Java SE '21' is not fully supported yet When will support be official? |
1641 |
Wed, 17 July 2024 14:23 By: Tom Eugelink |
Running Eclipselink JPA in OSGi Environment OSGi eclipselink JPA |
804 |
Thu, 11 July 2024 08:20 By: Christian Eugster |
PersistenceUnitLoadingException |
793 |
Wed, 10 July 2024 14:22 By: Christian Eugster |
_persistence_checkFetchedForSet(java.lang.String) Failed to create work Order after spring data upgrade |
1500 |
Tue, 11 June 2024 05:27 By: Priyanshu Gupta |
NoInitialContextException javax.naming.NoInitialContextException: Need to specify class name in environment or system property, or in an application resource file: java.naming.factory.initial |
677 |
Fri, 31 May 2024 11:17 By: Kalai S |
Eclipselink4.0.2 jar compatibility queries |
1289 |
Fri, 03 May 2024 09:33 By: Kalai S |
Eclipselink Cache objects filling the memory memory leak |
1024 |
Tue, 09 April 2024 15:39 By: Alfonso Luna |
Concurrently open statements: |
2324 |
Thu, 28 March 2024 15:14 By: Pradeep KC |
createnativequery |
1737 |
Tue, 26 March 2024 04:45 By: Jayaram Subramanian |
Eclipselink slow on merge - Register the existing object Register the existing object |
2001 |
Mon, 25 March 2024 09:29 By: Simone Di nobile |
How should static weaving be done in EclipseLink recent versions like 4.0.0 EclipseLink |
862 |
Fri, 22 March 2024 05:16 By: Alok Kumar |
Delete operation calling update statement to make foreign key field to null Delete operation calling update statement to make foreign key field to null |
1845 |
Wed, 20 March 2024 21:03 By: Chris Delahunt |
How to generate Metamodel classes with maven |
453 |
Wed, 13 March 2024 13:06 By: Radek Felcman |
Unable to use cache coordination |
654 |
Thu, 07 March 2024 10:06 By: Gonçalo Bernardo |
UCP connection labelling callback in eclipse link jpa |
657 |
Wed, 06 March 2024 20:02 By: Jayaram Subramanian |
few questions on RepeatableWriteUnitOfWork / IsolatedCache we have an old application relying more on eclispe link 2.7 without JPA |
6363 |
Tue, 13 February 2024 13:33 By: Marc Godin |
Using a @Converter on (nullable) foreign key fields |
8884 |
Thu, 25 January 2024 17:02 By: Adam Saghy |
Recommended way to model money (jsr354) and query by amount or by currency ? |
1183 |
Fri, 19 January 2024 11:53 By: Laurenzo Staal |
Enabling weaving - problems and advice on migration Problems with enabling weaving in order to fetch entities lazily |
739 |
Wed, 17 January 2024 16:00 By: Chris Delahunt |
Globally map boolean fields onto smallint in Postgres |
742 |
Tue, 16 January 2024 18:33 By: Chris Delahunt |
Deletion of entity throwing foreign key constraint for unidirectional mapping Deletion of entity throwing foreign key constraint for unidirectional mapping |
1602 |
Fri, 05 January 2024 14:28 By: Chris Delahunt |
delete operation not happening in child object for relationship mapping delete operation not happening in child object |
2581 |
Fri, 29 December 2023 05:49 By: Sanjana C |
Embedded Persistence Issue Embedded objects that contains a child which has one to many relationship not persisting during merge of parent. |
939 |
Wed, 27 December 2023 16:21 By: Chris Delahunt |
JDBC bind parameters only for one of them JDBC bind parameters only for one of them |
15085 |
Thu, 14 December 2023 22:03 By: Mike Arney |
MappedSuperClass with EclipseLink |
7090 |
Wed, 06 December 2023 18:05 By: Chris Delahunt |
OptimisticLockException Data from Table not getting Refreshed Subsequent query still refers to the old version of the record throwing Optimistic Lock Exception |
