27 April 2008 09:43 By: Vlad Varnica ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Error: No persistence.xml file in project By: Eclipse User on Thu, 24 April 2008 |
4579 |
Thu, 24 April 2008 20:00 By: Eclipse User ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Any guidelines (now or planned) for extenders? |
4769 |
Tue, 15 April 2008 23:01 By: Mike Yawn ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Misplaced annotations |
4710 |
Tue, 15 April 2008 16:45 By: Mike Yawn ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
Generating Interfaces |
6180 |
Tue, 01 April 2008 18:59 By: Mike Yawn ![Go to the last message in this topic](theme/Solstice/images/goto.gif) |