1381 |
Wed, 08 November 2023 15:37 By: Chris Delahunt |
distinct with order by sql query not working in eclipsleink distinct with order by sql query not working in eclipsleink |
1099 |
Fri, 03 November 2023 11:30 By: Sanjana C |
How to file an EclipseLink bug |
500 |
Fri, 03 November 2023 10:27 By: Radek Felcman |
Eclipselink gives exception when running TestSuite Eclipselink gives exception when running TestSuite |
2398 |
Mon, 23 October 2023 20:18 By: Chris Delahunt |
Eclipselink generating sequence twice which is unexcepted Eclipselink generating sequence twice which is unexcepted |
1175 |
Mon, 23 October 2023 20:11 By: Chris Delahunt |
Eclipselink with spring giving error while loading descriptor xml Eclipselink with spring giving error while loading descriptor xml |
2336 |
Wed, 20 September 2023 13:15 By: Sanjana C |
Caching or Something else Entity Efficiency |
9620 |
Tue, 12 September 2023 14:58 By: Chris Delahunt |
Eclipselink Static weave maven plugin throwing error Eclipselink Static weave maven plugin throwing error |
702 |
Thu, 07 September 2023 12:17 By: Sanjana C |
Eclipselink throwing error while running junit Eclipselink throwing error while running junit |
1999 |
Thu, 31 August 2023 09:08 By: Sanjana C |
DatabaseException is always logged to server.log I want to test for a lock on a row, this works basically, but an exception is always logged with stacktrace and pollutes the server.log file. |
1137 |
Fri, 21 July 2023 14:18 By: Chris Delahunt |
Memory comsumption with eclipselink (2.7) |
834 |
Wed, 19 July 2023 17:01 By: Chris Delahunt |
refreshIdentityMapResult - refresh cache only when new version How to refresh cache only when there is a new version in database? |
1618 |
Fri, 14 July 2023 15:12 By: Chris Delahunt |
Can't find eclipselink bundle when running java app with docker |
1271 |
Mon, 03 July 2023 07:13 By: Henrik van Onna |
EclipseLink migration 2.1.3 -> 2.7.12 An issue with using the refreshIdentityMapResult() method in version 2.7.12 |
1344 |
Tue, 27 June 2023 07:42 By: Vladislav Vladislav |
EL 3.0.x not writing into DiscriminatorColumn after migration from 2.7.3 In my migrated project the DTYPE column is not being populated by EclipseLink anymore |
4295 |
Thu, 15 June 2023 14:58 By: Chris Delahunt |
XMLIDRef behaviour changed from 3.0.3 to 4.0 XmlID_Annotation is no longer respected from superclasses |
1889 |
Wed, 14 June 2023 09:19 By: Michael Wojke |
Eclipselink 3.0.3 an Java 20 Errors when using Eclipselink 3.0.3 with Java 20 |
1278 |
Wed, 14 June 2023 09:16 By: Michael Wojke |
Error calling PostgreSQL stored procedure |
3226 |
Fri, 19 May 2023 00:49 By: Chris Delahunt |
TopLink migration to Eclipselink TopLink migration to Eclipselink |
2044 |
Fri, 19 May 2023 00:12 By: Chris Delahunt |
Analyze Profiler Logs |
1056 |
Wed, 26 April 2023 08:45 By: Marco Rohn |
Is there a way to ignore a field when writing history table with @Customizer |
1177 |
Wed, 12 April 2023 09:09 By: Renato Freire |
Exclude field when creating history table by using @Customizer |
1093 |
Wed, 12 April 2023 08:37 By: Renato Freire |
Spring orm toplink to eclipselink Migration of spring.orm.toplink.* to eclipselink |
732 |
Wed, 05 April 2023 19:07 By: Chris Delahunt |
Ping test failed error Ping test failed error |
1360 |
Wed, 29 March 2023 14:24 By: Chris Delahunt |
Eclipselink nosql with MongoDB Atlas Find JPA persistence unit settings to connect to MongoDB Atlas |
1357 |
Wed, 29 March 2023 10:08 By: Marcus B. |
Spring Transactions with ecliplink jpa Spring Transactions with ecliplink jpa |
1374 |
Wed, 29 March 2023 12:54 By: Sanjana C |
Transactions not working in junit with eclipselink Transactions not working in junit with eclipselink |
3778 |
Tue, 14 March 2023 09:31 By: Sanjana C |
Find managed entities in PersistenceContext How to avoid duplicated managed entities |
5087 |
Sat, 11 March 2023 16:32 By: Ulrich Cech |
Migration from Eclipselink 3.0.2 to 4.0.0 java.lang.NoClassDefFoundError JsonPlatform |
1546 |
Fri, 27 January 2023 09:25 By: Radek Felcman |
Eclipselink 2.6.9 - Select statements in Logs |
1941 |
Wed, 11 January 2023 18:19 By: Chris Delahunt |
Wrong type returned for aggregate functions over date? EclipseLink db<>Java type mapping |
1782 |
Fri, 06 January 2023 00:43 By: Chris Delahunt |
spring configuration for eclipselink spring-data jpa spring configuration for eclipselink spring-data jpa |
2066 |
Wed, 04 January 2023 16:49 By: Chris Delahunt |
Eclipse Link 4.0.0/MongoDB 6.0.1 unable to connect authSource param missing. Eclipse Link cannot connect to MongoDB with user and password because cannot pass authSource params |
1259 |
Mon, 02 January 2023 23:35 By: Tomás Moreno |
Unable to download EclipseLink 4.0 Documentation PDFs By: M Le on Sat, 24 December 2022 |
1266 |
Mon, 02 January 2023 15:26 By: Radek Felcman |
Multiple Entity Manager Factories? |
1364 |
Mon, 05 December 2022 15:57 By: Chris Delahunt |
L2 cache with OneToMany relationships L2 cache with OneToMany relationships |
2454 |
Mon, 07 November 2022 21:27 By: Chris Delahunt |
Schema changes on application upgrade |
3083 |
Sun, 23 October 2022 12:16 By: Ulrich Cech |
Problem with circular references |
2066 |
Sat, 08 October 2022 04:07 By: Alexander Roytman |
Customizer for VARRAY column |
2094 |
Thu, 29 September 2022 21:44 By: Dave Brosius |
@ManagedInterface to eclipselink specific code |
1743 |
Tue, 27 September 2022 11:56 By: arun rajan |
Missing IN in criteria API SQL Missing IN in SQL |
2465 |
Mon, 12 September 2022 11:29 By: in clause |
Split module conflict between eclipse and jakarta.jakartaee.api Using jakarta.jakartaee.api (provided) and eclipselink (provided) |
3734 |
Fri, 26 August 2022 13:15 By: John Manko |
Toplink 10 to Eclipselink migration Toplink 10 to Eclipselink migration without JPA By: Kamal on Fri, 22 July 2011 |
4050 |
Wed, 24 August 2022 12:49 By: Joe Satriani |
XA data source connection in EclipseLink in SpringBoot application. XA data source connection in EclipseLink in SpringBoot application |
1576 |
Wed, 10 August 2022 10:48 By: Atul Dhiman |
Cascade Issue @OnetoOne Cascade perform multiple updates overrides updated value to existing in DB |
4972 |
Mon, 08 August 2022 18:08 By: Chris Delahunt |
Wrong detected type for MIN operator - I think? EclipseLink db<>Java type mapping |
4425 |
Mon, 08 August 2022 18:00 By: Chris Delahunt |
migrating from openjpa to eclipselink migrating from openjpa to eclipselink |
1093 |
Mon, 08 August 2022 17:19 By: Chris Delahunt |
RollbackException on commit but transaction was successful. NPE received upon getTransaction().commit however the Database has been successfully updated. |
12447 |
Mon, 08 August 2022 17:14 By: Chris Delahunt |
BUG - @PrimaryKeyJoinColumns causes [EclipseLink-7223] when existing a composite primary key |
13642 |
Thu, 16 June 2022 11:50 By: Alfonso Luna |
InheritanceType.JOINED not doing the correct JOIN with composite primary key There is a problem when you try to use Inheritance.JOINED when the superclass has a composite primary key |
2523 |
Wed, 15 June 2022 08:46 By: Alfonso Luna |
JPA project classpath for JDBC driver dependencies using Postgresql JDBC driver with optional junixsocket dependency |
3911 |
Tue, 19 April 2022 14:56 By: Jeremy Jackson |
EclipseLink Validation Exception in Library Eclipse Version 2.7.8 Updates are not allowed |
1692 |
Mon, 21 February 2022 16:09 By: Nitin Dahyabhai |
OpenJDK11 and eclipse link 2.7.1 Compatibility issue - Named query not found |
4548 |
Sat, 19 February 2022 03:09 By: Brad Mising name |
EclipseLink fails with to connect to DB EclipseLink fails to create a clientSession to connect to the DB |
3301 |
Tue, 15 February 2022 19:35 By: ELUser Mising name |
Join condition of INNER JOIN |
8329 |
Tue, 15 February 2022 08:07 By: Thomas Giger |
Migrating EclipseLink from 2.7.x to 3.0.2 Migrating EclipseLink from 2.7.x to 3.0.2 |
3152 |
Thu, 03 February 2022 14:22 By: Radek Felcman |
Downloading EclipseLink5.2.5 -> EclispeLink2.3.3 gives empty zip error JPA Project configuration |
7555 |
Wed, 02 February 2022 09:44 By: Danielle Vigapan |
Persistence Units definitions are conflicting? Using two persistence units, one with annotation and on with orm.xml causes weird behaviour. |
3623 |
Fri, 28 January 2022 16:27 By: Hans Pikkemaat |
duplicate persistence classes in classpath eclipselink vs jakarta.persistence jars |
3369 |
Mon, 24 January 2022 13:34 By: Radek Felcman |
Is there any guide for migration from 2.7.9 to 3.0.x? By: Sean He on Sat, 22 January 2022 |
2904 |
Sat, 22 January 2022 22:29 By: Sean He |
Problems migrating from eclipselink 2.7.8 to 2.7.9 Problems with session customizers |
2576 |
Fri, 21 January 2022 20:42 By: Dave Brosius |
Metamodel Generation orm.xml inside persistence.xml is not relative to path |
3604 |
Thu, 06 January 2022 08:03 By: Hans Pikkemaat |
Extending tables looks up in wrong schema / catalog |
2835 |
Wed, 05 January 2022 14:54 By: Thorsten Hülß |
Attribute Converter with context based encryption Attribute Converter with context based encryption |
3305 |
Mon, 03 January 2022 09:33 By: Hans Pikkemaat |
Strange behavior of property eclipselink.jdbc.batch-writing By: r sr on Fri, 03 September 2021 |
3106 |
Mon, 13 December 2021 18:40 By: Chris Delahunt |
reading Clobs in eclipselink odd error |
3420 |
Mon, 13 December 2021 18:06 By: Chris Delahunt |
P2 Repository for Eclipselink 3.0.2 |
2821 |
Thu, 09 December 2021 08:24 By: Rubén Porras Campo |
class not found issues migrating to 3.0.2 java.lang.NoClassDefFoundError: jakarta/persistence/spi/PersistenceProvider when creating the jpa provider |
7501 |
Thu, 02 December 2021 07:16 By: Radek Felcman |
EclipseLink 2.7.x OneToMany relation and composite id parent id propagation when it's a part of a composite id |
2837 |
Wed, 01 December 2021 16:54 By: Chris Delahunt |
The class was compiled with an unsupported JDK. |
3326 |
Fri, 26 November 2021 09:57 By: Radek Felcman |
XMLAdapter for list not working |
3152 |
Wed, 10 November 2021 12:06 By: Radek Felcman |
MOXy - Json - Remove brackets from collection members |
2647 |
Tue, 28 September 2021 15:58 By: Eoin Flood |
secure password and user name in persistence.xml eclipseLink properties in java SE application |
3065 |
Sun, 19 September 2021 14:57 By: Christian Eugster |
JAXB throws Marshall Exception with message A descriptor with default root element was not found |
3429 |
Sun, 19 September 2021 10:25 By: Christian Eugster |
Weaving EclipseLink entites |
1509 |
Wed, 15 September 2021 07:00 By: Andrei Mura |
Metamodel class not found initialization throws a ConversionException |
2545 |
Tue, 31 August 2021 19:14 By: Ralf Heydenreich |
EllementCollection mapping throws [EclipseLink-6157] |
2372 |
Fri, 27 August 2021 15:35 By: Alfonso Luna |
Deadlock in cache under load Deadlock in cache under load |
11789 |
Mon, 09 August 2021 12:25 By: Nainsy Gupta |
SDO deprecation EclipseLink 3.0 Deprecated Functionality |
2045 |
Sat, 17 July 2021 04:17 By: Aleksandr Sanitckii |
lazy instantiation of collections and the cache how does the cache impact lazy updates to collections |
1966 |
Mon, 12 July 2021 14:36 By: joel sherriff |
JPA INSERT caused Oracle Version_Count increase High an Insert data from eclipselink JPA causing performance issues after Oracle version_count increased high |
2923 |
Fri, 02 July 2021 20:11 By: Chris Delahunt |
Using EclipseLink with latest Wildfly Version (24) ? |
1446 |
Thu, 01 July 2021 21:50 By: Ralph Soika |
JAXB/Moxy @XmlPath(".") conflicts with the XMLAdapter during the unmarshalling JAXB/Moxy issues By: AB B on Mon, 07 June 2021 |
2718 |
Mon, 07 June 2021 13:28 By: AB B |
EclipseLink perfomance issue (QueryImpl) |
1790 |
Tue, 01 June 2021 16:49 By: Chris Delahunt |
Stored procedure call does not work with entity object |
1721 |
Tue, 01 June 2021 06:36 By: Radek Felcman |
JAXB/Moxy Unmarshalling assigns all field values to Map<String,Object> rather than the specifi JAXB/Moxy issues By: AB B on Mon, 31 May 2021 |
2165 |
Mon, 31 May 2021 10:19 By: AB B |
ConcurrentModification Exception in JPA 3.0 Followup Migration issues from EclipseLink 2.2.0 to EclipseLink 3.0 |
3324 |
Thu, 13 May 2021 13:44 By: Chris Delahunt |
OneToMany - org.eclipse.persistence.exceptions.DatabaseException null value in column "parent_id" violates not-null constraint |
3762 |
Wed, 28 April 2021 16:49 By: Chris Delahunt |
ConcurrentModification Exception in JPA 3.0 Has anyone seen this exception in JPA 3.0 |
1755 |
Tue, 27 April 2021 16:43 By: Chris Delahunt |
DYNAMIC ENTITY SERIALIZATION ISSUE COHERENCE GRID CACHE IS NOT ABLE TO SERIALIZE DYNAMIC ENTITIES |
2243 |
Tue, 20 April 2021 18:43 By: Naveen Pilli |
Documentation for refresh.cascade query hint Can someone explain to me what the various options do, exactly? |
1881 |
Mon, 19 April 2021 15:16 By: WARREN WEIS |
Trying to send array of objects on json |
1678 |
Tue, 13 April 2021 05:52 By: Brian Lavender |
Create an array of objects when marshalled to json |
1015 |
Mon, 12 April 2021 23:18 By: Brian Lavender |
Unrecoverable OptimisticLockException Entities in cache get out of sync |
2532 |
Tue, 06 April 2021 00:02 By: Thomas Buckel |
Load subentities with JPQL/EntitGraph is not working with EclipseLink |
2110 |
Fri, 26 March 2021 09:57 By: Dennis Melzer |
IllegalStateException, unknown connection on second transaction in request on JBoss EAP 7.3 server |
3487 |
Fri, 19 March 2021 09:52 By: Geert-Jan Hut |
EclipseLink 3.0 post-upgrade performance degradation |
1485 |
Wed, 03 March 2021 12:31 By: Mark Durant |
[bug] MOXy @XmlNullPolicy not working with enums |
2154 |
Fri, 26 February 2021 19:00 By: ender tercero |
Metamodel generation issue for @NotNull and @Lob byte[] The metamodel class is getting generated with invalid Java causing a compilation error |
4333 |
Mon, 22 February 2021 17:29 By: Aaron Boudreaux |
ClassNotFoundException on EclipseLink MOXy JAXB Inner classes not working |
11877 |
Mon, 22 February 2021 05:27 By: Sambhav Kapoor |
Moxy and enums Potential bug for enum usage in moxy p2 provisioning |
3948 |
Mon, 01 February 2021 11:26 By: Robert Schulk |
EclipseLink DataModifyQuery does not throw fatal exception |
3126 |
Mon, 01 February 2021 02:32 By: Samuel wong |
lazy loading vs detached objects lazy loading vs detached objects |
1540 |
Fri, 29 January 2021 18:36 By: Hans Pikkemaat |
Session-specific eclipselink.jdbc.batch-writing.size |
5446 |
Thu, 28 January 2021 14:27 By: Cosmin Mendrea |
PerformanceMonitor Log output when used in Payara PerformanceMonitor Log output when used in Payara |
6926 |
Wed, 27 January 2021 14:17 By: Hans Pikkemaat |
Automatic entity validation for Container Constaints, doesn't work Validationg a List of Items |
4532 |
Thu, 21 January 2021 10:37 By: Francesco KronosOne |
EL 2.7 JPA-api classess inside eclipselink jar |
2772 |
Fri, 08 January 2021 21:15 By: Pablo Pina |
writing to a blob using streams in eclipselink |
2550 |
Tue, 22 December 2020 15:48 By: Dave Brosius |
Dynamically adding entities to eclipselink persistence |
3613 |
Wed, 16 December 2020 23:50 By: Dave Brosius |
Collection shows different data between database and cache after two inserts |
1304 |
Mon, 07 December 2020 23:14 By: Chris Delahunt |
Java Data Type mapping for DB data type that support timezone Mapping from Java data type to DB data type that support timezone |
2099 |
Tue, 01 December 2020 15:25 By: Chris Delahunt |
Quoted table names in @Column(..., table = "\"Addresses\"") produces DescriptorE |
10878 |
Mon, 30 November 2020 15:58 By: Chris Delahunt |
Failure create-and-extend-tables, foreign key creation, postgreSQL create or extends tables fails if foreign key already exists |
5189 |
Mon, 30 November 2020 15:52 By: Chris Delahunt |
EclipseLink Create-Or-Extend-Tables Foreign Key already exists Re-creation of foreign Key not supported |
4704 |
Mon, 23 November 2020 20:34 By: Chris Delahunt |
Eclipse Link Support with DBC File Eclipse Link with Oracle Database Integration using .dbc File |
2003 |
Fri, 09 October 2020 15:03 By: Abhijit Mishra |
Eclipselink library failed to build(version 2.7.5). please help. Eclipselink library failed to build. please help. |
2449 |
Thu, 24 September 2020 20:19 By: John Bullock |
Eclipselink - dead locks in aqcuire and release deferred locks - Eclipselink 2.4.2 and above |
7398 |
Wed, 23 September 2020 02:09 By: John Bullock |
ConcurrentModificationException in query execution upgraded eclipselink from 2.2.0 to 2.7.7 and migrated to Java 11 |
2796 |
Tue, 22 September 2020 15:20 By: Michael Earl |
Package org.eclipse.persistence.internal.libraries.asm not found building EclipseLink 2.7.0 |
65285 |
Tue, 15 September 2020 19:26 By: John Bullock |
Oracle Hints in subqueries How can i set custom hints in each subquery. |
2313 |
Mon, 07 September 2020 15:16 By: Rafael Garcia |
Null Pointer Exception when Marshalling |
9492 |
Wed, 02 September 2020 04:28 By: Padmanabhan Vijendran |
NoSql bundle not selectable |
7559 |
Thu, 27 August 2020 14:11 By: Christian Eugster |
Unable to retrieve TIMESTAMPTZ from Oracle |
4210 |
Thu, 27 August 2020 13:57 By: Aaron Carnes |
Issue with Primary Key with Postgresql and Audit Trigger 91+ Incorrect PKEY returned on persist when using Audit Trigger 91+ |
2417 |
Sat, 25 July 2020 19:54 By: Adam Chalkley |
How can I share a column between two FKs to the same reference table? |
14575 |
Wed, 22 July 2020 14:06 By: Adam Chalkley |
Error on calling StoredProcedure |
4888 |
Thu, 16 July 2020 14:05 By: Bruno Tavares |
How to create a history for a Many To Many relationship? |
8715 |
Thu, 18 June 2020 10:45 By: Gary Kristen |
Polyglot Composite PU - OneToMany/ManyToMany Polyglot Persistence - Composite PU - OneToMany/ManyToMany |
2899 |
Mon, 15 June 2020 19:09 By: Midori Shiro |
EntityGraph not working in GlassFish By: B J on Fri, 17 November 2017 |
6802 |
Mon, 15 June 2020 17:19 By: Chris Delahunt |
Using Eclipselink with Streams in parallel gives NullPointerException |
2926 |
Thu, 11 June 2020 16:22 By: Chris Delahunt |
How to validate JSON with Moxy on marshaling/unmarshaling? |
3545 |
Wed, 10 June 2020 07:04 By: Yevgeny Lvovski |
ElementCollection List<String> Exception during deployment |
4568 |
Tue, 09 June 2020 15:49 By: Chris Delahunt |
NamedEntityGraph hint does not use table joins NamedEntityGraph hint does not use table joins |
1890 |
Wed, 03 June 2020 23:50 By: Chris Delahunt |
JPA 2.1 AttributeConverter autoApply option not working if converter class extends base class |
8609 |
Wed, 27 May 2020 09:17 By: Jan Ortmann |
Static Weaving and Lifecycle Methods Problems with Lifecycle methods using static weaving |
2405 |
Wed, 20 May 2020 14:32 By: Chris Delahunt |
EclipseLink 2.7.4 mixed approach - Native TopLinkProject and JPA approaches don't work together |
3274 |
Tue, 28 April 2020 01:33 By: krishna Mising name |
Deadlock exception while using jpa with eclipselink on SQL Server |
4098 |
Mon, 27 April 2020 17:43 By: Chris Delahunt |
Embeddable constants incorrectly initialize to the same value Following a read query, constants with multiple values initialize to the same value: the first value read from database, even if the constants have already been initialized. |
11281 |
Thu, 23 April 2020 22:03 By: Farhan Nasim |
Classes with @MappedSuperclass use a lot of memory |
7955 |
Mon, 20 April 2020 15:42 By: Chris Delahunt |
how to Use UNION and Order by Clause in my JPQL Query how to Use UNION and Order by Clause in my JPQL Query |
8936 |
Tue, 14 April 2020 13:13 By: Ali Y. Akgul |
Pdf link in Understanding EclipseLink Concepts 2.7 pointing to 2.6 |
2659 |
Tue, 31 March 2020 12:39 By: Space Borg |
JPQL SQL Function does not accept or escape single qoutes |
3536 |
Tue, 24 March 2020 17:03 By: Jeroen Benckhuijsen |
How to use MOXy as default JAXB implementation? Problems switching to MOXy for migrating an RCP application to Java 11 |
4503 |
Mon, 16 March 2020 16:23 By: Nils Loose |
Insert using identity column and trigger returns wrong primary key When inserting into a table which has a trigger which does an insert into another table returns the id of the record inserted into the other table instead |
4703 |
Mon, 16 March 2020 09:13 By: Francois Thirion |
Multitenant per table and native query |
126048 |
Mon, 09 March 2020 18:48 By: Chris Delahunt |
Merge trying to delete an existing entry while trying to add a new entry Merge trying to delete an existing entry while trying to add a new entry |
2181 |
Mon, 09 March 2020 16:27 By: Chris Delahunt |
EclipseLink throws JPQLException on using SELECT ... AS in a constructor expression |
322788 |
Sun, 01 March 2020 12:34 By: Karsten Wutzke |
add arbitrary JSON to a marshaled bean |
4167 |
Wed, 05 February 2020 08:59 By: Ilya Basin |
LocalDateTime is not mapped correctly LocalDateTime is not mapped correctly in criteriaquery with isTrue |
28433 |
Mon, 27 January 2020 14:01 By: Jeno Tobak |
NPE on a JPQL query with NULL arg: bug? |
43459 |
Wed, 15 January 2020 15:37 By: Karsten Wutzke |
Zombie Entities? Constraint violation when modifying removed Entity |
2375 |
Fri, 03 January 2020 18:54 By: Chris Delahunt |
npe while unmarshal date field as json array By: Juriy K on Mon, 02 December 2019 |
6233 |
Mon, 02 December 2019 10:04 By: Juriy K |
OptimisticLockException activated batch-writing How to get causing object |
3605 |
Mon, 25 November 2019 09:59 By: thorsten kruse |
StackOverflowError Ending in DatabaseField.equals Need help with root cause for StackOverflowError |
4452 |
Mon, 18 November 2019 17:57 By: Narunart Kitiyakara |
EclipseLink Dialect For MariaDB 10.3.* / . 10.4.* EclipseLink Dialect For MariaDB 10.3.* / . 10.4.* |
5795 |
Sat, 02 November 2019 04:44 By: Shridhar Bichchal |
No Snapshots for 2.6.6, 2.7.4 and2.7.5 |
2358 |
Wed, 30 October 2019 14:53 By: Lukas Jungmann |
Size of @OneToMany List Reliable way to know size of @OneToMany List |
7734 |
Tue, 29 October 2019 01:50 By: Chris Delahunt |
"Bug" with JPA InheritanceType SINGLE_TABLE and key |
1684 |
Tue, 29 October 2019 01:47 By: Chris Delahunt |
eclipselink 2.7.4 and java 13 causes java.lang.IllegalArgumentException eclipselink under java 13 causes: java.lang.IllegalArgumentException: Unsupported class file major version 57 |
11331 |
Wed, 02 October 2019 15:18 By: erich siffert |
null exception when using find |
9080 |
Fri, 20 September 2019 02:25 By: Jon Morgan |
@ManyToMany: Why columns order in primary key depends on entity class names? Columns order in relation table primary key doesn't depends on mappedBy attribute |
4169 |
Tue, 17 September 2019 20:02 By: Chris Delahunt |
NamedStoredProcedureQuery with OracleTypes.STRUCT IN parameter doesn't pass String value to db |
1859 |
Wed, 04 September 2019 15:53 By: Tatiana Gaydukova |
Object: is not a known Entity type. New JPA project does not recognize entities. |
12412 |
Wed, 04 September 2019 09:18 By: Hendre Louw |
Foreign Key Constraint generation for SAP HANA Database FK constraints are not generated on HANA |
10393 |
Wed, 04 September 2019 06:10 By: Alexander Parr |
Migration from Toplink to Eclipselink |
3596 |
Wed, 28 August 2019 03:49 By: Chris Delahunt |
Table per tenant not working Problems with table per tenant in EclipseLink |
27306 |
Wed, 28 August 2019 03:21 By: Chris Delahunt |
EclipseLink with Java 9+ |
5226 |
Tue, 13 August 2019 01:36 By: Ossama Nasser |
Optimization batch reading collection after invalidation |
21657 |
Mon, 12 August 2019 14:05 By: Chris Delahunt |
Passing Collection List to In clause in nativeQuery - EclipseLink Could not pass List to in clause |
2237 |
Thu, 01 August 2019 08:35 By: Adem KÖSE |
EclipseLink PreUpdate on OneToOne Relationship not persisted PreUpdate |
1374 |
Wed, 31 July 2019 13:34 By: Sara Rüegg |
NotReadablePropertyException while using SpringData projection |
2956 |
Tue, 30 July 2019 07:46 By: Wojciech Korczynski |
Composite foreign key with a fixed value generates wrong SQL |
1727 |
Mon, 29 July 2019 15:18 By: Francois Thirion |
NullPointerException from getAttribute() |
21931 |
Tue, 16 July 2019 04:18 By: Jin Kwon |
java.lang.IllegalStateException: Could not load the JPQL parser class. Could not load the JPQL parser class. |
18631 |
Mon, 15 July 2019 06:34 By: Prakash Suvarna |
Empty MetaModel when using EclipseLink 2.7.4 EclipseLink 2.7.4 using Criteria API |
33251 |
Tue, 02 July 2019 11:47 By: Hui Jessie |
